kazikm3
Treść opublikowana przez kazikm3
  1. a jakie wartości powinny mieć sondy ??
  2. u mnie jest to samo :)
  3. ja sobie RINGI podpiąłem pod oświetlenie wnętrza :D
  4. panowie kto mi powie co oznaczają te błędy :O silnik m43b19tu http://img683.imageshack.us/img683/203/bladinpa.jpg http://img856.imageshack.us/img856/1971/bladinpa2.jpg http://img51.imageshack.us/img51/6030/bladinpa3.jpg 125 to wiem lambda przed katem dodam ze check sie nie pojawia
  5. mam radio z 2003r. to dolne na zdjęciu http://img10.imageshack.us/img10/4306/dsc09030p.jpg chcę mieć aux do ipoda, taki kabel powinien załatwić sprawę http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=190445442915&ssPageName=STRK:MEWAX:IT mam taką rozpiskę http://homepage.ntlworld.com/richard.parkinson7/BMW/New%20Gen%2040%20Pin%20Radio%20pinout.jpg
  6. ;============================================================================= ;EDIABAS 6.4.3 Configuration [Configuration] ;============================================================================= ;----------------------------------------------------------------------------- ; EcuPath ; Description : ECU file path ; Default = . EcuPath = C:\EDIABAS\ECU ;----------------------------------------------------------------------------- ; SimulationPath ; Description : Simulation file path ; Default = . SimulationPath = C:\EDIABAS\SIM ;----------------------------------------------------------------------------- ; TracePath ; Description : Trace file path ; Default = . TracePath = C:\EDIABAS\TRACE ;----------------------------------------------------------------------------- ; CodeMapping ; Description : Character mapping file path ; Default = . ;CodeMapping = C:\EDIABAS\BIN\ansi2oem.tab ;----------------------------------------------------------------------------- ; TraceSize ; Description : Maximum size of each trace file [KB] ; Value : 0..32767 ; Default = 1024 ;TraceSize = 1024 ;----------------------------------------------------------------------------- ; ApiTrace ; Description : Enable/Disable API/User trace ; Value : 0 = Trace disabled ; 1 = User trace ; 2 = User trace + time stamp ; 3 = User trace + time stamp + process id (Win32) ; 4 = Function trace ; 5 = Function trace + time stamp ; 6 = Function trace + time stamp + timing ; 7 = Function trace + time stamp + timing + process id (Win32) ; Default = 0 ApiTrace = 0 ;----------------------------------------------------------------------------- ; IfhTrace ; Description : Enable/Disable IFH trace ; Value : 0 = Trace disabled ; 1 = Trace enabled ; 2 = Trace enabled ; 3 = Trace enabled ; Default = 0 IfhTrace = 0 ;----------------------------------------------------------------------------- ; SystemTraceSys ; Description : Enable/Disable system trace (runtime system) ; Value : 0 = Trace disabled ; Trace levels 1..7 ; Default = 0 SystemTraceSys = 0 ;----------------------------------------------------------------------------- ; SystemTraceBip ; Description : Enable/Disable BIP trace (runtime system) ; Value : 0 = Trace disabled ; Trace levels 1..7 ; Default = 0 SystemTraceBip = 0 ;----------------------------------------------------------------------------- ; SystemTraceIfh ; Description : Enable/Disable IFH system trace ; Value : 0 = Trace disabled ; Trace levels 1..7 ; Default = 0 SystemTraceIfh = 0 ;----------------------------------------------------------------------------- ; SystemTraceNet ; Description : Enable/Disable network trace ; Value : 0 = Trace disabled ; Trace levels 1..7 ; Default = 0 SystemTraceNet = 0 ;----------------------------------------------------------------------------- ; BipDebugLevel ; Description : BIP debug level of ECU files ; Value : 0..32767 ; Default = 0 BipDebugLevel = 0 ;----------------------------------------------------------------------------- ; UbattHandling ; Description : Ubatt ON/OFF handling ; Value : 0 = Ubatt ON/OFF: No EDIABAS error ; 1 = Ubatt ON/OFF: EDIABAS error ; Default = 1 UbattHandling = 1 ;----------------------------------------------------------------------------- ; IgnitionHandling ; Description : Ignition ON/OFF handling ; Value : 0 = Ignition ON/OFF: No EDIABAS error ; 1 = Ignition ON/OFF: EDIABAS error ; Default = 1 IgnitionHandling = 1 ;----------------------------------------------------------------------------- ; TaskPriority ; Description : EDIABAS process/thread priority (only Win32/16) ; Value : 0 = Optimal EDIABAS performance = 8 ; 1 = Minimal EDIABAS performance ; .. ; 10 = Maximal EDIABAS performance ; Default = 0 TaskPriority = 0 ;----------------------------------------------------------------------------- ; LoadWin32 ; Description : Map EDIABAS Win16 calls to EDIABAS Win32 ; Value : 0 = Win16/32 Mapping disabled (Win16-->Win16) ; 1 = Win16/32 Mapping enabled (Win16-->Win32) ; Default = 0 for Windows 9x/Me ; Default = 1 for Windows NT4/2000/XP LoadWin32 = 1 ;----------------------------------------------------------------------------- ; SystemResults ; Description : Enable/Disable system results (ubatt/ignition/jobstatus) ; Value : 0 = Disable system results ; 1 = Enable system results ; Default = 1 SystemResults = 1 ;----------------------------------------------------------------------------- ; RetryComm ; Description : Repeat failed communication automatically (1x) ; Value : 0 = Retry disabled ; 1 = Retry enabled (1x) ; Default = 1 RetryComm = 1 ;----------------------------------------------------------------------------- ; Simulation ; Description : Enable/Disable ECU simulation ; Value : 0 = Simulation disabled ; 1 = Simulation enabled ; Default = 0 Simulation = 0 ;----------------------------------------------------------------------------- ; Interface ; Description : Connected diagnosis interface ; Default = STD:OBD Interface = STD:OBD ; Additional information (in German) : ; Bitte beachten: Der HW-Treiber fuer das Interface muss installiert sein! ; Interface = STD:OBD ; Beschreibung : Serieller Pegelwandler (Nachfolger von ADS / Anschluss an OBD-Dose) ; Installation : \EDIABAS\HARDWARE\OBD\ODBSETUP (nur noetig fuer WIN NT4, WIN 2000, WIN XP) ; INI-Datei : OBD.ini nur benutzt wenn im Windows-Verzeichnis ; Unterstuetzung : WIN3.xx : Nein ; WIN95,98 16-Bit : Ja ; WIN95,98 32-Bit : Ja ; WIN NT 4.0 : Ja ; WIN XP : Ja ; Interface = STD:FUNK ; Beschreibung : Funk-Diagnose Interface MDA von Fa. Siemens ; Installation : keine ; INI-Datei : FUNK.INI ; Unterstuetzung : WIN95,98 16-Bit : Ja ; WIN95,98 32-Bit : Ja ; WIN NT 4.0 : Ja ; WIN XP : Ja ; Interface = OBD ; Beschreibung : Serieller Pegelwandler (Anschluss an Diagnose-Dose) ; Installation : \EDIABAS\HARDWARE\ADS\ADS32\ADSSETUP (nur fuer WinNT4 noetig) ; INI-Datei : keine ; Unterstuetzung : WIN95,98 16-Bit : Ja ; WIN95,98 32-Bit : Nein ; WIN NT 4.0 : Ja ; WIN XP : Ja ; Interface = KBUS ; Beschreibung : Serieller Pegelwandler (Anschluss direkt an K-Bus oder I-Bus) ; Installation : \EDIABAS\HARDWARE\ADS\ADS32\ADSSETUP (nur fuer WinNT4 noetig) ; INI-Datei : keine ; Unterstuetzung : WIN95,98 16-Bit : Ja ; WIN95,98 32-Bit : Nein ; WIN NT 4.0 : Ja ; WIN XP : Ja ; Interface = EDIC ; Beschreibung : Serielles , PCMCIA , PC-Card Interface von Fa. Softing ; Installation : \EDIABAS\HARDWARE\EDIC\SETUP.EXE ; INI-Datei : EDICFW.INI, EDICHW.INI ; Unterstuetzung : WIN95,98 16-Bit : Ja ; WIN95,98 32-Bit : Ja ; WIN NT 4.0 : Ja ; WIN XP : Ja ; Interface = EDICC ; Beschreibung : EDIC-Card C oder EDIC-Card 2 CAN-Interface von Fa. Softing ; Installation : \EDIABAS\HARDWARE\EDIC\SETUP.EXE ; INI-Datei : XEDICC.INI ; Unterstuetzung : WIN95,98 16-Bit : Ja ; WIN95,98 32-Bit : Ja ; WIN NT 4.0 : Ja ; WIN XP : Ja ; Interface = STD:CAN ; Beschreibung : PCMCIA CAN-Interface CanCardX von Fa. Vector ; Installation : keine (ausser Installation der CAN-Karte) ; INI-Datei : CANRTTP.INI ; Unterstuetzung : WIN95,98 16-Bit : ? ; WIN95,98 32-Bit : ? ; WIN NT 4.0 : Ja ; WIN XP : ? ; Ansprechpartner: Hr. Jusko ; Telefon : +49-(0)89/382-35891 (Hotline) ; email : [email protected] (Hotline) ; Interface = STD:ADS4MOST ; Beschreibung : Most-Interfaces von Fa. Oasis ; Installation : keine (ausser Installation der Oasis-Karte) ; INI-Datei : ADS4MOST.INI ; Unterstuetzung : WIN95,98 16-Bit : ? ; WIN95,98 32-Bit : ? ; WIN NT 4.0 : Ja ; WIN XP : Ja ; Ansprechpart.: Hr. Rowedder ; Telefon : 089 / 382-29159 ; email : [email protected] ; Interface = REMOTE ; Beschreibung : Anbindung eines EDIABAS-Interfaces über TCP/IP ; Installation : Anpassung der Einträge in [TCP] auf beiden Seiten (ins.: RemoteHost, Port) ; INI-Datei : keine ; Unterstuetzung : WIN95,98 16-Bit : Nein ; WIN95,98 32-Bit : Ja ; WIN NT 4.0, XP : Ja ; WIN XP : Ja ; Sonderfall : Interface OPPS ; Ansprechpart.: Hr. Rowedder ; Telefon : 089 / 382-29159 ; email : [email protected] ; Interface = REMOTE:name ; Beschreibung : Anbindung eines EDIABAS-Interfaces über TCP/IP ; Installation : Anpassung der Einträge in [TCP] auf beiden Seiten (ins.: RemoteHost, Port) ; INI-Datei : REMOTE.INI (insbesondere für Parallelbetrieb notwendig) ; In REMOTE.INI stehen unter [name] spezif. Einstellungen(z.B.: RemoteHost, Port) ; Unterstuetzung : WIN95,98 16-Bit : Nein ; WIN95,98 32-Bit : Ja ; WIN NT 4.0, XP : Ja ; WIN XP : Ja ; Sonderfall : Interface OPPS ; Ansprechpart.: Hr. Rowedder ; Telefon : 089 / 382-29159 ; email : [email protected] ;----------------------------------------------------------------------------- ; NetworkProtocol ; Description : Network protocol ; Default = NetworkProtocol = TCP ;============================================================================= ;TCP/IP Configuration [TCP] ;============================================================================= ;----------------------------------------------------------------------------- ; RemoteHost ; Description : server address/name ; Default = RemoteHost = 192.168.68.30 ;----------------------------------------------------------------------------- ; Port ; Description : IP communication port ; Value : 1000 < port < 30000 ; Default = Port = 6801 ;----------------------------------------------------------------------------- ;TimeoutConnect ; Description : Timeout for establishing the connection ; Default = 5000 TimeoutConnect = 2000 ;----------------------------------------------------------------------------- ;TimeoutReceive ; Description : Timeout for receiving a message ; Default = 5000 TimeoutReceive = 2000 ;----------------------------------------------------------------------------- ;TimeoutFunction ; Description : Timeout for a long function ; Default = 59000 TimeoutFunction = 10000 ;----------------------------------------------------------------------------- ;DisconnectOnApiEnd ; Description : Enable/Disable Disconnection with function call ApiEnd ; Value : 0 = Disconnection disabled ; 1 = Disconnection enabled ; Default = 0 ;DisconnectOnApiEnd = 1 ;----------------------------------------------------------------------------- ;InitCmd ; Description : Initialization command (normally for OPPS) ; Default = ;InitCmd0 = FE,04,00,03,01 ;InitCmd1 = FD,05,00,03,01 ;============================================================================= ; End Of File EDIABAS.ini ;============================================================================= http://img543.imageshack.us/img543/388/82340664.png http://img203.imageshack.us/img203/4012/73603637.png http://img204.imageshack.us/img204/407/25358626.png nie wiem co stało się z INPĄ, łączę się przez okrągłe złącze wykrywa bat. i ign. ale przez OBD w środku nie chcę się połączyć ? z góry dzięki :)
  7. witam panowie pomóżcie z instalacją DIS'a na win7 i vm7 doszedłem do api testu i nie przechodzi nie wiem co dalej ??
  8. sprawdzałem na real.oem mam dwie, teraz pytanie która ?
  9. u Ciebie po wymianie sondy pomogło ? a ile jest sond jedna czy dwie ? co do sondy to nie wiem, mam już ponad 260 tyś. (o ile ktoś nie grzebał) może kat nie domaga :?: czyli taka może być http://motoallegro.pl/item1172365663_bosch_sonda_lambda_bmw_e46_e36_e39_e60_e38_e53_e61.html
  10. u Ciebie po wymianie sondy pomogło ? a ile jest sond jedna czy dwie ?
  11. przepływkę wymieniałem, raczej sonda bo jest jakis błąd od sondy nr 141 jeszcze, ale silnik pali dobrze wiec chyba oleje :D
  12. nie tylko benzyna a co zrobiłeś że już nie masz ?
  13. panowie pomóżcie takie błędy mi wyskoczyły http://img718.imageshack.us/img718/305/bdyw.jpg http://img185.imageshack.us/img185/2852/bdy1.jpg
  14. nie wiem co zrobiłem, ale już się połączyłem z kompem :D przez OBD w aucie z silnikiem a pod maską z resztą :cool2: dalej mi wyskakują błędy ale coś można zrobić :norty:
  15. to napisz co mam teraz zrobić
  16. ale ten link nie działa :mad2:
  17. panowie pogrzebałem w ediabas.ini i teraz jest coś takiego http://img215.imageshack.us/img215/431/40656345.jpg
  18. mam na OBD USB II, było ustawione na COM3, a ja zmieniłem na COM1, nie wiem czy dobrze. a i przy zrobieniu OBD setup coś takiego http://img178.imageshack.us/img178/5061/60187770.jpg to znaczy że sterowniki są nie te ?
  19. panowie pomóżcie jestem szczęśliwym posiadaczem fejsa od nerwusa ale mam problem z zainstalowaniem inpy pod viste, po zainstalowaniu mam coś takiego http://img21.imageshack.us/img21/7095/53461642c.jpg a po kliknięciu ok jest tak http://img26.imageshack.us/img26/6516/37995597.jpg co mam pozmieniać? z góry dziękuje za pomoc
  20. e-46 w macie jest wypas :norty: :norty: :norty:
  21. kazikm3 odpowiedział(a) na et_cb199 temat w E46
    o co ci chodzi ?
  22. kazikm3 odpowiedział(a) na et_cb199 temat w E46
    tego nie napisałeś :nienie: tu masz rysunek z realoem http://www.realoem.com/bmw/diagrams/q/b/17.png ale o co ci chodzi to nie wiem
  23. a po naciśnięciu przycisku wysuwania słychać jakby chciało wysunąć ? jak tak to mu pomóż poruszaj nim
  24. potrzebujesz interfejs np. od nerwusa z forum :D
