INSTRUKCJA KODOWANIA NCS EXPERT / NCS DUMMY
INSTRUKCJA WEDŁUG ZALECEŃ NCS DUMMY I BMW CODING TOOL
http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/1_zpsi071kkcq.jpg
PLIK / WCZYTAJ
http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/2_zps5ueqef5p.jpg
REVTOR LUB EXPERTMODUS / OK
http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/3_zpspwafts5z.jpg
F1 / F3
http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/4_zpscv1mwyux.jpg
MODEL / OK
http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/5_zpspuyymaah.jpg
GŁÓWNY MODUŁ PRZEZ KTÓRY SIĘ ŁĄCZYMY / OK
http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/6_zpsi274dbvs.jpg
WSTECZ
http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/7_zpsfnwdmaw8.jpg
F4 CZYTAJ ECU / WYBIERAMY MODUŁ DO KODOWANIA
http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/8_zpspa1egm1d.jpg
WYSKAKUJE MODUŁ KTÓRY CHCEMY KODOWAĆ / OK
http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/9_zpsiplhtsbf.jpg
ZAMYKAMY OKNO NETTODAT.TRC
NCS SKOPIOWAŁ FSW_PSW DO PLIKU.TRC W C:/NCSEXPER/WORK
URUCHAMIAMY NCS DUMMY
http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/10_zps8mnf5kba.jpg
MODEL SAMOCHODU
LOAD FSW_PSW.TRC
http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/11_zpsc6rrveae.jpg
FILTER MODULES BY TRACE FILE
http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/12_zps9nj7y17c.jpg
FILTER
http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/13_zpsizgpzjin.jpg
W POLU WYSZUKIWANIA ZAZNACZAMY "v" WSZYSTKIE OPCJE, TE PO PRAWEJ / ODNAJDUJEMY ŻĄDANE FUNKCJE / ZAZNACZAMY CO CHCEMY WŁĄCZYĆ LUB WYŁĄCZYĆ
http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/14_zpsr7zjzhql.jpg
KLIKAMY EXPORT FSW_PSW.MAN
W TYM MOMENCIE DANE ZOSTAŁY PRZESŁANE DO C:/NCSEXPER/WORK DO PLIKU FSW_PSW.MAN
http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/15_zpstumzjrsr.jpg
NIE ZAMYKAJ NCS DUMMY ZANIM NIE WCIŚNIESZ W NCS EXECUTE JOB, PONIEWAŻ NCS DUMMY AUTOMATYCZNIE PRZY ZAMYKANIU OPRÓŻNIA PLIK.MAN
MOŻNA GO ZAMKNĄĆ ZANIM SKOŃCZYSZ W NCS TYLKO TRZEBA WCISNĄĆ CANCEL
http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/16_zps0oew5j8o.jpg
WRACAMY DO NCS I WCISKAMY/ZMIEŃ ZADANIE / SG_CODIEREN/ OK
http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/17_zpssuttprcv.jpg
WYKONAJ ZADANIE
http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/18_zpstoqfgd8u.jpg
GOTOWE
http://i769.photobucket.com/albums/xx338/mareksokol/instr%20ncs%20new/19_zpsqbmehptl.jpg
JEŚLI CHCEMY JESZCZE PRZEKODOWAĆ JAKIŚ MODUŁ KLIKAMY ZMIEŃ ECU I RESZTA ANALOGICZNIE
PONIŻEJ DRUGI SPOSÓB JEDNAK BARDZIEJ SKOMPLIKOWANY
1 - FILE / LOAD PROFIL
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/2_zpsa7a52664.jpg
2 - REVTOR LUB EXPERTMODUS / OK
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/3_zpsea4d8aba.jpg
3 - F1 / F3 / MODEL / OK
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/4_zps2bb8e7a7.jpg
4 - GŁÓWNY MODUŁ PRZEZ KTÓRY SIĘ ŁĄCZYMY / OK
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/6_zpsba71b228.jpg
5 - BACK
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/7_zps4a705f6c.jpg
6 - F4 PROCES ECU
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/8_zps6b8ca2c4.jpg
7 - MODUŁ KTÓRY CHCEMY KODOWAĆ / OK
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/9_zps88e28b75.jpg
8 - OK
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/10_zpsdb22928e.jpg
9 - F5 BASIC FUNCTIONS / capiReadSgGetFswPsw / OK
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/11_zps1af357e8.jpg
10 - KLIKAMY OK JEŚLI WYSKOCZY BŁĄD ZMIENIAMY POZYCJĘ CBD NAME O JEDEN NUMER W GÓRĘ / OK
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/12_zps6a6b260b.jpg
11 - URUCHAMIAMY NCS DUMMY
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/13_zps2b714c71.jpg
12 - WYBIERAMY CHASIS NP: E65
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/14_zps47809339.jpg
13 - WYBIERAMY NAZWĘ NASZEGO MODUŁU Z PUNKTU 10
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/15_zpsbd8c432e.jpg
14 - LOAD FSW_PSW.TRC
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/16_zpsd4d7b71a.jpg
15 - ODZNACZAMY FUNKCJE KTÓRE CHCEMY WŁĄCZYĆ / WYŁĄCZYĆ
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/17_zps1477c8d3.jpg
16 - KLIKAMY EXPORT FSW_PSW.MAN
W TYM MOMENCIE DANE ZOSTALY PRZESŁANE DO C:/NCSEXPER/WORK DO PLIKU FSW_PSW.MAN
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/18_zpsf0ed2703.jpg
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/19_zpsa8f0a9e6.jpg
16 - WRACAMY DO NCS I WCISKAMY / EXECUTE JOB
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/20_zps3a02e154.jpg
W RAZIE JAKICHKOLWIEK PROBLEMÓW ZAWSZE MOŻEMY PRZYWRÓCIĆ ORYGINALNE USTAWIENIA MODUŁU WYKONUJĄC KROKI 1...10
NASTĘPNIE WCHODZIMY DO C:/NCSEXPER/WORK OTWIERAMY NOTATNIKIEM PLIK FSW_PSW.MAN OPRÓŻNIAMY JEŚLI NIE JEST PUSTY
ZAMYKAJĄC ZAPISUJEMY ZMIANY WTEDY PUNKT 16 I GOTOWE
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/1_zpsb1ecd6b8.jpg
5 - BACK
6 - F4 PROCES ECU
8 - OK
BEZ OBAW I MIŁEJ ZABAWY :cool2:
PZDR
Edytowane przez bmw-power
  • Odpowiedzi 397
  • Wyświetleń 355,9 tys.
Bardzo dobra instrukcja kolego :cool2:
Możesz jeszcze zrobić jak będziesz miał czas przez Read ECU (F4) zamiast F5 BASIC FUNCTIONS / capiReadSgGetFswPsw / OK
Mam ncs dummy, ele jakoś łatwiej przez Coding Tool, może kwestia przyzwyczajenia.
Ok, masz racje :cool2:
Gdzie pobrać coding tool?
Żeby wszystko działało ok, trzeba jeszcze poprawnie skonfigurować profil EXPERTMODUS
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/1_zpsbd2554a2.jpg
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/2_zpsd07a8fc0.jpg
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/3_zps8a3efe5f.jpg
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/4_zps8b0b3f41.jpg
HASŁO: REPXET
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/5_zps0972a86c.jpg
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/6_zps8936b557.jpg
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/7_zps694d0740.jpg
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/8_zpscea487d8.jpg
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/9_zpse67b9e38.jpg
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/10_zps68ee2bac.jpg
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/11_zpsacfda85b.jpg
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/12_zps0f8f5f07.jpg
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/13_zps63614d93.jpg
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/14_zpsa7d8aec9.jpg
http://i769.photobucket.com/albums/xx338/mareksokol/NCS%20DUMMY/EXPERTMODUS/16_zpsdebac3c3.jpg
http://chomikuj.pl/Dinpl/BMW/NCS+4.0.1/Dodatki+NCS/BMW+Coding+Tool+v240,3757352470.rar(archive)
W windows 7 , 8 32/64bit przed uruchomieniem z dowolnej lokalizacji wejdź we Właściwości, zakładka, zgodność (ustaw na Windows XP SP3 i zaznacz uruchom jako administrator) Aplikacja Coding Tool
(nawet myślałem aby sobie tłumacza przetłumaczyć na język Polski)
Nie jest trudno otwierasz plik w Coding tool\ "Translations" i tłumaczysz zamiast angielskiego polskie tłumaczenie, muszę powiedzieć że najnowszy NSC dummy ma lepsze
tłumaczenie, tzn więcej jest przetłumaczone, sprawdziłem można przełożyć do Coding tool
Dziękuje bmw-power. Jesteś gość! Bardzo przydatna instrukcja.
Pozdrawiam.
Kolego bmw-power muszę Cie znowu pochwalić kodowałem dziś e46 KMB licznik i dla sprawdzenie i nauki zamiast coding tool wybrałem NCS DUMMY i muszę
przyznać, mimo żę jest bardziej skomplikowany, NCS DUMMY jest lepszy do kodowania wszystkie funkcje do zaznaczenia są widoczne nie trzeba zgadywać
nie mówię to o prostej funkcji jak aktiv i nicht_aktiv ale chciałem sobie kiedyś zmniejszyć przebieg miedzy wymianami oleju z 22-tyś do 16-tyś i nie pozwalał na to
sterownik KMB już wiem dlaczego jest tylko kilka możliwości do wyboru gdybym wybrał 15-tys od razu to bym zakodował ale w Coding tool nie ma tej funkcji widocznej
a w NCS DUMMY jest wszystkie możliwości pokazane tylko zaznaczamy właściwe i gotowe.
I też jest funkcja szukaj, jak koduje to mam przygotowaną ściągawkę w notatniku funkcje do
zakodowania i tylko kopiuje i wklejam do ramki szukaj lupa FIND po prawej stronie i samo odnajduje funkcje do zmiany w FSW_PSW po zmianie export man i
dla mnie F2 Codiren SG >F3 i gotowe
:cool2:
NcsDummy jest najlepszy :cool2:
Próbowałem w tym tyg z bmw coding tool ale słabo w porównaniu do dummy
A i chyba wezmę się za tłumaczenie z ANG na PL
Jest ktoś chętny do pomocy? chodzi o prawidłowa interpretację tłumaczeń
Nawet mam gdzieś tłumaczenie , ale nie trzeba usuwać eng tylko można dopisać po polsku jak tak robię w INPIE w plikach ipo wtedy lepiej się uczysz angielskiego
jak znajdę to wkleję wszystkie co mam na forum
NCS SPIS OPCJI PLIK FSW
HEIMLEUCHTEN - czas świecenia
(wert_02 - minuta LUB wert_03 - 2 minuty)
HEIMLEUCHTEN_ABBRUCH : - wyłaczenie odprowadzania
HEIMLEUCHTEN_AL : - odprowadanie światłami mijania
HEIMLEUCHTEN_BL : - odprowadzanie STOPami
HEIMLEUCHTEN_BLK : - odprowadzanie kierunkowskazami.
HEIMLEUCHTEN_FL : - odprowadzanie drogowymi
HEIMLEUCHTEN_FUNKSCHL : - odprowadzanie po zamknięciu pilotem
HEIMLEUCHTEN_KL58G : - odprowadzanie światłami wewnętrznymi (+popielniczka, słupki itp.)
HEIMLEUCHTEN_KZL : - odprowadzanie oświetleniem tablic rej.
HEIMLEUCHTEN_NSL : - odprowadzanie tylnymi przeciwmgielymi
HEIMLEUCHTEN_NSW : - odprowadzanie halogenami
HEIMLEUCHTEN_RFS : - odprowadzanie światłami cofania
HEIMLEUCHTEN_SL_H : - odprowadzanie tylnymi postojówkami
HEIMLEUCHTEN_SL_V : - odprowadzanie przednimi postojówkami
_
Tu masz komendy. miłego szukania
**** FSW-PSW :action caused by aktiv/nicht aktiv selection ****
ABFRAGEZEIT_AHM : - czestotliwość kontroli modułu przyczepy
ABKLAPPSTELLUNG : – zmiana położenia wycieraczek – po zgaszeniu auta poz. pionowa gdy “active”
ABKLAPPWERT : – wartość klapy Touring
ABSCHALTDREHZAHL_ANLASSER : – odcięcie rozrusznika przy RPM
ABSCHALT_GESCHWINDIGKEIT : - prędkość wyłączania
ABSCHALT_KL50 : - wyłącza przycisk rozrusznika gdy “active”
ABSCHALTKRITERIUM : – włącza zabezpieczenie (odbojnik szyby) kiedy „active“
ABSCHALTMELDUNG : – potwierdzenie wyłączenia
ABSCHALTSPANNUNG_KL_30 : – wartość wyłączenia
ABSCHALTUNG_UNTERSPG : – przekroczona wartość wyłączenia (w dół)
ABSCHALTUNG_VERBRAUCHER : – wyłączenie - użytkownik
ABSCHALTWEG : – wyłączanie po przebiegu
ABSENKUNG_10_KM/H : - Obniżanie po 10 km/h
ABS_MIN_STELLUNG_2 : – minimalne położenie ABS
ABSTAND_HOLD_NORMAL_MODE : – tryb normalny utrzymywania dystansu
ABSTAND_KALTPULSE :
ABSTELLPOS_CUSTOM : shut down?
ABSTELLPOS_SMC :
ABTASTRATE_DYN  ynamic feeler rate. wert_01
ABTASTRATE_TREND :
ACC_FLAG : – aktywacja wskaźnika tempomatu
ADRESSE_AUSWERTEN : – ewaluacja (kontrola) adresu
AIRBAG_BEIFAHRER_1 : – poduszka pasażera
AIRBAG_FAHRER_1 : – poduszka kierowcy
AIRBAG_TRIGGERED_E-CALL : – wystrzelona poduszka dzwoni pod 112 telefonem pokładowym
AKUSTIK_ABBLENDLICHT : – alarm słabej wiązki (drogowe)
AKUSTIK_BREMSLICHT : – sygnał dźwiękowy światła stopu
AKUSTIK_DSC_ASC : – alarm aktywnego DSC lub ASC
AKUSTIK_GURT_WARN : – alarm niezapiętego pasa bezp.
AKUSTIK_HECKKLAPPE : – alarm otwartego bagażnika
AKUSTIK_KONZEPT : alarm concept ?
AKUSTIK_PARKBREMSE : – alarm hamulca postojowego (ręczny)
AKUSTIK_RDKS : – alarm niskiego ciśnienia powietrza
AKUSTIK_RUECKLICHT : – alarm – światła tylne
AKUSTIK_TUEREN : – alarm otwartych drzwi
AKUSTIK_WASCHWASSER : – alarm niski poziom płynu do spr.
AL_ALS_DRL : – słabe światła podczas użytkowania świateł dziennych
ALARM_AKUSTISCH : – wybór dźwięku alarmu
ALARM_AKUSTISCH_LANG : - długi dźwięk alarmu
ALARMSCHALTER_SI_FZG : – przełączanie alarmu
ALARMSCHALTER_TAXI : przełącznik alarmu (wersja taxi)
ALARM_OPT_ABBLENDLICHT : miganie słabymi światłami kiedy alarm aktywowany
ALARM_OPT_WARNBLINKER : miganie awaryjnymi kiedy alarm aktywowany
ALARM_OPT_FERNLICHT : miganie mocnymi światłami kiedy alarm aktywowany
ALC : – automatyczna kontrola poziomu
ALC_ABSENKUNG_10_KM/H : Automatyczna kontrola obniżania o 10km/h
ALC_AUSWERT_GRADIENT :
ALC_AUSWERT_PROP_ABWEICH :
ALC_FAILSAFE_FCT_EIN :
ALC_FAILSAFE_NSW_AUS_OPT1 :
ALC_FAILSAFE_NSW_AUS_OPT2 :
ALC_FAILSAFE_NSW_EIN :
ALC_FAILSAVE_NSW_LOCK :
ALC_FAILSAVE_NSW_NEU :
ALC_GRADIENT_SCHLECHTWEG :
ALC_KLS_ENABLE :
ALC_KLS_DISABLE :
ALC_LED_DEF : Automatyczna kontrola uszkodzonych LED
ALC_LWR_VORZEICHEN :
ALC_SAETT_TIMER_SCHLECHTW :
ALC_SCHWENK_LATCH :
ALC_VERBAUT
AL_KL_50 : słabe światła kiedy zapłon ON
ANHAENGERKUPPLUNG : wyłączanie tylnego PDC kiedy podłączona wiązka przyczepy
ANHAENGERMODUL_PWM_WERT : Wartość napięcia modułu przyczepy.
ANHEBUNG_175_KM/H : podnoszenie przy 175 km/h??
ANKUNFTSZEIT_VON_NAVI : czas przybycia pobierany z NAVI
ANLAUFSTROMBEGRENZ_MEMO : - ostrzeżenie zakłócenia napięcia
ANPRESSDRUCKVERSTELLUNG : - ustawienie sły nacisku wycieraczek
ANTI_DROEHN_STELLUNG :
ANZAHL_QUICK_RUNDEN : - ilośc szybkich obrotów.
ANZAHL_RAEDER_VERBAUT : - ilość zamontowanych kół
ANZAHL_SPRITZIMPULSE : - Ilość impulsów sprayowania
ANZAHL_STUFEN : - Ilość poziomów.
ANZEIGE_EML : - wyświetlanie ładowanie silnika el.
ANZEIGE_ANKUNFTSZEIT : - pokaż czas przybycia
ANZEIGE_HOCHLADEN : - pokaż przeładowanie.
ANZEIGE_OELSTAND_PREDRIVE : - pokaż poziom oleju przed ruszeniem
ANZEIGE_POSITION_AUS : - pokaż położenie.
ANZEIGE_SITZLEHNE_VER : - pokaż położenie fotela
ANZEIGE_UHR_IM_DISPLAY : - pokaż zegar
ASC : - kontrola trakcji
ASC3_AUSWERTUNG : – wykorzystanie ASC
ASC_PREDRIVE_UEBER_SG :
ASL :
ASL_DSC_5_7 :
ATEMP_WARNUNG_KALTLAND : – ostrzeżenie niskiej temp. zew
AUFHEIZAUTOMATIK : – automatyka ogrzewania
AUSSENGEFUEHRTE_SHDUSSENTEMP_ABH_GEBL_ANH_1 :
AUSSENTEMPERATUR_KORR : - korekta wskazań temp zewnętrznej
AUSSENTEMP_BEWERT : - szacowanie temp zewnętrznej
AUSSENTEMP_SENSOR : – czujnik temperatury zewnętrznej
AUSSENTEMP_SPERRZEIT_2 : – zablokowanie zegara (temp. zew.) – wartość nr 1
AUSSENTEMP_SPERRZEIT_3 : – zablokowanie zegara (temp. zew.) – wartość nr 2
AUSSENTEMP_WARN_AKUSTIK : – ostrzeżenie dźw. temp. zew.
AUSSENTEMP_WARNUNG_GONG : – gong ostrzegawczy temp.zew
AUSSTATTUNG_RPA : - wersja RPA
AUSSTELLFENSTER : – okno uchylne
AUSTAUSCHPUNKT : – punkt kontrolny (wymiana)
AUSWERT_GRADIENT : - Pochylenie przyczepy
AUSWERT_PROP_ABWEICHUNG :
AUT_SPIEGELVERSTELLUNG : – ustawienie lusterek dla kluczyka
AUT_SITZVERSTELLUNG : – automatyczne pozycjonowanie fotela kiedy drzwi otwarte, lub odrygl. pilotem
AUTO_B_ZUEND_EIN_1; – predkość nawiewu przy zapłonie ON dla klucz 1
AUTO_LED_GEBL_MANUELL :
AUTO_LED/SCHRIFTZUG : - ciągłość listwy LED
AUTO_LWR_ENABLE : – kontrola samopoziomowania świateł
AUTOMATISCHER_NOTRUF : – automatyczne powiadomienie na 112
AUTOM_FAHRL_STEUERG : – automatyczny kontroler przednich świateł
AUTO_ZV_DISABLE : – wyłączenie zamka.centr
BACKUP_ANTENNA : - zapasowa antena
BACKUP_BATTERY : - zapasowa bateria
BACKUP_BATTERY_ENABLED : - włączenie zapasowej baterii
BAUREIHE_A : – seria (np 3er/5er/7er)
BC_ANFORD_WEGFAHRSICH : - żadanie zezwolenia przez OBC
BC_CODE_AKTIV : funkcja blokady zapłonu przez OBC (CODE)
BC_DIGITAL_V = wyświetla cyfrowo prędkość na desce kiedy “active”
BC_KL_R : w pozycji R OBC pokazuje ostatnią wybieraną funkcję.
BC_V_KORREKTUR : - jeżeli “active” pozwala korygować wskazania prędkości INPĄ
BEDIENSTELLE_BFT : -Sekcja kontrolna drzwi kierowcy
BEGRENZUNGSLICHT_IN_PARK ; oświetlenie obrysowe podczas parkowania
BEIFAHRERBAG_STUFE2_1 : - poduszka pasażera w trybie “2_1”
BEIKLAPPEN_B_KOMFORTSCHL : przytrz. zamykanie na pilocie żeby zamknąć szyby I złożyć lusterka
BELUEFTUNGSKLAPPE_OEFF_1 : nawiewy otwarte podczas nagrzewania
BETRMODI_DEAKT_KL15_EIN :
BETR_STD_AUTO_LOESCH :B_SATELLIT_1
BETR_STD_NICHT_LOESCHEN : No deleting of usage hours
BEWERTUNG_FEHLER : - szacowanie uszkodzenia
BEWERTUNG_FEHLER_30 : - „hot-line“ szacowania uszkodzenia.
BEWERTUNG_FEHLER_31 : szacowanie uszkodzenia uziemienia podwozia
BFD_ABS_STUFE3 :
BFD_ASC_REG :
BFD_AX_REF :
BFD_ON :brake force display on
BFD_OPTION :
BFD_SCHWELLE :
BFD_ST3_ON :
BFD_SW1_STUFE :
BFD3_ASC_AKTIV :
BF_UEBERWACHUNG : - kontrola (obecności?) pasażera
BI_XENON : - bixenony.
BIXENON_EIN_BEI_LICHTHUPE : - błyśnięcie bixenon+halogeny
BL_ALS_SL_DIMMEN : - Stopy ściemniane do poziomu postojowych?
BL_DIMMEN : - zmienna siła światła STOP?
BL_DIMMUNGS_OPT_1 :
BL_ERSETZ_DEFEKT_SL : - światła STOP zastępują spalone pozycyjne.
BL_ERSETZT_DEFEKT_BLK : - światła STOP zastępują spalone kierunkowskazy
BLEND_CHECK_IST_WINKEL :
BLEND_CHECK_SOLL_WINKEL :
BL_GEDIMMT_ALS_ERSATZ :brake light &
BL_GED_ALS_ERSATZ_MIT_AH :brake light &
BLINKIMPULS_CRASHBLK : - częstotliwość pracy kierukowsk.[01&02norm.03b.sz.04podw.prędk]
BLINKIMPULS_WARNBLK : - częstotliwość pracy awaryjnych.[01&02norm.03b.sz.04podw.prędk]
BLK_DIMMEN : - przyciemnione kierunkowskazy.
BLK_DIMMUNGS_OPT_1 : - dostosowanie przyciemniania kierukowskazu
BLK_H_L_PICT : - sygnał tylnego lewego kierunkowskazu na desce rozdziel.
BLK-H-R-PICT : - sygnał tylnego prawego kierunkowskazu na desce rozdziel.
BLK_V_GED_ALS_PARKLICHT : - przednie kirunki jako światła parkowania
BLK_V_GED_ALS_SIDEMARK : - tylne światła wł., halogeny wł, jako obrysy
BLK_V_GEDIMMT_ALS_ERSATZ : - front turn light & together as
BLK_V_L_PICT : - sygnał przedniego lewego kierunkowskazu na desce rozdziel.
BLK_V_R_PICT : - sygnał przedniego prawego kierunkowskazu na desce rozdziel.
BLS_PRUEFEN : - kontrola przycisku światła stopu
BLST1_BLST3 :
BL_UND_BLK_H_GEM_BLK : - STOP I tylne kierunki świecą razem podczas hamowania
BL_UND_BLK_H_GEMEINSAM : - STOP I tylne kierunki świecą razem
BL_UND_BLK_H_GEM_WBL : - STOP I tylne kierunki świecą razem podczas zagrożenia
BORDMONITOR : - monitor pokładowy
BORDNETZ : - zsieciowanie pokładowe (navi)
BPLUS_TRENNUNG1_1 : - rozdział baterii zapasowej
BRAKE_FORCE : - siła hamowania
BREMSFLUESSIGK_INV : brake fluid ?
BREMSLICHT_ALS_STANDLICHT : Brake Lights as parking lights
BREMSLICHTSCHALTER : wyłącznik świateł STOP
BREMSWARNLEUCHTE : Ostrzegawsze światło hamowania
B_SATELLIT_1 :
CAN_11H :
CAN_AUSFALL_BEWERTUNG : ocena awarii CAN
CAN_EBV : - rozdział siły hamowania na CAN
CAN_INSTR2_SENDEN :
CAN_OELDRUCK : - ciśnienie oleju dla linii CAN
CAN_OELDRUCKSCHALTER : - przełącznik ciśnienie oleju dla linii CAN
CAN_S_GSU : - czujnik zmierzchu na linii CAN
CC_ABBLENDLICHT : check control słabe światła (mijania)
CC_AUSSENTEMPERATUR : check control niska temperatura zewnętrzna
CC_BREMSLICHT: Check control światła STOP
CC_BREMSLICHT_MITTE :Check control środkowe światło STOP
CC_BLINKER_HINTEN ;Check control tylne kierunkowskazy.
CC_BLINKER_VORN :Check control przednie kierunkowskazy
CC_FERNLICHT :Check control mocne światła (drogowe)
CC_HECKKLAPPE :Check control tylna klapa
CC_KENNZEICHENLEUCHTE_LI:Check control number oświetlenie tablicy rejestracyjnej
CC_LAMPEN :Check control światła
CC_MELDUNG_AL_L :Check control informacja świateł mijania
CC_NSL_LINKS :Check control tylne lewe przeciwmgielne
CC_RUECKLICHT :Check control światła cofania
CC_RUECKLICHT_2_RECHTS ;Check control prawe światło cofania aktiv / nicht_aktiv
CC_RUECKLICHT_3_LINKS :Check control lewe światło cofania aktiv / nicht_aktiv
CC_RUECKLICHT_3_RECHTS :Check control prawe światło cofania aktiv / nicht_aktiv
CC_RUECKLICHT_LINKS :Check control lewe światło cofania aktiv / nicht_aktiv
CC_RUECKLICHT_RECHTS :Check control prawe światło cofania.
CC_STANDLICHT_LINKS :Check control lewe światło parkingowe aktiv / nicht_aktiv
CC_STANDLICHT_RECHTS :Check control prawe światło parkowania.
CC_TUEREN :Check control drzwi
CC_WASCHWASSER :Check control płyn spryskiwacza szyb
CC_ZUSATZBLINKER :Check control zewnętrzna sygnalizacja skrętu.
CENT_LOCK_MGL_VO_TUER_AUF :
CHECK_FGN_SMC_ALC_OFF :
CHECK_IGNITIONA :
CHECK_IGNITIONC :
CHECK_IGNITIONK :
CHECK_SMC_ERROR :
CLT_AKTIV_IM_CRASH_MODE :
CODIERUNG_ERFOLGT : - wykonanie kodowania. (CODE)
CODIERWERT : - wartość kodowania (CODE)
COD_IFL :
COD_IFL_AN_PIN48 :
COD_IFL_ASYNC :
CORNERING_BREAK_CONTROL : - Kontrola dohamowania w zakręcie
CRASH_DISABLE_BEWERTUNG_10S :
CRASH_DISABLE_HECKKL_10S :
CRASH_KLEMME_58G_EIN : - włączenie oświetlenia wewnętrznego podczas wypadku.
CRASH_WARNBLINKEN : - Włącz awaryjne podczas wypadku
CUSTOMER_CALLS_OVER_GMIN
CYCL_TI_BLK;1 – dotknięty kierunek miga raz, dwa lub 3 razy.
DATENSATZ_1
DAUER_DYN_NACHFUEHRUNG :
DAUERFAHRLICHT_EU : - Czujnik świateł - Europa.
DAUERFAHRLICHT_US : - Czujnik świateł - US.
DBC_DBS : - controla dynamicznego hamowania, dynamiczne hamowanie.
DBC_MSB :
DEB_TIME_CS_0 :
DEBUG_SIGNAL :
DEF_LWR_SENSOR_HI : - uszkodzony tylny czujnik poziomowania lamp przednich.
DEF_PIN_20_DEFEKTBLINKEN :
DEF_PIN_20_VOR :
DEF_PIN_37_DEFEKTBLINKEN :
DEF_PIN_37_VOR :
DELTA_LIMIT_GESETZ : - wartość limitu zmiennej
DIAGNOSE_DELAY_ZEIT : - diagnoza czasu opóźnienia
DIAGNOSE_SCHRITTMOTOR : - diagnoza silnika krokowego
DIAGNOSE_ZWP :
DIFFERENZ_ANLAUF_BLOCK :
DISPLAYANZEIGE_HIGH : - temperature wyświetlana na IHKA jako HI jeżeli jest 91°F jeżeli “in-active”
DISPLAYANZEIGE_LOW : - temperature wyświetlana na IHKA jako LO jeżeli jest 59°F jeżeli “in-active”
DISPLAY_GEBLAESRAHMEN :
DOPPELKLICK_AUF :
DOPPELKLICK_HEBEN :
DOPPELKLICK_ZU :
DREHZAHL_KENNLINIE : krzywa charakterystyki RPM
DRIFT_DEKR : - zmniejszeje uślizgu (drift)
DRIFT_INKR : - zwiększenie uślizgu (drift)
DRIFT_SCHWELLE : - limit uślizgu
DRL_BLK_VORN_GEDIMMT : przyciemnione kierunkowskazy jako światła dzienne.
DRL_DIMMUNG : - przyciemnienie DRL
DROSSEL : - przpustnica
DRUCK_OFFSET : - Wyrównanie ciśnienia.
DRUCKMODELL_HINTERACHSE : - model ciśnienia tylnej osi.
DRUCKMODELL_VORDERACHSE : - model ciśnienia przedniej osi.
DRUCKMODELLPARAMETER : - parametr modelu ciśnienia.
DRUCKPUMPE_DREHRICHTUNG : - wytyczne ciśnienia dla pompy.
DSC_DEF_GONG : sygnał ostrzegawczy kiedy DSC aktywowane.
DSP_ACOUSTIC_PROFILE : - Cyfrowy Dźwięk Przetwarzania profilu.
DSP_CDC_DIGITALLTG : - processor cyfrowego dźwięku
DTC_LAMPE :
DWAH_PIN_C17 : - sygnał syreny alarmu
DWA_BLK_ABSCHALTEN : zamknięcie szyb podczas aktywowania alarmu
DWA : - system zabezpieczenia przed kradzieżą
DWA_HANDSCHUHFACHKONTAKT : - przełącznik alarmu - schowek na rękawiczki.
DWA_HECKKLAPPENKONTAKT : - przełącznik alarmu - bagażnik.
DWA_HECKSCHEIBENKONTAKT : - przełącznik alarmu – tylna szyba
DWA_NOTENTSCHAERFEN : - alarm nie będzie deaktywowany
DWA-QUITTIERUNG : - kwitowanie systemu antywłamaniowego
DYNAM_LWR_ENABLE : - aktywne położenie pionowe przednich lamp
DYN_BREMS_UNTERSTUETZUNG : - aktywna asysta hamowania
E52_FUNKTIONEN : - Funkcje BMW Z8
E83_FUNKTIONEN : - Funkcje BMW X3
E85_FUNKTIONEN : - Funkcje BMW Z4
E52_LINKS_LENKER : - Funkcje BMW Z8 dla ruchu prawostronnego
E52_RECHTS_LENKER : - Funkcje BMW Z8 dla ruchu lewostronnego
E53_FAHRZEUG :
E9X_HIMMEL :
EBV_LAMPE : - elektroniczna siła światła STOP
E_CALL_COUNTD_DEL_TMR : - czas opóźnienia odliczania połączeń alarmowych
E-CALL_HARDKEY_FITTED : - zainstalowany przycisk połączenia alarmowego
ECHOSCHWELLWERTE_ECKE_HI : - PDC sensor tylny narożnik
ECHOSCHWELLWERTE_ECKE_VO : - PDC sensor przedni narożnik
ECHOSCHWELLWERTE_MITTE_HI : - PDC sensor środek tył.
ECHOSCHWELLWERTE_MITTE_VO : - PDC sensor środek przód.
EC_LUEFTER : - wentylator
EEPROM_SHD :
EHC : - elektroniczna kontrola wysokości
EINGANG_2 : - wejście (danych) 2.
EINGANG_2_KONTAKT_GESCHL : - zamknięty kontakt 2 wejścia (danych).
EINKLEMMSCH_HINTEN : - sensor zabezpieczający przyciśnięcie – tylna szyba
EINKLEMMSCH_REVERSIEREN : - dystans powrotu sensora antyprzyciśnięcia
EINKLEMMSCH_VORNE : - sensor zabezpieczający przyciśnięcie – przednia szyba
EINSCHALTMELDUNG_BEI_1MA : start?
EINSCHALTMELDUNG_IMMER : - zgłoszenie błędu - zawsze.
EINSCHALTVERZOEGERUNG : - włączanie stopniowe.
EINSPRITZANLAGE_CAN : - informacje z wtrysku paliwa do linii CAN
EINSTIEGSHILFE : - wspomaganie kierownicy kiedy klucz w pozycji w pozycji “1”
EINSTIEGSHILFE_HOEHE : - automatyczna regulacji wysokości kierownicy
EINSTIEGSHILFE_LAENGE : - automatyczna regulacja wysunięcia kierownicy
EIS_AUSBLENDEN : - stopniowe wyłącznaie rozmrażacza
EL_DURCHLAUFERHITZER : - elektryczne podgrzewanie.
E_LUEFTER :
ENABLE_EURO_NCAP : - włącz NCAP
ENABLE_US_SBR : - włącz SBR
ENTFALL_ZV_BEDIENST_HECK :
ENTFROSTKLAPPE_SCHLIES_1 : - rozmrażacz 1 zamknięty
ENTFROSTKLAPPE_SCHLIES_2 : - rozmrażacz 2 zamknięty
ENTFROSTKLAPPE_SCHLIES_3 : - rozmrażacz 3 zamknięty
ENTFROSTKLAPPE_SCHLIES_4 : - rozmrażacz 4 zamknięty
ENTSICHERN_CENTERLOCK : - przycisk centralnego w kabinie działa bez kluczyka
ENTPRELLZAHL_FEHLERERK : - roznawanie numeru otwieranego błedu.
ENTRIEGELN_HKL : - otwórz bagażnik
ENTR_HKL_MGL_WENN_VER :
ENTR_HS_MGL_WENN_VER :
ENTR_KL.R_30S_NACH_SICH :
ENTSICHERN_CENTERLOCK : - kabinowy przycisk centralnego działa kiedy drzwi zamknięte I kluczyk nie w pozycji „zapłon“ kiedy „active”
EPSILON_DELTA_A :
ERKENNUNG_BREMSLICHT : - rozpoznawaj światła STOP
ERKENNUNG_SITZBELEGUNG_1 : - rozpoznawanie położenia fotela (nie wyłaczaj ponieważ system AIRBAG zwariuje)
ER_KEYOUT_AUTOVR : - otwórz centralny po zatrzymaniu auta (w module CAS)
ERR_LWR_L_IGNORIEREN :
ERR_LWR_R_IGNORIEREN :
ERR_SCHWENK_L_IGNORIEREN : - ignorowanie błedu lewego łożyska
ERR_SCHWENK_R_IGNORIEREN : - ignorowanie błedu prawego łożyska
EWS_3_SCHNITTSTELLE : electronic immobiliser interface
FAHRZEUG_HERSTELLER : - producen pojazdu
FAHRZEUG_TYP : - Typ pojazdu
FE_SCHEIBENWISCHER : - błąd wycieraczki szyby
FEHLER_ABBLENDLICHT : - błąd świateł mijania.
FEHLER_ABTAKTEN : - błąd taktowania
FEHLER_ANHAENGER : - błąd przyczepy.
FEHLER_BL_BLINKEN : - raportuj bład świateł STOP.
FEHLER_BREMSLICHT : - bład świateł STOP
FEHLER_NSL_RECHTS : - raportowanie błędu tylnego przeciwmgielnego melden/nicht melden (raportuj/nie)
FEHLER_SCHALTER_BREMSL : - raportuj zaburzenia pracy przełacznika hamulca.
FEHLER_1_CODE : - kod błedu „1“
FEHLER_1_HAEUFIGKEIT : - błąd „1“ częstotliwości
FEHLER_5_HAEUFIGKEIT : - bład „5“ częstotliwości
FEHLER_HECKSCHEIBE : - bład tylnej szyby
FEHLERZAEHLER : - licznik błedów
FERNBEDIENUNG : - kontrola zdalnego serwisu
FERNLICHT_DRL : - DRL świateł drogowych.
FERNWIRKEN_GENERELL : - zdalna kontrola ogólnie
FERNWIRKEN_NAVZIELE : - zdalna kontrola założeń NAVI
FERNWIRKEN_POSITION : - zdalna kontrola pozycji
FERNWIRKEN_STANDHEIZUNG : - zdalna kontrola ogrzewania
FERNWIRKEN_TELEFONLISTEN : - zdalna kontrola książki telefonicznej
FENSTERHEBER_HINTEN : - domykanie tylnych szyb
FENSTERHEBER_VORNE : - domykali przednich szyb
FH_ABSCHALTKRITERIUM : - US oznacza wyłączenie domykania szyb po zgaszeniu auta (z paneli na drzwiach. ECE oznacza aktywne domykanie po zgaszeniu przez 1 minutę
FH_ABSENKUNG_SPERREN : - wyłącz zasilanie samoczynne do opuszczania szyb.
FH_ABSENKEN_VERDECK_OEFF : - opuść szyby kiedy otwierasz dach.
FH_ABSENKUNG_SPERREN : - wyłącz samoczynne opuszczanie szyb
FH_AUF_STUFE2_KLR_AUS :
FH_BEIFAHRERTUER_TIPP_AUF : - szyba pasażera opuszczana jednym kliknięciem
FH_BEIFAHRERTUER_TIPP_ZU : - szyba pasażera podnoszona jednym kliknięciem
FH_FAHRERTUER_TIPP_AUF : - szyba kierowcy opuszczana jednym kliknięciem
FH_FAHRERTUER_TIPP_ZU : - szyba kierowcy podnoszona jednym kliknięciem
FH_INIT_TRANSPORTMODE : - szyby samoczynne w trybie transportowym
FH_NACH_TUERE_AUF : - domykanie szyb kiedy drzwi otwarte
FH_TIMEOUT : - maksymalny czas pracy silnika szyb
FH_TIPP_DISABLE_TUER_AUF :
FH_TUEREN_HINTEN_TIPP_AUF : - tylne szyby opuszczane jednym kliknięciem
FH_TUEREN_HINTEN_TIPP_ZU : - tylne szyby podnoszone jednym kliknięciem
FH_ZTR_SCHALTER_TIPP_AUF : - 4 szyby opuszczane jednym kliknięciem.
FH_ZTR_SCHALTER_TIPP_ZU : - 4 szyby zamykane jednym kliknięciem.
FILTER_DETEKTION_WEIT :
FL_AL_AUS : - światła drogowe jako mijania
FLC_DIMMER_OPTION :
FLC_LED_EIN ;
FLC_SCHWELLWERT_SATZ – utomatyczna kontrola świateł drogowych (zmienne/normalne)
FL_DIMMUNG_ALS_DRL :wert_01 = 0 % wert_02 = 18,82 % wert_03 = 20,39 % wert_04 = 43,92 %wert_05 = 18,82 % ustawienia intensywności świateł drogowych działających w trybie dziennym
FL_KL_50 : - św. drogowe właczane przy zapłonie.
FL_UND_NSW_NICHT_GLEICHZ : - światła drogowe I przeciwmgielne nie świecą razem
FONDGEBLAESE : - wentylator nawiewu tylnej kanapy
FOND_MODUL_1 : - moduł tylnego nawiewu
FS_UNLOCK_300MS_P_BUS : - odblokowanie czujnikiem zderzenia
FUHRPARK_FLOTTENMODUS : - Drive park fleet mode.
FUNK_INNENRAUMSCHUTZ : - monitoring wnętrza pojazdu
FUNKINNENRAUMSCHUTZ_HI : - monitoring wnętrza pojazdu - tył.
FUNKTION_CABRIO : - funkcja cabrio
FUNKTION_DSC : - funkcje DSC
FUNKTION_DTC : - funkcje DTC
FUNKTION_RPA : - funkcje RPA
FUNKTIONEN_TOURING : - funkcje touringa.
FUNKTIONTUERSCHLOSS : - funkcje centralnego
FUNKUHR : godzina zegarka
FUSSRAUMKLAPPE SCHLIES : - nawiewy stop zamknięte
FZG_RADSTAND : - stan kół pojazdu.
FZG_VERZOEGERUNG : - zwalnianie pojazdu.
GEARMOMENTREGLER_MAX_HA : - kontrola maksymalnego momentu obrotowego tylnej osi.
GEARMOMENTREGLER_MIN_HA : - kontrola minimalnego momentu obrotowego tylnej osi.
GEBL_OFF_MODE :
GEBLAESE_BALKEN : - automatyczny tryb linii dmuchawy
GEBL AUT B ZUEND EIN : - nawiew przy zapłonie
GEBLAESEKORREKTUR : - korekta nawiewu – słabiej/mocniej/nicht activ
GEBLAESEBALKEN_AUT_MOD_1 : linia dmuchawy w automatycznym trybie “1”
GED_FL_ALS_DRL : - przyciemnione światła drogowe jako światła jazdy dziennej (USA style)
GEDIMMT_BL__BEGRENZ_LICHT : - przyciemnione STOPY jako obrysówki.
GEDIMMT_BLK_BEGRENZ_LICHT : - przyciemnione kierunki jako obrysówki.
GENERATOR_UEBER_CAN : - pradnica przez linię CAN
GERAETENAME : - nazwa urzadzenia.
GEREGELTER_KOMPRESSOR : - sprężarka wyregulowana
GESCHW_PRUEFUNG : - sprawdzenie prędkości.
GESCHW_VERDECK_AKTIV : - kontrola prędkości dla cabrio.
GESCHWINDIGKEIT : - prędkość.
GESCHWINDIGKEIT_FEHLER : - bład prędkości.
GETRIEBE : - skrzynia biegów.
GETRIEBE_ANZEIGE_GANG : - wyświetlanie bieżącego biegu.
GETRIEBEART : - typ skrzyni biegów.
GLASDACH : - szyberdach
GPS_UHR : - pobierz z GPS czas dla zegara radia – w DE i UK niezbędny odbiornik LW.
GRADIENT_MM_ZUGABE : - stopniowanie regulacji w milimetrach
GRADIENT_SCHLECHTWEG – wysokość przy złej nawierzchni
GURTKONTAKT_MELDUNG_UEBER : - ostrzeżenie o pasach przez linię K
GURTSCHLOSS_BEIFAHRER_1 : - pasy pasażera.
GURTSCHLOSS_FAHRER_1 : - pasy kierowcy
GURTSCHLOSS_HINTEN_LI_1 : - pasy lewy tył 1
GURTSCHLOSS_HINTEN_LI_2 : - pasy lewy tył 2
GURTSCHLOSS_HINTEN_RE_1 : - pasy prawy tył 1
GURTSCHLOSS_HINTEN_RE_2 : - pasy prawy tył 2
GURTSCHLOSS_HI_MITTE_1 : - pasy tył środek.
GURTSCHLOSS_SPANNUNGSS_1 : - napięcie/naprężenie pasów.
GURTSCHLOSS_STROMSS_1 : - zasilanie pasów.
GURTSTRAFFER_BEIFAHRER_1 : - naprężenie pasów - pasażer
GURTSTRAFFER_FAHRER_1 : - naprężenie pasów kierowca
GURTSTRAFFER_HINTEN_LI_1: - naprężenie pasów – lewy tył 1
GURTSTRAFFER_HINTEN_LI_2: - naprężenie pasów – lewy tył 2
GURTSTRAFFER_HINTEN_MI_1: - naprężenie pasów – środek tył 1
GURTSTRAFFER_HINTEN_MI_2: - naprężenie pasów – środek tył 2
GURTSTRAFFER_HINTEN_RE_1: - naprężenie pasów – prawy tył 1
GURTSTRAFFER_HINTEN_RE_2: - naprężenie pasów – prawy tył 2
GURTWARNUNG_EURO_NCAP : - ostrzeżenie o pasach wg NCAP
GURTWARNUNG : - ostrzeżenie o pasach
GURTWARNUNG_GONG : - Dźwięk ostrzegawczy pasów
GURTWARNUNG_TEXT : - text ostrzegawczy pasów
HALB/VOLLSCHRITT : - Step całkowity/połowa
HALLSENSOR_VSW72 :
HALLSENSOR_VSW8 :
HALTEZEIT : - czas zatrzymania
HALTEZEIT_VENTILE : - czas odcięcia zaworów.
HANDY_TYP : - typ komórki.
HARDTOP_ERKENNUNG : - wykrywanie hardtop
HBA_DSC_5_7 :
HEBEN_AUS_GEOEFFNET : - unoszenie włączone
HECKKLAPPE : - klapa bagażnika.
HECKKLAPPE_ENTSICHERN : - otwieranie klapy pilotem
HECKKLAPPEN_LOGIK : - pozycja klapy bagażnika.
HECKSCHEIBE_ENTRI_INNEN : - podgrzewanie tylnej szyby
HECKSCHEIBE_HEIZZEIT : - czas ogrzewania tylnej szyby
HEIMLEUCHTEN : - wert_01 wyłącza, wert_02 włącza odprowadzanie do domu (błysnięciem drogowymi przy wyjętym kluczyku)
HEULTON : - wyjąca syrena
HHS_AUTOMATIK : - automatyczne odmglanie tylnej szyby
HILLDESC_DSC_5_7 :
HILLDESC_DXC_8 :
HIMMEL_AUTO_AUF : - autoroleta otwarta
HIMMEL_AUTO_ZU : - autoroleta zamknięta
HKL_SPERREN_BEI_ZS : - zamknij klapę bagażnika zamkiem centralnym
HUB_VERZOEGERUNG_FH_VORN :
HWL_1 :
HYDRAUL_HECKKLAPPE : - hydrauliczne otwieranie bagażnika
HYDR_BREMSKRAFTVERTEILUNG : - hydrauliczne rozdzielanie siły hamowania.
HYD_HECKKLAPPE_OHNE_PDC : - hydrauliczna klapa bagażnika bez PDC
IB_AUS_NACH_X_SEKUNDEN : - oświetlenie wnętrza wył po x sekundach
IB_BEI_KL.R_AUS : - włączanie oświetlenia wnętrza przy wyłaczonym zapłonie po jeździe na światłach
IB_CRASH_ON_0_KMH : właczenia oświetlenia wnętrza przy 0 km/h
IB_EIN_16MIN_WENN_STANDLI : sygnał kontrolny oświetlenia wnętrza
IB_EIN_BEI_HKK/HSK :
IB_EIN_HK_AUF :
IB_EIN_SCHLOSS_ENTRIEGELN : - włączenie oświetlenia wnętrza przy otwarciu kluczykiem
IB_POWER_CONF_0 : - oświetlenie wnętrza konfiguracja zerowa
IBUS_R_GANG : - wsteczny na linii I.
IB_SPERRE_BEI_FEHLER : - zablokuj oświetlenie wnętrza przy błędzie
IK_BUS_TEILNEMER :
ITS_FRONTCRASH_1 : napełnij przednią osłonę
ITS_LINKS_1 : - napełnij przednią lewą osłonę
ITS_RECHTS_1 : - napełnij przednią prawą osłonę
INNENLICHT_AN_MEHRFACH_ZV : - dwukrotne wciśnięcie LOCK na pilocie zapala światła wewnątrz.
INTERM_FL : - przerywane światła drogowe.
INTERVALLZEIT_GESCHWABH : - zmienna czasu prędkości
IR_FERNBEDIENUNG : - zdalne sterowanie podczerwienią
IR_FERNBEDIENUNG_BF : - zdalne sterownaie podczerwienią dla pasażera
KALIBRIERFAKTOR_VERBRAUCH : - współczynnik kalibracji zużycia paliwa
KALTUEBERWACH_ZUSATZ_BLK : - zimny test zewnętrznych kierunkowskazów
KALTUEBERWACHUNG_AL : - zimny test żarówek świateł mijania
KALTUEBERWACHUNG_BL : - zimny test żarówek STOP
KALTUEBERWACHUNG_BLK_HI : - zimny test żarówek kierunkowskazów tył
KALTUEBERWACHUNG_BLK_VO : - zimny test żarówek kierunkowskazów przód
KALTUEBERWACHUNG_BL_MI : - zimny test żarówek STOP środkowy
KALTUEBERWACHUNG_FL : - zimny test żarówek świateł drogowych
KALTUEBERWACHUNG_KZL : - zimny test żarówek oświetlenia tablic
KALTUEBERWACHUNG_KZL_LI : - zimny test żarówek ośw tablic?
KALTUEBERWACHUNG_NSW : - zimny test żarówek halogenów
KALTUEBERWACHUNG_NSL : - zimny test żarówek przeciwmgielnego tył
KALTUEBERWACHUNG_RL : - zimny test żarówek świateł cofania
KALTUEBERWACHUNG_SL_LHI : - zimny test żarówek parkingowych (lewe)
KALTUEBERWACHUNG_SL_RHI : - zimny test żarówek parkingowych (prawe)
K_BUS_FB_SPERREN :
KBUS_FUNKTION : - funkcje linii K.
K_BUS_FREI_OHNE :
K_BUS_FS_UNLOCK_300MS :
KEINE_L_R_SYNCHRONISATION :
KEINE_PARKLICHT_FUNKT : - brak funkcji parkingowych
KENNFELDKUEHLUNG : - Test chłodzenia.
KENNLINIE_AUTO_GEBLAESE_1 : - automatyczny test nawiewu 1
KENNLINIE_AUTO_GEBLAESE_2 : - automatyczny test nawiewu 2
KENNLINIE_AUTO_GEBLAESE_3 : - automatyczny test nawiewu 3
KENNLINIE_AUTO_GEBLAESE_4: - automatyczny test nawiewu 4
KENNLINIE_GESCHWINDIGKEIT :- test prędkości liniowej.
KENNLINIE_LWR_SENSOR_HI : - autopoziomowanie świateł – linia tylnego czujnika.
KENNLINIE_LWR_SENSOR_VO : - autopoziomowanie świateł – linia przedniego czujnika.
KENNLINIENFELD2_AKTIV : linia testująca błędy „2“ aktywna
KENNLINIE_WAERMETAUSCHER : - szybka zmiana linii testującej (w trakcie pracy)
KEY_MEMORY : - pamięć kluczyka
KEY_MEMORY_IHK : - ustawienia temperatury ostatniego używania auta zapamiętana (dla kluczyka)
KEY_MEMORY_RADIO : - źródło/głośność I stacja radiowa zapamiętana z ostatniego użycia (dla kluczyka)
KINDER_SBE_1 : - siedzisko dla dziecka
KINDER_SBE_2 : - siedzisko dla dziecka
KISI_N_DEAKT_IM_CRASH :
KL50_ABSCHALT_AL : - kiedy kluczyk w pozycji start wyłącz światła mijania
KL50_ABSCHALT_FL : - kiedy kluczyk w pozycji start wyłącz światła drogowe
KL50_ABSCHALT_NSW : - kiedy kluczyk w pozycji start wyłącz halogeny
KL_50_CAN : - kluczyk w pozycji start – sygnał na linię CAN
KL_50_FUNK_AKT : - dwukrotne wciśnięcie LOCK na pilocie zapala światła wewnątrz.
KL58_HELLIGKEITSSTUFE – jasność oświetlenia wnętrza wert_01
KL58_HELLIGKEITSSTUFE_FLC – automatyczna kontrola jasności oświetlenia wnętrza.
KLAPPEN OEFFNEN : - otwarcie klap (nawiewu) przy zapłonie
KLASSIF_DRIFT_ENA :
KLASSIF_LENKM_ENA :
KLASSIF_UEBERST_ENA :
KLEMME_15_LIEGT_AM_SG_AN : - przy zapłonie włącz zacisk 15
KLEMME_15_NOTWENDIG :
KLEMMENSTATUS :
KLEMME_50_UEBER_CAN : - zacisk 50 poprzez linię CAN
KL_ENABLE ; - AC
KLIMABETR BEI ZUEND EIN : Właczenie AC przy włączonym zapłonie (dla kluczyka)
KLIMATASTE_SPERREN :
KLS_BEI_AL_AKTIV
KM_SERVICE_INTERVALL : dystans międzyserwisowy
KOPFBAG_FOND_LINKS_1 : - ustawienia zagłówka lewego
KOPFBAG_FOND_RECHTS_1 : - ustawienia zagłówka prawego
KOMFOEFFNEN_SPERRE_KEY_IN : - komfortowe otwieranie cabrio poprzez przytrzymanie kluczyka w zamku w pozycji “otwórz”
KOMFORTFUNK_BEREICH_HEB : - funkcje komfortu w obszarze unoszenia
KOMFORTOEFFNEN_FB_O_FH_HI : - komfortowe otwieranie bez tylnych szyb
KOMFORTOEFFNEN_FB_O_SHD : - komfortowe otwieranie pilotem bez szyberdachu
KOMFOEFFNEN_SPERRE_KEY_IN – komfortowe otwieranie kluczykiem w zamku
KOMFORTOEFFNUNG : - komfortowe otwieranie – drzwi pilotem
KOMFORTOEFFNUNG_FB : - otwieranie dachu przez przytrzymanie “otwórz” pilotem, lub otwieranie wszystkich szyb&szyberdachu w nie-cabro
KOMFORTOEFFNUNG_BEREICH : - obszar komfortowego otwierania
KOMFORTOEFFNUNG_VERDECK : - komfortowe otwieranie dachu cabrio
KOMFORT_POS_AUF : - komfort – stan wł
KOMFORT_POS_ZU : - komfort – stan wył
KOMFORTSCHLIE_FB_O_FH_HI : - komfortowe zamykanie bez tylnych szyb
KOMFORTSCHLIE_FB_OHNE_SHD : - przyrzymanie LOCK w pilocie zamyka okna oprócz szyberdachu
KOMFORTSCHLIESSEN_VERDECK : - zamykanie dachu cabrio przez przytrzymanie kluczyka w zamku kierowcy
KOMFORTSCHLIESSUNG : - komfortowe zamykanie
KOMFORTSCHLIESSUNG_FB : - zamykanie dachu przez przytrzymanie “zamknij” pilotem, lub zamykanie wszystkich szyb&szyberdachu w nie-cabro
KOMPRESSOR_GEREGELT :
KOMPRESSOR_TRANSPORT_SICH :
KUEHLMITTELUEBERTEMP_CAN : - temperature chłodzenia na linii CAN
KUEHLMITTEL_G_GRENZE : - poziom G cieczy chłodzącej
KUEHLMITTELNIV_FILTERZEIT : - poziom czasu filtra cieczy chłodzącej wert_01
KUEHLMITTELTEMP_ANZEIGEWI : - temperatura cieczy chłodzącej
Edytowane przez Din76
i druga część
DATENSATZ_1
DBC_MSB :
DEB_TIME_CS_0 :
DEBUG_SIGNAL :
DEF_PIN_20_VOR :
DEF_PIN_37_VOR :
DIAGNOSE_ZWP :
DOPPELKLICK_AUF :
DOPPELKLICK_HEBEN :
DOPPELKLICK_ZU :
DTC_LAMPE :
E53_FAHRZEUG :
E9X_HIMMEL :
EEPROM_SHD :
E_LUEFTER :
EPSILON_DELTA_A :
FLC_DIMMER_OPTION :
FLC_LED_EIN ;
GEBL_OFF_MODE :
HALLSENSOR_VSW72 :
HALLSENSOR_VSW8 :
HBA_DSC_5_7 :
HILLDESC_DSC_5_7 :
HILLDESC_DXC_8 :
HWL_1 :
IB_EIN_HK_AUF :
IK_BUS_TEILNEMER :
K_BUS_FB_SPERREN :
K_BUS_FREI_OHNE :
KLASSIF_DRIFT_ENA :
KLASSIF_LENKM_ENA :
KLEMMENSTATUS :
KL_ENABLE ; - AC
KLS_BEI_AL_AKTIV
LAENDERVARIANTE_LSZ : - Wersja kraju LSZ
LAENDERVARIANTE_RADIO : - Ustawienia regionalne dla radia
LAMPENCHECK_GESICHERT : - Zweryfikowana kontrola świateł.
LATENTWAERMESPEICHER : - Archiwizator ukrytego(?) ogrzewania
LAUTSTAERKE_HINTEN : - Głośność dla tyłu
LAUTSTAERKE_TONGEBER : - Wartość głośności E46/2
LAUTSTAERKE_VORN : - Głośność dla przodu.
LDA_BEI_UNTERSPANNUNG : - podnieś rpm biegu jałowego
LDA_BEI_VERBRAUCHER : - obniż rpm biegu jałowego.
LED_ANSCHLUSS ; - połączenie LED
LED_HARDWARE : - osprzet LEDL
LED_RUECKLICHT_OPTION : - opcje LED tylnich świateł
LENKSAEULENMEMORY : - pamięć pozycji kierownicy
LENKSEITE_1 : - strona elementów kierujących (konsola, kierownica itp.)
LENKSEITE_2 : - strona elementów kierujących (konsola, kierownica itp.)
LENKSEITE_LSZ : - strona włącznika świateł.
LENKSTOCKSCHALTER_ANALOG
LENKSTOCKSCHALTER_KLR : - Włącznik kierowania?
LENK_UEBERSETZUNG : - proporcja (współczynnik) elementów sterujących
LENK_UEBERSETZUNG_LO : - niska proporcja (współczynnik) elementów sterujących
LENKWINKELKENNLINIE: linia poznawania kąta elementów sterujących
LEUCHTDICHTE_EXPO : - koncentracja świateł.
LEUCHTWEITENREG_AUTOM : - automatyczna długość świateł
LEUCHTWEITENREG_DYNAM : - dynamiczna długość świateł
LEUCHTWEITENREGELUNG : - regulacja długości świateł
LICHTBEDIENEINHEIT : - obsługa świateł
LICHTWARNUNG : - ostrzeżenie świateł
LINKSVERKEHR : - ruch lewostronny
LL/RL : - kierowca lewa/prawa strona
LOAD_DUMP : - zgubiony ładunek
LOGIK_HA_SPERRE :
LOGIK_SCHALTER_RESERV :
LOGIK_SWBUNT :
LR_BEI_AL_DRL  RL BS.?
LUFTFEDERUNG :
LUFTVER_AUT_B_ZUEND_EIN_1 : - powietrze dla przekaźników/bezpieczników?
LWR_AUT_EXTERN : - automatyczna kontrola poziomowania świateł
LWR_NEIGUNG_KONSTANTE : - stała regulacji pionowej świateł.
LWR_TREIBER_BEW :
LWR_TREIBER_ERR :
LWR_VORZEICHEN : - wskaźnik poziomowania świateł.
MANUELLE_LWR : - ręczne poziomowanie świateł
MAX_BREMS_UNTERSTUETZUNG : - maksymalne wspomaganie hamowania
MAUT_N_ABBRECH_N_TUER_AUF : - pozwala na obsługę szyb przy otwartych drzwiach jeżeli “not aktive”
MAUT_NUR_BEI_KL15EIN : - Szyby działają kiedy kluczyk w pozycji “ON”.
MAUT_ZU_STOP_N_TUER_AUF : - zatrzymuje obsługę szyb przy otwartych drzwiach jeżeli “not aktive”
MELDUNG_AENDERUNG_DIMMER : - zgłoszenie przy zmianie regulatora światła.
MELDUNG_KATALYSATOR : - zgłoszenie katalizatora
MELDUNG_TASTER : - zgłoszenie czujnika
MEMORY_POS_ANFAHREN : - Pozycja pamięci do jazdy.
MEMORY_POS_SPEICHERN : - Memory position safe.
MEMORY_SP_ABKLAPPEN_GM : - czujnik zmierzchu lusterka stały lub do kluczyka
MEMORY_SPIEGELABKLAPPEN : - czujnik zmierzchu lusterka stały lub do pamięci kluczyka
MEMORY_TIPP_BETRIEB : - obsługa pamięci jednym przyciskiem.
MILANSTEUERUNG :
MIND_ANZ_ZYKL_TIPP_BLK;1 – dotknięcie kierunku (1/3 mrugnięcia)
MIN_WT_SOLLWERT :
MIT_LIN_SCHALTER :
MIT_SRA_EIN_LENKSTOCK :
MIT_WISCHER_SERVICEPOS : - wycieraczki w pozycji serwisowej (pion)
MOTOR_ABKUEHLZEIT : - czas wychłodzenia silnika
MOTOR_ART : - typ silnika
MOTORDIAGNOSE : - diagnoza silnika
MOTOR_NOTPROGRAMM_CAN : -
MOTOR_OELSTAND_PREDRIVE : - poziom oleju na starcie
M_TELEGRAM :
NACHLAUF_ZEIT_H : - pobudka - godzina
NACHLAUF_ZEIT_MIN : - pobudka - minuty
NACHREG_DYN_SLOW :
NAVI_DIST_TO_JUNCTION: - pokaż dystans do manewru (z navi).
NEIGUGSGEBER : - czujnik przechyłu dla alarmu
NG_MOTORVARIANTEN : - odchyłka NG silnika
NIVEAU_1 : - poziom/wartość 1
NLR_AKTIV :
NON-TELEMATIC_E-CALL :
NOTENTRIEGELN_HKL : - awaryjne otwieranie bagażnika.
NOTFUNKTION : - funkcje awaryjne w PDC
NOTLAUF : - rozruch awaryjny.
NOTLAUF_IMMER : - rozruch awaryjny zawsze
NOTSTROMSIRENE : - mocna syrena alarmowa
NSL_AH_US_OPTION : - tylne przeciwmgielne – opcja US
NSL_ALS_STANDLICHT : - halogeny jako parkingowe
NSL_ERSETZT_DEFEKT_BL : - halogeny w zastępstwie STOPów.
NSL_R_NICHT_ANSTEUERN : - tylne przeciwmgielne - zaburzenia
NSW_KEIN_TASTER : - halogeny bez włącznika
NSW_KL_50 : - przednie halogeny na 50 przy ruszaniu
NUR_EIN_TONGEBER :
NUR_KL15_BETRIEB : - PDC pracuje kiedy kluczyk w pozycji pracy kiedy “active”
N_VER_B_ERN_GESCHW_SCHWEL :
OEFFNEN_AUS_GEHOBEN :
OEH_POWER_CONF_0 :
OELNIVEAU_M3 : - poziom oleju M3
OELST_SENS_DEF_WARNUNG : - ostrzeżenie o awarii czujnika poziomu oleju
OELSTAND_MOTOR_CAN : - poziom oleju na linię CAN
OFFENE_FENSTER : - otwarte okna.
OHNE_CENTERLOCK_0 : - wyłacznie zamka centralnego
OHNE_FERNBEDIENUNG_1
OHNE_FERTIGUNGSMODE :
OHNE_FH_BF_HINTEN_0 :
OHNE_FH_BF_VORNE_0 :
OHNE_FH_FA_HINTEN_0 :
OHNE_GIERRATE :
OHNE_IB_0 :
OHNE_INTERVALLBETRIEB :
OHNE_POWERDOWNMODE : - bez samoczynnego opuszczania
OHNE_SERVICEMODE : - bez trybu serwisowego
OHNE_SRA_0 :
OHNE_TRANSPORTMODE : - bez trybu transportowego
OHNE_VA_ZEITEN_0 :
OHNE_WISCH_BEI_WASCH
OPT_ENTRY_HELP :
OPTIMIERTE_SCHLIESSFKT
PANIC_CLOSE : - przytrzymanie zamknięcia na pilocie włącza alarm
PANIC_FREIGABE_CAS :
PANIC_FREIGABE_KL15 :
PANIK_MODUS : - tryb paniki
PARK/NEUTRAL_EINGANG : - przycisk ominięcia bezpieczeństwa sprzęgał&pozwala na start przez EWS podczas parkowania
PASSIVES_DWA_HORN :
PAUSE_ZW_SPRITZIMPULSE : - pauza dla spryskiwaczy.
PDC_AKTIV/DEAKTIV : - aktywacja PDC
PDC_EIN_BEI_KL15 :
PDC_SCHALTER : przycisk PDC
PHASE_AUS_GEDIM_LICHT_AUS :
PHYSIOLOGIEANPASSUNG_1 :
PIKTOGRAMM_ERWEITERT : - grafika sygnalizująca status świateł drzwi (żarówki)
PIN_5_10_AHM_ERS_FU_GESP :
PIN5_10_BFD :
PIN_20_ALS_FRA_LI_VO_2
PIN_29_30_AHM_ERS_FU_GESP :
PIN29_30_BL_NSL :
PIN_37_ALS_FRA_RE_VO_2 :
PM_SCHALTERBLOCK_FOND :
PM_SCHIEBEHEBEDACH :
PM_SITZMEMORY : - pamięć fotela kierowcy
PM_SITZMEMORY_BEIFAHRER : - pamięć fotela pasażera
POWERDOWN_ZEIT : - czas Powerdown
PORTABLE_BT : - przenośny BT
POTI_DIMMER_INVERS :
POTI_LWR_INVERS :
PREFIT_SIM_ENABLED :
PREDRIVE_RPA : - ustawienia lokalne RPA
PRE_MSR :
PRE_VLABS :
PROGRAMMPARAMETER_LSZ_1 to 13: - Parametry ECE (Europa) lub US (USA)
PULS_TIME_OPTION : - opcje pulsacyjne czasu
PWM_ANSTEUERUNG_AL : - wtyczka świateł mijania.
PWM_ANSTEUERUNG_BIXENON : - wtyczka Bi-xenonów.
PWM_ANSTEUERUNG_BL : - wtyczka STOPów.
PWM_ANSTEUERUNG_BL_MITTE – wtyczka 3-go STOPu.
PWM_ANSTEUERUNG_BLK_HI : - wtyczka tylnych kierunków
PWM_ANSTEUERUNG_BLK_VORNN : - wtyczka przednich kierunków
PWM_ANSTEUERUNG_FERNLICHT : - wtyczka świateł drogowych
PWM_ANSTEUERUNG_KZL : - wtyczka oświetlenia tablicy
PWM_ANSTEUERUNG_NSL_LI : - wtyczka halogenów
PWM_ANSTEUERUNG_SL_LI_HI: - wtyczka parkingowych lewy tył
PWM_ANSTEUERUNG_SL_RE_HI : - wtyczka parkingowych prawy tył
PWM_ANSTEUERUNG_SL_VO_LI : - wtyczka parkingowych lewy przód
PWM_ANSTEUERUNG_SL_VO_RE ; - wtyczka parkingowych prawy przód
PWM_ANSTEUERUNG_SL2_RE_HI : - wtyczka parkingowych prawy tył 2
PWM_ANSTEUERUNG_SL3_LI_HI : - wtyczka parkingowych lewy tył 3
PWM_ANSTEUERUNG_SL3_RE_HI : - wtyczka parkingowychprawy tył 3
PWM_ANSTEUERUNG_ZUSTZBLK : - wtyczka dodatkowego kierunku
PWM_WERT2_ALS_BL_AUSGANG : - wyjście STOPu.
PWM_WERT2_ALS_SL_AUSGANG : - wyjście świateł parkingowych.
PWM_WERT2_BLK_ZUSATZFKT – dodatkowy efekt kierunkowskazu
PWM_WERT2_FL_BIXENON : - wert_02= domyślne / wert_01=bixenony&halogeny razem
PWM_WERT2_NSL_ZUSATZFKT : - dodatkowy efekt przeciwmgielnych (halogeny)
PWM_WERT2_SL3_ZUSATZFKT : - dodatkowy efekt parkingowych 3.
QUIT_AKUST_DAUER_10/20/40_MS: - czas sygnału alarmu
QUIT_AKUST_ENTSCH : - dźwięk alarmu przy otwarciu (2x)
QUIT_AKUST_SCHAERF : - dźwięk alarmu przy zamknięciu (1x)
QUIT_AKUST_SCHAERF_KLAPPE : - akustyczne uzbrojenie zamkniętych drzwi
QUITT_A_TEMP_WARNUNG_LSS; - tymczasowe ostrzeżenie o lodzie
QUITT_BLK_SICHERN; - kierunki przy zamknięciu bez alarmu.
QUITT_BLK_ENTSICHERN; - kierunki przy otwarciu bez alarmu.
QUITIMP_SICHERN/ENTSICHER; - potwierdzenie zamknięcia/otwarcia bez alarmu.
QUIT_OPT_ENTSCH : - optyczne powiadomienie otwarcia pilotem (2x kierunki)
QUIT_OPT_SCHAERF : - optyczne powiadomienie zamknięcia pilotem (1xkierunki)
QUIT_OPT_SCHAERF_KLAPPE : - optyczne powiadomienie o zakniętych drzwiach
RCC_UHR : - godzina
RCC_WECKZEIT : - godzina “pobudki”
RDC_ALARM_VIA_HFK : - alarm ciśnienia w kołach przez HFK
RDC_ALARM_VIA_KBUS : - alarm ciśnienia w kołach przez linię K
RDKS : - system monitorowania ciśnienia w kołach
RECHTS_LINKS ; - prawy-lewy.
RECHTSVERKEHR : - prawa (komunikacja/ruch)
REFERENZLAUF_LWR_KL15 :
REGENSCHLIESSEN : - zamykanie przez czujnik deszczu
REGENSCHLIESSENTILT : - zamykanie szyberdachu przez czujnik deszczu
REIFENCONTR_INAKTIV : - melduj/nie melduj aktywność kontroli ciśnienia powietrza
REIFEN_DEFEKT : - uszkodzenie kół
REIFENDRUCKWARNSYSTEM : - ostrzeżenie o przebiciu kół
REIFENTOL_ABGLEICH_ASC : - tolerancja balansu ASC
REIFENTOLERANZABGLEICH : - tolerancja balansu
RFS_AH_OPTION : - opcje swiateł cofania
RL_INNEN_BLINKT : - vizualne ostrzeżenie kierowcy o wstecznym
RR_SCHALTER : - przełącznik cofania
RUECKFAHRGONG : - alarm cofania
RUECKLICHT_INNEN_FEHLT : - informacja o błędzie świateł cofania
RUECKWAERTSGANG_WARN_MED : - typ ostrzeżenia o wstecznym piezo / gong
RUECKWAERTSGANG_WARNUNG : - ostrzeżenie o wstecznym.
SAETT_TIMER_SCHLECHTWEG :
SB_ANHEBEN :
SBE1_STATUS_VERZ_1 :
SBR_US : - przypomnienie o pasach - US
SCA_HECKKLAPPE : - delikatne zamykanie klapy
SCHAERFEN/ENTSCHAERFEN : - zarygluj/odrygluj
SCHALTER2_BL : - przełącznik #2 drugi przełącznik STOPu
SCHALTER_BREMSL_SCHWELLW : - poniesienie wartości przełącznika STOPu wert_01
SCHALTER_BREMSL_WARTEZEIT : - opóźnienie przełącznika świateł STOP.
SCHALTER_R_GANG : - przełącznik biegu wstecznego
SCHALT_KRITERIUM_EWS_3 : - kryteria czujnika immo.
SCHEIBE_ABSENKZEIT : - czas opuszczania szyb.
SCHEIBENABSENK_OHNE_EKS : - otwieranie szyb bez EKS
SCHEIBENINTENSIVREINIGUNG : - zgodność intensywności szyb
SCHIEBEHEBEDACH_TIPP_AUF : - szyberdach jednym przyciskiem - otwieranie
SCHIEBEHEBEDACH_TIPP_HEB : - szyberdach jednym przyciskiem - uchylenie
SCHIEBEHEBEDACH_TIPP_SENK : - szyberdach jednym przyciskiem - opuszczanie
SCHIEBEHEBEDACH_TIPP_ZU : - szyberdach jednym przyciskiem - zamykanie
SCHEINWERFERREINIGUNG : - intensywne zmywanie reflektorów co piąte mycie szyb kiedy “active”
SCHRITTMOTOR_UEBERLAUF : - przeciążenie silnika krokowego
SECOND_HARDKEY :
SEL_ZV_SENDER_1 :
SENSOR_REGEN : - czujnik deszczu
SENSOR_VALEO : - czujnik wycieraczek.
SEQ_M_GETRIEBE : - SMG
SERVOTRONIK :
SHD_ACTU_ALLOWED : - moduł dachu
SHD_CFL_ALLOWED :
SHD_CLOUD_ALLOWED : - zaciemnienie dachu
SHD_RESTARTALLOWED : - zezwolenie na restart dachu
SHD_RRD_ALLOWED :
SHD_SKB_OHNE_KL_OE :
SHD_SKB_OHNE_KL_SCH :
SHD_TMON_ALLOWED :
SIA_RESET_KI_TASTE : przerwania kodowania obsługi
SICHERHEITSFAHRZEUG : - bezpieczeństwo pojazdu
SICHERHEITS_FZG : - bezpieczeństwo pojazdu
SIDEBAG_FOND_LINKS_1 : - czułość poduszki bocznej lewej
SIDEBAG_FOND_RECHTS_1 : - czułość poduszki bocznej prawej
SIDEMARKER_US : - tryb US świateł parkingowych
SIM_IN_TELEMATIK_READER :
SITZMEMORY_VERBAUT : - pamięć foteli przerwana (zaburzenie pracy)
SL_3_ERSETZT_DEFEKT_BLK : - 3 światło parkingowe w przypadku awarii kieruku nicht_aktiv
SL_ERSETZT_DEFEKT_BL ; - światła parkingowe w przypadku awarii STOPu nicht_aktiv
SL_ERSETZT_DEFEKT_BLK : - światła parkowania w przypadku awarii kierunków.
SL_INNEN_ALS_TWL : - światło parkowania
SL_VO_ANSTEUERUNG : - przednie światła parkowania aktywowane
SL_VORNE_ALS_ZUSATZ_BLK : - przednie światła parkowania jako dodatkowe kierunki
SMG_S_ANZEIGE :
SOFT ON/OFF : - stopniowe zapalanie/gaszenie oświetlenia wnętrza
SOFTWARE_VERDECK : - oprogramowanie cabrio
SOLLWERT_KORREKTUR_1 : - korekta ustawienia wartości klap
SONDERFHZG_MIT_WSA :
SOS_ACTU_ALLOWED :
SOS_CFL_ALLOWED :
SOS_CLOUD_ALLOWED :
SOS_RESTARTALLOWED :
SOS_RRD_ALLOWED :
SOS_SKB_OHNE_KL_OE :
SOS_SKB_OHNE_KL_SCH :
SOS_TMON_ALLOWED :
SP_BEWERT_OD_ALC_NSW_AUS :
SPERRDIFFERENZREGELUNG : - regulacja różnic szpery
SPERR_VENT_TEST :
SPERR_WLM_TEST :
SPERRZEIT_KL_R_AUS_0.2_S : - czas szpery
SPIEGELEINKLAPPEN : - składanie lusterek
SPIEGELABKLAPPEN : - rozkładanie lusterek
SPIEGELHEIZUNG : - podgrzewanie lusterek
SPIEGELHEIZUNG_VERBAUT : - zaburzenia podgrzewania lusterek (przerwanie)
SPIEGELMEMORY : - pamięć kierowcy dla lusterek
SPIEGELMEMORY_GM : - pamięć pozycji lusterek.
SP_MOTOR_BEWERTEN :
SP_MOTOR_F_EINTRAG : - błąd na wejściu silnika (lusterek)
SP_MOTOR_STOP : - stop silnika (lusterek)
SPG_NACHREGELUNG : - regulacja lusterek
SPG_NACHREGELUNG_LANGSAM :
SPG_NACHREGELUNG_ZUSATZ :
SPRACHE : wybór języka
SPZ_PROG :
SRA_L322_RELAY :
SRA_MIT_WASCH_WISCH_SW
STANDHEIZUNG : - webasto
STANDHEIZUNG_KONZEPT -
STANDLICHT_ALS_BREMSLICHT : - światła parkingowe jako STOPy. nicht_aktiv
STANDLICHT_ALS_NSL_LINKS : - światła parkingowe jako przeciwmgielne lewa. nicht_aktiv
STANDLICHT_ALS_NSL_RECHTS : - światła parkingowe jako przeciwmgielne prawa.
STANDLICHT_VORNE : - ringi
STANDLUEFTUNG : - ogrzewanie parkingowe
STANDRUECKSCHALTUNG : warunek resetowany przy zatrzymaniu
STATUS_LESEN : - status odczytu
STEIG_KL58_T_PER_D :
ST3_SCHWEL:
TACHO_SKALA_ENDWERT - końcowa wartość prędkościomierza
TAGFAHRLICHT_ECE : - światła dzienne ECE [ringi]
TAGFAHRLICHT_DAN : - światła dzienne Dania?
TAKTUNG_HHS :
TAKTEN HIGH LOW ANZEIGE : - HIGH/LOW informacja taktowania
TAKTUNG_IB :
TAKTUNG_VERBRAUCHERABSCHA :
TANK_KENNLINIE Tank : - kalibracja pojemności zbiornika 60_l_literskala
TANK_MITTLUNGSZEIT : -cześtotliwość pomiaru przepływu paliwa 5_sec
TANK_SCHWELLE_AUF/AB : - światło rezerwy 6_l
TANK_SCHWELLE_RESERVE : - próg rezerwy 8_l
TANK_SICHERHEITSFAKTOR : - czynnik bezpieczeństwa zbiornika 1.3
TANK_VORHALT_REICHW : - zasięg na zbiorniku
TASTE_UEBER_CAN : - przycisk/czujnik poprzez linię CAN
TASTER_NSL : - czujnik tylnich przeciwmgielnych
TASTER_NSW : - czujnik halogenów
TASTER_NSW_NSL : czujnik przeciwmgielnych + halogeny
TAXI_ENABLE : - moduł taxi.
TELEMATIK :
TELEGRAMM_ZEIT_ZYKLUS : - długośc cyklu Telegram.
TEMPCFLUSEOUTER : - temperatura zewnętrzna
TEMPCFLUSESENSOR : - czujnik temperatury zewnętrznej
TEMP_DRUCKPUMPE : - temperatura pompy ciśnienia
TEMPERATUR_EINHEIT : - jednostka temperatury (°C/°F)
TEMPERATUR_GRENZE : - granica temperaturay.
TEMP_FOND : - czułość temperatury
TEMPTMONUSEOUTER :
TEMPTMONUSESENSOR :
TESTBETRIEB : - test rozruchu
TEST_OD_ST2_OHNE_NSW
TNK_DECKEL_WARNUNG : - ostrzeżenie otwartej klapki wlewu
TP_FUNKTION : - funkcje radia ?
TRAKTIONDIFFERENZREGELUNG : regulowanie różnic trakcji
TREIBER_BEWERTEN : - rozpoznawanie kierowcy.
TREIBER_F_EINTRAG : - zapisywanie kierowcy
TREIBER_STOP_OD_ALC_RE_OK :
TRIGGERSCHALTER_1 : - przełącznik spustowy
UEBERLAUFSCHRITTE_BEI_0 : - przepełnienie krokowe przy 0
UEBERLAUFSTEPS_BEI_100% : - przepełnianie krokowe przu 100%
UEBER_ROLLSENSOR_1 :
UEBERSPANNUNGSSCHUTZ : - zabezpieczenie antyprzepięciowe (natężenie)
UEBERSPG_ABSCHALT_58G ;
UEBERSPG_ABSCHALT_BL : - zabezpieczenie antyprzepięciowe kierunków
UEBERSPG_ABSCHALT_NSL : - zabezpieczenie antyprzepięciowe halogenów
UEBERSPG_ABSCHALT_RFS : - zabezpieczenie antyprzepięciowe światęł cofania
UEBERSPG_ABSCHALT_SL : - zabezpieczenie antyprzepięciowe św. postojowe
UEBERSPG_ABSCHALT_SL_H :
UEBERSPG_ABSCHALT_SL_HI : - zabezpieczenie antyprzepięciowe św. tylnych
UEBERWACH_FENSTER_BF_HI : - nadzór szyby pasażera tył
UEBERWACH_FENSTER_F_VO : - nadzór szyby kierowcy przód
UEBERWACH_HECKSCHEIBE : - nadzór szyby tylnej
ULF_EIN_AUS : - zabezpieczenie antyprzepięciowe (napięcie)
UMLUFT MEMORY : - obieg wewnętrzny powietrza (pamięta czy był włączony przed zgaszeniem auta)
UNTERSTEUERUNGSALGORYTHM : - algorytm przesterowania
US_CALL_SERVICE_CENTER : - centrala systemu serwisowego US
USE_SOS :
VA1_SPERRE_BEI_FEHLER :
VA_2 :
V_ABHAENGIG :
VARIANTE_LSZ : - Wersja LSZ.
VENTIL_HALTESTELLUNG : - pozycja zatrzymania zaworu
VERBRAUCH D1 : - jednostki zużycia (L/100Km,mpg-Eng,mpg-USA,Km/L)
VERDECKKLAPPE_VORHANDEN : - obecność składanego dachu
VERL_ALARMZEI_WAEHR_ALARM :
VERRIEGELN_AUT_AB_X_KMH : - automatyczne ryglowanie po przekroczeniu X Km/h
VERRIEGELN_AUT_NACH_2_MIN : - ponowne zamknięcie po 2 min jeżeli auto otwarte I nie otwarto drzwi
VERRIEGELN_SITZLEHNE_FA_1 : - blokada siedzisko-oparcie
VERRIEGELUNGSSCHWELLE : - wybór prędkości automatycznego ryglowania
VERZUG_ENTR_HECKKLAPPE : - opóźnienie otwarcia tylnej klapy
VERZUG_PANIK_MODUS_0.2_S : - opóźnienie trybu Panic 0.2 sekundy.
VOLUMENDURCHFLUSSPARA_2 :
VORGLUEHEN/KAT_HEIZEN_CAN : - dogrzewanie
VKBODEN_ERKENNUNG :
VMAX_BESCHLEUNIGUNG : - limit przyspieszania
VMAX_BREMSEN : - limit hamowania
VOLUMENDURCHFLUSSPARA : - głośność przy parametrze przepływu
V_VAR_SPERRE_BEIKLAPPEN : - parametr pracy zamka
WARMUEBERWACH_ZUSATZ_BLK: - ciepły test zewnętrznych sygnałów skrętu
WARMUEBERWACHUNG_AL : - ciepły test żarówek mijania
WARMUEBERWACHUNG_AL_L : - ciepły test żarówek mijania
WARMUEBERWACHUNG_BL_MI : - ciepły test żarówek świateł STOP
WARMUEBERWACHUNG_BLK_HI : - ciepły test żarówek tylnych kierunków
WARMUEBERWACHUNG_BLK_VO : - ciepły test żarówek przednich kierunków
WARMUEBERWACHUNG_FL : - ciepły test żarówek świateł drogowych
WARMUEBERWACHUNG_KZL_LI : - ciepły test żarówek oświetlenia tablic
WARMUEBERWACHUNG_NSL_LI : - ciepły test żarówek przeciwmgielnych.
WARMUEBEWARMUEBERWACHUNG_RL_LI :
WARMUEBERWACHUNG_RL_RE: - ciepły test żarówek cofania prawe
WARMUEBERWACHUNG_SL_LHI : - ciepły test żarówek pozycyjnych lewy tył
WARMUEBERWACHUNG_SL_RHI : - ciepły test żarówek pozycyjnych prawy tył
WARNBLINKER : - kierunki ostrzegawcze, 1x lub 2x mignięcie
WARN_MEDIUM_AUSSENTEMP : - ostrzeżenie piezo o temperaturze zewnętrznej
WARN_MEDIUM_GURT : - ostrzeżenie piezo o pasach
WARN_MEDIUM_PARKBREMSE : - ostrzeżenie piezo o ręcznym
WARN_MEDIUM_RDKS : - ostrzeżenie piezo PDC
WARN_MEDIUM_ZUENDSCHL : - ostrzeżenie o zapłonie
WARNUNG_GESCHW_LIMIT : - ostrzeżenie o limicie prędkości
WARNUNG_MOTOR_OELSTAND : - ostrzeżenie o poziomie oleju
WARTEN_SCHEIBEN_ABGESENK : - poczekaj na opuszczenie szyb przed otwarciem dachu
WAKEUP_GENERELL : - ogólna “pobudka”
WAKEUP_TAGE : - dzień “pobudki”
WAKEUP_ZEIT : - godzina “pobudki”
WASSERPUMPE : - pompa wody
WASSERSTOFF_FZG :
WEG_DURCHSCHNITT : - średnia jednostka drogi
WEG_EINHEIT : - jednostka odległości ( mls lub km)
WEGFAHRSICHERUNG_AUTOM : - Automatyczne unieruchamianie pojazdu
WEGSIGNAL_SERVO_ABS :
WE_MODE :
WISCHER_RUECK_GESCHW : - prędkość tylnej wycieraczki.
WISCHERINTERVALL: - wybór przerwania wycieraczek
WISCHERMOTOR_RSK : - silnik wycieraczek
WISCHERPOTI : - taktowanie wycieraczek
WISCHER_VOLLEND_KLR_AUS ;
WINDSCHOTT :
WINDSCHOTT_OPT :
XDT :
XENONLICHT_ZUEND_OPTION : - Zapłon ksenonów
XENON_TEST : - test ksenonów.
XENON_TIME : - czas ksenonów.
XENON_TIMEOUT : - limit czasowy ksenonów.
ZEIT_EINHEIT : - Tryb czasu (12H /24H)
ZEIT_BIS_AUTOM_SPERREN : - czas przed automatycznym zamknięciem.
ZEITDAUER_BIS_ABSCHALTUNG : - czas przed zamknięciem.
ZEIT_KALT_PULSE : - czas zimnego sygnału. wert_01
ZEIT_KALT_PULSE_QUICK : - szybki czas zimnego sygnału. wert_01
ZEIT_KALT_RUNDEN : - czas zimnego obrotu.
ZEIT_TUER/SCHLIESSZEIT : - czas zamknięcia drzwi
ZKE : - główna elektronika nadwozia
ZUHEIZUNG : - podgrzewanie wstępne diesla
ZUENDSCHL_GONG_R_EIN : - pozostawiony kluczyk - gong
ZUENDSCHLUESSEL_KBUS : - pozostawiony kluczyk na linię K
ZUENDSCHLUESSEL_WARNUNG : dżwięk + komunikat pozostawiony kluczyk w stacyjce
ZUSATZWASSERPUMPE : - dodatkowa pompa wody
ZUWACHS_TASTVERH_KL_58G :
ZYKLUS_KALT_RUNDEN_QUICK : - cycle zimnych obrotów QIUCK.
ZV_AGGREGATE_TYP : typ systemu zamka centralnego
ZV_BEDIENST_BT_DISABLE :
ZV_ENTR_SCHL_BEI_DWA_AKT :
ZV_SELEKTIV : - odrygluj tylko drzwi kierowcy jeżeli [aktive] lub wszystkie jeżeli [nicht aktive] dla klucza
ZV_VR_BEDIENSTELLE_HECK : -
swietna sprawa, tez chce zaczac z ncs dummy , jutro napisze bo mam jedno pytanie :)
pozdro
Dobra robota :P
F30 330i, 252 hp, xDrive, 2017
VO - FA Code List.txt
S000A Dummy-SALAPA
S001A Country vers. not controlled as package
S0BVA Fuel refuelling
S0BWA Partial refuelling
S100A Usable load increase
S102A Chassis, officials utility vehicle
S102A Reinforced brakes
S103A Four seasons tyres
S103A Aggregate protective plate
S104A Middle East version
S105A Job control "German Federal State"
S106A Safety vehicle
S107A Preparation, tachograph
S108A Motor afterrun control unit
S109A SECURITY PLUS
S110A Preparation, fitting, emerg.-doctor sign
S112A Beklebung leuchtrot RAL 3024
S113A Beklebung Polizei Bayern minzgrün hell
S114A Police sticker, Norddeutschland
S114A Sticking, Police, minzgrün
S115A Paramedic sticker NRW
S115A NRW Fire-brigade Sticker
S116A Standard holder, left
S117A Standard holder, right
S118A Top Speed reduction
S119A Electric auxiliary module
S120A BASIC EQUIPMENT
S121A Bracket for police stop sign
S122A Sticks holder
S123A Auxiliary interior mirror
S124A Roofliner, official-use
S125A Interior trim, official-use, open
S126A Interior trim, official-use, camouflaged
S127A Gun mount on front passenger door
S129A Gun mount in roof, front
S130A WEAPON BOX
S130A Gun mount in centre armrest, rear
S131A Weapon bracket
S139A Priority vehicle light, blue
S140A 1 RKLE 130,Tonfolge,Polizeischaltung
S141A High-low signal system
S142A Two rotating beacons, blue
S143A Alarm switch with police circuit
S144A Rot.beacon,high-low signal, police circ.
S145A Alarm switch with fire-service circuit
S146A Additional energy supply
S147A Priority vehicle light
S148A iDrive operation,spec. signalling system
S149A Double flash light, removable
S150A Installation RTK-4 with handset
S151A Sondersignalanlage Hella RTK-6
S152A Special signaling system
S153A Roof attachm.w/out spec. signal system
S155A Installation Top-4 with handset
S159A Installation Aero-Dynic system
S160A Installation Becker signal system LU 322
S161A Exhaust emissions standards EU5
S162A Preparation, installation, siren
S163A Exhaust emissions standard EU6
S163A BMW diesel with Blue Performance
S165A ITS head airbag deactivation
S166A Preparation, stop signal, parcel shelf
S167A EU4 exhaust emissions standard
S168A EU2 exhaust emissions standard
S169A DIESEL CATALYST
S169A EU3 exhaust emissions standard
S170A Vorb. FuG 2m-4m Bd, AEG(BKA)
S170A Prep, install radio equip. AEG Teledux
S171A Preparation, installation, FuG Ascom
S172A Vorber. FuG 7B kpl. Handschuhk.
S172A Adaptation, fuel containing ethanol
S173A Vorber. FuG 7B/8B/9C Handschuhk.
S174A Vorb. FuG 8B/9C Handschuhk.
S175A Vorb. FuG 8B/9C
S176A Vorb. FuG 8B/9C abgesetzt
S178A Support, manual radio equipment
S179A Irritant gas sensors
S180A Roof antenna
S180A Preparation, roof antenna
S181A Preparation/installation, roof antenna
S182A Fire extinguishing system
S183A Preparation for active defence
S184A EMERGENCY EXIT FRONT WINDSHIELD
S185A UNMASKED OFFICIAL VEHICLE
S186A Emergency vehicle, camouflaged
S187A Floor protection
S188A Door window,lowerable,front left + right
S189A Door window, lowerable, front + rear
S190A Intercom system
S191A Door window, lowerable, front right
S192A Door window, lowerable, front left
S193A Heated windscr. and side windows dropped
S194A Remote control start system
S195A Additional floor armouring
S196A Fuel tank, drain-inhibiting
S197A Acoustic and optical alarm system
S198A Additional fresh-air system
S199A without catalytic converter
S199A Equipment for leaded fuel
S1A1A Ausst. Kraftstoffe mit Verkokungsneigung
S1AAA 55 kW motor variant
S1AEA Flexible Fuel
S1AFA Enlarged fuel filler pipe
S1AGA Larger fuel tank
S1AKA Outer fuel filter
S1CAA Selection of COP-relevant vehicles
S1CBA CO2 equipment
S1CCA Auto start/stop function
S1CDA Brake Energy Regeneration
S200A Diesel particle filter
S200A without catalytic converter
S201A Rape methyl ester version (RME)
S202A Steptronic
S203A 4-wheel drive
S204A Shorter final drive ratio
S204A Drive layout, export
S205A Automatic transmission
S206A Sequential manual transmission (SMG)
S207A 6-speed manual transmission
S208A DSC III discontinued
S209A Differential lock 25%
S210A Dynamic stability control
S211A Dynamic stability control
S212A Equipment, brake syst. country-specific
S212A ABS discontinued
S213A Hill Descent Control (HDC)
S213A Automatic stability control
S214A Automatic stability control (ASC+T)
S215A Power steering, engine-speed-dependent
S216A HYDRO STEERING-SERVOTRONIC
S217A Active steering
S217A Steering wheel, leather
S218A LEATHER SPORTS STEERING WHEEL II
S219A Leather-covered sport st. wheel 380 mm
S220A Self-levelling suspension
S221A 2-axle self-levelling suspension
S222A Electronic Damper Control (EDC)
S223A Electronic Damper Control (EDC)
S224A Driving dynamic control
S225A Standard suspension
S226A Sports suspension settings
S227A Sport susp.+low-slung+ride-height ctrl.
S228A Sports suspension settings Plus
S228A Comfort suspension
S229A Dynamic Drive
S230A Low-slung sports suspension
S230A Extra package, EU-speciifc
S231A Deleted: 250 km/h limitation
S232A BMW light alloy wheel, radial spoke 50
S233A Increased towing capability
S234A Trailer tow hitch, height adjustable
S235A Towing hitch, detachable
S236A BMW LA wheels with mixed tyres
S238A BMW LA wheel, double spoke 93
S239A BMW LA wheel Styling 94
S240A Steering wheel, leather
S241A Air bag for driver and passenger
S242A Steering wheel airbag
S243A Airbag for front passenger
S244A Manually adjust. steering column
S245A Steering wheel column adjustment,electr.
S246A Manually adjust. steering column
S247A Axial st.-wheel adjustment, mechanical
S248A Steering wheel heater
S249A Multifunction f steering wheel
S250A Multi-functional steering wheel
S250A Side airbags for rear passengers
S251A Runflat indicator
S252A Active knee protection, driver/passenger
S253A Multi-functional steering wheel,wood
S253A Leather steering wheel Cooper S
S254A Sport steering whl. with wood rim
S254A Steering wheel, wood
S255A Sports leather steering wheel
S256A Sports multifunct.strng whl,cruise cntrl
S257A Deactivation, side airbag rear
S258A Tyres with runflat properties
S259A Deleted, side airbag
S260A Side airbag for driver/passenger
S261A Side airbags for rear passengers
S262A ITS - Head airbag
S263A LA wheels with mixed tyres
S263A ITS head airbag/rear compartment
S264A BMW light alloy wheel, star spoke 55
S265A Tyre pressure control (TPC)
S266A BMW light alloy wheel, radial spoke 48
S267A BMW light alloy wheel, star spoke 49
S268A BMW LA wheel, star spoke 95
S269A BMW light alloy wheel, radial spoke 32
S270A Wider tyres
S271A BMW LA wheel Z Line
S272A BMW LA wheel Z Star
S273A BMW light-alloy wheel star spokes 43
S274A BMW light alloy wheel, double spoke 53
S274A BMW LA wheel/flat star styling
S275A BMW LA wheel, chrome-plated/Z Star
S276A BMW LA wheel, round-spoke styling
S277A BMW LA wheel/double spoke
S278A BMW LA wheels with mixed tyres
S278A BMW light alloy wheel BMW styling
S279A BMW light-alloy wheel star spokes 45
S279A BMW LA wheel without flat-running prop.
S280A BMW LA wheel-spoke 176
S281A BMW LA wheel, chr.-plated/roundspokes
S282A BMW LA wheel, sport-spoke styling II
S283A BMW LA wheel, BMW styling II
S284A BMW light alloy wheel, ellips. styl. 46
S284A BMW light alloy wheel BMW styling
S285A BMW light alloy wheel BMW styling
S286A BMW light alloy wheel BMW styling
S287A BMW light alloy wheel, star spoke 64
S288A BMW light alloy wheel, cross spoke 29
S289A BMW light alloy wheel BMW styling
S290A BMW light-alloy wheel star spokes 44
S291A BMW light alloy wheel, cross spoke 2 pce
S292A BMW light alloy wheel, cross spoke 29
S293A BMW LA wheel w flat-running properties
S293A BMW LA wheel, V spoke 54
S294A BMW LA wheel, multi-spoke styling
S295A BMW LA wheel, star spoke 96
S295A BMW LA wheel, exclusive styling
S296A BMW LA wheel, Classic
S297A BMW LA wheel Streamline
S297A BMW LA wheel,forged wheel/multi-spoke
S298A BMW LA wheel turbine styling
S298A BMW LA wheel, double spoke 98
S299A BMW LA wheels with mixed tyres
S2A1A BMW LA wheel, double spoke 309
S2A2A BMW LA wheel, double spoke 421
S2A3A BMW LA wheel, double spoke 424
S2A4A BMW LA wheel, double spoke 401
S2A5A BMW LA wheel, double spoke 397
S2A6A BMW LA wheel, double spoke 392
S2A7A BMW LA wheel, double spoke 385
S2A8A BMW LA wheel, M double spoke 369
S2A9A BMW LA wheel, double spoke 313
S2AAA BMW light alloy wheel, ellips. styl. 46
S2ABA BMW LA wheel ellipsoid spoke 162
S2ACA BMW LA wheel, ellipsoid styling 109
S2ADA BMW LA wheel ellipsoid spoke 202
S2AEA BMW LA wheel turbine styling 292
S2AFA BMW LA wheel turbine styling 271
S2AGA BMW LA wheel honeycomb styling 323
S2AHA BMW LA wheel turbine styling 329
S2AKA BMW LA wheel turbine styling 329
S2ALA BMW LA wheel Streamline 297
S2AMA BMW LA wheel Streamline 306
S2ANA BMW LA wheel Streamline 363
S2APA BMW LA wheel Streamline 370
S2ARA BMW LA wheel Streamline 357
S2ASA BMW LA wheel turbine styling 381
S2ATA BMW LA wheel Streamline 306
S2AUA BMW LA wheel, Streamline 364
S2AVA BMW LA wheel, turbine styling 452
S2AWA BMW LA wheel, turbine styling 457
S2AXA BMW LA wheel, turbine styling 452
S2AYA BMW LA wheel, turbine styling 453
S2AZA BMW LA wheel, double spoke 446
S2B1A BMW LA wheel double spoke 278
S2B2A BMW LA wheel double spoke 316
S2B3A BMW LA wheel double spoke 321
S2B4A BMW LA wheel/double spoke 195
S2B6A 19" LA wheel M Performance dbl. spk 313
S2B7A BMW LA wheel, double spoke 309
S2B8A BMW LA wheel, star spoke 304
S2B9A BMW LA wheel, star spoke 276
S2BAA BMW LA wheel, double spoke 88
S2BBA BMW LA wheel, double spoke 98
S2BCA BMW LA wheel/double spoke 111
S2BDA BMW LA wheel/double spoke 112
S2BEA BMW alloy wheel, double spoke 148
S2BFA BMW alloy wheel, double spoke 154
S2BGA BMW alloy wheel, double spoke 161
S2BHA BMW alloy wheel, double spoke 156
S2BKA BMW LA wheel/double spoke 174
S2BLA BMW LA wheel/double spoke 174flat-runn.
S2BMA BMW LA wheel/double spoke 116
S2BNA BMW LA wheel/double spoke 205
S2BPA BMW alloy wheel,doub.sp. 205,All Season
S2BRA BMW LA wheel/double spoke 247 flat-runn.
S2BSA BMW LA wheel/double spoke 247 flat-runn.
S2BTA BMW LA wheel/double spoke 222
S2BUA BMW alloy wheel,doub.sp. 120,All Season
S2BVA BMW LA wheel, double spoke 266
S2BWA BMW LA wheel, double spoke 268
S2BXA BMW LA wheel, double spoke 253
S2BYA BMW LA wheel,double spoke 278/flat-runn.
S2BZA BMW alloy wheel, double spoke 161
S2C0A BMW LA star spoke 124 w flat-runn. prop.
S2C1A BMW light alloy wheel, spider spoke 175
S2C2A BMW LA star spoke 175 w flat-runn. prop.
S2C3A MINI alloy wheel 5 Star Rocket 93
S2C4A BMW light alloy wheel, spider spoke 157
S2C5A BMW LA wheel, star spoke 185
S2C6A BMW LA wheel, star spoke 189
S2C7A BMW LA star spoke 218 w flat-runn. prop.
S2C8A BMW LA wheel, star spoke 200
S2C9A BMW LA wheel, star spoke 209
S2CAA BMW LA wheel, star spoke 119
S2CBA BMW LA wheel, star spoke 113
S2CCA BMW LA wheel, star spoke 132
S2CDA BMW light alloy wheel, spider spoke 136
S2CEA BMW light alloy wheel, spider spoke 137
S2CFA BMW light alloy wheel, spider spoke 138
S2CGA BMW light alloy wheel, spider spoke 140
S2CHA BMW light alloy wheel, spider spoke 142
S2CKA BMW light alloy wheel, spider spoke 143
S2CLA MINI alloy wheel 5 Star Rocket 93
S2CMA MINI LM Rad 5 Star Bullet m. Notlauf
S2CNA MINI alloy wheel 5-star 91
S2CPA BMW LA wheel, spider spoke 137m.All-year
S2CRA BMW light alloy wheel, spider spoke 153
S2CSA BMW LA wheel, star spoke 113
S2CTA BMW light alloy wheel, spider spoke 151
S2CUA BMW light alloy wheel, star spoke 169
S2CVA BMW light alloy wheel, star spoke 170
S2CWA BMW light alloy wheel, star spoke 171
S2CXA BMW light alloy wheel, spider spoke 155
S2CYA BMW light alloy wheel, spider spoke 158
S2CZA BMW light alloy wheel, spider spoke 159
S2D1A BMW LA wheel, star spoke 262
S2D2A BMW LA wheel star spoke 272
S2D3A BMW LA wheel, star spoke 365
S2D4A BMW LA wheel, star spoke 449
S2D5A BMW LA wheel, star spoke 407
S2D6A BMW LA wheel, star spoke 427
S2D7A BMW LA wheel, star spoke 427
S2DAA BMW light alloy wheel, cross spoke 197
S2DBA BMW LA wheel, star spoke 327
S2DCA BMW LA wheel, star spoke 330
S2DDA BMW LA wheel, star spoke 330
S2DEA BMW LA wheel, star spoke 334
S2DFA BMW LA wheel, star spoke 339
S2DGA BMW LA wheel, star spoke 340
S2DHA BMW LA wheel, star spoke 340
S2DKA BMW LA wheel, star spoke 341
S2DLA BMW LA wheel Streamline 357
S2DMA BMW LA wheel, star spoke 371
S2DNA BMW LA wheel, star spoke 365
S2DPA BMW LA wheel, star spoke 367
S2DRA BMW LA wheel, star spoke 376
S2DSA BMW LA wheel, star spoke 377
S2DTA BMW LA wheel, star spoke 379
S2DUA BMW LA wheel, star spoke 382
S2DVA BMW LA wheel, star spoke 391
S2DWA BMW LA wheel, star spoke 393
S2DXA BMW LA wheel, star spoke 394
S2DYA BMW LA wheel, star spoke 396
S2DZA BMW LA wheel, star spoke 365
S2EAA BMW LA wheel Y-spoke 149
S2EBA BMW LA wheel Y-spoke 305
S2ECA BMW LA wheel Y-spoke 308
S2F5A MINI LA wheel 5-hole Black Star
S2F6A MINI LA wheel Infinite Stream Spoke
S2F7A MINI Yours LA wheel twin spoke
S2F8A MINI LA wheel twin spoke black
S2F9A MINI LA wheel Twin Spoke black burnished
S2FAA BMW LA wheel, V spoke 372
S2FBA BMW LA wheel, V spoke 366
S2FCA BMW LA wheel, V-spoke 411
S2FDA BMW LA wheel, V-spoke 378
S2FEA BMW LA wheel, V-spoke 412
S2FFA BMW LA wheel, V spoke 366
S2FGA BMW LA wheel, star spoke 367
S2FHA BMW LA wheel, V-spoke 390
S2FKA BMW LA wheel, V-spoke 413
S2FLA BMW LA wheel, V-spoke 395
S2FMA BMW LA wheel, V-spoke 398
S2FNA BMW LA wheel, V-spoke 324
S2FPA BMW LA wheel, V-spoke 426
S2FRA BMW LA wheel, V-spoke 425
S2FSA BMW LA wheel, V-spoke 426
S2FTA BMW LA wheel, V-spoke 514
S2FUA BMW LA wheel, V-spoke 515
S2FVA BMW LA wheel, V spoke 366
S2FWA BMW LA wheel, V-spoke 621
S2G4A BMW LA wheel 20 turbine styling 444
S2G5A BMW LA wheel, turbine styling 428
S2G6A BMW LA wheel, turbine styling 429
S2G7A BMW LA wheel, turbine styling 402
S2GAA MINI LA wheel 5-Star Twin Spoke
S2GBA MINI LA wheel 4-Hole Circular Spoke
S2GCA MINI LA wheel 6 Star Twin Spoke
S2GDA MINI LA wheel Conical Spoke
S2GEA MINI Yours LA wheel Twin Blade Spoke
S2GFA MINI LA wheel Sandblast Turned
S2GGA MINI LA wheel Cross Spoke Crusher
S2GHA MINI LA wheel, 6-star twin spoke, black
S2GKA 17"LM RAEDER DOUBLE CROSS TURNED BL
S2GLA MINI Steel Wheel black
S2GMA MINI LA wheel 5-Star Single Spoke
S2GNA MINI LA wheel 5-Hole Circular Spoke
S2GPA MINI LA wheel 5-Star Double Spoke
S2GRA MINI LA wheel Tunnel Spoke
S2GSA MINI LA wheel, conical spoke, black
S2GTA MINI LA wheel Turbo Fan
S2GUA MINI LA wheel 5-Star Double Spoke Comp.
S2GVA MINI LA wheel 5-Star Double Spoke Comp.
S2H1A BMW LA wheel, multispoke 235
S2H2A BMW LA wheel, multi spoke 416
S2H3A BMW LA wheel, multi spoke 414
S2H4A BMW LA wheel, multi spoke 448
S2H5A BMW LA wheel, multi spoke 458
S2H6A BMW LA wheel, multi spoke 459
S2H7A BMW LA wheel, V-spoke 450
S2H8A BMW LA wheel, V-spoke 152
S2H9A BMW LA wheel, V-spoke 356
S2HAA BMW light alloy wheel, spider spoke 139
S2HBA BMW light alloy wheel, spider spoke 160
S2HCA BMW light alloy wheel, spider spoke 187
S2HDA BMW light alloy wheel, spider spoke 190
S2HEA BMW LA radialspoke 32 w flat-runn. prop.
S2HFA BMW LA radialspoke 32 w flat-runn. prop.
S2HGA BMW LA wheel, radial spoke 244
S2HHA BMW LA radialspoke 244w flat-runn. prop.
S2HKA BMW light alloy wheel, radial spoke 216
S2HLA BMW LA wheel, radial spoke 252
S2HMA BMW LA wheel, radial spoke 237
S2HZA MINI LA wheel Multi Spoke
S2K0A BMW LA wheel, V spoke 304
S2K1A BMW LA wheel, V spoke 236
S2K2A BMW LA wheel, V spoke 328
S2K3A BMW LA wheel, V spoke 331
S2K4A BMW LA wheel, V spoke 331
S2K5A BMW LA wheel, V spoke 338
S2K6A BMW LA wheel, V spoke 342
S2K7A BMW LA wheel, double spoke 238
S2K8A BMW LA wheel, V spoke 307
S2K9A BMW LA wheel, V spoke 360
S2KAA BMW LA wheel, V spoke 110
S2KBA BMW LA wheel, V spoke 130
S2KCA BMW light alloy wheel, V-spoke 141
S2KDA BMW light alloy wheel, V-spoke 168
S2KEA BMW light alloy wheel, V-spoke 188
S2KFA BMW alloy wheel M V-spoke 217
S2KGA BMW LA wheel V-spoke 188 / All Season
S2KHA BMW light alloy wheel, V-spoke 229
S2KKA BMW light alloy wheel, V-spoke 206
S2KLA BMW light alloy wheel, V-spoke 245
S2KMA BMW LA wheel, V-spoke 245 flat-runn.
S2KNA BMW light alloy wheel, V-spoke 255
S2KPA BMW light alloy wheel, V-spoke 248
S2KRA BMW light alloy wheel, V-spoke 257
S2KSA BMW LA wheel, V-spoke 254
S2KTA BMW LA wheel, V-spoke 277 / flat-runn.
S2KUA BMW LA wheel V-spoke 285
S2KVA BMW LA wheel V-spoke 294
S2KWA BMW LA wheel V-spoke 296
S2KXA BMW LA wheel V-spoke 279
S2KYA BMW LA wheel V-spoke 277
S2KZA BMW LA wheel V spoke 318
S2L0A BMW LA wheel, V spoke 236
S2L1A BMW LA wheel, multi spoke 399
S2L2A BMW LA wheel, V-spoke 387
S2L3A BMW LA wheel, V-spoke 395
S2L8A BMW LA wheel, double spoke 466
S2L9A BMW LA wheel, double spoke 384
S2LAA BMW LA wheel Y-spoke 114
S2LBA BMW LA wheel Y-spoke 131
S2LCA BMW LA wheel Y-spoke 183
S2LDA BMW LA wheel Y-spoke 211
S2LEA BMW LA wheel Y-spoke 214
S2LFA BMW LA wheel Y-spoke 280
S2LGA BMW LA wheel Y spoke 315
S2LHA BMW LA wheel Y spoke 322
S2LKA BMW LA wheel Y spoke 335
S2LLA BMW LA wheel Y spoke 335
S2LMA BMW LA wheel Y spoke 336
S2LNA BMW LA wheel Y spoke 315
S2LPA BMW LA wheel Y-spoke 380
S2LRA BMW LA wheel Y spoke 322
S2LSA BMW LA wheel, Y-spoke 451
S2LTA MINI LA wheel Y-spoke, light anthracite
S2LXA BMW LA wheel Y spoke 337
S2M0A BMW LA wheel, Individual 152 I, 18"
S2M1A BMW LA wheel, Individual 152 I, 19"
S2M2A BMW LA wheel, Individual 152 I, 20"
S2M3A BMW LA wheel, individual V spoke 349
S2M4A Ind.leath.-cov. steer.wheel,leath.inlay
S2M5A BMW LA wheel, M V spoke 223
S2M6A Individ. leather st.wheel w/wood inlay
S2M7A M High Performance tyres
S2M8A BMW LA wheel, V-spoke 228,individ.
S2M9A BMW LA wheel, M V-spoke 227
S2MAA Manual gearbox
S2MBA BMW alloy wheel, 19" forged
S2MBA BMW alloy wheel, M double spoke 167
S2MCA BMW alloy wheel, M radial spoke 166
S2MDA M Drive
S2MEA BMW alloy wheel, M double spoke 194
S2MFA BMW alloy wheel, M spider spoke 193
S2MGA BMW alloy wheel, M double spoke 207
S2MHA BMW alloy wheel, M double spoke 208
S2MKA M twin-clutch transm. with Drivelogic
S2MLA BMW alloy wheel, M double spoke 192
S2MMA BMW alloy wheel M Y-spoke 191
S2MNA BMW LA wheel M double spoke 192/All S.
S2MPA BMW alloy wheel, M double spoke 225
S2MRA BMW LA wheel, M double spoke 261
S2MSA BMW LA wheel, M star spoke 368
S2MTA BMW LA wheel, M double spoke 220
S2MUA BMW LA wheel, M star spoke 325
S2MVA BMW LA wheel, M double spoke 326
S2MWA BMW LA wheel, V spoke 265 Individual
S2MXA BMW LA wheel, M double spoke 354
S2MYA BMW LA wheel, M double spoke 355
S2MZA BMW LA wheel, individual V spoke 349
S2N0A BMW i Carbon ceramic brake
S2N1A MINI LA wheel Silver Shield
S2N2A MINI LA wheel Infinite Stream Spoke
S2N3A BMW LA wheel, M star spoke 383
S2N4A BMW LA wheel, M star spoke 386
S2N6A BMW LA wheel M Y-spoke 359
S2N7A BMW LA wheel, M double spoke 345
S2N8A BMW LA wheel, M star spoke 344
S2N9A BMW LA wheel, M double spoke 434
S2NAA Interior mirror with digital compass
S2NAA BMW LA wheel, M double spoke 350
S2NBA BMW LA wheel, M double spoke 351
S2NCA BMW LA wheel, M double spoke 350
S2NDA BMW LA wheel, M double spoke 351
S2NEA BMW LA wheel, M double spoke 369
S2NFA BMW LA wheel, M double spoke 313
S2NGA BMW LA wheel, M V spoke 302
S2NHA M Sport brake
S2NKA M Carbon ceramic brake
S2NLA BMW LA wheel, individual V-spoke 374
S2NMA BMW LA wheel, M double spoke 373
S2NNA BMW alloy wheel, M double spoke 172
S2NPA BMW alloy wheel, M double spoke 135
S2NRA BMW alloy wheel, M double spoke 172
S2NSA BMW LA wheel double spoke 288
S2NTA BMW LA wheel, M V spoke 299
S2NUA BMW LA wheel double spoke 300
S2NVA BMW LA wheel, individual V spoke 301
S2NWA BMW LA wheel, M V spoke 302
S2NXA BMW LA wheel double spoke 303
S2NYA BMW LA wheel, M double spoke 333
S2NZA BMW LA wheel, M double spoke 343
S2P0A Dummy-SALAPA
S2P1A BMW LA wheel, W spoke 423
S2P2A MINI LA wheel Double Cross Turned
S2P3A BMW LA wheel, W spoke 418
S2P4A BMW LA wheel, Streamline 419
S2P5A BMW LA wheel, turbine styling 415
S2P6A MINI LA wheel Rip Spoke
S2P7A MINI LA wheel, Twin Spoke, red lining
S2P8A MINI LA wheel, Cross Spoke Challenge
S2P9A MINI LA wheel silver
S2P9A MINI LA wheel Bright Silver
S2PAA Wheel bolt locks
S2PBA Wheel cover
S2PCA BMW LA wheel, M double spoke 354
S2PDA BMW LA wheel, M double spoke 355
S2PEA BMW LA wheel, M star spoke 400
S2PFA BMW LA wheel, M star spoke 403
S2PGA BMW LA wheel, M double spoke 436
S2PHA BMW LA wheel, M double spoke 435
S2PKA BMW alloy wheel, M double spoke 194
S2PLA BMW LA wheel, M double spoke 442
S2PMA BMW LA wheel, M double spoke 441
S2PNA BMW LA wheel, M V-spoke 438
S2PPA BMW LA wheel, M star spoke 400
S2PRA BMW LA wheel, individual V-spoke 439
S2PSA BMW LA wheel, M double spoke 433
S2PTA BMW LA wheel, M double spoke 460
S2PUA BMW LA wheel, M double spoke 461
S2PVA BMW LA wheel, M double spoke 467
S2PWA BMW LA wheel, M double spoke 469
S2PXA MINI LA wheel, Cross Spoke Challenge
S2PYA BMW LA wheel, turbine styling 453
S2PZA BMW LA wheel, Streamline 364
S2R0A Steel rims in black
S2R1A BMW light alloy wheel, spider spoke 138
S2R2A BMW LA wheel, start spoke 256
S2R3A BMW LA wheel, star spoke 203
S2R4A BMW LA wheel, star spoke 230
S2R5A BMW LA wheel, star spoke 204
S2R6A BMW LA wheel, start spoke 231
S2R7A MINI LA wheel Bridge Spoke/ All Season
S2R8A BMW LA wheel, start spoke 241
S2R9A Runflat tyres
S2RAA BMW alloy wheel, trapezoid style 134
S2RBA MINI LM Rad 7 Fin Spoke m. Notlauf
S2RCA Aluminum rim with wheel cover
S2RDA BMW LA wheel-spoke 176/mixed tyres
S2REA MINI LA wheel Web spoke flat-runn. prop.
S2RFA MINI LA wheel Delta Spoke silver
S2RFA MINI LA wheel Delta spoke 96
S2RGA MINI LA wheel Bridge Spoke
S2RHA MINI LA wheel Flame Spoke 97
S2RKA MINI alloy wheel, 5-start spooler 100
S2RLA MINI alloy wheel, rotator spoke 101
S2RMA MINI LA wheel, night spoke,runflat
S2RNA MINI LA wheel, 5-star blaster,limp-home
S2RPA MINI LA wheel,Crown spoke flat-runn. pro
S2RRA LM Rad anthrazit
S2RRA MINI LA wheel,Crown spoke 104
S2RSA MINI LA wheel "5 Star Pace Spoke"
S2RTA BMW LA wheel turbine styling 201
S2RUA MINI LA wheel Black Star Bullet
S2RVA MINI LA wheel in black
S2RWA MINI LA wheel "Web Spoke two-tone"anthr.
S2RXA BMW LA wheel, star spoke 210
S2RYA BMW LA wheel, star spoke 212
S2RZA BMW LA wheel, star spoke 213
S2S0A BMW LA wheel, double spoke 234
S2S1A BMW LA wheel star spoke 286
S2S2A BMW LA wheel star spoke 287
S2S3A BMW LA wheel star spoke 290
S2S4A BMW LA wheel star spoke 295
S2S5A BMW LA wheel multi-spoke 293
S2S6A BMW LA wheel, start spoke 258
S2S7A BMW LA wheel star spoke 317
S2S8A BMW LA wheel star spoke 319
S2S9A BMW LA wheel star spoke 320
S2SAA Wheels w/o emergency running properties
S2SBA BMW LA wheel, start spoke 242
S2SCA BMW LA wheel, start spoke 243
S2SDA BMW LA star spoke 243 w flat-runn. prop.
S2SEA BMW LA star spoke 246 w flat-runn. prop.
S2SFA BMW LA wheel, start spoke 249
S2SGA BMW LA wheel, start spoke 232
S2SHA BMW LA wheel, start spoke 258
S2SKA BMW LA wheel, start spoke 259
S2SLA BMW LA wheel, star spoke 262
S2SMA BMW LA wheel, star spoke 264
S2SNA BMW LA wheel, star spoke 117
S2SPA BMW LA wheel, star spoke 233
S2SRA BMW LA wheel, double spoke 234
S2STA BMW LA wheel, multispoke 235
S2SUA BMW LA wheel, star spoke 250
S2SVA BMW LA wheel, star spoke 251
S2SWA BMW LA wheel star spoke 272
S2SXA BMW LA wheel multi-spoke 282
S2SYA BMW LA wheel star spoke 283
S2SZA BMW LA wheel multi-spoke 284
S2T1A BMW LA wheel, star spoke 407
S2T2A BMW LA wheel, star spoke 490
S2T6A BMW LA wheel 19 M double spoke 467
S2T7A BMW i LA wheel, double spoke 430
S2T8A BMW LA wheel, double spoke 466
S2T9A BMW LA wheel, double spoke 496
S2TAA Differential lock 25%
S2TBA Sport automatic gearbox
S2TCA Sport gearbox with twin clutch
S2TDA Automatic transm. with w/ twin clutch
S2TEA Automatic transmission w/ shift paddles
S2TMA Control, transmission type
S2TVA BMW LM Rad M Doppelspeiche 623
S2TWA BMW LM Rad M Doppelspeiche 623
S2TXA BMW LA wheel, M double spoke 601
S2TYA BMW LA wheel, M double spoke 343
S2TZA BMW LA wheel, M star spoke 491
S2U1A Winter wheel and tyre, star spoke 317
S2U2A Winter wheel&tyre, radial spoke 50
S2U3A Winter wheel&tyre, radial spoke 118
S2U4A Winter wheel&tyre, Flame spoke
S2U5A Winter wheel&tyre, Bridge spoke
S2UAA Winter wheel&tyre with steel rim
S2UBA Winter wheel&tyre with steel rim
S2UCA Winter wheel&tyre, double spoke 116
S2UDA Winter wheel&tyre, double spoke 184M
S2UEA Winter wheel&tyre, double spoke 234
S2UFA Winterkomplettrad Doppelspeiche 268
S2UGA Winter wheel&tyre, double spoke 270M
S2UHA Winter wheel&tyre, multi-spoke 235
S2UKA Winter wheel&tyre, V-spoke 110
S2ULA Winter wheel&tyre, V-spoke 223M
S2UMA Winter wheel&tyre, V-spoke 229
S2UNA Winter wheel&tyre, V-spoke 257
S2UPA Winter wheel&tyre, V-spoke 298M
S2URA Winter wheel&tyre, Y-spoke 214
S2USA Winter wheel&tyre, cross spoke 177
S2UTA Winter wheel&tyre, star spoke 138
S2UUA Winter wheel&tyre, star spoke 143
S2UVA Winter wheel&tyre, star spoke 158
S2UWA Winter wheel&tyre, star spoke 209
S2UXA Winter wheel&tyre, star spoke 233
S2UYA Winter wheel&tyre, star spoke 256
S2UZA Winter wheel&tyre, star spoke 276
S2V0A BMW LM Rad Individual V-Speiche 551
S2V1A BMW LM Rad M Doppelspeiche 622
S2V2A BMW LM Rad M Doppelspeiche 622
S2V3A BMW LA wheel, M double spoke 613
S2V4A BMW LA wheel, M double spoke 613
S2V5A BMW LA wheel, M double spoke 598
S2V7A BMW LA wheel, M double spoke 441
S2V9A BMW LA wheel, M double spoke 468
S2VAA Chassis & suspens. setup"Adaptive Drive"
S2VBA Tyre pressure display
S2VBA Tyre pressure control (TPC)
S2VCA Tyre repair set
S2VFA Adaptive M chassis
S2VGA PERFORMANCE CONTROL
S2VHA Integral active front steering
S2VKA DYNAMIC PERFORMANCE CONTROL
S2VLA Variable sport steering
S2VMA Adaptive suspension package Comfort
S2VNA Dynamic Damper Control
S2VPA Adaptive suspension package Dynamic
S2VRA Two-axle air suspension
S2W1A BMW LA wheel, multi spoke 454
S2W2A BMW LA wheel, multi spoke 455
S2W3A BMW LA wheel, multi spoke 456
S2W4A BMW LA wheel, multi spoke 455
S2W5A BMW LA wheel, multi spoke 399
S2W6A BMW LA wheel, multi spoke 458
S2W8A BMW LA wheel 20 W-spoke 470
S2W9A BMW LA wheel, W-spoke 440
S2WAA BMW LA wheel, W-spoke 263
S2WBA BMW LA wheel W-spoke 291
S2WCA BMW LA wheel, W spoke 332
S2WDA BMW LA wheel, W spoke 332
S2WEA BMW LA wheel, W spoke 423
S2WFA BMW LA wheel, W-spoke 447
S2WGA BMW LA wheel, W-spoke 440
S2WWA BMW LA wheel, turbine styling 452
S2WXA BMW LA wheel, turbine styling 389
S2WYA BMW LA wheel, turbine styling 402
S2WZA BMW LA wheel, turbine styling 389
S2XAA Sport leather st. wheel w/ shift paddles
S2XAA Leath.-cov.sport st.wheel+padd.+multif.
S2XBA MINI Yours Soda Sport-Lederlenkrad
S2XCA JOHN COOPER WORKS LEDERLENKRAD
S2XEA Leather sports steering wheel
S2XLA Premium Luxury Lenkrad
S2Y0A Dummy-SALAPA
S2Y1A Dummy-SALAPA
S2Y2A Dummy-SALAPA
S2Y3A Dummy-SALAPA
S2Y4A Dummy-SALAPA
S2Y5A Dummy-SALAPA
S2Y6A Dummy-SALAPA
S2Y7A Dummy-SALAPA
S2Y8A Dummy-SALAPA
S2Y9A Dummy-SALAPA
S2YWA Dummy-SALAPA
S2YXA Dummy-SALAPA
S2YYA Dummy-SALAPA
S2YZA Dummy-SALAPA
S300A Central locking with anti-theft system
S300A Emergency spare wheel
S301A All-terrain tyres
S301A Alarm system
S302A Alarm system
S303A BURGLAR AL. WITH TILT ALARM SENSOR
S303A BMW light alloy wheel, ellips. styl. 60
S304A BMW light alloy wheel, ellips. styl. 60
S305A Remote control for central locking
S306A Closing pack
S306A MINI alloy wheel 7-hole 81
S306A Remote control for central locking
S307A BMW light alloy wheel, radial spoke 61
S307A Safety locking for luggage compartment
S308A Comfort package
S308A BMW light alloy wheel, cross spoke 42
S309A BMW light alloy wheel, star spoke 57
S309A BMW LA wheel, star-spoke styling
S310A BMW light alloy wheel, star spoke 58
S310A Comfort package
S311A BMW light alloy wheel chromed
S311A BMW LA wheel, star spoke 69
S312A BMW LA wheel, V-styling 63
S312A BMW LA wheels with mixed tyres
S313A Fold-in outside mirror
S314A Door mirror, driver lock, heated
S315A Rear window wiper
S316A automatic trunk lid mechanism
S317A Soft Close Automatic, luggage-comp. lid
S317A Comfort actuation, doors
S318A Interior surface in vehicle colour
S318A Soft Close Automatic, door/luggage comp.
S318A Double sun visors
S319A Integrated universal remote control
S320A Deleted, model lettering
S321A Exterior parts in vehicle colour
S321A Model lettering
S322A Comfort access
S322A Rear chrome strip discontinued
S323A Soft-Close-Automatic doors
S324A Front and rear spoilers
S324A BMW LA wheel, ellipsoid styling 107
S325A Rear spoiler
S326A Deleted, rear spoiler
S327A Ornamental strips on hood, white
S328A Footplate, aluminium
S328A Door sill
S329A Ornamental strips on hood, black
S331A BMW LA wheel, star spoke 102
S332A BMW LA wheel turbine styling 106
S333A Wind deflector
S333A BMW LA wheel, star spoke 105
S334A BMW LA wheel/double spoke 71
S334A BMW LA wheel/double spoke 103
S338A M Sports package II
S339A Shadow-Line
S340A Rubbing strips black
S340A Bumper, partially painted
S341A Bumpers completely in body colour
S342A Interior trim strips, Titan Shadow
S343A Chrome Line interior, matt
S344A Alu Line Interieur
S345A Chrome Line Interieur
S346A Chrome Line exterieur
S347A Titan Line Exterieur
S348A Highlight exterieur
S349A Highlight interieur
S350A BMW Composite wheel, star spoke 108
S350A Therm.insulat.glass green
S351A BMW LA wheel, star spoke 89
S352A Insulating double-glazing
S353A Windscreen&rear window,green-tintedstrip
S354A Windscreen, green-tinted upper strip
S355A Laminated glass
S355A Windscreen, clear with anti-glare strip
S356A Climate comfort laminated glass
S357A Protective glazing
S358A Climate comfort windscreen
S359A Therm.insulat.glass green/clear windscr.
S359A Visibility package
S360A BMW LA wheel, star spoke 81
S361A BMW LA wheel, parallel spoke 82
S361A Vent window rear
S362A Vent window, electric, rear
S363A BMW light alloy wheel, radial spoke 32
S364A Safety tyres
S365A Safety tyres
S365A Rear window, laminated glass
S366A BMW LA wheel, star spoke 70
S367A MINI LA wheel, 8-spoke 82
S368A MINI LA wheel, 5-star 16"
S369A MINI LA wheel, S-spoke 85
S370A Land Rover LM Rad Styling 1
S370A Softtop, black
S371A Land Rover LA wheel styling 2
S372A Folding top, dunkel-braun
S372A Land Rover LM Rad Styling 3
S373A Land Rover LM Rad Styling 4
S373A Softtop, dark blue
S374A BMW light alloy wheel,radial styling
S375A BMW LA wheel, double spoke 79
S375A Convertible top, electromech., black
S376A BMW LA wheel, star spoke 74
S376A Convertible top, electromech.,dark brown
S377A Convertible top, electromech., dark blue
S377A BMW LA wheel, star spoke 69
S378A BMW LA wheel w flat-running properties
S379A BMW LA wheel Y-spoke 80
S380A Hardtop-preparation
S381A Outs.mirror black/roof vhcle colour
S382A Roof and mirror caps, white
S383A Roof and mirror caps, black
S384A Light-alloy wheels, white
S385A Outside mirror/roof in grey
S385A MINI LA wheel, X-Lite 84
S385A ROOF RACK SYSTEM
S386A Roof railing
S387A Wind deflector
S388A Softtop, black
S389A Softtop, grey
S390A Softtop classic red
S391A Softtop, dark blue
S392A Softtop, dark green
S393A Convertible top, turquoise
S394A Softtop dark beige
S395A Rollover protection system
S396A Safety tyres
S397A BMW LA wheel, star spoke 83
S398A Softtop, electromech. semiautom.
S399A Softtop, electromech. all-autom.
S3A1A JCW aerodynamic kit
S3A2A Black headlights
S3A3A Roof and mirror caps, red
S3A5A Bonnet stripes, damson red
S3A6A MINI Yours Soda mirror caps
S3A7A Sport Stripes, black
S3A8A Sport Stripes, red
S3A9A Sport Stripes, silver
S3AAA Roof railing black
S3ABA Mirror cap in vehicle colour
S3ACA Trailer coupling
S3ADA Engine-compartment lid stripes Park Lane
S3AEA Engine-compartment lid stripes Checkmate
S3AFA Outside mirror/roof in silver
S3AGA Reversing camera
S3AHA Reversing camera and Top View
S3AKA Engine-compartment lid stripes silver
S3ALA John Cooper Works Kit
S3AMA C-pillars in matt silver
S3ANA C-pillars in silver
S3APA Windscreen with grey wedge
S3ARA Preparation, rear luggage rack
S3ASA Roof rails, silver
S3ATA Roof rail, aluminium, satinised
S3AUA Bonnet stripes Toffy
S3AVA Bonnet graphic Camden
S3AWA Spray nozzles without heating
S3AXA MINI YOURS TATTOO FUNKY
S3AYA MINI YOURS TATTOO GLORIOUS
S3AZA Engine-bonnet stripes, John Cooper Works
S3B2A C-pillars, cool champagne
S3BAA MINI Yours engine comp. lid stripe Soda
S3BBA MOTORHAUBENSTREIFEN BAKER STREET
S3BCA MOTORHAUBENSTREIFEN HIGHGATE
S3BDA MOTORHAUBENSTREIFEN REDBRIDGE
S3BEA SPIEGELKAPPEN SCHWARZ
S3BFA SPIEGELKAPPEN ROT
S3BGA Mirror caps, white
S3BHA Sport Stripes, white
S3BKA MINI Yours eng.-comp.lid str. Soda schw.
S3BLA Roof and mirror caps, British R. Green
S3BMA Roof and mirror caps, Hot Chocolate
S3BNA Eng.-comp. lid stripes British R. Green
S3BPA MOTORHAUBENSTREIFEN HOT CHOCOLATE
S3BRA MOTORHAUBENSTREIFEN COOL CHAMPAGNE
S3BXA Roof and mirror caps, cool champagne
S3BYA MINI Yours
S3DVA Roof-rack preparation
S3DYA Entrance strips
S3DZA Omission of additional lettering, outer
S3E1A EXTERIEURDESIGN PURE EXCELLENCE
S3E2A EXTERIEURDESIGN PURE EXPERIENCE
S3E3A Präsenzpaket Exterieur
S3L1A Dark Style
S3L8A Exterior equipment, aluminium, satinised
S3MAA Individ. roof rail, burnished aluminium
S3MBA Indiv. Ext. Line, burnished aluminium
S3MCA Indiv.roofrailing,mirror-fin.Shadow Line
S3MDA BMW Individual rear-end identification
S3WZA BMW Individual hardtop
S3XLA Exterior design equipment X Line
S3XLA X Line
S3YAA Convert. top, anthracite, silver effect
S3YBA Convertible top, silver effect,dark blue
S3YCA Soft top, silvertouched-brown
S3YDA Folding top, dunkel-braun
S3YEA Softtop dark beige
S3YFA VERDECK BRAUN SILBEREFFEKT
S400A Slide/tilt sunroof, manually operated
S401A Lift-up-and-slide-back sunroof, electric
S402A Panorama glass roof
S403A Glass roof, electrical
S404A DOUBLE COVER-SLIDING LIFTING ROOF
S405A Exterior mirror caps, chrome-plated
S406A roll-back roof
S410A Window lifts, electric, front
S411A Window lifts,electric,front/rear
S412A Luggage-compartment floor, extendable
S413A Luggage compartment net
S414A ROLLER BLIND, REINFORCED
S414A Parcel net, passenger side
S415A Sun-blind, rear
S416A Roller sun visor, rear lateral
S417A Roller sun visor, rear door
S418A Luggage compartment package
S419A Glove compartment cover with lighting
S420A Sun protection glazing
S421A Fire extinguisher, halon 2 kg
S422A Fine wood trim, mussle maple
S423A Floor mats velours
S424A Floor carpet, black
S425A Interior trim finishers
S426A Interior trim finishers, aluminium
S427A Interior surface, silver
S428A Warning triangle and first aid kit
S429A Interior surface, anthracite
S430A Interior/outside mirror with auto dip
S431A Interior mirror with automatic-dip
S432A Rain sensor/int. mirror auto dim action
S433A Interior trim finishers
S434A Interior surface aluminium
S434A Interior trim finishers
S435A Fine wood trim
S436A Fine wood trim
S436A Prep,infinitely variable dip in/rv/mir
S437A Instrumententafel schwarz
S437A Fine wood trim
S438A Fine wood trim
S439A Interior trim finishers
S439A Interior trim finishers, matt chrome
S440A non-smoker package
S441A Smoker package
S442A Drink holder
S443A Compass function
S444A multi-purpose armrest
S445A Centre console to the rear
S445A Pack, stowage tables
S447A High Line interior lining
S449A Interior toll mirror for Japan
S449A Make-up mirror, rear cabin
S450A Height adjustment, passenger seat
S450A Active seat-backrest ventilation
S451A Active seat for driver
S451A Height adjustment, front-pass.seat,mech.
S452A Entrance assistance in the rear
S452A Active seats in rear
S453A Climatised front seats
S454A Air-conditioned seats, rear
S454A Seat adjustment, electric, driver side
S455A Active seat for driver and passenger
S455A Seat adjustment, electric, driver side
S456A Comfort seat with memory
S457A Contour seat, front, electr. with memory
S458A Electr. front seat adjustment
S459A Seat adjustment, electric, with memory
S460A Comfort seat, rear, electr.adjustable
S460A ELECTR.REAR SEAT ADJUSTMENT
S461A Electric seat backrest adjustment, rear
S463A Interior surface Alloy Patina
S464A Ski bag
S465A Through-loading system
S466A Roof mouldings in body colour
S467A Taxi rear seats in fabric
S467A Rear seat bench w/out single-seat shape
S468A Through-loading system with ski bag
S468A Ski bag
S469A Integrated child seats
S470A Isofix-System
S471A Interior surface graphit-metallic
S472A Armrest, front, driver/passenger
S473A Armrest front
S474A Deleted, front armrest
S475A Armrest, front, incl. st.-wheel adjmnt
S476A Door trim panel magnesium-grey
S477A Interior surface wood decor
S481A Sports seat
S482A Sport seat and sport steering wheel
S488A Lumbar support, driver and passenger
S489A Lumbar support, front passenger, electr.
S490A Lumbar support for rear seats
S490A Adjustment, seat-backrest width
S492A Oddments tray, centre console
S493A Storage compartment package
S494A Seat heating driver/passenger
S495A 3-point belt & head restrnt,rear middle
S496A Seat heating, rear
S497A Centre armrest, rear
S498A Headrests mechanically adjustable, rear
S499A Headrests electrically adjustable, rear
S4A0A Interior trim finishers, aluminium
S4A1A Interior trim finishers Graphitane matt
S4A3A Fine-wood trim walnut light
S4A4A Interior trim strips, Alu Cirrus
S4A5A Interior colour Gotham grey
S4A6A Interior colour Tuscan-Beige
S4A7A Colour Line Dark Grey
S4A8A Colour Line Cream White
S4A9A Colour Line mellow yellow
S4AAA Headlining anthracite
S4ABA Fine wood trim burr walnut
S4ACA Fine wood trim Poplar woodgrain
S4ADA Interior trim strips, brushed aluminium
S4AEA Armrest front, retractable
S4AFA Roofliner, basalt-grau
S4AGA Interior trim finishers Titanium matt
S4AHA Fine wood trim american nutwood
S4AKA Interior trim finishers silver
S4ALA Interior trim finishers Titanium dark
S4ANA Interior surface Seven
S4APA Interior surface Park Lane
S4ARA Interior surface Checkmate
S4ASA Fine-wood trim poplar grain grey
S4ATA Interior trim finishers black high-gloss
S4AUA Extended decorative scopes
S4AVA Interior surface, sidewalk
S4AZA Fine-wood trim bamboo grain dark
S4B0A Real myrtle wood-grain trim, anthracite
S4B1A Interior mouldings kaschmir-silver
S4B2A Real myrtle wood-grain trim, anthracite
S4B3A Int. mouldings alumin."Akzentschliff"
S4B4A Alu. strips ground lngthwise/Leather ins
S4B5A Superior wood,ash,varieg., bright finish
S4B6A Int. trim strips, Alu Flywheel black
S4B7A Fine-wood version Fineline highly shiny
S4B8A Edelholzausf. Nussbaumwurzel/Intarsien
S4B9A Interieurleisten Alu Feinschliff
S4BAA Colour Line Rooster Red
S4BBA Colour Line Pacific Blue
S4BCA Interior surface, Fluid Silver
S4BDA Interior surface Piano Black
S4BEA Interior surface, English Oak
S4BFA Interior surface Brushed Aluminium
S4BGA Dummy-SALAPA
S4BKA Alum. interior strips ground lengthwise
S4BLA Interior colour, Redwood Red
S4BMA Interior trim finish. Graphite silk matt
S4BNA Fine-wood trim ash grain
S4BPA Fine-wood trim poplar grain light
S4BRA Interior surface, aluminium ground
S4BSA Interior World Hot Chocolate
S4BTA Dummy-SALAPA
S4BUA Colour Line Hot Chocolate
S4BWA Real maple wood-grain trim
S4BXA Interior strips, high-gloss, grey
S4BYA Real Bamboo wood-grain trim, anthracite
S4BZA Interior trim finishers Titanium light
S4C0A Interior colour, Satellite Grey
S4C1A COLOUR LINE CARBON BLACK
S4C2A COLOUR LINE POLAR BEIGE
S4C3A COLOUR LINE SATELLITE GREY
S4C4A COLOUR LINE DARK TOBACCO
S4C5A COLOUR LINE PURE RED
S4C6A COLOUR LINE SURF BLUE
S4C7A Cockpit surface, dark silver
S4C8A Cockpit surface, dark anthracite
S4C9A Interior surface, Pepper White
S4CAA High-gr.wood vers.,varieg.ash anthracite
S4CBA Fine-wood version Fineline natural
S4CCA High-gr.wood appl. f. leather st. wheel
S4CDA Interior strips, ruthenium-grau metallic
S4CEA Fine-wood version, Fineline, anthracite
S4CFA Interior strips, space-grau, metallic
S4CGA Interior trim strips "satin-silber" matt
S4CHA Fine-wood version Fineline Wave
S4CKA Fine-wood version Fineline light
S4CLA Interior strips, marrakesch-braun met.
S4CMA Interior strips, platin-bronze metallic
S4CNA COLOUR LINE TOFFY
S4CPA COLOUR LINE TECH WHITE
S4CRA Interior surface, Toffy Lining
S4CSA Interior surface, Silver Lining
S4CTA Fine wood variegated ash, brown + inlay
S4CUA Interior colour, Carbon Black
S4CVA Fine-wood trim, American oak
S4CVA Fine wood version, oak unhewn, high-fin.
S4CWA Interior colour, Polar Beige
S4CXA Interior colour, Dark Tobacco
S4CYA Interior surface, Chili Red
S4CZA Interior trim surface, Damson Red Lining
S4D0A Edelholzausführung Fineline Stripe
S4D1A COLOUR LINE ROOFTOP GREY LIGHT
S4D2A COLOUR LINE DARK TRUFFLE
S4D3A COLOUR LINE ROCKLIKE ANTHRACITE
S4D5A Contrast Interior Colour Polar Beige
S4D6A Interior surface Highgate
S4D8A Interior surface Bayswater
S4D9A Interior surface Baker Street
S4DAA Interior surface, Striped Alloy
S4DBA Interior surface, Dark Silver
S4DCA Interior surface, Black chequered
S4DDA Fine-wood trim Fineline Pur
S4DEA Fine-wood trim Fineline Siena
S4DFA Cockpit surface, Piano Black
S4DGA Interior surface Deep Champagne
S4DHA Interior trim strips, alpin-weiss
S4DKA Accent strips, oxid-silber matt
S4DLA Accent strips, black, high-polish
S4DMA Accent strips, pearl-effect chrome
S4DNA Accent strips, korall-rot matt
S4DPA Fine wood trim Fineline Stream
S4DRA Int. trim strips, acrylic glass, white
S4DSA Int. trim finishers,acrylic glass, white
S4DTA Interior trim finishers, Pearl
S4DUA Accent strips, jade-weiss
S4DVA MINI Yours Soda interior surface
S4DXA Accent strips, blue metallic matt
S4DYA Int.trim finishers oxid-silber dark matt
S4DZA INTERIEURLEISTEN PEARL DUNKEL
S4EBA Fine-wood trim Fineline Bay matt
S4ECA Interior world Pure
S4EDA Interior world Care
S4EEA Interior world Cosmo
S4EFA Int. trim finishers,alum.embossed fabric
S4EGA Fine-wood version Fineline natural
S4EHA Interior trim strips, black high gloss
S4EKA Interior trim strips, satin-silber matt
S4ELA Fine-wood trim Fineline Pur
S4EMA Colour Line Red Copper
S4ENA Interior surface, Dark Anthracite
S4EPA Interior surface Hazy Grey
S4ERA Interior surface Fibre Alloy
S4ESA Interior surface Off-White
S4ETA Interior surface Dark Cottonwood
S4EUA Interior surface Firework
S4EZA High-grade wood trim, variegated ash
S4F1A Colour Line Dinamca
S4F2A COLOUR LINE SHADOW GREY
S4FAA Recaro sports seat
S4FBA Omission of sport seat
S4FCA Rear seat with further parts
S4FDA Seat adjustment for rear seats
S4FEA Interior trim finishers, metal fabric
S4FFA KOMFORTSITZE IM FOND
S4FGA Seat belt BMW i blue
S4FKA BEIFAHRERSITZLEHNE UMKLAPPBAR
S4FLA Travel & Comfort system
S4KSA Contrast stitching
S4L0A MINI Yours dashboard leather, black
S4L2A Omission door sill finishers w/ Lines ID
S4L3A Interior trim finishers, Dark Copper
S4L4A JCW dashboard leather, black/anthracite
S4L5A MINI Yours dashboard leather, black/grey
S4L6A MINI Yours dashboard leather,black/beige
S4L7A Interior trim finishers, palladium-grau
S4L9A Interior trim strips, Alu Trace
S4LXA Accent strips, black chrome
S4LYA Interior trim strips, Aluminium Blade
S4LZA Interior trim strips, Blue Shadow
S4M0A Individual fine natural poplar wood
S4M1A Individual fine wood Mahagoni Maritim
S4M2A Individual folding table in rear comp.
S4M3A Interior trim strips, Alu Cube Pure
S4M4A Individual strip, alu silver grid
S4M4A Int. trim strips, Alu 3D Silver Grid
S4M5A Individual leather-covered dashboard
S4M6A Milled aluminium Controller
S4M7A Individual fine wood Mahagoni
S4M8A Individual rear-reading light
S4M9A Individual rear console
S4MAA M multifunction seat
S4MBA Interior line Style
S4MCA Interior trimstrips, Carbon Fibre
S4MDA Interior mouldings Fibre Net eis-grey
S4MEA Fine wood trim Madeira nutwood
S4MFA Active backrest width adjustment
S4MFA Dynamic seat back width adjustment
S4MGA Int. mouldings aluminium glacier-silver
S4MHA Individual fine wood Mahagoni Maritim
S4MKA Fine wood trim Carrara
S4MKA Fine wood trim olivesche carrara nat
S4MLA Interior strips, piano lacquer, black
S4MMA Individual strips, leather-covered
S4MPA Interior trimstrips,alum.dark,cross-gr.
S4MRA Interior trim strips, alum. hexagon
S4MSA Interior trim strips, Alu Pentan
S4MTA Int. trim strips,Alu Shadow dark brushed
S4MUA High-grade wood, eucalyptus, red-brown
S4MVA Interior trim strips, Alu Micro
S4MWA Interior strips, Aluminium Carbon Shadow
S4MXA Int. trim strips, alum. Shadow long. gr.
S4MYA Int.trim,leather,carbon struct.,black
S4MZA Fine wood,var.plane-tree mirror,anthrac.
S4NAA Interior mirror with digital compass
S4NBA Autom. climate control with 4-zone ctrl
S4NCA Auxiliary heating/ventilation
S4NDA Instrument panel, leather-covered
S4NEA Blow-by heater
S4NFA Extended rear-cabin air conditioning
S4NGA Trims, dashboard, mirror-finish
S4NHA Neck warmer
S4NKA MINI Yours dashboard, leather-covered
S4NLA Cool Shield
S4NMA Ionisation
S4T6A Massage function in rear cabin
S4T7A Massage function f.driver & fr.passenger
S4T8A Outside mirror with auto dip
S4T9A Winter package
S4U1A Ceramic application, control elements
S4U2A Eco pro
S4U2A Driving experience switch incl. ECO PRO
S4U3A Smoker package
S4U4A 2-part centre rail
S4U7A Rapid charging, direct current
S4U8A Rapid charging, alternating current
S4U9A Acoustic pedestrian protection
S4UAA Partially electric seat adjustment
S4UBA 3rd seat row
S4UCA Pedals "Steel Line"
S4UDA Sliding loading floor
S4UEA Rear bench seat, longitudinally adjust.
S4UFA Sport button
S4UGA Rear seat bench, 2-seat
S4UGA Rear passenger compartment, 2-seat
S4UHA Sport instruments
S4UKA 5-seater
S4ULA Flat load platform
S4UMA Massage function in rear seat backrests
S4UNA Thr.load opening w/integ.storagecomp.
S4UPA Adaptive securing system
S4URA Ambient interior light
S4USA 2-seater preparation
S4UTA Throughload opening w/int. transport bag
S4UUA Socket 230V
S4UVA Tables in rear cabin
S4UWA Socket 115V
S4UXA Tables in rear cabin
S4UYA Ski and snowboard bag
S4UZA Ski and snowboard bag
S4V9A MINI Excitement package
S4VAA MINI FAHRERLEBNISPAKET
S4VBA Centre rail, straight-through
S4WAA Int.trimstrips, alum.glacier-silber dk.
S4WBA Int.trim finishers, Alcantara anthracite
S4WCA Indi. Edelholz Esche Vulcano braun
S4WDA M Laptimer
S4XAA Dummy-SALAPA
S4XBA Dummy-SALAPA
S4XDA Dummy-SALAPA
S4XEA Dummy-SALAPA
S4XFA Dummy-SALAPA
S4XHA Dummy-SALAPA
S4XKA Dummy-SALAPA
S4XLA Dummy-SALAPA
S4XMA Dummy-SALAPA
S4XNA Dummy-SALAPA
S4YAA Colour Line 1
S4YBA Colour Line 2
S4YCA Colour Line 3
S4YDA Colour Line 4
S4YEA Colour Line 5
S4YFA Colour Line 6
S4YGA Colour Line 7
S4YHA Colour Line 8
S4YKA Colour Line 9
S4YLA Colour Line 10
S500A Headl.washer system/intensive cleaning
S502A Headlight cleaning system
S507A Park Distance Control (PDC), rear
S508A Park Distance Control (PDC)
S509A Laser distance measuring device (LAM)
S510A Headlight vertical aim control
S512A Omission of headlight vertical aim cntrl
S519A Additional headlight
S520A Fog lights
S521A Rain sensor
S522A Xenon Light
S523A Air conditioning for rear with cool box
S524A Driving-light control
S524A Adaptive Headlights
S525A Coolbox
S526A Deleted, air conditioning, rear
S527A Activated-carbon filter for air cond.
S527A Deleted, coolbox/bar compartment
S528A AUTOMATIC AIR FLOW CONTROL
S529A Microfilter
S530A Air conditioning
S531A All-season Roadster
S532A Air Fresher
S532A Air-conditioning system ZG
S533A Air conditioning, rear
S534A Automatic air conditioning
S536A Auxiliary heating
S537A Independent ventilation control
S538A Latent heat accumulator
S539A REMOTE CONTROL INDEP.HEATING
S539A Independent heating
S539A Independent A/C with remote control
S540A Cruise control
S541A Active cruise control
S542A Check Control
S543A Supercharger pressure gauge
S544A Individual equipment
S544A Dynamic cruise control
S544A Cruise control with brake function
S545A Revcounter,km/h speedo,analogue clock+EC
S545A Rev counter, km/h speedo, clock, EC
S545A Additional indicator f oil temperature
S546A Revolution counter
S547A Cockpit chrono package
S548A Kilometre speedo
S549A Radio clock
S549A Exklusiv-Uhr
S550A On-board computer
S551A On-board computer II with remote control
S552A Adaptive LED headlight
S553A On-board computer IV with remote control
S554A On-board computer V with remote control
S555A On-board computer V with remote control
S556A Outdoor temperature indicator
S560A Reading light in rear compartment
S562A Reading light
S563A Light package
S563A MAKE-UP MIRROR ILLUMINATED
S564A Interior light package
S570A Reinforced power supply
S571A Reinforced power supply
S575A Additional 12V sockets
S575A Socket, lugg. comp. incl. 2. batt.
S577A Preparation, hire car
S581A Taxi package
S582A Dummy-SALAPA
S583A BMW LA wheel Aero 90
S584A BMW LA wheel Styling 94
S585A BMW LA wheel/double spoke 71
S586A BMW LA wheel S-spoke
S587A BMW LA wheel/double spoke 116
S588A BMW LA wheel, star spoke 115
S589A BMW LA wheel, star spoke 122
S590A BMW LA wheel, star spoke 123
S591A BMW LA wheel, star spoke 124
S592A BMW LA wheel, radial spoke 118
S593A BMW LA wheel/double spoke 120
S594A BMW light alloy wheel,spider spoke 92
S595A BMW LA wheel, ellipsoid styling 121
S596A BMW light alloy wheel, V-spoke 126
S597A BMW LA wheel, star spoke 89
S5A1A LED Fog lights
S5A2A LED headlight
S5A4A LED headlight with cornering light
S5AAA Rear fog light
S5ABA Two-stage stoplamp discontinued
S5ACA High-beam assistant
S5ADA Lane departure warning
S5AEA High speed brake system
S5AFA SIDE UNDER MONITOR
S5AGA Lane change warning
S5AHA Decoding, dynamic brake light
S5AKA LED light elements
S5ALA Active Protection
S5AMA Second reversing light
S5APA Decoding anti-gl. high beam assistant
S5ARA Traffic jam assistant
S5ASA DRIVING ASSISTANT
S5ATA DRIVING ASSISTANT PLUS
S5DAA Passenger airbag deactivation
S5DBA Retractor 3-point seat belt, rear center
S5DCA Rear-seat headrests, folding
S5DDA LIFTING JACK
S5DFA Active cruise control+stop&go function
S5DKA Side view camera
S5DLA Surround View
S5DPA Park Assist
S5DRA Park Distance Control incl. Top View
S5DSA Emergency release, luggage compartment
S5DTA DYNAMIC TRACTION CONTROL
S5GAA Preparation alarm system
S5GBA Stolen Vehicle Tracking
S5GCA Preparation Flexible Car Use
S601A TV function
S602A On-board monitor withTV
S603A Fond screen
S604A Personal Travel Assistent
S605A Telematics preparation
S605A BTX/Telefon
S606A Navigation system Business
S606A Navigation system, radio
S607A Preparation, Teleservice
S607A Personal computer (PC)
S608A Travel Note System
S608A Navigation system with on-board monitor
S609A Navigation system Professional
S610A Head-up display
S611A BMW Night Vision
S612A BMW Assist
S613A Internet-based services
S614A Internet preparation
S615A Extended BMW Online Information
S616A BMW Online
S619A Emergency SOS call system
S620A Voice control
S621A Fully integrated mobile phone, Korea
S621A BMW Telefon Bedienhör.vorn C-Netz
S622A Second handset in rear for BMW telephone
S623A Car telephone D-network (GSM)
S624A Freisprechanlage für C-Netz
S624A Prepartation BMW Handy (Siemens)
S625A Preparation BMW Handy (Motorola)
S625A Telephone, D-Network mobile phone
S626A Telephone Siemens C2
S627A Telephone Siemens C3 handset, front
S627A Prepartation BMW Handy (Nokia)
S629A Car telephone (GSM) w card reader, front
S630A Car phone with cordless receiver
S631A Second receiver in the rear, cordless
S632A Vorber. Tel. C-Netz Bed. vo. u. hi.
S632A Preparation BMW Handy (Motorola)
S633A Preparation, mobile phone, Business
S633A Prep., telephone Siemens handset, front
S634A FITTINGS TELEPHONE INSTALL. C NET
S635A FITTINGS TELEPHONE INSTALL. D NET
S636A Prep.,tel.instn, mob.phone, D-Network
S637A Prep.,telephone Siemens C3 handset,front
S638A Car telephone Professional
S639A Preparation f mobile phone cpl. USA/CDN
S640A Preparation f tel.installation universal
S641A Prep. mobile phone USA Universal
S641A Prep. telephone installation BMW,covered
S642A Prep. telephone installation BMW, compl.
S642A Mobile, fully integrated US standard
S643A Prep. car tel. D-Network f. Axicon
S644A Preparation f mobile phone w Bluetooth
S645A BMW US Radio
S646A Preparation f teleph.installation Japan
S647A Becker Mexico Electronic II o.VF
S648A Radio BMW CD
S648A Radio Grundig 3883 RDS
S649A MC player
S650A CD player
S650A Radio BMW Reverse
S651A MD player
S651A Radio BMW Reverse RDS
S652A Radio Bavaria C II
S652A DVD player
S653A High Definition Radio
S653A Radio Bavaria C Reverse II
S653A BMW digital radio
S654A Radio Bavaria C III
S654A DAB tuner
S655A Radio Bavaria C business
S655A Satellite tuner
S656A Radio MINI MC
S656A Radio, BMW Reverse/MINI Wave
S656A Radio Bavaria C Professional
S657A Radio Bavaria C Reverse III
S657A Radio, BMW Business/MINI Boost
S658A Radio BMW Business CD RDS
S659A Radio Bavaria Electronic CD II
S659A Radio BMW Business CD
S660A Radio BMW Reverse (C42)
S661A Radio BMW Business (C43)
S662A Radio BMW Business CD
S663A Radio BMW Professional CD
S663A Radio BMW Professional (C44)
S664A Mobile phone, US standard
S664A Radio BMW Reverse RDS
S664A Mobile phone preparation
S665A Radio BMW Business RDS
S666A Radio BMW Business CD RDS
S667A Radio BMW Professional RDS
S667A Radio BMW Audio
S668A Radio BMW Reverse RDS
S669A Radio BMW Business RDS
S670A Radio BMW Professional RDS
S672A CD changer for 6 CDs
S673A Hifi system USA
S674A Hi-Fi system Harman Kardon
S675A Sound system
S675A Rear-cabin audio system
S676A HiFi speaker system
S677A HiFi system Professional DSP
S678A Headset system in rear compartment
S679A Subwoofer, HiFi system
S679A REAR WINDOW ANTENNA
S680A Radio antenna, manual
S681A Roof antenna
S682A Rear seat bench in fabric
S683A Telephone antenna D-network
S684A Rear-window telephone antenna D-Network
S685A Telephone antenna C-network
S686A Antenna-Diversity
S687A Radio preparation
S688A HARMAN/KARDON SURROUND SOUND SYSTEM
S689A Preparation for in-car video
S690A Cassette holder
S691A CD holder
S692A Preparation, BMW 6-CD changer I-bus
S693A Rear speaker system
S693A Preparation BMW satellite radio
S694A Provisions for BMW 6 CD changer
S695A Remote control radio
S695A MD-Changer
S696A DVD changer
S696A CD box
S697A Area- 1 for DVD
S697A Automatic telephone aerial
S698A Area- 2 for DVD
S699A Area- 3 for DVD
S6A1A Always Open Timer
S6AAA BMW TeleServices
S6ABA Control, Teleservices
S6ACA Intelligent emergency call
S6ADA MINI Head-Up Display
S6AEA TELESERVICES
S6AHA CONNECTED SERVICES
S6AKA Connected Drive Services
S6ALA BMW Live
S6AMA Real-Time Traffic Information
S6ANA Concierge Services
S6APA Remote Services
S6ARA Internet
S6F1A BANG&OLUFSEN HIGH END SOUND SYSTEM
S6F1A Bowers & Wilkins High End Sound System
S6F2A Bang&Olufsen High End Sound System Plus
S6FAA Provision for DVD system in rear
S6FBA Radio MINI Wave CD
S6FBA Radio MINI CD
S6FCA Radio MINI Boost CD
S6FDA MINI HiFi speaker system
S6FEA MASK New Zealand
S6FFA DVD-system in rear compartment
S6FGA Rear-compartment entertainment
S6FHA Rear-cabin entertainment, Professional
S6FKA Audio operation in rear cabin
S6FLA USB/audio interface
S6FMA DVD-system in rear compartment
S6FNA DVD changer, preparation
S6FPA Radio MINI Visual Boost
S6FRA Rear comp.entertain. Profess. w/ I-Drive
S6FSA TV function analogue
S6FSA HARMAN/KARDON SURROUND SYSTEM
S6FVA ONLINE ENTERTAINMENT
S6FWA Media
S6M1A Individual rear-compartment entertainm.
S6M2A Individ. rear-comp.online Infotainment
S6NAA Car telephone in rear compartment
S6NBA Rear-cabin telephone w/ cordless handset
S6NBA Rear compartment telephone
S6NCA Telephone with cordless keypad handset
S6NDA Hands-free system Bluetooth
S6NDA Hands-free kit, Bluetooth + USB/audio
S6NEA Mobile-phone prep.,Bluetooth + USB/audio
S6NEA Extend. mob. phone preparation Bluetooth
S6NFA Music interface for Smartphone
S6NFA Connection, MP3 player in mobile phone
S6NGA Dummy-SALAPA
S6NHA Hands-free system with USB interface
S6NKA Connection, Bluetooth and USB devices
S6NLA Connection Bluetooth + USB devices incl.
S6NMA MINI CONNECTED
S6NNA Hands-free kit
S6NRA Apps
S6NSA Comfort telephony w/ enhanced Smartphone
S6S1A Language version Turkish
S6S2A Language version Greek
S6S3A Language version Portuguese
S6S4A Language version Swedish
S6UAA Preparation for navigation system
S6UAA Preparation CCC
S6UBA Preparation of voice input system
S6UCA Preparation for TV function
S6UDA Language version, Russian
S6UEA Anti-theft protection for navigation DVD
S6UFA Preparation for navigation system
S6UGA MINI navigation system
S6UHA Traffic Information
S6UKA Night Vision with person recognition
S6ULA Navigation system, portable
S6UMA MINI navigation system
S6UNA Navigation
S6UPA Navigation Plus
S6UZA Map material for navigation system
S6VAA CIC assignment
S6VBA Control Infotainment
S6VBA CCC assignment
S6VCA Control, Combox
S6WAA Instrument panel with extended scope
S6WBA Multifunctional instrument display
2 część VO FA
S700A Area- 4 for DVD
S701A Area- 5 for DVD
S702A Area- 6 for DVD
S704A M Sports suspension
S705A M sports suspension II
S708A M sports steering wheel leather
S709A M sports steering wheel leather
S710A M sports steering wheel, multifunction
S710A M leather steering wheel
S711A M Sports seats
S712A M sports seat
S713A Off-road pack
S713A Rear spoiler
S715A M Aerodynamics package
S716A Aerodynamics package
S717A Comfort Edition
S718A Exclusive Edition
S719A Sports Edition
S720A Edition ZD
S720A Sports Limited Edition
S721A Edition ZB
S722A Lifestyle Edition
S722A Edition ZF
S723A Exclusive Edition
S724A Edition ZH
S724A Sports Edition
S725A Edition ZE
S725A Basic Package
S726A Edition ZN
S727A Edition ZO
S728A Edition ZV
S729A Edition, importers
S731A Additional edition scope
S732A Interior mouldings, carbon fibre Pyrit
S733A Interior mouldings, wood, Yacht-Line
S736A 2nd radio remote control key
S737A Interior mouldings, Alu Shadow, brushed
S738A Fine wood trim
S739A Fine wood trim
S750A TV/Video (PAL)
S751A TV/Video NTSC
S752A Individual audio system
S753A Young-Line
S754A M Rear spoiler
S755A FOLDING SLIDING ROOF
S756A BMW LA wheel, round spoke, individual
S757A Individual sound pack
S759A Familiy Kit
S760A High gloss shadow line
S761A Individual sunshade glazing
S763A Individual series Japan
S764A High Line equipment
S766A Individual series Japan
S767A Individual, Sport
S767A Individual series "Avus"
S767A Performance package
S767A 330i -Sports version
S768A Individual series "Clubsport"
S768A Individuals. 95 Atlanta Olymp.Ed.
S769A Individual series 96 Japan
S770A Individual series 96 Classic
S770A Interior trim trips, Alu Silver Cube
S771A Interior trim strips, Titan Shadow
S771A Sports Edition
S772A Interior strip strips, Alu Black Cube
S772A Luxury equipment
S773A Fine wood trim
S774A Fine wood trim
S775A Headlining anthracite
S776A Roofliner Alcantara anthracite
S776A Chrom equipment
S777A Trunk trim panel Alcantara
S778A Individual BMW identification
S778A Entrance strips "BMW Individual"
S779A Carbon Line
S780A BMW LA wheel, M parallel spoke
S781A BMW LA wheel M Kontur
S782A BMW LA wheel, M system II
S782A Suspension system Nürburgring
S783A M DOUBLE-SPOKE,FORGED
S784A M Outside mirror
S785A White direction indicator lights
S786A Measures, 17" wheels
S787A BMW alloy wheel, M double spoke 135
S787A BMW LA wheel, Individual
S788A BMW LA wheel, Individual
S789A BMW LA wheel, Individual
S790A extra tank
S790A BMW alloy wheel, M double spoke 97
S791A M Technic Servotronic
S791A Coolbox
S792A BMW LA wheel M 19" forged
S793A Sequential M Gearbox Drivelogic
S795A BMW Composite wheel, M double spoke 71
S798A Convertible top, magenta (individual)
S7ARA Aerodynamics package
S7BAA MINI Repair Inclusive
S7BBA MINI Repair Inclusive
S7BCA MINI Repair Inclusive
S7BDA MINI Repair Inclusive
S7BEA MINI Repair Inclusive
S7BFA MINI Repair Inclusive
S7BGA MINI Repair Inclusive
S7BHA including MINI service
S7BKA including MINI service
S7CAA MINI Repair Inclusive
S7CBA MINI Repair Inclusive
S7CCA MINI Repair Inclusive
S7CDA MINI Repair Inclusive
S7CEA MINI Repair Inclusive
S7CFA MINI Repair Inclusive
S7CGA Service
S7CHA MINI Repair Inclusive
S7CKA Service
S7CLA MINI Repair Inclusive
S7D1A Service
S7D2A BMW Service
S7D3A BMW Service
S7D4A BMW Service + Repair Inclusive
S7D5A BMW Service
S7D6A BMW Service inclusive
S7D7A BMW Service
S7D8A BMW Service
S7DAA BMW Service inclusive
S7DBA BMW Service inclusive
S7DCA BMW Service
S7DDA BMW Service inclusive
S7DEA BMW Service inclusive
S7DFA BMW Service
S7DGA BMW Service inclusive
S7DHA BMW Service
S7DKA BMW Service
S7DLA BMW Service inclusive
S7DMA BMW Service inclusive
S7DNA BMW Service inclusive
S7DPA BMW Service inclusive
S7DRA Service
S7DSA BMW Service inclusive
S7DTA BMW Service inclusive
S7DUA BMW Service inclusive
S7DVA Service
S7DWA Service
S7DXA BMW Service inclusive
S7DYA BMW Service inclusive
S7DZA BMW Service inclusive
S7FAA including MINI service
S7FBA including MINI service and repair
S7FCA including MINI service and repair
S7FDA including MINI service
S7FEA including MINI service
S7FFA including MINI service
S7FGA MINI Basic Service Inclusive
S7FHA BMW Service inclusive
S7FHA MINI Basic Service Inclusive
S7FKA including MINI service
S7FLA including MINI service
S7FMA including MINI service
S7M0A BMW Individual composition I
S7M1A BMW Individual composition II
S7M5A BMW individual exterior kit
S7M5A M exterior equipment
S7MAA Competition package
S7MEA M Drivers Package
S7N1A BMW Service inclusive
S7N2A BMW Service inclusive
S7N3A BMW Service
S7N4A BMW Service inclusive
S7N5A BMW Service inclusive
S7N6A BMW Service
S7N7A BMW Service inclusive
S7N8A BMW Service inclusive
S7N9A BMW Service
S7NAA BMW Service inclusive
S7NBA BMW Service
S7NCA BMW Service inclusive
S7NDA BMW Service
S7NEA BMW Service inclusive
S7NFA BMW Service
S7NGA BMW Service inclusive
S7NHA BMW Service inclusive
S7NKA BMW Service inclusive
S7NLA BMW Service
S7NMA BMW Service inclusive
S7NNA BMW Service
S7NPA MINI Repair Inclusive
S7NRA MINI Repair Inclusive
S7NSA BMW Service + Repair Inclusive
S7NTA BMW Service inclusive
S7NUA BMW Service inclusive
S7NVA BMW Service
S7NWA BMW Service inclusive
S7NXA BMW Service inclusive
S7NYA BMW Service inclusive
S7NZA BMW Service
S7P1A including MINI service
S7P2A including MINI service
S7P3A including MINI service
S7P4A including MINI service
S7P5A MINI Basic Service Inclusive
S7P6A including MINI service
S7P7A including MINI service
S7P8A including MINI service
S7P9A including MINI service
S7PAA including MINI service
S7PBA including MINI service and repair
S7PCA MINI Basic Service Inclusive
S7PDA MINI Basic Service Inclusive
S7PEA including MINI service
S7PFA including MINI service and repair
S7PGA MINI Basic Service Inclusive
S7PHA including MINI service
S7PKA including MINI service and repair
S7PLA MINI Basic Service Inclusive
S7PMA including MINI service
S7PNA including MINI service and repair
S7PPA MINI Basic Service Inclusive
S7PRA including MINI service
S7PSA including MINI service and repair
S7PTA MINI Basic Service Inclusive
S7PUA including MINI service
S7PVA including MINI service and repair
S7PWA MINI Basic Service Inclusive
S7PXA including MINI service
S7PYA including MINI service and repair
S7SNA Navi Business/mobile-ph.prep. Bluetooth
S7SPA Navi Professional/m.-ph.prep. Bluetooth
S7T1A BMW Service Inclusive 5 years/120,000 km
S7T2A BMW Service Inclusive 5 years/120,000 km
S7T3A BMW Service Inclusive 5 years/120,000 km
S7T4A BMW Service Inclusive 5 years/120,000 km
S7T5A BMW Service inclusive
S7T6A BMW Service inclusive
S7T7A BMW Service
S7T8A BMW Service
S7TAA Service
S7TBA Service
S7TCA Service
S7TDA Service
S7TEA Service
S7TFA Service
S7TGA Service
S7THA Service
S7TKA Service
S7TLA Service
S7TMA Service
S7TNA Service
S7TPA Service
S7TRA Service
S7TSA Service
S7TTA Service
S7TUA Service
S7TVA Service
S7TWA Service
S7TXA Service
S7TYA Service
S7TZA Service
S7U9A Omission of BMW Service Inclusive
S7UAA BMW Service inclusive
S7UBA BMW Service
S7UCA BMW Service
S7UDA BMW Service inclusive
S7UEA BMW Service
S7UFA BMW Service inclusive
S7UGA BMW Service
S7UHA BMW Service inclusive
S7UKA BMW Service
S7XAA M leather st.wheel+shiftpaddle+multif.
S800A Exhaust system, complete, countries
S803A Omission of third brake light
S805A Activated Charcoal Filter
S806A Third stoplamp
S815A Poor road package
S817A Engine design RON 91
S818A Battery master switch
S823A Hot-climate version
S825A Radio control Oceania
S826A Fahrwerk in Exportabstimmung
S828A Bumper, country variant
S829A Preparation for convertible conversion
S831A Omission of radio
S832A Battery in luggage compartment
S834A Deleted, 330d France
S834A Omission of cassette holder
S835A US tourist version
S836A Omission of Bavaria CD 6 Selection
S837A Omission of navigation system
S837A Omission of HiFi speaker system
S839A Pseudo control, omission-optional extra
S840A High speed synchronisation
S840A Omission of remote control for radio
S841A Optional extra pack, pseudo code no.
S842A Cold-climate version
S843A Power reduction
S845A Acoustic fasten seat belt reminder
S847A Preparation for safety vehicle
S847A Auxiliary battery f. C-Network telephone
S848A Expanded wiring harness
S849A Deleted: automatic emergency call
S849A Tail light, country-specific
S850A Additional Export tank filling
S851A Language version German
S852A Language version Japanese
S853A Language version, English
S854A Language version, French
S855A Language version, Italian
S856A Language version, Spanish
S857A Preparation autom.air conditioning
S858A Low compression engine
S859A TV decoding
S859A Adaptation/control IHKA
S860A Additional turn indicator lamp
S861A Data record without EOBD
S862A Fabric seat, front, for taxi pack
S862A Definition of exhaust emis.standard/COC
S863A Dealer List Europe
S864A Dealer List Overseas
S865A Stowage tables / footrests in rear
S866A Language version, trad. Chinese
S866A Language version, Chinese simpl.
S866A Service Card Germany
S867A Language version Korean
S868A Radio preparation for ZF/ZI
S868A Language version, Dutch
S869A Radio preparation for ZG/ZZ
S869A Language version Switzerland
S870A Equipment "Salt"
S871A Equipment "Pepper"
S872A Equipment "Chili"
S872A Preparation f teleph.installation Japan
S873A Dummy-SALAPA
S874A Radio frequency 434 MHz
S875A Infrared remote control
S876A Radio frequency 315 MHz
S877A Omission of non-combined operation
S878A Thermal glazing without anti-glare strip
S879A On-board literature, German
S880A On-board literature, English
S881A On-board literature, French
S882A Gutschrift für Erstausstattung
S883A On-board literature, Spanish
S884A Bordliteratur italienisch
S885A On-board literature, Swedish
S886A On-board literature, Dutch
S887A On-board literature, Arabic
S888A On-board literature, Danish
S889A On-board literature, Portuguese
S889A Operating instructions, Finish
S890A On-board literature, Japanese
S891A On-board literature, Russian
S892A Owners Handbook Chines.Trad.
S892A On-board literature, Chinese, simplified
S895A Additional fan
S896A Daytime driving lights
S897A Continuous tone for anti-theft alarm
S898A CKD version
S899A Optical signalling for anti-theft alarm
S8A1A Language version, Polish
S8A2A Language version, Hungarian
S8A3A Language version, Arabic
S8A4A Language version Czech
S8A5A Language version Slovak
S8A6A Language version Slovene
S8A7A Language version Norwegian
S8A8A Language version Danish
S8A9A Language version Finnish
S8ABA China joint venture
S8ACA Dummy-SALAPA
S8ADA Alpina Roadster S
S8AEA On-board literature, Greek
S8AFA On-board literature, Korean
S8AGA Chaffeur Handbook in English
S8AHA On-board literature, Turkish
S8AKA On-board literature, Slovak
S8ALA On-board literature, Czech
S8AMA Anpassung für minderen Kraftstoff
S8ARA On-board literature, Romanian
S8ASA On-board literature, Chinese,traditional
S8ATA On-board literature, Polish
S8AUA On-board literature, Hungarian
S8AVA On-board literature, Slovene
S8AWA On-board literature, Norwegian
S8AXA On-board literature, Finnish
S8EBA Steuerung Einzelbetriebserlaubnis
S8HAA Dummy-SALAPA
S8KAA Dummy-SALAPA
S8KBA Dummy-SALAPA
S8KCA Dummy-SALAPA
S8KEA Dummy-SALAPA
S8KKA Dummy-SALAPA
S8KLA Oil service interval 15,000 km/12 months
S8KMA Oil serv. interval 12,000 km/12 months
S8KPA Dummy-SALAPA
S8L1A Country control
S8LBA Country control
S8LFA Country control
S8LHA Country control
S8LMA Country control
S8LRA Country control, Russia
S8LSA Country control
S8LTA Country control
S8R9A Dummy-SALAPA
S8REA Summer and winter tyres
S8S1A Decoding, daytime running lamps
S8S2A Coding, alarm signal
S8S3A Automatic locking during starting
S8S4A Decoding, variable light distribution
S8S5A Deleted, Diesel particulate filter
S8S6A Prespecified for export
S8S7A Vehicle without TV function
S8S8A Country-specific navigation control
S8S9A Dummy-SALAPA
S8SAA Navigation access request,country-spec.
S8SBA Telematics access request,country-spec.
S8SCA Telematics access request,country-spec.
S8SDA Underride protection, national variants
S8SEA 4-seats version
S8SFA Special edition "Sport"
S8SGA Special edition "Exclusive"
S8SHA Thailand engine
S8SKA Deleted, Int. line graphit metallic
S8SLA Trailer coupling preparation
S8SMA Car ident. number visible from outside
S8SPA Control unit COP
S8SPA Control unit CO2
S8SRA Special edition "Lifestyle"
S8SSA Special edition "Special control unit"
S8STA Maintenance interval encoding, stage 3
S8SUA Car ident. number Security
S8SVA Hands-free kit
S8SWA Transport protection foil
S8SXA Prov.assignm.for Telematic/Online serv.
S8SYA Dummy-SALAPA
S8SZA Cornering lights decoding
S8T1A ROBI-Optio-s
S8T2A ROBI- extended
S8TAA Radio stage, M Drive
S8TBA Acoustic kit
S8TCA Dummy-SALAPA
S8TDA Decoding Speed Limit Info
S8TEA Frequency variant RDC
S8TFA Active pedestrian protection
S8TGA Thiefproofing device
S8THA SPEED LIMIT INFO
S8TKA Passive pedestrian protection
S8TLA Dummy-SALAPA
S8TMA Dummy-SALAPA
S8TNA Dummy-SALAPA
S8TPA Control N1 approval as comm. vehicle
S8TRA Decoding additional functions
S8V1A Label
S8V2A Label
S8V3A Label
S8V4A Label
S8V5A Label
S8V6A Label
S8V7A Label
S8WAA Dummy-SALAPA
S8WBA Dummy-SALAPA
S8Y1A Dummy-SALAPA
S8Y2A Dummy-SALAPA
S8Y3A Dummy-SALAPA
S8Y4A Dummy-SALAPA
S900A Electronic immobilizer
S901A General special inspection
S902A Special inspection press vehicles
S903A Fotofahrzeug
S904A inspect.f type approval vehicles
S905A inspect.f demonstration vehicles
S906A Fotofahrzeug
S907A James Bond edition
S908A Dummy-SALAPA
S909A Dummy-SALAPA
S910A Development veh. w/out handover insp.
S911A Development veh. w/ handover insp.
S915A Omission of outer-skin preservation
S916A Development veh. w/out preservation
S917A Overseas preservation
S918A Alpina B3, intern
S919A Doors, aluminium
S920A Alpina without registration document
S921A Alpina intern
S922A Alpina Engine-oil cooler
S923A Deleted, Titan-Line
S923A Kidney, narrow
S924A Mirror, glass, level, front passenger
S924A Collapsible spare tyre
S925A Dispatch protection pack
S926A Spare wheel
S927A All-season tyres
S927A Tourist handling
S928A Tyre control
S929A Dummy-SALAPA
S930A Dummy-SALAPA
S931A Winter instead of summer tyres ex-fact.
S932A Dummy-SALAPA
S933A Dummy-SALAPA
S934A Dummy-SALAPA
S936A BMW Handy b. Ausliefer. anfordern
S936A Light alloy wheel rims "SA"
S937A Dummy-SALAPA
S938A Individual series
S938A Winter package
S939A Dummy-SALAPA
S940A special equipment BMW Individual
S941A Dummy-SALAPA
S942A Cancellation of special request
S943A Dummy-SALAPA
S944A Subsequent conversion by individual
S945A Dummy-SALAPA
S946A Dummy-SALAPA
S947A Dummy-SALAPA
S954A Dummy-SALAPA
S960A Steering detent
S961A SPECIAL MOTOR
S962A Deleted, licence plate support front
S962A Engine characteristic curves
S963A Thailand engine 2.4
S964A Navi DVD to be requested at shipping
S964A Pseudocontrol f.countryversion/opt.extra
S965A Additional opt. equipm. (front)+25Kg
S966A Additional opt. equipm. (front)+50Kg
S967A Additional opt. equipm. (rear)+25Kg
S968A Additional opt. equipm. (rear)+50Kg
S969A Navi DVD to be requested at shipping
S969A Additional opt. equipm. (rear)+75Kg
S970A Business Package
S976A Backrest, reinforced
S978A Innovation package
S979A Business package II
S979A Value Package
S980A Exclusive package
S982A Hardtop
S983A Dummy-SALAPA
S984A Coding for none EU countries
S984A Maintenance interval encoding
S985A US radio completion set
S986A Dummy-SALAPA
S987A Dummy-SALAPA
S988A Omission of radio
S988A Maintenance interval encoding
S989A Dummy-SALAPA
S990A Dummy-SALAPA
S991A Dummy-SALAPA
S992A Control of number-plate attachment
S993A model year code in VIN
S994A Dummy-SALAPA
S995A Dummy-SALAPA
S996A HEA ALT
S997A Dummy-SALAPA
S998A Dummy-SALAPA
S999A Job control "HEA"
S9AAA Outer skin protection
S9ABA Outer skin protection, elimination
S9ACA Dummy-SALAPA
S9ADA ABSCHLIESSBARE TARNPLANE
S9AEA Dummy-SALAPA
S9AGA Dummy-SALAPA
S9AWA Delivery BMW Welt
S9C1A CKD installation Egypt
S9C2A CKD installation India
S9C3A CKD installation Indonesia
S9C4A CKD installation Malaysia
S9C5A CKD installation Russia
S9C6A CKD installation Thailand
S9KAA Dummy-SALAPA
S9KBA Dummy-SALAPA
S9KCA Dummy-SALAPA
S9KDA Dummy-SALAPA
S9KEA Dummy-SALAPA
S9KFA Dummy-SALAPA
S9KGA Dummy-SALAPA
S9KHA Dummy-SALAPA
S9KKA Dummy-SALAPA
S9KLA Dummy-SALAPA
S9MRA M Sport manufacture
S9S1A SZ M PERFOMANCE PAKET S
S9S2A SZ M PERFOMANCE PAKET M
S9S3A SZ M PERFOMANCE PAKET L
S9S4A SZ M PERFOMANCE PAKET XL
S9SAA SZ STANDHEIZUNG
S9W1A ASD Active Sound Design
S9WRA Winter wheels
S9XAA ALPINA Package
SDY0A Dummy-SALAPA
SDY1A Dummy-SALAPA
SDY2A Dummy-SALAPA
SDY3A Dummy-SALAPA
SDY4A Dummy-SALAPA
SDY5A Dummy-SALAPA
SDY6A Dummy-SALAPA
SDY7A Dummy-SALAPA
SDY8A Dummy-SALAPA
SDY9A Dummy-SALAPA
SRA1A Picnic table
SRA2A Make-up mirror, rear cabin
SRA3A REAR CAN HOLDER
SRA4A Hight-qual. design. analog clock, front
SRA5A Floor mats, lambswool
SRA6A Floor mats, front and rear
SRA7A Outside mirror with auto dip
SRA8A Rear compartment foot rest
SRA9A Warning triangle
SRAAA Interior door handle rear
SRABA Briefcase integrated
SRACA Humidor
SRADA Umbrellas in vehicle
SRAEA Extended leather trim
SRAFA Polished grille
SRAGA Clothes bag for trunk
SRAHA Roller cover for luggage compartment
SRAKA Cover, dashboard, veneered
SRALA Dashboard, covered with leather
SRAMA Boot trim panel in interior-color
SRAPA Steering wheel spokes , wooden
SRARA Picnic tables, veneered, both sides
SRASA Drinks cabinet for single seats
SRATA FULL METAL FACIA
SRAUA RR logos on head restraints
SRAVA RR contrast logos on head restraints
SRAWA Drinks cabinet for seat bench, rear
SRAXA Contrast welt
SRAYA Preparation Stolen Vehicle Tracking
SRB1A Steering-wheel spokes, metallised
SRB2A Liquidmetal Bonnet Windscreen
SRB3A COLOURED GRILLE SURROUND
SRB6A ARMORED LIMOUSINE
SRC1A Stainless steel pack
SRC2A Teak decking
SRC3A Interior trim panels, veneered
SRC4A Chrome and paint instead of wood
SRC5A Mirror-finish stainless-steel pack
SRC6A Trim strip, side frame, chrome look
SRC7A Wood trim
SRC8A Natural Grain Leather
SRD1A Two-colour paint, side
SRD2A Two-colour paint, continuous
SRD3A Trim line
SRD3A Ornamental line, single
SRD4A Ornamental line, double
SRD5A Spirit of Ecstacy individual
SRD6A blau chrom
SRD7A Contrast colour, outer
SRD8A Interior Mono Package
SRD9A Linear Colour Package
SRDAA Extended wheelbase
SRDBA BESPOKE LACKAPPLIKATIONEN
SRDCA Sun visor
SRE0A RR LA wheel 21 fully polished 417
SRE1A RR LA wheel 21 partly polished 422
SRE3A Seat heating, front and rear
SRE4A Universal remote in interior mirror
SRE5A Independent heating
SRE7A Charging socket
SRE8A Reinforced power supply
SRE9A Spirit of Ecstacy electr. retractable
SREAA Curtains in the rear
SREBA automatic trunk lid mechanism
SRECA Air conditioning, rear
SREDA Electric curtain, rear window
SREFA Sunshade rear window, oyster
SREGA Sunshade rear window, black
SREHA Sun protection, rear pass. comp., oyster
SREKA Sun protection, rear pass. comp., black
SRELA Camera System
SREMA Cooling compartment for single seats
SRENA Cooling compartment for seat bench, rear
SREPA Rear compartment foot rest
SRERA Rear-cabin air conditioning
SRESA SEAT PIPING
SRETA Rear Seat Heating
SREWA Extended wheelbase
SREXA RR LA cast wheel styling 614 painted
SREYA RR LA forged wheel styling 615 painted
SRF0A RR forgedwheel styling 615 fullypolished
SRF1A RR LA wheel chrome-plated
SRF2A Hub cap, chrome-plated
SRF3A Wheel centre cap with RR symbol
SRF4A RR LA wheel Sport Style
SRF5A RR LA wheel Sport Style chrome-plated
SRF6A Hub cover, Sports style chrome
SRF7A Dummy-SALAPA
SRF8A All-season tyres
SRF9A Centre cap, stand. wheel, in car colour
SRFAA RR LA wheel 274
SRFBA RR LA wheel 274, chrome-plated
SRFCA RR LA wheel Seven Spokes 21"
SRFDA RR LA wheel Seven Spokes 21" polished
SRFEA RR Forged Alloy Wheels 420
SRFFA RR LA wheel 273
SRFGA RR LA cast wheel styling 462 painted
SRFHA RR LA forged wheel styling 593 painted
SRFKA RR LA forged wheel styl.593 chrome-pltd.
SRFLA RR forged wheel 420 partly polished
SRFMA RR forged wheel 420 fully polished
SRFNA RR LA forged wheel styling 593
SRFPA RR LA wheel Seven Spokes 21" polished
SRFRA Centre cap, stand. wheel, in car colour
SRFTA RR LA wheel Ten Spoke
SRFUA RR LA wheel Forged Part Polished Ten Spk
SRFVA RR Forged Eleven Spoke Alloy Wheel
SRFWA RR Forged Fully Polished 11 Spoke Alloy
SRFXA RR LA forged wheel styling 602
SRFYA RR LA forged wheel styling 602
SRG1A Privacy glazing
SRG1A RR LA wheel, star design
SRG2A Privacy glazing, rear window only
SRG2A RR LA wheel Star 21" polished
SRG3A Privacy glazing with clear windscreen
SRG4A IR protection glazing f side window
SRG5A Sunshade glazing, rear
SRG7A Roofliner, Cashmere, black
SRG8A Leather Headlining
SRG9A Extended leather trim
SRGGA Roofliner Cashmere dark grey
SRGLA RR LA forged wheel styling 602 polished
SRGMA RR LA cast wheel styl. 462 chrome-plated
SRGNA RR LA cast wheel styling 462 bicolor
SRGPA RR LA wheel Star 21" polished
SRH1A Real wood version, mahogany crossbanding
SRH2A Real wood version, mahogany crossbanding
SRH3A Real wood version, Walnut Burr
SRH4A Superior wood trim, varieg. oak crossb.
SRH5A High-grade wood trim, variegated oak
SRH6A Real wood version, elm cluster crossb.
SRH7A High-grade wood trim, elm Cluster
SRH8A Real wood vers. birds eye maple, crossb
SRH9A Real wood version, birds eye maple.
SRHAA Fine wood trim Black Tulip
SRHBA High-grade wood trim, jacaranda
SRHCA High-grade wood trim, variegated ash
SRHDA Fine woodgrain, Piano lacquer, black
SRHEA Wood interior trim "Brown Oak"
SRHFA Wood interior trim "Chestnut Burr"
SRHGA Fine woodgrain version, Olive grain
SRHHA Sup. wood trim, Flare mahogany crossb.
SRHKA Sup.wood trim, Santos palisander crossb.
SRHMA Superior wood trim, varieg. ash crossb.
SRHNA Wood interior trim "Zebrano"
SRHPA Wood Interior Malabar
SRHPA Wood Interior Santos Palisander
SRHRA Dark Wenge Straight Grain
SRK1A Navi system with TV/on-board monitor
SRK2A Rolls Royce Assist
SRK5A Voice input system
SRL1A Padded steering wheel
SRM1A Visible engine number
SRM2A Top Speed US/CDN
SRM3A Exhaust tailpipes, visible
SRM6A Driver´s Package
SRMKA East Asia Edition
SRP1A Business package I
SRP2A Business package II
SRPDA IPOD INTEGRATION
SRPEA #Rolls-Royce Bespoke Audio
SRPPA Partition Preparation
SRR5A CD changer, 6-fold
SRR6A DVD changer, for 6 DVDs
SRR7A Navigation DVD North America
SRR8A Navi DVD Europe
SRR9A Navigation DVD Arabian Gulf
SRRAA Navi DVD Japan
SRRBA Navi DVD Singapore and Malaysia
SRRDA Navi DVD China/Hongkong
SRREA Navi DVD Korea
SRRSA Starlight roofliner
SRS1A Two individual seats, rear
SRS2A Lift-up-and-slide-back sunroof, front
SRS3A Theatre Configuration Lounge Seat
SRS4A Front sunroof discontinued
SRS5A Preparation, insert, glovebox
SRS6A EXTENDED STORAGE OPTION
SRS7A FESTES GLASDACH
SRSCA Starlight roofliner "bamboo"
SRSDA Starlight roofliner "dark grey"
SRT1A Car phone with cordless receiver
SRT3A Preparation f mobile phone cpl. USA/CDN
SRT4A Second receiver in the rear, cordless
SRT5A Complete preparation, mobile phone
SRT6A Integral telephone w cordless handset
SRT7A Prep., mob. phone, Bluetooth interface
SRV1A Softtop, black
SRV2A Softtop dark beige
SRV3A Folding top, blue
SRV4A Folding top, red
SRV5A Folding top, green
SRV6A Convertible top, metallic appearance
SRVXA BESPOKE HOOD
SRXLA Extended boot
SRZ1A Dummy-SALAPA
SV01A Dummy-SALAPA
SV02A Dummy-SALAPA
SV03A Dummy-SALAPA
SV04A Dummy-SALAPA
SV05A Dummy-SALAPA
SV06A Dummy-SALAPA
SV07A Dummy-SALAPA
SV08A Dummy-SALAPA
SV09A Dummy-SALAPA
SV0AA Dummy-SALAPA
SV0BA Dummy-SALAPA
SV0CA Dummy-SALAPA
SV0DA Dummy-SALAPA
SV0EA Dummy-SALAPA
SV0FA Dummy-SALAPA
SV0GA Dummy-SALAPA
SV0HA Dummy-SALAPA
SV0IA Dummy-SALAPA
SV0JA Dummy-SALAPA
SV0KA Dummy-SALAPA
SV0LA Dummy-SALAPA
SV0MA Dummy-SALAPA
SV0NA Dummy-SALAPA
SV0OA Dummy-SALAPA
SV0PA Dummy-SALAPA
SV0QA Dummy-SALAPA
SV0RA Dummy-SALAPA
SV0SA Dummy-SALAPA
SV0TA Dummy-SALAPA
SV0UA Dummy-SALAPA
SV0VA Dummy-SALAPA
SV0WA Dummy-SALAPA
SV0XA Dummy-SALAPA
SV0YA Dummy-SALAPA
SV0ZA Dummy-SALAPA
SV10A Dummy-SALAPA
SV11A Dummy-SALAPA
SV12A Dummy-SALAPA
SV13A Dummy-SALAPA
SV14A Dummy-SALAPA
SV15A Dummy-SALAPA
SV16A Dummy-SALAPA
SV17A Dummy-SALAPA
SV18A Dummy-SALAPA
SV19A Dummy-SALAPA
SV1AA Dummy-SALAPA
SV1BA Dummy-SALAPA
SV1CA Dummy-SALAPA
SV1DA Dummy-SALAPA
SV1EA Discontinuation, roof rails
SV1FA Discontinuation, rear seat bench
SV1GA Dummy-SALAPA
SV1HA Dummy-SALAPA
SV1IA Dummy-SALAPA
SV1JA Dummy-SALAPA
SV1KA Dummy-SALAPA
SV1LA Dummy-SALAPA
SV1MA Dummy-SALAPA
SV1NA Dummy-SALAPA
SV1OA Dummy-SALAPA
SV1PA Dummy-SALAPA
SV1QA Dummy-SALAPA
SV1RA Dummy-SALAPA
SV1SA Dummy-SALAPA
SV1TA Dummy-SALAPA
SV1UA Dummy-SALAPA
SV1VA Dummy-SALAPA
SV1WA Dummy-SALAPA
SV1YA Dummy-SALAPA
SV1ZA Dummy-SALAPA
SV20A Dummy-SALAPA
SV21A Dummy-SALAPA
SV22A Dummy-SALAPA
SV23A Dummy-SALAPA
SV24A Dummy-SALAPA
SV25A Dummy-SALAPA
SV26A Dummy-SALAPA
SV27A Dummy-SALAPA
SV28A Dummy-SALAPA
SV29A Dummy-SALAPA
SV2AA Dummy-SALAPA
SV2BA Dummy-SALAPA
SV2CA Dummy-SALAPA
SV2DA Dummy-SALAPA
SV2EA Dummy-SALAPA
SV2FA Dummy-SALAPA
SV2GA Dummy-SALAPA
SV2HA Dummy-SALAPA
SV2IA Dummy-SALAPA
SV2JA Dummy-SALAPA
SV2KA Dummy-SALAPA
SV2LA Dummy-SALAPA
SV2MA Dummy-SALAPA
SV2NA Dummy-SALAPA
SV2PA Dummy-SALAPA
SV2QA Dummy-SALAPA
SV2RA Dummy-SALAPA
SV2SA Dummy-SALAPA
SV2TA Dummy-SALAPA
SV2UA Dummy-SALAPA
SV2VA Dummy-SALAPA
SV2WA Dummy-SALAPA
SV2XA Dummy-SALAPA
SV2YA Dummy-SALAPA
SV30A Soft-Close-Automatic
SV31A Dummy-SALAPA
SV32A Dummy-SALAPA
SV33A Dummy-SALAPA
SV34A Dummy-SALAPA
SV35A Dummy-SALAPA
SV36A Dummy-SALAPA
SV37A Dummy-SALAPA
SV38A Dummy-SALAPA
SV39A Dummy-SALAPA
SV3AA Dummy-SALAPA
SV3BA Dummy-SALAPA
SV3CA Dummy-SALAPA
SV3DA Dummy-SALAPA
SV3EA Dummy-SALAPA
SV3FA Dummy-SALAPA
SV3GA Dummy-SALAPA
SV40A Dummy-SALAPA
SV41A Dummy-SALAPA
SV42A Dummy-SALAPA
SV43A Dummy-SALAPA
SV44A Dummy-SALAPA
SV45A Dummy-SALAPA
SV46A Dummy-SALAPA
SV47A Dummy-SALAPA
SV48A Dummy-SALAPA
SV49A Dummy-SALAPA
SV4AA Dummy-SALAPA
SV4BA Dummy-SALAPA
SV4CA Dummy-SALAPA
SV4DA Dummy-SALAPA
SV50A Dummy-SALAPA
SV51A Dummy-SALAPA
SV52A Dummy-SALAPA
SV53A Dummy-SALAPA
SV54A Dummy-SALAPA
SV55A Dummy-SALAPA
SV56A Dummy-SALAPA
SV57A Dummy-SALAPA
SV58A Dummy-SALAPA
SV59A Dummy-SALAPA
SV5AA Dummy-SALAPA
SV5BA Dummy-SALAPA
SV5CA Dummy-SALAPA
SV5DA Dummy-SALAPA
SV60A Deleted DSC module
SV61A Trailer coupling
SV62A Airbag inert
SV62A Antenna
SV63A Engine emergency OFF switch
SV63A Airbag deactivation
SV64A Fire extinguisher + emergency hammer
SV64A Emission tank
SV65A Dummy-SALAPA
SV66A Dummy-SALAPA
SV67A Dummy-SALAPA
SV68A Dummy-SALAPA
SV69A Mirror attachment function
SV6AA Dummy-SALAPA
SV6BA Dummy-SALAPA
SV6CA Dummy-SALAPA
SV6DA Dummy-SALAPA
SV6HA Dummy-SALAPA
SV6IA Dummy-SALAPA
SV70A Dummy-SALAPA
SV71A Container, headlight washer sys, front
SV72A Rear window washer container, front
SV73A Storage tray in instrument panel
SV74A Dummy-SALAPA
SV75A Dummy-SALAPA
SV76A Trailer coupling
SV77A Up-rated fuel pump
SV78A ABS sensor, variant 1
SV79A ABS sensor, variant 2
SV7AA Dummy-SALAPA
SV7BA Dummy-SALAPA
SV7CA Dummy-SALAPA
SV7DA Dummy-SALAPA
SV7EA Dummy-SALAPA
SV7FA Dummy-SALAPA
SV7GA Dummy-SALAPA
SV7HA Dummy-SALAPA
SV7IA Dummy-SALAPA
SV80A BONNET HINGE
SV81A Headliner 2-layer
SV82A Dummy-SALAPA
SV83A BATTERY TRAY
SV84A D-pillar reinforcement
SV85A Dummy-SALAPA
SV86A Dummy-SALAPA
SV88A 4-wheel drive
SV8AA Dummy-SALAPA
SV8CA Dummy-SALAPA
SV8DA Dummy-SALAPA
SV8EA Dummy-SALAPA
SV8FA Dummy-SALAPA
SV8GA Dummy-SALAPA
SV8HA Dummy-SALAPA
SV8KA Dummy-SALAPA
SV8LA Dummy-SALAPA
SV8MA Dummy-SALAPA
SV8NA Dummy-SALAPA
SV8PA Dummy-SALAPA
SV90A Dummy-SALAPA
SV91A Dummy-SALAPA
SV92A Partial construction with panoramic roof
SV99A Dummy-SALAPA
SV9AA Dummy-SALAPA
SV9BA Dummy-SALAPA
SV9CA Dummy-SALAPA
SV9DA Dummy-SALAPA
SV9EA Dummy-SALAPA
SV9FA Dummy-SALAPA
SV9GA Dummy-SALAPA
SV9HA Dummy-SALAPA
SV9IA Dummy-SALAPA
SV9JA Dummy-SALAPA
SV9KA Dummy-SALAPA
SV9LA Dummy-SALAPA
SV9MA Dummy-SALAPA
SV9NA Dummy-SALAPA
SVDAA Dummy-SALAPA
SVSBA All-season tyres
SVZ1A Dummy-SALAPA
SVZ2A Dummy-SALAPA
SVZ3A Dummy-SALAPA
SVZ4A Dummy-SALAPA
SVZ5A Dummy-SALAPA
SVZ6A Dummy-SALAPA
SVZ7A Dummy-SALAPA
SVZ8A Dummy-SALAPA
SVZAA Dummy-SALAPA
SVZBA Dummy-SALAPA
SVZCA Dummy-SALAPA
SVZDA Dummy-SALAPA
SVZEA Dummy-SALAPA
SVZFA Dummy-SALAPA
SVZGA Dummy-SALAPA
SVZHA Dummy-SALAPA
SVZKA Dummy-SALAPA
SVZLA Dummy-SALAPA
SVZMA Dummy-SALAPA
SVZNA Dummy-SALAPA
SVZPA Dummy-SALAPA
SVZRA Dummy-SALAPA
SVZSA Dummy-SALAPA
SVZTA Dummy-SALAPA
SVZUA Dummy-SALAPA
SVZVA Dummy-SALAPA
SVZWA Dummy-SALAPA
SVZXA Dummy-SALAPA
SVZYA Dummy-SALAPA
SVZZA Dummy-SALAPA
SXAAA Individual R.S. Infotainment online
SXABA Individual R.S. Infotainment
SXD1A Special Edition carbon/gold-brown
SXD2A Special Edition stratus/ecru
SXD3A Special edition carbon/ecru
SXD4A Special edition stratus/gold-brown
SXD5A Indiv. roofliner, Alcantara
SXD6A Individual SA
SXD7A Dummy-SALAPA
SXD8A Dummy-SALAPA
SXE1A Indiv. fine wood, walnut Amarone
SXE2A Indiv.sup.wood,quilted maple, anthracite
SXE3A Indiv. fine wood, eucalyptus timber
SXE4A Indiv. fine wood, olive ash, red-brown
SXE5A Indiv.sup.wood,planetree,red-brown, dark
SXE6A Indiv.sup.wood, satin walnut, honigbraun
SXE7A Indiv. int.trim strips,piano paint,black
SXE8A Indiv. int. piano paint, black, w/inlay
SXE9A Individual decorative strips, leather
SXEWA Indi. Edelholz Sen hellbraun
SXEXA Individual Edelholz Esche Maser weiss
SXEYA Alpina fine wood
SXEZA Alpina piano lacquer
SXF1A BMW Individual rear-end identification
SXL1A Indiv. wood inlay f. leather st.wheel
SXL2A Indiv. leather inlay f. leather st.wheel
SXL3A BMW INDIVIDUAL LEDERLENKRAD
SXL4A #BMW Individual Lederlenkrad
SXT1A Indiv. instrument panel, leather-covered
SZBCA 16 winter wheel&tyre V-spoke 360
SZBDA Sticker, M Performance
SZBEA 16 winter wheel&tyre star spoke 376
SZBFA 20 WWT double spoke 409M
SZBGA Wallbox Business
SZBHA Reserved for UX
SZBIA 16 WWT W-spoke 418
SZBJA 17 WWT V-spoke 395
SZBKA 18 WWT double spoke 397
SZBLA 21 LA wheel M Performance dbl spk 599M
SZBMA Reserved for UX
SZBNA Reserved for UX
SZBOA Reserved for UX
SZBPA Reserved for UX
SZBQA Reserved for UX
SZBRA Reserved for UX
SZBSA Reserved for UX
SZBTA Reserved for UX
SZBUA Reserved for UX
SZBVA Reserved for UX
SZBWA Reserved for UX
SZBXA Reserved for UX
SZBYA Reserved for UX
SZBZA Reserved for UX
SZC1A Freizeitjacke/-weste
SZC2A Inner Bags
SZC3A Aluminium case
SZC4A BMW Performance interior trim in Carbon
SZC5A 16" Winter w&t, double spoke 268
SZC6A 18" winter wheel&tyre, double spoke 238
SZC7A 19" Winter w&t, double spoke 238
SZC8A 19" Winter w&t, multi-spoke 235
SZC9A 19" Winter w&t, star spoke 251
SZCAA 18" Winter w&t, double spoke 234
SZCBA 18" Winter w&t, star spoke 250
SZCCA Additional tool kit
SZCDA Paddock stand
SZCEA Charging device
SZCFA Cover
SZCGA Impact protrectors
SZCHA Sport silencer
SZCIA Carbon cover
SZCJA Mini footpump
SZCKA Emergency kit
SZCLA Cylinder head cover
SZCMA Pinion cover
SZCNA Valve cover protector
SZCOA Safety screw, oil filler neck
SZCPA Radiator trim
SZCQA Balaclava / neck warmer
SZCRA Headlight protection
SZCSA MOTOR FULL PROTECTION
SZCTA Crash sensor
SZCUA Hand lever, milled
SZCVA Impact protection, handlebar
SZCWA Function underclothing
SZCXA Can holder
SZCYA REAR VIEW MIRROR
SZCZA Back cushion, topcase
SZD0A 16" light alloy S-Winder R102
SZD1A Performance gearshift knob
SZD2A 15"Winter w&t, 7-hole spoke R81
SZD3A Carbon exterior components
SZD4A Cover in car colour
SZD5A Service products
SZD6A Roof flags
SZD9A 16" light alloy Double Spoke R87
SZDAA 17" light alloy crown spoke R104
SZDBA Reserved for UX
SZDCA Reserved for UX
SZDDA 17" light alloy flame spoke R97
SZDEA Reserved for UX
SZDFA 16" WKR Double Spoke R87
SZDGA 16" WKR S-Winder R102
SZDHA Roof decor
SZDIA Roof spoiler
SZDJA Decorative strip, Sport Stripes
SZDKA Decorative strip, Bonnet Stripes
SZDLA Paintwork and rim care
SZDMA Window cleaning
SZDNA Interior care
SZDOA Convertible and Roadster care
SZDPA Special applications
SZDQA Portable Navigation
SZDRA iPod adapter cable
SZDSA Bluetooth Snap-in adapter
SZDTA Emergency bag
SZDUA Junior seat II-III
SZDVA Selector-lever grip, leather
SZDWA Selector-lever grip
SZDXA Handbrake grip, leather
SZDYA Additional headlight
SZDZA 18" light alloy double spoke 125
SZE1A Aerodynamic components for M Sport kit
SZE2A Body styling
SZE3A Aerodynamics package
SZE4A Rear spoiler
SZE5A Exhaust tailpipe trim
SZE6A Sports rear silencer
SZE7A Turning/fog light
SZE8A Rear lights Black Line
SZE9A White rear lights
SZEAA Supplementary xenon high-beam headlights
SZEBA Paintwork protection film, transparent
SZECA Moulding rocker panels
SZEDA Strut brace
SZEEA Rear carrier
SZEFA Exterior mirror covers
SZEGA SLIPSTREAM DEFLECTOR
SZEHA Luggage compartment fastening straps
SZEIA Load area turning mat
SZEJA Wind deflector
SZEKA Storage compartment, instrument panel
SZELA Workshop products
SZEMA Underride protection
SZENA Multi-functional rucksack
SZEOA Diesel particle filter
SZEPA 15" winter wh.&tyre 5 Star Spooler R100
SZEQA 16" winter wh.&t.Bridge Spoke silver R94
SZERA 15" winter wheel&tyre, cross spoke 42
SZESA 17" winter wheel & tyre, double spoke 79
SZETA 17" winter wheel&tyre, star spoke 57
SZEUA 17" winter wheel&tyre, V spoke 130
SZEVA 17" winter wheel&tyre, star spoke 200
SZEWA USB interface for the ACM
SZEXA Door entrance strips, illuminated
SZEYA Park Distance Control (PDC)
SZEZA Ice scraper
SZF1A CD/DVD storage pouch
SZF2A Clean Bag
SZF3A Halogen reading light
SZF4A Hand lamp
SZF5A Aluminium footrest
SZF6A Aluminium pedals
SZF7A Floor mat, textile
SZF8A Floor mat, Allweather
SZF9A High-grade steel pedal covers
SZFAA Belt holder
SZFBA Handbrake trim, wood
SZFCA Handbrake lever, metal
SZFDA Leather handbrake lever with decor. trim
SZFEA frei vergebbar
SZFFA Baby seat 0+, with/without ISOFIX
SZFGA Junior seat II
SZFHA Junior seat III
SZFIA Junior seat I-II, with/without ISOFIX
SZFJA Leather steering wheel w/ wood dec. trim
SZFKA Leather sports st. wheel + decor trim
SZFLA Sport gearshift knob
SZFMA Leather gearshift knob w/ decorative bar
SZFNA Leather sport gearsh.knob w/decor. bar
SZFOA Seat cover BMW design
SZFPA Seat cover lambskin
SZFQA Ski and snowboard bag
SZFRA Sunblind
SZFSA Loading-sill protective mat
SZFTA Door entrance strips
SZFUA Selector-lever grip leather w/ dec. bar
SZFVA Rear-cabin bag
SZFWA Case set
SZFXA Leather retrofit
SZFYA Drink holder
SZFZA Trim rings
SZG1A Freizeithose
SZG2A Fleece jacket
SZG3A Fleece shirt
SZG4A Neck scarf / scarf
SZG5A Regenanzug/-overall
SZG6A Function stocking
SZG7A Kids Anzug/Jacke
SZG8A Protektorenjacke/-weste
SZG9A Neck brace
SZGAA Jet helmet
SZGBA Fork protector
SZGCA Enduro helmet
SZGDA Footrests
SZGEA Frame protection
SZGFA Handle
SZGGA Chainguard
SZGHA Mudguard rear
SZGIA Integral helmet
SZGJA HipBag
SZGKA Bluetooth
SZGLA Radio partition insert
SZGMA Case protective film
SZGNA Seat bench
SZGOA Vario topcase
SZGPA Top
SZGQA Top Case
SZGRA Topcase carrier
SZGSA Working lamp
SZGTA Rear light LED
SZGUA Tyre holder
SZGVA Sweatshirt
SZGWA Schlüsselanhänger/-tasche
SZGXA Bag, Ride
SZGYA Trinkpak
SZGZA Visor helmet
SZH1A 19" light alloy star spoke 145
SZH2A 19" light alloy star spoke 146
SZH3A 19" light alloy star spoke 147
SZH4A 19" light alloy double spoke 150
SZH5A Multi-function device
SZH7A BMW Performance selector-lever grip
SZH8A BMW Performance handbrake grip
SZH9A 19" winter wheel&tyre, V spoke 257
SZHAA 16" summer w&t, steel wheel 12
SZHBA 18 LA wheel, M double spoke 219
SZHCA 18 LA wheel, M double spoke 260
SZHDA 18" Winter complete wheel V spoke 281
SZHEA 21 LA wheel Y-spoke375 BMW Performance
SZHFA 18" light alloy star spoke 276
SZHGA 17" winter wheel&tyre V-spoke 318
SZHHA 17" winter wheel&tyre star spoke 319
SZHIA Interior bicycle holder
SZHJA 20 LA wheel, M double spoke 310
SZHKA 18" WKR Radialspeiche 388
SZHLA Radio, multifunction
SZHMA Multifunct.lugg.compartm.mat w.fold.cont
SZHNA Roof antenna
SZHOA 18 winter wheel&tyre, radial spoke 237
SZHPA Travel & Comfort system
SZHQA 17-inch WKR V-Spoke 304
SZHRA 17-inch WKR V-Spoke 305
SZHSA 18-inch WKR V-Spoke 307
SZHTA 19 Winter wheel&tyre double spoke 309
SZHUA 19" LMR Double Spoke R129
SZHVA 16" WKR 5-Star Single Spoke R122
SZHWA 17" WKR 5-Star Double Spoke R124
SZHXA 17" WKR Double Spoke R99
SZHYA Chrome package, interior
SZHZA 16 winter wheel&tyre steel wheel R12
SZJ1A Universal lift
SZJ2A Collapsible box
SZJ3A Compartment cover
SZJ4A Drink holder-module
SZJ5A Coat hanger
SZJ6A Cool bag
SZJ7A Seat-back storage pocket
SZJ8A Umbrella holder
SZJ9A Storage compartment module
SZJAA Roof box
SZJBA Base support system
SZJCA Luggage basket
SZJDA Ski and snowboard holder
SZJEA SUPPORT SNOWBOARD
SZJFA Surfboard rack
SZJGA Universal holder
SZJHA Bicycle rack, trailer coupling
SZJIA Bicycle lift
SZJJA Racing-bike holder, lockable
SZJKA Touring-bike holder, lockable
SZJLA Non-skid mat
SZJMA Luggage compartment net
SZJNA Fitted luggage compartment mat
SZJOA Door handles with flags
SZJPA Key fob
SZJQA Interior surfaces
SZJRA Luggage-compartment lashing straps
SZJSA Boot partitioning grate
SZJTA Luggage-compartment tray
SZJUA Loading-sill protective film
SZJVA Luggage compartment cover
SZJWA Multifix system
SZJXA Pocket holder
SZJYA Dog harness
SZJZA Exterior mirror for towing
SZK1A AUX connection
SZK2A Hands-free facility Universal
SZK3A BMW DVD system, Advanced
SZK4A BMW DVD system for Control Display
SZK5A BMW Portable DVD system
SZK6A iPod interface
SZK7A BMW Radio Navigation
SZK8A Digital road maps
SZK9A Rear View
SZKAA Side View
SZKBA Electronic log book
SZKCA Bracket, navigation, portable
SZKEA 18" light alloy V Spoke 281
SZKFA 19" light alloy V spoke 281
SZKGA 20" LA wheel, V-spoke 281
SZKHA 17" winter wheel&tyre star spoke 327
SZKIA Ski- und Snowboardtasche Pro
SZKJA Battery charger
SZKKA Loading sill cover
SZKLA Driver utility set
SZKMA Rubber floor mat, classic
SZKNA Ashtray
SZKOA 20" winter wheel&tyre, Y-spoke 214
SZKPA 17" winter wheel&tyre, double spoke 238
SZKQA 17" WKR Sternspeiche 317
SZKRA 16" WKR Doppelspeiche 154
SZKSA Luggage compartment net
SZKTA 16 winter wheel&tyre, star spoke 45
SZKUA 17" winter wheel&tyre, double spoke 98
SZKVA 18" winter wheel&tyre,ellips.styling 91
SZKWA 17 winter wheel&tyre, star spoke 233
SZKXA DVD-system in rear compartment
SZKYA 17 Winter w&t, multi-spoke 284
SZKZA Mission Control
SZL0A 21" light alloy double spoke 215
SZL1A 16" light alloy radial spoke 50
SZL2A 17" light alloy douple spoke 178
SZL3A 17" light alloy cross spoke 144
SZL4A 18" light alloy double spoke 129
SZL5A 18" light alloy double spoke 182
SZL6A 18" light alloy double spoke 195
SZL7A 18" LA double spoke composite 71
SZL8A 18" light alloy radial spoke 196
SZL9A 18" light alloy double spoke 180
SZLAA 18" light alloy star spoke 181
SZLBA 18" light alloy star spoke composite 179
SZLCA 19" light alloy double spoke 125
SZLDA 19" light alloy radial spoke compos. 198
SZLEA 19" light alloy star spoke 128
SZLFA 19" light alloy star spoke 199
SZLGA 19" light alloy radial spoke bicolor 190
SZLHA 19" light alloy star spoke compos. 179
SZLIA 18" light alloy double spoke 184
SZLJA 18" light alloy star spoke 89
SZLKA 18" light alloy radial spoke 32
SZLLA 19 LA wheel, M cross spoke 101
SZLMA 21" light alloy V spoke 239
SZLNA 21" light alloy double spoke 275
SZLOA 18" light alloy cross spoke 197
SZLPA 18" light alloy radial spoke 216
SZLQA 18" LA BMW Performance double spoke 269
SZLRA 18" light alloy JCW star spoke R95
SZLSA 18" light alloy JCW double spoke R109
SZLTA 18" light alloy JCW double spoke R105
SZLUA 17" winter wheel&tyre, star spoke 165
SZLVA 18" winter light alloy star spoke 153
SZLWA 18" winter light alloy star spoke 69
SZLXA Wheel bolt locks
SZLYA Mud flaps
SZLZA Snow chains
SZM1A Tow-cable/-bar
SZM2A Fire extinguisher, powder-type
SZM3A Jump leads in original BMW pouch
SZM4A First aid kit
SZM5A Jack set
SZM6A Warning triangle
SZM7A Warning vest
SZM8A Car cover
SZM9A Non Paints
SZMAA Hard-sided case
SZMBA Paints
SZMCA Ski/snowboard holder f. rear-rack mntng.
SZMDA Mobility set
SZMEA Fuel canister in spare wheel
SZMFA HiFi system, Alpine
SZMGA BMW Performance strut brace, aluminium
SZMHA 17" winter wheel&tyre, double spoke 116
SZMIA Glasses case
SZMJA 19" LA wheel, V spoke 324
SZMKA DVD system Tablet
SZMLA Vario case
SZMMA System case
SZMNA T-Shirt
SZMOA Shirt long-sleeved
SZMPA Shirt
SZMQA Sweatshirt jacket
SZMRA Trousers
SZMSA Cap
SZMTA Rucksack, Ride
SZMUA Belt / braces
SZMVA Miniature
SZMWA Glasses
SZMXA LEATHER SUIT
SZMYA Textile suit
SZMZA Gloves
SZN1A Side scuttles carrier set
SZN2A Air inlet cover
SZN3A Grip, trunk lid
SZN4A Interior rear-view mirror cover
SZN5A Accessory Control Menu ACM
SZN6A Infrared headphones
SZN7A DVB-T set-top box
SZN8A Winter traction aid
SZN9A BMW Performance door sill strips
SZNAA Reserved for UX
SZNBA Reserved for UX
SZNCA Reserved for UX
SZNDA Reserved for UX
SZNEA Reserved for UX
SZNFA Reserved for UX
SZNGA Reserved for UX
SZNHA Reserved for UX
SZNIA Reserved for UX
SZNJA Reserved for UX
SZNKA Reserved for UX
SZNLA Reserved for UX
SZNMA Reserved for UX
SZNNA Reserved for UX
SZNOA Reserved for UX
SZNPA Reserved for UX
SZNQA Reserved for UX
SZNRA Reserved for UX
SZNSA Reserved for UX
SZNTA Reserved for UX
SZNUA Reserved for UX
SZNVA Reserved for UX
SZNWA Reserved for UX
SZNXA Reserved for UX
SZNYA Reserved for UX
SZNZA Reserved for UX
SZO1A Aluminium topcase
SZO2A Duffle bag
SZO3A Jacket
SZO4A Tank bag
SZO5A Tank-Bag
SZO6A Rear pocket
SZO7A Windscreen
SZO8A Sports case
SZO9A Soft bag
SZOAA Polo shirt
SZOBA Underglove
SZOCA VEST
SZODA Windbreaker
SZOEA Kids Kurzarm
SZOFA Insert
SZOGA iPod adapter cable
SZOHA Footboards chrome
SZOIA Helmet pocket
SZOJA Kidsbike NF
SZOKA Audio system
SZOLA Miscellaneous
SZOMA Sew-on badge / pin
SZONA Boots
SZOOA BMW Motorrad communication system
SZOPA Kids Langarm
SZOQA HP Race Parts
SZORA Impact protection
SZOSA Spoke wheel
SZOTA Parts, chrome
SZOUA Floor lighting
SZOVA Bags, Style
SZOWA Rucksacks, Style
SZOXA Chain lubrication system
SZOYA Short-sleeve shirt
SZOZA Cardigan
SZP0A Transmission tunnel bag
SZP1A BMW Performance braking system
SZP2A BMW Performance air-intake system
SZP3A BMW Performance silencer system
SZP4A BMW Performance shortshift
SZP5A BMW Performance suspension
SZP6A BMW Performance decal stripes
SZP7A 17" winter wheel&tyre, star spoke 256
SZP8A BMW Performance sport steering wheel
SZP9A Interior trim finishers
SZPAA BMW Performance sport seat
SZPBA 18" winter wheel&tyre, V spoke 254
SZPCA BMW Performance strut brace, Carbon
SZPDA Snap-in adaptor w USB interface
SZPEA BMW Performance aluminium footrest
SZPFA BMW Performance aluminium pedals
SZPGA Multimedia pocket
SZPHA BMW Performance aerodynamic kit
SZPIA Telematics platform accessory
SZPJA Additional instruments
3 część VO FA
SZPKA 18" winter light alloy star spoke 99
SZPLA 18" winter light alloy double spoke 93
SZPMA 18" winter light alloy multi-spoke 94
SZPNA Inside pocket for hard-sided case
SZPOA 16" winter wheel&tyre, star spoke 104
SZPPA Stowage net in footwell
SZPQA 18" winter light alloy star spoke 209
SZPRA 18" winter light alloy cross spoke 177
SZPSA 15" light alloy star spoke R86
SZPTA Care-product sets
SZPUA 18" light alloy double spoke 238
SZPWA 19" winter light alloy Y spoke 211
SZPXA 19" light alloy double spoke 75
SZPYA 18 Winter wheel&tyre,M double spoke270
SZPZA 20" light alloy star spoke 87
SZQ1A Decorative trim, steering wheel
SZQ2A Reserved for UX
SZQ3A Reserved for UX
SZQ4A Reserved for UX
SZQ5A Reserved for UX
SZQ6A 17" light alloy star spoke 90
SZQ7A Reserved for UX
SZQ8A Reserved for UX
SZQ9A Reserved for UX
SZQAA Hub cap
SZQBA BMW M Performance Akzentstreifen
SZQCA MINI Radvollblende
SZQDA Frontziergitter
SZQEA 19" LMR, M Performance II Doppelsp. 624M
SZQFA 18" LA wheel, V spoke 217
SZQGA 20" LMR, M Performance II Doppelsp. 624M
SZQHA 21" LMR Y-Speiche 627
SZQIA 17" WKR Y-Speiche 489M
SZQKA LA wheel, star spoke 95, 19-inch
SZQLA 18" LMR Doppelspeiche 361
SZQMA LA wheel, V spoke 63, 19-inch
SZQNA 19" LMR Turbinenstyling 487
SZQOA 16" light alloy radial spoke 139
SZQPA 16" light alloy star spoke 140
SZQQA 19" light alloy double spoke 238
SZQRA Decorative trim, gear selector switch
SZQSA 15" WKR Star Spoke R86
SZQTA 16" WKR Double Spoke R88
SZQUA 16" WKR X-Lite Styling R84
SZQVA 17" WKR S-Spoke R85
SZQWA 16" winter wheel&tyre, 7 spoke R92
SZQXA 15" winter wheel&tyre, 8 spoke R82
SZQYA 18 LA wheel, M cross spoke 101
SZQZA 20 LA wheel, M cross spoke 101
SZR0A 19" LA Performance double spoke 269
SZR1A 16" light alloy radial spoke 32
SZR2A 17" light alloy radial spoke 32
SZR3A 21" light alloy star spoke 128
SZR4A 17" light alloy star spoke 199
SZR5A 19" light alloy star spoke 89
SZR6A 17" light alloy cross spoke 238
SZR7A 18" light alloy cross spoke 238
SZR8A 19" light alloy cross spoke 238
SZR9A 16" WKR Radialspeiche 508
SZRAA 17" WKR Doppelspeiche 510
SZRBA 20" light alloy cross spoke 177
SZRCA 19" light alloy cross spoke 177
SZRDA 18" light alloy cross spoke 177
SZREA 17" light alloy M double spoke 207
SZRFA 17" LMR Multi Spoke 505
SZRGA 19" winter wheel&tyre, V spoke 223M
SZRHA 18" LMR Kreuzspeiche 506
SZRIA Anti-chip protective film
SZRJA 17" light alloy double spoke 238
SZRKA 16" winter wheel&tyre, star spoke 102
SZRLA 17" winter wheel&tyre, star spoke 90
SZRMA 17" winter wheel&tyre, double spoke 103
SZRNA 17" winter wheel&tyre, cross spoke 133
SZROA 19 Winter wheel & tyre M V-spoke 298
SZRPA 17" emergency wheel, styling 84
SZRQA 19" winter light alloy cross spoke 177
SZRRA 18" LMR JCW Doppelspeiche 534
SZRSA Shoe case
SZRVA 18" winter wheel&tyre, star spoke 74
SZRXA Pouch for emergency wheel
SZRYA 19" winter light alloy star spoke 232
SZRZA 20" light alloy radial spoke 32
SZS3A BMW Performance Power Kit
SZS4A 17" winter wheel&tyre star spoke 276
SZS5A 17" WKR Sternspeiche 290
SZS6A 20" light alloy cross spoke 312
SZS7A 20" light alloy star spoke 311
SZS8A 20" LA wheel, V spoke 356
SZS9A 19 LA wheel double spoke 361
SZSBA 17 winter wheel&tyre tunnel spoke R125
SZSCA 18 winter wheel&tyre star spoke 330
SZSDA 18 winter wheel&tyre star spoke 320
SZSEA 18 winter wheel&tyre V-spoke 328
SZSFA 18 Winter wheel&tyre turbinestyl. 329
SZSGA 17 winter wheel&tyre V-spoke 236
SZSHA 17 winter wheel&tyre, Y-spoke 305
SZSIA 16" winter wheel&tyre V-spoke 255
SZSJA 16 winter wheel&tyre multi-spoke 282
SZSKA 20 winter wheel&tyre V-spoke 299M
SZSLA 20 LA wheel, multi spoke 410
SZSMA Daytime running lights
SZSNA 19 LA wheel, M Y-spoke 359
SZSOA Backrest guard
SZSPA Design trims, bumper/sill
SZSQA Interior trim finishers, adhesive
SZSRA Adaptive securing system
SZSSA Sport aerial
SZSTA Center Rail Produkte
SZSUA Design package
SZSVA BMW Link
SZSWA Floor mat, velours
SZSXA JCW Rear spoiler
SZSYA Side stripe
SZSZA Electric drive motor MINI
SZT1A HP instrument cluster
SZT2A HP engine spoiler
SZT3A HP sticker
SZT4A Smart Phone Integration
SZT5A Mounting, BMW Navigator
SZT6A Base plate, BMW Navigator
SZT7A Load area net
SZT8A Scooter jacket
SZT9A HP forged wheel
SZTAA SLIPSTREAM DEFLECTOR
SZTBA Backrest
SZTCA RAIN PROTECTION CAP
SZTDA Mobile phone insert
SZTEA Motorcycle lock
SZTFA BLOUSE
SZTGA Tank bag, universal
SZTHA Single seat
SZTIA Drivers seat, high
SZTJA Drivers seat low
SZTKA Seat bench, high
SZTLA Seat bench, low
SZTMA Reserved for UX
SZTNA Reserved for UX
SZTOA Reserved for UX
SZTPA Brake pedal
SZTQA Reserved for UX
SZTRA Kidney belt
SZTSA HP panel, fuel tank
SZTTA HP Carbon parts
SZTUA HP hand lever, folding
SZTVA Connectivity snap-in adapter
SZTWA HP footbrake lever/shift lever, milled
SZTXA HP footrest system
SZTYA Junior Bike
SZTZA HP laptimer
SZV0A 18" light alloy cross spoke R113
SZV1A 16" light alloy Cross Spoke R90
SZV2A 17" LA cross spoke composite R90
SZV3A 17" light alloy double spoke R99
SZV5A 17" light alloy multi spoke R108
SZV6A MINI valve caps
SZV7A Sunscreen-film
SZV8A Licence plate holder
SZV9A 17" LA cross spoke challenge R112
SZVAA 17" winter wheel&tyre, cross Spoke R114
SZVBA 20" LA wheel M Performance V-spoke 464
SZW0A 15" Winter w&t, steel wheel 12
SZW1A 16" Winter w&t, trapezoidal styling 134
SZW2A 16" Winter w&t, star spoke 115
SZW3A 16" Winter w&t, radial spoke 50
SZW4A 16" Winter w&t, radial spoke 139
SZW5A 16" Winter w&t, V spoke 229
SZW6A 16" Winter w&t, double spoke 156
SZW7A 16" Winter w&t, radial spoke 32
SZW8A 16" Winter w&t, star spoke 155
SZW9A 16" Winter w&t, steel wheel 12
SZWAA 16" Winter w&t, star spoke 151
SZWBA 16" Winter w&t, star spoke 140
SZWCA 17" Winter w&t, radial spoke 244
SZWDA 17" Winter w&t, star spoke 138
SZWEA 17" Winter w&t, star spoke 243
SZWFA 17" Winter w&t, star spoke 122
SZWGA 17" Winter w&t, star spoke 117
SZWHA 17" Winter w&t, V spoke 110
SZWIA 17" Winter w&t, double spoke 111
SZWJA 17" Winter w&t, double spoke 112
SZWKA 17" Winter w&t, V spoke 141
SZWLA 17" Winter w&t, star spoke 199
SZWMA 17" Winter w&t, radial spoke 32
SZWNA 17" Winter w&t, star spoke 158
SZWOA 17" Winter w&t, star spoke 159
SZWPA 18" Winter w&t, radial spoke 118
SZWQA 18" Winter w&t, M double spoke 184
SZWRA 18" Winter w&t, M double spoke 164
SZWSA 18" Winter w&t, star spoke 143
SZWTA Glovebox subdivider
SZWUA Storage tray, centre console
SZWVA 17" winter wheel&tyre, steel wheel 12
SZWWA 17" winter wheel&tyre, star spoke 105
SZWXA Centre armrest with storage compartment
SZWYA 17" light alloy cross spoke 133
SZWZA 17" light alloy double spoke 71
SZX0A JCW gearshift indicator
SZX1A JCW aerodynamic kit
SZX2A JCW rear spoiler, Carbon
SZX3A JCW rear-lid handle, Carbon
SZX4A JCW door-mirror caps, Carbon
SZX5A JCW air-inlet trim, Carbon
SZX6A JCW sport brake 16"
SZX7A JCW perforated brake disc
SZX8A JCW suspension cross-brace
SZX9A JCW car cover
SZXAA JCW sport seat, leather
SZXBA JCW steering-wheel rim, leather
SZXCA JCW trim, Carbon
SZXDA JCW gearshift knob with Carbon strip
SZXEA JCW gearshift gaiter
SZXFA JCW handbrake grip with Carbon bar
SZXGA JCW entrance strip with logo
SZXHA JCW floor mat with Chequered Flag
SZXIA JCW Tuning Kit
SZXJA JCW sports suspension
SZXKA JCW coil springs, red
SZXLA JCW Side Scuttles, trim-cap set
SZXMA 16" light alloy double spoke R88
SZXNA 17" winter wheel&tyre, flame spoke R97
SZXOA 20" light alloy double spoke 238
SZXPA 21" light alloy double spoke 238
SZXQA 21" light alloy cross spoke 312
SZXRA 21" light alloy star spoke 311
SZXSA 19" light alloy star spoke 311
SZXTA 18" light alloy star spoke 311
SZXUA 17" light alloy star spoke 276
SZXVA 19" light alloy star spoke 276
SZXWA 18 LA wheel M Performance dbl spk 313M
SZXXA 19" LA Performance double spoke 313
SZXYA 17" emergency wheel, steel
SZXZA Trim, loading sill, illuminated
SZY1A Dog Guard
SZY2A Stolen vehicle recovery
SZY3A Radar warning system
SZY4A Smartnav
SZY5A Exterior decals
SZY6A Caravan leads
SZY7A Twin Electrics
SZY8A Alarm system
SZY9A Accessory packs
SZZ1A Auxiliary connecting cable
SZZ2A 19 LA wheel cross-spoke R134
SZZ3A 18 LA wheel V-spoke R133
SZZ4A Electric drive motor BMW
SZZ5A Door sill, foil
SZZ6A 19 WWT double spoke 408M
SZZ7A Black Line
SZZ8A BMW M Performance aerodynamic kit
SZZ9A Organizer Set
SZZAA Auxiliary heating
SZZBA Indep. heater/indep. ventilation
SZZCA Control element, independent heating
SZZDA JCW sport brake 17"
SZZEA Top stripe
SZZFA 18" LA wheel radial spoke 388
SZZGA 19" LA wheel Performance double spk 405
SZZHA 20" LA wheel cross spoke 404
SZZIA 20" LA wheel M Performance dbl. spk 405
SZZJA 20" LA wheel double spoke 361
SZZKA 16 winter wheel&tyre star spoke 377
SZZLA 16 winter wheel&tyre V-spoke 411
SZZMA 17 winter wheel&tyre, Y-spoke 380
SZZNA 17 Winter wheel&tyre turbinestyl. 381
SZZOA 18 WWT double spoke 385
SZZPA 16 winter wheel&tyre V-spoke 390
SZZQA 16 winter wheel&tyre star spoke 391
SZZRA 17 winter wheel&tyre star spoke 393
SZZSA 17 winter wheel&tyre V-spoke 413
SZZTA 18 Winter wheel&tyre turbinestyl. 415
SZZUA 18 winter wheel&tyre star spoke 396
SZZVA 18 winter wheel&tyre star spoke 365
SZZWA 18 winter wheel&tyre, Y-spoke 308
SZZXA 21 LA wheel M double spoke 310M
SZZYA 19 LA wheel double spoke 465
SZZZA 21 LA wheel V-spoke 463
L801A National version Germany/Austria
L801A NATIONAL VERSION GERMANY
L802A National version Korea
L804A NATIONAL VERSION SWITZERLAND
L807A NATIONAL VERSION JAPAN
L808A NATIONAL VERSION ISRAEL
L809A NATIONAL VERSION DENMARK
L810A National version Australia
L811A National version Belgium
L812A National version England / Ireland
L812A NATIONAL VERSION GREAT BRITAIN
L813A NATIONAL VERSION FRANCE
L814A NATIONAL VERSION ITALY
L816A NATIONAL VERSION EASTERN EUROPE
L819A NATIONAL VERSION SPAIN
L820A NATIONAL VERSION LATIN AMERICA
L821A National version Egypt
L822A GULF VERSION
L824A NATIONAL VERSION SOUTH AFRICA
L827A NATIONAL VERSION SCANDINAVIA
L830A NATIONAL VERS. NORTHERN COUNTRIES
L833A country specification, Singapore
L838A NATIONAL VERSION CANADA
L846A Country-specific version Taiwan
L8AAA National version China
L8LAA National version, India
P237A Driving dynamics package
P330A Sports package
P335A Individual series 95 Special Exec.
P335A SPORT PACKAGE M TECHNIC
P336A Sports package
P337A M Sports package
P338A Dummy-SALAPA
P3BZA MINI YOURS SODA EXTERIOR PACK
P446A Rear compartment equipment
P448A High Line Top-equipment
P462A Comfort seat with stowage table
P4G1A #MINI Yours Interior Style Off-White
P4G2A MINI Yours Interior Style Dark Cottage
P505A Headl.washer system/fog lamps,rear wiper
P535A Electronic temperature control
P535A A/C comfort pack
P580A Taxi package
P581A Taxi package
P5A3A BMW NIGHT VISION MIT DYNAMIC LIGHT
P5DUA PARKASSISTENZPAKET
P626A communication package mobile phone
P628A Communication pack
P671A Radio Busin./CD Changer/HiFi-Sys.
P703A Eastern Europe package
P706A V5 package
P714A Luxury package
P720A SPORT LIMITED EDITION
P730A Advantage package
P730A Individual special series
P734A Levant package
P735A Basic Package
P740A Edition ZD
P741A Edition ZB
P742A Edition ZF
P743A Edition, special markets
P744A Edition ZH
P745A Edition ZE
P746A Edition ZN
P747A Edition ZO
P748A Edition ZV
P749A Edition, importers
P758A Individual Luxury Compact
P762A Individual series 95 Selection Japan
P763A Individual, Brazil
P765A Motorsport Edition ZA
P777A Motorsport, international
P7A1A MINI sidewalk
P7A2A Innovation pack II
P7A3A Business Package
P7A4A Advantage package + innovation package
P7A5A Advantage Package+Limited Sport Edition
P7A6A Innovation package + Editions
P7A7A Innovation package+Comfort p.+Editions
P7A8A Innovation package+Comfortp.+Advantagep.
P7A9A Innovation package + Comfort package
P7AAA EXECUTIVE PACKAGE
P7ABA SPORT EXECUTIVE PACKAGE
P7ACA Sport Line
P7ADA Urban Line
P7AEA Taiwan-Package, low
P7AFA Extended chrome package
P7AGA Int. package Individual, Piano Lacquer
P7AHA Interior package, Individual Royal Ash
P7AKA Interior package, Individual Walnut
P7ALA MINI Seven
P7AMA MINI Park Lane
P7ANA MINI Checkmate
P7APA Dynamics + Advantage package
P7ARA Aerodynamics package
P7ASA Package Dynamic + Comfort + Advantage
P7ATA Advantage + Comfort Package
P7AUA Advantage + Sport Package
P7AVA Comfort + Sport Package
P7AWA Advantage + Comfort + Sport Package
P7AXA Advantage + Sport Package M
P7AYA Comfort + Sport Package M
P7AZA Advantage + Comfort + Sport Package M
P7G1A Package Dynamic + Edition Lifestyle
P7G2A Package Dynamic + Edition Exclusive
P7G3A Package Comfort + Edition Lifestyle
P7G4A Package Comfort + Edition Exclusive
P7G5A Package Dynamic + Comfort + Ed.Lifestyle
P7G6A Package Dynamic + Comfort + Ed.Exclusive
P7G7A Edition 10 years X5
P7G8A DESIGN COOL ELEGANCE
P7G9A Comfort + Limited Sport Edition
P7GZA Captain Chair
P7H1A SPECIAL EDITION
P7H2A EDITION APEC BLACK & WHITE
P7H3A Tech-Package
P7H4A SPECIAL EDITION
P7H5A SPECIAL EDITION
P7H6A MINI Green Park
P7H7A MINI HYDE PARK
P7H8A Mobile phone prep. with USB interface
P7H9A Hands-free system with USB interface
P7HAA MINI 50 MAYFAIR
P7HBA MINI 50 CAMDEN
P7HCA Comfort Plus + Limited Sport Edition
P7HDA EARL GREY
P7HEA Connectivity package
P7HFA JALAPENO
P7HGA Curry
P7HHA Habanero
P7HKA WORLD CHAMPIONSHIP 50
P7HLA MINI Clubman 50 Hampton
P7HMA Italy kit
P7HNA John Cooper Works package
P7HPA Connectivity Package II
P7HRA MINIMALISM package
P7HSA CO2 optimisation
P7HTA MINI Baker Street
P7HUA MINI Bayswater
P7HVA MINI Highgate
P7HWA X Line
P7HXA MINI Goodwood
P7HYA Design Pure Traction
P7HZA Design Pure Traction + M Sport
P7K1A CKD China high
P7K2A CKD China high
P7K3A CKD China high
P7K4A CKD China high
P7K5A CKD China high
P7KAA Navigation package Business
P7KBA Navigation package Professional
P7KCA NAVIGATION PROFESSIONAL
P7KDA NAVIGATION BUSINESS
P7KEA TELEFONIE ASIA
P7KFA TELEFONIE ASIA PLUS
P7KHA John Cooper Works GP
P7KKA MINI Clubman Bond Street
P7KMA JOHN COOPER WORKS INTERIEUR PAKET
P7KNA JOHN COOPER WORKS EXTERIEUR PAKET
P7KPA JOHN COOPER WORKS CHILI PAKET
P7KRA ESSENTIAL PAKET
P7KSA MINI Yours Soda Pack
P7KTA BMW Head-Up Display + Connectivity pack
P7KXA Interior world Pure
P7KYA Interior world Care
P7KZA Interior world Cosmo
P7L1A LIMITED EDITION LIFESTYLE
P7L2A Limited Edition Lifestyle + M package
P7L4A RED HOT
P7L5A WIRED
P7L6A City
P7L7A LIGHTHOUSE
P7L8A PACK-UP
P7L9A always open
P7LXA #MINI Sidewalk Chili
P7LZA Edition Powder Ride
P7M2A BMW Individual Composition
P7M3A BMW Individual Composition, maritime
P7M4A BMW Individual Composition, sporty
P7MBA Exclusive Sport Edition
P7MCA Exclusive Edition
P7MDA Lifestyle Edition
P7MFA Sports Edition
P7MHA M Sport Edition
P7MPA Sports package
P7MRA Design Pure White + M Sports package
P7MRA M Sports package
P7MSA Limited Sport Edition
P7PAA including MINI service
P7PBA including MINI service and repair
P7R1A Navig. syst. with mobile phone provision
P7R2A Lifestyle package
P7R3A Package 1
P7R3A Ukraine package
P7R4A Driver package with Dynamic package
P7R5A Driver package with M Sport package
P7R6A Comfort Plus package w/ M sport package
P7R7A Innovation package
P7R8A Innovation package plus
P7R9A James Fleet
P7RAA Special edition Exclusive carbon/grey
P7RBA Special edition Exclusive carbon/zimt
P7RCA Special edition Exclusive stratus/grey
P7RDA Special edition Exclusive stratus/zimt
P7REA Special edition Lifestyle carbon/grey
P7RFA Special edition Lifestyle carbon/zimt
P7RGA Special edition Lifestyle stratus/grey
P7RHA Special edition Lifestyle stratus/zimt
P7RKA Special edit. Lifestyle diamant/walk sw
P7RLA Special edit. Sport nachtblau/Alcantara
P7RMA Light technology package
P7RNA Driver Package
P7RPA Advantage package
P7RRA Dynamic package
P7RSA Package Comfort
P7RTA Dynamic and Comfort package
P7RUA Special edition Exclusive diamant/black
P7S1A Modern Line
P7S2A Luxury Line
P7S3A Design Pure Balance
P7S4A Design Pure Balance + M Sports package
P7S5A Interior design Pure Excellence
P7S6A INTERIEURDESIGN PURE EXPERIENCE
P7S7A Interior design Pure Excellence
P7S8A Interior design Pure Excellence
P7SAA Open Air package
P7SBA Dummy-SALAPA
P7SCA EDITION FLEET PLUS
P7SDA Package Comfort Plus + Edition Lifestyle
P7SEA Package Comfort Plus + Edition Exclusiv
P7SFA Advantage + Edition Sport
P7SGA Comfort + Edition Sport
P7SHA Hotel package
P7SKA Innovation package
P7SLA Design Pure White
P7SMA Design Pure Impulse
P7SRA Ambient and Sound
P7SSA Lounge pack
P7STA Interior package
P7SUA Rear-cabin package
P7SVA Ambient & Sound + Individual components
P7SWA Design Pure Impulse + Sportpaket
P7SZA Adaptive suspension pack. Professional
P7V1A Comfort Package Plus + Modern Line
P7V2A Comfort Package Plus + Luxury Line
P7V3A COMFORT PAKET PLUS
P7V4A Comfort Package Plus + M Sports package
P7V5A Comfort Package Plus + Urban Line
P7V6A Comfort Package Plus + Sport Line
P7VAA Ride comfort package
P7VBA Comfort package
P7VCA Sun protection glazing package
P7VDA Sicht Packet
P7VEA Adaptive xenon light package
P7VFA Visibility package + M Sports package
P7VGA Heat comfort package
P7VHA Surround View package
P7VUA Advantage Package Plus + Modern Line
P7VVA Advantage Package Plus + Luxury Line
P7VWA Advantage Package Plus
P7VXA Advantage Package Plus + M Sports pckge
P7VYA Advantage Package Plus + Urban Line
P7VZA Advantage Package Plus + Sport Line
P7X1A Dummy-SALAPA
P7X2A Dummy-SALAPA
P7X3A Dummy-SALAPA
P7X4A Dummy-SALAPA
P7X5A Dummy-SALAPA
P7X6A Dummy-SALAPA
P7X7A Dummy-SALAPA
P7X8A Dummy-SALAPA
P7X9A Dummy-SALAPA
P7XYA Connected Drive package
P7XZA Dummy-SALAPA
P7Y0A SALT II
P7Y1A PEPPER II
P7Y2A CHILI II
P7Y8A Interior equipment Verve
P7Y9A Interior equipment Fusion
P7YAA Corporate
P7YBA Business
P7YCA Executive
P844A Adverse weather package
P890A Standard pack
P891A EXECUTIVE EQUIPMENT
P892A High Line-Package
P893A Middle-East package
P894A V5-IC PACKAGE 1
P894A HK-2 package
P912A Package 2
P912A Eastern Europe pack
P913A Eastern Europe pack plus
P914A Premium package
P948A Core model package V5-KA
P949A Sport pack LA
P950A Latin America pack
P951A Korea pack
P951A Summer package
P952A China pack
P953A V5-IC PACKAGE 2
P953A Taiwan pack
P954A Business package II
P955A Middle-East package
P955A MO package
P955A Business line
P956A Middle-East package
P957A HK-Paket
P957A V5-IC PACKAGE 3
P958A Basic Package, Mexico
P959A Luxury package Mexico
P970A Aktionspaket
P971A Exclusive package
P972A Comfort package
P973A Winter package
P973A Black & White Line
P973A Malaysia package
P974A Asia package
P975A Dummy-SALAPA
P976A Package Comfort
P977A Exclusive Line
P981A Top Komfortpaket
P981A Comfort Plus package
P9A1A 3 SERIES SUNSHINE PACKAGE
P9A2A Advantage-Package
P9A3A Tech-Package 2
P9A4A Luxury Package
P9A5A X LINE PLUS
P9A8A Drive-Package
P9A9A DRIVER PACKAGE 2
P9B1A Package 3
P9B2A Innovation package + Business package
P9B3A AUSSTATTUNGSPAKET OPEN SKY
P9B8A Comfort Package
P9B9A Exclusive Package
P9BAA Premium Package
P9BBA Package Premium + Comfort
P9BCA Final Package
P9BDA Business Package
P9BEA Motivation Package
P9BFA Navigation Package
P9BGA Navigation package + M Sports package
P9BHA Advantage Package Plus+Business Package
P9BKA Comfort Package Plus + Business Package
P9BLA Special Package
P9BMA Special Package + Business Package
P9BNA V5-IC PACKAGE 4
P9BPA High Package
P9BRA Latinamerica Package 1
P9BSA Latinamerica Package 2
P9BTA Latinamerica Package 3
P9BUA Drive Comfort Package
P9BVA Sunshine Package
P9BWA Interior Comfort Package
P9BXA Sight Package
P9BYA Light Package
P9BZA Connectivity Package
P9CAA Comfort Package
P9CBA Sight Package
P9CCA EXECUTIVE PACKAGE
P9CDA Drive Package
P9CEA Seating Package
P9CFA Exterior Package
P9CGA Baltics Package 1
P9CHA Baltics Package 2
P9CKA Baltics Package 3
P9CLA Baltics Package 4
P9CMA Baltics Package 5
P9CXA Driver Comfort Package
P9CYA Visibility Package
P9CZA Luxury Package
PRP1A Business package I
PRP2A Business package II
PRP3A Brushed Steel and Teak Decking
PRP4A Black Starlight Starburst Headliner
PXA1A Special edition carbon/cinnamon
PXA2A Special edition carbon/bicolor grey
PXA3A Special edition carbon/champagner
PXB1A Special edition stratus/cinnamon
PXB2A Special edition stratus/bicolor grey
PXB3A Special edition stratus/champagne
PXC1A Special edition nightblue/cinnamon
PXC2A Special edition nightblue/bicolor grey
PXC3A Special edition nightblue/champagne
PXC4A BMW Individual Composition
PXK1A MINI Clubvan
PZAAA Individual RSI Professional
Bateryjki, wyp dodatkowe, do retrofitow
/ / NOTE: Due to overlap with KMM no e-and K-words are allowed, starting with "L" or "P"
/ / E: active supplement lines (PUSY relevance for control SA <100) (-) A maximum of 10 in the FA
/ / E LEDE LEATHER / / leather
/ / Attention Battery size over e-words. (See section H)
E B046 BATT_46AH / / 46 Ah battery
E B055 BATT_55AH / / 55 Ah battery
E B070 BATT_70AH / / 70 Ah battery
E B080 BATT_80AH / / 80 Ah battery
E B090 BATT_90AH / / 90 Ah battery
E A070 BATT_AGM_70AH / / 70 Ah AGM battery
E A080 BATT_AGM_80AH / / 80 Ah AGM battery
E A090 BATT_AGM_90AH / / 90 Ah AGM battery
E EWS4 / / rate for new generation EWS (not coding!)
E TARN TARN / / for all PPP veh. with camouflage headlight
E EFZG prototype / / test vehicles (CLASS_PWR) only in conjunction with plant control SAs 0W3 and 0W4
EMEA e / / omission must Adapter (MAIL Haller 27.2. 7:56) PA603 / 586
Sixt E / / disable DSC M3 with Sixt Fzgen
E ANRA / / "for" another radio "according to the SCCB 05:11:09 E-word not coding, just KMM!!
E OGKB OHNE_GKB_FA_BF / / Without load limiters FA / BF
E OAPC OHNE_SITZ_POS / / seat position sensors FA / BF auscodieren
E M3NK ENTFALL_KLIMA / / elimination SA534 with M3 GTS KG91, KG92 / / NA190286
E RECA NR_SPORTSITZE / / retrofitting performance sport seat for retrofitting M3 GTS performance sport seat, Project no. 000 000 484
E MSPS MIT_SITZ_POS / / seat position sensors BF eincodieren E84US
E MPTC MIT_PTC / / PTC sheeting factory - CEK from 09.05.2008
E ZABF BEIAIRBAGST2 / / Two-stage front passenger airbag 09-09-410 <09-09-450 then H word
E EEKP EKP_HW / / vehicles before 10-03-450 nachcodiert performed without rebuilding measures
E E459 SITZMEMORY_FA SPRITZD_HZG / / For type-Schl. PM93 from 03/10 to 09/10
To use e EOAS OHNE_AUFROL_STR / / Without Aufrollstrammer, older vehicles in the FIT with 16 ignition circuit devices continue to
E CTM3 CTM3 / / PVL E89 with the old hood with 3 function valves open and close while driving
E OVSW OHNE_VSW1_4 / / CTM E93, new roof sensor VSW 1.4 package stored on the left (new in 12-07-450, or in plant use at 12-07) is made hideable. (Shoring and error review)
/ / H: historical lines (no PUSY relevance, former controls <100) (+ / -) Maximum 10 FA
H FITT FITT / / Display CC messages in the combined active
H TARN TARN / / for all PPP veh. with camouflage headlight
H KMB1 / / for interim status PL2-1 in combination with Codierindex I2.20
H B046 BATT_46AH / / 46 Ah battery
H B055 BATT_55AH / / 55 Ah battery
H B070 BATT_70AH / / 70 Ah battery
H B080 BATT_80AH / / 80 Ah battery
H B090 BATT_90AH / / 90 Ah battery
H A070 BATT_AGM_70AH / / 70 Ah AGM battery
H A080 BATT_AGM_80AH / / 80 Ah AGM battery
H A090 BATT_AGM_90AH / / 90 Ah AGM battery
H ID4P ID_GEBER_4 / / 4 ID-Enter for passive access
H NNIC NACHRUEST_NIC / / Re-equipment with customer complaint "clutch judder when driving"
H IHKA KLIMA_HIGH IHKA_NACHR / / Use + IHKA is in the low variant E87 without FZD FZD with no air required
H SPHZ NACHRUEST_SPHZ / / retrofitting mirror heating
H nDVD NACHRUEST_DVD / / retrofitting REAR DVD PLAYER
H DBFA DEAKT_BEIF_AIRB / / retrofitting passenger airbag deactivation
H BEEF KEIN_RADIO / / Nachruestoption Radio Navigation Indianapolis E87 and E90
H GSHI OHNE_GUSTR_HI / / pretensioners are back to VS not installed E90/E91. / Rear belttighter not buld in till VS E90/E91
H GKBF OHNE_BF_GK / / Without belt contact passenger (PVL E90) /
H SHSZ SONDERSTANDHEIZ / / heater as Machine Accessories
H OPSS OPT_KEY_SEARCH / / temporary e-WORD spec. for CAS and KOMBI from I-5:20! (Only FIT / Labcar)
H OI12 OHNE_BF_SBR / / disable passenger Seatbeltreminder (PVL E90)
H OPOL OHNE_POL_DIMM / / Without Pin Dimming (MRS5 Flash 05-09-410 -> 05-09-420)
H IALT I_TAFEL_ALT / / Old instr.panel Installed (for control IHKA appropriate software)
H EWS4 / / rate for new generation EWS (not coding!)
H MEPS / / EPS control pre-series
(Must be at least Fzg flashed on CCC_APP.C08) H KMP3 NACHRUEST_MP3 / / Re-equipment / retrofitting MP3 activation at CCC for cars before 09/05
H ULF2 ULF2 / / Control ULF2 in CCC_APP; SVS_MICRO (or most similar)
H BRSP / / Control record for 06-03-511 Sports Cars 100% from 0606
H USHD FH_DISASHD_KR / / activation Schiebehubdach with terminal R (PA603/161?)
H IPOD IPOD CD_WECHSLER CD_DVD / / retrofitting IPOD as a CD changer
H œœ œœ / / customer oeffnen tailgate without unlocking
H abig NR_ABBIEGELICHT / / retrofitting cornering not yet in ASAP
H DIFI DPARTIKELFILTER / / diesel particulate filter
H MLIB / / Re-equipment for Lebanon for bad fuel quality
H HFMM / / HFM retrofitting retrofitting E90N46 with SA858
H K302 ALARM / / retrofitting Alarm 0306-0906
H HOS3 / / control the plant for the exhaustion of parts to 0307
H SWUL / / software update MULF
H K638 TEL_PROFESIONEL / / retrofitting Car telephone Professional
H K644 ULF / / retrofitting kit universal
H MOGB OHNE_GB / / Without GB (M3 PPP patch)
H KOAB KOLIAB / / conversion will comfort light off
H DCAN D_CAN / / As of 03/07 is dependent on a motor DCAN. Please be heading just before 09/07!
H EHHS KURZ_HEIZ / / New rear window, Einsatzt 100% from JUNI06, einfliessend with EHHS
ALKS H / / CO2_ALKS / / Adaptive air flap control
H MMSA CO2_MSA / / engine start stop automatic
H MIGR CO2_IGR / / Intelligent Alternator Control "6cyl Diesel"
H KOKU / / compressor clutch
H OMSA OHNE_MSA / / No engine start stop automatic
H IGRX / / IGR_6BMOT / / IRG encoding for "gasoline" 6cyl.
H NSWA NR_NSWA / / (Project no: 000 000 251) Pennsylvenia retrofitting FRMFA
H SPBR NR_SPORTBREMSEN / / retrofitting sport brakes, project no. 000000478
H OSST OHNE_SOFTSTOP / / retrofitting deactivation SST
H Exra EXTERNES_RADIO KEIN_RADIO / / retrofitting external radio (combi no request!)
H OI03 OHNE_SIDEBAG_VL / / side airbag deactivation, front left
H OI04 OHNE_SIDEBAG_VR / / side airbag deactivation, front right
H ZBEP PERF_CONT / / Conversion PL2 conversion from ZBEH to Perform. Controller, project no. 000000379
H K640 TELE_VORBE / / universal retrofit kit (without mute FZD), Project no. 000 000 370
H OSTH OSTH / / retrofitting heater, Project no. 000000347
H OKOM OKOM / / Conversion Komfortoeffnen deactivation, Project no. 000000304
H MKOM MKOM / / Conversion Komfortoeffnen activation, project no. 000000304
H XFRM / / retrofit heater (remove space create $ 520 without exchange FRM), Project no. 000 000 412
H MUEB MUE_BELEUCHTUNG / / retrofit measure E87N LCI tail lights, project no. FZ 000 000 246
H UKKP UMKLIKOMP / / Re-equipment Air Compressor
H KLED LED_AHM / / retrofitting LED lights for trailers, Project no. 000000453
H NAVp NAVI_PORTABLE / / retrofitting Portable Navi, project no. 000000419
H RUZU / / Re-equipment E90/91 M57D30TU2 speed variation, Project no. 000 000 474
H NSBK NR_SPIEGELBEIKL / / retrofitting Spiegelbeiklappen, Project no. 000000480
H RECA NR_SPORTSITZE / / retrofitting performance sport seat for retrofitting M3 GTS performance sport seat, Project no. 000 000 484
H RecF NR_SPORTS_FAHRE / / retrofitting Performance sports seat only driver, project no. 49563
H LINS LIN_BEDIENBLOCK / / retrofitting performance sport seat patch for LIN mirror
H TAK1 TCU_E91_AUDKORR / / TCU audio correction E91, project no. 000 000 506
H URLK ALPINA_ERSATZ / / retrofit / replacement parts are required for MSD80 ALPINA B3, Project no. 000 000 504
H EMEA / / omission must Adapter (MAIL Haller 27.2. 7:56) PA603 / 586
H MUE_BEL_FRONT MTF / / control dummy for clear separation FRONT / REAR
H toil MUE_BEL_HECK / / retrofit / upgrade facelift rear lights, project no. 000000536
H MUEG MUE_BEL_FRONT MUE_BEL_HECK / / retrofit / upgrade facelift front and rear lights, project no. 000000539
H K5DA DEAKT_BEIF_AIRB FZD FZD_E88 FZD_E89 / / BF airbag disconnection, in conjunction with roofing Electrical module without ISOFIX, Project no. 000 000 554
H MPTC MIT_PTC / / PTC sheeting factory - CEK from 09.05.2008
H OBBV ONBREMBELVERANZ / / Auskodieren Lining Wear, Project no. 000000557
H ZUOF OHNE_ZUHEIZER / / heater not working, project no. 000000563
H EFZG prototype / / test vehicles (CLASS_PWR) only in conjunction with plant control SAs 0W3 and 0W4
H WGAK / / retrofit / wastegate measure, project no. 000000712
H ASCD ASCD / / ASC (diesel) Control N57 W-bikes.
H NPOW / / conversion / performance tuning N54 135i / 335i, Project no. 22761
H ZABF BEIAIRBAGST2 / / Two-stage front passenger airbag 09-09-410 <09-09-450 then H word
H RNIC DREHZAHL_ANHEB / / Conversion / Anfahrdrehzahlanhebung with clutch judder E89xN47, Project no. 98161 156511 190164
H TEAL / / Conversion KMM / Anfahrdrehzahlanhebung with clutch judder E89xN47 EU3 EU4, project no. 169745
H DIRU / / Conversion / E9x N53 MSD80 jerking, project no. 113847
H FRAUD FRAUD / / Conversion / iSpeech One Shot Ireland PN 187425
H ONSW OHNE_NEBELSW / / retrofitting retrofitting heater - deactivation NSW
Sixt H / / disable DSC M3 with Sixt Fzgen
H EEKP EKP_HW / / vehicles before 10-03-450 nachcodiert performed without rebuilding measures
H E459 SITZMEMORY_FA SPRITZD_HZG. / / For type-Schl PM93 from 03/10 to 09/10
H ANRA / / "for" another radio "according to the SCCB 05:11:09 E-word not coding, just KMM!!
H OGKB OHNE_GKB_FA_BF / / Without load limiters FA / BF
H OAPC OHNE_SITZ_POS / / seat position sensors FA / BF auscodieren
H OSAT OHNE_SAT_BILD / / elimination satellite imagery in some countries
H MUH2 MUE_HECKL_LCI_9 / / conversion for tail lights for LCI retrofit E92/E93
H MUH1 MUE_HECKL_LCI_8 / / conversion for LCI tail lights retrofit E82/E88
H KDDE N47D20_KDDE / / Re-equipment DDE71 N47D20O0 performance L2 (originally KMM only)
H KDD1 N47D20_KDD1 / / Conversion / E91 v-max increase with diesel performance
H KAMP ERSATZ_AMP / / Can Bus replacement by low cost HiFi HiFi AMP E89
H K3AR HECKTRAEG_NACH / / NA rear luggage rack for E84 vehicles between 09/09 and 03/10
H ONIC O_DREHZ_ANHEB / / disable Anfahrdrehzahlanhebung NA190231
H M3NK ENTFALL_KLIMA / / elimination SA534 with M3 GTS KG91, KG92 / / NA190286
H KSHD SHD_KOMFORTPOS / / E84 Panaramadach comfort position for vehicles before 09/10
H Katb / / Conversion / DDE73 data compatibility for SCR catalyst at E90US only for KMM
H MSPS MIT_SITZ_POS / / seat position sensors BF eincodieren E84US
H TINT TEL_INTEGR / / telematics integration for various PLATF.
H FHRC FH_HINTEN_CABR / / Conversion / E89/E93 Rear FH
H KEPS / / EPS FSC for Altfahzeuge / Mischverbau (for CMM)
H AGRI / / Inverse EGR valve
H KDD2 / / Diesel Performance Package
H KNET RAD_TEL_US / / radio telephony for U.S.
H CTM3 CTM3 / / PVL E89 with the old hood with 3 function valves open and close while driving
H EOAS OHNE_AUFROL_STR / / Without Aufrollstrammer to use older vehicles in the FIT with 16 ignition circuit devices continue to
H MOTORCYCLE / / ALPINE CD83 radio (CD73)
H OK3Z / / Conversion DDE data available at Oxi Kat exchange E90US
H DMBA DMB_AUDIO / / retrofitting DMB audio
H KDSC DSC_TR_BREMSEN / / DSC E84 brake drying
H KEQA EQ_AMPT / / customer complaint EQ AMPT70 E89
H AMKS / / N46T Panama knocking noise only for KMM
H SWTK SW_TUERKONTAKT / / threshold Tuerkontakt
H OSNU OHNE_SNU_DIAG / / Without diagnosis of Hall sensors in the lock nut
H HLED LED_OHNE_XENON / / retrofit LED rear lamps for E84 without xenon light
H FLXL LCI_XENON_SW / / retrofit for LCI-Xenon/AHL-Scheinwerfer in E84-LCI vehicles before production (07/12)
H FLCE FLC_EMPF / / automatic headlight control sensitive
De-/activate H KLSD LAUTSPR_DIAG / / Speaker diagnosis for ASD
H KVNE VERDECK_NEU / / CTM E93, new roof sensor package placed on the left
H OVSW OHNE_VSW1_4 / / CTM E93, new roof sensor VSW 1.4 package stored on the left (new in 12-07-450, or in plant use at 12-07) is made hideable. (Shoring and error review)
/ / K: Customer Service supplementary lines (no PUSY relevance) (+) A maximum of 10 in the FA
K Oneg OHNE_NEIGUNG / / deactivation inclination sensor
K OFIS OHNE_FUNK_IN / / deactivation indoor sensor
K MTFL MIT_TAGLICHT / / with daytime running lights
K OSZV OHNE_SEL_ZV / / without selective central locking
K MSZV MIT_SEL_ZV / / with selective central locking
K LOCK VERRIEGELN_AN / / lock 16 km / h on (without head unit)
K NLOC VERRIEGELN_AUS / / lock 16 km / h off (without head unit)
K FLCN FLC_NORMAL / / automatic headlight control low sensitivity (sensitivity = Series)
K FLCS FLC_SEHR_EMPF / / automatic headlight control is very sensitive
C107 K NACHR_CKM_A107 / / Re-equipment of the mechanical activation. Procedure (CKM_A107) (no activation / Akt. Been unlocked with FB / Akt. According unlocking and opening the door with FB)
K TELD TELEMATIC_DIS / / disable function for Telematic TCU_MOST
K PVCA AKT_PERS_V_CALL / / enable voice calls staff coupled with speech recognition
K K639 NACHRUEST_TCUUS / / SAZK639 / / retrofitting Everest platform for U.S. (SA639)
K K633 BT_AKTIVIERUNG / / retrofitting MOBILE PREPARATION BUSINESS (only with SA639)
K K641 NACHRUEST_STDUS / / U.S. standard upgrade kit universal mobile phone preparation (South America and Korea)
K RASK MOST_RING_MASK / / enable bit in the MASK RING
K OSVs OHNE_SVS_LOW / / disable function "low language processing" in MASK / M ULF
K KSET AUTO_SITZVERST / / Automatic seat adjustment after unlocking FB
Disable K OI11 OHNE_FA_SBR / / Seatbeltreminder driver
Disable K OI12 OHNE_BF_SBR / / Seatbeltreminder passenger
K GKBF OHNE_BF_GK / / Without passenger belt contact
K SHSZ SONDERSTANDHEIZ / / heater as Machine Accessories
K OI03 OHNE_SIDEBAG_VL / / side airbag deactivation, front left
K OI04 OHNE_SIDEBAG_VR / / side airbag deactivation, front right
K ID4P ID_GEBER_4 / / 4 ID-Enter for passive access
K NNIC NACHRUEST_NIC / / Re-equipment with customer complaint "clutch judder when driving"
K IHKA KLIMA_HIGH IHKA_NACHR / / Use + IHKA is in the low variant E87 without FZD FZD with no air required
K SPHZ NACHRUEST_SPHZ / / retrofitting mirror heating
K nDVD NACHRUEST_DVD / / retrofitting REAR DVD PLAYER
K DBFA DEAKT_BEIF_AIRB / / retrofitting passenger airbag deactivation
K BEEF KEIN_RADIO / / Nachruestoption Radio Navigation Indianapolis E87 and E90
K KMP3 NACHRUEST_MP3 / / Re-equipment / retrofitting MP3 activation at CCC for cars before 09/05 (Fzg must be at least flashed to CCC_APP.C08)
K USHD FH_DISASHD_KR / / activation Schiebehubdach with terminal R (PA603/161?)
K IPOD IPOD CD_WECHSLER CD_DVD / / retrofitting IPOD as a CD changer
K œœ œœ / / customer oeffnen tailgate without unlocking
K abig NR_ABBIEGELICHT / / retrofitting cornering not yet in ASAP
K DIFI DPARTIKELFILTER / / diesel particulate filter
K MLIB / / Re-equipment for Lebanon for bad fuel quality
K HFMM / / HFM retrofitting retrofitting E90N46 with SA858
K KFDM / / retrofitting flexible diagnostic module
K K302 ALARM / / retrofitting Alarm 0306-0906
K SWUL / / software update MULF
K K638 TEL_PROFESIONEL / / retrofitting Car telephone Professional
K K644 ULF / / retrofitting kit universal
K KOAB KOLIAB / / conversion will comfort light off
K NSWA NR_NSWA / / (Project no: 000 000 251) Pennsylvenia retrofitting FRMFA
K SPBR NR_SPORTBREMSEN / / retrofitting sport brakes
K OSST OHNE_SOFTSTOP / / retrofitting deactivation SST
K Exra EXTERNES_RADIO KEIN_RADIO / / retrofitting external radio, project no. 000000260, 261
K ZBEP PERF_CONT / / Conversion PL2 conversion from ZBEH to Perform. Controller, project no. 000000379
K K640 TELE_VORBE / / universal retrofit kit (without mute FZD), Project no. 000 000 370
K OSTH OSTH / / retrofitting heater, Project no. 000000347
K OKOM OKOM / / Conversion Komfortoeffnen deactivation, Project no. 000000304
K MKOM MKOM / / Conversion Komfortoeffnen activation, project no. 000000304
K XFRM / / retrofit heater (remove space create $ 520 without exchange FRM), Project no. 000 000 412
K MUEB MUE_BELEUCHTUNG / / retrofit measure E87N LCI tail lights, project no. FZ 000 000 246
K KLED LED_AHM / / retrofitting LED lights for trailers, Project no. 000000453
K NAVp NAVI_PORTABLE / / retrofitting Portable Navi, project no. 000000419
K RUZU / / Re-equipment E90/91 M57D30TU2 speed variation, Project no. 000 000 474
K NSBK NR_SPIEGELBEIKL / / retrofitting Spiegelbeiklappen, Project no. 000000480
K RECA NR_SPORTSITZE / / retrofitting performance sport seat, Project no. 000000484
K RecF NR_SPORTS_FAHRE / / retrofitting Performance sports seat only driver, project no. 49563
K LINS LIN_BEDIENBLOCK / / retrofitting performance sport seat patch for LIN mirror
K TAK1 TCU_E91_AUDKORR / / TCU audio correction E91, project no. 000 000 506
K URLK ALPINA_ERSATZ / / retrofit / replacement parts are required for MSD80 ALPINA B3, Project no. 000 000 504
K toil MUE_BEL_HECK / / retrofit / upgrade facelift rear lights, project no. 000000536
K MUEG MUE_BEL_FRONT MUE_BEL_HECK / / retrofit / upgrade facelift front and rear lights, project no. 000000539
K K5DA DEAKT_BEIF_AIRB FZD FZD_E88 FZD_E89 / / BF airbag disconnection, in conjunction with roofing Electrical module without ISOFIX, Project no. 000 000 554
K OBBV ONBREMBELVERANZ / / Auskodieren Lining Wear, Project no. 000000557
K ZUOF OHNE_ZUHEIZER / / heater not working, project no. 000000563
K WGAK / / retrofit / wastegate measure, project no. 000000712
K ASCD ASCD / / ASC (diesel) Control N57 W-bikes.
K NPOW / / conversion / performance tuning N54 135i / 335i, Project no. 22761, N55 135i / 335i, NA 190224 190565
K RNIC DREHZAHL_ANHEB / / Conversion / Anfahrdrehzahlanhebung with clutch judder E89xN47 EU5, project no. 156511 (98161) 190174
K TEAL / / Conversion KMM / Anfahrdrehzahlanhebung with clutch judder E89xN47 EU3 EU4, project no. 169745
K DIRU / / Conversion / E9x N53 MSD80 jerking, project no. 113847
K FRAUD FRAUD / / Conversion / iSpeech One Shot Ireland PN 187425
K ONSW OHNE_NEBELSW / / retrofitting retrofitting heater - deactivation NSW / / NA 187686
K OSAT OHNE_SAT_BILD / / elimination satellite imagery in some countries / / NA 190129
K MUH2 MUE_HECKL_LCI_9 / / conversion for tail lights for LCI retrofit E92/E93 / / NA 190103
K KDDE N47D20_KDDE / / Re-equipment DDE71 N47D20O0 performance L2 (originally only KMM), / / ??RCV 190132
K KDD1 N47D20_KDD1 / / Conversion / E91 v-max increase with diesel performance / / NA 190151
K KAMP ERSATZ_AMP / / Replacement Can-Bus low cost HiFi HiFi AMP by E89 / / NA 190171
K K3AR HECKTRAEG_NACH / / NA rear luggage rack for E84 vehicles between 09/09 and 03/10 / / NA 190183
K ONIC O_DREHZ_ANHEB / / disable Anfahrdrehzahlanhebung / / NA 190231
K KSHD SHD_KOMFORTPOS / / E84 Panaramadach comfort position for vehicles before 09/10 / / NA 190218
K Katb / / Conversion / DDE73 data compatibility for SCR catalyst at E90US only for KMM / / NA 190216
K GTRR / / HO word to correct the Schaltklackerproblem's in the DKG / GS40 in HO / / NA 190279
K MUH1 MUE_HECKL_LCI_8 / / conversion for retrofit E82/E88 LCI tail lights / / 190284
K FHRC FH_HINTEN_CABR / / Conversion / FH E89/E93 Rear / / NA 190296 190491
K KEPS / / EPS FSC for Altfahzeuge / Mischverbau / / NA 190323 190324
K AGRI / / Inverse EGR valve / / NA 190306
K KDD2 / / Diesel Performance Package / / NA 190308
K KNET RAD_TEL_US / / radio telephony for U.S. / / NA 190334
K MOTORCYCLE / / Conversion for CD83 ALPINE CD73 radio, only for CMM / / NA 190357 190358
K OK3Z / / Conversion DDE data available at Oxi Cat E90US exchange for KMM / / NA 190370
K DMBA DMB_AUDIO / / retrofitting DMB audio / / NA 190385
K KDSC DSC_TR_BREMSEN / / DSC E84 brake drying / / NA 190381 190485
K KEQA EQ_AMPT / / customer complaint EQ AMPT70 E89 / / NA 190411
K AMKS / / N46T Panama knocking noise only for KMM / / NA 190413
K SWTK SW_TUERKONTAKT / / threshold Tuerkontakt / / NA 190424
K HLED LED_OHNE_XENON / / retrofit LED rear lamps for E84 without xenon light / / NA 190442
K FLXL LCI_XENON_SW / / retrofit for LCI-Xenon/AHL-Scheinwerfer in E84-LCI vehicles before production (07/12) / / NA 190467, 190468
K FLCE FLC_EMPF / / automatic headlight control sensitive / / NA 190475
K KLSD LAUTSPR_DIAG / / enable or disable Speaker diagnosis for ASD / / NA 190488
K KVNE VERDECK_NEU / / CTM E93, new roof sensor package placed left / / NA 190495
K OKOS O_KOMFORT_SCHL / / retrofitting elimination Komfortoeffnen about Castle in SA 877 / / NA 190627
/ / K MUE9 / / Facaelift retrofitting Xenon headlights E89 / / NA 190 578 and 190580
K CSUS CARSHARING_US / / U.S. car-sharing, disable CC message key is
Tutaj FA (VO) po polsku
S000A
Dummy-SALAPA
S001A
LA nie jest sterowane jako pakiet
S0BVA
Tankowanie do pełna
S0BWA
Partial refuelling
S100A
Zwiększenie obciążenia użytkowego
S102A
Wzmacniane hamulce
S102A
Podwozie pojazdu służbowego
S103A
Opona całoroczna
S103A
Dolna osłona agregatu
S104A
Wersja na Bliski Wschód
S105A
Zarządzanie zleceniami "Bund"
S106A
Samochód opancerzony
S107A
Instalacja tachografu
S108A
Motor afterrun control unit
S109A
SECURITY PLUS
Kod
Nazwa
S110A
Instalacja montażowa ozn. karetki pog.
S112A
Beklebung leuchtrot RAL 3024
S113A
Beklebung Polizei Bayern minzgrĂźn hell
S114A
Oklejenie dla policji, Północne Niemcy
S114A
Oklejenie dla policji, minzgrĂźn
S115A
Oklejenie dla straży pożarnej NRW
S115A
Oklejenie dla karetki NRW
S116A
Uchwyt chorągiewki lewy
S117A
Uchwyt chorągiewki prawy
S118A
Redukcja maksymalnej prędkości
S119A
Elektryka modułu dodatkowego
S120A
Wyposażenie podstawowe
S121A
Mocowanie na lizak policyjny
S121A
Inst. do umieszczania lizaka
S122A
Mocowanie na pałki policyjne
S123A
Dodatkowe lusterko wewnętrzne
S124A
Podsufitka poj. służb.
S125A
Wyposażenie wnętrza poj. służb. otw.
S126A
Wyposażenie wnętrza poj. służb., mask.
S127A
Uchwyt na broń po stronie pasażera
S129A
Uchwyt na broń w dachu z przodu
S130A
Uchwyt na broń w podłk. środ. z tyłu
S131A
Uchwyt na broń
S139A
Kogut niebieski
S140A
1 RKLE 130,Tonfolge,Polizeischaltung
S141A
Instalacja sygnału dźwiękowego
S142A
Dwa koguty niebieskie
S143A
Włącznik alarmu z sygn. dla policji
S144A
RKLE zdejm. sygnał. policyjny
S145A
Włącznik alarmu z sygn. dla straży poż.
Kod
Nazwa
S146A
Dodatkowe zasilanie energetyczne
S147A
Kogut zdejmowany
S149A
Podwójny kogut, zdejmowany
S150A
Montaż RTK-4 z aparatem ręcznym
S151A
Sondersignalanlage Hella RTK-6
S152A
Specjalne urządzenie sygnalizacyjne
S153A
Nakładka na dach bez inst. sygn. specj.
S155A
Montaż Top-4 z aparatem ręcznym
S159A
Montaż instalacji Aero-Dynic
S160A
Montaż urządz. sygnal. Becker LU 322
S161A
ABGASNORM EU5
S162A
Instalacja montażowa sygnału dźwięk.
S163A
Norma spalinowa EU6
S165A
Dezaktywacja czołowej pod. pow. ITS
S166A
Inst. sygnału zatrz. na tylnej półce
Kod
Nazwa
S167A
Norma spalinowa EU 4
S168A
Redukcja spalin EU 2
S169A
Redukcja spalin EU 3
S169A
Katalizator Diesel
S170A
Inst. FuG 2m-4m Bd, AEG(BKA)
S170A
Instalacja mont. FuG AEG Teledux
S171A
Instalacja mont. FuG Ascom
S172A
Przygotowanie na paliwo zawier. etan
S172A
Inst. FuG 7B kpl. sch. na ręk.
S173A
Inst. FuG 7B/8B/9C sch. na ręk.
S174A
Inst. FuG 8B/9C w sch. na rękawiczki
S175A
Inst. FuG 8B/9C
S176A
Inst. FuG 8B/9C przes.
S178A
Mocowanie krótkofalówki
S179A
Czujniki gazu drażniącego
Kod
Nazwa
S180A
Instalacja anteny dachowej
S180A
Antena dachowa
S181A
Instalacja/Montaż anteny tylnej
S182A
Instalacja do gaszenia pożaru
S183A
Inst. do aktywnej obrony
S184A
Wyjście awaryjne, przednia szyba
S185A
Pojazd specjalny otwarty
S186A
Pojazd specjalny zakryty
S187A
Ochrona podwozia
S188A
Siłownik szyby el. przedn poj. służb.
S189A
Siłownik szyby el. prz./tyl. poj. służ.
S190A
Instalacja rozmowy naprzemiennej
S191A
Siłownik szyby el. przed prawy poj.służ
S192A
Siłownik szyby el. przedn lewy poj.służ
S193A
Brak podgrz. szyb przedn. i boczn.
Kod
Nazwa
S194A
Zdalna instalacja rozruchowa
S195A
Dodatkowe opancerzenie podłogi
S196A
Zbiornik paliwa z hamowaniem wypływu
S197A
Akustyczna i optyczna inst. alarm.
S198A
Dodatkowa instalacja świeżego powietrza
S199A
Wersja na benzynę ołowiową
S199A
Brak katalizatora
S1AAA
55 KW MOTORVARIANTE
S1AFA
Zmieniona rurka wlewu paliwa
S1AKA
Zewnętrzny filtr paliwa
S1CAA
Dummy-SALAPA
S1CBA
ACEA / CO2 Zakres
S1CCA
Auto start/stop function
S1CDA
Brake Energy Regeneration
S200A
Brak katalizatora
Kod
Nazwa
S200A
Przeciwpyłkowy filtr paliwowy
S201A
Zd. do pracy na estrze oleju rzep. (RME)
S202A
Steptronic
S203A
Napęd na cztery koła
S204A
Krótsze przełoż. przekładni tylnej osi
S204A
Wersja napędu na eksport
S205A
Automatyczna skrzynia biegów
S206A
Sekwencyjna ręczna skrzynia biegów
S207A
6-stopniowa skrzynia biegów
S208A
Brak DSC III
S209A
Blokada dyrefencjału
S210A
Dynamiczny ukł. przeciwpoślizgowy
S210A
Dynamiczny ukł. przeciwpoślizgowy III
S211A
S212A
Wyposażenie w układ ham. dla dan. kraju
Kod
Nazwa
S212A
Brak ABS
S213A
Hill-Descent-Control (ukł. pom.)
S213A
Automatyczna ukł. przeciwpoślizgowy
S214A
Automat. ukł. przeciwpoślizg. (ASC+T)
S215A
Wspom. ukł. kier., zależ. od pręd. obr.
S216A
Wspomaganie układu kier. Servotronic
S217A
Aktywny układ kierowniczy
S217A
Koło kierownicy ze skóry
S218A
Kierownica sportowa ze skóry II
S219A
Kierownica sportowa ze skóry 380 mm
S220A
Regulacja poziomu
S221A
2-osiowa regulacja poziomu
S223A
EDC
S224A
Kontroler dynamiki jazdy
S225A
Brak sportowej kompozycji podwozia
Kod
Nazwa
S226A
Sportowe dostosowanie podwozia
S227A
Podw. sport.+ obniż. zaw.+ regul. poz.
S228A
Sportowe dostosowanie podwozia Plus
S228A
Podwozie komfort
S229A
Dynamic Drive
S230A
Podwozie sportowe z obniżaniem zawiesz.
S230A
Zakres dodatkowy, charakteryst. dla UE
S231A
Usuwanie ograniczenia do 250 km/h
S232A
Obr. BMW, st. le. spr. rad. 50
S233A
Zwiększona masa przyczepy
S234A
Zaczep holowniczy z reg. wysokości
S235A
Zaczep holowniczy zdejmowany
S236A
Obr. BMW, st. le. z ogumieniem mieszanym
S238A
Obr. BMW, st. le. podw. spr. 93
S239A
BMW LA wheel Styling 94
Kod
Nazwa
S240A
Skórz. koło kier. z pod. pow.
S241A
Poduszka powietrzna kierowcy i pasażera
S242A
Kierownica z poduszką powietrzną
S243A
Poduszka powietrzna pasażera
S244A
Kolumna kierownicy regulowana
S245A
Kolumna kierownicy elektr. regulowana
S246A
S247A
Regulacja osiowa kierownicy, mechan.
S248A
Podgrzewanie kierownicy
S249A
Wielofunkcyjność dla kierownicy
S250A
Kierownica wielofunkcyjna
S250A
Poduszka bocz. pasaż. na tyln. siedz.
S251A
Wskaźnik uszkodzenia opon
S252A
Aktywa ochrona kolan kierowcy/pasażera
S253A
Skórzane koło kierownicy COOPER S
Kod
Nazwa
S253A
Kierownica wielofunkcyjna, drewniana
S254A
Kierownica drewniana
S254A
Kierownica sportowa z kołem drewnianym
S255A
Kierownica sportowa ze skóry z poduszką
S256A
Kierownica sport./MFL/regul. prędk.
S257A
Dezaktyw. bocz. pod. powietrz., z tyłu
S258A
Bereifung mit Notlaufeigenschaften
S259A
Brak poduszek bocznych
S260A
Poduszka boczna dla kierowcy/pasażera
S261A
S262A
Czołowa poduszka pow. ITS
S263A
Czołowa poduszka pow. ITS z tyłu
S263A
Koła ze st. lekk. z ogumieniem mieszanym
S264A
BMW light alloy wheel, star spoke 55
S265A
Kontrola ciśnienia w oponach (RDC)
Kod
Nazwa
S266A
Obr. BMW, st. le. spr. rad. 48
S267A
BMW light alloy wheel, star spoke 49
S268A
BMW LA wheel, star spoke 95
S269A
Obr. BMW, st. le. spr. rad. 32
S270A
Koła z szerokim ogumieniem
S271A
BMW LA wheel Z Line
S272A
BMW LA wheel Z Star
S273A
Obr. BMW, st. le. spr. gwiaz. 43
S274A
Obr. BMW, st. le. podw. spr. 53
S274A
Obr. BMW, st. le. Flachsternstyling
S275A
BMW LA wheel, chrome-plated/Z Star
S276A
Obr. BMW, st. le. styl. spr. okr.
S277A
Obr. BMW, st. le. BMW podw. spr.
S278A
Obr. BMW, st. le. BMW Styling
S278A
Kod
Nazwa
S279A
Obr. BMW, st. le. nie zd. do j. po uszk.
S279A
Obr. BMW, st. le. spr. gwiaz. 45
S280A
S281A
BMW LA wheel, chr.-plated/roundspokes
S282A
Obr. BMW, st. le. styl. spr. II
S283A
Obr. BMW, st. le. BMW Styling II
S284A
Obr. BMW, st. le. styl. elips. 46
S284A
S285A
S286A
S287A
BMW light alloy wheel, star spoke 64
S288A
Obr. BMW, st. le. spr. krz. 29
S289A
S290A
Obr. BMW, st. le. spr. gwiaz. 44
S291A
Obr. BMW ze st. le. spr. krz. 2-cz.
Kod
Nazwa
S292A
S293A
BMW LA wheel, V spoke 54
S293A
BMW LA wheel w flat-running properties
S294A
BMW LA wheel, multi-spoke styling
S295A
BMW LA wheel, star spoke 96
S295A
Obr. BMW, st. le. Exclusivstyling
S296A
Obr. BMW, st. le. Classic
S297A
BMW LA wheel Streamline
S297A
BMW LA wheel,forged wheel/multi-spoke
S298A
Obr. BMW, st. le. podw. spr. 98
S298A
BMW LA wheel turbine styling
S299A
S2AAA
S2ABA
Obr. BMW, st. le. Ellipsoidsp. 162
S2ACA
Obr. BMW, st. le. styl. elips. 109
Kod
Nazwa
S2ADA
Obr. BMW, st. le. Ellipsoidsp. 202
S2AEA
Obr. BMW, st. le. Turbinenstyling 292
S2AFA
Obr. BMW, st. le. wz. turbiny 271
S2AGA
Obr. BMW, st. le. wz. plastra miodu 323
S2AHA
Obr. BMW, st. le. wz. turbiny 329
S2AKA
S2ALA
LM RAEDER STREAMLINE 297/MB
S2B1A
Obr. BMW, st. le. podw. spr. 278
S2B2A
Obr. BMW, st. le. podw. spr. 316
S2B3A
Obr. BMW, st. le. podw. spr. 321
S2B4A
Obr. BMW, st. le. podw. spr. 195
S2BAA
Obr. BMW, st. le. podw. spr. 88
S2BBA
S2BCA
Obr. BMW, st. le. podw. spr. 111
S2BDA
Obr. BMW, st. le. podw. spr. 112
Kod
Nazwa
S2BEA
Obr. BMW, st. le. podw. spr. 148
S2BFA
Obr. BMW, st. le. podw. spr. 154
S2BGA
Obr. BMW, st. le. podw. spr. 161
S2BHA
Obr. BMW, st. le. podw. spr. 156
S2BKA
Obr. BMW, st. le. podw. spr. 174
S2BLA
Obr. BMW, st. le. Doppelsp. 174/j.p.u
S2BMA
Obr. BMW, st. le. podw. spr. 116
S2BNA
Obr. BMW, st. le. podw. spr. 205
S2BPA
Obr. BMW, st. le. Doppelsp.205 całoro.
S2BRA
Obr. BMW, st. le. Doppelsp.247/j.p.u.
S2BSA
S2BTA
BMW LA wheel/double spoke 222
S2BUA
BMW alloy wheel,doub.sp. 120,All Season
S2BVA
Obr. BMW, st. le. podw. spr. 266
S2BWA
Obr. BMW, st. le. podw. spr. 268
Kod
Nazwa
S2BXA
Obr. BMW, st. le. podw. spr. 253
S2BYA
Obr. BMW, st. le. sp. podw. 278/j.p.u
S2BZA
S2C0A
Obr. BMW, st. le. spr. gw. 124 j.p.u
S2C1A
Obr. BMW, st. le. spr. gw. 175
S2C2A
Obr. BMW, st. le. spr. gw. 175/j.p.u
S2C3A
Obr. MINI st. le. 5 Star Rocket 93
S2C4A
Obr. BMW, st. le. spr. gw. 157
S2C5A
Obr. BMW, st. le. spr. gw. 185
S2C6A
Obr. BMW, st. le. spr. gw. 189
S2C7A
BMW LA star spoke 218 w flat-runn. prop.
S2C8A
Obr. BMW, st. le. spr. gw. 200
S2C9A
Obr. BMW, st. le. spr. gw. 209
S2CAA
Obr. BMW, st. le. spr. gw. 119
S2CBA
Obr. BMW, st. le. spr. gw. 113
Kod
Nazwa
S2CCA
Obr. BMW, st. le. spr. gw. 132
S2CDA
Obr. BMW, st. le. spr. gw. 136
S2CEA
Obr. BMW, st. le. spr. gw. 137
S2CFA
Obr. BMW, st. le. spr. gw. 138
S2CGA
Obr. BMW, st. le. spr. gw. 140
S2CHA
Obr. BMW, st. le. spr. gw. 142
S2CKA
Obr. BMW, st. le. spr. gw. 143
S2CLA
S2CMA
MINI LM Rad 5 Star Bullet m. Notlauf
S2CNA
Obr. MINI st. le. 5 Star Bullet 91
S2CPA
Obr. BMW, st.le. spr. gw. 137, całorocz.
S2CRA
Obr. BMW, st. le. spr. gw. 153
S2CSA
S2CTA
Obr. BMW, st. le. spr. gw. 151
S2CUA
Obr. BMW, st. le. spr. gw. 169
Kod
Nazwa
S2CVA
Obr. BMW, st. le. spr. gw. 170
S2CWA
Obr. BMW, st. le. spr. gw. 171
S2CXA
Obr. BMW, st. le. spr. gw. 155
S2CYA
Obr. BMW, st. le. spr. gw. 158
S2CZA
Obr. BMW, st. le. spr. gw. 159
S2DAA
Obr. BMW, st. le. spr. krz. 197
S2DBA
Obr. BMW, st. le. szprycha gwiaz. 327
S2DCA
Obr. BMW, st. le. szprycha gwiaz. 330
S2DDA
S2DEA
Obr. BMW, st. le. szprycha gwiaz. 334
S2DFA
Obr. BMW, st. le. szprycha gwiaz. 339
S2DGA
Obr. BMW, st. le. szprycha gwiaz. 340
S2DHA
S2DKA
Obr. BMW, st. le. szprycha gwiaz. 341
S2EAA
BMW LA wheel Y-spoke 149
Kod
Nazwa
S2HAA
Obr. BMW, st. le. spr. rad. 139
S2HBA
Obr. BMW, st. le. spr. rad. 160
S2HCA
Obr. BMW, st. le. spr. rad. 187
S2HDA
Obr. BMW, st. le. spr. rad. 190
S2HEA
Obr. BMW, st. le. Radialsp. 32. j.p.u
S2HFA
S2HGA
Obr. BMW, st. le. spr. rad. 244
S2HHA
Obr. BMW, st. le. Radialsp. 244 / j.p.u
S2HKA
Obr. BMW, st. le. spr. rad. 216
S2HLA
Obr. BMW, st. le. spr. rad. 252
S2HMA
Obr. BMW, st. le. szprycha rad. 237
S2K1A
Obr. BMW, st. le., szprycha V 236
S2K2A
Obr. BMW, st. le., szprycha V 328
S2K3A
Obr. BMW, st. le., spr. V 331
S2K4A
Kod
Nazwa
S2K5A
Obr. BMW, st. le., spr. V 338
S2K6A
Obr. BMW, st. le., spr. V 342
S2K7A
BMW LM Rad Doppelspeiche 238
S2KAA
BMW LA wheel, V spoke 110
S2KBA
BMW LA wheel, V spoke 130
S2KCA
BMW light alloy wheel, V-spoke 141
S2KDA
BMW light alloy wheel, V-spoke 168
S2KEA
BMW light alloy wheel, V-spoke 188
S2KFA
BMW alloy wheel M V-spoke 217
S2KGA
BMW LA wheel V-spoke 188 / All Season
S2KHA
BMW light alloy wheel, V-spoke 229
S2KKA
BMW light alloy wheel, V-spoke 206
S2KLA
BMW light alloy wheel, V-spoke 245
S2KMA
BMW LA wheel, V-spoke 245 flat-runn.
S2KNA
BMW light alloy wheel, V-spoke 255
Kod
Nazwa
S2KPA
BMW light alloy wheel, V-spoke 248
S2KRA
BMW light alloy wheel, V-spoke 257
S2KSA
Obr. BMW, st. le., spr. V 254
S2KTA
Obr. BMW, st. le. spr. V 277, j.p.u
S2KUA
Obr. BMW, st. le., spr. V 285
S2KVA
Obr. BMW, st. le., spr. V 294
S2KWA
Obr. BMW, st. le., spr. V 296
S2KXA
Obr. BMW, st. le., spr. V 279
S2KYA
Obr. BMW, st. le., spr. V 277
S2KZA
Obr. BMW, st. le., spr. V 318
S2LAA
BMW LA wheel Y-spoke 114
S2LBA
BMW LA wheel Y-spoke 131
S2LCA
BMW LA wheel Y-spoke 183
S2LDA
BMW LA wheel Y-spoke 211
S2LEA
BMW LA wheel Y-spoke 214
Kod
Nazwa
S2LFA
Obr. BMW, st. le. spr. Y 280
S2LGA
Obr. BMW, st. le. spr. Y 315
S2LHA
Obr. BMW, st. le. spr. Y 322
S2LKA
Obr. BMW, st. le. spr. Y 335
S2LLA
S2LMA
Obr. BMW, st. le. spr. Y 336
S2LXA
Obr. BMW, st. le. spr. Y 337
S2M0A
Obr. BMW, st. le. indywid. 152 I,18"
S2M1A
Obr. BMW, st. le. indywid. 152 I,19"
S2M2A
Obr. BMW, st. le. indywid. 152 I,20"
S2M4A
Ind. kier. skórz., intarsja ze skóry
S2M5A
BMW LA wheel, M V spoke 223
S2M6A
Ind. kier. skórz. z intarsją drewn.
S2M7A
M High Performance Ogumienie
S2M8A
Obr. BMW, st. le. indywid. spr. V 228
Kod
Nazwa
S2M9A
BMW LA wheel, M V-spoke 227
S2MAA
Ręczna skrzynia biegów
S2MBA
Obr. BMW, st. le. M podw. spr. 167
S2MBA
Obr. BMW, st. le. M 19" kuta
S2MCA
Obr. BMW, st. le. M spr. rad. 166
S2MDA
M Drive
S2MEA
Obr. BMW, st. le. M podw. spr. 194
S2MFA
Obr. BMW, st. le. M spr. gw. 193
S2MGA
Obr. BMW, st. le. M podw. spr. 207
S2MHA
Obr. BMW, st. le. M podw. spr. 208
S2MKA
M Przekładnia dwusprzęgłowa z Drivelogic
S2MLA
Obr. BMW, st. le. M podw. spr. 192
S2MMA
Obr. BMW, st. le. M spr. Y 191
S2MNA
Obr. BMW, st. le. M podw. 192 / All S.
S2MPA
Obr. BMW, st. le. M podw. spr. 225
Kod
Nazwa
S2MRA
BMW LA wheel, M double spoke 261
S2MTA
Obr. BMW, st. le. M podw. spr. 220
S2MUA
Obr. BMW, st. le. M spr. gw. 325
S2MVA
Obr. BMW, st. le. M podw. spr. 326
S2MWA
Obr. BMW, st. le. spr. V 265, indywid.
S2MXA
BMW LM Rad M Doppelspeiche 354
S2MYA
BMW LM Rad M Doppelspeiche 355
S2N1A
ALLOY WHEEL INFINITE STREAM SPOKE
S2N2A
ALLOY WHEEL WHITE SHIELD
S2NAA
Lusterko wewnętrzne z kompasem cyfrowym
S2NNA
Obr. BMW, st. le. M podw. spr. 172
S2NPA
Obr. BMW ze st. le. M podw. spr. 135
S2NRA
S2NSA
Obr. BMW, st. le. podw. spr. 288
S2NTA
Obr. BMW, st. le. M spr. V 299
Kod
Nazwa
S2NUA
Obr. BMW, st. le. M podw. spr. 300
S2NVA
Obr. BMW, st. le. indywid. spr. V 301
S2NWA
Obr. BMW, st. le. M spr. V 302
S2NXA
Obr. BMW, st. le. M podw. spr. 303
S2NYA
Obr. BMW, st. le. M podw. spr. 333
S2PAA
Zabezpieczenie śrub kół
S2R1A
S2R2A
BMW LA wheel, start spoke 256
S2R3A
Obr. BMW, st. le. spr. gw. 203
S2R4A
BMW LA wheel, star spoke 230
S2R5A
BMW LA wheel, star spoke 204
S2R6A
BMW LA wheel, start spoke 231
S2R7A
Obr. MINI st. le. Bridge Spoke / całor.
S2R8A
BMW LA wheel, start spoke 241
S2R9A
Ogumienie runflat
_________________
Darmowe rozkodowanie VIN (Polski opis):
napisz VIN na ==>> [email protected]
Problem z PW, proszę pisać na mail
Ostatnio edytowano 22 stycznia 2009, 14:37 przez stones1, łącznie edytowano 1 raz
Góra	 Zobacz profil Wyślij e-mail
stones1
Tytuł: PostNapisane: 22 stycznia 2009, 14:32
Offline
Uzależniony od forum :)
Avatar użytkownika
Moje BMW: 535i
Kod silnika: N55
Kod
Nazwa
S2RAA
BMW alloy wheel, trapezoid style 134
S2RBA
MINI LM Rad 7 Fin Spoke m. Notlauf
S2RCA
Koło na obr. alum. z pełnym kołpakiem
S2RDA
Obr. BMW, st. le. styl. spr. 176/miesz.
S2REA
Obr. MINI st. le.Web Spoke 2-cz. j.p.u.
S2RFA
Obr. MINI st. le. Delta Spoke 96
S2RGA
S2RHA
Obr. MINI st. le. Flame Spoke97
S2RKA
MINI alloy wheel, 5-start spooler 100
S2RLA
MINI alloy wheel, rotator spoke 101
S2RMA
Obr. MINI st. le. Night Spoke, j.p.u
S2RNA
Obr. MINI st. le. 5 Star Blaster j.p.u.
S2RPA
Obr. MINI st. le. Crown Spoke, j.p.u
S2RRA
MINI LA wheel,Crown spoke 104
S2RSA
Obr. MINI st. le. "5 Star Pace Spoke"
Kod
Nazwa
S2RTA
BMW LA wheel turbine styling 201
S2RUA
Obręcz MINI ze st. le. Black Star Bullet
S2RVA
Obr. MINI z stopów lek. w kolorze czarny
S2RWA
Obr. MINI s.l."Web Spoke two-tone" antr.
S2RXA
Obr. BMW, st. le. spr. gw. 210
S2RYA
Obr. BMW, st. le. spr. gw. 212
S2RZA
BMW LA wheel, star spoke 213
S2S1A
Obr. BMW, st. le. spr. gw. 286
S2S2A
Obr. BMW, st. le. spr. gw. 287
S2S3A
Obr. BMW, st. le. spr. gw. 290
S2S4A
Obr. BMW, st. le. spr. gw. 295
S2S5A
Obr. BMW, st. le. wieloszprych. 293
S2S6A
BMW LA wheel, start spoke 258
S2S7A
Obr. BMW, st. le. spr. gwiaz. 317
S2S8A
Obr. BMW, st. le. spr. gwiaz. 319
Kod
Nazwa
S2S9A
Obr. BMW, st. le. spr. gwiaz. 320
S2SAA
Koło bez możliw. jazdy po uszkodzeniu
S2SBA
BMW LA wheel, start spoke 242
S2SCA
BMW LA wheel, start spoke 243
S2SDA
BMW LA star spoke 243 w flat-runn. prop.
S2SEA
BMW LA star spoke 246 w flat-runn. prop.
S2SFA
BMW LA wheel, start spoke 249
S2SGA
BMW LA wheel, start spoke 232
S2SHA
S2SKA
BMW LA wheel, start spoke 259
S2SLA
BMW LA wheel, star spoke 262
S2SMA
BMW LA wheel, star spoke 264
S2SNA
Obr. BMW, st. le. spr. gw. 117
S2SPA
Obr. BMW, st. le. spr. gw. 233
S2SRA
Obr. BMW, st. le. podw. spr. 234
Kod
Nazwa
S2STA
Obr. BMW, st. le. wieloszprych. 235
S2SUA
Obr. BMW, st. le. spr. gw. 250
S2SVA
Obr. BMW, st. le. spr. gw. 251
S2SWA
Obr. BMW, st. le. spr. gwiaz. 272
S2SXA
Obr. BMW, st. le. wieloszprych. 282
S2SYA
Obr. BMW, st. le. spr. gw. 283
S2SZA
Obr. BMW, st. le. wieloszprych. 284
S2TAA
S2TBA
Sportowa automatyczna skrzynia biegów
S2TCA
SPORT. SKRZ. BIEGÓW ZE SPRZĘGŁEM PODW.
S2TDA
Autom. skrz. biegów z podw. sprzęgłem
S2VAA
Adaptive Drive
S2VBA
S2VFA
Adaptacyjne podwozie M
S2VHA
Integral active front steering
Kod
Nazwa
S2VKA
DYNAMIC PERFORMANCE CONTROL
S2VLA
VARIABLE SPORTLENKUNG (ARBEITSNAME)
S2WAA
BMW LA wheel, W-spoke 263
S2WBA
Obr. BMW, st. le., spr. W 291
S2WCA
Obr. BMW, st. le., spr. W 332
S2WDA
S2XAA
Kier.sport.ze skóry+dźw.przeł.+wielof.
S2XAA
Sportowa kierownica z dźwign. przełączn.
S2Y1A
Dummy-SALAPA
S2Y2A
Dummy-SALAPA
S2Y3A
Dummy-SALAPA
S2Y4A
Dummy-SALAPA
S2Y5A
Dummy-SALAPA
S2Y6A
Dummy-SALAPA
S2Y7A
Dummy-SALAPA
Kod
Nazwa
S2Y8A
Dummy-SALAPA
S2Y9A
Dummy-SALAPA
S300A
Centralny zamek z autoalarmem
S300A
Koło dojazdowe
S301A
Ogumienie All-Terrain
S301A
Autoalarm
S302A
Instalacja alarmowa
S303A
Obr. BMW, st. le. styl. elips. 60
S303A
Ochrona wnętrza z czujn. alarm. nachyl.
S304A
S305A
Pilot do zamka centralnego
S306A
Obr. MINI st. le. 7 Hole 81
S306A
S306A
Pakiet zamykający
S307A
Blokada bezpieczeństwa do bagażnika
Kod
Nazwa
S307A
Obr. BMW, st. le. spr. rad. 61
S308A
Pakiet komfort
S308A
Obr. BMW, st. le. spr. krz. 42
S309A
Obr. BMW, st. le. spr. gwiaz. 57
S309A
S310A
Obr. BMW, st. le. spr. gwiaz. 58
S310A
Pakiet komfort
S311A
Obr. BMW, st. le. spr. gwiaz. 69
S311A
Obr. BMW, st. le., chromowana
S312A
S312A
Obr. BMW, st. le., spr. V stylizacja 63
S313A
Lusterko zewn. z funkcją składania
S314A
Lusterko zewn. /Zamek kier. podgrz.
S315A
Wycieraczka tylnej szyby
S316A
Autom. uruchamianie tylnej klapy
Kod
Nazwa
S317A
Sterowanie drzwi komfort
S317A
Autom. miękkiego zam. pokr. bagażnika
S318A
Autom. miękkiego zam. drzwi/bagażnika.
S318A
Podwójna osłona przeciwsłoneczna
S318A
Powierzchnia wewn. w kolorze nadwozia
S319A
Zintegrowana pilot uniwersalny
S320A
Brak napisu modelu
S321A
Zakr. wyp. zewn. w kolorze pojazdu
S321A
Napis
S322A
Funkcja dostępu komfortowego
S322A
Brak listwy chromowanej tylnej
S323A
S324A
Obr. BMW, st. le. styl. elips. 107
S324A
Spojler przedni i tylny
S325A
Tylny spoiler
Kod
Nazwa
S326A
Brak spojlera tylnego
S327A
Pasek ozd. na pokr. przedn., biały
S328A
Stopień, aluminium
S328A
Listwa progowa
S329A
Pasek ozd. na pokr. przedn., czarny
S331A
Obr. BMW, st. le. spr. gw. 102
S332A
BMW LA wheel turbine styling 106
S333A
Osłona przeciwwietrzna
S333A
Obr. BMW, st. le. spr. gw. 105
S334A
Obr. BMW, st. le. podw. spr. 71
S334A
Obr. BMW, st. le. podw. spr. 103
S338A
M Pakiet sportowy II
S339A
Shadow-Line
S340A
Listwy zderzakowe czarne
S340A
Zderzak częściowo lakierowany
Kod
Nazwa
S341A
Zderzak - w pełni lakierowany
S342A
Listwy wewnętrzne Titan Shadow
S343A
Wyposaż. wewn. Chrome Line mat.
S344A
Wyposaż. wewn. Alu Line
S345A
S346A
Wyp. zewnętrzne Chrome-Line
S347A
Wyposażenie. zewn. Titan Line
S348A
Wyposażenie zewn. Highlight
S349A
Wyposażenie wewn. Highlight
S350A
Szkło izolacji cieplnej zielone
S350A
Obręcz łączona BMW szpr. gw. 108
S351A
BMW LA wheel, star spoke 89
S352A
Pod. oszklenie izolacyjne
S353A
Przednia i tylna szyba z klinem zielon.
S354A
Szyba przednia ziel. z klinem ziel.
Kod
Nazwa
S355A
Oszklenie zespolone
S355A
Szyba przednia przezroczysta z kl.ziel.
S356A
Oszklenie zespolone Klimakomfort
S357A
Oszklenie ochronne
S358A
Szyba frontowa klimatyzacji komfort
S359A
Szkło izol. ciep. ziel./jas. szy. przed.
S359A
Pakiet przezroczysty
S360A
BMW LA wheel, star spoke 81
S361A
Obr. BMW, st. le. spr. rów. 82
S361A
Szyba obrotowa tylna
S362A
Szyba obrotowa elektryczna, tylna
S363A
S364A
Ogumienie ochronne
S365A
Ogumienie ochronne
S365A
Tylna szyba ze szkła bezpiecznego
Kod
Nazwa
S366A
BMW LA wheel, star spoke 70
S367A
Obr. MINI st. le. 8-Spoke 82
S368A
Obr. MINI st. le. 5, gwiazda 16"
S369A
Obr. MINI st. le. S-Spoke 85
S370A
Land Rover LM Rad Styling 1
S370A
Dach składany czarny
S371A
Obr. Land Rover st. le. Styling 2
S372A
Land Rover LM Rad Styling 3
S372A
Dach składany ciemnobrązowy
S373A
Land Rover LM Rad Styling 4
S373A
Dach składany granatowy
S374A
Obr. BMW, st. le. spr. rad.nstyling
S375A
Dach składany elektromech. czarny
S375A
Obr. BMW, st. le. podw. spr. 79
S376A
BMW LA wheel, star spoke 74
Kod
Nazwa
S376A
Dach składany elektromech. ciemnobrąz.
S377A
S377A
Dach składany elektromech. granatowy
S378A
S379A
BMW LA wheel Y-spoke 80
S380A
Przygotowanie pod Hardtop
S381A
Lust. zewn. czarne/Góra w kol. nadwozia
S382A
Lusterko zewn./góra biała
S383A
Lusterko zewn./góra czarna
S384A
Koło ze stopów lekkich białe lakierow.
S385A
Lusterko zewn./góra szara
S385A
Obr. MINI st. le. X-Lite 84
S385A
System bagażnika dachowego
S386A
Reling dachowy
S387A
Kod
Nazwa
S388A
S389A
Dach składany ciemnoszary
S390A
Dach składany klassisch-rot
S391A
S392A
Dach składany ciemnozielony
S393A
Dach składany turkusowy
S394A
Dach składany beżowy
S395A
System zabezp. na wypadek dachowania
S396A
Ogumienie ochronne
S397A
BMW LA wheel, star spoke 83
S398A
Dach skł. el.-mech., półautomatyczny
S399A
Dach skł. el.-mech., całk. automatyczny
S3ABA
Pokrywa lusterka w kolorze nadwozia
S3ACA
Zaczep holowniczy
S3ADA
Pasek ozd. na pokr. przedn., Park Lane
Kod
Nazwa
S3AEA
Pasek ozd. na pokr. przedn., Checkmate
S3AFA
Lusterko zewn./góra srebrna
S3AGA
Kamera jazdy wstecz
S3AHA
Kamera jazdy wstecz i Top View
S3AKA
Pasek na maskę silnika, srebrny
S3ALA
Zestaw John Cooper Works
S3AMA
Słupki C, srebrne mat.
S3ANA
Słupki C, srebrne
S3APA
Szyba przednia z klinem szarym
S3ARA
Zest. przygot. tylnego bagażnika
S3ASA
Reling dachowy srebrny
S3ATA
Reling dachowy, aluminium satynowane
S3AUA
Pasek Toffy na pokrywę silnika
S3AVA
Grafika Camden na pokrywę silnika
S3DVA
Przystawka bagażnika dachowego
Kod
Nazwa
S3MAA
Ind. reling dachowy alum. satynowane
S3MBA
Ind. linia wyp. wnętrza alum. satynow.
S3MCA
Ind. relingi dach. wys. poł. Shadow Line
S3XLA
X Line
S3YAA
Dach skł. antracyt z ozdobą srebrną
S3YBA
Dach składany granatowy z ozdob. srebr.
S3YDA
S3YEA
S400A
Dach przesuwno-uchylny obsług. ręcznie
S401A
Dach przesuwno-uchylny elektryczny
S402A
Dach panoramiczny elektryczny
S403A
Dach przesuwno-uchylny, elektryczny
S404A
DOUBLE COVER-SLIDING LIFTING ROOF
S405A
Lusterko zewn. chromowane
S406A
Dach rolowany
Kod
Nazwa
S410A
Siłownik szyby elektryczny przedni
S411A
Siłownik szyby elektryczny przedn/tylny
S412A
Podłoga ładunkowa bagażnika wyciągana
S413A
Siatka oddzielająca bagażnika
S414A
Roleta ochronna przezroczysta wzmocniona
S414A
Siatka na przedmioty po str. pasażera
S415A
Roleta przeciwsłoneczna tylna
S416A
Roleta przeciwsłoneczna tylna /boczna
S417A
Roleta przeciwsłoneczna drzwi tylna
S418A
Pakiet bagażnika
S419A
Pokrywa schowka na rękaw. z oświetl.
S420A
Przyciemniane szyby
S421A
Gaśnica halonowa 2 kg
S422A
Wer. drewna szlach. klon muszlowy
S423A
Dywaniki podłogowe Velours
Kod
Nazwa
S424A
Wykładzina podłogowa, czarna
S425A
Listwy wewnętrzne
S426A
Listwy wewnętrzne z aluminium
S427A
Wyp. wn., powierzchnia srebrna
S428A
Trójkąt ostrzegawczy i apteczka
S429A
Wyp. wn., powierzchnia antracyt
S430A
Lust. wew./zew. z automatyką przyciemn.
S431A
Wew. lust. wst. z automatyką przyciemn.
S432A
Czujn. deszczu/Lust. wew. Autom. ściemn.
S433A
Listwy wewnętrzne
S434A
Listwy wewnętrzne
S434A
Wyp. wn., powierzchnia aluminium
S435A
Wersja z drewna szlachetnego
S436A
Inst. płynn. przyciemn. lusterek
S436A
Kod
Nazwa
S437A
Tablica przyrządów, w kolorze czarnym
S437A
S438A
S439A
Listwy wewnętrzne
S439A
Listwy wewnętrzne chrom mat.
S440A
Pakiet dla niepalących
S441A
Pakiet dla palących
S442A
Uchwyt do napojów
S443A
Funkcja kompasu
S444A
Podłokietnik wielofunkcyjny
S445A
Pakiet stolików
S445A
konsola środk. przezn. na siedz. tylne
S447A
Wyposażenie wnętrza High Line
S449A
Lusterko do makijażu, z tyłu
S449A
Lusterko z rejestratorem myta w Japonii
Kod
Nazwa
S450A
Regulacja wysokości fotela pasaż.
S450A
aktywna wentylacja oparć fotela
S451A
Aktywny fotel kierowcy
S451A
Regulacja wysokości fotela pasaż. mech.
S452A
Syst. ułatw. wsiadania siedz. tyln.
S452A
Aktywne fotele z tyłu
S453A
Klimatyzowane fotele przednie
S454A
Regul. fotela elektr., strony kierowcy
S454A
Klimatyzowane fotele tylne
S455A
S455A
Aktywny fotel kierowcy/pasażera
S456A
Fotel komfort z pamięcią
S457A
Fotel kontur. el. z pamięcią
S458A
Regulacja fotela przedn. elektryczna
S459A
Elektryczna regulacja foteli z pamięcią
Kod
Nazwa
S459A
Regulacja fotela przedn. elektr. Memory
S460A
Fotel komfort siedz. tyln. reg. elektr.
S460A
Regulacja fotela tylna elektryczna
S461A
Regulacja oparć fotela elektr. tylna
S463A
Wyp. wn., powierzchnia Alloy Patina
S464A
Worek na narty
S465A
System załadunku
S466A
Listwa dachowa w kolorze nadwozia
S467A
Siedzenie tylne bez ukł. jednosiedz.
S467A
Taksówka-Tylne siedzenia z materiału
S468A
Worek na narty
S468A
System załadunku z workiem na narty
S469A
Wbudowane foteliki dla dzieci
S470A
System Isofix
S471A
Wyp. wn., powierzchnia grafit-metalik
Kod
Nazwa
S472A
Podłokietnik przedni kierowcy/pasażera
S473A
S474A
Brak podłokietnika przedniego
S475A
Podłokietnik przedni, z reg. kierownicy
S476A
Tapicerka drzwi, magnesium-grau
S477A
Wyp. wn., powierzchnia dekor. drew.
S481A
Fotel sportowy
S482A
Fotel sportowy i kierownica sportowa
S488A
Podparcie lędźwi kierowcy i pasażera
S489A
Podparcie lędźwi pasażera elektr.
S490A
Regulacja szerokości oparcia
S490A
Podparcie lędźwi do siedzeń tylnych
S492A
Schowek w konsoli środkowej
S493A
Zespół schowków
S494A
Podgrzwanie fotela kierowcy/pasażera
Kod
Nazwa
S495A
Pas bezp. trzypunkt. i zagł. tył środek
S496A
Podgrzewanie fotela tylne
S497A
Podłokietnik środkowy na kanapie
S498A
Zagłówki w siedzeniu tylnym mechaniczne
S499A
Zagłówki w siedzeniu tylnym elektryczne
S4A0A
S4A1A
Listwy wewnętrzne grafit mat
S4A3A
Wer. dr. szlach. drzewo orzech. jasne
S4A4A
Listwy wewnętrzne z aluminium "cirrus"
S4A5A
Kolor wypos. wnętrza Gotham grey
S4A6A
Kolor wypos. wnętrza tuscan-beige
S4A7A
Colour Line dark grey
S4A8A
Colour Line cream white
S4A9A
Colour Line mellow yellow
S4AAA
Podsufitka antracyt
Kod
Nazwa
S4ABA
Wer. dr. szlach. korzeń drzewa orzech.
S4ACA
Wer. dr. szlach. topolowy rys. słojów
S4ADA
Listwy wewn. alum., szlif. wzdłuż. dr.
S4AEA
Podłokietnik przedni, przesuwany
S4AFA
Podsufitka basalt-grau
S4AGA
Listwy wewnętrzne tytanowe matowe
S4AHA
Wer. dr. szlach. drzewo orzech ameryk.
S4AKA
Listwy wewnętrzne srebrne
S4ALA
Listwy wewnętrzne tytanowe ciemne
S4ANA
Wyp. wn., powierzchnia Seven
S4APA
Wyp. wn., powierzchnia Park Lane
S4ARA
Wyp. wn., powierzchnia Checkmate
S4ASA
Wer. dr. szlach. topol.rys.słojów szary
S4ATA
Listwy wewn., wysoki połysk, czarne
S4AUA
Rozszerzone zakresy dekoracji
Kod
Nazwa
S4AVA
Wyp. wn., powierzchnia Sidewalk
S4AZA
Wer. z dr.szl. bambus. rys. słoj. ciemn
S4B0A
Wer. dr. szl. mirt rys.słojów antracyt
S4B1A
Listwy wewnętrzne kaschmir-silber
S4B2A
S4B3A
Listwy wewnętrzne alum. szlif akcent.
S4B4A
Alu. strips ground lngthwise/Leather ins
S4B5A
W. z drew. szla. jes. rys. sł. wys. poł
S4B6A
Listwy wewn. alum."Flywheel" czarne
S4B7A
Wer. dr. szlach. "Fineline", wys. połysk
S4B8A
Wer. dr. szlach. korz. orzech./intarsje
S4B9A
Listwy wewnętrzne alum. drobno szlif.
S4BAA
Colour Line rooster red
S4BBA
Colour Line pacific blue
S4BCA
Wyp. wn., powierzchnia Fluid Silver
Kod
Nazwa
S4BDA
Wyp. wn., powierzchnia Piano black
S4BEA
Wyp. wn., powierzchnia English Oak
S4BFA
Wyp. wn., powierzch. Brushed Aluminium
S4BGA
Dummy-SALAPA
S4BKA
Listwy wewnętrzne alum., szlif. wzdłuż.
S4BLA
Kolor wypos. wnętrza redwood-red
S4BMA
Listwy wewnętrzne grafit mat jedw.
S4BNA
Wer. drewna szlach. jesion. rys. słojów
S4BPA
Wer. dr. szlach. topol.rys.słojów jasny
S4BRA
Interior surface, aluminium ground
S4BSA
Interior World Hot Chocolate
S4BTA
Dummy-SALAPA
S4BUA
Colour Line Hot Chocolate
S4BWA
Wer. z drewna szlach. klon. rys. słojów
S4BXA
Listwy wewn., wysoki połysk, szare
Kod
Nazwa
S4BYA
Wer. z drewna szlach. bambus antracyt
S4BZA
LISTWY WEWN. TYTANOWE JASNE
S4CAA
Wers.drew.szl.jesion.rys.słoj.antrac.
S4CBA
Wer. dr. szlach. "Fineline" naturalna
S4CCA
Aplikacja z drewna szl. do kier. skórz.
S4CDA
Listwy wewn. metalik ruthenium-grau
S4CEA
Wers. z dr. szlach. Fineline antracyt
S4CFA
Listwy wewnętrzne space-grau metalik
S4CGA
Listwy wewnętrzne "satin-silber" matowe
S4CHA
Wer. dr. szlach. "Fineline Wave"
S4CKA
Wer. dr. szlach. "Fineline" jasna
S4CLA
Listwy wewn. marrakesch-braun met.
S4CMA
Listwy wewn. platin-bronze metalik
S4CNA
COLOUR LINE TOFFY
S4CPA
COLOUR LINE TECH WHITE
Kod
Nazwa
S4CRA
Interieur Oberfläche toffy
S4CSA
S4CUA
COLOUR LINE CARBON BLACK
S4CVA
EDELHOLZAUSF.EICHE STAMMHOLZ HOCHGL
S4FAA
Fotel sportowy Recaro
S4FBA
Brak fotela sportowego
S4KSA
Contrast stitching
S4M0A
Ind. drew. szlach. topola naturalna
S4M1A
Ind. drew. szlach. mahoń maritim
S4M2A
Ind. składany stolik z tyłu
S4M3A
Listwy wewnętrzne alum. "cube pure"
S4M4A
Listwy wewn. alum. 3D silver grid
S4M4A
Ind. listwy alum. silver grid
S4M5A
Ind. tabl. przyrz., obciąg. skórą
S4M6A
Kontroler aluminiowy frezowany
Kod
Nazwa
S4M7A
S4M8A
Ind. lampki do czytania z tyłu
S4M9A
Ind. konsola tylna
S4MAA
M Fotel wielofunkcyjny
S4MBA
Interior line Style
S4MCA
Listwy wewnętrzne Carbon Fibre
S4MDA
Listwy wewnętrzne Fibre Net eis-grau
S4MEA
Wer. dr. szlach. drzewo orzech. madera
S4MFA
Regulacja szerokości oparcia dynamiczna
S4MFA
Dynamiczna regulacja szerokości oparcia
S4MGA
Listwy wewn. alum. glacier-silber
S4MKA
Wer. dr. szlach. oliwkowa carrara nat.
S4MKA
Wer. z drewna szlachetnego carrara
S4MLA
Listwy wewn. lakier. fortep. czarny
S4MMA
Ind. listwy obciągane skórą
Kod
Nazwa
S4MPA
Interieurleisten Alu dunkel Kreuzschliff
S4MRA
Listwy wewnętrzne z aluminium Hexagon
S4MSA
Listwy wewnętrzne alum. "Pentan"
S4MTA
List. wew. al. "Shadow" ciem.szczotk.
S4MUA
Wer. dr. szl. eukalip. prążk. czer. br.
S4MVA
Listwy wewnętrzne Alu "Micro"
S4MWA
Listwy wewn. Aluminium Carbon Shadow
S4MXA
List. wewn. alum., shadow szlif. wzdłuż.
S4MYA
List. wew., skóra strukt. karbon. czarn.
S4MZA
Drewno szl. platan. o sł.lustrz.antracyt
S4NAA
S4NBA
Autom. klimatyzacja z regul. 4 strefową
S4NCA
Wentylacja/ogrzewanie dodatkowe
S4NDA
Tablica przyrządów, obciągana skórą
S4NFA
Rozszerzony zakres klimatyzacji z tyłu
Kod
Nazwa
S4U1A
Aplikacja ceramiczna elementów ster.
S4UAA
Regulacja fotela półelektryczna
S4UBA
3. rząd foteli
S4UCA
Pedały "steel line"
S4UDA
Podłoga ładunkowa przesuwna
S4UEA
Tylna kanapa z regul. przód-tył
S4UFA
Sport button
S4UGA
Rear seat bench, 2-seat
S4UHA
Sport instruments
S4UKA
5-miejscowy
S4ULA
Płaska podłoga ładunkowa
S4UMA
Massage function in rear seat backrests
S4UNA
Otwór załad. z wbudowanym schowkiem
S4UPA
Adaptacyjny system mocujący
S4URA
Oświetlenie wnętrza dookoła
Kod
Nazwa
S4USA
2-seater preparation
S4UTA
Throughload opening w/int. transport bag
S4UUA
Gniazdko wtyczkowe 230V
S4UVA
Stoliki z tyłu
S4UWA
Gniazdko wtyczkowe 115V
S4UXA
Stoliki z tyłu
S4UYA
Torba na narty i snowboard
S4XAA
Dummy-SALAPA
S4XBA
Dummy-SALAPA
S4XDA
Dummy-SALAPA
S4XEA
Dummy-SALAPA
S4XHA
Dummy-SALAPA
S4XKA
Dummy-SALAPA
S4XLA
Dummy-SALAPA
S500A
Inst.czyszcz.refl./Czyszcz. intensywne
Kod
Nazwa
S502A
Spryskiwacze reflektorów
S507A
Park Distance Control z tyłu (PDC)
S508A
Park Distance Control (PDC)
S509A
Laserowy miernik odległości (LAM)
S510A
Regulacja zasięgu świateł
S512A
Brak regulacji długości świateł
S519A
Reflektor dodatkowy
S520A
Reflektor przeciwmgłowy
S521A
Czujnik deszczu
S522A
Światło ksenonowe
S523A
Klimatyzacja siedzenia ze skrz. chłodn.
S524A
Adaptacyjne doświetlanie zakrętów
S524A
Kontrola świateł mijania
S525A
Skrzynka chłodnicza
S526A
Brak klimatyzacji z tyłu
Kod
Nazwa
S527A
Filtr z węglem aktywnym do klimatyzacji
S527A
Brak lodówki / schowka
S528A
Autom. kontrola obiegu powietrza
S529A
Mikrofiltr
S530A
Klimatyzacja
S531A
All Season Roadster
S532A
Klimatyzacja ZG
S532A
Air Fresher
S533A
Klimatyzacja siedzenia tylnego
S534A
Automatyczna klimatyzacja
S536A
Ogrzewanie na postoju
S537A
Wentylacja na postoju
S538A
Ukryty zasobnik ciepła
S539A
Pilot ogrzewania na postoju
S539A
Klimatyzacja standardowa
Kod
Nazwa
S539A
Klimatyzacja standardowa z pilotem
S540A
Regulacja prędkości
S541A
Adaptive Cruise Control
S542A
Check-Control
S543A
Wskaźnik ciśnienia doładowania
S544A
Dynamiczna regulacja prędkości
S544A
Ind. wyposażenie
S544A
Regulacja prędkości z funkcją hamowania
S545A
Obrotomierz,km/h-Tacho,Zegar analog+EC
S545A
Dodatkowy wskaźnik temperatury oleju
S546A
Obrotomierz
S547A
Pakiet Cockpit Chrono
S548A
Licznik kilometrów
S549A
Zegar radiowy
S549A
Exklusiv-Uhr
Kod
Nazwa
S550A
Komputer pokładowy
S551A
Komputer pokładowy II z pilotem
S553A
Komputer pokładowy IV z pilotem
S554A
Komputer pokładowy V z pilotem
S555A
S556A
Wskazanie temperatury zewn.
S560A
Lamki do czytania w tylnym siedzeniu
S562A
Lampka do czytania
S563A
Lusterko do makijażu, podświetl.
S563A
Pakiet oświetlenia
S564A
Pakiet oświetlenia wnętrza
S570A
Silniejsze zasilanie prądem
S571A
S575A
Gniazdko wtyk. bagażnika z 2 akumul.
S577A
Instalacja samoch. do wynajęcia
Kod
Nazwa
S581A
Pakiet do taksówek
S582A
Dummy-SALAPA
S583A
Obr. BMW, st. le. Aero 90
S584A
S585A
S586A
Obr. MINI st. le. szprycha, całor.
S587A
S588A
Obr. BMW, st. le. spr. gw. 115
S589A
Obr. BMW, st. le. spr. gw. 122
S590A
Obr. BMW, st. le. spr. gw. 123
S591A
S592A
Obr. BMW, st. le. spr. rad. 118
S593A
Obr. BMW, st. le. podw. spr. 120
S594A
BMW light alloy wheel,spider spoke 92
S595A
Obr. BMW, st. le. styl. elips. 121
Kod
Nazwa
S596A
BMW light alloy wheel, V-spoke 126
S597A
S5AAA
Tylne światło przeciwmgłowe
S5ABA
Brak światła hamowania dwustopniowego
S5ACA
Asystent świateł drogowych
S5ADA
Ostrzeżenie przed opuszcz. toru jazdy
S5AEA
Układ hamowania z wysokich prędkości
S5AFA
SIDE UNDER MONITOR
S5AGA
Lane change warning
S5AHA
Dekodowanie dynamicznego światła hamow.
S5AKA
Elementy oświetleniowe LED
S5DAA
Dezaktywacja poduszki powietrznej pasaż.
S5DBA
Autom. pas 3-punktowy z tyłu na środku
S5DCA
Zagłówki w siedzeniu tylnym składane
S5DDA
Podnośnik samochodowy
Kod
Nazwa
S5DFA
Aktywna reg. prędkości+funkcja Stop&Go
S5DKA
Side view camera
S5DPA
Park Assist
S5DRA
Park Distance Control incl. Top View
S5DSA
Odryglowanie awaryjne bagażnika
S5DTA
DYNAMIC TRACTION CONTROL
S5GAA
Inst. autoalarmu
S5GBA
STOLEN VEHICLE TRACKING
S601A
Funkcja TV
S602A
Monitor pokładowy z TV
S603A
Ekran siedzenia tylnego
S604A
Personal Travel Assistent
S605A
BTX/Telefon
S605A
Instalacja Telematik
S606A
System nawigacji Business
Kod
Nazwa
S606A
Radionawigacja
S607A
Instalacja Teleservice
S607A
Komputer osobisty (PC)
S608A
System nawigacji z monitorem pokładowym
S608A
Travel Note System
S609A
System nawigacji Professional
S610A
Wyświetlacz Head-Up
S611A
Night Vision
S612A
BMW Assist
S613A
Usługi oparte o internet
S614A
Internet
S615A
Rozszerzona informacja BMW Online
S616A
BMW Online
S619A
System połączenia ratunkowego
S620A
Wejście głosowe
_________________
stones1
Tytuł: PostNapisane: 22 stycznia 2009, 14:33
Offline
Avatar użytkownika
Moje BMW: 535i
Kod silnika: N55
S621A
BMW Telefon BedienhĂśr.vorn C-Netz
S621A
Całk. zintegr. tel. komórkowy Korea
S622A
Słuch. podw. w siedz. tyln. telef. BMW
S623A
Telefon samochodowy sieci D (GSM)
S624A
Instalacja tel. kom. BMW (Siemens)
S624A
Instalacja słuchawkowa dla sieci C
S625A
Instalacja tel. kom. BMW (Motorola)
S625A
Telefon komórkowy sieć D
S626A
Telefon Siemens C2
S627A
Telefon Siemens C3 słuch z pan., przód
S627A
Instalacja tel. kom. BMW (Nokia)
S629A
Tel. sam. sieci D z czytn. kart z przod.
S630A
Telefon samoch. z słuchawką bezprzew.
S631A
Słuch. podw. w siedz. tyln. (bezprzew.)
S632A
Inst. tel. sieci C ze sł. z prz. i ty.
Kod
Nazwa
S632A
S633A
Inst. tel. Siemens ze sł. z przodu
S633A
Instalacja tel. kom. Business
S634A
Instalacja pod montaż telefonu sieci C
S635A
Instalacja pod montaż telefonu sieci D
S636A
Inst. mont. telef. kom. sieci D
S637A
Inst. tel. Siemens C3 ze sł. z przodu
S638A
Telefon samochodowy Professional
S639A
Instalacja tel. kom. kompl. USA/CDN
S640A
Instalacja pod montaż tel. uniwers.
S641A
Inst. mont. telef. BMW zakryta
S641A
Instalacja tel. kom. USA uniwersal.
S642A
Inst. mont. telef. BMW kompletna
S642A
Całk. zintegr. tel. kom., standard USA
S643A
Inst. tel. sam. sieci D dla Axicon
Kod
Nazwa
S644A
Instalacja tel. kom. z Bluetooth
S645A
Radio v
S646A
Instalacja pod montaż tel. na Japonię
S647A
Becker Mexico Electronic II o.VF
S648A
Radio Grundig 3883 RDS
S648A
Radio BMW CD
S649A
Napęd kaset
S650A
CD Napęd
S650A
Radio BMW Reverse
S651A
Stacja napędu MD
S651A
Radio BMW Reverse RDS
S652A
Radio Bavaria C II
S652A
Napęd DVD
S653A
High Definition Radio
S653A
Radio Bavaria C Reverse II
Kod
Nazwa
S653A
Radio cyfrowe BMW
S654A
Moduł odbiornika DAB
S654A
Radio Bavaria C III
S655A
Radio satelitarne BMW
S655A
Radio Bavaria C Business
S656A
Radio BMW Reverse/MINI Wave
S656A
Radio MINI MC
S656A
Radio Bavaria C Professional
S657A
Radio Bavaria C Reverse III
S657A
Radio BMW Business/MINI Boost
S658A
Radio BMW Business CD RDS
S659A
S659A
Radio Bavaria Electronic CD II
S660A
Radio BMW Reverse (C42)
S661A
Radio BMW Business (C43)
Kod
Nazwa
S662A
S663A
Radio BMW Professional CD
S663A
Radio BMW Professional (C44)
S663A
S664A
S664A
S664A
Tel. kom., standard USA
S665A
Radio BMW Business RDS
S666A
S667A
Radio BMW Audio
S667A
Radio BMW Professional RDS
S668A
S669A
S670A
S672A
Zmieniarka CD na 6 płyt CD
Kod
Nazwa
S673A
System HiFi USA
S674A
System HiFi Harman Kardon
S675A
System audio siedzenia tylnego
S675A
Sound System
S676A
System głośników HiFi
S677A
System HiFi Professional DSP
S678A
Inst. słuchawek w siedz. tylnym
S679A
Subwoofer systemu HiFi
S679A
Antena tylnej szyby
S680A
Antena radiowa ręczna
S681A
Antena dachowa
S682A
Siedzenie tylne z materiału
S683A
Antena tel., sieć D
S684A
Telefon. antena w tylnej szybie, sieć D
S685A
Antena tel., sieć C
Kod
Nazwa
S686A
Anteny Diversity
S687A
Instalacja radiowa
S689A
Instalacja do In-Car Video
S690A
Uchwyt kasety
S691A
Mocowanie CD
S692A
Instalacja zmieniarki BMW na 6 CD I-Bus
S693A
Instalacja radia satelitarnego BMW
S693A
Inst. głośników z tyłu
S694A
S695A
Zmieniarka MD
S695A
Pilot radia
S696A
Skrzynka CD
S696A
Zmieniarka DVD
S697A
Area-Code 1 do DVD
S697A
Automatyczna antena telefoniczna
Kod
Nazwa
S698A
Area-Code 2 do DVD
S699A
Area-Code 3 do DVD
S6A1A
ALWAYS OPEN TIMER
S6AAA
BMW Teleservices
S6ABA
Sterowanie teleserwisem
S6FAA
Instalacja systemu DVD z tyłu
S6FBA
Radio MINI Wave CD
S6FBA
Radio MINI CD
S6FCA
Radio MINI Boost CD
S6FDA
System głośników HiFi MINI
S6FEA
MASK Nowa Zelandia
S6FFA
System DVD z tyłu
S6FGA
Urządz. do rozrywki z tyłu
S6FHA
Urządz. do rozrywki z tyłu Professional
S6FKA
Obsł. audio na tylnym siedz.
Kod
Nazwa
S6FLA
Złącze USB-/Audio
S6FNA
Instalacja dla zmieniarki DVD
S6M1A
Ind. urządz. do rozrywki z tyłu
S6M2A
Ind. tył. poj. Infotainment online
S6NAA
Telefon samochodowy z tyłu
S6NBA
Rear-cabin telephone w/ cordless handset
S6NCA
Telephone with cordless keypad handset
S6NDA
Urz. gośnomów. Bluetooth + USB/Audio
S6NEA
Inst. tel. kom. Bluetooth + USB/Audio
S6NFA
Inst. Smartphone Bluetooth USB/Audio
S6NFA
Anbindung Music-Player im Mobilteil
S6UAA
Instalacja CCC
S6UBA
Instalacja systemu sterowania głosem
S6UCA
Instalacja montażowa funkcji TV
S6UDA
Wersja językowa, rosyjski
Kod
Nazwa
S6UEA
Zabezp. syst. nawig. DVD przed kradzieżą
S6UFA
System nawigacji, przygotowanie
S6UGA
System nawigacji MINI
S6UHA
Traffic Information
S6UKA
Night Vision z rozpozn. osób
S6VAA
Sterowanie CIC
S6VBA
Sterowanie CCC
S6VCA
Dummy-SALAPA
S700A
Area-Code 4 do DVD
S701A
Area-Code 5 do DVD
S702A
Area-Code 6 do DVD
S704A
M Podwozie sportowe
S705A
M Podwozie sportowe II
S708A
M Kierownica sportowa, skórzana
S709A
Kod
Nazwa
S710A
M Kierownica skórzana
S710A
M Kier. sport. wielofunk.
S711A
M Fotel
S712A
M Fotel sportowy
S713A
Tylny spoiler
S713A
Pakiet Off-Road
S715A
M Technic Pakiet aerodynamiczny
S716A
S717A
Wydanie Comfort
S718A
Pakiet wydania Exclusive
S719A
Wydanie Sport
S720A
Wydanie Sport Limited
S720A
Edition ZD
S721A
Edition ZB
S722A
Pakiet wydania Lifestyle
Kod
Nazwa
S722A
Edition ZF
S723A
S724A
Wydanie Sport
S724A
Edition ZH
S725A
Pakiet podstawowy
S725A
Edition ZE
S726A
Edition ZN
S727A
Edition ZO
S728A
Edition ZV
S729A
Wydanie dla importerów
S731A
Dodatkowy zakres edycji
S732A
Listwy wewnętrzne z wł. węglowych Pyrit
S733A
Listwy wewnętrzne, drewn. Yacht-Line
S736A
2. kluczyk do obsługi pilotem
S737A
Listwy wewnętrzne z aluminium, szczotk.
Kod
Nazwa
S738A
S739A
S750A
TV/wideo z tyłu (PAL)
S751A
TV/wideo z tyłu (NTSC)
S752A
Ind. system audio
S753A
Young-Line
S754A
M Spojler tylny
S755A
Składany dach przesuwny
S756A
Obr. BMW, st. le. spr. okr. indywid.
S757A
Ind. pakiet dźwiękowy
S759A
Pakiet familijny
S760A
Wysoki połysk Shadow-Line
S761A
Ind. oszklenie przeciwsłon.
S763A
Seria indyw. Japan
S764A
Wyposażenie High Line
Kod
Nazwa
S766A
Seria indyw. Japan
S767A
Seria indywidualna "Avus"
S767A
Performance Package
S767A
330i- wersja sportowa
S767A
Ind. sportowe
S768A
Seria indywidualna "Clubsport"
S768A
Seria ind. 95 Atlanta Olymp.Ed.
S769A
Seria indyw. 96 Japan
S770A
Listwy wewnętrzne alum. "silver cube"
S770A
Seria indyw. 96 Classic
S771A
Wydanie Sport
S771A
S772A
Wyposażenie luksusowe
S772A
Listwy wewnętrzne alum. "black cube"
S773A
Kod
Nazwa
S774A
S775A
Obicie podsufitki, antracyt
S776A
Obicie podsufitki Alcantara
S776A
Wyposażenie chromowane
S777A
Obudowa bagażnika Alcantara
S778A
Oznaczenie BMW Individual
S778A
Listwy wejściowe "BMW Individual"
S779A
Carbon Line
S780A
Obr. BMW, st. le. M spr. rów.
S781A
Obr. BMW, st. le. M Kontur
S782A
Obr. BMW, st. le. M System II
S782A
Podwozie NĂźrburgring
S783A
Obr. BMW, st. le. M podw. spr., kuta
S784A
M Lusterko zewnętrzne
S785A
Lampy kierunkowskazów białe
Kod
Nazwa
S786A
Czynności marketingowe dla kół 17"
S787A
S787A
S788A
S789A
S790A
Obr. BMW, st. le. M podw. spr. 97
S790A
Zbiornik dodatkowy
S791A
Skrzynka chłodnicza
S791A
M Technic Servotronic
S792A
Obr. BMW ze st. le. M 19" kuta
S793A
Sekw. skrzynia biegów M Drivelogic
S795A
Obręcz łączona BMW M podw.szpr. 71
S798A
Dach składany magenta (indywid.)
S7ARA
S7BAA
MINI Repair inclusive
Kod
Nazwa
S7BBA
S7BCA
S7BDA
S7BEA
S7BFA
S7BGA
S7BHA
S7BKA
S7CAA
BMW Repair inclusive
S7CBA
S7CCA
S7CDA
S7CEA
S7CFA
S7CGA
Kod
Nazwa
S7CHA
S7CKA
S7CLA
BMW REPAIR INCLUSIVE 4/120
S7D1A
Technika serwisowa BMW
S7D2A
Serwis BMW
S7D3A
Serwis BMW
S7D4A
BMW Service + Repair inklusive
S7D5A
Serwis BMW
S7D6A
Serwis BMW
S7D7A
BMW Basic Service inklusive
S7D8A
S7DAA
S7DBA
S7DCA
Serwis BMW
S7DDA
Kod
Nazwa
S7DEA
S7DFA
Serwis BMW
S7DGA
S7DHA
Serwis BMW
S7DKA
Serwis BMW
S7DLA
S7DMA
S7DNA
S7DPA
S7DRA
S7DSA
S7DTA
S7DUA
S7DVA
S7DWA
Kod
Nazwa
S7DXA
S7DYA
S7DZA
S7FAA
MINI Service inclusive
S7FBA
MINI Service + Repair inclusive
S7FCA
S7FDA
S7FEA
S7FFA
S7FGA
MINI Basic Service inklusive
S7FHA
S7M0A
Indywidualna kompozycja BMW I
S7M1A
Indywidualna kompozycja BMW II
S7M5A
Indywidualny pakiet wyposaż. zewn. BMW
S7M5A
M Zakres wyposażenia zewn.
Kod
Nazwa
S7MAA
Competition Paket
S7MEA
M Drivers Package
S7N1A
S7N2A
S7N3A
Serwis BMW
S7N4A
S7N5A
S7N6A
Serwis BMW
S7N7A
S7N8A
S7N9A
Serwis BMW
S7NAA
S7NBA
Serwis BMW
S7NCA
S7NDA
Serwis BMW
Kod
Nazwa
S7NEA
S7NFA
Serwis BMW
S7NGA
S7NHA
S7NKA
S7NLA
Serwis BMW
S7NMA
S7NNA
Serwis BMW
S7NPA
S7NRA
S7NSA
S7NTA
S7NUA
S7NVA
Serwis BMW
S7NWA
Kod
Nazwa
S7NXA
S7NYA
S7NZA
Serwis BMW
S7P1A
S7P2A
S7P3A
S7P4A
S7P5A
S7P6A
S7P7A
S7P8A
S7P9A
S7PAA
S7PBA
S7PCA
Kod
Nazwa
S7PDA
S7PEA
S7PFA
S7PGA
S7PHA
S7PKA
S7PLA
S7PMA
S7PNA
S7PPA
S7PRA
S7PSA
S7PTA
S7PUA
S7PVA
Kod
Nazwa
S7PWA
S7PXA
S7PYA
S7SNA
Naw. Business/Handyvorber. Bluetooth
S7SPA
Naw. Professional/Handyvorber. Bluetooth
S7T1A
Basic Service Inclusive
S7T2A
S7T3A
S7T4A
S7T5A
S7T6A
S7T7A
Serwis BMW
S7T8A
Serwis BMW
S7TAA
S7TBA
Kod
Nazwa
S7TCA
S7TDA
S7TEA
S7TFA
S7TGA
S7THA
S7TKA
S7TLA
S7TMA
S7TNA
S7TPA
S7TRA
S7TSA
S7TTA
S7TUA
Kod
Nazwa
S7TVA
S7TWA
S7TXA
S7TYA
S7TZA
S7U9A
Omission of BMW Service Inclusive
S7UAA
S7UBA
Serwis BMW
S7UCA
Serwis BMW
S7UDA
S7UEA
Serwis BMW
S7UFA
S7UGA
Serwis BMW
S7UHA
S7UKA
Serwis BMW
Kod
Nazwa
S7XAA
M leather st.wheel+shiftpaddle+multif.
S800A
Układ wydechowy kompletny, kraje
S803A
Brak trzeciego światła hamowania
S805A
S806A
Trzecie światło hamowania
S815A
Pakiet na złe drogi
S817A
Silnik zaprojekt. na 91 oktan
S818A
Główny wyłącznik akumulatora
S823A
Wersja dla krajów tropikalnych
S823A
Wersja dla ciepłych krajów
S825A
Radio dla Oceanii
S825A
Radio dla Oceanii
S826A
Podwozie w kompozycji eksportowej
S828A
Zderzak - warianty krajowe
S829A
Przygotowanie do modyfikacji Cabrio
Kod
Nazwa
S831A
Brak radia
S832A
akumulator w bagażniku
S834A
Rozmiar braków 330d Francja
S834A
Brak uchwytu na kasety
S835A
Wersja turystyczna dla USA
S836A
Brak Bavaria CD 6 Selektion
S837A
Brak systemu nawigacji
S837A
Brak systemu głośników HiFi
S839A
Sterowanie pozorne Awaria-SA
S840A
Dostos. do wysokich prędkości
S840A
Brak pilota do radia
S841A
Pozorny numer klucza pakietu OW
S842A
Wersja dla zimnych krajów
S843A
Redukcja mocy
S845A
Akustyczne ostrzeżenie o pasach
Kod
Nazwa
S847A
Inst. do samoch. opancerzonych
S847A
Akumulator dodatk. do sieci C telefonu
S848A
Rozszerzona wiązka kabli
S849A
Tyl. św. poz. dla danego kraju
S849A
Brak autom. syst. powiadamiania alarm.
S850A
Dodatkowe napełnienie zbiorn. na eksport
S851A
Wersja językowa, niemiecki
S852A
Wersja językowa, japoński
S853A
Wersja językowa, angielski
S854A
Wersja językowa, francuski
S855A
Wersja językowa, włoski
S856A
Wersja językowa, hiszpański
S857A
Instalacja automatycznej klimatyzacji
S858A
Silnik niskoprężny
S859A
Dekodowanie funkcji TV
Kod
Nazwa
S859A
Dostosowanie/sterowanie IHKA
S860A
Dodatkowe światło kierunkowskazu
S861A
Zestaw danych bez EOBD
S862A
Definicja normy spalinowej/COC
S862A
Fotel mat. z przodu w przyp.pakietu taxi
S863A
Spis dealerów, Europa
S864A
Spis dealerów za oceanem
S865A
Stoliki / Podpórki stóp z tyłu
S866A
Wersja językowa, chiński uproszczony
S866A
Service Card Niemcy
S866A
Wersja językowa, tradycyjny chiński
S867A
Wersja językowa, koreański
S868A
Instalacja radiowa do ZF/ZI
S868A
Wersja językowa, niderlandzki
S869A
Instalacja radiowa do ZG/ZZ
Kod
Nazwa
S869A
Wersja językowa, szwajcarska
S870A
Wyposażenie "Salt"
S871A
Wyposażenie "Pepper"
S872A
Wyposażenie "Chili"
S872A
S873A
Dummy-SALAPA
S874A
Częstotliwość radiowa 434 MHZ
S875A
Pilot na podczerwień
S876A
Częstotliwość radiowa 315 MHz
S877A
Brak obsługi krzyżowej
S878A
Oszkl. klim. komf. bez klina ziel.
S879A
Instrukcja obsługi po niemiecku
S880A
Instrukcja obsługi po angielsku
S881A
Instrukcja obsługi po francusku
S882A
Gutschrift fĂźr Erstausstattung
Kod
Nazwa
S883A
Instrukcja obsługi po hiszpańsku
S884A
Instrukcja obsługi po włosku
S885A
Instrukcja obsługi po szwedzku
S886A
Instrukcja obsługi po holendersku
S886A
S887A
Instrukcja obsługi, po arabsku
S888A
Instrukcja obsługi po duńsku
S889A
Instrukcja obsługi po fińsku
S889A
Instrukcja obsługi po portugalsku
S890A
Instrukcja obsługi po japońsku
S891A
Instrukcja obsługi po rosyjsku
S892A
Instrukcja obsługi, w trad. chińskim
S895A
Wentylator dodatkowy
S896A
Sterowanie św. do jazdy w dzień
S897A
Ciągły dźwięk do DWA
Kod
Nazwa
S898A
Wersja CKD
S899A
optyczne podawanie sygnałów do DWA
S8ABA
Joint Venture China
S8ACA
Dummy-SALAPA
S8ADA
Alpina Roadster S
S8AEA
Instr. obsł./Książka serw. po grecku
S8AFA
Instr. obsł./Książka serw. po koreańsku
S8AGA
CHAUFFEUR HANDBOOK IN ENGLISH
S8ARA
Owner‘s Handbook/Service Bklet, Romanian
S8ASA
Instr. obsł./książka serw. po chińsku
S8EBA
Steuerung Einzelbetriebserlaubnis
S8HAA
Dummy-SALAPA
S8L1A
Wymagania danego kraju dot. wyposażenia
S8LBA
S8LFA
S8LFA
Kod
Nazwa
S8LHA
S8LMA
S8LRA
Dummy-SALAPA
S8LSA
S8LTA
S8S1A
Dekodowanie świateł do jazdy w dzień
S8S2A
Kodowanie sygnału alarmowego
S8S3A
Automatyczne ryglowanie prz ruszaniu
S8S4A
Dekodowanie zmienn. rozkł. świateł
S8S5A
Brak przeciwpyłkowego filtru paliw.
S8S6A
Wstępna specyfikacja na eksport
S8S7A
Fleet vehicle without TV function
S8S8A
Country-specific navigation control
S8S9A
Dummy-SALAPA
S8SAA
Aktywacja nawigacji charakt. dla kraju
Kod
Nazwa
S8SBA
Aktywacja syst. telem. char. dla kraju
S8SCA
S8SDA
Zab. przed wjech. pod poj.,wer. kraj.
S8SEA
Wersja 4 miejscowa
S8SFA
Special Edition Sport
S8SGA
Special Edition Exklusive
S8SHA
Silnika na Tajlandię
S8SKA
Brak linii wewn. grafit metalik
S8SLA
Przygot. pod zaczep holowniczy
S8SMA
Numer podwozia widoczny od zewnątrz
S8SPA
Sterowanie COP
S8SPA
Sterowanie CO2
S8SRA
Special Edition Lifestyle
S8SSA
Sterownik specjalny Special Edtion
S8STA
Kodowanie częst. przeglądów, stopień 3
Kod
Nazwa
S8SUA
Numer podwozia Security
S8SVA
Urządzenie głośnomówiące
S8SWA
Folia ochronna na czas transportu
S8SXA
Przyp. operatora do Telematik-/Online D.
S8SYA
Dummy-SALAPA
S8SZA
Dekodowanie światła skrętu
S8TAA
Stop. wyjściowy radia M Drive
S8TBA
Pakiet akustyczny
S8TCA
Dummy-SALAPA
S8TDA
Dummy-SALAPA
S8TEA
Dummy-SALAPA
S8TFA
Aktywna ochrona pieszych
S8TGA
Zabezpieczenie antykradzieżowe
S8WAA
Dummy-SALAPA
S8WBA
Dummy-SALAPA
Kod
Nazwa
S900A
Elektroniczny immobilizer
S901A
Kontrola specjalna ogólna
S902A
Kontrola specjalna pojazdów prasowych
S903A
Pojazd fotograficzny
S904A
Kontrola specj. pojazdów kontroli typu
S905A
Kontrola specj. pojazdów prowadzących
S906A
S907A
Wydanie James Bond
S908A
Dummy-SALAPA
S909A
Dummy-SALAPA
S910A
Pojazd projekt. bez zasilania wymien.
S911A
Pojazd projekt. z zasilaniem wymiennym
S915A
Brak konserwacji pokrycia zewn.
S916A
Pojazd projekt. bez warstwy konserwacji
S917A
Konserwacja przed wodą morską
Kod
Nazwa
S918A
Alpina B3, wewn.
S919A
Drzwi aluminium
S920A
Alpina bez dok.
S921A
Alpina B8, wewn.
S922A
Chłodnica silnika Alpina
S923A
Brak Titan-Line
S923A
Atrapa chłodnicy wąska
S924A
Lusterko, szkło płaskie pasażera
S924A
Koło składane
S925A
Ochronny pakiet wysyłkowy
S926A
pełnowartościowe koło zapasowe
S927A
Uregulowanie dla turystów
S927A
Ogumienie całoroczne
S928A
Sterowanie opon
S929A
Dummy-SALAPA
Kod
Nazwa
S930A
Dummy-SALAPA
S931A
Opony zimowe zamiast letnich z fabryki
S932A
Dummy-SALAPA
S933A
Dummy-SALAPA
S934A
Dummy-SALAPA
S936A
Koła ze st. lekk. "OW"
S936A
BMW Handy b. Ausliefer. anfordern
S937A
Dummy-SALAPA
S938A
Seria indywidualna
S938A
Pakiet zimowy
S939A
Dummy-SALAPA
S940A
Wyposażenie na życzenie Klienta
S941A
Dummy-SALAPA
S942A
Storno życzenia specjalnego
S943A
Dummy-SALAPA
Kod
Nazwa
S944A
Późn. zmiana na indywid.
S945A
Dummy-SALAPA
S946A
Dummy-SALAPA
S947A
Dummy-SALAPA
S954A
Dummy-SALAPA
S960A
Ogranicznik kierowniczy
S961A
Silnik specjalny
S962A
Specjalna charakterystyka silnika
S962A
Brak podst. tabl. rejestr. przedniej
S963A
Silnika 2.4 l na Tajlandię
S964A
Przy dost. zażądać płyty DVD nawigacji
S964A
Sterowanie pozorne do LA/SA
S965A
Dod. wyposaż. specj. przednie +25kg
S966A
Dod. wyposaż. specj. przednie +50kg
S967A
Dod. wyposaż. specj. tylne +25kg
Kod
Nazwa
S968A
Dod. wyposaż. specj. tylne +50kg
S969A
S969A
Dod. wyposaż. specj. tylne +75kg
S970A
Pakiet Business
S976A
Oparcie wzmocnione
S978A
Pakiet innowacyjny
S979A
Pakiet Business II
S979A
Value Package
S980A
Pakiet Exklusiv
S982A
Hardtop
S983A
Dummy-SALAPA
S984A
Kodowanie dla krajów spoza UE
S984A
Kodowanie częstotliwości przeglądów
S985A
Radiowy zestaw uzupełn. dla USA
S986A
Dummy-SALAPA
Kod
Nazwa
S987A
Dummy-SALAPA
S988A
Brak radia
S988A
S989A
Dummy-SALAPA
S990A
Dummy-SALAPA
S991A
Dummy-SALAPA
S992A
Sterowanie mocowania tabl. rej.
S993A
Kod dla roku modelu w numerze FG
S994A
Dummy-SALAPA
S995A
Dummy-SALAPA
S996A
HEA ALT
S997A
Dummy-SALAPA
S998A
Dummy-SALAPA
S999A
Zarządzanie zleceniami HEA
S9AAA
Zabezp. zewn. pokrycia z tworzywa szt.
Kod
Nazwa
S9ABA
Zabezp. zew. pokr. z tworz. szt. - brak
S9AEA
Dummy-SALAPA
S9AWA
Dostawa do BMW na całym świecie
S9W1A
FAHRZEUGSTEUERUNG WERK
S9WRA
Koła zimowe
S9XAA
Pakiet ALPINA
SRA1A
Stół piknikowy
SRA2A
SRA3A
Uchwyt na puszkę z tyłu
SRA4A
Wysokojak. styl. zegar analog., przedni
SRA5A
Dywaniki podłogowe z owczej wełny
SRA6A
Dywaniki podłogowe przednie i tylne
SRA7A
Lusterko zewn. z automatyką przyciemn.
SRA8A
Podparcie stóp dla siedzenia tylnego
SRA9A
SRAAA
Wspomaganie zamykania tylnych drzwi
SRABA
Wbudowana aktówka
SRACA
Skrzynka na cygara
SRADA
Parasole w samochodzie
SRAEA
Rozszerzone wyposażenie ze skóry
SRAGA
Worek na ubranie bagażnika
SRAHA
Roleta do bagażnika
SRAKA
Osłona tabl. przyrz. fornirowana
SRALA
Osłona tabl. przyrz., obciąg. skórą
SRAMA
Obudowa bagażnika w kolorze nadwozia
SRAPA
Ramię kierownicy fornirowane
SRARA
Stoły piknikowe okleina, obustronne
SRASA
Zestaw do napojów do poj. siedzeń
SRAUA
RR logos on head restraints
SRAWA
Zestaw do napojów do tylnej kanapy
Kod
Nazwa
SRAXA
CONTRAST SEAT PIPING
SRAYA
Preparation Stolen Vehicle Tracking
SRB1A
Szprychy kierownicy, metalizowane
SRB2A
LIQUIDMETAL BONNET WINDSCREEN
SRB6A
ARMORED LIMOUSINE
SRC1A
Stal nierdzewna pakiet
SRC2A
Teak decking
SRC3A
Obudowy wnętrza, okleinowane
SRC4A
Rozszerz. pakiet wypos. drewnianego
SRC5A
Pakiet ze stali nierdz. na wysoki połysk
SRD1A
Lakierowanie dwukolorowe, strona
SRD2A
Lakierowanie dwukolorowe wokół
SRD3A
Linia ozdobna prosta
SRD4A
Linia ozdobna podwójna
SRD5A
Spirit of Ecstacy, wersja indywidualna
Kod
Nazwa
SRD6A
niebieski chromowany
SRD7A
Farba kontrastowa zewn.
SRD8A
Interior Mono Package
SRD9A
Linear Colour Package
SRE3A
Podgrzewanie fotela przednie i tylne
SRE4A
Uniwersalny pilot w lusterku wewn.
SRE5A
SRE7A
Wtyczka ładowania
SRE8A
SRE9A
Spirit of Ecstacy, opuszczanie elektr.
SREAA
Zasłonki z tyłu
SREBA
SRECA
SREDA
Zasłona elektryczna tylnej szyby
SREFA
Osł. przeciwsł. tylnej szyby oyster
Kod
Nazwa
SREGA
Osłona przeciwsł. tylnej szyby czarna
SREHA
Osłona przeciwsł. tyln. cz. poj. oyster
SREKA
Osłona przeciwsł. tyln. cz. poj. czarna
SRELA
Camera System
SREMA
Chłodziarka do poj. siedzeń
SRENA
Chłodziarka do tylnej kanapy
SREWA
EXTENDED WHEEL BASE
SRF1A
Koło Rolls-Royce ze st. lekk. chrom.
SRF2A
Osłona piasty, chromowana
SRF3A
Śr. kołpak koła z symbolem RR do wyboru
SRF4A
Koło Rolls-Royce, SL 21" Sport Style
SRF5A
Koło Rolls-Royce, SL 21" Sport Style,ch.
SRF6A
Osłona piasty, Sport Style chrom
SRF7A
Dummy-SALAPA
SRF8A
Opony całoroczne
Nazwa
SRF9A
Kołpak środ. seryj. koła w kol. nadwozia
SRFAA
Koło Rolls-Royce ze st. lek. 20"
SRFBA
Obr. RR, st. le. 20" chromowana
SRFCA
Obr. RR, st. le. Seven Spokes 21"
SRFDA
Obr. RR, st. le. Seven Spokes 21" poler.
SRFPA
21" 7 SPK.FORGED W. FULLY POLISHED
SRG1A
Obr. RR ze SL Star Design
SRG1A
Oszklenie Privacy
SRG2A
Oszklenie Privacy tylko tylna szyba
SRG3A
Oszklenie Privacy z przezr. przed. szybą
SRG4A
Oszk. chr. przed pr. podczerw, sz. bocz.
SRG5A
Oszklenie przeciwsłoneczne tylne
SRG7A
Podsufitka Cashmere, czarna
SRG8A
Leather Headlining
SRG9A
Kod
Nazwa
SRGPA
21" STAR FORGED W. FULLY POLISHED
SRH1A
Wer. drewna szlach. mahoń Crossbanding
SRH2A
Wer. dr. szlach. orzech włoski Crossb.
SRH3A
Wer. dr. szlach. korzeń orzecha włosk.
SRH4A
Wer. z dr. szl. dąb z rys. sł. crossb.
SRH5A
Wer. drewna szlach. dębow. rys. słojów
SRH6A
Wer. z dr. szlach. Ulme Cluster Crossb.
SRH7A
Wersja z drewna szlach. RĂźster Cluster
SRH8A
Wer. z drewna szlach. klon.Crossband.
SRH9A
Wersja z drewna szlach. klonowego
SRHAA
Wer. drewna szlach. czarny tulipan
SRHBA
Wersja z drewna szlach., palisander
SRHCA
SRHDA
Wer. drewna szlach. Piano Black
SRHEA
Drewn. wyposażenie wnętrza "Brown Oak"
Kod
Nazwa
SRHFA
Drewn. wyposaż. wnętrza "Chestnut Burr"
SRHGA
Wer. z dr.szlach. jesion czer. rys. sł.
SRHHA
Wer. z dr. szl. mahoń Flare crossb.
SRHKA
Wer. z dr. szl., palisander crossb.
SRHMA
Wer. z dr. szl. jesion z rys. sł. crossb
SRHNA
Drewn. wyposażenie wnętrza "Zebrano"
SRHPA
Wood Interior Santos Palisander
SRHRA
DARK WENGE STRAIGHT-GRAIN
SRK1A
System nawigacji z TV/monitorem pokład.
SRK2A
Rolls-Royce Assist
SRK5A
System sterowania głosem
SRL1A
Kierownica z obiciem
SRM1A
Widoczny numer silnika
SRM2A
Top Speed US/CDN
SRM3A
Końcówka rury wydech., widoczna
Kod
Nazwa
SRM6A
DRIVER`S PACKAGE
SRMKA
East Asia Edition
SRP1A
Pakiet Business I
SRP2A
Pakiet Business II
SRPDA
IPOD INTEGRATION
SRPPA
Partition Preparation
SRR5A
SRR6A
Zmieniarka DVD na 6 płyt
SRR7A
Płyta DVD nawigacji, Ameryka Północna
SRR8A
Płyta DVD nawigacji, Europa
SRR9A
Płyta DVD nawigacji, Zatoka Arabska
SRRAA
Płyta DVD nawigacji, Japonia
SRRBA
Płyta DVD nawigacji, Singapur i Malezja
SRRDA
Navi DVD China/Hongkong
SRREA
Navi DVD Korea
Kod
Nazwa
SRRSA
Podsufitka z mapą nieba
SRS1A
2 siedzenia indywidualne z tyłu
SRS2A
Dach przesuwno-uchylny przedni
SRS3A
Theatre Configuration Lounge Seat
SRS4A
Brak dachu przesuwnego przedn
SRS5A
Przygotowanie pod wkł. schowka na rękaw.
SRS6A
EXTENDED STORAGE OPTION
SRSCA
Podsufitka z mapą nieba "bamboo"
SRSDA
Podsufitka z mapą nieba "dark grey"
SRT1A
SRT3A
SRT4A
SRT5A
Kompl. instalacja telefonu kom.
SRT6A
Telefon zintegr. z pan. obsł., bezprz.
SRT7A
Instalacja tel. kom. przez Bluetooth
Kod
Nazwa
SRV1A
SRV2A
SRV3A
Dach składany niebieski
SRV4A
Dach składany czerwony
SRV5A
Dach składany zielony
SRV6A
Dach składany Metall-Optik
SRXLA
Extended boot
SRZ1A
Dummy-SALAPA
SV01A
Dummy-SALAPA
SV02A
Dummy-SALAPA
SV03A
Dummy-SALAPA
SV04A
Dummy-SALAPA
SV05A
Dummy-SALAPA
SV06A
Dummy-SALAPA
SV07A
Dummy-SALAPA
Kod
Nazwa
SV08A
Dummy-SALAPA
SV09A
Dummy-SALAPA
SV0AA
Dummy-SALAPA
SV0BA
Dummy-SALAPA
SV0CA
Dummy-SALAPA
SV0DA
Dummy-SALAPA
SV0EA
Dummy-SALAPA
SV0FA
Dummy-SALAPA
SV0GA
Dummy-SALAPA
SV0HA
Dummy-SALAPA
SV0IA
Dummy-SALAPA
SV0JA
Dummy-SALAPA
SV0KA
Dummy-SALAPA
SV0LA
Dummy-SALAPA
SV0MA
Dummy-SALAPA
Kod
Nazwa
SV0NA
Dummy-SALAPA
SV0OA
Dummy-SALAPA
SV0PA
Dummy-SALAPA
SV0QA
Dummy-SALAPA
SV0RA
Dummy-SALAPA
SV0SA
Dummy-SALAPA
SV0TA
Dummy-SALAPA
SV0UA
Dummy-SALAPA
SV0VA
Dummy-SALAPA
SV0WA
Dummy-SALAPA
SV0XA
Dummy-SALAPA
SV0YA
Dummy-SALAPA
SV0ZA
Dummy-SALAPA
SV10A
Dummy-SALAPA
SV11A
Dummy-SALAPA
Kod
Nazwa
SV12A
Dummy-SALAPA
SV13A
Dummy-SALAPA
SV14A
Dummy-SALAPA
SV15A
Dummy-SALAPA
SV16A
Dummy-SALAPA
SV17A
Dummy-SALAPA
SV18A
Dummy-SALAPA
SV19A
Dummy-SALAPA
SV1AA
Dummy-SALAPA
SV1BA
Dummy-SALAPA
SV1CA
Dummy-SALAPA
SV1DA
Dummy-SALAPA
SV1EA
Brak relingu dachowego
SV1FA
Brak tylnej kanapy
SV1GA
Dummy-SALAPA
Kod
Nazwa
SV1HA
Dummy-SALAPA
SV1IA
Dummy-SALAPA
SV1JA
Dummy-SALAPA
SV1KA
Dummy-SALAPA
SV1LA
Dummy-SALAPA
SV1MA
Dummy-SALAPA
SV1NA
Dummy-SALAPA
SV1OA
Dummy-SALAPA
SV1PA
Dummy-SALAPA
SV1QA
Dummy-SALAPA
SV1RA
Dummy-SALAPA
SV1SA
Dummy-SALAPA
SV1TA
Dummy-SALAPA
SV1UA
Dummy-SALAPA
SV1VA
Dummy-SALAPA
Kod
Nazwa
SV1WA
Dummy-SALAPA
SV1YA
Dummy-SALAPA
SV1ZA
Dummy-SALAPA
SV20A
Dummy-SALAPA
SV21A
Dummy-SALAPA
SV22A
Dummy-SALAPA
SV23A
Dummy-SALAPA
SV24A
Dummy-SALAPA
SV25A
Dummy-SALAPA
SV26A
Dummy-SALAPA
SV27A
Dummy-SALAPA
SV28A
Dummy-SALAPA
SV29A
Dummy-SALAPA
SV2AA
Dummy-SALAPA
SV2BA
Dummy-SALAPA
Kod
Nazwa
SV2CA
Dummy-SALAPA
SV2DA
Dummy-SALAPA
SV2EA
Dummy-SALAPA
SV2FA
Dummy-SALAPA
SV2GA
Dummy-SALAPA
SV2HA
Dummy-SALAPA
SV2IA
Dummy-SALAPA
SV2JA
Dummy-SALAPA
SV2KA
Dummy-SALAPA
SV2LA
Dummy-SALAPA
SV2MA
Dummy-SALAPA
SV2NA
Dummy-SALAPA
SV2PA
Dummy-SALAPA
SV2QA
Dummy-SALAPA
SV2RA
Dummy-SALAPA
Kod
Nazwa
SV2SA
Dummy-SALAPA
SV2TA
Dummy-SALAPA
SV2UA
Dummy-SALAPA
SV2VA
Dummy-SALAPA
SV2WA
Dummy-SALAPA
SV30A
Autom. miękkiego zamykania
SV31A
Dummy-SALAPA
SV32A
Dummy-SALAPA
SV33A
Dummy-SALAPA
SV34A
Dummy-SALAPA
SV35A
Dummy-SALAPA
SV36A
Dummy-SALAPA
SV37A
Dummy-SALAPA
SV38A
Dummy-SALAPA
SV39A
Dummy-SALAPA
Kod
Nazwa
SV3AA
Dummy-SALAPA
SV3BA
Dummy-SALAPA
SV3CA
Dummy-SALAPA
SV3DA
Dummy-SALAPA
SV3EA
Dummy-SALAPA
SV3FA
Dummy-SALAPA
SV3GA
Dummy-SALAPA
SV40A
Dummy-SALAPA
SV41A
Dummy-SALAPA
SV42A
Dummy-SALAPA
SV43A
Dummy-SALAPA
SV44A
Dummy-SALAPA
SV45A
Dummy-SALAPA
SV46A
Dummy-SALAPA
SV47A
Dummy-SALAPA
Kod
Nazwa
SV48A
Dummy-SALAPA
SV49A
Dummy-SALAPA
SV4AA
Dummy-SALAPA
SV4BA
Dummy-SALAPA
SV4CA
Dummy-SALAPA
SV4DA
Dummy-SALAPA
SV50A
Dummy-SALAPA
SV51A
Dummy-SALAPA
SV52A
Dummy-SALAPA
SV53A
Dummy-SALAPA
SV54A
Dummy-SALAPA
SV55A
Dummy-SALAPA
SV56A
Dummy-SALAPA
SV57A
Dummy-SALAPA
SV58A
Dummy-SALAPA
Kod
Nazwa
SV59A
Dummy-SALAPA
SV5AA
Dummy-SALAPA
SV5BA
Dummy-SALAPA
SV5CA
Dummy-SALAPA
SV5DA
Dummy-SALAPA
SV60A
Brak modułu DSC
SV61A
Zaczep holowniczy
SV62A
Airbag inert
SV62A
Antena
SV63A
Wyłącznik awaryjny silnika
SV63A
SV64A
Gaśnica + młotek bezpieczeństwa
SV64A
Zbiornik emisyjny
SV65A
Dummy-SALAPA
SV66A
Dummy-SALAPA
Kod
Nazwa
SV67A
Dummy-SALAPA
SV68A
Dummy-SALAPA
SV69A
Lusterko z funkcją składania
SV6AA
Dummy-SALAPA
SV6BA
Dummy-SALAPA
SV6CA
Dummy-SALAPA
SV6DA
Dummy-SALAPA
SV6HA
Dummy-SALAPA
SV6IA
Dummy-SALAPA
SV70A
Dummy-SALAPA
SV71A
Zbiornik spryskiwaczy reflektorów, prz.
SV72A
Tylny zbiornik do mycia, przednia cz.
SV73A
Schowek w tabl. przyrz.
SV74A
Dummy-SALAPA
SV75A
Dummy-SALAPA
Kod
Nazwa
SV76A
Dummy-SALAPA
SV77A
Pompa paliwowa wzmocniona
SV78A
Czujnik ABS wariant 1
SV79A
Czujnik ABS wariant 2
SV7AA
Dummy-SALAPA
SV7BA
Dummy-SALAPA
SV7CA
Dummy-SALAPA
SV7DA
Dummy-SALAPA
SV7EA
Dummy-SALAPA
SV7FA
Dummy-SALAPA
SV7GA
Dummy-SALAPA
SV7HA
Dummy-SALAPA
SV7IA
Dummy-SALAPA
SV80A
Zawias przedniej pokrywy
SV81A
Podsufitka 2-warstwowa
Kod
Nazwa
SV82A
Dummy-SALAPA
SV83A
Podstawa pod akumulator
SV84A
Wzmocnienie słupka D
SV85A
Dummy-SALAPA
SV86A
Dummy-SALAPA
SV88A
SV8AA
Dummy-SALAPA
SV8CA
Dummy-SALAPA
SV8DA
Dummy-SALAPA
SV8EA
Dummy-SALAPA
SV8FA
Dummy-SALAPA
SV8GA
Dummy-SALAPA
SV8HA
Dummy-SALAPA
SV8KA
Dummy-SALAPA
SV8LA
Dummy-SALAPA
Kod
Nazwa
SV8MA
Dummy-SALAPA
SV8NA
Dummy-SALAPA
SV8PA
Dummy-SALAPA
SV90A
Dummy-SALAPA
SV91A
Dummy-SALAPA
SV92A
Konstrukcja częściowa z dachem panoram.
SV99A
Dummy-SALAPA
SV9AA
Dummy-SALAPA
SV9BA
Dummy-SALAPA
SV9CA
Dummy-SALAPA
SV9DA
Dummy-SALAPA
SV9EA
Dummy-SALAPA
SV9FA
Dummy-SALAPA
SV9GA
Dummy-SALAPA
SV9HA
Dummy-SALAPA
Kod
Nazwa
SV9IA
Dummy-SALAPA
SV9JA
Dummy-SALAPA
SV9KA
Dummy-SALAPA
SV9LA
Dummy-SALAPA
SV9MA
Dummy-SALAPA
SV9NA
Dummy-SALAPA
SVDAA
Dummy-SALAPA
SVSBA
SVZ1A
Dummy-SALAPA
SVZ2A
Dummy-SALAPA
SVZ3A
Dummy-SALAPA
SVZ4A
Dummy-SALAPA
SVZ5A
Dummy-SALAPA
SVZ6A
Dummy-SALAPA
SVZ7A
Dummy-SALAPA
Kod
Nazwa
SVZ8A
Dummy-SALAPA
SVZAA
Dummy-SALAPA
SVZBA
Dummy-SALAPA
SVZCA
Dummy-SALAPA
SVZDA
Dummy-SALAPA
SVZEA
Dummy-SALAPA
SVZFA
Dummy-SALAPA
SVZGA
Dummy-SALAPA
SVZHA
Dummy-SALAPA
SVZKA
Dummy-SALAPA
SVZLA
Dummy-SALAPA
SVZMA
Dummy-SALAPA
SVZNA
Dummy-SALAPA
SVZPA
Dummy-SALAPA
SVZRA
Dummy-SALAPA
Kod
Nazwa
SVZSA
Dummy-SALAPA
SVZTA
Dummy-SALAPA
SVZUA
Dummy-SALAPA
SVZVA
Dummy-SALAPA
SVZWA
Dummy-SALAPA
SVZXA
Dummy-SALAPA
SVZYA
Dummy-SALAPA
SVZZA
Dummy-SALAPA
SXAAA
Ind. R.S. Infotainment online
SXABA
SXD1A
Special Edition carbon/złoto-brąz.
SXD2A
Special Edition stratus/ecru
SXD3A
Special Edition carbon/ecru
SXD4A
Special Edition stratus/złoto-brąz.
SXD5A
Ind. podsufitka Alcantara
Kod
Nazwa
SXE1A
Ind. dr. szlach. orzech amarone
SXE2A
Ind. drew. szl. klon perł. antracyt
SXE3A
Ind. dr. szlach. eukaliptus prążk.
SXE4A
Ind. dr. szlach. jesion czerw.-brąz.
SXE5A
Ind. drew. szl. platan czerw.-br. ciemny
SXE6A
Ind. drew. szl. orzech sat., honigbraun
SXE7A
Ind. listwy wewn., pianolack czarny
SXE8A
Ind. int. pianolack czarny z intarsją
SXL1A
Ind. intarsja w drewnie do kierownicy
SXL2A
Ind. intarsja w skórze do kierownicy
SXT1A
Ind. tab. przyrz. obita skórą
SZBBA
Test Workshop SA3
SZC1A
Reserviert fĂźr UX
SZC2A
Reserviert fĂźr UX
SZC3A
Reserviert fĂźr UX
Kod
Nazwa
SZC4A
Listwy wewn. BMW Performance, karbon
SZC5A
16" kpl. k. zim. szpr. podw. 268
SZC6A
18" kpl. k. zim. szprycha podw. 238
SZC7A
19" kpl. k. zim. szpr. podw. 238
SZC8A
19‘‘ kpl. k. zim. wieloszpr. 235
SZC9A
19‘‘ kpl. k. zim. spr. gwiaz. 251
SZCAA
18" kpl. k. zim. szpr. podw. 234
SZCBA
18‘‘ kpl. k. zim. spr. gwiaz. 250
SZD0A
16" LMR S-Winder R102
SZD1A
Gałka zm. bieg., BMW Performance
SZD2A
15‘‘ kpl. k. zim. 7 Hole Spoke R81
SZD3A
Elem. wyp. zew., karbon
SZD4A
Nakładki na błotniki w kolorze nadwozia
SZD5A
Produkty serwisowe
SZD6A
Flagi dachowe
Kod
Nazwa
SZD7A
15" LMR S-Star Spooler R100
SZD8A
15" LMR Rotator Spoke R101
SZD9A
16" LMR Double Spoke R87
SZDAA
17" LMR Crown Spoke R104
SZDBA
16" LMR Bridge Spoke R94
SZDCA
16" LMR 5-Star Blaster R103
SZDDA
17" LMR Flame Spoke R97
SZDEA
17" LMR Web Spoke Composite R98
SZDFA
16" WKR Double Spoke R87
SZDGA
16" WKR S-Winder R102
SZDHA
Dekor. dachu
SZDIA
Spoiler krawędzi dachu
SZDJA
Pasek dekoracyjny Sport Stripes
SZDKA
Pasek dekoracyjny Bonnet Stripes
SZDLA
Pielęgn. lakieru i felg
Kod
Nazwa
SZDMA
Czyszczenie szyb
SZDNA
Pielęgnacja wnętrza pojazdu
SZDOA
Pielęgn. Cabrio i Roadster
SZDPA
Aplikacje specjalne
SZDQA
navigation portable
SZDRA
Adapter kabla iPod
SZDSA
Adapter Snap-In Bluetooth
SZDTA
Torba ratunkowa
SZDUA
Junior Seat III
SZDVA
Skórzana dźwignia sterująca
SZDWA
Uchwyt dźwigni sterującej
SZDXA
Uchwyt hamulca ręcznego ze skóry
SZDYA
Reflektor dodatkowy
SZDZA
18" obr.st.le. szprycha podw. 125
SZE1A
Komponenty aerodynamiczne do pakietu M
Kod
Nazwa
SZE2A
SZE3A
SZE4A
Tylny spoiler
SZE5A
Osłona rury wydechowej
SZE6A
Sportowa Końcówka tłumika
SZE7A
Światła skrętu/przeciwmgielne
SZE8A
Tylne światła pozycyjne Black-Line
SZE9A
Białe tylne światła pozycyjne
SZEAA
Dodatkowe ksenonowe światła drogowe
SZEBA
Folia ochronna na lakier, przezroczysta
SZECA
Listwy zderzakowe
SZEDA
Gniazdo amortyzatora
SZEEA
Tylny wspornik
SZEFA
Osłony lusterek zewn.
SZEGA
Owiewka
Kod
Nazwa
SZEHA
Pasy mocujące do bagażnika
SZEIA
Mata dwustronna do przestrzeni ładunk.
SZEJA
SZEKA
Schowek tablicy przyrządów
SZELA
Produkty dla warsztatów
SZEMA
Osłona dolna pojazdu
SZENA
Plecak wielofunkcyjny
SZEOA
Przeciwpyłkowy filtr paliwowy
SZEPA
15" kpl. k. zim. 5 Star Spooler R100
SZEQA
16" kpl. k. zim Bridge Spoke, srebr. R94
SZERA
15" kpl. k. zim spr. krzyż. 42
SZESA
17" kpl. k. zim. szpr. podw. 79
SZETA
17‘‘ kpl. k. zim. spr. gwiaz. 57
SZEUA
17‘‘ kpl. k. zim. szprycha V 130
SZEVA
17‘‘ kpl. k. zim. spr. gwiaz. 200
Kod
Nazwa
SZEWA
Złącze USB do ACM
SZEXA
Listwy wejściowe drzwi, podświetlane
SZEYA
SZEZA
Skrobaczka do szyb
SZF1A
Etui na CD/DVD
SZF2A
Clean Bag
SZF3A
Halogenowa lampka do czytania
SZF4A
Latarka
SZF5A
Alum. podstawka na stopę
SZF6A
Alum. pedały
SZF7A
Wykładzina podłogowa tekstylna
SZF8A
Gumowa mata podłogowa
SZF9A
Nakładki na pedały ze stali nierdzewnej
SZFAA
Uchwyt pasa
SZFBA
Drewniany uchwyt hamulca ręcznego
Kod
Nazwa
SZFCA
Metalowy uchwyt hamulca ręcznego
SZFDA
Skórz. uchw. ham. ręczn. z klamrą dek.
SZFEA
Drewniane listwy wewnętrzne
SZFFA
Baby Seat 0+, z/bez ISOFIX
SZFGA
Junior Seat II
SZFHA
Junior Seat III
SZFIA
Junior Seat I-II, z/bez ISOFIX
SZFJA
Kierownica skórzana z drew. osł. dekor.
SZFKA
Sport. kierown. skórz. z osł. dekor.
SZFLA
Sport. gałka zmiany biegów
SZFMA
Skórzana gałka zm. bieg. z kl. dekor.
SZFNA
Sk. sport. gałka zm. bieg. z kl. dekor.
SZFOA
Seat cover BMW design
SZFPA
Obicie siedziska z owczej skóry
SZFQA
Kod
Nazwa
SZFRA
Ochrona przeciwsłoneczna
SZFSA
Mata ochr. krawędzi załad.
SZFTA
SZFUA
Skórz. dźwignia ster. z klamrą dekor.
SZFVA
Torba z tyłu
SZFWA
Zestaw kufrów
SZFXA
Wyposażenie dodatkowe ze skóry
SZFYA
Uchwyt do napojów
SZFZA
Pierścienie ozdobne
SZH1A
19" obr.st.le. szprycha krzyż. 145
SZH2A
19" obr.st.le. szprycha gwiaz. 146
SZH3A
19" obr.st.le. szprycha gwiaz. 147
SZH4A
19" obr.st.le. szprycha podw. 150
SZH5A
Asystent wielofunkcyjny
SZH6A
18" obr.st.le., szprycha V 206
Kod
Nazwa
SZH7A
Uchw. dźw. ster. Performance BMW
SZH8A
Uchwyt hamulca ręcznego Performance BMW
SZH9A
19" kpl. k. zim. szprycha V 257
SZHAA
16" kpl. k. let. obr. stalowa 12
SZHBA
18" obr. st.le. szprycha podw. 219M
SZHCA
18" obr. st.le. szprycha podw. 260M
SZJ1A
Uniwersalny podnośnik z adapterem
SZJ2A
Skrzynka składana
SZJ3A
Pokrowiec siedzenia tylnego
SZJ4A
Moduł uchwytu do napojów
SZJ5A
Wieszak na odzież
SZJ6A
Kieszeń chłodząca
SZJ7A
Kieszeń oparcia
SZJ8A
Uchwyt na parasol
SZJ9A
Moduł schowka
Kod
Nazwa
SZJAA
Skrzynka dachowa
SZJBA
Bagażnik podstawowy
SZJCA
Kosz bagażowy
SZJDA
Uchwyt na narty i snowboard
SZJEA
Mocowanie deski snowboardowej
SZJFA
Uchwyt na deskę surfingową
SZJGA
Uniwersalne mocowanie
SZJHA
Uchwyt na rower na zaczep holowniczy
SZJIA
Podnośnik do rowerów
SZJJA
Uchwyt na rower wyścigowy, zamykany
SZJKA
Uchwyt na rower turystyczny, zamykany
SZJLA
Mata przeciwpoślizgowa
SZJMA
Siatka bagażnika
SZJNA
Mata kształtowa do bagażnika
SZJOA
Klamki drzwi z flagami
Kod
Nazwa
SZJPA
Etui do kluczyków
SZJQA
Powierzchnie wewnętrzne
SZJRA
Pasy moc. do bagażnika
SZJSA
Kratki działowe bagażnika
SZJTA
Wanienka bagażnika
SZJUA
Folia ochronna krawędź załadunkową
SZJVA
Pokrywa ochronna komory ładunkowej
SZJWA
System Multifix
SZJXA
Uchwyt na torbę
SZJYA
Uprząż zabezpieczająca dla psów
SZJZA
Lusterka zewnętrzne do jazdy z przyczepą
SZK1A
Przyłącze AUX
SZK2A
Urządzenie głośnomówiące Universal
SZK3A
System BMW DVD Advanced
SZK4A
System BMW DVD do monitora centralnego
Kod
Nazwa
SZK5A
System BMW DVD Portable
SZK6A
Złącze iPOD
SZK7A
Radiowa nawigacja BMW
SZK8A
Cyfrowe mapy drogowe
SZK9A
Rear View
SZKAA
Side View
SZKBA
Elektron. ewidencja przebiegu pojazdu
SZKKA
Osłona krawędzi ładunkowej
SZKLA
Driver Utility Set
SZKMA
Gummifussmatte Klassik
SZKNA
Popielniczka
SZKOA
20‘‘ WKR Y-Speiche 214
SZL0A
21" obr.st.le. szprycha podw. 215
SZL1A
16" obr.st.le. szprycha radialna 50
SZL2A
17" obr.st.le. szprycha podw. 178
Kod
Nazwa
SZL3A
17" obr.st.le. szprycha krzyż. 144
SZL4A
18" obr.st.le. szprycha podw. 129
SZL5A
18" obr.st.le. szprycha podw. 182
SZL6A
18" obr.st.le. szprycha podw. 195
SZL7A
18" obr.ze st.le. szpr. pod. obr. łącz71
SZL8A
18" obr.st.le. szprycha radialna 196
SZL9A
18" obr.st.le. szprycha gwiaz. 180
SZLAA
18" obr.st.le. szprycha gwiaz. 181
SZLBA
18" obr.ze st.le. szpr. gw. obr. łącz179
SZLCA
19" obr.st.le. szprycha podw. 125
SZLDA
19" obr.ze st.le. szpr. rad.obr.łącz 198
SZLEA
19" obr.st.le. szprycha gwiaz. 128
SZLFA
19" obr.st.le. szprycha gwiaz. 199
SZLGA
19" obr.st.le. szpr. rad. dwukol.190
SZLHA
19" obr.ze st.le. szpr. gw. obr. łącz179
Kod
Nazwa
SZLIA
18" obr. M ze st.le. szprycha podw. 184
SZLJA
18" obr.st.le. szprycha gwiaz. 89
SZLKA
18" obr.st.le. szprycha radialna 32
SZLLA
19" obr. M ze st.le. szpr. krzyż. 101 M
SZLMA
21" obr.st.le., szprycha V 239
SZLNA
21" obr.st.le. szprycha podw. 275
SZLOA
18" obr.st.le. szprycha krzyż. 197
SZLPA
18" obr.st.le. szprycha radialna 216
SZLQA
18" obr.st.le. Perform. szpr. podw. 269
SZLRA
18" obr.st.le. Star Spoke R95
SZLSA
18" obr.st.le. Double Spoke Compos. R109
SZLTA
18" obr.st.le. Double Spoke R105
SZLUA
17‘‘ kpl. k. zim. spr. gwiaz. 165
SZLVA
18‘‘ kpl. k. zim. spr. gwiaz. 153
SZLWA
18‘‘ kpl. k. zim. spr. gwiaz. 69
Kod
Nazwa
SZLXA
SZLYA
Fartuch błotnika
SZLZA
Łańcuchy przeciwślizgowe
SZM1A
Linka/drążek holowniczy
SZM2A
Gaśnica proszkowa
SZM3A
Kable rozruchowe w orygin. torbie BMW
SZM4A
Apteczka
SZM5A
Podnośnik samochodowy - zestaw
SZM6A
SZM7A
Kamizelka odblaskowa
SZM8A
Pokrowiec Car Cover
SZM9A
Non Paints
SZMAA
Kufer z powłoką twardą
SZMBA
Paints
SZMCA
Tylny bagażn.z uchw. nary/desek snowb.
Kod
Nazwa
SZMDA
Zestaw Mobility
SZMEA
Kanister na paliwo w kole zapasowym
SZMFA
System Hifi Alpine
SZMGA
Alum. poprz. gniazd amort. BMW Perform.
SZMHA
17" kpl. k. zim. szpr. podw. 116
SZN1A
Zestaw Side Scuttles
SZN2A
Osłona wlotu powietrza
SZN3A
Listwa uchwyt. klapy tylnej
SZN4A
Czasza lusterka wewnętrznego
SZN5A
Accessory Control Menu ACM
SZN6A
Słuchawki na podczerwień
SZN7A
DVB-T Settop-Box
SZN8A
Wspomaganie przy ruszaniu
SZN9A
Listwy prog. drzwi BMW Performance
SZP1A
Układ hamulcowy BMW Performance
Kod
Nazwa
SZP2A
System wlotu pow. BMW Performance
SZP3A
System tłumika BMW Performance
SZP4A
Skr. skoku dź. zm. bieg. BMW Performance
SZP5A
Podwozie BMW Performance
SZP6A
Pasek ozdobny BMW Performance
SZP7A
17‘‘ kpl. k. zim. spr. gwiaz. 256
SZP8A
Sportowa kierownica BMW Performance
SZP9A
Listwy wewnętrzne karbon
SZPAA
Fotel sportowy BMW Performance
SZPBA
18‘‘ kpl. k. zim. szprycha V 254
SZPCA
Poprz. gn. amort. BMW Performance, karb.
SZPDA
Adapter Snap-In ze złączem USB
SZPEA
Alum. podst. na stopę BMW Performance
SZPFA
Alum. nakł. na pedały BMW Performance
SZPGA
Torba na multimedia
Kod
Nazwa
SZPHA
Pakiet aerodynam. BMW Performance
SZPIA
Telematik Plattform Accessory
SZPJA
Przyrządy dodatkowe
SZPKA
18‘‘ kpl. k. zim. spr. gwiaz. 99
SZPLA
18" kpl. k. zim. szpr. podw. 93
SZPMA
18‘‘ kpl. k. zim. wieloszprych. 94
SZPNA
Torba wewnętrzna do kufra z powł. twardą
SZPOA
16‘‘ kpl. k. zim. spr. gwiaz. 104
SZPPA
Siatka na przedmioty w przestrz. przyp.
SZPQA
18‘‘ kpl. k. zim. spr. gwiaz. 209
SZPRA
18" kpl. k. zim. spr. krzyż. 177
SZPSA
15" obr.st.le. Star Spoke R86
SZPTA
Zest. śr. pielęgnacyjnych
SZPUA
18" obr.st.le. szprycha podw. 238
SZPVA
17" obr.st.le. szprycha gwiaz. 158
Kod
Nazwa
SZPWA
19‘‘ kpl. k. zim. szprycha Y 211
SZPXA
19" obr.st.le. szprycha podw. 75
SZPYA
18" kpl. k. zim. szpr. podw. 270M
SZPZA
20" obr.st.le. szprycha gwiaz. 87
SZQ1A
Dekoracyjna osłona kierownicy
SZQ2A
17" obr.st.le. M szprycha podw. 207
SZQ3A
18" obr.st.le. M szprycha gwiaz. 193
SZQ4A
17" obr.st.le. szprycha gwiaz. 122
SZQ5A
17" obr.st.le. szprycha gwiaz. 138
SZQ6A
17" obr.st.le. szprycha gwiaz. 90
SZQ7A
17" obr.st.le., szprycha V 141
SZQ8A
17" obr.st.le. szprycha gwiaz. 142
SZQ9A
17" obr.st.le. szprycha gwiaz. 105
SZQAA
17" obr.st.le. szprycha podw. 161
SZQBA
18" obr.st.le. szprycha gwiaz. 123
Kod
Nazwa
SZQCA
18" obr.st.le. szprycha gwiaz. 124
SZQDA
18" obr.st.le. szprycha podw. 93
SZQEA
18" obr.st.le. szprycha radialna 118
SZQFA
18" obr.st.le., szprycha V 217
SZQGA
18" obr.st.le., szprycha Y 114
SZQHA
18‘‘ obr.st.le. styliz. elipsoid. 107
SZQIA
18‘‘ obr.st.le. styliz. elipsoid. 162
SZQJA
18" obr.st.le. szprycha gwiaz. 74
SZQKA
19" obr.st.le. szprycha gwiaz. 95
SZQLA
19" obr.st.le., szprycha Y 191
SZQMA
19" obr.st.le., szprycha V 63
SZQNA
20" obr.st.le., szprycha Y 214
SZQOA
16" obr.st.le. szprycha radialna 139
SZQPA
16" obr.st.le. szprycha gwiaz. 140
SZQQA
19" obr.st.le. szprycha podw. 238
Kod
Nazwa
SZQRA
Dekoracyjna osłona przeł. zmiany biegów
SZQSA
15‘‘ WKR Star Spoke R86
SZQTA
16‘‘ WKR Double Spoke R88
SZQUA
16‘‘ WKR X-Lite Styling R84
SZQVA
17‘‘ WKR S-Spoke R85
SZQWA
16‘‘ kpl. k. zim. 7-sprych. R92
SZQXA
15‘‘ kpl. k. zim. 8-sprych. R82
SZQYA
18" obr. M ze st.le. szpr. krzyż. 101 M
SZQZA
20" obr. M ze st.le. szpr. krzyż. 101 M
SZR0A
19" obr.st.le. Perform. szpr. podw. 269
SZR1A
16" obr.st.le. szprycha radialna 32
SZR2A
17" obr.st.le. szprycha radialna 32
SZR3A
21" obr.st.le. szprycha gwiaz. 128
SZR4A
17" obr.st.le. szprycha gwiaz. 199
SZR5A
19" obr.st.le. szprycha gwiaz. 89
Kod
Nazwa
SZR6A
17" obr.st.le. szprycha krzyż. 238
SZR7A
18" obr.st.le. szprycha krzyż. 238
SZR8A
19" obr.st.le. szprycha krzyż. 238
SZR9A
20" obr.st.le. szprycha krzyż. 238
SZRAA
21" obr.st.le. szprycha krzyż. 238
SZRBA
20" obr.st.le. szprycha krzyż. 177
SZRCA
19" obr.st.le. szprycha krzyż. 177
SZRDA
18" obr.st.le. szprycha krzyż. 177
SZREA
17" obr. st.le. szprycha podw. 207M
SZRFA
18" obr. st.le. szprycha podw. 135M
SZRGA
19‘‘ kpl. k. zim. szprycha V 223M
SZRHA
19" obr. st.le. szprycha podw. 172M
SZRIA
Folia chron. przed uderz. kamieni
SZRJA
17" obr.st.le. szprycha podw. 238
SZRKA
16‘‘ kpl. k. zim. spr. gwiaz. 102
Kod
Nazwa
SZRLA
17‘‘ kpl. k. zim. spr. gwiaz. 90
SZRMA
17" kpl. k. zim. szpr. podw. 103
SZRNA
17" kpl. k. zim spr. krzyż. 133
SZROA
19‘‘ kpl. k. zim. M szprycha V 298M
SZRPA
17" koło dojazdowe stylizacja 84
SZRQA
19" kpl. k. zim. spr. krzyż. 177
SZRRA
19" obr.st.le. szprycha gwiaz. 230
SZRSA
Shoe Case
SZRTA
18" obr.st.le. szprycha gwiaz. 246
SZRUA
18" obr.st.le. szprycha podw. 247
SZRVA
18‘‘ kpl. k. zim. spr. gwiaz. 74
SZRWA
20" obr.st.le., szprycha Y 149
SZRXA
Torba na koło dojazdowe
SZRYA
19‘‘ kpl. k. zim. spr. gwiaz. 232
SZRZA
20" obr.st.le. szprycha radialna 32
Kod
Nazwa
SZS1A
20" obr.st.le., szprycha V 168
SZS2A
19‘‘ obr.st.le. wz. spr. 176
SZS3A
Kpl. BMW Performance Power
SZS4A
17" kpl. k. zim. spr. gwiaz. 276
SZSZA
Elektr. zespół napędowy
SZV0A
18" LMR Cross Spoke R113
SZV1A
16‘‘ obr.st.le. Cross Spoke R90 jednocz.
SZV2A
17‘‘ obr.st.le. Cross Spoke Compos. R90
SZV3A
17‘‘ obr.st.le. Double Spoke R99
SZV4A
17‘‘ obr.st.le. S-Spoke R85
SZV5A
17‘‘ obr.st.le. Multi Spoke R108
SZV6A
Kapturki na zawory MINI
SZV7A
Folia przeciwsłoneczna
SZV8A
Uchwyt tablicy rejestracyjnej
SZV9A
17" LMR Cross Spoke Challenge R112
Kod
Nazwa
SZVAA
17" kpl. k. zim. Cross Spoke R114
SZW0A
15" kpl. k. zim. obr. stalowa 12
SZW1A
16‘‘ kpl. k. zim. styl trap.134
SZW2A
16‘‘ kpl. k. zim. spr. gwiaz. 115
SZW3A
16" kpl. k. zim. szpr. radialna 50
SZW4A
16" kpl. k. zim. szpr. radialna 139
SZW5A
16‘‘ kpl. k. zim. szprycha V 229
SZW6A
16" kpl. k. zim. szpr. podw. 156
SZW7A
16" kpl. k. zim. szpr. radialna 32
SZW8A
16‘‘ kpl. k. zim. spr. gwiaz. 155
SZW9A
16" kpl. k. zim. obr. stalowa 12
SZWAA
16‘‘ kpl. k. zim. spr. gwiaz. 151
SZWBA
16‘‘ kpl. k. zim. spr. gwiaz. 140
SZWCA
17" kpl. k. zim. szpr. radialna 244
SZWDA
17‘‘ kpl. k. zim. spr. gwiaz. 138
Kod
Nazwa
SZWEA
17‘‘ kpl. k. zim. spr. gwiaz. 243
SZWFA
17‘‘ kpl. k. zim. spr. gwiaz. 122
SZWGA
17‘‘ kpl. k. zim. spr. gwiaz. 117
SZWHA
17‘‘ kpl. k. zim. szprycha V 110
SZWIA
17" kpl. k. zim. szpr. podw. 111
SZWJA
17" kpl. k. zim. szpr. podw. 112
SZWKA
17‘‘ kpl. k. zim. szprycha V 141
SZWLA
17‘‘ kpl. k. zim. spr. gwiaz. 199
SZWMA
17" kpl. k. zim. szpr. radialna 32
SZWNA
17‘‘ kpl. k. zim. spr. gwiaz. 158
SZWOA
17‘‘ kpl. k. zim. spr. gwiaz. 159
SZWPA
18" kpl. k. zim. szpr. radialna 118
SZWQA
18" kpl. k. zim. szpr. podw. M 184
SZWRA
18" kpl. k. zim. szpr. podw. M 164
SZWSA
18‘‘ kpl. k. zim. spr. gwiaz. 143
Kod
Nazwa
SZWTA
Rozdzielacz schowka na rękawiczki
SZWUA
Wnęki w konsoli środkowej
SZWVA
17" kpl. k. zim. obr. stalowa 12
SZWWA
17‘‘ kpl. k. zim. spr. gwiaz. 105
SZWXA
Podłokietnik środkowy ze schowkiem
SZWYA
17" obr.st.le. szprycha krzyż. 133
SZWZA
17" obr. st. le. szprycha podw. 71
SZX0A
JCW Gear Shift Indicator
SZX1A
Pakiet aerodynamiczny JCW
SZX2A
JCW Tylny spoiler karbon
SZX3A
JCW Klamka tylnej klapy karbon
SZX4A
JCW Osłony lusterek zewnętrznych karbon
SZX5A
JCW Osłona wlotu powietrza karbon
SZX6A
JCW Hamulec sportowy
SZX7A
Perforowana tarcza hamulcowa JCW
Kod
Nazwa
SZX8A
JCW Łącznik gniazd amortyzatorów
SZX9A
JCW Car Cover
SZXAA
JCW Fotel sportowy, skóra
SZXBA
JCW Koło kierownicy, skóra
SZXCA
JCW Osłona, karbon
SZXDA
JCW Gałka zm. bieg. z klamrą karbonową
SZXEA
JCW Mieszek gałki zmiany biegów
SZXFA
JCW Uchwyt ham. ręczn. z klamrą karbon.
SZXGA
JCW Listwa wejściowa z logo
SZXHA
JCW Mata podłogowa z Checkered Flag
SZXIA
Zestaw tuningowy JCW
SZXJA
JCW Podwozie sportowe
SZXKA
JCW Sprężyna śrubowa czerwona
SZXLA
JCW Side Scuttles, komplet osłon ozdobn.
SZXMA
16" obr.st.le. Double Spoke R88
Kod
Nazwa
SZXNA
17" kpl. k. zim. Flame Spoke R97
SZXOA
20" obr.st.le. szprycha podw. 238
SZXPA
21" obr.st.le. szprycha podw. 238
SZXQA
21" obr.st.le. szprycha krzyż. 312
SZXRA
21" obr.st.le. szprycha gwiaz. 311
SZXSA
19" obr.st.le. szprycha gwiaz. 311
SZXTA
18" obr.st.le. szprycha gwiaz. 311
SZXUA
17" obr.st.le. szprycha gwiaz. 276
SZXVA
19" obr.st.le. szprycha gwiaz. 276
SZXWA
18" obr.st.le. Perform. szpr. podw. 313
SZXXA
19" obr.st.le. Perform. szpr. podw. 313
SZXYA
17" koło dojazdowe stalowe
SZXZA
Osł. krawędzi załad., podśw.
SZZAA
SZZBA
Ogrzew. na postoju/wentyl. na postoju
Kod
Nazwa
SZZCA
Element obsługi ogrzewania na postoju
L801A
Wersja krajowa Niemcy/Austria
L801A
L802A
Wersja krajowa Korea
L804A
Wersja krajowa Szwajcaria
L807A
Wersja krajowa Japonia
L808A
Wersja krajowa Izrael
L809A
Wersja krajowa Dania
L810A
Wersja krajowa Australia
L811A
Wersja krajowa Belgia
L812A
Wersja krajowa Anglia / Irlandia
L812A
Wersja krajowa Wielka Brytania
L813A
Wersja krajowa Francja
L814A
Wersja krajowa Włochy
L816A
Wersja krajowa Europa Środkowa
Kod
Nazwa
L819A
Wersja krajowa Hiszpania
L820A
Wersja krajowa Ameryka Łacińska
L821A
Wersja krajowa Egipt
L822A
Wersja krajowa Golf
L824A
Wersja krajowa Ameryka Południowa
L827A
Wersja krajowa Skandynawia
L830A
Wersja krajowa dla krajów półn.
L833A
Wersja krajowa Singapur
L838A
Wersja krajowa Kanada
L846A
Wersja krajowa Taiwan
L8AAA
Wersja krajowa Chiny
L8LAA
National version, India
P237A
Pakiet dynamiki jazdy
P330A
Pakiet sportowy
P335A
Seria indyw. 95 Special Exec.
Kod
Nazwa
P336A
M Pakiet sportowy
P336A
Pakiet sportowy
P337A
M Pakiet sportowy
P338A
Dummy-SALAPA
P446A
Wyposażenie specjalne siedzenia tylnego
P448A
Wyposażenie High Line Top
P462A
Fotel komfort ze stolikiem
P505A
Inst.czyszcz.refl.,św.p-mgl.,refl.tyln.
P535A
Elektroniczna regelacja temperatury
P535A
Pakiet klimatyzacji komfort
P580A
Pakiet do taksówek
P581A
Pakiet do taksówek
P626A
Pakiet komunikacyjny telefonu kom.
P628A
Pakiet komunikacji
P671A
Radio Busin./CD Changer/HiFi-Sys.
Kod
Nazwa
P703A
Pakiet na Europę Wschodnią
P706A
Dummy-SALAPA
P714A
Pakiet luksusowy
P730A
Ind. seria specjalna
P730A
Pakiet Advantage
P734A
Pakiet Levant
P735A
Basic Package
P740A
Edition ZD
P741A
Edition ZB
P742A
Edition ZF
P743A
Wydanie na rynki specjalne
P744A
Edition ZH
P745A
Edition ZE
P746A
Edition ZN
P747A
Edition ZO
Kod
Nazwa
P748A
Edition ZV
P749A
P758A
Ind. Luxus-Compact
P762A
Seria indyw. 95 Selection Japan
P763A
Ind. dla Brazylii
P765A
Motorsport Edition ZA
P777A
Motorsport International
P7A1A
MINI Sidewalk
P7A2A
Innovation pack II
P7A3A
Pakiet Business
P7A4A
Advantage package + innovation package
P7A5A
Pak. Advantage + Limited Sport Edition
P7A6A
Pakiet innow. + edycje
P7A7A
Pakiet innow. + pakiet komfort. + edycje
P7A8A
Pakiet innow. + pak. komf.+p. Advantage
Kod
Nazwa
P7A9A
P7AAA
EXECUTIVE PACKAGE
P7ABA
SPORT EXECUTIVE PACKAGE
P7AEA
Pakiet low na Taiwan
P7AFA
Pakiet chromowany. rozszerz.
P7AGA
Pakiet ind. wyp. wnętrza lakier fortep.
P7AHA
Pakiet ind. wyp. wnętrza jesion
P7AKA
Pakiet indyw. wyp. wnętrza, orzech
P7ALA
MINI Seven
P7AMA
MINI Park Lane
P7ANA
MINI Checkmate
P7APA
Pakiet Dynamic + Advantage
P7ARA
P7ASA
Pakiet Dynamic + Comfort + Advantage
P7ATA
Pakiet Advatage + Comfort
Kod
Nazwa
P7AUA
Pakiet Advantage + Sport
P7AVA
Pakiet Comfort + Sport
P7AWA
Pakiet Advantage + Comfort + Sport
P7AXA
Pakiet Advantage + pakiet sport. M
P7AYA
Pakiet Comfort + pakiet sportowy M
P7AZA
Pakiet Advantage+Comfort+pak. sport. M
P7G1A
Pakiet Dynamic + Edition Lifestyle
P7G2A
Pakiet Dynamic + Edition Exclusive
P7G3A
Pakiet Comfort + Edition Lifestyle
P7G4A
Pakiet Comfort + Edition Exclusive
P7G5A
Pakiet Dynamic + Comfort + Ed. Lifestyle
P7G6A
Pakiet Dynamic + Comfort + Ed. Exclusive
P7G7A
EDITION 10 JAHRE X5
P7G8A
DESIGN COOL ELEGANCE
P7G9A
Comfort + Limited Sport Edition
Kod
Nazwa
P7HAA
MINI 50 MAYFAIR
P7HBA
MINI 50 CAMDEN
P7HCA
Comfort Plus + Limited Sport Edition
P7HDA
EARL GREY
P7HEA
CONNECTIVITY PAKET
P7K1A
Dummy-SALAPA
P7K2A
Dummy-SALAPA
P7K3A
Dummy-SALAPA
P7K4A
Dummy-SALAPA
P7K5A
Dummy-SALAPA
P7M2A
P7M3A
Indywidualna kompozycja BMW maritim
P7M4A
Indywidualna kompozycja BMW sportiv
P7MBA
Wydanie Exclusive Sport
P7MCA
Kod
Nazwa
P7MDA
P7MFA
Wydanie Sport
P7MPA
Pakiet sportowy
P7MSA
P7PAA
P7PBA
P7R1A
System nawigacji z inst. tel. kom.
P7R2A
Pakiet Lifestyle
P7R3A
Pakiet na Ukrainę
P7R4A
Zestaw kierowcy z pakietem dynamicznym
P7R5A
Zestaw kierowcy z pakietem sport. M
P7R6A
Comfort Plus package w/ M sport package
P7R7A
Pakiet innowacyjny
P7R8A
Pakiet innowacyjny plus
P7R9A
Wydanie Fleet
Kod
Nazwa
P7RAA
Spezial Edition Exklusive carbon/szary
P7RBA
Spezial Edition Exklusive carbon/cynam.
P7RCA
Spezial Edition Exklusive stratus/szary
P7RDA
Spezial Edition Exklusive stratus/cynam
P7REA
Spezial Edition Lifestyle carbon/szary
P7RFA
Spezial Edition Lifestyle carbon/cynam.
P7RGA
Spezial Edition Lifestyle stratus/szary
P7RHA
Spezial Edition Lifestyle stratus/cynam
P7RKA
Spezial Ed. Lifestyle diamant/walk cz
P7RLA
Spezial Ed. Sport nachtblau/Alcantara cz
P7RMA
Pakiet techniczny oświetleniowy
P7RNA
Zestaw kierowcy
P7RPA
Pakiet Advantage
P7RRA
Pakiet Dynamic
P7RSA
Pakiet Comfort
Kod
Nazwa
P7RTA
P7RUA
Spezial Edition Exklusive diamant/czar.
P7SAA
Pakiet Open Air
P7SBA
Dummy-SALAPA
P7SCA
EDITION FLEET PLUS
P7SDA
Pakiet Comfort Plus + Edition Lifestyle
P7SEA
Pakiet Comfort Plus + Edition Exclusiv
P7SFA
Advantage + Edition Sport
P7SGA
Comfort + Edition Sport
P7SHA
Pakiet hotelowy
P7SKA
Pakiet innowacyjny
P7SLA
Design Pure White
P7SMA
DESIGN PADDOCK CLUB
P844A
Pakiet na złą pogodę
P890A
Pakiet standardowy
Kod
Nazwa
P891A
Wyposażenie Executive
P892A
Pakiet High Line
P893A
Middle-East-Paket
P894A
Pakiet HK-2
P894A
V5-IC PACKAGE 1
P912A
Pakiet OE
P913A
Pakiet OE plus
P914A
Pakiet Premium
P948A
Pakiet modelu jądra V-5-KA
P949A
Pakiet sportowy LA
P950A
Pakiet latynoamerykański
P951A
Pakiet letni
P951A
Pakiet koreański
P952A
Pakiet dla Chin
P953A
Pakiet na Taiwan
Kod
Nazwa
P953A
V5-IC PACKAGE 2
P954A
Pakiet Business II
P955A
Business-Line
P955A
Middle-East-Paket
P956A
Middle-East-Paket
P957A
HK-Paket
P957A
V5-IC PACKAGE 3
P958A
Pakiet podstawowy Meksyk
P959A
Luxury package Mexico
P970A
Aktionspaket
P971A
Pakiet Exklusiv
P972A
Pakiet komfort
P973A
Pakiet zimowy
P973A
Pakiet na Malezję
P974A
Pakiet dla krajów azjatyckich
Kod
Nazwa
P975A
Dummy-SALAPA
P976A
Pakiet Comfort
P977A
Linia Exclusive
P981A
Top Komfortpaket
P981A
Comfort Plus Paket
P9BAA
Premium Package
P9BBA
Pakiet Premium + Comfort
P9BCA
Final Package
P9BDA
Business Package
P9BEA
Pakiet motywacyjny
P9BFA
Pakiet nawigacji
P9BGA
Nawigacja pakiet + M pakiet sportowy
PRP1A
Pakiet Business I
PRP2A
Pakiet Business II
PRP3A
BRUSHED STEEL AND TEAK DECKING
Kod
Nazwa
PRP4A
BLACK STARLIGHT STARBURST HEADLINER
PXA1A
Spezial Edition carbon/cynam.
PXA2A
Spezial Edition carbon/dwukolor. szary
PXA3A
Spezial Edition carbon/champagner
PXB1A
Spezial Edition stratus/cynamon
PXB2A
Spezial Edition stratus/dwukolor. szary
PXB3A
Spezial Edition stratus/champagner
PXC1A
Spezial Edition nacht-blau/cynam.
PXC2A
Spezial Edition nacht-blau/dwukol.szary
PXC3A
Spezial Edition nacht-blau/champagner
PXC4A
PZAAA
I znowu dobra robota kolego :cool2:
jak chcesz to możesz jeszcze zrobić jakiś manuał ze zdjęciami zmiana FA, mam to na pdf mogę dostarczyć instrukcje nie ma jeszcze na naszym forum
http://chomikuj.pl/Dinpl/BMW/NCS+4.0.1/Dodatki+NCS/NCS+Expert+-+Change+FA,3766609306.pdf
niema problemu
Też mam ten pdf ze zmiana Fa
Jak bede miał czas to zrobie to i jeszcze jak dodawac nowe wartosci do funkcji w module np jesli w module dla funkcji follow me home czas świecenia do wyboru jest tylko 30s 60s 90s 120s a ktoś potrzebuje np 10s - niema problemu
poniżej trochę praktyki
http://www.bmw-klub.pl/forum/viewtopic.php?f=76&t=226966
