No i Panowie mam wielki problem... Auto nie chce odpalic. Probowalem zdeaktywaowac mate ale sie nie udalo, kontrolka dalej sie swiecila. Wiec wgralem oryginalny plik .MAN spowrotem i poodlaczalem wszystko. Chcac odpalic auto wielkie zdziwienie- nie odpala... kontrolki sie pala, buczy tak dziwnie i po przekreceniu kluczyka nic sie nei dzieje. Oto bledy jakie odczytalem z silnika (wczesniej nie bylo zadnych): E R R O R M E M O R Y --------------------------------------- Date: 14.03.2012 12:25:28 ECU: D50M47A JobStatus: OKAY Variant: D50M47A ------------------------------------------------------------- RESULT: 3 error in error memory ! ------------------------------------------------------------- 4661 4661 Supply voltage Error counter: 6 Logistic counter: 40 1. Umweltsatz Mileage 253220 km average engine rotational speed 0.00 rpm coolant temperature 5.95 deg C maximum common-rail-pressure of last 10ms 7.88 bar injection volume setpoint without volume offset 42.53 mg/cyc intaken air mass per cylinder 0.00 mg/Hub charge pressure value 1014.15 hPa linearised APP1 0.00 % Battery Voltage 7820.46 mV Vehicle speed 0.00 km/h Atmospheric-pressure 1004.30 hPa 2. Umweltsatz Mileage 0 km average engine rotational speed 0.00 rpm coolant temperature 5.95 deg C maximum common-rail-pressure of last 10ms 7.88 bar injection volume setpoint without volume offset 42.53 mg/cyc intaken air mass per cylinder 0.00 mg/Hub charge pressure value 1014.15 hPa linearised APP1 0.00 % Battery Voltage 7820.46 mV Vehicle speed 0.00 km/h Atmospheric-pressure 1004.30 hPa Signal or value below threshold Test conditions fulfilled Error present now and already stored Error would not cause a warning lamp to light up Fehler in Entprellphase Fehler in Entprellphase Fehler in Entprellphase Error code: 46 61 62 06 00 00 06 28 62 EA 00 38 01 6C 00 67 00 30 00 66 00 00 00 38 01 6C 00 67 00 30 00 66 ------------------------------------------------------------- 4A30 4A30 multi funktion steering wheel Error counter: 5 Logistic counter: 40 1. Umweltsatz Mileage 0 km average engine rotational speed 0.00 rpm coolant temperature 5.95 deg C maximum common-rail-pressure of last 10ms 7.88 bar injection volume setpoint without volume offset 44.11 mg/cyc intaken air mass per cylinder 0.00 mg/Hub charge pressure value 1014.15 hPa linearised APP1 0.00 % Battery Voltage 7820.46 mV Vehicle speed 0.00 km/h Atmospheric-pressure 1004.30 hPa 2. Umweltsatz Mileage 0 km average engine rotational speed 0.00 rpm coolant temperature 7.96 deg C maximum common-rail-pressure of last 10ms 7.88 bar injection volume setpoint without volume offset 0.00 mg/cyc intaken air mass per cylinder 0.00 mg/Hub charge pressure value 1014.15 hPa linearised APP1 0.00 % Battery Voltage 7820.46 mV Vehicle speed 0.00 km/h Atmospheric-pressure 1004.30 hPa Signal or value above threshold Test conditions fulfilled Error not occurred yet Error would not cause a warning lamp to light up Fehler in Entprellphase Fehler in Entprellphase Fehler in Entprellphase Error code: 4A 30 01 06 00 00 05 28 00 00 00 38 01 70 00 67 00 30 00 66 00 00 00 3A 01 00 00 67 00 30 00 66 ------------------------------------------------------------- 4A42 4A42 EWS Interface-Error Error counter: 1 Logistic counter: 40 Mileage 0 km average engine rotational speed 0.00 rpm coolant temperature 4.95 deg C maximum common-rail-pressure of last 10ms 7.88 bar injection volume setpoint without volume offset 42.93 mg/cyc intaken air mass per cylinder 0.00 mg/Hub charge pressure value 1014.15 hPa linearised APP1 0.00 % Battery Voltage 7820.46 mV Vehicle speed 0.00 km/h Atmospheric-pressure 1004.30 hPa No signal or value Test conditions fulfilled Error not occurred yet Error would not cause a warning lamp to light up Fehler in Entprellphase Fehler in Entprellphase Fehler in Entprellphase Error code: 4A 42 04 02 00 00 01 28 00 00 00 37 01 6D 00 67 00 30 00 66 ============================================================= oraz blad z modulu ABG: RESULT: 1 errors in error memory ! ------------------------------------------------------------- 80 Versorgungsspannung Error frequency : 1 Fehler aktuell vorhanden Unterspannung Fehler nicht sporadisch ============================================================= Bardzo prosze o pomoc.. auto zachowuje sie jakby mialo slaby aku, ale rozrusznik nic nie kreci. Ale dopiero co robilem trase 100km.. Pozdrawiam, Łukasz.
