Zafi
Treść opublikowana przez Zafi
  1. witam .... to jedyna osoba ( z doswiadczenien ) ktora moze Tobie pomoc albo cos doradzic .....
  2. witam 54C4 – VTG Calibration Faulty - eng. / Fehler 54C4 - Kalibrierung Fehlerhaft - germ. / Kalibracja nie powiodła się - bledna 54c6 oil wear / 54c6 - > Zużycie oleju P.S. Dogadaj się z papikiem :D
  3. witam @rkuznik 54c6 oil wear 54c6 - > Zużycie oleju .... ale Ty podales [ 55C4 ] oraz [ 55C6 ] :duh: I po temacie... :D
  4. witam .... silnik N52 ma jedna pompe wody - napedzana elektrycznie :D http://fs2.directupload.net/images/150225/temp/p7mvvnk3.jpg kiknij na zdjecie ! zeby powiekszyc @Golian.... mam pytanie : sam wyciagales pompe , czy byles w warsztacie np. BMW ? .... czytam troche o tym silniku ( N52 ) , ten silnik posiada elektryczna pompe wodna .... i tu jest specjalna instrukcja w jaki sposob PRAWIDLOWO przeprowadzic procedure odpowietrzania systemu chlodzacego ( nie stosujac sie do wskazan moze uledz uszkodzeniu pompa lub inne elementy !!! ) :cool2: cytuje : EN / " Workshop Hints Electronically Controlled Coolant Pump Particular care must be taken when performing servicing work to ensure that the pump does not run dry. When the pump is removed, it should be stored filled with coolant. The bearing points of the pump could seize if the pump were not filled with coolant. This could jeopardize subsequent start-up of the pump thus rendering the entire heat management system inoperative (the pump not starting up could cause serious engine damage). If the pump should ever run dry, the pump wheel should be turned by hand before finally connecting the coolant hoses. The system should then be immediately filled with coolant. Particular care must be taken during assembly to ensure that the connector is clean and dry and the connections are undamaged. Diagnosis should be performed only with the approved adapter cables. The information provided in the repair instructions must be observed. Due to this coolant pump, a special filling and bleeding procedure must be implemented for servicing: 1. Fill system with coolant via the expansion tank (AGB). Top up coolant level to lower edge of expansion tank. 2. Close expansion tank. 3. Switch on ignition. 4. Set heating to maximum (temperature), switch on blower (lowest stage). 5. Press accelerator pedal module to floor for at least 10 seconds. The engine must NOT be started. 6. Bleeding via EWP takes app.. 12 minutes. Then check coolant level in expansion tank, top up to MAX marking if necessary. 7. Check cooling circuit and drain plugs for leaks. 8. If the procedure needs to be repeated several times, allow DME to completely de-energize (remove ignition key for app.. 3 minutes) and then repeat procedure as from item 3. Note: Connect battery charger if battery charge level is low. " DE / Beim Befüllen und Entlüften ergibt sich für den Servicebereich eine besondere Vorgehensweise aufgrund dieser Kühlmittelpumpe (siehe aktuelle Reparaturanleitung): Kühlmittel Ausgleichsbehälter bis Unterkante Einfüllstutzen mit vorgeschriebenem Kühlmittel befüllen. Verschlussdeckel des Kühlmittel Ausgleichbehälters schließen. Während des Entlüftungsvorgangs den Verschlussdeckel des Kühlmittel Ausgleichsbehälters nicht öffnen. 1. Batterieladegerät anschließen. 2. Zündung einschalten. 3. Heizung auf maximale Temperatur stellen, ("Automatik" aktivieren), Gebläse auf kleinste Stufe zurücknehmen. 4. Gaspedal für 10 Sekunden bis Anschlag drücken. Motor darf nicht gestartet werden. 5. Der Entlüftungsvorgang wurde durch Drücken des Gaspedals gestartet und dauert ca. 12 Minuten. (Die elektrische Kühlmittelpumpe wurde aktiviert und schaltet sich nach ca. 12 Minuten automatisch ab). 6. Danach Füllstand mit Kühlmittel Ausgleichsbehälter mit über 250 ml über "Max." befüllen. (Fahrzeugspezifische Service-Literatur beachten!). 7. Kühlsystem auf Wasserdichtheit prüfen. 8. Falls die Entlüftung nochmal durchgeführt werden muss, (z. B. Bei undichtem Kühlsystem) DME (Digitale Motor Elektronik ) komplett abfallen lassen (ca. 3 Minuten Zündschlüssel abgezogen lassen), dann ab Punkt 3 wiederholen. Przy dolewaniu i odpowietrzaniu nalezy zachowac nastepujaca procedure ze wzgledu na pompe wody ( patrz aktualna instrukcja naprawy ) Zbiornik wyrownawczy systemu do dolnego ozakowania zalac zalecanym plynem. Korek zakrecic na zbiorniku wyrownawczym. Podczas procesu odpowietrzania nie odkecac korka zbiornika wyrownawczego. 1. Podlaczyc prostownik (zasilacz) 2. Zalaczyc stacyjke – przekrecic kluczyk w stacyjce 3. Ogrzewanie na max. temperature („automatic“ wlaczyc), dmuchawe na najmniejsze obroty ( stopien ) ustawic. 4. Pedal gazu 10 sekund do oporu wcisnac. Silnik nie wolno wlanczac . 5. Proces odpowietrzania zostal wlaczony i trwa ok. 12 minut. ( Elektryczna pompa syslemu chlodzacego zostala zalaczona i wylaczy sie po ok. 12 minutach automatycznie ). 6. Nastepnie poziom plynu chlodniczego uzupelnic 250 ml. powyzej Max. ( Literature serwisowa uwzglednic ) 7. Sprawdzic szczelnosc systemu chlodzacego. 8. Jezeli odpowietrzanie systemu trzeba powtorzyc ( np. poniewaz system jest nieszczelny ) DME (Digitale Motor Elektronik ) kompletnie wyllaczyc ( na ok. 3 minuty wyciagnac kluczyk ) , nastepnie od punktu 3. powtorzyc .
  5. witam 55C4 - > No Message from DSC 55C4 - > brak ( kontaktu ) polaczenia z CSC 55C6 - CAN_MESSAGE_GESCHWINDIGKEIT_RAD - da fehlten dem steuergerät wohl die einzelnen radgeschwindigkeiten 55C6 - > CAN_polaczenia_szybkosci_kola ( kol ) - brak informacji ; w urzadzeniu sterujacym ; predkosci poszczegolnych kol
  6. Zafi odpowiedział(a) na rkuznik temat w X5 (E53)
    witam " niewiarygodny sygnal albo wartosc" "warunki testu spelnione" "błąd obecnie dostępny i już zapisany(zapamietany)" "błąd nie spowoduje świecenia sie lampy ostrzegawczej" :cool2:
  7. @bosniak ... to moze teraz napisz dokladnie co masz / nagraj video i wstaw - b. mnie to interesuje
  8. @bosniak ... nic nie rozumiem ! ! ! wstawiles tutaj filmy YouTube : http://www.bmw-klub.pl/forum/viewtopic.php?f=91&t=265483&p=1993615#p1993615 w pierwszym filmie - 10 sekunda - pokazuje na monitorze => USTAWIENIA > Ekran , Zegar , Data , Glos. navi , Dzien/Noc ........... oraz ...................... Radar alarm [ wlacz ; wylacz ]
  9. Hej kolego a jaki masz soft [4-1/00] ?? .... widac na filmie Nr. 1 :D .... na koncu sa dwa zera .... to jest stara .... najstarsza wersja ?
  10. .... to chyba nic nowego , ze na wsi nie ma lotniska , dworca kolejowego albo parkingu :cool2:
  11. witam :D @bosniak : zobacz na filmie NR.2 - czas : 0,42 ( 42-ga sekunda) Informacje podrozne >Informacje o miescie >POI - Informacje >Informacje o produkcie >Ukryj ikony " Ukryj ikony " - co to za opcja ? co sie za nia kryje ? ..... moze ta opcja " ukrywa " ikonki ? :D
  12. witam @bosniak : zrob zdjecia - USTAWIEN / albo zrob film jakie masz ustawienia i zobaczymy co i jak :D to jest moje tlumaczenie z j.niemieckiego / ja nie mam nawigacji wiec nie moge sprawdzic
  13. witam .... pisalem juz na ten temat powyzej !!! @bosniak :D ogladnij kilka razy ten film .... i ustaw swoje opcje w nawigacji tak jak na filmie i powinno smigac :D
  14. Witam kolego... tutaj jest BMW Workshop Manuals / X Series E83 X3 3.0d (M57TU) OFFRD/41 Parking Brake > 1 RA General Information On Braking In New Brake Discs _ Brake Pads : http://workshop-manuals.com/bmw/x_series_e83/x3_3.0d_m57tu_offrd/2_repair_instructions/34__brakes/41__parking_brake/1_ra__general_information_on_braking_in_new_brake_discs___brake_pads/ > 2 RA Adjusting Handbrake : http://workshop-manuals.com/bmw/x_series_e83/x3_3.0d_m57tu_offrd/2_repair_instructions/34__brakes/41__parking_brake/2_ra__adjusting_handbrake/ > 3 RA Overview Of Parking Brake : http://workshop-manuals.com/bmw/x_series_e83/x3_3.0d_m57tu_offrd/2_repair_instructions/34__brakes/41__parking_brake/3_ra__overview_of_parking_brake/ > 4 RA Removing And Installing Or Replacing Gaiter For Handbrake Lever : http://workshop-manuals.com/bmw/x_series_e83/x3_3.0d_m57tu_offrd/2_repair_instructions/34__brakes/41__parking_brake/4_ra__removing_and_installing_or_replacing_gaiter_for_handbrake_lever/ > 5 RA Removing And Installing (replacing) Handbrake Lever : http://workshop-manuals.com/bmw/x_series_e83/x3_3.0d_m57tu_offrd/2_repair_instructions/34__brakes/41__parking_brake/5_ra__removing_and_installing_%28replacing%29_handbrake_lever/ > 6 RA Replacing Handle For Handbrake Lever : http://workshop-manuals.com/bmw/x_series_e83/x3_3.0d_m57tu_offrd/2_repair_instructions/34__brakes/41__parking_brake/6_ra__replacing_handle_for_handbrake_lever/ > 7 RA Removing And Installing _ Replacing Both Handbrake Bowden Cables : http://workshop-manuals.com/bmw/x_series_e83/x3_3.0d_m57tu_offrd/2_repair_instructions/34__brakes/41__parking_brake/7_ra__removing_and_installing___replacing_both_handbrake_bowden_cables/ > 8 RA Removing And Installing_replacing All Handbrake Shoes : http://workshop-manuals.com/bmw/x_series_e83/x3_3.0d_m57tu_offrd/2_repair_instructions/34__brakes/41__parking_brake/8_ra__removing_and_installing_replacing_all_handbrake_shoes/ > 9 RA Removing And Installing_replacing Expander Lock For Handbrake Shoes : http://workshop-manuals.com/bmw/x_series_e83/x3_3.0d_m57tu_offrd/2_repair_instructions/34__brakes/41__parking_brake/9_ra__removing_and_installing_replacing_expander_lock_for_handbrake_shoes/ ... jest po angielsku , ale mam nadzieje ze pomoze
  15. ..... ponizej wykaz czesci jakie BMW oferuje : Elem. poj. reflektora http://pl.bmwfans.info/parts-catalog/E83N/Europe/X3_3.0si-N52N/L-N/browse/lighting/single_components_for_headlight/ nie ma samych kloszy :nienie:
  16. przez papik » 19 Paź 2013 14:14
  17. witam ... łańcuch to nie wszystko !!! :mad2:
  18. witam wszystkich zainteresowanych oraz @tomekbuniax5 aby ulatwic montaz uszkodzonego panelu tutaj kilka szczegolow jak sie za to zabrac .... :D 16. Front Seat, Sports, Electric > 5 RA Removing And Installing_replacing Outer Cover On Front Left Or Right Seat http://workshop-manuals.com/bmw/x_series_e53/x5_4.6is_m62_offrd/2_repair_instructions/52__seats/16__front_seat_sports_electric/5_ra__removing_and_installing_replacing_outer_cover_on_front_left_or_right_seat_%28sport/ Page 2147 http://workshop-manuals.com/bmw/x_series_e53/x5_4.6is_m62_offrd/2_repair_instructions/52__seats/16__front_seat_sports_electric/5_ra__removing_and_installing_replacing_outer_cover_on_front_left_or_right_seat_%28sport/page_2147/ Page 2148 http://workshop-manuals.com/bmw/x_series_e53/x5_4.6is_m62_offrd/2_repair_instructions/52__seats/16__front_seat_sports_electric/5_ra__removing_and_installing_replacing_outer_cover_on_front_left_or_right_seat_%28sport/page_2148/ ... jest w j.angielskim , ale mysle ze to wystarczy :D
  19. Witam :D sprawdzilem ... S522A > Xenon-Licht -Xenon Light S524A > Adaptives Kurvenlicht - Adaptive Headlights
  20. Witam kolego :D ... myslisz ze my tutaj mamy szklana kule w ktorej wszystkie mozliwe usterki mozna zobaczyc i zdjagnozowac ? Tutaj jest opisany problem z kierownica i siedzeniami podobny do twojego ( bezpieczniki sa O.K. ) http://www.motor-talk.de/forum/elektrische-sitz-und-lenkradeinstellung-t3794919.html Erstellt am 9. Mai 2012 um 12:09:09 Uhr Tlumaczenie : mialem w zeszlym roku ten sam problem i bylem w warsztacie. U mnie byl kabel w konsoli srodkowej przetarty. Poniewaz wymiana jest bardzo skomplikowana i droga kabel zostal odlaczony i pociagnolem nowy, teraz funkcjonuje wszystko.
  21. Witam dla zainteresowanych - jak wyciagnac plyte CD z radia BUSINESS CD X3 (E83) ... a jak wyciagnac CD Player ? Tutaj film :D
  22. Witam @mattheus wyslalem oba Pdf-y . W instrukcji w j.angielskim na stronie nr.5 / druga i trzecia ilustracja / musisz zdemontowac metalowy uchwyt do montazu zmieniarki :D , na stronie nr.6 jest ilustracja - jak wyglada kabel i jakie ma kostki :D ( 1. Power/ i-bus connector 2. Audio DSP 3.Digital Audio / Navi 4. 6-pin connector CD-SDARS ) :cool2:
  23. .... ten film na YouTube zostal 11 tys. razy wyswietlony !!! :D wiec problem jest znany Na zblizeniu widac w prawym gornym rogu [ SW 4 - 1 / 00 ] dwa zera na koncu - tj. pierwsza wersja :D
  24. Witam .... mam instrukcje montazu zmieniarki CD - org. BMW ( Pdf.) - krok po kroku w j. angielskim i w j. niemieckim - co i jak zdemontowac ,jak podlaczyc, schematy, wtyczki, itp prosze podaj mi swoj adres mailowy - na PW
  25. Zafi odpowiedział(a) na andy_64 temat w X5 (E70)
    Witam , kolego znalazlem kilka informacji na ten temat , moze cos pomoga BMW Electromechanical Parking Brake : tak to dziala , i jak mozna odblokowac - awaryjnie ? http://www.kneb.net/bmw/F01-02/02_EMF%20Parking%20Brake.pdf ... tu masz sporo informacji co i jak , i jakie bledy wystepuja i jak jak sie za to zabrac ...O.K. ale moze problem jest np. tutaj DIY: BMW E70 X5 Parking Brake Module Replacement :
