Treść opublikowana przez Jack79
Aktualizacja map navi professional
Nie. Mialeś pobrać tylko DVD, ktore cie interesuje. Wszędzie pisalem ze Polska jest na DVD3. Nagrywasz tylko DVD3.
Usunięcie DPF. Czym zastąpić? Co przy okazji?
Według mnie i informacji w materialach BMW trzeba wykodować, bo DDE odpala regenerację sam. There are two kinds of regeneration: - Continuous regeneration: This form of regeneration takes place during normal driving. At exhaust-gas temperatures of between 280-350°C, continuous regeneration takes place in the form of a slow oxidation process. The soot particles cannot be incinerated until the exhaust gases reach the required temperature. - Periodic regeneration: Periodic regeneration is performed automatically by the DDE after no later than 1000 km (600 miles). On vehicles with many short-distance drives, periodic regeneration already starts taking place after just 400 - 800 km (250 - 500 miles). For regeneration, the intake air is reduced by the throttle valve. One or two post-injections are performed. This increases the exhaust-gas temperature to about 600 °C. The soot is incinerated with the residual oxygen. The periodic regeneration is performed at all speeds. The most efficient method is regeneration at a constant speed in excess of 60 km/h (38 mph) over a period of 20-30 minutes. The DDE calculates the time for periodic regeneration from the following values: average distance travelled average driving speed temperature in the diesel particle filter values from the exhaust gas pressure sensor The last successful regeneration can be read out by the diagnosis system The following conditions must be fulfilled for a regeneration: The coolant temperature must be in excess of 75 °C the exhaust-gas temperature before the diesel particle filter must be greater than 240 °C there must be enough fuel (fuel reserve indicator light is not lit up). Whenever the reserve lamp lights up, the regeneration process is suspended. no fault codes from the air mass system, exhaust emission system and sensors must be saved in the DDE The fault codes 480A / 245700 (from F01) and 481A / 245800 (from F01) must display the status "currently not present" Constant driving speed above about 60 km/h (approx. 38 mph). The optimum speed is about 100 km/h (approx. 60 mph).
Ło Boziu, wierzę, że ogarniesz. W linku są wszystkie mapy jakie wypuszcza BMW. Ty potrzebujesz map: Road Map Europe Professional 2019 Więc szukasz tych i odpalasz te. Masz do wyboru chomik lub mega. Mógłbym ci tu link tylko do tego wkleić, ale włączyl mi się tryb nauczyciela :) ufam że ogarniesz :)
BMW E60 530D sterownik świec żarowych spr.
Wiesz, co w 99 procentach przypadków błąd jednak jest. Zaczalbym od poczatku, czyli wyjał sterownik na stół. Przy tej operacji spójrz na pojedyncza wtyczke czy nie jest upalona, chociaż w tym przypadku mialbys błąd wszystkich świec. Potem miernik w dloń i sprawdź przez 12 pinową wtyczke świece. Piny 123478 to kolejne świece. Opór koło 1-3 ohm do masy. No i na koniec obmierzenie sterownika. Na pinach 123478 trzeba obmierzyć swiece. Koleżka tu fajny film nakrecił, który wszystko pokazuje. Jak wszystko jest ok. To na 99 procent wrzanie jest ok.
W wersji EXPERT w funkcjach serwisowych. Z tego co pamietam zakladka MOTOR i tam znajdziesz.
Tu masz wszystkie mapy. https://www.bmw-klub.pl/forum/viewtopic.php?f=91&t=364232 CCC jest tak stare, ze BMW w 2019 przestalo wypuszczać aktualizacje. Ściagasz mape PROFFESIONAL i nagrywasz na płyte najowolniej jak sie da np progrem imgBURN. Polska jest na DVD3. Sciagasz tylko ta ktora potrzebujesz.
Twoje mapy Next 2022-2 sciagniete z torrenta nie są spakowane w winrar tylko folder , tak ma być ? wystarczy zawartość folderu skopiować na pendrive ? pytam bo dotychczas wszystkie mapy były spakowane w winrar. Nie ma znaczenia czym 6sa spakowane. Zazwyczaj uzywam 7zip. Z tego co pamiętam to tutaj nie dawalem żadnego katalogu. Mozesz rozpakować bezposrednio na pendrive. Ma byc na nim katalog 1,2,3,4,5 i trzy pliki. Do rozpakowywania uzywaj najnowszego 7zip.
2.0d 150km chwilowo/czasami chodzi na 3 gary
Ja mialem uwalony wtrysk przez mechanika, ktory szarpal go, żeby wyciagnąć. Za chiny nie chcial wyjść, no i po tej akcji mialem tak jak opisujesz. W momencie gdy gar sie wyłaczał, korekty na nim kosmiczne. Po wymianie wszystko ok. Tylko ja wiedzialem co kto zepsuł. Jak masz błąd świec i świece sprawne to sterownik do naprawy lub nowy kup.
BMW e90 kody błędów
Auto nie komunikuje ci się z alternatorem. Drugi bład o tym mówi. Pierwszy o uszkodzonym BSD. Jak naprawisz problem z alternatorem, to oba błędy znikną. Sprawdź wtyczkę. Spsikaj kontaktem piny, obejrzyj kable.
brak centralnego
Nie prosciej te przrkaźniki wymienić? Koszt mniejszy niż tego modułu, już nie wspomnę o zbędnym kodowanou i szukaniu. Podłączasz i działa. W swoim nowe wsadzałem z 7 lat temu. Do tej pory spokój.
Nie powinien. Nigdy nie sprawdzałem.
Było instalowane i działa. Skąd masz klucz?
Dodałem mapy NEXT EAST 2022-2 Road Map Europe NEXT EAST 2022-2 (chomikuj) https://chomikuj.pl/Jack1979/BMW/BMW+Europe+NEXT+2022-2/EAST Road Map Europe NEXT EAST 2022-2 (torrent) https://mega.nz/file/rNZDXCrZ#J42-K7Dm2dha-OL3Jg88RUEpWEARkPAqNiG7ED9ADvw
Dodałem mapy EAST ROUTE 2022-2 tutaj i na pierwszej stronie. Road Map Europe East ROUTE 2022-2 (chomikuj) https://chomikuj.pl/Jack1979/BMW/BMW+Europe+ROUTE+2022-2/EAST Road Map Europe East ROUTE 2022-2 (torrent) https://mega.nz/file/TFwgxQYL#H6n3Wx8UwgpRMhRongGPVNHMrUOvjfMX0y2_DyCPASs
Jaką nasadką odkręcić fotel w E90
To chyba byl TORX T50
E87 118d - Reset kontrolki informującej o zużyciu klocków
Poczytales to wiesz jak ten dziwny swustopniowy czujnik działa, pewnoe dlatego nikt nye odpowiadał. Ja bym wymienil ten czyjnik na nowy i ewentualnie kompem kasował.
Road Map Europe West PREMIUM 2022-1 [MEGA + Torrent]
Tutaj masz wsztstkie dzialajace https://www.bmw-klub.pl/forum/viewtopic.php?f=91&t=364232&sid=1ffc23850719c484006866af6ceb7c78
Road Map Europe NEXT 2022-2 | 2023-1
Juz dawno wszystko jest :lol: Torrent, chomik i mega https://www.bmw-klub.pl/forum/viewtopic.php?f=91&t=364232&sid=3dc1487a4238cea45fb3a57c3c940493
Check
Najważniejsze to o jakim silniku mówimy. Wnioskuje, ze benzyna jeśli piszesz katalizator. Najproscie bedzie odczytac kody czyms do duagnostyki BMW.
Kody błędów E91 LCI
CAN idzie dwoma kablami, zielonym i zielonym z pomaranczowym kablem zawsze skrecone ze sobą. Błąd mowi że jest problem z komunikacja modulu od poduszek z autem. Loczytaj ten temat. Koles rozwiazał ten problem skasowaniem błedu i odlaczeniem akumulatora. Tylko uważaj, bo masz FRM3, przy odłaczaniu akumulatora możesz uwalic ten moduł https://www.bimmerfest.com/threads/error-a8c4-and-c947.1410048/
BMW Road Map Europe EVO 2023-1 [MEGA]
Nie wypuscili jeszcze nowszej. Przynajmniej na luty 2022 nie bylo jeszcze. Trzeba czekać.
Nie ma takich informacji. Wyobrazasz sobie, plik, ktory informowalby o zmianach w calej Europie. Musisz zainstalowac i obadac.
Check
To zapytaj wróżki, bo z twoim opisem nic się tu nie dowiesz
Kody błędów E91 LCI
Ti sprawdzisz opisy. Napisz co to za silnik chociaż, bo błedy no. Z DDE rożnia się opisem w zakeżnosci z jakiego modulu czytane. https://bmwfault.codes/ C947 MRS: K-CAN Communication fault
E87 PDC problem
Wyjmij oba moduły na stół. One sa identyczne, tylko ten od buzzera ma około 20 elementow dodatkowych. Przełóż wszystkie z zalanego do nowego i wssystko będzie działać. Robilem juz tak. Elementy do przełożenia zazwyczaj nie są mocno zalane. Jak nie masz lutownicy porządnej to daj komuś do przełożenia. To jest najprostsze do zrobienia w tej sytuacji.
