Natknąłem się na to auto, zastanawia mnie zmiana puszki na filtry stożkowe, kiedy reszta seria.
Jak jest z takim radiem usa/canada w PL, będzie problem z odbiorem stacji radiowych ?
http://otomoto.pl/oferta/bmw-seria-3-e92-coupe-3-0i-306km-bixenon-lopatki-m-pakiet-335i-stan-idealny-ID6yC8Zw.html
Pozdrawiam!
rozkodowany vin
VIN WBAWB73577PV82973
Prod. Date 2006-08-18
Mileage Check mileage and service history
Type code WB73
Type 335I (USA)
Series E92 (3 Series)
Body Type COUPE
Steering LHD
Engine N54
Displacement 3.00
Power 225kw / 306hp
Drive HECK
Transmission Automatic
Colour ARKTIS METALLIC (A34)
Upholstery LEDER DAKOTAD2 JADEGRAU (LCD2)
Options
S205A Automatic transmission
S2C6A BMW LA wheel, star spoke 189
S2XAA Sport steering wheel with shift paddles
S319A Integrated universal remote control
S403A Glass roof, electrical
S430A Interior/outside mirror with auto dip
S431A Interior mirror with automatic-dip
S441A Smoker package
S464A Ski bag
S481A Sports seat
S488A Lumbar support, driver and passenger
S494A Seat heating driver/passenger
S4ADA Interior trim strips, alu, brushed, fine
S4NAA Interior mirror with digital compass
S534A Automatic air conditioning
S544A Dynamic cruise control
S548A Kilometer-calibrated speedometer
S563A Light package
S5GAA Preparation alarm system
S640A Preparation f tel.installation universal
S677A HiFi System Professional DSP
S693A Preparation BMW satellite radio
S694A Provisions for BMW 6 CD changer
S818A Battery master switch
L838A National version Canada
S840A High speed synchronisation
S8SPA Control unit COP
S925A Dummy-SALAPA
S998A Launch management, internal requirements
Standard Equipment
S226A Sports suspension settings
S459A Seat adjuster, electric, with memory
S520A Fog lights
S521A Rain sensor
S522A Xenon Light
S524A Adaptive Headlights
S645A BMW US Radio
S663A Radio BMW Professional
S823A Hot-climate version
S845A Acoustic belt warning
S850A Dummy-SALAPA
S853A Language version English
S876A Radio frequency 315 MHz
Ty się filtrem i lampami przejmujesz przy tej cenie?
JA bym się raczej zainteresował czy ćwiartka nie wpadła biorąc pod uwagę wygląd lewego kielicha i brak wklejek na lewym słupku B
Mam nadzieję że przy zakupie takiego auta jak 335i z przebiegiem 260tys za niecałe 40tys jesteś świadomy że pakiet startowy może wynieść na dzień dobry kilkanaście tys + tak jak poprzednicy pisali pochodzenie USA + spore prawdopodobieństwo że ćwiara wspawana
335i tanie w serwisie (pomijając spalanie 13-15l) nie jest, jak już się zacznie psuć to naprawy idą w grube tysiące, to nie 320d. Temperatura pracy 335i to 120 a bywa że i 130 stopni pod obciążeniem, dla porównania w dieselku 90 i to ma wpływ na zużywanie się szybsze podzespołów.
Daj znać jakie wrażenia z oględzin auta na żywo :)
29.04.2016 - SALVAGE - CANADA OSHAWA, ON
Grubo serwisowany ten samochód:
06.09.07 - 32 138 km - serwis olejowy, olej, filtr oleju, kontrola pojazdu, diagnostyka komputerowa pojazdu, opona letnia Bridgestone, zmiana opony, wyważenie koła
10.03.08 - 46 106 km - diagnostyka i programowanie pojazdu
03.09.08 - 60 016 km - prace przy szyberdachu, diagnostyka i programowanie pojazdu, płyn hamulcowy, uzupełnienie oświetlenia, śruba odpowietrzenia układu chłodzenia, sprawdzenie układu chłodzenia pod kątem wycieków, płyn do układu chłodzenia
27.11.08 - 67 046 km - serwis olejowy, olej, filtr oleju, mikrofiltr, kontrola pojazdu
20.01.09 - 71 870 km - pompa wysokociśnieniowa, uszczelki, elementy technologiczne, świece zapłonowe, diagnostyka komputerowa pojazdu
27.08.09 - 88 040 km - serwis olejowy, olej, filtr oleju, mikrofiltr, kontrola pojazdu, filtr powietrza, uzupełnienie oświetlenia
17.11.09 - 94 598 km - uszczelka miski olejowej automatycznej skrzyni biegów, tulejka uszczelniająca mechatroniki
05.02.10 - 99 622 km - wizyta serwisowa
16.03.10 - 102 389 km - filtr powietrza, świece zapłonowe, pompa wysokociśnieniowa, uszczelki, elementy technologiczne, cewka zapłonowa, diagnostyka komputerowa pojazdu
12.04.10 - 104 536 km - kolumna kierownicza, diagnostyka i programowanie pojazdu
27.08.10 - 112 499 km - serwis olejowy, olej, filtr oleju,diagnostyka komputerowa pojazdu, uzupełnienie oświetlenia
08.11.10 - 119 527 km - pompa wysokociśnieniowa, uszczelki, elementy technologiczne, diagnostyka komputerowa pojazdu
17.12.10 - 122 658 km - drążek kierowniczy lewy i prawy, geometria kół pojazdu
07.02.11 - 126 437 km - zawór ogrzewania, diagnostyka komputerowa pojazdu
16.03.11 - 129 193 km - osłona pokrywy głowicy
15.04.11 - 131 286 km - uzupełnienie oświetlenia, wspornik żarówek lampy tylnej prawej i lewej, diagnostyka komputerowa pojazdu
28.09.11 - 145 709 km - świece zapłonowe
30.09.11 - 145 714 km - termostat, pompa wody, śruby, uszczelki, elementy technologiczne, sprawdzenie układu chłodzenia pod kątem wycieków, diagnostyka komputerowa pojazdu
30.01.12 - 155 126 km - kontrola pojazdu
03.02.12 - 155 475 km - serwis olejowy, olej, filtr oleju, kontrola pojazdu, zawór vanos x 2, diagnostyka komputerowa pojazdu
07.03.12 - 158 220 km - klocki i tarcze hamulcowe przód
15.05.12 - 164 522 km - akumulator, diagnostyka i programowanie pojazdu
24.01.13 - 183 943 km - serwis olejowy, olej, filtr oleju, mikrofiltr, kontrola pojazdu, płyn hamulcowy, chłodnica wody, sprawdzenie układu chłodzenia pod kątem wycieków, diagnostyka komputerowa pojazdu
19.07.13 - 200 801 km - klocki i tarcze hamulcowe tył , mikrofiltr, zmiana opon, wyważenie kół, olej do wspomagania
21.11.13 - 211 175 km - serwis olejowy, olej, filtr oleju, kontrola pojazdu
wymiana oleju co 30-40tys km raczej temu silnikowi nie służy
Tak jest niestety ,że serwisy tak zalecają wymieniać ,a póżniej jest jak jest.Częsta wymiana oleju jest ważna w każdym aucie,a tym bardziej z takim fajnym silnikiem :wink:
Pompa wysokociśnieniowa 2 czy 3 razy wymieniana dawno temu zapewne niedługo będzie trzeba wymienić a to nie mały koszt
  • 4 miesiące temu...
  • Główni Moderatorzy
Wcześniej kosztował 39,900 ;)
Rozumiem pakiet startowy itp ale że 150% ceny :shock:
myśli że ktoś połasi się na moc 422KM i kupi ;)
wczesniej 39900 do nego czyli poszła za 37-38k a teraz 66335 to jakiś żart, za tyle to USA kupuje się 2011-2012r a nie 2006 jeszcze z przebiegiem bliskim 300tys
ale kto mu zabroni ,jego auto to może i 100tys cenić przecież :)
Tylko możliwe że on musiał dołożyć jeszcze opłaty celno akcyzowe. Dokładając
do tego te wszystkie części które są opisane w temacie to wcale nie wygląda
jakby został zrobiony pakiet startowy tylko doprowadzenie do stanu zadowalającego właściciela.
Stąd nie zakładałbym że on próbuje na tym zarobić 25k
Robię sobie wydatki wszystkiego i w exelu arkusz - na chwilę obecną wszystkie koszty włącznie z rej, ubezpieczeniem itd itp, moje widzi mi sie, mechanika, modyfikacje wyniosły tylko albo aż - 11700zł
To był post właściciela z 24 stycznia
+naprawa WG i regeneracji turbo
http://www.bmw-sport.pl/viewtopic.php?p=2139481#p2139481
Edytowane przez dawidWrc
kupiona za 38, włożone koło 12 w mody podnoszące moc i serwis=50
wszystko co ponad 50 to na + dla niego
to nie jest zadbany egz tylko 11letnie 335i z nalotem pod 300tys z ameryki
