przelacznik AS w automatycznej skrzyni
Mimo podjecia proby przeszukania forum nie udalo mi sie znalezc co oznacza przelacznik trybu pracy skrzyni A S w E38 z 1994. Domyslam sie, ze S to jest sport. Ale co to jest to "A"? Moze ktos sprawnie podpowiedziec?
A - adaptative getriebe steurung - czyli adaptatywne sterowanie skrzynia - skrzynia dopasowuje styl zmiany biegów do upodoban kierowacy - w zaleznosci jak jezdzisz - jak emeryt to zmienia biegi przy nizszych predkosciach obrotowych silnika , jezdzisz dynamicznie - to zmienia przy wyzszych predkoscich obrotowych - chyba proste ?? :mrgreen:
Selector lever positions
P R N D 4 3 2
Shift programs
Lever positions:
> A (Adaptive/Economy)
> M (Manual)
Selector lever in position 4:
> S (Sport program)
For an explanation of the programs, refer
to the next page.
Starting engine
The engine can only be started in positions
"Park" or "Neutral."
380us045
Changing the selector lever
position
A detent prevents inadvertent shifts into
some selector lever positions. To release
the shift-lock mechanism, press
the button on the front side of the selector
handle (arrow).
While the vehicle is stationary and
before shifting out of "Park" or
"Neutral," depress the footbrake in order
to disengage the selector lever's
lock mechanism (shift-lock).
Hold the footbrake down until starting
off. The vehicle will otherwise "creep"
when a drive position is engaged.<
380us046
Before exiting the vehicle when
the engine is running, place the
selector lever in the "Park" or "Neutral"
position and apply the parking brake. If
you do not, the vehicle can move.
Do not leave the car unattended with
the engine running.
An unattended vehicle with a running
engine represents a potential safety
hazard.<
P - Park
Select "Park" only when the vehicle is
stationary. The transmission locks to
prevent the rear wheels from turning.
R - Reverse
Select "Reverse" only when the vehicle
is stationary.
N - Neutral
Select "Neutral" only if your journey is
interrupted for a longer period.
D - Drive
(automatic shift program)
This position is designed for driving under
all normal operating conditions. All
forward gears are available; the Adaptive
Transmission Control (ATC) is fully
operational.
Repairs Index Overview Controls Car care Technology Data
Automatic transmission
4 - Sport program
This position is recommended if your
driving style is performance-oriented.
3 and 2 - Shift limiter
Select this range when you wish to limit
gear changes (on steep uphill or downhill
slopes, for instance). The transmission
upshifts only as far as the selected
gear.
"Kickdown"
(automatic downshift)
In the "Kickdown" mode, you achieve
maximum performance.
Press the accelerator pedal past the increased
resistance point at the fullthrottle
position.
Shift programs
The automatic transmission of your
BMW is equipped with the Adaptive
Transmission Control (ATC) as standard
equipment.
When you select program A, the ATC
system automatically adapts to individual
driving styles and road conditions to
provide optimal performance with the
selector lever at position D.
Because of this, the remaining selector
lever positions for forward driving are
only required in extreme situations such
as those listed in the description of position
2.
A - Adaptive program
This is the initial position that the transmission
selects at every start. In the positions
for forward driving, the ATC
(Adaptive Transmission Control) automatically
selects the optimal gear from
different shift programs. To achieve
this, the system constantly adapts to
driver characteristics (such as a moderate
or performance-oriented driving
style), road condition factors (slick
roads or extreme slopes, for instance)
as well as the current driving situation
(winding roads or mountain travel, for
instance).
For details concerning ATC, please refer
to the chapter titled "Advanced
Technology" on page 184.
M – Manual program
This program is for driving in one gear
(4th gear when D has been selected).
The transmission then remains in the
selected gear both when underway and
when starting off. For instance, when
you make a steep ascent with the selector
lever in position 2, the transmission
does not make undesired upshifts.
The same principle applies during operation
on ice-covered roads: By placing
the selector lever in position 3 you can
move off gradually, and the transmission
will also suppress subsequent
shifts into higher gears.
Positions 4, 3 and 2 have the function of
enhanced control over shifting – control
which is desired and intentionally selected.
The ATC also functions in these selector
lever positions – of course with limitations
for gear selection imposed by
the lever position.
Special functions
In program A, the Adaptive Transmission
Control influences several special
functions in the selection of the drive
gear.
With the system active, some shifts that
would be made in other modes will be
suppressed. The system also reacts to
special situations by executing shifts
that would not occur with a conventional
transmission.
Control of the winter program
A winter program is automatically selected
when the vehicle is operated on
slippery road surfaces (snow and ice).
When this program is active, the transmission
starts in 2nd gear and shifts
into the higher gears earlier. This program
improves response under winter
driving conditions by providing enhanced
traction and vehicle stability.
ATC leaves the winter program when it
registers a high-traction road surface,
when the Sport program is selected and
when ASC+T/DSC is deactivated.
Electronic transmission control
module
If the message "TRANS. FAILSAFE
PROG" appears in the Check Control,
there is a fault in the gearshift electronic
system or in the transmission itself.
You can still place the selector lever in
all positions. However, it is possible
that not all gears are available for the
vehicle's forward drive.
If this happens, avoid extreme engine
loads and consult the nearest authorized
BMW center.
Do not work in the engine compartment
when a drive gear (forward
or reverse) is engaged. If you do
this, the vehicle could move.<
For towing, tow-starting or jump-starting
the vehicle, refer to pages 179, 180. Dane z instrukcji. pozdrawiam
Ach swietne to forum. Pan Admin moze ten watek zamknac a ja dziekuje za odpowiedz. :cool2:
xsilver - moja tez tak zmienia a nie mam AGS :wink:
wiem frank - moja tez tak zmieniała - tylko ze z ags skrzynia sama wybiera sobe tryb albo E albo S.... powiem wiecej - według strony realoem modułu AGS były montowanie takze w 530 i 540 v8 e34 - wiec w skrzyniach 5hp - w e32 nie wiem czy były - napewno w 750 po 92 roku było - mysle ze musiałbys wyjac sterownik i sprawdzic co na nim pisze - ja mam 2 sterowniki - z 530 i 730 i oba sa GS.....
cos tu było ale sie zmyło
Edytowane przez Frank
popieram frank - to chwyt zeby wzbogacic czyms stara skrzynie 4 biegowa w 750 - bo dziwnym trafem wejscie ags zbiegło sie w czasie z wprowadzeniem silnikow v8 z 5 biegowymi skrzyniami......
Co do samoczynnego wyboru trybu S - w takim razie po co przełącznik na S ?
nowe auta juz tego nie mają , wystarczy trzymac gaz do dechy
Frank, :nienie: trochę jesteś w błędzie.
Wciśnięcie gazu do dechy to tzw. kickdown, a wybór na tryb S to oddzielny temat.
Mam e39 530dA z obiema tymi funkcjami i dla zobrazowania podam max prędkości obrotowe:
- przy wciśnięciu pedału do końca (kickdown) w trybie AUTO - 4200obr/min
- przy wciśnięciu pedału do końca (kickdown) w trybie SPORT - 4600obr/min
PZDR :)
GDYBY PRZEDNI NAPĘD BYŁ LEPSZY TO CHODZILIBYŚMY NA RĘKACH :dance:
http://img171.imageshack.us/img171/9086/2fn2.jpg
no to dokładnie tak jak u mnie :D na S trzyma dłużej, logiczne .
Mówiłem o autach, które nie mają przełącznika skrzyni na S a jednak po przytrzymaniu gazu i kick -downie ciągną na kazdym biegu do odcinki :nienie:
nie rozumiem co CI sie nie zgadza
to są twoje słowa :)
nowe auta też to mają, bo są to oddzielne rzeczy
chodzi o to że przy obu trybach odcinka jest przy innych obrotach :)
PZDR :)
ale nie wszystkie :D
np mb C 220 CDI , którym ostatnio pomykałem - ma tylko dwa tryby - letni i zimowy :D
a ,ze np E66 745Li ma guziczek S to wiem. Nie chodziło mi generalnie tylko o BMW, jesli sie nieprecyzyjnie wyraziłem, to wybacz. :wink:
:cool2:
myślałem że rozmawiamy tylko o BMW :D
PZDR :)
