e-46 wyświetlacz
Witam,naciskając na przycisk do kasowania kilometrów przy dłuższym jego przytrzymaniu na wyświetlaczy pojawiają sie rózne cyfry i liczby np.prz1.1 22703,przy 1,2 np.68.... itd. cz może ktoś z was wie co to oznacza.
1 Car Engine and cluster data
1.0 46nnn Chassis nr/VIN serial number (last 5 digits)
1.1 4nnn K-number
1.2 690236 Cluster Part #
1.3 045210 Coding (04)/diagnosis (52)/bus index (10)
1.4 1200 Week (12)/year of manufacture (2000)
1.5 09_160 Hardware (09) and software # (16.0) of cluster
1.6 Not used
1.7 04__44 CAN-version (04) KI-revision index (44)
1.1 4nnn K-number
1.6 Not used
Dziękuję Marcin
Troche wiecej informacji:
Hidden Onboard Computer Functions
There are a number of "secret" OBC functions which can be enabled to display raw data output on the digital odometer. Some are found during standard operation (e.g. average fuel economy), but many others are unique to the "hidden" mode (e.g. engine speed or vehicle speed).
Note: these functions will work on ALL US-spec E46 cars, even early 323/325 models which are technically not equipped with the OBC option. The OBC is in fact installed and operative in every E46; as an option, it can be "retrofitted" (activated) by installing the OBC-style turn signal stalk and activating the appropriate trigger during an ECU reflash. The better dealership service departments will know how to do this.
Instructions to access the hidden OBC functions:
1. Hold Trip Reset while turning ignition key to on position
2. OBC should show "Test"
3. Use Trip Reset to select function 19.0 that unlocks all the features
4. Wait for display to show "Off"
5. Depress Trip Reset for 1/4 second and release it
6. With no delay press Trip Reset several times to select one of the following functions
BMW E46 On-Board Computer (OBC) Hidden Codes
example description
1.1 4nnn K-number
1.6 Not used
1.7 04__44 CAN-version (04) **-revision index (44)
2 (test) Cluster System Test - Activates the gauge drivers, indicators and LEDs to confirm function -- 3 SI Data
3.0 1098 Used fuel in liters since last SI (Service Inspection)
3.1 0231 Periodic inspection days; elapsed days (since last SI)
4 Momentary Consumption
4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km
4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour
5 Distance Gone Consumption
5.0 082 Average mileage; 082=8.2 liters/100km
5.1 0536 Calc. km to refuel (momentary distance to go)
6 Fuel Level sensor inputs in liters
6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters
6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters
6.2 0442+ Indicated value (44.2) and tank phase
7 Temperature and Speed
7.0 021+ Coolant/Engine temperature (2.1C)
7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135
7.2 + Engine speed / Current RPMs 1/min
7.3 + Vehicle speed / Current Speed in km/hour
8 Input value in HEX form
8.0 1d0+ System voltage ADC-Value Hex code
8.1 26C33C+ ADC Values HG left/HG right
8.2 0000 ADC Value brake degradation sensor (000=o.k.)
8.3 18C ADC Value outside temperature
9 Battery
9.0 140 Battery Voltage - 140 = UB 14.0v
9.1 242013+?
9.2 074_78+?
9.3 0011+?
10 Not used
11 Not used
12 Not used
13 GonG Gong Test
14 Not used
15 Status cluster I/O-ports (bit codes) 0=low; 1=high
1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0 Status Digital Outputs (bits) 0=inactive, 1=active 1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot
16 Not used
17 Not used
18 Not used
19 Lock Status; unlocks functions in range 3-18
19.0 L-On/L-Off Unlock: press button when "L-Off"
20 Not used
21 Software Reset; reset OBC settings
00 End of test
bardz fajnie dzięki Lukasz PL
