Treść opublikowana przez bsbs
Zakup X3 rozterki opinie porady porównania
WBAPA91090WA17083download .pdf-version of WBAPA91090WA17083 Type PA91 Model X3 3.0i Vehicle History Get a car report instantly! Market Europe Development Code E83 Chassis Sports Activity Vehicle Steering left Doors 5 Engine M54 Displacement 3.00 l Power 170 kW Drivetrain All Wheel-Drive Transmission automatic Color Titan-silber - 354 Upholstery Leder "ambiente"/schwarz - LGSW Manufacturer BMW AG Mileage Show mileage of this vehicle Production Plant Graz, Austria (Magna Steyr) Production Date 2003-11-21 Options Get a detailed car report instantly! Detaillierte Fahrzeughistorie überprüfen! 205 Automatic Transmission Automatic Getriebe 240 Leather Steering Wheel Lederlenkrad 249 Multi-function For Steering Wheel Multifunktion Fuer Lenkrad 2BD Lt/aly Wheels Double Spoke 112 Lm Raeder Doppelspeiche 112 302 Alarm System Alarmanlage 321 Exterior Parts In Body Color Exterieurumfaenge In Wagenfarbe 386 Roof Rail Dachreling 413 Luggage Compartment Net Gepaeckraumtrennetz 423 Floor Mats, Velour Fussmatten In Velours 428 Warning Triangle Warndreieck 441 Smokers Package Raucherpaket 459 Seat Adjustm., Electr. W. Memory Sitzverstellung, Elektr.mit Memory 473 Armrest, Front Armauflage Vorn 493 Storage Compartment Package Ablagenpaket 494 Seat Heating F Driver/front Passenger Sitzheizung Fuer Fahrer/beifahrer 502 Headlight Washer System Scheinwerfer-waschanlage 508 Park Distance Control (pdc) Park Distance Control (pdc) 520 Foglights Nebelscheinwerfer 534 Automatic Air Conditioning Klimaautomatik 548 Speedometer With Kilometer Reading Kilometertacho 550 On-board Computer Bordcomputer 644 Prep. For. Mob. Ph. Bluet. Interf. Handy Vorb. Mit Bluetooth-schnitts. 662 Radio Bmw Business Cd Radio Bmw Business Cd 801 Germany Version Deutschland-ausfuehrung 818 Main Battery Switch Batteriehauptschalter 851 Language Version German Sprachversion Deutsch 863 Europe/dealer Directory Service Kontakt-flyer Europa 877 Deletion Cross-over Operation Ueberkreuzbedienung Entfall 879 German / On-board Documentation Deutsch / Bordliteratur 8SP Cop Control Cop Steuerung 999 Order Control First Dealer Cars Auftragssteuerung Hea
X1 WBAVP11020VU03810
bsbs odpowiedział(a) na bsbs temat w Co sądzicie o tym BMW z ogłoszenia? Opinie na temat samochodów na sprzedażTo że manual to mi nie przeszkadza potrzebne mi auto na dojazd do roboty 15 km w jedną strone po zadupiu Ale jak to francja to na 99,9% była uszkodzona nie mogłem sie skontaktowac spróbuje dziś
- jaki olej w rozdzielaczu?
bsbs opublikował(a) temat w Co sądzicie o tym BMW z ogłoszenia? Opinie na temat samochodów na sprzedażWitam ktoś cos na tenat tego x1 https://www.otomoto.pl/oferta/bmw-x1-bmw-x1-czarne-ID6DsLDk.html?
z
bsbs odpowiedział(a) na nenes temat w Co sądzicie o tym BMW z ogłoszenia? Opinie na temat samochodów na sprzedażOdczytaj przebieg z skrzynki rozdzielczej
X3 E83 SD wymiana oleju xdrive lubuskie
Stary olej musisz spuścic żeby wlać nowy to chyba logiczne
Witam nie musisz nic wymieniać oleju wlej do przelania górym korkiem. W ista masz wymiane oleju nic skomplikowanego .W szkrzynce vtg jest zpisywany przebieg auta można to sprawdzić
błąd czujnika abs po wymianie łoysk
Chodziło mi o coś takiego i takie było u mnie i takie załozyłem https://www.repxpert.com/en/mediadocument/FAG-0036/en
Witam a u siebie wymieniałem z przodu nie ma koronki abs odczyt jest z łozyska .Tzn dokładnie z uszczelnienia łożyska tylko nie wiem czy z obustron jest(przypuszczam że jest) .Jezeli wezmiesz nowe łożysko to czuc pod palcami na tym plastiku takie zgrubienia jakby koronke ale próbować trzebaod czujnika abs
5EBE DSC: czujnik kąta skrętu wiarygodność 5DEC DSC: Przekładnia rozdzielcza: Usterka tymczasowa 5E58 DSC: Wiarygodność prędkości obrotowej koła, przód prawa strona
żółta kontrolka ręcznego plus 4x4
6E3E DSC: Czujnik kąta skrętu, wymagana kalibracja 6E3C DSC: Złącze silnika dxc_83 mozliwe że zebatka ale najpierw kalibracja zujnika
Musisz podlaczyc pod komputer ta to mozna zgadywac moze czujnik abs moze koronka moze skrzynka vtg
Błąd DPF 480A
Witam z tłumaczenia błędu 1. Sprawdzić poziom oleju i interwał wymiany. Skorygować poziom oleju lub wymienić olej. 2. 2. Sprawdzić klapy zawirowujące. 3. 3. Przeprowadzić kontrolę ciśnienia spalin. 4. Sprawdzić filtr cząstek stałych w silniku wysokoprężnym (kontrola wzrokowa w celu sprawdzenia, czy w rurze wydechowej i na wylocie filtra cząstek stałych nie znajduje się sadza). 5. Przeprowadzić regenerację. 5. Regeneracja jest możliwa tylko przy stałej prędkości obrotowej przez co najmniej 30 minut (regeneracja nie może być zatrzymana przy odpowiedniej funkcji serwisowej dla tego usterki). 6. 6. Sprawdzić otwory wlotowe i zawory wlotowe pod względem zanieczyszczenia. Nadmierny dopływ oleju z układu odpowietrzania skrzyni korbowej może prowadzić do osadzania się sadzy, szczególnie przy jeździe na krótkich dystan tu do tłumaczenia błedów http://bmwfault.codes
E53 M57 czy mam klapki w kolektorze?
Witam czy mam te nieszczęsne klapki Nazwa Wartość Drzwi 5 Silnik M57 Pojemność 3 Moc (kW) 135 Napęd ALLR Lakier 475 black-sapphire metall VIN:WBAFA71080 LW21187 / Nadwozie:SAV Wersja katalogu/region:ECE / Kod typu:FA71 / Skrzynia biegów:Automatyczny / Układ kierowniczy:Lewostronny Data produkcji:09.18.2003 / Lakier: 475 / Tapicerka: LCHC
BMW E87 118D 2006 Błędy
Uszkodzone 4 swiece zarowe może być też sterownik swiec
Prostownik, zasilacz do diagnostyki, programowania, kodowa.
Witam taki do 100A wystarczy ci do e83 i nie tylko myśle że do większosci bmw będzie dobry
BMW E60 vin WBANC31010CP51150
bsbs opublikował(a) temat w Co sądzicie o tym BMW z ogłoszenia? Opinie na temat samochodów na sprzedażPanowie coś na ten temat https://www.otomoto.pl/oferta/bmw-seria-5-bmw-e60-m-pakiet-2-0d-163km-jasna-skora-xenon-ID6Dn9eN.html#7548f17dbc
ISTA P nietypowy problem
Witam ista p jest przeznaczona do seri e do seri f ista + a do kodowania esys
[e60]przepustnica
Witam czy ktos próbował uszczelnic wałek przepustnicy żeby olej nie dostawał się do elektroniki przepustnicy
- Swiatła dzienne DRL
Swiatła dzienne DRL
Masz wyłącznik swiateł z literką A i czujnik zmierzchu??? Jesteś z okolic Siedlec dokładnie skąd
E61 2.0 n47 2009r 177km Zgasła podczas jazdy S0074 S0098
Masz tu strone do rozkodowania błędów może coś ci rozjaśni http://bmwfault.codes
„Strzelanie” przy kręceniu kierownicą na postoju
Ta blacha pod silnikiem jest przykręcona na 4 śruby bodajże na klucz 17
Jeżeli tnie Ci opony to itak musisz jechać na geometrie najlepiej 3d Ale ja bym najpierw podjechał na szarpaki te sruby to od osłony silnika raczej nie mają nic wspólnego ze stukami
Na szarpaki a potem na geometrie zawieszenia
