schemat GM3 rozpiska wtyczek pinów
ma ktoś może rozpiskę pinów we wtyczce modułu gm3 ?
A w jakim samochodzie ?
530d e39 po lifcie, touring
A1 General module
Plug connector overview
Number X-pin, colour Description
X253 26-pin, black Plug connector B General module
X254 20-pin, black Plug connector C General module
X332 26-pin, black Plug connector A General module
Pin assignments at plug connector X253
Pin Type Description / Signal type Connection /
Measuring notes
1 A Signal, driver's door contact Driver's door contact switch
2 A Front lid signal Saloon only Front lid contact switch
3 Not used
4 A Interface signal RDC/DWA RDC control unit
5 A Interior protection Saloon only Interior protection control unit
6 Not used
7 A Wipe-wash control Intermittent wipe/wash control unit, rear
8 A Vehicle inclination signal Saloon only Tilt sensor
9 Not used
10 A Rear lid open signal Rear lid unlocking switch
11 A Rear lid open signal Rear lid release switch (interior)
12 A Signal, anti-jamming system Jamming protection switch, rear left window right-hand drive Jamming protection switch, rear right window
13 A Crash signal Airbag diagnostic module
14 Not used
15 E Wiper I activation Wiper relay
16 E Wiper II activation Wiper relay
17 A Headlight cleaner activation Headlight washer module
18 A Intensive wash activation Headlight washer module
19 E LED activation Electrochromic interior rear view mirror
20 A Inclination signal Tilt sensor
21 E Start lock relay Touring only Rear lid motor relay
22 E Relay Unlock boot lid Touring only Window motor relay
23 E Signal Rear left wheel speed (not used on S62) Integrated electronic control unit (IKE) Instrument cluster
24 A Signal, anti-jamming system Jamming protection switch, rear right window right-hand drive Jamming protection switch, rear left window
25 A Intermittent switching supply Windscreen wiper switch
26 M Terminal 31 Ground connector
Pin assignments at plug connector X254
Measuring notes
1 M Terminal 31 Power ground Ground point right-hand drive Ground connector
2 A Open window signal Power window motor, rear left right-hand drive Power window motor, rear right
3 A Engine Unlock boot lid ZV drive rear lid Touring Boot lid servo motor
4 E Terminal 30 Fuse F27
5 A Open window signal Power window motor, rear right right-hand drive Power window motor, rear left
6 A Lock signal ZV motor drives, rear doors/tank flap
7 Not used
8 M Terminal 31 Touring only Ground connector
9 A Servotronic activation (not used on S62) Electrohydraulic converter of servotronic
10 E Terminal 30 Fuse F4
11 A Servotronic activation (not used on S62) Electrohydraulic converter of servotronic
12 A Close window signal Power window motor, rear left right-hand drive Power window motor, rear right
13 A Central arrest signal ZV motor drives, rear doors
14 A Unlock signal ZV motor drives, rear doors/tank flap
15 A Close window signal Power window motor, rear right right-hand drive Power window motor, rear left
16 Not used
17 A Horn signal Antitheft horn (DWA)
18 A Pump signal Washer pump
19 A Signal, switch off consumer load Connector, switch off consumer load
20 A Interior lights signal Connector, interior lights
Pin assignments at plug connector X332
Measuring notes
1 E Terminal 30 Fuse F11
2 E Interior lights signal Interior/reading lamp, front
3 E Windscreen wash signal Windscreen wiper switch
4 E Windscreen wipe 2 signal Windscreen wiper switch
5 E Windscreen wipe 1 signal Windscreen wiper switch
6 E Door contact signal Rear RH door contact switch right-hand drive Rear left door contact switch
7 E Door contact signal Rear left door contact switch right-hand drive Rear RH door contact switch
8 E Door contact signal Passenger's door contact switch
9 E Signal, unlock/lock Saloon only Rear lid lock switch
10 A Intensive wash activation Headlight washer module
11 E Rear lid closed signal ZV drive rear lid
12 E/A K-bus signal line K-bus connector
13 E Central locking signal Electrochromic interior rear view mirror Remote control central locking
14 M Ground Ground connector
15 E Close window signal Rear left door power window switch right-hand drive Rear right door power window switch
16 E Intensive wash signal Windscreen wiper switch
17 E Open window signal Rear right door power window switch right-hand drive Rear left door power window switch
18 E Close window signal Rear right door power window switch right-hand drive Rear left door power window switch
19 E Signal soft-close automatic unlock Motor drive for rear lid servo lock
20 E Signal, windscreen wipers in motion Wiper motor
21 A Rear lid open signal Rear window servo opening switch
22 Not used
23 E Terminal R Fuse F38
24 E Close signal Central locking (ZV) switch
25 E/A P-bus signal line P-bus connector
26 E Open window signal Rear left door power window switch right-hand drive Rear right door power window switch
Dziękować :)
  • 1 rok później...
Ma ktoś taką rozpiskę do e39 z '96?
  • Członkowie klubu
WDS sie klania tam wszystko mozna znalezc.
Można liczyć na jakąś pomoc? Ciężko mi to ogarnąć. W których kategoriach mam szukać, poza tym tam w większości widzę symbole, a nie konkretne opisy. Możesz mnie oświecić?
