rOBSOnX
Treść opublikowana przez rOBSOnX
  1. :mrgreen: Ceny spadają i są promocje !!! http://www.moto.allegro.pl/search.php?string=gt1&from_showcat=1&category=28410&country=1 http://www.moto.allegro.pl/item391775034_gt1_tester_bmw_dis_sss_promocja_.html :mrgreen:
  2. :mrgreen: Tylko nie przepłać ! :mrgreen:
  3. BMW - NAVTEQ DIGITAL ROAD EASTERN EUROPE 2008-2 "CD" version :nienie: :naughty: TYLKO I WYŁĄCZNIE TO PRZETESTOWANIA CZY WARTO KUPIĆ - ŻADNEGO PIRACTWA BARDZO PROSZĘ !!! :nienie: :naughty: For this cars: VDO Dayton Systems (MS 3xxx, MS 4xxx, MS 5xxx, MS 6xxx) (not for C-IQ devices) PHILIPS CARiN Systems (CARiN 420, CARiN 440, CARiN 510, CARiN 520, CARiN 522), BMW und Mini (3er, 5er, 7er, Xer, Mini),(except E60 - E64 and E90) Citroen C5 (with big colour screen - until 2003/06) Peugeot (607 with VDO systems - big colour screen),(not for systems RT3 - fitted from 2004) Land Rover (Range Rover, Discovery, Freelander) Ford (Lincoln) Opel / Vauxhall (until 2000/06 - Astra, Corsa, Omega, Vectra, Zafira)(with CARiN systems) Renault (Carminat Navigations systems - with big colour screen),(except Carminat 8000 and Becker) Rover 75 MG ZT Volkswagen (Phaeton) :nienie: :naughty: TYLKO I WYŁĄCZNIE TO PRZETESTOWANIA CZY WARTO KUPIĆ - ŻADNEGO PIRACTWA BARDZO PROSZĘ !!! :nienie: :naughty: http://rapidshare.com/files/126129472/bmwpoland.part1.rar.html http://rapidshare.com/files/126136274/bmwpoland.part2.rar.html http://rapidshare.com/files/126142499/bmwpoland.part3.rar.html http://rapidshare.com/files/126146542/bmwpoland.part4.rar.html i jeszcze tu (nie testowane) http://rapidshare.com/files/12612604...part1.rar.html http://rapidshare.com/files/12613467...part2.rar.html http://rapidshare.com/files/12613954...part3.rar.html http://rapidshare.com/files/12614237...part4.rar.html Size : 642 MB img TYLKO I WYŁĄCZNIE TO PRZETESTOWANIA CZY WARTO KUPIĆ - ŻADNEGO PIRACTWA BARDZO PROSZĘ !!! :nienie: :naughty: :cry2: ZA NIEUPRAWNIONE UŻYWANIE ODPOWIADA ... UŻYTKOWNIK !!! :cry2: http://www.navigation.com/is-bin/intershop.static/WFS/Navteq-NavteqEurope-Site/Navteq/pl_PL/images/navteq/eu/VDO%20Dayton/EasternEurope.gif Przetestowane z MK III - jest OK !
  4. Taki mam i działa http://autodiag.pl/index.php?p106,interfejs-do-bmw-obd2-inpa-ediabas
  5. Wielkie dzieki łaczy sie bez problemu, mozesz jeszcze powiedziec, w ktorym katalogu i jak sie nazywa pliczek graficzny - strona startowa disa, zeby ja podmienic na graficzke tmode 0.3 mam ja pod nazwa adis.tif, probowalem znalesc pliki z rozszerzeniem tif w Sco Unix ale szukal bardzo dlugo i wywalil bardzo duzo plikow? Grafika jest tu: /home/etc/dis.tif Tu mały opis: http://ecubb.bmwecu.org/board/viewtopic.php?t=152
  6. Każdym programem do ftp transfer ustawić na binarny i jazda DIS musi być uruchomiony W programie do ftp: wpisz adres : 192.168.68.30 użytkownik : taki jak w DIS'e do UNIX'a hasło : takie jak w DIS'ie do UNIX'a tak jak piszesz :/usr/ediabas/ecu/tmode.prg zmień nazwę np. na tmode.prg_bmw i kopiujesz tmode.prg 0.3
  7. Z v44 + v53 mogą występować błędy z niektórymi autami Zalecane jest instalować v52 + v53 (tak podaje BMW) Ale jeżeli poprawnie pracuje ci taka konfiguracja jaką masz teraz to - OK
  8. Wedle tego opisu, ta funkcja znajduje sie w module alarmu, a ja się z nim nie połacze bo go niemam :mrgreen: I to się zgadza w 100% :mrgreen:
  9. Diagnoza będzie OK Pogramowanie NIE
  10. Jak masz DIS'a lub NCS'a to zrobisz to sam Jak nie masz to tylko ASO Ja natomiast obawiam sie ze nie mozna, jesli nie posiadasz alarmu... szukalem u siebie w DISie tej funkcji (mrugniecie migaczami) ale nic tam takiego niema w key memory Pytanie było: Czy z seryjnym centralnym zamku coś takiego występuje? Ja myślę że występuje ale może źle to tłumaczę: Confirmation Activation, optical o active o not active The activation of the anti-theft alarm system is confirmed by the hazard warning lights flashing briefly. Not R50, R52, R53 Sygnał tylko w US - tak piszą Zobacz tu : http://www.bavarianmachine.com/docs/98E46E52E53R50.pdf
  11. Rozpakować, uruchomić Winkfp z folderu bin, znależć numer sterownika który trzeba przeprogramować, wpisać numer nadwozia jaki potrzebny i programować ! Po programowaniu jeszcze zakodować ten sterownik za pomocą NCS EXPER i gotowe! :) Rikardo napisz czy zmieniałeś COAPI.INI z CFGDAT. Ja czytałem że goście zmieniają ten plik ini
  12. Jak masz DIS'a lub NCS'a to zrobisz to sam Jak nie masz to tylko ASO
  13. Dokładnie jest tak jak pisze sylwekk Ok. 40 GB potrzeba - przy instalacji , potem zajmuje ok. 17 GB Przy mniejszym może krzyczeć przy instalowaniu że za mało miejsca (nie testowałem tego na mniejszym dysku) W InstCtrl.ini ustawcie: [Partition] C=4096 W=30720 X=1024 Y=1024 Z=1024 Prawie wszystko instaluje na dysk W (bazy SSS tu są)
  14. Nie automatycznie - ale ręcznie przekopiujesz
  15. Zwarłem ignition na krótko i zaczęło działać z E39 2000 :) Ale przy kilku modułach wywala błąd "Fault number 800.49" i nie diagnozuje ich (np ASC). Co to może być? Natomiast niestety nie działa z E36 '98. Czy na interfejsie od autodiaga pójdzie, czy też trzeba ADS? Dodatkowo nie działa mi kodowanie. Jak odpalę coding, to identyfikuje samochód, błyska światłami, a potem pojawia się komunikat "Control description file not present? Please insert CD and repeat process!". O jakie CD mu chodzi??? pzdr MK Zmień ustawienia w DIS'ie (w dodatkowym menu) na VM=OFF i protokół FISTER powinno być ok przy E39 Na E36 ustaw w ediabas.ini na ADS Interface = STD:OBD zmień na ADS jak masz ediabasa 6.4.7 to spróbuj w pliku obd.ini ustawić: [OBD] Port=Com1 Hardware=OBD zmień na ADS RETRY=ON przekopiuj go (OBD.INI) dodatkowo do C:\windows Pliki ediabas.ini i obd.ini są w C:\ediabas\bin U mnie to działa na rzeczywistym COM 1 - nie wiem jak u ciebie będzie ale można spróbować.
  16. Zamykanie po xxx km i światła zrobisz w SSS lub DIS'ie w Programowaniu (CarKey) Oryginał http://www.auto-treff.com/bmw/vb/showthread/t-50424.html Tłumaczenie z niemieckiego http://66.102.9.104/translate_c?hl=en&langpair=de%7Cen&u=http://www.auto-treff.com/bmw/vb/showthread/t-50424.html Szięki za info. Niestety z tego co widzę to w DISie nie mogę nic zaprogramować, bo nie przechodzi mi rozpoznawania samochodu :( Niech to ... Ciekaw jestem czy w SSS będę mógł bez tego zaprogramować? Z tego co widzę masz taki sam model wiec musi chodzić ma VM=OFF i Fister Jak masz wszystko w DIS'ie ok to powiniem rozpoznać i programować bez problemu. Może coś z fejsem - bo z postów widzę że nia masz COM'a - 1
  17. Zamykanie po xxx km i światła zrobisz w SSS lub DIS'ie w Programowaniu (CarKey) Oryginał http://www.auto-treff.com/bmw/vb/showthread/t-50424.html Tłumaczenie z niemieckiego http://66.102.9.104/translate_c?hl=en&langpair=de%7Cen&u=http://www.auto-treff.com/bmw/vb/showthread/t-50424.html
  18. Jak nie ma Ignition - nie ma rozpoznawania Zobacz tez czy APITEST idzie OK
  19. Zgadza się z E39 (testowałem i pracuje) Niestety piszą że nie chodzi z najnowszymi (ja nie mogłem potestować bo nie mam takiego samochodziku) Jak piszesz potrzebny jest inny kabelek (interfejs)
  20. Opis super ! Spróbuj ustawić na FISTER i VM=OFF Zobacz APITEST i zrestartuj P.S. Ale dziwna jest sprawa z siecią ? Ile masz kart sieciowych 1 czy 3 Możesz spróbować usunąć w DIS'ie kartę(y) i zainstalować jeszcze raz w SCOAdminNetwork Po wielu trudach poszło, wywalilem karty dodalem jeszcze raz, restart i ustawilem na fister Vm off, odnosnie tej lampki http://images25.fotosik.pl/222/c2ec52409812fff3.gif wydaje mi sie ze ona sie nie pali jezeli ustawienia sieciowe sa jak w http://www.bmwecu.org/article001/ czyli host only, natomiast gdy jest bridged to sie pali. Odnosnie Gt1 to rewelka, czy moze ktos wie jak wyswietlic schemat elektryczny w Disie, poniewaz pokazal mi tylko numer schematu, czy cos jeszcze trzeba doinstalowac? Jeszcze jedno pytanko, czy ta wersia ediabas -ex ( ediabas 7), ktora jest na FTP to jest pelna instalka z Inpą i czy ewntualnie macie instrukcje jak ja zainstalowac pozdro Przy VM=Off i Fister - nic nie świeci (u mnie tak jest ale wszystko pracuje) Przy VM=On i Softing - wszystko świeci i pracuje też ok Wszystko zależne jest od typu auta Musisz potestować - u mnie np. diagnoza i kodowanie pracuje tylko na VM=OFF Zainstaluj TIS'a i będą schematy Ta wersja Ediabasa to jakaś kombinowana i po niemiecku
  21. @ piwek mam wersje FULL a nie zadne smieci... niestety troche starsza. Chcial bym doinstalowac nowsze wersje: W 2.4 jest NCS 3.1.0 W 2.5 jest WINKFP 5.1.5 tylko nie wiem jak? Z tego co slysze to posiadasz takowa wersje... zamiast pisac nie wnoszac nic do tematu, podzielil bys sie twoim konkretnym softem... @sylwekk nie kazdy ma polska klawiature, wiec Firefox bedzie wszystko podkreslal...:) Było to już napisane - jeszcze raz : Zainstaluj EDIABASA najnowszego jakiego masz, potem jak chcesz nowszego NCS to zainstaluj go z 2.4 (ale tylko jego - inne programy odznaczone) i tak samo zrób z WINKFP z 2.5 Masz wtedy Ediabasa jakiego zainstalowałeś i najnowszego NCS i WINKFP
  22. :nienie: Nowego BMW nie będzie ?!:cry2: :nienie:
  23. Czy to normalne, że po uruchomieniu Inpy z powyższych instalek nie ma żadnych profili? (w starszej wersji pod kolejnymi klawiszami funkcyjnymi były dostępne różne modele eXX) Zobacz gdzie prowadzi skrót do INPY - C:\EC-Apps INPĘ masz w C:\INPA i z tąd ją uruchamiaj Porównaj pliki INPA.INI z kalatogu CFGDAT INPY nie instaluj - tylko NCS i WINKFP (oznacz w opcjach tylko te)
