bmw-power
Treść opublikowana przez bmw-power
  1. ZMIANA FA (VO) Możliwe że kojarzycie ta instrukcje ale nie mam dostępu do samochodu i nie mogę zrobić na żywo. http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/Zmiana%20FA/1_zpsfb435379.jpg 1 ZACZYNAMY OD ZALADOWANIA ODPOWIEDNIEGO PROFILU FILE / LOAD PROFIL Z GORNEGO MENU http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/Zmiana%20FA/2_zpsec1efe87.jpg 2 WYBIERAMY EXPERTMODE/EXPERTMODUS OK WAZNE ZEBY PROFIL BYL ODPOWIEDNIO SKONFIGUROWANY WYBIERAMY EXPERTMODUS KTORY JUZ MAMY USTAWIONY JAK W INSTRUKCJI http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/Zmiana%20FA/3_zps3a50e609.jpg 3 PO ZALADOWANIU PROFILU PRZYCISKI W DOLNYM MENU SA JUZ AKTYWNE WYBIERAMY F1 "VIN/ZCS/FA" ABY ZCZYTAC DANE POJAZDU http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/Zmiana%20FA/4_zpsfa0c1b35.jpg 4 NASTEPNIE F3 "ZCS/FA f. ECU" ABY ZCZYTAC FA Z ECU MUSINY WYKONAC TE CZYNNOSCI ZA KAZDYM RAZEM http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/Zmiana%20FA/5_zpsbf5d7178.jpg 5 WYBIERAMY MODEL NAD KTORYM PRACUJEMY TU NA PRZYKLADZIE E65 OK http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/Zmiana%20FA/6_zpsf15b1a8a.jpg 6 WYBIERAMY MODUL PRZEZ KTORY BEDZIEMY SIE LACZYC W TYM PRZYPADKU CAS OK http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/Zmiana%20FA/7_zpsa5ceb89f.jpg 7 POKAZE NAM SIE MODEL VIN I FA WYBIERAMY F2 "ENTER FA" W CELU ZMIANY FA http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/Zmiana%20FA/8_zpsa81ad8d7.jpg 8 WYBIERAMY MODEL NAD KTORYM PRACUJEMY TU NA PRZYKLADZIE E65 OK http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/Zmiana%20FA/9_zpsea09e3e6.jpg 9 SPRAWDZAMY CZY VIN JEST PRAWIDLOWY OK http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/Zmiana%20FA/10_zpsc0f55142.jpg 10 W POLU "ATTRIBUTE" WPISUJEMY KOD KTORY CHCEMY DODAC MUSI SIE ON ZACZYNAC OD $... NASTEPNIE "ADD" ZEBY GO DODAC KODY SERWISOWE MUSZA SIE ZACZYNAC OD +... OK http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/Zmiana%20FA/11_zps496dcff7.jpg 11 DLA PRZYKLADU WPISUJEMY KOD $655 KLIKAMY "ADD" (DODAJ) ZEBY SPRAWDZIC PRZEWIJAJAMY LISTE POWINIEN SIE NA NIEJ ZNAJDOWAC http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/Zmiana%20FA/12_zps86e0bab0.jpg 12 KOD DODANY W CELU USUNIECIA KTOREGOS Z KODOW KLIKAMY NA NIEGO AZ SIE PODSWIETLI NA NIEBIESKO I NASTEPNIE PRZYCISK DELETE http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/Zmiana%20FA/13_zps661c2238.jpg 13 DLA PRZUKLADU WPISUKEMY KOD +EVER KLIKAMY "ADD" (DODAJ) ZEBY SPRAWDZIC PRZEWIJAJAMY LISTE POWINIEN SIE NA NIEJ ZNAJDOWAC OK http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/Zmiana%20FA/14_zps1d6f6197.jpg 14 PO UDANYM DODANIU KODOW NA DOLE POKAZE SIE NAM TAKIE MENU F6 "BACK" http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/Zmiana%20FA/15_zpsf196e825.jpg 15 F4 "PROCESS ECU" http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/Zmiana%20FA/16_zpsabf039de.jpg 16 WYBIERAMY CAS OK http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/Zmiana%20FA/17_zps2256adb7.jpg 17 NASTEPNIE F2 "CHANGE JOB" (ZMIEN ZADANIE) http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/Zmiana%20FA/18_zps84ad9629.jpg 18 WYBIERAMY "FA_WRITE" OK http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/Zmiana%20FA/19_zps8e121326.jpg 19 SPRAWDZAMY "JOB NAME" MUSI BYC "FA_WRITE" I ECU W KTORYM ZMIENIAMY FA TO CAS F3 "EXECUTE JOB" WYKONAJ ZADANIE FA MUSI BYC ZAPISANE WE WSZYSTKICH GLOWNYCH ECU PRZEZ KTORE MOZNA SIE LACZYC W PRZYPADKU E65 JEST ICH 2 CAS I LMA ALE W INNYCH MOZE BYC WIECEJ I WE WSZYSTKICH MUSI BYC ZAPISANE FA http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/Zmiana%20FA/20_zpsb3177220.jpg 20 WYBIERAMY F1 "CHANGE ECU" (ZMIEN ECU) I WYBIERAMY LMA http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/Zmiana%20FA/21_zps87c57040.jpg 21 WYBIERAMY LMA OK http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/Zmiana%20FA/22_zps6c63fe04.jpg 22 SPRAWDZAMY "JOB NAME" MUSI BYC "FA_WRITE" I ECU W KTORYM ZMIENIAMY FA TO LMA KLIKAMY F3 "EXECUTE JOB" (WYKONAJ ZADANIE) JESLI NP ZMIENILISMY MODUL SWIATEL NA POLIFLINGOWY LM1 NA LM2 I CHCEMY TYLKO SKOPIOWAC / WCZYTAC DO NIEGO FA Z NASZEGO SAMOCHODU NIE MOZEMY SIE LACZYC PRZEZ LMA PONIEWAZ POKAZE SIE VIN I FA Z SAMOCHODU Z KTOREGO BYL WYMONTOWANY MODUL SWIATEL LACZYMY SIE PRZEZ INNY W TYM WYPADKU CAS I NASZE FA SKOPIUJE SIE Z CAS DO NOWEGO MODULU BEZ ZADNEGO PROBLEMU W TYM CELU UZYWAMY 1 2 3 4 5 6 (BACK) 15 16 (ZAMIAST CAS JAK W PRZYKLADZIE PRZEZ KTORY JESTESMY POLACZENI WYBIERAMY LMA BO TO DO NIEGO CHCEMY SKOPIOWAC FA Z CAS) 17 18 19 GOTOWE
  2. Dokładnie o coś takiego chodziło :cool2: Pzdr
  3. 10s = 0A 20s = 14 30s = 1E 40s = 28 50s = 32 60s = 3C 90s = 5A 150s = 96 240s = F0 Jeżeli nie znacie odpowiednika wartości którą chcecie ustawić (czas- S, napięcie- V, ilość- Times) proponuje przeszukać inne funkcje w module do których przypisane są konkretne opcje. Z reguły niema problemu żeby je znaleźć zapamiętać ich wartość i ustawić jako nowy parametr. Jeśli ma ktoś jakiś prosty sposób jak przeliczać te wartości lub jakis dobry konwerter mile widziane info.
  4. Instrukcja dodawania nowych wartości konkretnych funkcji w module. http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/New%20parameter/1_zpseab22cc0.jpg Wybieramy swoje nadwozie. http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/New%20parameter/2_zps3cbcdd67.jpg Następnie moduł który chcemy edytować. (nie wczytujemy danych .trc) http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/New%20parameter/3_zpsd0fcfeda.jpg Na przykładzie funkcji FOLLOW ME HOME jak widac najnizsza wartośc czasu swiecenia to 40s Dodajemy wartość parametru 10s. http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/New%20parameter/4_zps3f4f590d.jpg Klikamy prawym przyciskiem "ADD PARAMETER". http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/New%20parameter/5_zps6c37e833.jpg Nazywamy nowy parametr jak chcemy, ale najlepiej jako następną wartość czyli wert_06. W polu data wpisujemy 0A co jest odpowiednikiem wartości 10s. http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/New%20parameter/6_zpsdaf4d5f7.jpg Klikamy "MODLE FUNCTIONS". http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/New%20parameter/7_zps0b542d3b.jpg Następnie "UPDATE/ MODULE". http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/New%20parameter/8_zps8f16f44e.jpg OK. http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/New%20parameter/9_zpsdc65682b.jpg Nowa wartość już jest dostępna, dopisujemy ją również w innych funkcjach z których będziemy korzystać jak poniżej żeby wszystko działało ok. http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/New%20parameter/10_zps93b5ebd7.jpg http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/New%20parameter/11_zps91f5704b.jpg http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/New%20parameter/12_zps7b61af3a.jpg http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/New%20parameter/13_zpsf2ee462c.jpg http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/New%20parameter/14_zps25fad3e8.jpg http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/New%20parameter/15_zps304256f6.jpg Możemy tez np zmienić maksymalną liczbę aktywacji danej funkcji, tutaj na przykładzie WELCOME LIGHTS. Jak widać jedyna dostępną opcja jest 5 razy, dodamy parametr 10 razy. Jego odpowiednikiem jest wartość 0A. (wszystko analogicznie jak poprzednio) http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/New%20parameter/16_zps23da8cd1.jpg http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/New%20parameter/17_zps4029f863.jpg http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/New%20parameter/18_zps558f32c5.jpg http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/New%20parameter/19_zpsa7b792aa.jpg http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/New%20parameter/20_zps5cc2ebea.jpg Po wszystkim wczytujemy fsw_psw.trc zaznaczamy nowe wartości, eksportujemy do fsw_psw.man i kodujemy. http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/New%20parameter/21_zps12ba98a7.jpg http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/New%20parameter/22_zps5a00d27e.jpg Można zmieniać dosłownie wszystko , miedzy innymi PULSE WIDTH MODULATION czyli decydować jakie napięcie będzie wysyłane do konkretnej żarówki itp. Wszystkie zmiany które zrobimy można cofnąć za pomocą funkcji "RESTORE MODULE BACKUP..." znajdującej się w "MODULE FUNCTIONS"
  5. niema problemu Też mam ten pdf ze zmiana Fa Jak bede miał czas to zrobie to i jeszcze jak dodawac nowe wartosci do funkcji w module np jesli w module dla funkcji follow me home czas świecenia do wyboru jest tylko 30s 60s 90s 120s a ktoś potrzebuje np 10s - niema problemu poniżej trochę praktyki http://www.bmw-klub.pl/forum/viewtopic.php?f=76&t=226966
  6. S8LFA Wymagania danego kraju dot. wyposażenia Kod Nazwa S8LHA Wymagania danego kraju dot. wyposażenia S8LMA Wymagania danego kraju dot. wyposażenia S8LRA Dummy-SALAPA S8LSA Wymagania danego kraju dot. wyposażenia S8LTA Wymagania danego kraju dot. wyposażenia S8S1A Dekodowanie świateł do jazdy w dzień S8S2A Kodowanie sygnału alarmowego S8S3A Automatyczne ryglowanie prz ruszaniu S8S4A Dekodowanie zmienn. rozkł. świateł S8S5A Brak przeciwpyłkowego filtru paliw. S8S6A Wstępna specyfikacja na eksport S8S7A Fleet vehicle without TV function S8S8A Country-specific navigation control S8S9A Dummy-SALAPA S8SAA Aktywacja nawigacji charakt. dla kraju Kod Nazwa S8SBA Aktywacja syst. telem. char. dla kraju S8SCA Aktywacja syst. telem. char. dla kraju S8SDA Zab. przed wjech. pod poj.,wer. kraj. S8SEA Wersja 4 miejscowa S8SFA Special Edition Sport S8SGA Special Edition Exklusive S8SHA Silnika na Tajlandię S8SKA Brak linii wewn. grafit metalik S8SLA Przygot. pod zaczep holowniczy S8SMA Numer podwozia widoczny od zewnątrz S8SPA Sterowanie COP S8SPA Sterowanie CO2 S8SRA Special Edition Lifestyle S8SSA Sterownik specjalny Special Edtion S8STA Kodowanie częst. przeglądów, stopień 3 Kod Nazwa S8SUA Numer podwozia Security S8SVA Urządzenie głośnomówiące S8SWA Folia ochronna na czas transportu S8SXA Przyp. operatora do Telematik-/Online D. S8SYA Dummy-SALAPA S8SZA Dekodowanie światła skrętu S8TAA Stop. wyjściowy radia M Drive S8TBA Pakiet akustyczny S8TCA Dummy-SALAPA S8TDA Dummy-SALAPA S8TEA Dummy-SALAPA S8TFA Aktywna ochrona pieszych S8TGA Zabezpieczenie antykradzieżowe S8WAA Dummy-SALAPA S8WBA Dummy-SALAPA Kod Nazwa S900A Elektroniczny immobilizer S901A Kontrola specjalna ogólna S902A Kontrola specjalna pojazdów prasowych S903A Pojazd fotograficzny S904A Kontrola specj. pojazdów kontroli typu S905A Kontrola specj. pojazdów prowadzących S906A Pojazd fotograficzny S907A Wydanie James Bond S908A Dummy-SALAPA S909A Dummy-SALAPA S910A Pojazd projekt. bez zasilania wymien. S911A Pojazd projekt. z zasilaniem wymiennym S915A Brak konserwacji pokrycia zewn. S916A Pojazd projekt. bez warstwy konserwacji S917A Konserwacja przed wodą morską Kod Nazwa S918A Alpina B3, wewn. S919A Drzwi aluminium S920A Alpina bez dok. S921A Alpina B8, wewn. S922A Chłodnica silnika Alpina S923A Brak Titan-Line S923A Atrapa chłodnicy wąska S924A Lusterko, szkło płaskie pasażera S924A Koło składane S925A Ochronny pakiet wysyłkowy S926A pełnowartościowe koło zapasowe S927A Uregulowanie dla turystów S927A Ogumienie całoroczne S928A Sterowanie opon S929A Dummy-SALAPA Kod Nazwa S930A Dummy-SALAPA S931A Opony zimowe zamiast letnich z fabryki S932A Dummy-SALAPA S933A Dummy-SALAPA S934A Dummy-SALAPA S936A Koła ze st. lekk. "OW" S936A BMW Handy b. Ausliefer. anfordern S937A Dummy-SALAPA S938A Seria indywidualna S938A Pakiet zimowy S939A Dummy-SALAPA S940A Wyposażenie na życzenie Klienta S941A Dummy-SALAPA S942A Storno życzenia specjalnego S943A Dummy-SALAPA Kod Nazwa S944A Późn. zmiana na indywid. S945A Dummy-SALAPA S946A Dummy-SALAPA S947A Dummy-SALAPA S954A Dummy-SALAPA S960A Ogranicznik kierowniczy S961A Silnik specjalny S962A Specjalna charakterystyka silnika S962A Brak podst. tabl. rejestr. przedniej S963A Silnika 2.4 l na Tajlandię S964A Przy dost. zażądać płyty DVD nawigacji S964A Sterowanie pozorne do LA/SA S965A Dod. wyposaż. specj. przednie +25kg S966A Dod. wyposaż. specj. przednie +50kg S967A Dod. wyposaż. specj. tylne +25kg Kod Nazwa S968A Dod. wyposaż. specj. tylne +50kg S969A Przy dost. zażądać płyty DVD nawigacji S969A Dod. wyposaż. specj. tylne +75kg S970A Pakiet Business S976A Oparcie wzmocnione S978A Pakiet innowacyjny S979A Pakiet Business II S979A Value Package S980A Pakiet Exklusiv S982A Hardtop S983A Dummy-SALAPA S984A Kodowanie dla krajów spoza UE S984A Kodowanie częstotliwości przeglądów S985A Radiowy zestaw uzupełn. dla USA S986A Dummy-SALAPA Kod Nazwa S987A Dummy-SALAPA S988A Brak radia S988A Kodowanie częstotliwości przeglądów S989A Dummy-SALAPA S990A Dummy-SALAPA S991A Dummy-SALAPA S992A Sterowanie mocowania tabl. rej. S993A Kod dla roku modelu w numerze FG S994A Dummy-SALAPA S995A Dummy-SALAPA S996A HEA ALT S997A Dummy-SALAPA S998A Dummy-SALAPA S999A Zarządzanie zleceniami HEA S9AAA Zabezp. zewn. pokrycia z tworzywa szt. Kod Nazwa S9ABA Zabezp. zew. pokr. z tworz. szt. - brak S9AEA Dummy-SALAPA S9AWA Dostawa do BMW na całym świecie S9W1A FAHRZEUGSTEUERUNG WERK S9WRA Koła zimowe S9XAA Pakiet ALPINA SRA1A Stół piknikowy SRA2A Lusterko do makijażu, z tyłu SRA3A Uchwyt na puszkę z tyłu SRA4A Wysokojak. styl. zegar analog., przedni SRA5A Dywaniki podłogowe z owczej wełny SRA6A Dywaniki podłogowe przednie i tylne SRA7A Lusterko zewn. z automatyką przyciemn. SRA8A Podparcie stóp dla siedzenia tylnego SRA9A Trójkąt ostrzegawczy SRAAA Wspomaganie zamykania tylnych drzwi SRABA Wbudowana aktówka SRACA Skrzynka na cygara SRADA Parasole w samochodzie SRAEA Rozszerzone wyposażenie ze skóry SRAGA Worek na ubranie bagażnika SRAHA Roleta do bagażnika SRAKA Osłona tabl. przyrz. fornirowana SRALA Osłona tabl. przyrz., obciąg. skórą SRAMA Obudowa bagażnika w kolorze nadwozia SRAPA Ramię kierownicy fornirowane SRARA Stoły piknikowe okleina, obustronne SRASA Zestaw do napojów do poj. siedzeń SRAUA RR logos on head restraints SRAWA Zestaw do napojów do tylnej kanapy Kod Nazwa SRAXA CONTRAST SEAT PIPING SRAYA Preparation Stolen Vehicle Tracking SRB1A Szprychy kierownicy, metalizowane SRB2A LIQUIDMETAL BONNET WINDSCREEN SRB6A ARMORED LIMOUSINE SRC1A Stal nierdzewna pakiet SRC2A Teak decking SRC3A Obudowy wnętrza, okleinowane SRC4A Rozszerz. pakiet wypos. drewnianego SRC5A Pakiet ze stali nierdz. na wysoki połysk SRD1A Lakierowanie dwukolorowe, strona SRD2A Lakierowanie dwukolorowe wokół SRD3A Linia ozdobna prosta SRD4A Linia ozdobna podwójna SRD5A Spirit of Ecstacy, wersja indywidualna Kod Nazwa SRD6A niebieski chromowany SRD7A Farba kontrastowa zewn. SRD8A Interior Mono Package SRD9A Linear Colour Package SRE3A Podgrzewanie fotela przednie i tylne SRE4A Uniwersalny pilot w lusterku wewn. SRE5A Klimatyzacja standardowa SRE7A Wtyczka ładowania SRE8A Silniejsze zasilanie prądem SRE9A Spirit of Ecstacy, opuszczanie elektr. SREAA Zasłonki z tyłu SREBA Autom. uruchamianie tylnej klapy SRECA Klimatyzacja siedzenia tylnego SREDA Zasłona elektryczna tylnej szyby SREFA Osł. przeciwsł. tylnej szyby oyster Kod Nazwa SREGA Osłona przeciwsł. tylnej szyby czarna SREHA Osłona przeciwsł. tyln. cz. poj. oyster SREKA Osłona przeciwsł. tyln. cz. poj. czarna SRELA Camera System SREMA Chłodziarka do poj. siedzeń SRENA Chłodziarka do tylnej kanapy SREWA EXTENDED WHEEL BASE SRF1A Koło Rolls-Royce ze st. lekk. chrom. SRF2A Osłona piasty, chromowana SRF3A Śr. kołpak koła z symbolem RR do wyboru SRF4A Koło Rolls-Royce, SL 21" Sport Style SRF5A Koło Rolls-Royce, SL 21" Sport Style,ch. SRF6A Osłona piasty, Sport Style chrom SRF7A Dummy-SALAPA SRF8A Opony całoroczne Nazwa SRF9A Kołpak środ. seryj. koła w kol. nadwozia SRFAA Koło Rolls-Royce ze st. lek. 20" SRFBA Obr. RR, st. le. 20" chromowana SRFCA Obr. RR, st. le. Seven Spokes 21" SRFDA Obr. RR, st. le. Seven Spokes 21" poler. SRFPA 21" 7 SPK.FORGED W. FULLY POLISHED SRG1A Obr. RR ze SL Star Design SRG1A Oszklenie Privacy SRG2A Oszklenie Privacy tylko tylna szyba SRG3A Oszklenie Privacy z przezr. przed. szybą SRG4A Oszk. chr. przed pr. podczerw, sz. bocz. SRG5A Oszklenie przeciwsłoneczne tylne SRG7A Podsufitka Cashmere, czarna SRG8A Leather Headlining SRG9A Rozszerzone wyposażenie ze skóry Kod Nazwa SRGPA 21" STAR FORGED W. FULLY POLISHED SRH1A Wer. drewna szlach. mahoń Crossbanding SRH2A Wer. dr. szlach. orzech włoski Crossb. SRH3A Wer. dr. szlach. korzeń orzecha włosk. SRH4A Wer. z dr. szl. dąb z rys. sł. crossb. SRH5A Wer. drewna szlach. dębow. rys. słojów SRH6A Wer. z dr. szlach. Ulme Cluster Crossb. SRH7A Wersja z drewna szlach. RĂźster Cluster SRH8A Wer. z drewna szlach. klon.Crossband. SRH9A Wersja z drewna szlach. klonowego SRHAA Wer. drewna szlach. czarny tulipan SRHBA Wersja z drewna szlach., palisander SRHCA Wer. drewna szlach. jesion. rys. słojów SRHDA Wer. drewna szlach. Piano Black SRHEA Drewn. wyposażenie wnętrza "Brown Oak" Kod Nazwa SRHFA Drewn. wyposaż. wnętrza "Chestnut Burr" SRHGA Wer. z dr.szlach. jesion czer. rys. sł. SRHHA Wer. z dr. szl. mahoń Flare crossb. SRHKA Wer. z dr. szl., palisander crossb. SRHMA Wer. z dr. szl. jesion z rys. sł. crossb SRHNA Drewn. wyposażenie wnętrza "Zebrano" SRHPA Wood Interior Santos Palisander SRHRA DARK WENGE STRAIGHT-GRAIN SRK1A System nawigacji z TV/monitorem pokład. SRK2A Rolls-Royce Assist SRK5A System sterowania głosem SRL1A Kierownica z obiciem SRM1A Widoczny numer silnika SRM2A Top Speed US/CDN SRM3A Końcówka rury wydech., widoczna Kod Nazwa SRM6A DRIVER`S PACKAGE SRMKA East Asia Edition SRP1A Pakiet Business I SRP2A Pakiet Business II SRPDA IPOD INTEGRATION SRPPA Partition Preparation SRR5A Zmieniarka CD na 6 płyt CD SRR6A Zmieniarka DVD na 6 płyt SRR7A Płyta DVD nawigacji, Ameryka Północna SRR8A Płyta DVD nawigacji, Europa SRR9A Płyta DVD nawigacji, Zatoka Arabska SRRAA Płyta DVD nawigacji, Japonia SRRBA Płyta DVD nawigacji, Singapur i Malezja SRRDA Navi DVD China/Hongkong SRREA Navi DVD Korea Kod Nazwa SRRSA Podsufitka z mapą nieba SRS1A 2 siedzenia indywidualne z tyłu SRS2A Dach przesuwno-uchylny przedni SRS3A Theatre Configuration Lounge Seat SRS4A Brak dachu przesuwnego przedn SRS5A Przygotowanie pod wkł. schowka na rękaw. SRS6A EXTENDED STORAGE OPTION SRSCA Podsufitka z mapą nieba "bamboo" SRSDA Podsufitka z mapą nieba "dark grey" SRT1A Telefon samoch. z słuchawką bezprzew. SRT3A Instalacja tel. kom. kompl. USA/CDN SRT4A Słuch. podw. w siedz. tyln. (bezprzew.) SRT5A Kompl. instalacja telefonu kom. SRT6A Telefon zintegr. z pan. obsł., bezprz. SRT7A Instalacja tel. kom. przez Bluetooth Kod Nazwa SRV1A Dach składany czarny SRV2A Dach składany beżowy SRV3A Dach składany niebieski SRV4A Dach składany czerwony SRV5A Dach składany zielony SRV6A Dach składany Metall-Optik SRXLA Extended boot SRZ1A Dummy-SALAPA SV01A Dummy-SALAPA SV02A Dummy-SALAPA SV03A Dummy-SALAPA SV04A Dummy-SALAPA SV05A Dummy-SALAPA SV06A Dummy-SALAPA SV07A Dummy-SALAPA Kod Nazwa SV08A Dummy-SALAPA SV09A Dummy-SALAPA SV0AA Dummy-SALAPA SV0BA Dummy-SALAPA SV0CA Dummy-SALAPA SV0DA Dummy-SALAPA SV0EA Dummy-SALAPA SV0FA Dummy-SALAPA SV0GA Dummy-SALAPA SV0HA Dummy-SALAPA SV0IA Dummy-SALAPA SV0JA Dummy-SALAPA SV0KA Dummy-SALAPA SV0LA Dummy-SALAPA SV0MA Dummy-SALAPA Kod Nazwa SV0NA Dummy-SALAPA SV0OA Dummy-SALAPA SV0PA Dummy-SALAPA SV0QA Dummy-SALAPA SV0RA Dummy-SALAPA SV0SA Dummy-SALAPA SV0TA Dummy-SALAPA SV0UA Dummy-SALAPA SV0VA Dummy-SALAPA SV0WA Dummy-SALAPA SV0XA Dummy-SALAPA SV0YA Dummy-SALAPA SV0ZA Dummy-SALAPA SV10A Dummy-SALAPA SV11A Dummy-SALAPA Kod Nazwa SV12A Dummy-SALAPA SV13A Dummy-SALAPA SV14A Dummy-SALAPA SV15A Dummy-SALAPA SV16A Dummy-SALAPA SV17A Dummy-SALAPA SV18A Dummy-SALAPA SV19A Dummy-SALAPA SV1AA Dummy-SALAPA SV1BA Dummy-SALAPA SV1CA Dummy-SALAPA SV1DA Dummy-SALAPA SV1EA Brak relingu dachowego SV1FA Brak tylnej kanapy SV1GA Dummy-SALAPA Kod Nazwa SV1HA Dummy-SALAPA SV1IA Dummy-SALAPA SV1JA Dummy-SALAPA SV1KA Dummy-SALAPA SV1LA Dummy-SALAPA SV1MA Dummy-SALAPA SV1NA Dummy-SALAPA SV1OA Dummy-SALAPA SV1PA Dummy-SALAPA SV1QA Dummy-SALAPA SV1RA Dummy-SALAPA SV1SA Dummy-SALAPA SV1TA Dummy-SALAPA SV1UA Dummy-SALAPA SV1VA Dummy-SALAPA Kod Nazwa SV1WA Dummy-SALAPA SV1YA Dummy-SALAPA SV1ZA Dummy-SALAPA SV20A Dummy-SALAPA SV21A Dummy-SALAPA SV22A Dummy-SALAPA SV23A Dummy-SALAPA SV24A Dummy-SALAPA SV25A Dummy-SALAPA SV26A Dummy-SALAPA SV27A Dummy-SALAPA SV28A Dummy-SALAPA SV29A Dummy-SALAPA SV2AA Dummy-SALAPA SV2BA Dummy-SALAPA Kod Nazwa SV2CA Dummy-SALAPA SV2DA Dummy-SALAPA SV2EA Dummy-SALAPA SV2FA Dummy-SALAPA SV2GA Dummy-SALAPA SV2HA Dummy-SALAPA SV2IA Dummy-SALAPA SV2JA Dummy-SALAPA SV2KA Dummy-SALAPA SV2LA Dummy-SALAPA SV2MA Dummy-SALAPA SV2NA Dummy-SALAPA SV2PA Dummy-SALAPA SV2QA Dummy-SALAPA SV2RA Dummy-SALAPA Kod Nazwa SV2SA Dummy-SALAPA SV2TA Dummy-SALAPA SV2UA Dummy-SALAPA SV2VA Dummy-SALAPA SV2WA Dummy-SALAPA SV30A Autom. miękkiego zamykania SV31A Dummy-SALAPA SV32A Dummy-SALAPA SV33A Dummy-SALAPA SV34A Dummy-SALAPA SV35A Dummy-SALAPA SV36A Dummy-SALAPA SV37A Dummy-SALAPA SV38A Dummy-SALAPA SV39A Dummy-SALAPA Kod Nazwa SV3AA Dummy-SALAPA SV3BA Dummy-SALAPA SV3CA Dummy-SALAPA SV3DA Dummy-SALAPA SV3EA Dummy-SALAPA SV3FA Dummy-SALAPA SV3GA Dummy-SALAPA SV40A Dummy-SALAPA SV41A Dummy-SALAPA SV42A Dummy-SALAPA SV43A Dummy-SALAPA SV44A Dummy-SALAPA SV45A Dummy-SALAPA SV46A Dummy-SALAPA SV47A Dummy-SALAPA Kod Nazwa SV48A Dummy-SALAPA SV49A Dummy-SALAPA SV4AA Dummy-SALAPA SV4BA Dummy-SALAPA SV4CA Dummy-SALAPA SV4DA Dummy-SALAPA SV50A Dummy-SALAPA SV51A Dummy-SALAPA SV52A Dummy-SALAPA SV53A Dummy-SALAPA SV54A Dummy-SALAPA SV55A Dummy-SALAPA SV56A Dummy-SALAPA SV57A Dummy-SALAPA SV58A Dummy-SALAPA Kod Nazwa SV59A Dummy-SALAPA SV5AA Dummy-SALAPA SV5BA Dummy-SALAPA SV5CA Dummy-SALAPA SV5DA Dummy-SALAPA SV60A Brak modułu DSC SV61A Zaczep holowniczy SV62A Airbag inert SV62A Antena SV63A Wyłącznik awaryjny silnika SV63A Dezaktywacja poduszki powietrznej SV64A Gaśnica + młotek bezpieczeństwa SV64A Zbiornik emisyjny SV65A Dummy-SALAPA SV66A Dummy-SALAPA Kod Nazwa SV67A Dummy-SALAPA SV68A Dummy-SALAPA SV69A Lusterko z funkcją składania SV6AA Dummy-SALAPA SV6BA Dummy-SALAPA SV6CA Dummy-SALAPA SV6DA Dummy-SALAPA SV6HA Dummy-SALAPA SV6IA Dummy-SALAPA SV70A Dummy-SALAPA SV71A Zbiornik spryskiwaczy reflektorów, prz. SV72A Tylny zbiornik do mycia, przednia cz. SV73A Schowek w tabl. przyrz. SV74A Dummy-SALAPA SV75A Dummy-SALAPA Kod Nazwa SV76A Dummy-SALAPA SV77A Pompa paliwowa wzmocniona SV78A Czujnik ABS wariant 1 SV79A Czujnik ABS wariant 2 SV7AA Dummy-SALAPA SV7BA Dummy-SALAPA SV7CA Dummy-SALAPA SV7DA Dummy-SALAPA SV7EA Dummy-SALAPA SV7FA Dummy-SALAPA SV7GA Dummy-SALAPA SV7HA Dummy-SALAPA SV7IA Dummy-SALAPA SV80A Zawias przedniej pokrywy SV81A Podsufitka 2-warstwowa Kod Nazwa SV82A Dummy-SALAPA SV83A Podstawa pod akumulator SV84A Wzmocnienie słupka D SV85A Dummy-SALAPA SV86A Dummy-SALAPA SV88A Napęd na cztery koła SV8AA Dummy-SALAPA SV8CA Dummy-SALAPA SV8DA Dummy-SALAPA SV8EA Dummy-SALAPA SV8FA Dummy-SALAPA SV8GA Dummy-SALAPA SV8HA Dummy-SALAPA SV8KA Dummy-SALAPA SV8LA Dummy-SALAPA Kod Nazwa SV8MA Dummy-SALAPA SV8NA Dummy-SALAPA SV8PA Dummy-SALAPA SV90A Dummy-SALAPA SV91A Dummy-SALAPA SV92A Konstrukcja częściowa z dachem panoram. SV99A Dummy-SALAPA SV9AA Dummy-SALAPA SV9BA Dummy-SALAPA SV9CA Dummy-SALAPA SV9DA Dummy-SALAPA SV9EA Dummy-SALAPA SV9FA Dummy-SALAPA SV9GA Dummy-SALAPA SV9HA Dummy-SALAPA Kod Nazwa SV9IA Dummy-SALAPA SV9JA Dummy-SALAPA SV9KA Dummy-SALAPA SV9LA Dummy-SALAPA SV9MA Dummy-SALAPA SV9NA Dummy-SALAPA SVDAA Dummy-SALAPA SVSBA Ogumienie całoroczne SVZ1A Dummy-SALAPA SVZ2A Dummy-SALAPA SVZ3A Dummy-SALAPA SVZ4A Dummy-SALAPA SVZ5A Dummy-SALAPA SVZ6A Dummy-SALAPA SVZ7A Dummy-SALAPA Kod Nazwa SVZ8A Dummy-SALAPA SVZAA Dummy-SALAPA SVZBA Dummy-SALAPA SVZCA Dummy-SALAPA SVZDA Dummy-SALAPA SVZEA Dummy-SALAPA SVZFA Dummy-SALAPA SVZGA Dummy-SALAPA SVZHA Dummy-SALAPA SVZKA Dummy-SALAPA SVZLA Dummy-SALAPA SVZMA Dummy-SALAPA SVZNA Dummy-SALAPA SVZPA Dummy-SALAPA SVZRA Dummy-SALAPA Kod Nazwa SVZSA Dummy-SALAPA SVZTA Dummy-SALAPA SVZUA Dummy-SALAPA SVZVA Dummy-SALAPA SVZWA Dummy-SALAPA SVZXA Dummy-SALAPA SVZYA Dummy-SALAPA SVZZA Dummy-SALAPA SXAAA Ind. R.S. Infotainment online SXABA Ind. R.S. Infotainment SXD1A Special Edition carbon/złoto-brąz. SXD2A Special Edition stratus/ecru SXD3A Special Edition carbon/ecru SXD4A Special Edition stratus/złoto-brąz. SXD5A Ind. podsufitka Alcantara Kod Nazwa SXE1A Ind. dr. szlach. orzech amarone SXE2A Ind. drew. szl. klon perł. antracyt SXE3A Ind. dr. szlach. eukaliptus prążk. SXE4A Ind. dr. szlach. jesion czerw.-brąz. SXE5A Ind. drew. szl. platan czerw.-br. ciemny SXE6A Ind. drew. szl. orzech sat., honigbraun SXE7A Ind. listwy wewn., pianolack czarny SXE8A Ind. int. pianolack czarny z intarsją SXL1A Ind. intarsja w drewnie do kierownicy SXL2A Ind. intarsja w skórze do kierownicy SXT1A Ind. tab. przyrz. obita skórą SZBBA Test Workshop SA3 SZC1A Reserviert fĂźr UX SZC2A Reserviert fĂźr UX SZC3A Reserviert fĂźr UX Kod Nazwa SZC4A Listwy wewn. BMW Performance, karbon SZC5A 16" kpl. k. zim. szpr. podw. 268 SZC6A 18" kpl. k. zim. szprycha podw. 238 SZC7A 19" kpl. k. zim. szpr. podw. 238 SZC8A 19‘‘ kpl. k. zim. wieloszpr. 235 SZC9A 19‘‘ kpl. k. zim. spr. gwiaz. 251 SZCAA 18" kpl. k. zim. szpr. podw. 234 SZCBA 18‘‘ kpl. k. zim. spr. gwiaz. 250 SZD0A 16" LMR S-Winder R102 SZD1A Gałka zm. bieg., BMW Performance SZD2A 15‘‘ kpl. k. zim. 7 Hole Spoke R81 SZD3A Elem. wyp. zew., karbon SZD4A Nakładki na błotniki w kolorze nadwozia SZD5A Produkty serwisowe SZD6A Flagi dachowe Kod Nazwa SZD7A 15" LMR S-Star Spooler R100 SZD8A 15" LMR Rotator Spoke R101 SZD9A 16" LMR Double Spoke R87 SZDAA 17" LMR Crown Spoke R104 SZDBA 16" LMR Bridge Spoke R94 SZDCA 16" LMR 5-Star Blaster R103 SZDDA 17" LMR Flame Spoke R97 SZDEA 17" LMR Web Spoke Composite R98 SZDFA 16" WKR Double Spoke R87 SZDGA 16" WKR S-Winder R102 SZDHA Dekor. dachu SZDIA Spoiler krawędzi dachu SZDJA Pasek dekoracyjny Sport Stripes SZDKA Pasek dekoracyjny Bonnet Stripes SZDLA Pielęgn. lakieru i felg Kod Nazwa SZDMA Czyszczenie szyb SZDNA Pielęgnacja wnętrza pojazdu SZDOA Pielęgn. Cabrio i Roadster SZDPA Aplikacje specjalne SZDQA navigation portable SZDRA Adapter kabla iPod SZDSA Adapter Snap-In Bluetooth SZDTA Torba ratunkowa SZDUA Junior Seat III SZDVA Skórzana dźwignia sterująca SZDWA Uchwyt dźwigni sterującej SZDXA Uchwyt hamulca ręcznego ze skóry SZDYA Reflektor dodatkowy SZDZA 18" obr.st.le. szprycha podw. 125 SZE1A Komponenty aerodynamiczne do pakietu M Kod Nazwa SZE2A Komponenty aerodynamiczne SZE3A Pakiet aerodynamiczny SZE4A Tylny spoiler SZE5A Osłona rury wydechowej SZE6A Sportowa Końcówka tłumika SZE7A Światła skrętu/przeciwmgielne SZE8A Tylne światła pozycyjne Black-Line SZE9A Białe tylne światła pozycyjne SZEAA Dodatkowe ksenonowe światła drogowe SZEBA Folia ochronna na lakier, przezroczysta SZECA Listwy zderzakowe SZEDA Gniazdo amortyzatora SZEEA Tylny wspornik SZEFA Osłony lusterek zewn. SZEGA Owiewka Kod Nazwa SZEHA Pasy mocujące do bagażnika SZEIA Mata dwustronna do przestrzeni ładunk. SZEJA Osłona przeciwwietrzna SZEKA Schowek tablicy przyrządów SZELA Produkty dla warsztatów SZEMA Osłona dolna pojazdu SZENA Plecak wielofunkcyjny SZEOA Przeciwpyłkowy filtr paliwowy SZEPA 15" kpl. k. zim. 5 Star Spooler R100 SZEQA 16" kpl. k. zim Bridge Spoke, srebr. R94 SZERA 15" kpl. k. zim spr. krzyż. 42 SZESA 17" kpl. k. zim. szpr. podw. 79 SZETA 17‘‘ kpl. k. zim. spr. gwiaz. 57 SZEUA 17‘‘ kpl. k. zim. szprycha V 130 SZEVA 17‘‘ kpl. k. zim. spr. gwiaz. 200 Kod Nazwa SZEWA Złącze USB do ACM SZEXA Listwy wejściowe drzwi, podświetlane SZEYA Park Distance Control (PDC) SZEZA Skrobaczka do szyb SZF1A Etui na CD/DVD SZF2A Clean Bag SZF3A Halogenowa lampka do czytania SZF4A Latarka SZF5A Alum. podstawka na stopę SZF6A Alum. pedały SZF7A Wykładzina podłogowa tekstylna SZF8A Gumowa mata podłogowa SZF9A Nakładki na pedały ze stali nierdzewnej SZFAA Uchwyt pasa SZFBA Drewniany uchwyt hamulca ręcznego Kod Nazwa SZFCA Metalowy uchwyt hamulca ręcznego SZFDA Skórz. uchw. ham. ręczn. z klamrą dek. SZFEA Drewniane listwy wewnętrzne SZFFA Baby Seat 0+, z/bez ISOFIX SZFGA Junior Seat II SZFHA Junior Seat III SZFIA Junior Seat I-II, z/bez ISOFIX SZFJA Kierownica skórzana z drew. osł. dekor. SZFKA Sport. kierown. skórz. z osł. dekor. SZFLA Sport. gałka zmiany biegów SZFMA Skórzana gałka zm. bieg. z kl. dekor. SZFNA Sk. sport. gałka zm. bieg. z kl. dekor. SZFOA Seat cover BMW design SZFPA Obicie siedziska z owczej skóry SZFQA Torba na narty i snowboard Kod Nazwa SZFRA Ochrona przeciwsłoneczna SZFSA Mata ochr. krawędzi załad. SZFTA Listwy wejściowe drzwi SZFUA Skórz. dźwignia ster. z klamrą dekor. SZFVA Torba z tyłu SZFWA Zestaw kufrów SZFXA Wyposażenie dodatkowe ze skóry SZFYA Uchwyt do napojów SZFZA Pierścienie ozdobne SZH1A 19" obr.st.le. szprycha krzyż. 145 SZH2A 19" obr.st.le. szprycha gwiaz. 146 SZH3A 19" obr.st.le. szprycha gwiaz. 147 SZH4A 19" obr.st.le. szprycha podw. 150 SZH5A Asystent wielofunkcyjny SZH6A 18" obr.st.le., szprycha V 206 Kod Nazwa SZH7A Uchw. dźw. ster. Performance BMW SZH8A Uchwyt hamulca ręcznego Performance BMW SZH9A 19" kpl. k. zim. szprycha V 257 SZHAA 16" kpl. k. let. obr. stalowa 12 SZHBA 18" obr. st.le. szprycha podw. 219M SZHCA 18" obr. st.le. szprycha podw. 260M SZJ1A Uniwersalny podnośnik z adapterem SZJ2A Skrzynka składana SZJ3A Pokrowiec siedzenia tylnego SZJ4A Moduł uchwytu do napojów SZJ5A Wieszak na odzież SZJ6A Kieszeń chłodząca SZJ7A Kieszeń oparcia SZJ8A Uchwyt na parasol SZJ9A Moduł schowka Kod Nazwa SZJAA Skrzynka dachowa SZJBA Bagażnik podstawowy SZJCA Kosz bagażowy SZJDA Uchwyt na narty i snowboard SZJEA Mocowanie deski snowboardowej SZJFA Uchwyt na deskę surfingową SZJGA Uniwersalne mocowanie SZJHA Uchwyt na rower na zaczep holowniczy SZJIA Podnośnik do rowerów SZJJA Uchwyt na rower wyścigowy, zamykany SZJKA Uchwyt na rower turystyczny, zamykany SZJLA Mata przeciwpoślizgowa SZJMA Siatka bagażnika SZJNA Mata kształtowa do bagażnika SZJOA Klamki drzwi z flagami Kod Nazwa SZJPA Etui do kluczyków SZJQA Powierzchnie wewnętrzne SZJRA Pasy moc. do bagażnika SZJSA Kratki działowe bagażnika SZJTA Wanienka bagażnika SZJUA Folia ochronna krawędź załadunkową SZJVA Pokrywa ochronna komory ładunkowej SZJWA System Multifix SZJXA Uchwyt na torbę SZJYA Uprząż zabezpieczająca dla psów SZJZA Lusterka zewnętrzne do jazdy z przyczepą SZK1A Przyłącze AUX SZK2A Urządzenie głośnomówiące Universal SZK3A System BMW DVD Advanced SZK4A System BMW DVD do monitora centralnego Kod Nazwa SZK5A System BMW DVD Portable SZK6A Złącze iPOD SZK7A Radiowa nawigacja BMW SZK8A Cyfrowe mapy drogowe SZK9A Rear View SZKAA Side View SZKBA Elektron. ewidencja przebiegu pojazdu SZKKA Osłona krawędzi ładunkowej SZKLA Driver Utility Set SZKMA Gummifussmatte Klassik SZKNA Popielniczka SZKOA 20‘‘ WKR Y-Speiche 214 SZL0A 21" obr.st.le. szprycha podw. 215 SZL1A 16" obr.st.le. szprycha radialna 50 SZL2A 17" obr.st.le. szprycha podw. 178 Kod Nazwa SZL3A 17" obr.st.le. szprycha krzyż. 144 SZL4A 18" obr.st.le. szprycha podw. 129 SZL5A 18" obr.st.le. szprycha podw. 182 SZL6A 18" obr.st.le. szprycha podw. 195 SZL7A 18" obr.ze st.le. szpr. pod. obr. łącz71 SZL8A 18" obr.st.le. szprycha radialna 196 SZL9A 18" obr.st.le. szprycha gwiaz. 180 SZLAA 18" obr.st.le. szprycha gwiaz. 181 SZLBA 18" obr.ze st.le. szpr. gw. obr. łącz179 SZLCA 19" obr.st.le. szprycha podw. 125 SZLDA 19" obr.ze st.le. szpr. rad.obr.łącz 198 SZLEA 19" obr.st.le. szprycha gwiaz. 128 SZLFA 19" obr.st.le. szprycha gwiaz. 199 SZLGA 19" obr.st.le. szpr. rad. dwukol.190 SZLHA 19" obr.ze st.le. szpr. gw. obr. łącz179 Kod Nazwa SZLIA 18" obr. M ze st.le. szprycha podw. 184 SZLJA 18" obr.st.le. szprycha gwiaz. 89 SZLKA 18" obr.st.le. szprycha radialna 32 SZLLA 19" obr. M ze st.le. szpr. krzyż. 101 M SZLMA 21" obr.st.le., szprycha V 239 SZLNA 21" obr.st.le. szprycha podw. 275 SZLOA 18" obr.st.le. szprycha krzyż. 197 SZLPA 18" obr.st.le. szprycha radialna 216 SZLQA 18" obr.st.le. Perform. szpr. podw. 269 SZLRA 18" obr.st.le. Star Spoke R95 SZLSA 18" obr.st.le. Double Spoke Compos. R109 SZLTA 18" obr.st.le. Double Spoke R105 SZLUA 17‘‘ kpl. k. zim. spr. gwiaz. 165 SZLVA 18‘‘ kpl. k. zim. spr. gwiaz. 153 SZLWA 18‘‘ kpl. k. zim. spr. gwiaz. 69 Kod Nazwa SZLXA Zabezpieczenie śrub kół SZLYA Fartuch błotnika SZLZA Łańcuchy przeciwślizgowe SZM1A Linka/drążek holowniczy SZM2A Gaśnica proszkowa SZM3A Kable rozruchowe w orygin. torbie BMW SZM4A Apteczka SZM5A Podnośnik samochodowy - zestaw SZM6A Trójkąt ostrzegawczy SZM7A Kamizelka odblaskowa SZM8A Pokrowiec Car Cover SZM9A Non Paints SZMAA Kufer z powłoką twardą SZMBA Paints SZMCA Tylny bagażn.z uchw. nary/desek snowb. Kod Nazwa SZMDA Zestaw Mobility SZMEA Kanister na paliwo w kole zapasowym SZMFA System Hifi Alpine SZMGA Alum. poprz. gniazd amort. BMW Perform. SZMHA 17" kpl. k. zim. szpr. podw. 116 SZN1A Zestaw Side Scuttles SZN2A Osłona wlotu powietrza SZN3A Listwa uchwyt. klapy tylnej SZN4A Czasza lusterka wewnętrznego SZN5A Accessory Control Menu ACM SZN6A Słuchawki na podczerwień SZN7A DVB-T Settop-Box SZN8A Wspomaganie przy ruszaniu SZN9A Listwy prog. drzwi BMW Performance SZP1A Układ hamulcowy BMW Performance Kod Nazwa SZP2A System wlotu pow. BMW Performance SZP3A System tłumika BMW Performance SZP4A Skr. skoku dź. zm. bieg. BMW Performance SZP5A Podwozie BMW Performance SZP6A Pasek ozdobny BMW Performance SZP7A 17‘‘ kpl. k. zim. spr. gwiaz. 256 SZP8A Sportowa kierownica BMW Performance SZP9A Listwy wewnętrzne karbon SZPAA Fotel sportowy BMW Performance SZPBA 18‘‘ kpl. k. zim. szprycha V 254 SZPCA Poprz. gn. amort. BMW Performance, karb. SZPDA Adapter Snap-In ze złączem USB SZPEA Alum. podst. na stopę BMW Performance SZPFA Alum. nakł. na pedały BMW Performance SZPGA Torba na multimedia Kod Nazwa SZPHA Pakiet aerodynam. BMW Performance SZPIA Telematik Plattform Accessory SZPJA Przyrządy dodatkowe SZPKA 18‘‘ kpl. k. zim. spr. gwiaz. 99 SZPLA 18" kpl. k. zim. szpr. podw. 93 SZPMA 18‘‘ kpl. k. zim. wieloszprych. 94 SZPNA Torba wewnętrzna do kufra z powł. twardą SZPOA 16‘‘ kpl. k. zim. spr. gwiaz. 104 SZPPA Siatka na przedmioty w przestrz. przyp. SZPQA 18‘‘ kpl. k. zim. spr. gwiaz. 209 SZPRA 18" kpl. k. zim. spr. krzyż. 177 SZPSA 15" obr.st.le. Star Spoke R86 SZPTA Zest. śr. pielęgnacyjnych SZPUA 18" obr.st.le. szprycha podw. 238 SZPVA 17" obr.st.le. szprycha gwiaz. 158 Kod Nazwa SZPWA 19‘‘ kpl. k. zim. szprycha Y 211 SZPXA 19" obr.st.le. szprycha podw. 75 SZPYA 18" kpl. k. zim. szpr. podw. 270M SZPZA 20" obr.st.le. szprycha gwiaz. 87 SZQ1A Dekoracyjna osłona kierownicy SZQ2A 17" obr.st.le. M szprycha podw. 207 SZQ3A 18" obr.st.le. M szprycha gwiaz. 193 SZQ4A 17" obr.st.le. szprycha gwiaz. 122 SZQ5A 17" obr.st.le. szprycha gwiaz. 138 SZQ6A 17" obr.st.le. szprycha gwiaz. 90 SZQ7A 17" obr.st.le., szprycha V 141 SZQ8A 17" obr.st.le. szprycha gwiaz. 142 SZQ9A 17" obr.st.le. szprycha gwiaz. 105 SZQAA 17" obr.st.le. szprycha podw. 161 SZQBA 18" obr.st.le. szprycha gwiaz. 123 Kod Nazwa SZQCA 18" obr.st.le. szprycha gwiaz. 124 SZQDA 18" obr.st.le. szprycha podw. 93 SZQEA 18" obr.st.le. szprycha radialna 118 SZQFA 18" obr.st.le., szprycha V 217 SZQGA 18" obr.st.le., szprycha Y 114 SZQHA 18‘‘ obr.st.le. styliz. elipsoid. 107 SZQIA 18‘‘ obr.st.le. styliz. elipsoid. 162 SZQJA 18" obr.st.le. szprycha gwiaz. 74 SZQKA 19" obr.st.le. szprycha gwiaz. 95 SZQLA 19" obr.st.le., szprycha Y 191 SZQMA 19" obr.st.le., szprycha V 63 SZQNA 20" obr.st.le., szprycha Y 214 SZQOA 16" obr.st.le. szprycha radialna 139 SZQPA 16" obr.st.le. szprycha gwiaz. 140 SZQQA 19" obr.st.le. szprycha podw. 238 Kod Nazwa SZQRA Dekoracyjna osłona przeł. zmiany biegów SZQSA 15‘‘ WKR Star Spoke R86 SZQTA 16‘‘ WKR Double Spoke R88 SZQUA 16‘‘ WKR X-Lite Styling R84 SZQVA 17‘‘ WKR S-Spoke R85 SZQWA 16‘‘ kpl. k. zim. 7-sprych. R92 SZQXA 15‘‘ kpl. k. zim. 8-sprych. R82 SZQYA 18" obr. M ze st.le. szpr. krzyż. 101 M SZQZA 20" obr. M ze st.le. szpr. krzyż. 101 M SZR0A 19" obr.st.le. Perform. szpr. podw. 269 SZR1A 16" obr.st.le. szprycha radialna 32 SZR2A 17" obr.st.le. szprycha radialna 32 SZR3A 21" obr.st.le. szprycha gwiaz. 128 SZR4A 17" obr.st.le. szprycha gwiaz. 199 SZR5A 19" obr.st.le. szprycha gwiaz. 89 Kod Nazwa SZR6A 17" obr.st.le. szprycha krzyż. 238 SZR7A 18" obr.st.le. szprycha krzyż. 238 SZR8A 19" obr.st.le. szprycha krzyż. 238 SZR9A 20" obr.st.le. szprycha krzyż. 238 SZRAA 21" obr.st.le. szprycha krzyż. 238 SZRBA 20" obr.st.le. szprycha krzyż. 177 SZRCA 19" obr.st.le. szprycha krzyż. 177 SZRDA 18" obr.st.le. szprycha krzyż. 177 SZREA 17" obr. st.le. szprycha podw. 207M SZRFA 18" obr. st.le. szprycha podw. 135M SZRGA 19‘‘ kpl. k. zim. szprycha V 223M SZRHA 19" obr. st.le. szprycha podw. 172M SZRIA Folia chron. przed uderz. kamieni SZRJA 17" obr.st.le. szprycha podw. 238 SZRKA 16‘‘ kpl. k. zim. spr. gwiaz. 102 Kod Nazwa SZRLA 17‘‘ kpl. k. zim. spr. gwiaz. 90 SZRMA 17" kpl. k. zim. szpr. podw. 103 SZRNA 17" kpl. k. zim spr. krzyż. 133 SZROA 19‘‘ kpl. k. zim. M szprycha V 298M SZRPA 17" koło dojazdowe stylizacja 84 SZRQA 19" kpl. k. zim. spr. krzyż. 177 SZRRA 19" obr.st.le. szprycha gwiaz. 230 SZRSA Shoe Case SZRTA 18" obr.st.le. szprycha gwiaz. 246 SZRUA 18" obr.st.le. szprycha podw. 247 SZRVA 18‘‘ kpl. k. zim. spr. gwiaz. 74 SZRWA 20" obr.st.le., szprycha Y 149 SZRXA Torba na koło dojazdowe SZRYA 19‘‘ kpl. k. zim. spr. gwiaz. 232 SZRZA 20" obr.st.le. szprycha radialna 32 Kod Nazwa SZS1A 20" obr.st.le., szprycha V 168 SZS2A 19‘‘ obr.st.le. wz. spr. 176 SZS3A Kpl. BMW Performance Power SZS4A 17" kpl. k. zim. spr. gwiaz. 276 SZSZA Elektr. zespół napędowy SZV0A 18" LMR Cross Spoke R113 SZV1A 16‘‘ obr.st.le. Cross Spoke R90 jednocz. SZV2A 17‘‘ obr.st.le. Cross Spoke Compos. R90 SZV3A 17‘‘ obr.st.le. Double Spoke R99 SZV4A 17‘‘ obr.st.le. S-Spoke R85 SZV5A 17‘‘ obr.st.le. Multi Spoke R108 SZV6A Kapturki na zawory MINI SZV7A Folia przeciwsłoneczna SZV8A Uchwyt tablicy rejestracyjnej SZV9A 17" LMR Cross Spoke Challenge R112 Kod Nazwa SZVAA 17" kpl. k. zim. Cross Spoke R114 SZW0A 15" kpl. k. zim. obr. stalowa 12 SZW1A 16‘‘ kpl. k. zim. styl trap.134 SZW2A 16‘‘ kpl. k. zim. spr. gwiaz. 115 SZW3A 16" kpl. k. zim. szpr. radialna 50 SZW4A 16" kpl. k. zim. szpr. radialna 139 SZW5A 16‘‘ kpl. k. zim. szprycha V 229 SZW6A 16" kpl. k. zim. szpr. podw. 156 SZW7A 16" kpl. k. zim. szpr. radialna 32 SZW8A 16‘‘ kpl. k. zim. spr. gwiaz. 155 SZW9A 16" kpl. k. zim. obr. stalowa 12 SZWAA 16‘‘ kpl. k. zim. spr. gwiaz. 151 SZWBA 16‘‘ kpl. k. zim. spr. gwiaz. 140 SZWCA 17" kpl. k. zim. szpr. radialna 244 SZWDA 17‘‘ kpl. k. zim. spr. gwiaz. 138 Kod Nazwa SZWEA 17‘‘ kpl. k. zim. spr. gwiaz. 243 SZWFA 17‘‘ kpl. k. zim. spr. gwiaz. 122 SZWGA 17‘‘ kpl. k. zim. spr. gwiaz. 117 SZWHA 17‘‘ kpl. k. zim. szprycha V 110 SZWIA 17" kpl. k. zim. szpr. podw. 111 SZWJA 17" kpl. k. zim. szpr. podw. 112 SZWKA 17‘‘ kpl. k. zim. szprycha V 141 SZWLA 17‘‘ kpl. k. zim. spr. gwiaz. 199 SZWMA 17" kpl. k. zim. szpr. radialna 32 SZWNA 17‘‘ kpl. k. zim. spr. gwiaz. 158 SZWOA 17‘‘ kpl. k. zim. spr. gwiaz. 159 SZWPA 18" kpl. k. zim. szpr. radialna 118 SZWQA 18" kpl. k. zim. szpr. podw. M 184 SZWRA 18" kpl. k. zim. szpr. podw. M 164 SZWSA 18‘‘ kpl. k. zim. spr. gwiaz. 143 Kod Nazwa SZWTA Rozdzielacz schowka na rękawiczki SZWUA Wnęki w konsoli środkowej SZWVA 17" kpl. k. zim. obr. stalowa 12 SZWWA 17‘‘ kpl. k. zim. spr. gwiaz. 105 SZWXA Podłokietnik środkowy ze schowkiem SZWYA 17" obr.st.le. szprycha krzyż. 133 SZWZA 17" obr. st. le. szprycha podw. 71 SZX0A JCW Gear Shift Indicator SZX1A Pakiet aerodynamiczny JCW SZX2A JCW Tylny spoiler karbon SZX3A JCW Klamka tylnej klapy karbon SZX4A JCW Osłony lusterek zewnętrznych karbon SZX5A JCW Osłona wlotu powietrza karbon SZX6A JCW Hamulec sportowy SZX7A Perforowana tarcza hamulcowa JCW Kod Nazwa SZX8A JCW Łącznik gniazd amortyzatorów SZX9A JCW Car Cover SZXAA JCW Fotel sportowy, skóra SZXBA JCW Koło kierownicy, skóra SZXCA JCW Osłona, karbon SZXDA JCW Gałka zm. bieg. z klamrą karbonową SZXEA JCW Mieszek gałki zmiany biegów SZXFA JCW Uchwyt ham. ręczn. z klamrą karbon. SZXGA JCW Listwa wejściowa z logo SZXHA JCW Mata podłogowa z Checkered Flag SZXIA Zestaw tuningowy JCW SZXJA JCW Podwozie sportowe SZXKA JCW Sprężyna śrubowa czerwona SZXLA JCW Side Scuttles, komplet osłon ozdobn. SZXMA 16" obr.st.le. Double Spoke R88 Kod Nazwa SZXNA 17" kpl. k. zim. Flame Spoke R97 SZXOA 20" obr.st.le. szprycha podw. 238 SZXPA 21" obr.st.le. szprycha podw. 238 SZXQA 21" obr.st.le. szprycha krzyż. 312 SZXRA 21" obr.st.le. szprycha gwiaz. 311 SZXSA 19" obr.st.le. szprycha gwiaz. 311 SZXTA 18" obr.st.le. szprycha gwiaz. 311 SZXUA 17" obr.st.le. szprycha gwiaz. 276 SZXVA 19" obr.st.le. szprycha gwiaz. 276 SZXWA 18" obr.st.le. Perform. szpr. podw. 313 SZXXA 19" obr.st.le. Perform. szpr. podw. 313 SZXYA 17" koło dojazdowe stalowe SZXZA Osł. krawędzi załad., podśw. SZZAA Ogrzewanie na postoju SZZBA Ogrzew. na postoju/wentyl. na postoju Kod Nazwa SZZCA Element obsługi ogrzewania na postoju L801A Wersja krajowa Niemcy/Austria L801A Wersja krajowa Niemcy L802A Wersja krajowa Korea L804A Wersja krajowa Szwajcaria L807A Wersja krajowa Japonia L808A Wersja krajowa Izrael L809A Wersja krajowa Dania L810A Wersja krajowa Australia L811A Wersja krajowa Belgia L812A Wersja krajowa Anglia / Irlandia L812A Wersja krajowa Wielka Brytania L813A Wersja krajowa Francja L814A Wersja krajowa Włochy L816A Wersja krajowa Europa Środkowa Kod Nazwa L819A Wersja krajowa Hiszpania L820A Wersja krajowa Ameryka Łacińska L821A Wersja krajowa Egipt L822A Wersja krajowa Golf L824A Wersja krajowa Ameryka Południowa L827A Wersja krajowa Skandynawia L830A Wersja krajowa dla krajów półn. L833A Wersja krajowa Singapur L838A Wersja krajowa Kanada L846A Wersja krajowa Taiwan L8AAA Wersja krajowa Chiny L8LAA National version, India P237A Pakiet dynamiki jazdy P330A Pakiet sportowy P335A Seria indyw. 95 Special Exec. Kod Nazwa P336A M Pakiet sportowy P336A Pakiet sportowy P337A M Pakiet sportowy P338A Dummy-SALAPA P446A Wyposażenie specjalne siedzenia tylnego P448A Wyposażenie High Line Top P462A Fotel komfort ze stolikiem P505A Inst.czyszcz.refl.,św.p-mgl.,refl.tyln. P535A Elektroniczna regelacja temperatury P535A Pakiet klimatyzacji komfort P580A Pakiet do taksówek P581A Pakiet do taksówek P626A Pakiet komunikacyjny telefonu kom. P628A Pakiet komunikacji P671A Radio Busin./CD Changer/HiFi-Sys. Kod Nazwa P703A Pakiet na Europę Wschodnią P706A Dummy-SALAPA P714A Pakiet luksusowy P730A Ind. seria specjalna P730A Pakiet Advantage P734A Pakiet Levant P735A Basic Package P740A Edition ZD P741A Edition ZB P742A Edition ZF P743A Wydanie na rynki specjalne P744A Edition ZH P745A Edition ZE P746A Edition ZN P747A Edition ZO Kod Nazwa P748A Edition ZV P749A Wydanie dla importerów P758A Ind. Luxus-Compact P762A Seria indyw. 95 Selection Japan P763A Ind. dla Brazylii P765A Motorsport Edition ZA P777A Motorsport International P7A1A MINI Sidewalk P7A2A Innovation pack II P7A3A Pakiet Business P7A4A Advantage package + innovation package P7A5A Pak. Advantage + Limited Sport Edition P7A6A Pakiet innow. + edycje P7A7A Pakiet innow. + pakiet komfort. + edycje P7A8A Pakiet innow. + pak. komf.+p. Advantage Kod Nazwa P7A9A Pakiet innow. + pakiet komfort. P7AAA EXECUTIVE PACKAGE P7ABA SPORT EXECUTIVE PACKAGE P7AEA Pakiet low na Taiwan P7AFA Pakiet chromowany. rozszerz. P7AGA Pakiet ind. wyp. wnętrza lakier fortep. P7AHA Pakiet ind. wyp. wnętrza jesion P7AKA Pakiet indyw. wyp. wnętrza, orzech P7ALA MINI Seven P7AMA MINI Park Lane P7ANA MINI Checkmate P7APA Pakiet Dynamic + Advantage P7ARA Pakiet aerodynamiczny P7ASA Pakiet Dynamic + Comfort + Advantage P7ATA Pakiet Advatage + Comfort Kod Nazwa P7AUA Pakiet Advantage + Sport P7AVA Pakiet Comfort + Sport P7AWA Pakiet Advantage + Comfort + Sport P7AXA Pakiet Advantage + pakiet sport. M P7AYA Pakiet Comfort + pakiet sportowy M P7AZA Pakiet Advantage+Comfort+pak. sport. M P7G1A Pakiet Dynamic + Edition Lifestyle P7G2A Pakiet Dynamic + Edition Exclusive P7G3A Pakiet Comfort + Edition Lifestyle P7G4A Pakiet Comfort + Edition Exclusive P7G5A Pakiet Dynamic + Comfort + Ed. Lifestyle P7G6A Pakiet Dynamic + Comfort + Ed. Exclusive P7G7A EDITION 10 JAHRE X5 P7G8A DESIGN COOL ELEGANCE P7G9A Comfort + Limited Sport Edition Kod Nazwa P7HAA MINI 50 MAYFAIR P7HBA MINI 50 CAMDEN P7HCA Comfort Plus + Limited Sport Edition P7HDA EARL GREY P7HEA CONNECTIVITY PAKET P7K1A Dummy-SALAPA P7K2A Dummy-SALAPA P7K3A Dummy-SALAPA P7K4A Dummy-SALAPA P7K5A Dummy-SALAPA P7M2A Indywidualna kompozycja BMW P7M3A Indywidualna kompozycja BMW maritim P7M4A Indywidualna kompozycja BMW sportiv P7MBA Wydanie Exclusive Sport P7MCA Pakiet wydania Exclusive Kod Nazwa P7MDA Pakiet wydania Lifestyle P7MFA Wydanie Sport P7MPA Pakiet sportowy P7MSA Limited Sport Edition P7PAA MINI Service inclusive P7PBA MINI Service + Repair inclusive P7R1A System nawigacji z inst. tel. kom. P7R2A Pakiet Lifestyle P7R3A Pakiet na Ukrainę P7R4A Zestaw kierowcy z pakietem dynamicznym P7R5A Zestaw kierowcy z pakietem sport. M P7R6A Comfort Plus package w/ M sport package P7R7A Pakiet innowacyjny P7R8A Pakiet innowacyjny plus P7R9A Wydanie Fleet Kod Nazwa P7RAA Spezial Edition Exklusive carbon/szary P7RBA Spezial Edition Exklusive carbon/cynam. P7RCA Spezial Edition Exklusive stratus/szary P7RDA Spezial Edition Exklusive stratus/cynam P7REA Spezial Edition Lifestyle carbon/szary P7RFA Spezial Edition Lifestyle carbon/cynam. P7RGA Spezial Edition Lifestyle stratus/szary P7RHA Spezial Edition Lifestyle stratus/cynam P7RKA Spezial Ed. Lifestyle diamant/walk cz P7RLA Spezial Ed. Sport nachtblau/Alcantara cz P7RMA Pakiet techniczny oświetleniowy P7RNA Zestaw kierowcy P7RPA Pakiet Advantage P7RRA Pakiet Dynamic P7RSA Pakiet Comfort Kod Nazwa P7RTA Pakiet Dynamic + Comfort P7RUA Spezial Edition Exklusive diamant/czar. P7SAA Pakiet Open Air P7SBA Dummy-SALAPA P7SCA EDITION FLEET PLUS P7SDA Pakiet Comfort Plus + Edition Lifestyle P7SEA Pakiet Comfort Plus + Edition Exclusiv P7SFA Advantage + Edition Sport P7SGA Comfort + Edition Sport P7SHA Pakiet hotelowy P7SKA Pakiet innowacyjny P7SLA Design Pure White P7SMA DESIGN PADDOCK CLUB P844A Pakiet na złą pogodę P890A Pakiet standardowy Kod Nazwa P891A Wyposażenie Executive P892A Pakiet High Line P893A Middle-East-Paket P894A Pakiet HK-2 P894A V5-IC PACKAGE 1 P912A Pakiet OE P913A Pakiet OE plus P914A Pakiet Premium P948A Pakiet modelu jądra V-5-KA P949A Pakiet sportowy LA P950A Pakiet latynoamerykański P951A Pakiet letni P951A Pakiet koreański P952A Pakiet dla Chin P953A Pakiet na Taiwan Kod Nazwa P953A V5-IC PACKAGE 2 P954A Pakiet Business II P955A Business-Line P955A Middle-East-Paket P956A Middle-East-Paket P957A HK-Paket P957A V5-IC PACKAGE 3 P958A Pakiet podstawowy Meksyk P959A Luxury package Mexico P970A Aktionspaket P971A Pakiet Exklusiv P972A Pakiet komfort P973A Pakiet zimowy P973A Pakiet na Malezję P974A Pakiet dla krajów azjatyckich Kod Nazwa P975A Dummy-SALAPA P976A Pakiet Comfort P977A Linia Exclusive P981A Top Komfortpaket P981A Comfort Plus Paket P9BAA Premium Package P9BBA Pakiet Premium + Comfort P9BCA Final Package P9BDA Business Package P9BEA Pakiet motywacyjny P9BFA Pakiet nawigacji P9BGA Nawigacja pakiet + M pakiet sportowy PRP1A Pakiet Business I PRP2A Pakiet Business II PRP3A BRUSHED STEEL AND TEAK DECKING Kod Nazwa PRP4A BLACK STARLIGHT STARBURST HEADLINER PXA1A Spezial Edition carbon/cynam. PXA2A Spezial Edition carbon/dwukolor. szary PXA3A Spezial Edition carbon/champagner PXB1A Spezial Edition stratus/cynamon PXB2A Spezial Edition stratus/dwukolor. szary PXB3A Spezial Edition stratus/champagner PXC1A Spezial Edition nacht-blau/cynam. PXC2A Spezial Edition nacht-blau/dwukol.szary PXC3A Spezial Edition nacht-blau/champagner PXC4A Indywidualna kompozycja BMW PZAAA
  7. Tutaj FA (VO) po polsku S000A Dummy-SALAPA S001A LA nie jest sterowane jako pakiet S0BVA Tankowanie do pełna S0BWA Partial refuelling S100A Zwiększenie obciążenia użytkowego S102A Wzmacniane hamulce S102A Podwozie pojazdu służbowego S103A Opona całoroczna S103A Dolna osłona agregatu S104A Wersja na Bliski Wschód S105A Zarządzanie zleceniami "Bund" S106A Samochód opancerzony S107A Instalacja tachografu S108A Motor afterrun control unit S109A SECURITY PLUS Kod Nazwa S110A Instalacja montażowa ozn. karetki pog. S112A Beklebung leuchtrot RAL 3024 S113A Beklebung Polizei Bayern minzgrĂźn hell S114A Oklejenie dla policji, Północne Niemcy S114A Oklejenie dla policji, minzgrĂźn S115A Oklejenie dla straży pożarnej NRW S115A Oklejenie dla karetki NRW S116A Uchwyt chorągiewki lewy S117A Uchwyt chorągiewki prawy S118A Redukcja maksymalnej prędkości S119A Elektryka modułu dodatkowego S120A Wyposażenie podstawowe S121A Mocowanie na lizak policyjny S121A Inst. do umieszczania lizaka S122A Mocowanie na pałki policyjne S123A Dodatkowe lusterko wewnętrzne S124A Podsufitka poj. służb. S125A Wyposażenie wnętrza poj. służb. otw. S126A Wyposażenie wnętrza poj. służb., mask. S127A Uchwyt na broń po stronie pasażera S129A Uchwyt na broń w dachu z przodu S130A Uchwyt na broń w podłk. środ. z tyłu S131A Uchwyt na broń S139A Kogut niebieski S140A 1 RKLE 130,Tonfolge,Polizeischaltung S141A Instalacja sygnału dźwiękowego S142A Dwa koguty niebieskie S143A Włącznik alarmu z sygn. dla policji S144A RKLE zdejm. sygnał. policyjny S145A Włącznik alarmu z sygn. dla straży poż. Kod Nazwa S146A Dodatkowe zasilanie energetyczne S147A Kogut zdejmowany S149A Podwójny kogut, zdejmowany S150A Montaż RTK-4 z aparatem ręcznym S151A Sondersignalanlage Hella RTK-6 S152A Specjalne urządzenie sygnalizacyjne S153A Nakładka na dach bez inst. sygn. specj. S155A Montaż Top-4 z aparatem ręcznym S159A Montaż instalacji Aero-Dynic S160A Montaż urządz. sygnal. Becker LU 322 S161A ABGASNORM EU5 S162A Instalacja montażowa sygnału dźwięk. S163A Norma spalinowa EU6 S165A Dezaktywacja czołowej pod. pow. ITS S166A Inst. sygnału zatrz. na tylnej półce Kod Nazwa S167A Norma spalinowa EU 4 S168A Redukcja spalin EU 2 S169A Redukcja spalin EU 3 S169A Katalizator Diesel S170A Inst. FuG 2m-4m Bd, AEG(BKA) S170A Instalacja mont. FuG AEG Teledux S171A Instalacja mont. FuG Ascom S172A Przygotowanie na paliwo zawier. etan S172A Inst. FuG 7B kpl. sch. na ręk. S173A Inst. FuG 7B/8B/9C sch. na ręk. S174A Inst. FuG 8B/9C w sch. na rękawiczki S175A Inst. FuG 8B/9C S176A Inst. FuG 8B/9C przes. S178A Mocowanie krótkofalówki S179A Czujniki gazu drażniącego Kod Nazwa S180A Instalacja anteny dachowej S180A Antena dachowa S181A Instalacja/Montaż anteny tylnej S182A Instalacja do gaszenia pożaru S183A Inst. do aktywnej obrony S184A Wyjście awaryjne, przednia szyba S185A Pojazd specjalny otwarty S186A Pojazd specjalny zakryty S187A Ochrona podwozia S188A Siłownik szyby el. przedn poj. służb. S189A Siłownik szyby el. prz./tyl. poj. służ. S190A Instalacja rozmowy naprzemiennej S191A Siłownik szyby el. przed prawy poj.służ S192A Siłownik szyby el. przedn lewy poj.służ S193A Brak podgrz. szyb przedn. i boczn. Kod Nazwa S194A Zdalna instalacja rozruchowa S195A Dodatkowe opancerzenie podłogi S196A Zbiornik paliwa z hamowaniem wypływu S197A Akustyczna i optyczna inst. alarm. S198A Dodatkowa instalacja świeżego powietrza S199A Wersja na benzynę ołowiową S199A Brak katalizatora S1AAA 55 KW MOTORVARIANTE S1AFA Zmieniona rurka wlewu paliwa S1AKA Zewnętrzny filtr paliwa S1CAA Dummy-SALAPA S1CBA ACEA / CO2 Zakres S1CCA Auto start/stop function S1CDA Brake Energy Regeneration S200A Brak katalizatora Kod Nazwa S200A Przeciwpyłkowy filtr paliwowy S201A Zd. do pracy na estrze oleju rzep. (RME) S202A Steptronic S203A Napęd na cztery koła S204A Krótsze przełoż. przekładni tylnej osi S204A Wersja napędu na eksport S205A Automatyczna skrzynia biegów S206A Sekwencyjna ręczna skrzynia biegów S207A 6-stopniowa skrzynia biegów S208A Brak DSC III S209A Blokada dyrefencjału S210A Dynamiczny ukł. przeciwpoślizgowy S210A Dynamiczny ukł. przeciwpoślizgowy III S211A Dynamiczny ukł. przeciwpoślizgowy S212A Wyposażenie w układ ham. dla dan. kraju Kod Nazwa S212A Brak ABS S213A Hill-Descent-Control (ukł. pom.) S213A Automatyczna ukł. przeciwpoślizgowy S214A Automat. ukł. przeciwpoślizg. (ASC+T) S215A Wspom. ukł. kier., zależ. od pręd. obr. S216A Wspomaganie układu kier. Servotronic S217A Aktywny układ kierowniczy S217A Koło kierownicy ze skóry S218A Kierownica sportowa ze skóry II S219A Kierownica sportowa ze skóry 380 mm S220A Regulacja poziomu S221A 2-osiowa regulacja poziomu S223A EDC S224A Kontroler dynamiki jazdy S225A Brak sportowej kompozycji podwozia Kod Nazwa S226A Sportowe dostosowanie podwozia S227A Podw. sport.+ obniż. zaw.+ regul. poz. S228A Sportowe dostosowanie podwozia Plus S228A Podwozie komfort S229A Dynamic Drive S230A Podwozie sportowe z obniżaniem zawiesz. S230A Zakres dodatkowy, charakteryst. dla UE S231A Usuwanie ograniczenia do 250 km/h S232A Obr. BMW, st. le. spr. rad. 50 S233A Zwiększona masa przyczepy S234A Zaczep holowniczy z reg. wysokości S235A Zaczep holowniczy zdejmowany S236A Obr. BMW, st. le. z ogumieniem mieszanym S238A Obr. BMW, st. le. podw. spr. 93 S239A BMW LA wheel Styling 94 Kod Nazwa S240A Skórz. koło kier. z pod. pow. S241A Poduszka powietrzna kierowcy i pasażera S242A Kierownica z poduszką powietrzną S243A Poduszka powietrzna pasażera S244A Kolumna kierownicy regulowana S245A Kolumna kierownicy elektr. regulowana S246A Kolumna kierownicy regulowana S247A Regulacja osiowa kierownicy, mechan. S248A Podgrzewanie kierownicy S249A Wielofunkcyjność dla kierownicy S250A Kierownica wielofunkcyjna S250A Poduszka bocz. pasaż. na tyln. siedz. S251A Wskaźnik uszkodzenia opon S252A Aktywa ochrona kolan kierowcy/pasażera S253A Skórzane koło kierownicy COOPER S Kod Nazwa S253A Kierownica wielofunkcyjna, drewniana S254A Kierownica drewniana S254A Kierownica sportowa z kołem drewnianym S255A Kierownica sportowa ze skóry z poduszką S256A Kierownica sport./MFL/regul. prędk. S257A Dezaktyw. bocz. pod. powietrz., z tyłu S258A Bereifung mit Notlaufeigenschaften S259A Brak poduszek bocznych S260A Poduszka boczna dla kierowcy/pasażera S261A Poduszka bocz. pasaż. na tyln. siedz. S262A Czołowa poduszka pow. ITS S263A Czołowa poduszka pow. ITS z tyłu S263A Koła ze st. lekk. z ogumieniem mieszanym S264A BMW light alloy wheel, star spoke 55 S265A Kontrola ciśnienia w oponach (RDC) Kod Nazwa S266A Obr. BMW, st. le. spr. rad. 48 S267A BMW light alloy wheel, star spoke 49 S268A BMW LA wheel, star spoke 95 S269A Obr. BMW, st. le. spr. rad. 32 S270A Koła z szerokim ogumieniem S271A BMW LA wheel Z Line S272A BMW LA wheel Z Star S273A Obr. BMW, st. le. spr. gwiaz. 43 S274A Obr. BMW, st. le. podw. spr. 53 S274A Obr. BMW, st. le. Flachsternstyling S275A BMW LA wheel, chrome-plated/Z Star S276A Obr. BMW, st. le. styl. spr. okr. S277A Obr. BMW, st. le. BMW podw. spr. S278A Obr. BMW, st. le. BMW Styling S278A Obr. BMW, st. le. z ogumieniem mieszanym Kod Nazwa S279A Obr. BMW, st. le. nie zd. do j. po uszk. S279A Obr. BMW, st. le. spr. gwiaz. 45 S280A Obr. BMW, st. le. styl. spr. S281A BMW LA wheel, chr.-plated/roundspokes S282A Obr. BMW, st. le. styl. spr. II S283A Obr. BMW, st. le. BMW Styling II S284A Obr. BMW, st. le. styl. elips. 46 S284A Obr. BMW, st. le. BMW Styling S285A Obr. BMW, st. le. BMW Styling S286A Obr. BMW, st. le. BMW Styling S287A BMW light alloy wheel, star spoke 64 S288A Obr. BMW, st. le. spr. krz. 29 S289A Obr. BMW, st. le. BMW Styling S290A Obr. BMW, st. le. spr. gwiaz. 44 S291A Obr. BMW ze st. le. spr. krz. 2-cz. Kod Nazwa S292A Obr. BMW, st. le. spr. krz. 29 S293A BMW LA wheel, V spoke 54 S293A BMW LA wheel w flat-running properties S294A BMW LA wheel, multi-spoke styling S295A BMW LA wheel, star spoke 96 S295A Obr. BMW, st. le. Exclusivstyling S296A Obr. BMW, st. le. Classic S297A BMW LA wheel Streamline S297A BMW LA wheel,forged wheel/multi-spoke S298A Obr. BMW, st. le. podw. spr. 98 S298A BMW LA wheel turbine styling S299A Obr. BMW, st. le. z ogumieniem mieszanym S2AAA Obr. BMW, st. le. styl. elips. 46 S2ABA Obr. BMW, st. le. Ellipsoidsp. 162 S2ACA Obr. BMW, st. le. styl. elips. 109 Kod Nazwa S2ADA Obr. BMW, st. le. Ellipsoidsp. 202 S2AEA Obr. BMW, st. le. Turbinenstyling 292 S2AFA Obr. BMW, st. le. wz. turbiny 271 S2AGA Obr. BMW, st. le. wz. plastra miodu 323 S2AHA Obr. BMW, st. le. wz. turbiny 329 S2AKA Obr. BMW, st. le. wz. turbiny 329 S2ALA LM RAEDER STREAMLINE 297/MB S2B1A Obr. BMW, st. le. podw. spr. 278 S2B2A Obr. BMW, st. le. podw. spr. 316 S2B3A Obr. BMW, st. le. podw. spr. 321 S2B4A Obr. BMW, st. le. podw. spr. 195 S2BAA Obr. BMW, st. le. podw. spr. 88 S2BBA Obr. BMW, st. le. podw. spr. 98 S2BCA Obr. BMW, st. le. podw. spr. 111 S2BDA Obr. BMW, st. le. podw. spr. 112 Kod Nazwa S2BEA Obr. BMW, st. le. podw. spr. 148 S2BFA Obr. BMW, st. le. podw. spr. 154 S2BGA Obr. BMW, st. le. podw. spr. 161 S2BHA Obr. BMW, st. le. podw. spr. 156 S2BKA Obr. BMW, st. le. podw. spr. 174 S2BLA Obr. BMW, st. le. Doppelsp. 174/j.p.u S2BMA Obr. BMW, st. le. podw. spr. 116 S2BNA Obr. BMW, st. le. podw. spr. 205 S2BPA Obr. BMW, st. le. Doppelsp.205 całoro. S2BRA Obr. BMW, st. le. Doppelsp.247/j.p.u. S2BSA Obr. BMW, st. le. Doppelsp.247/j.p.u. S2BTA BMW LA wheel/double spoke 222 S2BUA BMW alloy wheel,doub.sp. 120,All Season S2BVA Obr. BMW, st. le. podw. spr. 266 S2BWA Obr. BMW, st. le. podw. spr. 268 Kod Nazwa S2BXA Obr. BMW, st. le. podw. spr. 253 S2BYA Obr. BMW, st. le. sp. podw. 278/j.p.u S2BZA Obr. BMW, st. le. podw. spr. 161 S2C0A Obr. BMW, st. le. spr. gw. 124 j.p.u S2C1A Obr. BMW, st. le. spr. gw. 175 S2C2A Obr. BMW, st. le. spr. gw. 175/j.p.u S2C3A Obr. MINI st. le. 5 Star Rocket 93 S2C4A Obr. BMW, st. le. spr. gw. 157 S2C5A Obr. BMW, st. le. spr. gw. 185 S2C6A Obr. BMW, st. le. spr. gw. 189 S2C7A BMW LA star spoke 218 w flat-runn. prop. S2C8A Obr. BMW, st. le. spr. gw. 200 S2C9A Obr. BMW, st. le. spr. gw. 209 S2CAA Obr. BMW, st. le. spr. gw. 119 S2CBA Obr. BMW, st. le. spr. gw. 113 Kod Nazwa S2CCA Obr. BMW, st. le. spr. gw. 132 S2CDA Obr. BMW, st. le. spr. gw. 136 S2CEA Obr. BMW, st. le. spr. gw. 137 S2CFA Obr. BMW, st. le. spr. gw. 138 S2CGA Obr. BMW, st. le. spr. gw. 140 S2CHA Obr. BMW, st. le. spr. gw. 142 S2CKA Obr. BMW, st. le. spr. gw. 143 S2CLA Obr. MINI st. le. 5 Star Rocket 93 S2CMA MINI LM Rad 5 Star Bullet m. Notlauf S2CNA Obr. MINI st. le. 5 Star Bullet 91 S2CPA Obr. BMW, st.le. spr. gw. 137, całorocz. S2CRA Obr. BMW, st. le. spr. gw. 153 S2CSA Obr. BMW, st. le. spr. gw. 113 S2CTA Obr. BMW, st. le. spr. gw. 151 S2CUA Obr. BMW, st. le. spr. gw. 169 Kod Nazwa S2CVA Obr. BMW, st. le. spr. gw. 170 S2CWA Obr. BMW, st. le. spr. gw. 171 S2CXA Obr. BMW, st. le. spr. gw. 155 S2CYA Obr. BMW, st. le. spr. gw. 158 S2CZA Obr. BMW, st. le. spr. gw. 159 S2DAA Obr. BMW, st. le. spr. krz. 197 S2DBA Obr. BMW, st. le. szprycha gwiaz. 327 S2DCA Obr. BMW, st. le. szprycha gwiaz. 330 S2DDA Obr. BMW, st. le. szprycha gwiaz. 330 S2DEA Obr. BMW, st. le. szprycha gwiaz. 334 S2DFA Obr. BMW, st. le. szprycha gwiaz. 339 S2DGA Obr. BMW, st. le. szprycha gwiaz. 340 S2DHA Obr. BMW, st. le. szprycha gwiaz. 340 S2DKA Obr. BMW, st. le. szprycha gwiaz. 341 S2EAA BMW LA wheel Y-spoke 149 Kod Nazwa S2HAA Obr. BMW, st. le. spr. rad. 139 S2HBA Obr. BMW, st. le. spr. rad. 160 S2HCA Obr. BMW, st. le. spr. rad. 187 S2HDA Obr. BMW, st. le. spr. rad. 190 S2HEA Obr. BMW, st. le. Radialsp. 32. j.p.u S2HFA Obr. BMW, st. le. Radialsp. 32. j.p.u S2HGA Obr. BMW, st. le. spr. rad. 244 S2HHA Obr. BMW, st. le. Radialsp. 244 / j.p.u S2HKA Obr. BMW, st. le. spr. rad. 216 S2HLA Obr. BMW, st. le. spr. rad. 252 S2HMA Obr. BMW, st. le. szprycha rad. 237 S2K1A Obr. BMW, st. le., szprycha V 236 S2K2A Obr. BMW, st. le., szprycha V 328 S2K3A Obr. BMW, st. le., spr. V 331 S2K4A Obr. BMW, st. le., spr. V 331 Kod Nazwa S2K5A Obr. BMW, st. le., spr. V 338 S2K6A Obr. BMW, st. le., spr. V 342 S2K7A BMW LM Rad Doppelspeiche 238 S2KAA BMW LA wheel, V spoke 110 S2KBA BMW LA wheel, V spoke 130 S2KCA BMW light alloy wheel, V-spoke 141 S2KDA BMW light alloy wheel, V-spoke 168 S2KEA BMW light alloy wheel, V-spoke 188 S2KFA BMW alloy wheel M V-spoke 217 S2KGA BMW LA wheel V-spoke 188 / All Season S2KHA BMW light alloy wheel, V-spoke 229 S2KKA BMW light alloy wheel, V-spoke 206 S2KLA BMW light alloy wheel, V-spoke 245 S2KMA BMW LA wheel, V-spoke 245 flat-runn. S2KNA BMW light alloy wheel, V-spoke 255 Kod Nazwa S2KPA BMW light alloy wheel, V-spoke 248 S2KRA BMW light alloy wheel, V-spoke 257 S2KSA Obr. BMW, st. le., spr. V 254 S2KTA Obr. BMW, st. le. spr. V 277, j.p.u S2KUA Obr. BMW, st. le., spr. V 285 S2KVA Obr. BMW, st. le., spr. V 294 S2KWA Obr. BMW, st. le., spr. V 296 S2KXA Obr. BMW, st. le., spr. V 279 S2KYA Obr. BMW, st. le., spr. V 277 S2KZA Obr. BMW, st. le., spr. V 318 S2LAA BMW LA wheel Y-spoke 114 S2LBA BMW LA wheel Y-spoke 131 S2LCA BMW LA wheel Y-spoke 183 S2LDA BMW LA wheel Y-spoke 211 S2LEA BMW LA wheel Y-spoke 214 Kod Nazwa S2LFA Obr. BMW, st. le. spr. Y 280 S2LGA Obr. BMW, st. le. spr. Y 315 S2LHA Obr. BMW, st. le. spr. Y 322 S2LKA Obr. BMW, st. le. spr. Y 335 S2LLA Obr. BMW, st. le. spr. Y 335 S2LMA Obr. BMW, st. le. spr. Y 336 S2LXA Obr. BMW, st. le. spr. Y 337 S2M0A Obr. BMW, st. le. indywid. 152 I,18" S2M1A Obr. BMW, st. le. indywid. 152 I,19" S2M2A Obr. BMW, st. le. indywid. 152 I,20" S2M4A Ind. kier. skórz., intarsja ze skóry S2M5A BMW LA wheel, M V spoke 223 S2M6A Ind. kier. skórz. z intarsją drewn. S2M7A M High Performance Ogumienie S2M8A Obr. BMW, st. le. indywid. spr. V 228 Kod Nazwa S2M9A BMW LA wheel, M V-spoke 227 S2MAA Ręczna skrzynia biegów S2MBA Obr. BMW, st. le. M podw. spr. 167 S2MBA Obr. BMW, st. le. M 19" kuta S2MCA Obr. BMW, st. le. M spr. rad. 166 S2MDA M Drive S2MEA Obr. BMW, st. le. M podw. spr. 194 S2MFA Obr. BMW, st. le. M spr. gw. 193 S2MGA Obr. BMW, st. le. M podw. spr. 207 S2MHA Obr. BMW, st. le. M podw. spr. 208 S2MKA M Przekładnia dwusprzęgłowa z Drivelogic S2MLA Obr. BMW, st. le. M podw. spr. 192 S2MMA Obr. BMW, st. le. M spr. Y 191 S2MNA Obr. BMW, st. le. M podw. 192 / All S. S2MPA Obr. BMW, st. le. M podw. spr. 225 Kod Nazwa S2MRA BMW LA wheel, M double spoke 261 S2MTA Obr. BMW, st. le. M podw. spr. 220 S2MUA Obr. BMW, st. le. M spr. gw. 325 S2MVA Obr. BMW, st. le. M podw. spr. 326 S2MWA Obr. BMW, st. le. spr. V 265, indywid. S2MXA BMW LM Rad M Doppelspeiche 354 S2MYA BMW LM Rad M Doppelspeiche 355 S2N1A ALLOY WHEEL INFINITE STREAM SPOKE S2N2A ALLOY WHEEL WHITE SHIELD S2NAA Lusterko wewnętrzne z kompasem cyfrowym S2NNA Obr. BMW, st. le. M podw. spr. 172 S2NPA Obr. BMW ze st. le. M podw. spr. 135 S2NRA Obr. BMW, st. le. M podw. spr. 172 S2NSA Obr. BMW, st. le. podw. spr. 288 S2NTA Obr. BMW, st. le. M spr. V 299 Kod Nazwa S2NUA Obr. BMW, st. le. M podw. spr. 300 S2NVA Obr. BMW, st. le. indywid. spr. V 301 S2NWA Obr. BMW, st. le. M spr. V 302 S2NXA Obr. BMW, st. le. M podw. spr. 303 S2NYA Obr. BMW, st. le. M podw. spr. 333 S2PAA Zabezpieczenie śrub kół S2R1A Obr. BMW, st. le. spr. gw. 138 S2R2A BMW LA wheel, start spoke 256 S2R3A Obr. BMW, st. le. spr. gw. 203 S2R4A BMW LA wheel, star spoke 230 S2R5A BMW LA wheel, star spoke 204 S2R6A BMW LA wheel, start spoke 231 S2R7A Obr. MINI st. le. Bridge Spoke / całor. S2R8A BMW LA wheel, start spoke 241 S2R9A Ogumienie runflat _________________ Darmowe rozkodowanie VIN (Polski opis): napisz VIN na ==>> [email protected] Problem z PW, proszę pisać na mail Ostatnio edytowano 22 stycznia 2009, 14:37 przez stones1, łącznie edytowano 1 raz Góra Zobacz profil Wyślij e-mail stones1 Tytuł: PostNapisane: 22 stycznia 2009, 14:32 Offline Uzależniony od forum :) Avatar użytkownika Wiek: 29 Posty: 8674 Lokalizacja: Gorzów Wlkp. Moje BMW: 535i Kod silnika: N55 Kod Nazwa S2RAA BMW alloy wheel, trapezoid style 134 S2RBA MINI LM Rad 7 Fin Spoke m. Notlauf S2RCA Koło na obr. alum. z pełnym kołpakiem S2RDA Obr. BMW, st. le. styl. spr. 176/miesz. S2REA Obr. MINI st. le.Web Spoke 2-cz. j.p.u. S2RFA Obr. MINI st. le. Delta Spoke 96 S2RGA Obr. MINI st. le. Bridge Spoke S2RHA Obr. MINI st. le. Flame Spoke97 S2RKA MINI alloy wheel, 5-start spooler 100 S2RLA MINI alloy wheel, rotator spoke 101 S2RMA Obr. MINI st. le. Night Spoke, j.p.u S2RNA Obr. MINI st. le. 5 Star Blaster j.p.u. S2RPA Obr. MINI st. le. Crown Spoke, j.p.u S2RRA MINI LA wheel,Crown spoke 104 S2RSA Obr. MINI st. le. "5 Star Pace Spoke" Kod Nazwa S2RTA BMW LA wheel turbine styling 201 S2RUA Obręcz MINI ze st. le. Black Star Bullet S2RVA Obr. MINI z stopów lek. w kolorze czarny S2RWA Obr. MINI s.l."Web Spoke two-tone" antr. S2RXA Obr. BMW, st. le. spr. gw. 210 S2RYA Obr. BMW, st. le. spr. gw. 212 S2RZA BMW LA wheel, star spoke 213 S2S1A Obr. BMW, st. le. spr. gw. 286 S2S2A Obr. BMW, st. le. spr. gw. 287 S2S3A Obr. BMW, st. le. spr. gw. 290 S2S4A Obr. BMW, st. le. spr. gw. 295 S2S5A Obr. BMW, st. le. wieloszprych. 293 S2S6A BMW LA wheel, start spoke 258 S2S7A Obr. BMW, st. le. spr. gwiaz. 317 S2S8A Obr. BMW, st. le. spr. gwiaz. 319 Kod Nazwa S2S9A Obr. BMW, st. le. spr. gwiaz. 320 S2SAA Koło bez możliw. jazdy po uszkodzeniu S2SBA BMW LA wheel, start spoke 242 S2SCA BMW LA wheel, start spoke 243 S2SDA BMW LA star spoke 243 w flat-runn. prop. S2SEA BMW LA star spoke 246 w flat-runn. prop. S2SFA BMW LA wheel, start spoke 249 S2SGA BMW LA wheel, start spoke 232 S2SHA BMW LA wheel, start spoke 258 S2SKA BMW LA wheel, start spoke 259 S2SLA BMW LA wheel, star spoke 262 S2SMA BMW LA wheel, star spoke 264 S2SNA Obr. BMW, st. le. spr. gw. 117 S2SPA Obr. BMW, st. le. spr. gw. 233 S2SRA Obr. BMW, st. le. podw. spr. 234 Kod Nazwa S2STA Obr. BMW, st. le. wieloszprych. 235 S2SUA Obr. BMW, st. le. spr. gw. 250 S2SVA Obr. BMW, st. le. spr. gw. 251 S2SWA Obr. BMW, st. le. spr. gwiaz. 272 S2SXA Obr. BMW, st. le. wieloszprych. 282 S2SYA Obr. BMW, st. le. spr. gw. 283 S2SZA Obr. BMW, st. le. wieloszprych. 284 S2TAA Blokada dyrefencjału S2TBA Sportowa automatyczna skrzynia biegów S2TCA SPORT. SKRZ. BIEGÓW ZE SPRZĘGŁEM PODW. S2TDA Autom. skrz. biegów z podw. sprzęgłem S2VAA Adaptive Drive S2VBA Kontrola ciśnienia w oponach (RDC) S2VFA Adaptacyjne podwozie M S2VHA Integral active front steering Kod Nazwa S2VKA DYNAMIC PERFORMANCE CONTROL S2VLA VARIABLE SPORTLENKUNG (ARBEITSNAME) S2WAA BMW LA wheel, W-spoke 263 S2WBA Obr. BMW, st. le., spr. W 291 S2WCA Obr. BMW, st. le., spr. W 332 S2WDA Obr. BMW, st. le., spr. W 332 S2XAA Kier.sport.ze skóry+dźw.przeł.+wielof. S2XAA Sportowa kierownica z dźwign. przełączn. S2Y1A Dummy-SALAPA S2Y2A Dummy-SALAPA S2Y3A Dummy-SALAPA S2Y4A Dummy-SALAPA S2Y5A Dummy-SALAPA S2Y6A Dummy-SALAPA S2Y7A Dummy-SALAPA Kod Nazwa S2Y8A Dummy-SALAPA S2Y9A Dummy-SALAPA S300A Centralny zamek z autoalarmem S300A Koło dojazdowe S301A Ogumienie All-Terrain S301A Autoalarm S302A Instalacja alarmowa S303A Obr. BMW, st. le. styl. elips. 60 S303A Ochrona wnętrza z czujn. alarm. nachyl. S304A Obr. BMW, st. le. styl. elips. 60 S305A Pilot do zamka centralnego S306A Obr. MINI st. le. 7 Hole 81 S306A Pilot do zamka centralnego S306A Pakiet zamykający S307A Blokada bezpieczeństwa do bagażnika Kod Nazwa S307A Obr. BMW, st. le. spr. rad. 61 S308A Pakiet komfort S308A Obr. BMW, st. le. spr. krz. 42 S309A Obr. BMW, st. le. spr. gwiaz. 57 S309A Obr. BMW, st. le. szprycha gwiaz. S310A Obr. BMW, st. le. spr. gwiaz. 58 S310A Pakiet komfort S311A Obr. BMW, st. le. spr. gwiaz. 69 S311A Obr. BMW, st. le., chromowana S312A Obr. BMW, st. le. z ogumieniem mieszanym S312A Obr. BMW, st. le., spr. V stylizacja 63 S313A Lusterko zewn. z funkcją składania S314A Lusterko zewn. /Zamek kier. podgrz. S315A Wycieraczka tylnej szyby S316A Autom. uruchamianie tylnej klapy Kod Nazwa S317A Sterowanie drzwi komfort S317A Autom. miękkiego zam. pokr. bagażnika S318A Autom. miękkiego zam. drzwi/bagażnika. S318A Podwójna osłona przeciwsłoneczna S318A Powierzchnia wewn. w kolorze nadwozia S319A Zintegrowana pilot uniwersalny S320A Brak napisu modelu S321A Zakr. wyp. zewn. w kolorze pojazdu S321A Napis S322A Funkcja dostępu komfortowego S322A Brak listwy chromowanej tylnej S323A Autom. miękkiego zam. drzwi S324A Obr. BMW, st. le. styl. elips. 107 S324A Spojler przedni i tylny S325A Tylny spoiler Kod Nazwa S326A Brak spojlera tylnego S327A Pasek ozd. na pokr. przedn., biały S328A Stopień, aluminium S328A Listwa progowa S329A Pasek ozd. na pokr. przedn., czarny S331A Obr. BMW, st. le. spr. gw. 102 S332A BMW LA wheel turbine styling 106 S333A Osłona przeciwwietrzna S333A Obr. BMW, st. le. spr. gw. 105 S334A Obr. BMW, st. le. podw. spr. 71 S334A Obr. BMW, st. le. podw. spr. 103 S338A M Pakiet sportowy II S339A Shadow-Line S340A Listwy zderzakowe czarne S340A Zderzak częściowo lakierowany Kod Nazwa S341A Zderzak - w pełni lakierowany S342A Listwy wewnętrzne Titan Shadow S343A Wyposaż. wewn. Chrome Line mat. S344A Wyposaż. wewn. Alu Line S345A Wyposaż. wewn. Chrome Line S346A Wyp. zewnętrzne Chrome-Line S347A Wyposażenie. zewn. Titan Line S348A Wyposażenie zewn. Highlight S349A Wyposażenie wewn. Highlight S350A Szkło izolacji cieplnej zielone S350A Obręcz łączona BMW szpr. gw. 108 S351A BMW LA wheel, star spoke 89 S352A Pod. oszklenie izolacyjne S353A Przednia i tylna szyba z klinem zielon. S354A Szyba przednia ziel. z klinem ziel. Kod Nazwa S355A Oszklenie zespolone S355A Szyba przednia przezroczysta z kl.ziel. S356A Oszklenie zespolone Klimakomfort S357A Oszklenie ochronne S358A Szyba frontowa klimatyzacji komfort S359A Szkło izol. ciep. ziel./jas. szy. przed. S359A Pakiet przezroczysty S360A BMW LA wheel, star spoke 81 S361A Obr. BMW, st. le. spr. rów. 82 S361A Szyba obrotowa tylna S362A Szyba obrotowa elektryczna, tylna S363A Obr. BMW, st. le. spr. rad. 32 S364A Ogumienie ochronne S365A Ogumienie ochronne S365A Tylna szyba ze szkła bezpiecznego Kod Nazwa S366A BMW LA wheel, star spoke 70 S367A Obr. MINI st. le. 8-Spoke 82 S368A Obr. MINI st. le. 5, gwiazda 16" S369A Obr. MINI st. le. S-Spoke 85 S370A Land Rover LM Rad Styling 1 S370A Dach składany czarny S371A Obr. Land Rover st. le. Styling 2 S372A Land Rover LM Rad Styling 3 S372A Dach składany ciemnobrązowy S373A Land Rover LM Rad Styling 4 S373A Dach składany granatowy S374A Obr. BMW, st. le. spr. rad.nstyling S375A Dach składany elektromech. czarny S375A Obr. BMW, st. le. podw. spr. 79 S376A BMW LA wheel, star spoke 74 Kod Nazwa S376A Dach składany elektromech. ciemnobrąz. S377A Obr. BMW, st. le. spr. gwiaz. 69 S377A Dach składany elektromech. granatowy S378A BMW LA wheel w flat-running properties S379A BMW LA wheel Y-spoke 80 S380A Przygotowanie pod Hardtop S381A Lust. zewn. czarne/Góra w kol. nadwozia S382A Lusterko zewn./góra biała S383A Lusterko zewn./góra czarna S384A Koło ze stopów lekkich białe lakierow. S385A Lusterko zewn./góra szara S385A Obr. MINI st. le. X-Lite 84 S385A System bagażnika dachowego S386A Reling dachowy S387A Osłona przeciwwietrzna Kod Nazwa S388A Dach składany czarny S389A Dach składany ciemnoszary S390A Dach składany klassisch-rot S391A Dach składany granatowy S392A Dach składany ciemnozielony S393A Dach składany turkusowy S394A Dach składany beżowy S395A System zabezp. na wypadek dachowania S396A Ogumienie ochronne S397A BMW LA wheel, star spoke 83 S398A Dach skł. el.-mech., półautomatyczny S399A Dach skł. el.-mech., całk. automatyczny S3ABA Pokrywa lusterka w kolorze nadwozia S3ACA Zaczep holowniczy S3ADA Pasek ozd. na pokr. przedn., Park Lane Kod Nazwa S3AEA Pasek ozd. na pokr. przedn., Checkmate S3AFA Lusterko zewn./góra srebrna S3AGA Kamera jazdy wstecz S3AHA Kamera jazdy wstecz i Top View S3AKA Pasek na maskę silnika, srebrny S3ALA Zestaw John Cooper Works S3AMA Słupki C, srebrne mat. S3ANA Słupki C, srebrne S3APA Szyba przednia z klinem szarym S3ARA Zest. przygot. tylnego bagażnika S3ASA Reling dachowy srebrny S3ATA Reling dachowy, aluminium satynowane S3AUA Pasek Toffy na pokrywę silnika S3AVA Grafika Camden na pokrywę silnika S3DVA Przystawka bagażnika dachowego Kod Nazwa S3MAA Ind. reling dachowy alum. satynowane S3MBA Ind. linia wyp. wnętrza alum. satynow. S3MCA Ind. relingi dach. wys. poł. Shadow Line S3XLA X Line S3YAA Dach skł. antracyt z ozdobą srebrną S3YBA Dach składany granatowy z ozdob. srebr. S3YDA Dach składany ciemnobrązowy S3YEA Dach składany beżowy S400A Dach przesuwno-uchylny obsług. ręcznie S401A Dach przesuwno-uchylny elektryczny S402A Dach panoramiczny elektryczny S403A Dach przesuwno-uchylny, elektryczny S404A DOUBLE COVER-SLIDING LIFTING ROOF S405A Lusterko zewn. chromowane S406A Dach rolowany Kod Nazwa S410A Siłownik szyby elektryczny przedni S411A Siłownik szyby elektryczny przedn/tylny S412A Podłoga ładunkowa bagażnika wyciągana S413A Siatka oddzielająca bagażnika S414A Roleta ochronna przezroczysta wzmocniona S414A Siatka na przedmioty po str. pasażera S415A Roleta przeciwsłoneczna tylna S416A Roleta przeciwsłoneczna tylna /boczna S417A Roleta przeciwsłoneczna drzwi tylna S418A Pakiet bagażnika S419A Pokrywa schowka na rękaw. z oświetl. S420A Przyciemniane szyby S421A Gaśnica halonowa 2 kg S422A Wer. drewna szlach. klon muszlowy S423A Dywaniki podłogowe Velours Kod Nazwa S424A Wykładzina podłogowa, czarna S425A Listwy wewnętrzne S426A Listwy wewnętrzne z aluminium S427A Wyp. wn., powierzchnia srebrna S428A Trójkąt ostrzegawczy i apteczka S429A Wyp. wn., powierzchnia antracyt S430A Lust. wew./zew. z automatyką przyciemn. S431A Wew. lust. wst. z automatyką przyciemn. S432A Czujn. deszczu/Lust. wew. Autom. ściemn. S433A Listwy wewnętrzne S434A Listwy wewnętrzne S434A Wyp. wn., powierzchnia aluminium S435A Wersja z drewna szlachetnego S436A Inst. płynn. przyciemn. lusterek S436A Wersja z drewna szlachetnego Kod Nazwa S437A Tablica przyrządów, w kolorze czarnym S437A Wersja z drewna szlachetnego S438A Wersja z drewna szlachetnego S439A Listwy wewnętrzne S439A Listwy wewnętrzne chrom mat. S440A Pakiet dla niepalących S441A Pakiet dla palących S442A Uchwyt do napojów S443A Funkcja kompasu S444A Podłokietnik wielofunkcyjny S445A Pakiet stolików S445A konsola środk. przezn. na siedz. tylne S447A Wyposażenie wnętrza High Line S449A Lusterko do makijażu, z tyłu S449A Lusterko z rejestratorem myta w Japonii Kod Nazwa S450A Regulacja wysokości fotela pasaż. S450A aktywna wentylacja oparć fotela S451A Aktywny fotel kierowcy S451A Regulacja wysokości fotela pasaż. mech. S452A Syst. ułatw. wsiadania siedz. tyln. S452A Aktywne fotele z tyłu S453A Klimatyzowane fotele przednie S454A Regul. fotela elektr., strony kierowcy S454A Klimatyzowane fotele tylne S455A Regul. fotela elektr., strony kierowcy S455A Aktywny fotel kierowcy/pasażera S456A Fotel komfort z pamięcią S457A Fotel kontur. el. z pamięcią S458A Regulacja fotela przedn. elektryczna S459A Elektryczna regulacja foteli z pamięcią Kod Nazwa S459A Regulacja fotela przedn. elektr. Memory S460A Fotel komfort siedz. tyln. reg. elektr. S460A Regulacja fotela tylna elektryczna S461A Regulacja oparć fotela elektr. tylna S463A Wyp. wn., powierzchnia Alloy Patina S464A Worek na narty S465A System załadunku S466A Listwa dachowa w kolorze nadwozia S467A Siedzenie tylne bez ukł. jednosiedz. S467A Taksówka-Tylne siedzenia z materiału S468A Worek na narty S468A System załadunku z workiem na narty S469A Wbudowane foteliki dla dzieci S470A System Isofix S471A Wyp. wn., powierzchnia grafit-metalik Kod Nazwa S472A Podłokietnik przedni kierowcy/pasażera S473A Podłokietnik przedni S474A Brak podłokietnika przedniego S475A Podłokietnik przedni, z reg. kierownicy S476A Tapicerka drzwi, magnesium-grau S477A Wyp. wn., powierzchnia dekor. drew. S481A Fotel sportowy S482A Fotel sportowy i kierownica sportowa S488A Podparcie lędźwi kierowcy i pasażera S489A Podparcie lędźwi pasażera elektr. S490A Regulacja szerokości oparcia S490A Podparcie lędźwi do siedzeń tylnych S492A Schowek w konsoli środkowej S493A Zespół schowków S494A Podgrzwanie fotela kierowcy/pasażera Kod Nazwa S495A Pas bezp. trzypunkt. i zagł. tył środek S496A Podgrzewanie fotela tylne S497A Podłokietnik środkowy na kanapie S498A Zagłówki w siedzeniu tylnym mechaniczne S499A Zagłówki w siedzeniu tylnym elektryczne S4A0A Listwy wewnętrzne z aluminium S4A1A Listwy wewnętrzne grafit mat S4A3A Wer. dr. szlach. drzewo orzech. jasne S4A4A Listwy wewnętrzne z aluminium "cirrus" S4A5A Kolor wypos. wnętrza Gotham grey S4A6A Kolor wypos. wnętrza tuscan-beige S4A7A Colour Line dark grey S4A8A Colour Line cream white S4A9A Colour Line mellow yellow S4AAA Podsufitka antracyt Kod Nazwa S4ABA Wer. dr. szlach. korzeń drzewa orzech. S4ACA Wer. dr. szlach. topolowy rys. słojów S4ADA Listwy wewn. alum., szlif. wzdłuż. dr. S4AEA Podłokietnik przedni, przesuwany S4AFA Podsufitka basalt-grau S4AGA Listwy wewnętrzne tytanowe matowe S4AHA Wer. dr. szlach. drzewo orzech ameryk. S4AKA Listwy wewnętrzne srebrne S4ALA Listwy wewnętrzne tytanowe ciemne S4ANA Wyp. wn., powierzchnia Seven S4APA Wyp. wn., powierzchnia Park Lane S4ARA Wyp. wn., powierzchnia Checkmate S4ASA Wer. dr. szlach. topol.rys.słojów szary S4ATA Listwy wewn., wysoki połysk, czarne S4AUA Rozszerzone zakresy dekoracji Kod Nazwa S4AVA Wyp. wn., powierzchnia Sidewalk S4AZA Wer. z dr.szl. bambus. rys. słoj. ciemn S4B0A Wer. dr. szl. mirt rys.słojów antracyt S4B1A Listwy wewnętrzne kaschmir-silber S4B2A Wer. dr. szl. mirt rys.słojów antracyt S4B3A Listwy wewnętrzne alum. szlif akcent. S4B4A Alu. strips ground lngthwise/Leather ins S4B5A W. z drew. szla. jes. rys. sł. wys. poł S4B6A Listwy wewn. alum."Flywheel" czarne S4B7A Wer. dr. szlach. "Fineline", wys. połysk S4B8A Wer. dr. szlach. korz. orzech./intarsje S4B9A Listwy wewnętrzne alum. drobno szlif. S4BAA Colour Line rooster red S4BBA Colour Line pacific blue S4BCA Wyp. wn., powierzchnia Fluid Silver Kod Nazwa S4BDA Wyp. wn., powierzchnia Piano black S4BEA Wyp. wn., powierzchnia English Oak S4BFA Wyp. wn., powierzch. Brushed Aluminium S4BGA Dummy-SALAPA S4BKA Listwy wewnętrzne alum., szlif. wzdłuż. S4BLA Kolor wypos. wnętrza redwood-red S4BMA Listwy wewnętrzne grafit mat jedw. S4BNA Wer. drewna szlach. jesion. rys. słojów S4BPA Wer. dr. szlach. topol.rys.słojów jasny S4BRA Interior surface, aluminium ground S4BSA Interior World Hot Chocolate S4BTA Dummy-SALAPA S4BUA Colour Line Hot Chocolate S4BWA Wer. z drewna szlach. klon. rys. słojów S4BXA Listwy wewn., wysoki połysk, szare Kod Nazwa S4BYA Wer. z drewna szlach. bambus antracyt S4BZA LISTWY WEWN. TYTANOWE JASNE S4CAA Wers.drew.szl.jesion.rys.słoj.antrac. S4CBA Wer. dr. szlach. "Fineline" naturalna S4CCA Aplikacja z drewna szl. do kier. skórz. S4CDA Listwy wewn. metalik ruthenium-grau S4CEA Wers. z dr. szlach. Fineline antracyt S4CFA Listwy wewnętrzne space-grau metalik S4CGA Listwy wewnętrzne "satin-silber" matowe S4CHA Wer. dr. szlach. "Fineline Wave" S4CKA Wer. dr. szlach. "Fineline" jasna S4CLA Listwy wewn. marrakesch-braun met. S4CMA Listwy wewn. platin-bronze metalik S4CNA COLOUR LINE TOFFY S4CPA COLOUR LINE TECH WHITE Kod Nazwa S4CRA Interieur Oberfläche toffy S4CSA Wyp. wn., powierzchnia srebrna S4CUA COLOUR LINE CARBON BLACK S4CVA EDELHOLZAUSF.EICHE STAMMHOLZ HOCHGL S4FAA Fotel sportowy Recaro S4FBA Brak fotela sportowego S4KSA Contrast stitching S4M0A Ind. drew. szlach. topola naturalna S4M1A Ind. drew. szlach. mahoń maritim S4M2A Ind. składany stolik z tyłu S4M3A Listwy wewnętrzne alum. "cube pure" S4M4A Listwy wewn. alum. 3D silver grid S4M4A Ind. listwy alum. silver grid S4M5A Ind. tabl. przyrz., obciąg. skórą S4M6A Kontroler aluminiowy frezowany Kod Nazwa S4M7A Ind. drew. szlach. mahoń S4M8A Ind. lampki do czytania z tyłu S4M9A Ind. konsola tylna S4MAA M Fotel wielofunkcyjny S4MBA Interior line Style S4MCA Listwy wewnętrzne Carbon Fibre S4MDA Listwy wewnętrzne Fibre Net eis-grau S4MEA Wer. dr. szlach. drzewo orzech. madera S4MFA Regulacja szerokości oparcia dynamiczna S4MFA Dynamiczna regulacja szerokości oparcia S4MGA Listwy wewn. alum. glacier-silber S4MKA Wer. dr. szlach. oliwkowa carrara nat. S4MKA Wer. z drewna szlachetnego carrara S4MLA Listwy wewn. lakier. fortep. czarny S4MMA Ind. listwy obciągane skórą Kod Nazwa S4MPA Interieurleisten Alu dunkel Kreuzschliff S4MRA Listwy wewnętrzne z aluminium Hexagon S4MSA Listwy wewnętrzne alum. "Pentan" S4MTA List. wew. al. "Shadow" ciem.szczotk. S4MUA Wer. dr. szl. eukalip. prążk. czer. br. S4MVA Listwy wewnętrzne Alu "Micro" S4MWA Listwy wewn. Aluminium Carbon Shadow S4MXA List. wewn. alum., shadow szlif. wzdłuż. S4MYA List. wew., skóra strukt. karbon. czarn. S4MZA Drewno szl. platan. o sł.lustrz.antracyt S4NAA Lusterko wewnętrzne z kompasem cyfrowym S4NBA Autom. klimatyzacja z regul. 4 strefową S4NCA Wentylacja/ogrzewanie dodatkowe S4NDA Tablica przyrządów, obciągana skórą S4NFA Rozszerzony zakres klimatyzacji z tyłu Kod Nazwa S4U1A Aplikacja ceramiczna elementów ster. S4UAA Regulacja fotela półelektryczna S4UBA 3. rząd foteli S4UCA Pedały "steel line" S4UDA Podłoga ładunkowa przesuwna S4UEA Tylna kanapa z regul. przód-tył S4UFA Sport button S4UGA Rear seat bench, 2-seat S4UHA Sport instruments S4UKA 5-miejscowy S4ULA Płaska podłoga ładunkowa S4UMA Massage function in rear seat backrests S4UNA Otwór załad. z wbudowanym schowkiem S4UPA Adaptacyjny system mocujący S4URA Oświetlenie wnętrza dookoła Kod Nazwa S4USA 2-seater preparation S4UTA Throughload opening w/int. transport bag S4UUA Gniazdko wtyczkowe 230V S4UVA Stoliki z tyłu S4UWA Gniazdko wtyczkowe 115V S4UXA Stoliki z tyłu S4UYA Torba na narty i snowboard S4XAA Dummy-SALAPA S4XBA Dummy-SALAPA S4XDA Dummy-SALAPA S4XEA Dummy-SALAPA S4XHA Dummy-SALAPA S4XKA Dummy-SALAPA S4XLA Dummy-SALAPA S500A Inst.czyszcz.refl./Czyszcz. intensywne Kod Nazwa S502A Spryskiwacze reflektorów S507A Park Distance Control z tyłu (PDC) S508A Park Distance Control (PDC) S509A Laserowy miernik odległości (LAM) S510A Regulacja zasięgu świateł S512A Brak regulacji długości świateł S519A Reflektor dodatkowy S520A Reflektor przeciwmgłowy S521A Czujnik deszczu S522A Światło ksenonowe S523A Klimatyzacja siedzenia ze skrz. chłodn. S524A Adaptacyjne doświetlanie zakrętów S524A Kontrola świateł mijania S525A Skrzynka chłodnicza S526A Brak klimatyzacji z tyłu Kod Nazwa S527A Filtr z węglem aktywnym do klimatyzacji S527A Brak lodówki / schowka S528A Autom. kontrola obiegu powietrza S529A Mikrofiltr S530A Klimatyzacja S531A All Season Roadster S532A Klimatyzacja ZG S532A Air Fresher S533A Klimatyzacja siedzenia tylnego S534A Automatyczna klimatyzacja S536A Ogrzewanie na postoju S537A Wentylacja na postoju S538A Ukryty zasobnik ciepła S539A Pilot ogrzewania na postoju S539A Klimatyzacja standardowa Kod Nazwa S539A Klimatyzacja standardowa z pilotem S540A Regulacja prędkości S541A Adaptive Cruise Control S542A Check-Control S543A Wskaźnik ciśnienia doładowania S544A Dynamiczna regulacja prędkości S544A Ind. wyposażenie S544A Regulacja prędkości z funkcją hamowania S545A Obrotomierz,km/h-Tacho,Zegar analog+EC S545A Dodatkowy wskaźnik temperatury oleju S546A Obrotomierz S547A Pakiet Cockpit Chrono S548A Licznik kilometrów S549A Zegar radiowy S549A Exklusiv-Uhr Kod Nazwa S550A Komputer pokładowy S551A Komputer pokładowy II z pilotem S553A Komputer pokładowy IV z pilotem S554A Komputer pokładowy V z pilotem S555A Komputer pokładowy V z pilotem S556A Wskazanie temperatury zewn. S560A Lamki do czytania w tylnym siedzeniu S562A Lampka do czytania S563A Lusterko do makijażu, podświetl. S563A Pakiet oświetlenia S564A Pakiet oświetlenia wnętrza S570A Silniejsze zasilanie prądem S571A Silniejsze zasilanie prądem S575A Gniazdko wtyk. bagażnika z 2 akumul. S577A Instalacja samoch. do wynajęcia Kod Nazwa S581A Pakiet do taksówek S582A Dummy-SALAPA S583A Obr. BMW, st. le. Aero 90 S584A BMW LA wheel Styling 94 S585A Obr. BMW, st. le. podw. spr. 71 S586A Obr. MINI st. le. szprycha, całor. S587A Obr. BMW, st. le. podw. spr. 116 S588A Obr. BMW, st. le. spr. gw. 115 S589A Obr. BMW, st. le. spr. gw. 122 S590A Obr. BMW, st. le. spr. gw. 123 S591A Obr. BMW, st. le. spr. gw. 124 S592A Obr. BMW, st. le. spr. rad. 118 S593A Obr. BMW, st. le. podw. spr. 120 S594A BMW light alloy wheel,spider spoke 92 S595A Obr. BMW, st. le. styl. elips. 121 Kod Nazwa S596A BMW light alloy wheel, V-spoke 126 S597A BMW LA wheel, star spoke 89 S5AAA Tylne światło przeciwmgłowe S5ABA Brak światła hamowania dwustopniowego S5ACA Asystent świateł drogowych S5ADA Ostrzeżenie przed opuszcz. toru jazdy S5AEA Układ hamowania z wysokich prędkości S5AFA SIDE UNDER MONITOR S5AGA Lane change warning S5AHA Dekodowanie dynamicznego światła hamow. S5AKA Elementy oświetleniowe LED S5DAA Dezaktywacja poduszki powietrznej pasaż. S5DBA Autom. pas 3-punktowy z tyłu na środku S5DCA Zagłówki w siedzeniu tylnym składane S5DDA Podnośnik samochodowy Kod Nazwa S5DFA Aktywna reg. prędkości+funkcja Stop&Go S5DKA Side view camera S5DPA Park Assist S5DRA Park Distance Control incl. Top View S5DSA Odryglowanie awaryjne bagażnika S5DTA DYNAMIC TRACTION CONTROL S5GAA Inst. autoalarmu S5GBA STOLEN VEHICLE TRACKING S601A Funkcja TV S602A Monitor pokładowy z TV S603A Ekran siedzenia tylnego S604A Personal Travel Assistent S605A BTX/Telefon S605A Instalacja Telematik S606A System nawigacji Business Kod Nazwa S606A Radionawigacja S607A Instalacja Teleservice S607A Komputer osobisty (PC) S608A System nawigacji z monitorem pokładowym S608A Travel Note System S609A System nawigacji Professional S610A Wyświetlacz Head-Up S611A Night Vision S612A BMW Assist S613A Usługi oparte o internet S614A Internet S615A Rozszerzona informacja BMW Online S616A BMW Online S619A System połączenia ratunkowego S620A Wejście głosowe _________________ Darmowe rozkodowanie VIN (Polski opis): napisz VIN na ==>> [email protected] Problem z PW, proszę pisać na mail Góra Zobacz profil Wyślij e-mail stones1 Tytuł: PostNapisane: 22 stycznia 2009, 14:33 Offline Uzależniony od forum :) Avatar użytkownika Wiek: 29 Posty: 8674 Lokalizacja: Gorzów Wlkp. Moje BMW: 535i Kod silnika: N55 S621A BMW Telefon BedienhĂśr.vorn C-Netz S621A Całk. zintegr. tel. komórkowy Korea S622A Słuch. podw. w siedz. tyln. telef. BMW S623A Telefon samochodowy sieci D (GSM) S624A Instalacja tel. kom. BMW (Siemens) S624A Instalacja słuchawkowa dla sieci C S625A Instalacja tel. kom. BMW (Motorola) S625A Telefon komórkowy sieć D S626A Telefon Siemens C2 S627A Telefon Siemens C3 słuch z pan., przód S627A Instalacja tel. kom. BMW (Nokia) S629A Tel. sam. sieci D z czytn. kart z przod. S630A Telefon samoch. z słuchawką bezprzew. S631A Słuch. podw. w siedz. tyln. (bezprzew.) S632A Inst. tel. sieci C ze sł. z prz. i ty. Kod Nazwa S632A Instalacja tel. kom. BMW (Motorola) S633A Inst. tel. Siemens ze sł. z przodu S633A Instalacja tel. kom. Business S634A Instalacja pod montaż telefonu sieci C S635A Instalacja pod montaż telefonu sieci D S636A Inst. mont. telef. kom. sieci D S637A Inst. tel. Siemens C3 ze sł. z przodu S638A Telefon samochodowy Professional S639A Instalacja tel. kom. kompl. USA/CDN S640A Instalacja pod montaż tel. uniwers. S641A Inst. mont. telef. BMW zakryta S641A Instalacja tel. kom. USA uniwersal. S642A Inst. mont. telef. BMW kompletna S642A Całk. zintegr. tel. kom., standard USA S643A Inst. tel. sam. sieci D dla Axicon Kod Nazwa S644A Instalacja tel. kom. z Bluetooth S645A Radio v S646A Instalacja pod montaż tel. na Japonię S647A Becker Mexico Electronic II o.VF S648A Radio Grundig 3883 RDS S648A Radio BMW CD S649A Napęd kaset S650A CD Napęd S650A Radio BMW Reverse S651A Stacja napędu MD S651A Radio BMW Reverse RDS S652A Radio Bavaria C II S652A Napęd DVD S653A High Definition Radio S653A Radio Bavaria C Reverse II Kod Nazwa S653A Radio cyfrowe BMW S654A Moduł odbiornika DAB S654A Radio Bavaria C III S655A Radio satelitarne BMW S655A Radio Bavaria C Business S656A Radio BMW Reverse/MINI Wave S656A Radio MINI MC S656A Radio Bavaria C Professional S657A Radio Bavaria C Reverse III S657A Radio BMW Business/MINI Boost S658A Radio BMW Business CD RDS S659A Radio BMW Business CD S659A Radio Bavaria Electronic CD II S660A Radio BMW Reverse (C42) S661A Radio BMW Business (C43) Kod Nazwa S662A Radio BMW Business CD S663A Radio BMW Professional CD S663A Radio BMW Professional (C44) S663A Radio BMW Professional S664A Instalacja tel. kom. S664A Radio BMW Reverse RDS S664A Tel. kom., standard USA S665A Radio BMW Business RDS S666A Radio BMW Business CD RDS S667A Radio BMW Audio S667A Radio BMW Professional RDS S668A Radio BMW Reverse RDS S669A Radio BMW Business RDS S670A Radio BMW Professional RDS S672A Zmieniarka CD na 6 płyt CD Kod Nazwa S673A System HiFi USA S674A System HiFi Harman Kardon S675A System audio siedzenia tylnego S675A Sound System S676A System głośników HiFi S677A System HiFi Professional DSP S678A Inst. słuchawek w siedz. tylnym S679A Subwoofer systemu HiFi S679A Antena tylnej szyby S680A Antena radiowa ręczna S681A Antena dachowa S682A Siedzenie tylne z materiału S683A Antena tel., sieć D S684A Telefon. antena w tylnej szybie, sieć D S685A Antena tel., sieć C Kod Nazwa S686A Anteny Diversity S687A Instalacja radiowa S689A Instalacja do In-Car Video S690A Uchwyt kasety S691A Mocowanie CD S692A Instalacja zmieniarki BMW na 6 CD I-Bus S693A Instalacja radia satelitarnego BMW S693A Inst. głośników z tyłu S694A Instalacja zmieniarki BMW na 6 CD S695A Zmieniarka MD S695A Pilot radia S696A Skrzynka CD S696A Zmieniarka DVD S697A Area-Code 1 do DVD S697A Automatyczna antena telefoniczna Kod Nazwa S698A Area-Code 2 do DVD S699A Area-Code 3 do DVD S6A1A ALWAYS OPEN TIMER S6AAA BMW Teleservices S6ABA Sterowanie teleserwisem S6FAA Instalacja systemu DVD z tyłu S6FBA Radio MINI Wave CD S6FBA Radio MINI CD S6FCA Radio MINI Boost CD S6FDA System głośników HiFi MINI S6FEA MASK Nowa Zelandia S6FFA System DVD z tyłu S6FGA Urządz. do rozrywki z tyłu S6FHA Urządz. do rozrywki z tyłu Professional S6FKA Obsł. audio na tylnym siedz. Kod Nazwa S6FLA Złącze USB-/Audio S6FNA Instalacja dla zmieniarki DVD S6M1A Ind. urządz. do rozrywki z tyłu S6M2A Ind. tył. poj. Infotainment online S6NAA Telefon samochodowy z tyłu S6NBA Rear-cabin telephone w/ cordless handset S6NCA Telephone with cordless keypad handset S6NDA Urz. gośnomów. Bluetooth + USB/Audio S6NEA Inst. tel. kom. Bluetooth + USB/Audio S6NFA Inst. Smartphone Bluetooth USB/Audio S6NFA Anbindung Music-Player im Mobilteil S6UAA Instalacja CCC S6UBA Instalacja systemu sterowania głosem S6UCA Instalacja montażowa funkcji TV S6UDA Wersja językowa, rosyjski Kod Nazwa S6UEA Zabezp. syst. nawig. DVD przed kradzieżą S6UFA System nawigacji, przygotowanie S6UGA System nawigacji MINI S6UHA Traffic Information S6UKA Night Vision z rozpozn. osób S6VAA Sterowanie CIC S6VBA Sterowanie CCC S6VCA Dummy-SALAPA S700A Area-Code 4 do DVD S701A Area-Code 5 do DVD S702A Area-Code 6 do DVD S704A M Podwozie sportowe S705A M Podwozie sportowe II S708A M Kierownica sportowa, skórzana S709A M Kierownica sportowa, skórzana Kod Nazwa S710A M Kierownica skórzana S710A M Kier. sport. wielofunk. S711A M Fotel S712A M Fotel sportowy S713A Tylny spoiler S713A Pakiet Off-Road S715A M Technic Pakiet aerodynamiczny S716A Pakiet aerodynamiczny S717A Wydanie Comfort S718A Pakiet wydania Exclusive S719A Wydanie Sport S720A Wydanie Sport Limited S720A Edition ZD S721A Edition ZB S722A Pakiet wydania Lifestyle Kod Nazwa S722A Edition ZF S723A Pakiet wydania Exclusive S724A Wydanie Sport S724A Edition ZH S725A Pakiet podstawowy S725A Edition ZE S726A Edition ZN S727A Edition ZO S728A Edition ZV S729A Wydanie dla importerów S731A Dodatkowy zakres edycji S732A Listwy wewnętrzne z wł. węglowych Pyrit S733A Listwy wewnętrzne, drewn. Yacht-Line S736A 2. kluczyk do obsługi pilotem S737A Listwy wewnętrzne z aluminium, szczotk. Kod Nazwa S738A Wersja z drewna szlachetnego S739A Wersja z drewna szlachetnego S750A TV/wideo z tyłu (PAL) S751A TV/wideo z tyłu (NTSC) S752A Ind. system audio S753A Young-Line S754A M Spojler tylny S755A Składany dach przesuwny S756A Obr. BMW, st. le. spr. okr. indywid. S757A Ind. pakiet dźwiękowy S759A Pakiet familijny S760A Wysoki połysk Shadow-Line S761A Ind. oszklenie przeciwsłon. S763A Seria indyw. Japan S764A Wyposażenie High Line Kod Nazwa S766A Seria indyw. Japan S767A Seria indywidualna "Avus" S767A Performance Package S767A 330i- wersja sportowa S767A Ind. sportowe S768A Seria indywidualna "Clubsport" S768A Seria ind. 95 Atlanta Olymp.Ed. S769A Seria indyw. 96 Japan S770A Listwy wewnętrzne alum. "silver cube" S770A Seria indyw. 96 Classic S771A Wydanie Sport S771A Listwy wewnętrzne Titan Shadow S772A Wyposażenie luksusowe S772A Listwy wewnętrzne alum. "black cube" S773A Wersja z drewna szlachetnego Kod Nazwa S774A Wersja z drewna szlachetnego S775A Obicie podsufitki, antracyt S776A Obicie podsufitki Alcantara S776A Wyposażenie chromowane S777A Obudowa bagażnika Alcantara S778A Oznaczenie BMW Individual S778A Listwy wejściowe "BMW Individual" S779A Carbon Line S780A Obr. BMW, st. le. M spr. rów. S781A Obr. BMW, st. le. M Kontur S782A Obr. BMW, st. le. M System II S782A Podwozie NĂźrburgring S783A Obr. BMW, st. le. M podw. spr., kuta S784A M Lusterko zewnętrzne S785A Lampy kierunkowskazów białe Kod Nazwa S786A Czynności marketingowe dla kół 17" S787A Obr. BMW ze st. le. M podw. spr. 135 S787A Obr. BMW, st. le. indywid. S788A Obr. BMW, st. le. indywid. S789A Obr. BMW, st. le. indywid. S790A Obr. BMW, st. le. M podw. spr. 97 S790A Zbiornik dodatkowy S791A Skrzynka chłodnicza S791A M Technic Servotronic S792A Obr. BMW ze st. le. M 19" kuta S793A Sekw. skrzynia biegów M Drivelogic S795A Obręcz łączona BMW M podw.szpr. 71 S798A Dach składany magenta (indywid.) S7ARA Pakiet aerodynamiczny S7BAA MINI Repair inclusive Kod Nazwa S7BBA MINI Repair inclusive S7BCA MINI Repair inclusive S7BDA MINI Repair inclusive S7BEA MINI Repair inclusive S7BFA MINI Repair inclusive S7BGA MINI Repair inclusive S7BHA MINI Repair inclusive S7BKA MINI Repair inclusive S7CAA BMW Repair inclusive S7CBA BMW Repair inclusive S7CCA BMW Repair inclusive S7CDA BMW Repair inclusive S7CEA BMW Repair inclusive S7CFA BMW Repair inclusive S7CGA BMW Repair inclusive Kod Nazwa S7CHA BMW Repair inclusive S7CKA BMW Repair inclusive S7CLA BMW REPAIR INCLUSIVE 4/120 S7D1A Technika serwisowa BMW S7D2A Serwis BMW S7D3A Serwis BMW S7D4A BMW Service + Repair inklusive S7D5A Serwis BMW S7D6A Serwis BMW S7D7A BMW Basic Service inklusive S7D8A Technika serwisowa BMW S7DAA Technika serwisowa BMW S7DBA Technika serwisowa BMW S7DCA Serwis BMW S7DDA Technika serwisowa BMW Kod Nazwa S7DEA Technika serwisowa BMW S7DFA Serwis BMW S7DGA Technika serwisowa BMW S7DHA Serwis BMW S7DKA Serwis BMW S7DLA Technika serwisowa BMW S7DMA Technika serwisowa BMW S7DNA Technika serwisowa BMW S7DPA Technika serwisowa BMW S7DRA Technika serwisowa BMW S7DSA Technika serwisowa BMW S7DTA Technika serwisowa BMW S7DUA Technika serwisowa BMW S7DVA Technika serwisowa BMW S7DWA Technika serwisowa BMW Kod Nazwa S7DXA Technika serwisowa BMW S7DYA Technika serwisowa BMW S7DZA Technika serwisowa BMW S7FAA MINI Service inclusive S7FBA MINI Service + Repair inclusive S7FCA MINI Service + Repair inclusive S7FDA MINI Service + Repair inclusive S7FEA MINI Service + Repair inclusive S7FFA MINI Service + Repair inclusive S7FGA MINI Basic Service inklusive S7FHA MINI Basic Service inklusive S7M0A Indywidualna kompozycja BMW I S7M1A Indywidualna kompozycja BMW II S7M5A Indywidualny pakiet wyposaż. zewn. BMW S7M5A M Zakres wyposażenia zewn. Kod Nazwa S7MAA Competition Paket S7MEA M Drivers Package S7N1A Technika serwisowa BMW S7N2A Technika serwisowa BMW S7N3A Serwis BMW S7N4A Technika serwisowa BMW S7N5A Technika serwisowa BMW S7N6A Serwis BMW S7N7A Technika serwisowa BMW S7N8A Technika serwisowa BMW S7N9A Serwis BMW S7NAA Technika serwisowa BMW S7NBA Serwis BMW S7NCA Technika serwisowa BMW S7NDA Serwis BMW Kod Nazwa S7NEA Technika serwisowa BMW S7NFA Serwis BMW S7NGA Technika serwisowa BMW S7NHA Technika serwisowa BMW S7NKA Technika serwisowa BMW S7NLA Serwis BMW S7NMA Technika serwisowa BMW S7NNA Serwis BMW S7NPA Technika serwisowa BMW S7NRA Technika serwisowa BMW S7NSA BMW Service + Repair inklusive S7NTA Technika serwisowa BMW S7NUA Technika serwisowa BMW S7NVA Serwis BMW S7NWA Technika serwisowa BMW Kod Nazwa S7NXA Technika serwisowa BMW S7NYA Technika serwisowa BMW S7NZA Serwis BMW S7P1A MINI Basic Service inklusive S7P2A MINI Basic Service inklusive S7P3A MINI Basic Service inklusive S7P4A MINI Basic Service inklusive S7P5A MINI Basic Service inklusive S7P6A MINI Service inclusive S7P7A MINI Service inclusive S7P8A MINI Service inclusive S7P9A MINI Service inclusive S7PAA MINI Service inclusive S7PBA MINI Service + Repair inclusive S7PCA MINI Basic Service inklusive Kod Nazwa S7PDA MINI Basic Service inklusive S7PEA MINI Service inclusive S7PFA MINI Service + Repair inclusive S7PGA MINI Basic Service inklusive S7PHA MINI Service inclusive S7PKA MINI Service + Repair inclusive S7PLA MINI Basic Service inklusive S7PMA MINI Service inclusive S7PNA MINI Service + Repair inclusive S7PPA MINI Basic Service inklusive S7PRA MINI Service inclusive S7PSA MINI Service + Repair inclusive S7PTA MINI Basic Service inklusive S7PUA MINI Service inclusive S7PVA MINI Service + Repair inclusive Kod Nazwa S7PWA MINI Basic Service inklusive S7PXA MINI Service inclusive S7PYA MINI Service + Repair inclusive S7SNA Naw. Business/Handyvorber. Bluetooth S7SPA Naw. Professional/Handyvorber. Bluetooth S7T1A Basic Service Inclusive S7T2A Basic Service Inclusive S7T3A Basic Service Inclusive S7T4A Basic Service Inclusive S7T5A Technika serwisowa BMW S7T6A Technika serwisowa BMW S7T7A Serwis BMW S7T8A Serwis BMW S7TAA BMW Basic Service inklusive S7TBA BMW Basic Service inklusive Kod Nazwa S7TCA BMW Basic Service inklusive S7TDA BMW Basic Service inklusive S7TEA BMW Basic Service inklusive S7TFA BMW Basic Service inklusive S7TGA BMW Basic Service inklusive S7THA BMW Basic Service inklusive S7TKA BMW Basic Service inklusive S7TLA BMW Basic Service inklusive S7TMA Technika serwisowa BMW S7TNA Technika serwisowa BMW S7TPA Technika serwisowa BMW S7TRA Technika serwisowa BMW S7TSA Technika serwisowa BMW S7TTA Technika serwisowa BMW S7TUA Technika serwisowa BMW Kod Nazwa S7TVA Technika serwisowa BMW S7TWA Technika serwisowa BMW S7TXA Technika serwisowa BMW S7TYA BMW Repair inclusive S7TZA BMW Repair inclusive S7U9A Omission of BMW Service Inclusive S7UAA Technika serwisowa BMW S7UBA Serwis BMW S7UCA Serwis BMW S7UDA Technika serwisowa BMW S7UEA Serwis BMW S7UFA Technika serwisowa BMW S7UGA Serwis BMW S7UHA Technika serwisowa BMW S7UKA Serwis BMW Kod Nazwa S7XAA M leather st.wheel+shiftpaddle+multif. S800A Układ wydechowy kompletny, kraje S803A Brak trzeciego światła hamowania S805A Filtr z węglem aktywnym S806A Trzecie światło hamowania S815A Pakiet na złe drogi S817A Silnik zaprojekt. na 91 oktan S818A Główny wyłącznik akumulatora S823A Wersja dla krajów tropikalnych S823A Wersja dla ciepłych krajów S825A Radio dla Oceanii S825A Radio dla Oceanii S826A Podwozie w kompozycji eksportowej S828A Zderzak - warianty krajowe S829A Przygotowanie do modyfikacji Cabrio Kod Nazwa S831A Brak radia S832A akumulator w bagażniku S834A Rozmiar braków 330d Francja S834A Brak uchwytu na kasety S835A Wersja turystyczna dla USA S836A Brak Bavaria CD 6 Selektion S837A Brak systemu nawigacji S837A Brak systemu głośników HiFi S839A Sterowanie pozorne Awaria-SA S840A Dostos. do wysokich prędkości S840A Brak pilota do radia S841A Pozorny numer klucza pakietu OW S842A Wersja dla zimnych krajów S843A Redukcja mocy S845A Akustyczne ostrzeżenie o pasach Kod Nazwa S847A Inst. do samoch. opancerzonych S847A Akumulator dodatk. do sieci C telefonu S848A Rozszerzona wiązka kabli S849A Tyl. św. poz. dla danego kraju S849A Brak autom. syst. powiadamiania alarm. S850A Dodatkowe napełnienie zbiorn. na eksport S851A Wersja językowa, niemiecki S852A Wersja językowa, japoński S853A Wersja językowa, angielski S854A Wersja językowa, francuski S855A Wersja językowa, włoski S856A Wersja językowa, hiszpański S857A Instalacja automatycznej klimatyzacji S858A Silnik niskoprężny S859A Dekodowanie funkcji TV Kod Nazwa S859A Dostosowanie/sterowanie IHKA S860A Dodatkowe światło kierunkowskazu S861A Zestaw danych bez EOBD S862A Definicja normy spalinowej/COC S862A Fotel mat. z przodu w przyp.pakietu taxi S863A Spis dealerów, Europa S864A Spis dealerów za oceanem S865A Stoliki / Podpórki stóp z tyłu S866A Wersja językowa, chiński uproszczony S866A Service Card Niemcy S866A Wersja językowa, tradycyjny chiński S867A Wersja językowa, koreański S868A Instalacja radiowa do ZF/ZI S868A Wersja językowa, niderlandzki S869A Instalacja radiowa do ZG/ZZ Kod Nazwa S869A Wersja językowa, szwajcarska S870A Wyposażenie "Salt" S871A Wyposażenie "Pepper" S872A Wyposażenie "Chili" S872A Instalacja pod montaż tel. na Japonię S873A Dummy-SALAPA S874A Częstotliwość radiowa 434 MHZ S875A Pilot na podczerwień S876A Częstotliwość radiowa 315 MHz S877A Brak obsługi krzyżowej S878A Oszkl. klim. komf. bez klina ziel. S879A Instrukcja obsługi po niemiecku S880A Instrukcja obsługi po angielsku S881A Instrukcja obsługi po francusku S882A Gutschrift fĂźr Erstausstattung Kod Nazwa S883A Instrukcja obsługi po hiszpańsku S884A Instrukcja obsługi po włosku S885A Instrukcja obsługi po szwedzku S886A Instrukcja obsługi po holendersku S886A Instrukcja obsługi po holendersku S887A Instrukcja obsługi, po arabsku S888A Instrukcja obsługi po duńsku S889A Instrukcja obsługi po fińsku S889A Instrukcja obsługi po portugalsku S890A Instrukcja obsługi po japońsku S891A Instrukcja obsługi po rosyjsku S892A Instrukcja obsługi, w trad. chińskim S895A Wentylator dodatkowy S896A Sterowanie św. do jazdy w dzień S897A Ciągły dźwięk do DWA Kod Nazwa S898A Wersja CKD S899A optyczne podawanie sygnałów do DWA S8ABA Joint Venture China S8ACA Dummy-SALAPA S8ADA Alpina Roadster S S8AEA Instr. obsł./Książka serw. po grecku S8AFA Instr. obsł./Książka serw. po koreańsku S8AGA CHAUFFEUR HANDBOOK IN ENGLISH S8ARA Owner‘s Handbook/Service Bklet, Romanian S8ASA Instr. obsł./książka serw. po chińsku S8EBA Steuerung Einzelbetriebserlaubnis S8HAA Dummy-SALAPA S8L1A Wymagania danego kraju dot. wyposażenia S8LBA Wymagania danego kraju dot. wyposażenia S8LFA Wymagania danego kraju dot. wyposażenia
  8. Dzięki din76 Porównam ze swoimi, dobra robota
  9. Chciałem całkiem ang zastąpić polskim i byłoby ok, tak to za dużo tego może być. Wrzuć co masz
  10. NcsDummy jest najlepszy :cool2: Próbowałem w tym tyg z bmw coding tool ale słabo w porównaniu do dummy A i chyba wezmę się za tłumaczenie z ANG na PL Jest ktoś chętny do pomocy? chodzi o prawidłowa interpretację tłumaczeń
  11. beda pasowac i takie najlepiej kupic szukaj ze srebrnymi sprezynami na allegro data prod jest zawsze wybita na silowniku szukaj najmlodszych Pzdr
  12. Długo nie używałem samochodu i niestety problem powrócił tylko tym razem czasami działa ok, czasami nie. Otwiera się i od razu zamyka, jak nie pomogę ręką i nie uniosę jej minimalnie nie zadziała... Sprężyny są jak nowe i działają ok krańcówka przy pompie czy czujnik położenia klapy??? Brakuje mi już pomysłów :mad2:
  13. Ok, masz racje :cool2: Gdzie pobrać coding tool? Żeby wszystko działało ok, trzeba jeszcze poprawnie skonfigurować profil EXPERTMODUS http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/1_zpsbd2554a2.jpg http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/2_zpsd07a8fc0.jpg http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/3_zps8a3efe5f.jpg http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/4_zps8b0b3f41.jpg HASŁO: REPXET http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/5_zps0972a86c.jpg http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/6_zps8936b557.jpg http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/7_zps694d0740.jpg http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/8_zpscea487d8.jpg http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/9_zpse67b9e38.jpg http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/10_zps68ee2bac.jpg http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/11_zpsacfda85b.jpg http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/12_zps0f8f5f07.jpg http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/13_zps63614d93.jpg http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/14_zpsa7d8aec9.jpg http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/16_zpsdebac3c3.jpg
  14. Włączasz funkcje: bi_xenon_bei_lh - FLASH_TO_PASS WITH BI-XENON LIGHTS INSTEAD OF HALOGEN LIGHTS ( mignięcie ostrzegawcze z bi-xenonem zamiast halogenów ) lub jeśli masz LM2 to jest coś takiego jak ustawisz przełącznik świateł na AUTO na długich nie beda w ogóle świecić halogeny, za to przekrecąjac światła w normalna pozycje świateł (max na prawo) będą normalnie z halogenami. fl_aus_bei_bix_in_s_flc - HIGH BEAMS WITH BI-XENON LIGHTS AND NOT WITH HALOGEN LIGHTSWHEN LIGHT SWITCH SET TO AUTOMATIC LIGHT CONTROL (FLC) ( światła długie bi-xenon bez halogenów w pozycji AUTO ) Pzdr
  15. INSTRUKCJA WEDŁUG ZALECEŃ NCS DUMMY I BMW CODING TOOL http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/1_zpsi071kkcq.jpg PLIK / WCZYTAJ http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/2_zps5ueqef5p.jpg REVTOR LUB EXPERTMODUS / OK http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/3_zpspwafts5z.jpg F1 / F3 http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/4_zpscv1mwyux.jpg MODEL / OK http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/5_zpspuyymaah.jpg GŁÓWNY MODUŁ PRZEZ KTÓRY SIĘ ŁĄCZYMY / OK http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/6_zpsi274dbvs.jpg WSTECZ http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/7_zpsfnwdmaw8.jpg F4 CZYTAJ ECU / WYBIERAMY MODUŁ DO KODOWANIA http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/8_zpspa1egm1d.jpg WYSKAKUJE MODUŁ KTÓRY CHCEMY KODOWAĆ / OK http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/9_zpsiplhtsbf.jpg ZAMYKAMY OKNO NETTODAT.TRC NCS SKOPIOWAŁ FSW_PSW DO PLIKU.TRC W C:/NCSEXPER/WORK URUCHAMIAMY NCS DUMMY http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/10_zps8mnf5kba.jpg MODEL SAMOCHODU LOAD FSW_PSW.TRC http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/11_zpsc6rrveae.jpg FILTER MODULES BY TRACE FILE http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/12_zps9nj7y17c.jpg FILTER http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/13_zpsizgpzjin.jpg W POLU WYSZUKIWANIA ZAZNACZAMY "v" WSZYSTKIE OPCJE, TE PO PRAWEJ / ODNAJDUJEMY ŻĄDANE FUNKCJE / ZAZNACZAMY CO CHCEMY WŁĄCZYĆ LUB WYŁĄCZYĆ http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/14_zpsr7zjzhql.jpg KLIKAMY EXPORT FSW_PSW.MAN W TYM MOMENCIE DANE ZOSTAŁY PRZESŁANE DO C:/NCSEXPER/WORK DO PLIKU FSW_PSW.MAN http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/15_zpstumzjrsr.jpg NIE ZAMYKAJ NCS DUMMY ZANIM NIE WCIŚNIESZ W NCS EXECUTE JOB, PONIEWAŻ NCS DUMMY AUTOMATYCZNIE PRZY ZAMYKANIU OPRÓŻNIA PLIK.MAN MOŻNA GO ZAMKNĄĆ ZANIM SKOŃCZYSZ W NCS TYLKO TRZEBA WCISNĄĆ CANCEL http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/16_zps0oew5j8o.jpg WRACAMY DO NCS I WCISKAMY/ZMIEŃ ZADANIE / SG_CODIEREN/ OK http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/17_zpssuttprcv.jpg WYKONAJ ZADANIE http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/18_zpstoqfgd8u.jpg GOTOWE http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/19_zpsqbmehptl.jpg JEŚLI CHCEMY JESZCZE PRZEKODOWAĆ JAKIŚ MODUŁ KLIKAMY ZMIEŃ ECU I RESZTA ANALOGICZNIE PONIŻEJ DRUGI SPOSÓB JEDNAK BARDZIEJ SKOMPLIKOWANY 1 - FILE / LOAD PROFIL http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/2_zpsa7a52664.jpg 2 - REVTOR LUB EXPERTMODUS / OK http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/3_zpsea4d8aba.jpg 3 - F1 / F3 / MODEL / OK http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/4_zps2bb8e7a7.jpg 4 - GŁÓWNY MODUŁ PRZEZ KTÓRY SIĘ ŁĄCZYMY / OK http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/6_zpsba71b228.jpg 5 - BACK http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/7_zps4a705f6c.jpg 6 - F4 PROCES ECU http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/8_zps6b8ca2c4.jpg 7 - MODUŁ KTÓRY CHCEMY KODOWAĆ / OK http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/9_zps88e28b75.jpg 8 - OK http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/10_zpsdb22928e.jpg 9 - F5 BASIC FUNCTIONS / capiReadSgGetFswPsw / OK http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/11_zps1af357e8.jpg 10 - KLIKAMY OK JEŚLI WYSKOCZY BŁĄD ZMIENIAMY POZYCJĘ CBD NAME O JEDEN NUMER W GÓRĘ / OK http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/12_zps6a6b260b.jpg NCS SKOPIOWAŁ FSW_PSW DO PLIKU.TRC W C:/NCSEXPER/WORK 11 - URUCHAMIAMY NCS DUMMY http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/13_zps2b714c71.jpg 12 - WYBIERAMY CHASIS NP: E65 http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/14_zps47809339.jpg 13 - WYBIERAMY NAZWĘ NASZEGO MODUŁU Z PUNKTU 10 http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/15_zpsbd8c432e.jpg 14 - LOAD FSW_PSW.TRC http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/16_zpsd4d7b71a.jpg 15 - ODZNACZAMY FUNKCJE KTÓRE CHCEMY WŁĄCZYĆ / WYŁĄCZYĆ http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/17_zps1477c8d3.jpg 16 - KLIKAMY EXPORT FSW_PSW.MAN W TYM MOMENCIE DANE ZOSTALY PRZESŁANE DO C:/NCSEXPER/WORK DO PLIKU FSW_PSW.MAN http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/18_zpsf0ed2703.jpg NIE ZAMYKAJ NCS DUMMY ZANIM NIE WCIŚNIESZ W NCS EXECUTE JOB, PONIEWAŻ NCS DUMMY AUTOMATYCZNIE PRZY ZAMYKANIU OPRÓŻNIA PLIK.MAN MOŻNA GO ZAMKNĄĆ ZANIM SKOŃCZYSZ W NCS TYLKO TRZEBA WCISNĄĆ CANCEL http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/19_zpsa8f0a9e6.jpg 16 - WRACAMY DO NCS I WCISKAMY / EXECUTE JOB http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/20_zps3a02e154.jpg W RAZIE JAKICHKOLWIEK PROBLEMÓW ZAWSZE MOŻEMY PRZYWRÓCIĆ ORYGINALNE USTAWIENIA MODUŁU WYKONUJĄC KROKI 1...10 NASTĘPNIE WCHODZIMY DO C:/NCSEXPER/WORK OTWIERAMY NOTATNIKIEM PLIK FSW_PSW.MAN OPRÓŻNIAMY JEŚLI NIE JEST PUSTY ZAMYKAJĄC ZAPISUJEMY ZMIANY WTEDY PUNKT 16 I GOTOWE http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/1_zpsb1ecd6b8.jpg 1 - FILE / LOAD PROFIL http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/2_zpsa7a52664.jpg 2 - REVTOR LUB EXPERTMODUS / OK http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/3_zpsea4d8aba.jpg 3 - F1 / F3 / MODEL / OK http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/4_zps2bb8e7a7.jpg 4 - GŁÓWNY MODUŁ PRZEZ KTÓRY SIĘ ŁĄCZYMY / OK http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/6_zpsba71b228.jpg 5 - BACK http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/7_zps4a705f6c.jpg 6 - F4 PROCES ECU http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/8_zps6b8ca2c4.jpg 7 - MODUŁ KTÓRY CHCEMY KODOWAĆ / OK http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/9_zps88e28b75.jpg 8 - OK http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/10_zpsdb22928e.jpg 9 - F5 BASIC FUNCTIONS / capiReadSgGetFswPsw / OK http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/11_zps1af357e8.jpg 10 - KLIKAMY OK JEŚLI WYSKOCZY BŁĄD ZMIENIAMY POZYCJĘ CBD NAME O JEDEN NUMER W GÓRĘ / OK http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/12_zps6a6b260b.jpg NCS SKOPIOWAŁ FSW_PSW DO PLIKU.TRC W C:/NCSEXPER/WORK 11 - URUCHAMIAMY NCS DUMMY http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/13_zps2b714c71.jpg 12 - WYBIERAMY CHASIS NP: E65 http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/14_zps47809339.jpg 13 - WYBIERAMY NAZWĘ NASZEGO MODUŁU Z PUNKTU 10 http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/15_zpsbd8c432e.jpg 14 - LOAD FSW_PSW.TRC http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/16_zpsd4d7b71a.jpg 15 - ODZNACZAMY FUNKCJE KTÓRE CHCEMY WŁĄCZYĆ / WYŁĄCZYĆ http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/17_zps1477c8d3.jpg 16 - KLIKAMY EXPORT FSW_PSW.MAN W TYM MOMENCIE DANE ZOSTALY PRZESŁANE DO C:/NCSEXPER/WORK DO PLIKU FSW_PSW.MAN http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/18_zpsf0ed2703.jpg NIE ZAMYKAJ NCS DUMMY ZANIM NIE WCIŚNIESZ W NCS EXECUTE JOB, PONIEWAŻ NCS DUMMY AUTOMATYCZNIE PRZY ZAMYKANIU OPRÓŻNIA PLIK.MAN MOŻNA GO ZAMKNĄĆ ZANIM SKOŃCZYSZ W NCS TYLKO TRZEBA WCISNĄĆ CANCEL http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/19_zpsa8f0a9e6.jpg 16 - WRACAMY DO NCS I WCISKAMY / EXECUTE JOB http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/20_zps3a02e154.jpg W RAZIE JAKICHKOLWIEK PROBLEMÓW ZAWSZE MOŻEMY PRZYWRÓCIĆ ORYGINALNE USTAWIENIA MODUŁU WYKONUJĄC KROKI 1...10 NASTĘPNIE WCHODZIMY DO C:/NCSEXPER/WORK OTWIERAMY NOTATNIKIEM PLIK FSW_PSW.MAN OPRÓŻNIAMY JEŚLI NIE JEST PUSTY ZAMYKAJĄC ZAPISUJEMY ZMIANY WTEDY PUNKT 16 I GOTOWE BEZ OBAW I MIŁEJ ZABAWY :cool2: PZDR
  16. WPISANIE NOWEGO VIN-U DO LMA 1 - ODCZYTUJEMY VIN http://i769.photobucket.com/albums/xx338/mareksokol/ZMIANA%20VIN%20W%20LM2/3_zps38648275.jpg FILE / LOAD PROFIL http://i769.photobucket.com/albums/xx338/mareksokol/ZMIANA%20VIN%20W%20LM2/4_zpsf1290bd6.jpg EXPERTMODUS / OK http://i769.photobucket.com/albums/xx338/mareksokol/ZMIANA%20VIN%20W%20LM2/1_zpscb4c65da.jpg F1 / F3 / E65 / OK http://i769.photobucket.com/albums/xx338/mareksokol/ZMIANA%20VIN%20W%20LM2/2_zpse8d46fd3.jpg F2 / POKAZUJE SIE VIN SAMOCHODU / ZAPISUJEMY 2 - ODCZYTUJEMY PLIK.PRG http://i769.photobucket.com/albums/xx338/mareksokol/ZMIANA%20VIN%20W%20LM2/3_zps38648275.jpg FILE / LOAD PROFIL http://i769.photobucket.com/albums/xx338/mareksokol/ZMIANA%20VIN%20W%20LM2/4_zpsf1290bd6.jpg EXPERTMODUS / OK http://i769.photobucket.com/albums/xx338/mareksokol/ZMIANA%20VIN%20W%20LM2/5_zpsc51f345a.jpg F1 / F3 / E65 / OK http://i769.photobucket.com/albums/xx338/mareksokol/ZMIANA%20VIN%20W%20LM2/6_zpse19b566b.jpg CAS / OK http://i769.photobucket.com/albums/xx338/mareksokol/ZMIANA%20VIN%20W%20LM2/7_zps468e0c92.jpg F4 http://i769.photobucket.com/albums/xx338/mareksokol/ZMIANA%20VIN%20W%20LM2/8_zpscc10f5c4.jpg LMA / OK http://i769.photobucket.com/albums/xx338/mareksokol/ZMIANA%20VIN%20W%20LM2/9_zps10076bbf.jpg W OKIENKU POKAZUJE SIE NAM NAZWA PLIKU.PRG / ZAPISUJEMY 3 - WPISUJEMY W/W DANE W TOOL32 http://i769.photobucket.com/albums/xx338/mareksokol/ZMIANA%20VIN%20W%20LM2/12_zps00e538e1.jpg FILE / LOAD SGBD GROUP FILE http://i769.photobucket.com/albums/xx338/mareksokol/ZMIANA%20VIN%20W%20LM2/13_zps75626e45.jpg SZUKAMY PLIKU.PRG WYMIENIONEGO W PKT 2 / ŁADUJEMY GO / OK http://i769.photobucket.com/albums/xx338/mareksokol/ZMIANA%20VIN%20W%20LM2/14_zps50e2133a.jpg WYBIERAMY OPCJE WRITE_FVIN / WPISUJEMY W/W NUMER VIN / JOB / SELECT JOB ONCE ONLY http://i769.photobucket.com/albums/xx338/mareksokol/ZMIANA%20VIN%20W%20LM2/15_zpsf65b5743.jpg ZMIANY ZAKONCZONE POZYTYWNIE http://i769.photobucket.com/albums/xx338/mareksokol/ZMIANA%20VIN%20W%20LM2/10_zps30ebfe42.jpg WYBIERAMY READ_FVIN / JOB / START JOB ONCE ONLY http://i769.photobucket.com/albums/xx338/mareksokol/ZMIANA%20VIN%20W%20LM2/11_zps220013fb.png SPRAWDZAMY ZAPISANY VIN PO WSZYSTKIM KODUJEMY NOWY MODUŁ LM2 PUSTYM PLIKIEM.MAN Uwaga Podczas kodowania LMA gdy wybierzemy F5 BASIC FUNCTIONS / capiReadSgGetFswPsw pojawi sie stara nazwa modułu w moim przypadku LM_E65.C05 trzeba ja wtedy manualnie zmienić wybierając któraś z opcji LM2_E6X.C32 LM2_E6X.C33 LM2_E6X.C34 LM2_E6X.C35 W moim przypadku LM2_E6X.C34 i wtedy dopiero zaczyta dane do FSW_PSW.TRC tak za każdym razem, ale nie robiłem jeszcze modułu przez winkfp więc może wtedy bedzie ok W NCS dummy też korzystamy z modułu który zaakceptował NCS lub Kodując LMA wcisnąć READ ECU F5 wszystko skopiuje się do .trc i już w NCS dummy jak załadujecie .trc wybrać z tych 4 modułów lub za pomocą filtra "filter modules by trace file..." sam się wyszuka INSTRUKCJA KODOWANIA Z NCS DUMMY viewtopic.php?f=48&t=260787&p=1945746#p1945746 Dodatkowe funkcje LM2 których nie było w LM1 Angel Eyes as DRL - Ringi jako swiatła do jazdy dziennej Jak zamontyje diody CREE może coś z tego będzie, na chwile obecna za słabe ringi mozna wybrac przygaszone drogowe/mijania iinne które chemy zeby świeciły lub nie Follow Me Home - Prowadz do domu Ustawiamy światła które chcemy i czas świecenia, możemy uruchamiac/gasić jak wczesniej przy kierownicy lub z pilota. Gasna wtedy po ustawionym czasie lub wczesniej przez powtorne nacisniecia guzika na pilocie Welcome Lights - Światla powitalne Ustawiamy swiatla które nam mają świecić po otwarciu samochodu dzialaja w pozycji AUTO/światel mijania Osobiscie zeby nie wyczerpywać akumulatora ustawione mam na powitalne rylko ringi przod i pozycyjne led tył Jeśli chce zeby sie zaswieciły np z światłami mijania używam follow me home guzikiem na pilocie Brake Force Display - BFD1 i BFD2 BFD1 Podczas gwałtownego chamowania bez ABS załączają się nam wybrane światła i decydujemy czy maja pulsować czy nie (u mnie na BFD1 załączają sie dodatkowo do standardowych świateł stop światła przeciwmgielne) BFD2 Podczas gwałtownego chamowania z ABS załączają się nam wybrane światła i decydujemy czy maja pulsować czy nie (u mnie na BFD2 wszystkie światła stop wraz z przeciwmgielnymi pulsują) Cornering Lights - Doświetlanie Przeciwmgielnymi Jeszcze tego nie zrobiłem bo coś nie tak ustawiam (za dużo opcji) Mam moduł od bi-xenonów skrętnych których fizycznie w samochodzie niema i tu trzeba trochę po kombinować Jeśli ma ktoś poliftingowa E65 z tą funkcja będę wdzięczny za FSW_PSW.TRC z LMA Jak zrobię doświetlanie przeciwmgielnymi to wrzucę swoje FSW_PSW.TRC żeby nikt nie musiał więcej kombinować
  17. KODOWANIE NOWEGO MODUŁU LM2 POTRZEBNE BĘDĄ: -NCS EXPERT -TOOL32 KOPIOWANIE FA Z CAS DO LM2 http://i769.photobucket.com/albums/xx338/mareksokol/KOPIOWANIE%20FA%20Z%20CAS%20DO%20LMA%20NCS/1_zps6b661bf9.jpg http://i769.photobucket.com/albums/xx338/mareksokol/KOPIOWANIE%20FA%20Z%20CAS%20DO%20LMA%20NCS/2_zps964f1d16.jpg http://i769.photobucket.com/albums/xx338/mareksokol/KOPIOWANIE%20FA%20Z%20CAS%20DO%20LMA%20NCS/3_zps4726fac3.jpg http://i769.photobucket.com/albums/xx338/mareksokol/KOPIOWANIE%20FA%20Z%20CAS%20DO%20LMA%20NCS/4_zpsc71c1b2a.jpg http://i769.photobucket.com/albums/xx338/mareksokol/KOPIOWANIE%20FA%20Z%20CAS%20DO%20LMA%20NCS/5_zps2e4572c7.jpg http://i769.photobucket.com/albums/xx338/mareksokol/KOPIOWANIE%20FA%20Z%20CAS%20DO%20LMA%20NCS/6_zpsf107955a.jpg http://i769.photobucket.com/albums/xx338/mareksokol/KOPIOWANIE%20FA%20Z%20CAS%20DO%20LMA%20NCS/7_zpsc0db21d3.jpg http://i769.photobucket.com/albums/xx338/mareksokol/KOPIOWANIE%20FA%20Z%20CAS%20DO%20LMA%20NCS/8_zps5e7946e7.jpg http://i769.photobucket.com/albums/xx338/mareksokol/KOPIOWANIE%20FA%20Z%20CAS%20DO%20LMA%20NCS/9_zpsddfdd4f8.jpg http://i769.photobucket.com/albums/xx338/mareksokol/KOPIOWANIE%20FA%20Z%20CAS%20DO%20LMA%20NCS/10_zps7160e99a.jpg http://i769.photobucket.com/albums/xx338/mareksokol/KOPIOWANIE%20FA%20Z%20CAS%20DO%20LMA%20NCS/11_zps8607f458.jpg http://i769.photobucket.com/albums/xx338/mareksokol/KOPIOWANIE%20FA%20Z%20CAS%20DO%20LMA%20NCS/12_zpsa03d3b65.jpg FA ZOSTAŁO SKOPIOWANE Z CAS DO LM2
  18. Na początku trzeba kupić odpowiedni moduł świateł. Wchodzimy na http://www.realoem.com/bmw/select.do wpisujemy swój VIN i sprawdzamy wyposażenie: bi-ksenony skrętne itp. Wracamy do tabeli z danymi samochodu i zmieniamy rok na LCI czyli najlepiej po 06'. Wchodzimy na moduł świateł i mamy wszystkie opcje modułów z ich numerami jakie były stosowane po lifcie. Poniżej w/w tabela TABELA E65 LCI http://i769.photobucket.com/albums/xx338/mareksokol/LM1%20-%20LM2/1_zpsfece9570.jpg http://i769.photobucket.com/albums/xx338/mareksokol/LM1%20-%20LM2/2_zps47d106e2.jpg Wybieramy moduł zgadzający się z naszym wyposażeniem. Spisujemy numery i już wiadomo mniej więcej jakie moduły o jakim numerze części kupić żeby działały ok. Jak widać mojego modułu niema na liście,a był wyciągnięty z E65 06' i działa. Nie wiem jak z ksenonami skrętnymi, ale jeśli macie samochód z ALC(AHL), lepiej znaleźć któryś z listy obsługujący skrętne. Moduł musi mieć LWR, bo chyba nie ma E65 bez samopoziomującego się ksenonu. W E65 po lifcie, jak widać w tabeli stosowane były jeszcze przejściowo LM1 Numery czsęści modułów zaczynają się od LM1 6135 6 _ _ _ _ _ _ LM2 6135 9 _ _ _ _ _ _ INSTRUKCJA WYMIANY MODUŁU Potrzebne narzędzia: - śrubokręt (krzyżak) - mały śrubokręt (płaski) - klucz płaski 10 mm - nóż do tapet http://i769.photobucket.com/albums/xx338/mareksokol/LM1%20-%20LM2/IMG_2197_zpsf02a4c3a.jpg Moduł oryginalny LM1 . http://i769.photobucket.com/albums/xx338/mareksokol/LM1%20-%20LM2/IMG_2132_zps854b0ccf.jpg Moduł LCI LM2 : http://i769.photobucket.com/albums/xx338/mareksokol/LM1%20-%20LM2/6bc77817-524a-4429-a353-fc83ae2cc338_zpsadd5db79.jpg Odkręcamy 4 śruby i zdejmujemy osłonę http://i769.photobucket.com/albums/xx338/mareksokol/LM1%20-%20LM2/IMG_2158_zpsee73765b.jpg Odkręcamy śrubę mocującą nawiew na nogi i zdejmujemy pociąągąjac w lewo. http://i769.photobucket.com/albums/xx338/mareksokol/LM1%20-%20LM2/IMG_2157_zpsf2aea3f4.jpg Poluzowujemy śrubę mocującą moduł i wysuwamy go przesuwając w lewo i do przodu http://i769.photobucket.com/albums/xx338/mareksokol/LM1%20-%20LM2/IMG_2154_zps680a541b.jpg Odpinamy kostkę http://i769.photobucket.com/albums/xx338/mareksokol/LM1%20-%20LM2/IMG_2147_zps2a2580cb.jpg Ściągamy obudowę kostki http://i769.photobucket.com/albums/xx338/mareksokol/LM1%20-%20LM2/IMG_2143_zps86719704.jpg Przepinamy pin 17 w miejsce pinu 60. Na zdj pin 17 już przepięty, strzałki wskazują gdzie nacisnąć, żeby pin wyszedł Trzeba przepiąć piny żeby świeciła dioda FLC (auto) przy przełączniku świateł i z tego co widzę robi się to tylko w modelach do 3/2003 wyposażonych w FLC. http://www.bimmerfest.com/forums/attachment.php?attachmentid=416231&d=1389236666 http://i769.photobucket.com/albums/xx338/mareksokol/LM1%20-%20LM2/694a8055-667f-4ce2-945f-e635e92054a8_zpse0748eed.jpg Obudowę kostki trzeba przerobić. Na zdjęciu na czerwono fragment kostki, którego trzeba się pozbyć wycinając ostrym nożem (jest to około 2,5 mm od krawędzi)
  19. Siema, kupiłem LCI 08' moduł TCU 1,5 MOST ECE i chce go wymienić, żeby łączyć swój telefon z samochodem. Z tego co wiem z forów to to, że sama wymiana nie stanowi problemu, jest plug & play Jednak jesli macie samochod z przed 3 03' z modułem TE65 (mój przypadek) trzeba zmienic dwie kostki które tam są w orginale na jedną 54 pinowa, odpowiednio poprzepinać piny, oraz dodatkowo kostkę światłowodu 2 pin Po 3 03' zwykłe TCU maja te same wyjscia co TCU 1,5 MOST ECE jednak bez funkcji bluetooth W obu przypadkach konieczna jest wymiana TCU i MMI (monitor) na LCI poliftingowy Trzeba zmienić FA Usunąć $638 lub $630 Telefon samochodowy Professional / Telefon samoch. z słuchawką bezprzew i dodać $633 Instalacja tel. kom. Business Później przekodować NCS-em, wyłączyć funkcje assist żeby nie wyświetlało błędów o karcie sim i s.o.s. Ori telefon do wyrzucenia, żeby nie zajmował miejsca i byłoby ok. Jak rusze temat dam znać narazie kompletuje w/w elementy Tutaj wszystko a temat http://www.bimmerfest.com/forums/showthread.php?t=600318 Pzdr
  20. Padł mi komp z wszystkim od NCS i nie pamietam dokladnie nazw funkcji pyt 1: W module od klimatyzacji funkcja car/key memory dajesz activ i samochod zapamietuje czy miales właczana ostatnio klime przy zgaszeniu samochodu czy nie. pyt 2: w module LM drl_ece dajesz na activ pokretlo zostawiasz na stale w pozycji swiatel mijania. Swiatla swieca odrazu po wlaczeniu sam po zgaszeniu samochodu wszystkie gasna (normalnie jak swiatla sa właczone gasisz silnik i mijania gasna ale swieca sie pozycyjne ringi i masz ostzezenie wylacz swiatla) Wlacznik swiatel caly czas pozostawiony w pozycji auto- to w dzien nie swieca a zapalaja sie po zmierzchu, reszta analogicznie zeby w poz auto zawsze sie palily trzeba bylo by wylaczyc sensor ale to zbedne , zostawiajac na mijania masz to samo co chciales na auto Pzdr
  21. U mnie klapa po otwarciu opadała a nie powinna dodatkowo po przymknieciu jej do dowolnego kąta powinna stac w miejscu i tak teraz jest Powodem były sprężyny (siłowniki) Najlepieej je zmienic na nowe poprawione poliftowe (srebrne sprezyny) Więcej na http://www.bmw-klub.pl/forum/viewtopic.php?f=76&t=257973 Jeśli ktoś potrzebuje olej do pompy i nie chce za to płacić prawie 300zł w servisie to zamiennikiem nieosiągalnego nigdzie indziej oryginalnego czerwonego oleju MOBIL AERO HF NATO H-515 MIL-H-5606 (ostatnia rewizja) DEF Stan.91-48/1 OM 15 jest również czerwony o praktycznie tych samych parametrach wg tabel olej AEROSHELL FLUID 41 NATO-Code: H-515 MIL-PRF-5606H DEF-STAN 91-48 Issue 2 Superclean DCSEA 415/A; AMG-10 Sprzedają go na ebay-u de / us w butelkach po 150ml za +/- 8 euro specjalnie do klapy E38,E39,E60,E61,E65,E66 , ja kupiłem ostatnio na OLX za 15zł 150ml Pzdr
  22. Cała sobota grzebania i sprawdzania kolejno mechanizmu dociągania, zamka klapy i czujników położenia klapy- wszystko ok. Problem znaleziony, opróżniłem schowek w klapie z trójkątem, apteczką i kluczami ,a klapa zaczęła działać za każdym razem, gdy ja otwieram bez najmniejszego problemu. Powodem są siłowniki - sprężyny pokrywy bagażnika (nr 23 na w/w zdj), są już słabe. U mnie klapa w zależności od temp opada gdy bagażnik jest otwarty do końca. Dodatkowo doczytałem że klapa ze sprawnymi sprężynami po przymknięciu do połowy czy jakiegokolwiek kąta powinna stać w miejscu. Pompa zaczynając pracę stara się podnieść klapę, jednak zaraz po otwarciu sprężyny nie maja wystarczająco siły żeby ja odpowiednio unieść i wspomóc prace pompy. Siła potrzebna do podniesienia klapy jest zbyt duża, ciśnienie w układzie wzrasta ponad dany próg, zawór w pompie (krańcówka - nr 4 na w/w zdj) rozłącza ją, a bagażnik się z powrotem zamyka. Gdyby siłowniki były ok, mógł by to być jeszcze zawór - czujnik ciśnienia (krańcówka) przy pompie, ale wątpliwe w tym wypadku jeśli sprężyny są do wymiany. Kupiłem sprężyny z ostatniego rocznika E65 LCI '08, są one już zmienione (nowego typu sprężyny są koloru srebrnego,poprzednia wersja całe czarne) używane kpl 50-100zł , nowe kpl 500zł. Wymieniłem, klapa działa jak nowa. I tak jak wyżej napisane można ją przymknąć do dowolnego kąta, a klapa zostanie na swoim miejscu. Do tego po otwarciu przez pompę klapy ( po wyłączeniu już pompy) wyraźnie widać jak siłowniki jeszcze ją unoszą. Jeśli kupujecie używki przez internet zwróćcie uwagę, żeby były z końca produkcji E65. Data produkcji jest wybita na górnej części każdego siłownika. Jeśli ktoś potrzebuje olej do pompy i nie chce za to płacić 300zł w servisie to zamiennikiem nieosiągalnego nigdzie indziej oryginalnego czerwonego oleju MOBIL AERO HF NATO H-515 MIL-H-5606 (ostatnia rewizja) DEF Stan.91-48/1 OM 15 jest również czerwony o praktycznie tych samych parametrach olej AEROSHELL FLUID 41 NATO-Code: H-515 MIL-PRF-5606H DEF-STAN 91-48 Issue 2 Superclean DCSEA 415/A; AMG-10 Sprzedają go na ebay-u de / us w buteleczkach po 150ml za +/- 8 euro specjalnie do klapy E38,E39,E60,E61,E65,E66 , ja kupiłem ostatnio na OLX za 15zł 150ml Pzdr
  23. Jak w temacie? Też zabieram się za upgrade mojego LM I E6X LWR na LM II E6X LWR w mojej e65 2002
  24. trzeba to sprawdzić... http://www.realoem.com/bmw/diagrams/l/b/284.png Nr./// Opis/// Uzupełnienie/// Ilość/// Od/// Do/// Numer części/// Cena 01 Agregat hydrauliczny 1 09/2003 51247137999 $954.57 tylko w połączeniu z -- Sterownik podn. pokrywy bagażnika 1 09/2003 61356964008 02 Obudowa gniazda 2 POLIG 1 61138352330 $2.00 tylko w połączeniu z -- Okrągła tul. wtykowa 2.5 ELA z kablem 1,0-2,5 MM² 2 61130007571 $2.65 -- Końcówka GELB 1.0-2.5MM² 2 61131383791 $0.20 03 Cylinder hydrauliczny 1 51247202868 $281.73 04 Zawór 1 02/2003 51247138000 05 Kpl. elem. drob. agreg. hydr. z olejem 1 51247202869 $80.56 06 Końcówka D=25 3 17212246033 $1.97 07 Nakrętka sześciokątna M6-8-ZNNIV SI 3 07119905544 $0.64 08 Czujnik położenia 1 07/2006 51247032635 09 Nakrętka samozabezpieczająca M6 2 34411152614 09 Nakrętka samozabezpieczająca M6 2 07146778500 $0.47 10 Kpl. elem. drob. agreg. hydr. z olejem 1 51247202869 $80.56 11 Trzpień kulisty M10 1 41218407017 $5.63 12 Czujnik górny 1 07/2007 54347171085 12 Czujnik położenia 1 51247202331 $107.86 +podst 13 Obudowa gniazda 6 POL. 1 61138383300 $3.47 tylko w połączeniu z -- Wtyk z przewodem 0,2- 0,5MM² 6 61130005199 $1.88 -- Wtyk z przewodem 0,75MM² 6 61130006665 $1.97 http://www.realoem.com/bmw/diagrams/q/c/209.png Nr./// Opis/// Uzupełnienie/// Ilość/// Od/// Do/// Numer części/// Cena 01 Zamek tylnej klapy 1 51247197081 $82.90 02 Śruba Torx z podkładką ISA M6X9 3 08/2006 51238165044 02 Śruba Torx z podkładką M6X12 3 07146985055 $0.38 03 Cięgno pokrywy bagażnika 1 03/2005 51247014871 $16.22 04 Uchwyt cięgna 1 51247010977 $2.50 05 Nit rozprężny 3 51488353567 $0.63 06 Zamek kodowany 1 03/2005 51247061934 $151.95 07 Zamek z kluczem 1 03/2005 51247061935 $168.57 08 Śruba Torx z podkładką ISA M6X9 3 08/2006 51238165044 08 Śruba Torx z podkładką M6X12 3 07146985055 $0.38 09 Klamra 1 51247037714 $9.60 10 Napęd siłownika zamka pokrywy bagażn. 1 67107014872 $176.55 11 Śruba Torx z podkładką ISA M6X9 3 08/2006 51238165044 11 Śruba Torx z podkładką M6X12 3 07146985055 $0.38 16 Zawias pokrywy bagażnika, lewy 1 09/2007 41627175307 $100.82 16 Zawias pokrywy bagażnika, prawy 1 09/2007 41627175308 $100.82 16 Zawias pokrywy bagażnika, lewy 1 41627175307 $100.82 16 Zawias pokrywy bagażnika, prawy 1 41627175308 $100.82 17 Śruba z podkładką ISA M8X18 4 07147111389 $1.05 18 Nakrętka z podkładką M8 6 07146959644 18 Nakrętka kołpakowa z podkładką M8 6 41627062753 $2.30 19 Uszczelka zawiasu pokrywy bagażnika 2 51247054178 $6.56 20 Pierścień zaciskowy 2 51247023110 $3.81 21 Uszczelka zawiasu pokrywy bagażnika 2 41627023109 $4.87 22 Płytka dystansowa D=1MM ? 41627112645 $3.58 23 Sprężyna pokrywy bagażnika 2 06/2007 51248223811 23 Sprężyna pokrywy bagażnika 2 51247201463 $73.60 Dla samochodów z Autom. uruchamianie tylnej klapy S316A=Tak 23 Sprężyna pokrywy bagażnika lewa 1 06/2007 51247042104 23 Sprężyna pokrywy bagażnika lewa 1 51247201461 $80.65 23 Sprężyna pokrywy bagażnika prawa 1 06/2007 51247058646 23 Sprężyna pokrywy bagażnika prawa 1 51247201462 $80.65 24 Zaślepka D=6MM 2 51711904603 $0.32 25 Odbojnik 2 51247051785 $6.58 26 Odbojnik 2 51248254063 $1.35
