INPA
jest w inpie w menu funkcje specjale - czytaj wszystkie sterowniki i rozpoznawaj wszystkie sterowniki. w tym drugim auto bedzie przeczesane na obecnosc sterownikow i juz bedziesz wiedzial jakie urzadzenia rozpoznaje.
  • Odpowiedzi 3,2 tys.
  • Wyświetleń 1,2 mln.
Nie
Dziekuje :cry2:
Witam mam pytanie czy inpa bedzie smigac na takim fejsie
ale to powinno działać przyciśnij
na razie
Nerwus chodzi Ci oto:
;EDIABAS 6.4.7 Configuration
[Configuration]
; EcuPath
; Description : ECU file path
; Default = .
EcuPath =C:\EDIABAS\ECU
; SimulationPath
; Description : Simulation file path
; Default = .
SimulationPath =C:\EDIABAS\SIMULATION
; TracePath
; Description : Trace file path
; Default = .
TracePath =C:\EDIABAS\TRACE
; CodeMapping
; Description : Character mapping file path
; Default = .
;CodeMapping = C:\EDIABAS\BIN\ansi2oem.tab
; TraceSize
; Description : Maximum size of each trace file [KB]
; Value : 0..32767
; Default = 1024
TraceSize = 32767
; ApiTrace
; Description : Enable/Disable API/User trace
; Value : 0 = Trace disabled
; 1 = User trace
; 2 = User trace + time stamp
; 3 = User trace + time stamp + process id (Win32)
; 4 = Function trace
; 5 = Function trace + time stamp
; 6 = Function trace + time stamp + timing
; 7 = Function trace + time stamp + timing + process id (Win32)
; Default = 0
ApiTrace =0
; IfhTrace
; Description : Enable/Disable IFH trace
; 1 = User trace
; 2 = User trace + interface
; 3 = User trace + interface + time stamp
; Default = 0
IfhTrace =0
; IfhnTrace
; Description : Enable/Disable IFH network trace (with XREMOTE)
; 1 = User trace
; Default = 0
;IfhnTrace = 0
; SystemTraceSys
; Description : Enable/Disable system trace (runtime system)
; Trace levels 1..7
; Default = 0
SystemTraceSys = 0
; SystemTraceBip
; Description : Enable/Disable BIP trace (runtime system)
; Trace levels 1..7
; Default = 0
SystemTraceBip = 0
; SystemTraceIfh
; Description : Enable/Disable IFH system trace
; Trace levels 1..7
; Default = 0
SystemTraceIfh = 0
; SystemTraceNet
; Description : Enable/Disable network trace
; Trace levels 1..7
; Default = 0
SystemTraceNet = 0
; BipDebugLevel
; Description : BIP debug level of ECU files
; Value : 0..32767
; Default = 0
BipDebugLevel = 0
; UbattHandling
; Description : Ubatt ON/OFF handling
; Value : 0 = Ubatt ON/OFF: No EDIABAS error
; 1 = Ubatt ON/OFF: EDIABAS error
; Default = 1
UbattHandling = 0
; IgnitionHandling
; Description : Ignition ON/OFF handling
; Value : 0 = Ignition ON/OFF: No EDIABAS error
; 1 = Ignition ON/OFF: EDIABAS error
; Default = 1
IgnitionHandling = 0
; ClampHandling
; Description : automatic check of clamps for Ubatt and Ignition
; Value : 0 = no automatic clamp check with send_and_receive
; 1 = automatic clamp check with send_and_receive
; Default = 1
;ClampHandling = 1
; TaskPriority
; Description : EDIABAS process/thread priority (only Win32/16)
; Value : 0 = Optimal EDIABAS performance = 8
; 1 = Minimal EDIABAS performance
; 10 = Maximal EDIABAS performance
; Default = 0
TaskPriority = 0
; LoadWin32
; Description : Map EDIABAS Win16 calls to EDIABAS Win32
; Value : 0 = Win16/32 Mapping disabled (Win16-->Win16)
; 1 = Win16/32 Mapping enabled (Win16-->Win32)
; Default = 0 for Windows 9x/Me
; Default = 1 for Windows NT4/2000/XP
;LoadWin32 = 0
; SystemResults
; Description : Enable/Disable system results (ubatt/ignition/jobstatus)
; Value : 0 = Disable system results
; 1 = Enable system results
; Default = 1
SystemResults = 1
; RetryComm
; Description : Repeat failed communication automatically (1x)
; Value : 0 = Retry disabled
; 1 = Retry enabled (1x)
; Default = 1
RetryComm = 1
; Simulation
; Description : Enable/Disable ECU simulation
; Value : 0 = Simulation disabled
; 1 = Simulation enabled
; Default = 0
Simulation = 0
; Interface
; Description : Connected diagnosis interface
; Default = STD:OBD
Interface =ADS
; Additional information (in German) :
; Bitte beachten: Der HW-Treiber fuer das Interface muss installiert sein!
; Interface = STD:OBD
; Beschreibung : Serieller Pegelwandler (Nachfolger von ADS / Anschluss an OBD-Dose)
; Installation : \EDIABAS\HARDWARE\OBD\ODBSETUP (nur noetig fuer WIN NT4, WIN 2000, WIN XP)
; INI-Datei : Suchreihenfolge analog zu EDIABAS.ini
; Unterstuetzung : WIN3.xx : Nein
; WIN95,98 16-Bit : Ja
; WIN95,98 32-Bit : Ja
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = STD:FUNK
; Beschreibung : Funk-Diagnose Interface MDA von Fa. Siemens
; Installation : keine
; INI-Datei : FUNK.INI
; Unterstuetzung : WIN95,98 16-Bit : Ja
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = ADS
; Beschreibung : Serieller Pegelwandler (Anschluss an Diagnose-Dose)
; Installation : \EDIABAS\HARDWARE\ADS\ADS32\ADSSETUP (nur fuer WinNT4 noetig)
; INI-Datei : keine
; WIN95,98 32-Bit : Nein
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = KBUS
; Beschreibung : Serieller Pegelwandler (Anschluss direkt an K-Bus oder I-Bus)
; INI-Datei : keine
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = EDIC
; Beschreibung : Serielles , PCMCIA , PC-Card Interface von Fa. Softing
; Installation : \EDIABAS\HARDWARE\EDIC\SETUP.EXE
; INI-Datei : EDICFW.INI, EDICHW.INI
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = EDICC
; Beschreibung : EDIC-Card C oder EDIC-Card 2 CAN-Interface von Fa. Softing
; INI-Datei : XEDICC.INI
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = STD:CAN
; Beschreibung : PCMCIA CAN-Interface CanCardX/XL von Fa. Vector
; Installation : keine (ausser Installation der CAN-Karte)
; INI-Datei : CAN32.INI
; Unterstuetzung : WIN95,98 16-Bit : Nein
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Ansprechpartner: Hr. Jusko
; Telefon : +49-(0)89/382-35891 (Hotline)
; email : [email protected] (Hotline)
; Interface = STD:ADS4MOST
; Beschreibung : Most-Interfaces von Fa. Oasis
; Installation : keine (ausser Installation der Oasis-Karte)
; INI-Datei : ADS4MOST.INI
; Unterstuetzung : WIN95,98 16-Bit : ?
; WIN95,98 32-Bit : ?
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Ansprechpart.: Hr. Rowedder
; Telefon : 089 / 382-29159
; Interface = REMOTE
; Beschreibung : Anbindung eines EDIABAS-Interfaces über TCP/IP
; Installation : Anpassung der Einträge in [TCP] auf beiden Seiten (ins.: RemoteHost, Port)
; INI-Datei : keine
; WIN NT 4.0, XP : Ja
; WIN XP : Ja
; Sonderfall : Interface OPPS
; Interface = REMOTE:name
; INI-Datei : REMOTE.INI (insbesondere für Parallelbetrieb notwendig)
; In REMOTE.INI stehen unter [name] spezif. Einstellungen(z.B.: RemoteHost, Port)
; WIN XP : Ja
; NetworkProtocol
; Description : Network protocol
; Default =
NetworkProtocol = TCP
;TCP/IP Configuration
[TCP]
; RemoteHost
; Description : server address/name
; Default =
RemoteHost =OPPS
; Port
; Description : IP communication port
; Value : 1000 < port < 30000
; Default =
Port = 3000
;TimeoutConnect
; Description : Timeout for establishing the connection
; Default = 5000
TimeoutConnect = 2000
;TimeoutReceive
; Description : Timeout for receiving a message
; Default = 5000
TimeoutReceive = 2000
;TimeoutFunction
; Description : Timeout for a long function
; Default = 59000
TimeoutFunction = 10000
;DisconnectOnApiEnd
; Description : Enable/Disable Disconnection with function call ApiEnd
; Value : 0 = Disconnection disabled
; 1 = Disconnection enabled
; Default = 0
;DisconnectOnApiEnd = 1
;InitCmd
; Description : Initialization command (normally for OPPS)
; Default =
;InitCmd0 = FE,04,00,03,01
;InitCmd1 = FD,05,00,03,01
; End Of File EDIABAS.ini
;LoadWin32 = 0
No jeżeli pod XP/Vista to raczej 1.
ApiTrace = 7
Tak też przypuszczałem jak mi napisałeś o tym pliku Ediabas.ini, pozmieniam to i zobaczę jak działa. Ale właśnie dostalem info od kolegi który mi robi płytkę do ADS projekt fistera, że PCB obustronne jest już gotowe
Dalej to samo po zmianie ApiTrace=7 SYS0012 Error, nie wiem już co może być, może jeszcze coś innego mam zmienić doinstalować. Jakieś rady?
To nie usunie problemu ale pokaze jego zrodlo. Wrzuc pliki z c:\ediabs\trace ktore sie wygenerowaly.
podpowiedzcie mi gdzie nacisnac zeby zeskanowac dwa bo nie mam czegos takiego na liscie heheh
a moej pytanie jest takie..
Jak w INPA moge zmienic swiatła z automatycznego czujnika zmierzchu na to zeby na automacie cały czas sie paliły ?
Pytanie drugie.. prawdopodobnie musze doprogramować telefon w kompie bo zalozylem oryginalna instalacje.. jak to zrobic.
Pozdr!
Pozdr!
Wszystko zrobisz ale nie INPĄ
NCS lub DIS Ci pomoże :cool2:
BMW KLUB PRZEMYŚL
1 Jeżeli coś może się nie udać — nie uda się na pewno.
2 Nigdy nie kłóć się z głupcem — ludzie mogą nie dostrzec różnicy.
3 Jeżeli udoskonalasz coś dostatecznie długo — na pewno to zepsujesz.
4 Wszystko co dobre jest nielegalne, niemoralne albo powoduje tycie.
5 Niemożliwe jest zbudowanie niezawodnego urządzenia — głupcy są zbyt pomysłowi.
6 Wniosek to punkt, w którym nie masz już siły dalej myśleć.
7 Komputer służy do tego aby ułatwić Ci pracę, której bez niego w ogóle byś nie miał.
Czy ktoś mi może zdradzić co zawiera konfiguracja (dodatek) w INPA o nazwie BMW Group EA-80X i skąd ją można pobrać?
Dziękuje i pozdrawiam.
jak suka nie da to pies nie weźmie
No własnie mm NCS Expert czy jakos tak :) i teraz laduje profil jakis tam Softcos.... :) pozniej edytuje, wpisuje haslo, zaznaczam to indivdualzierun czy jakos tak... i pozniej nie wiem co robic :)
w sumie wszedlem do jakiegos menu gdzie mialem TAGLICHTE ;) czy cos takiego ale nie wiem czy to sie tak nazywa :)
Zawiera jeden fajny skrypt ktory skanuje cale auto w porownaniu do stareszej wersji. Calosc jest w jezyku niemieckim i zawiera skrypyt i potrzebne rzeczy do nowszych auta. To najwazniejsze dla zwyklego zjadacza chleba.
podczas instalacji wyskakuje nie znaleziono archivym lzh. co z tym zrobic ?
programowal juz ktos z Was webasto w ncs ?
TU
i TU
BMW KLUB PRZEMYŚL
podpowie mi ktos co wpisac w tym polu wymaganym do rejestracji
Are you an idiot: *
What is the square root of 49?
Czy jestes idiota ? ile jest pierwiastek z 49 :) to jest napisane po angielsku... czyli wpisujesz 7 i dziala ;)
Zainstalowałem INPE i NCSa, programy się otwierają ale nie ma komunikacji z autem, pokazuje mi się ostrzeżenie HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Serial.
A jak chcę uruchomić jakiś test to wyskakuje IFH-0018:INITIALIZATION ERROR, dodam że ani bateria ani zapłon nie jest podświetlony.
mógł by ktoś z was przesłać mi prawidłowy obd.ini mój troszke niebardzo działa
Moja BetsY zobacz
Interfejsy BMW INPA USB
Instalacje LPG Sekwencyjne montaż serwis
