Error codes
Witam, tak jak w temacie...czy posiada ktos z forum kody bledów to naszych bmw? Pozdrawiam!
Code Description
P1083
Fuel Control Mixture Lean (Bank 1 Sensor 1)
P1084
Fuel Control Mixture Rich (Bank 1 Sensor 1)
P1085
Fuel Control Mixture Lean (Bank 2 Sensor 1)
P1086
Fuel Control Mixture Rich (Bank 2 Sensor 1)
P1087
O2 Sensor
Circuit Slow Response in Lean Control Range (Bank 1 Sensor 1)
P1088
O2 Sensor Circuit Slow Response in Rich Control Range (Bank 1 Sensor 1)
P1089
O2 Sensor Circuit Slow Response in Lean Control Range (Bank 1 Sensor 2)
P1090
Pre-Catalyst Fuel Trim Too Lean Bank 1
P1091
Pre-Catalyst Fuel Trim Too Rich Bank 1
P1092
Pre-Catalyst Fuel Trim Too Lean Bank 2
P1093
Pre-Catalyst Fuel Trim Too Rich Bank 2
P1094
O2 Sensor Circuit Slow Response in Rich Control Range (Bank 2 Sensor 1)
P1095
O2 Sensor Circuit Slow Switching From Lean to Rich (Bank 1 Sensor 1)
P1096
O2 Sensor Circuit Slow Switching From Lean to Rich (Bank 2 Sensor 1)
P1097
O2 Sensor Circuit Slow Response after Coast Down Fuel Cutoff (Bank 1 Sensor 1)
P1098
O2 Sensor Circuit Slow Response after Coast Down Fuel Cutoff (Bank 2 Sensor 2)
P1111
Engine Coolant Temperature Radiator Outlet Sensor Low Input
P1112
Engine Coolant Temperature Radiator Outlet Sensor High Input
P1115
Coolant Temperature Sensor Plausibility
P1116
Mass Or Volume Air Flow Circuit Range/Performance Problem (Bank 2)
P1117
Mass Or Volume Air Flow Circuit Low Input (Bank 2)
P1118
Mass Or Volume Air Flow Circuit High Input (Bank 2)
P1120
Pedal Position Sensor Circuit
P1121
Pedal Position 1 Range/Performance Problem
P1122
Pedal Position 1 Low Input
P1123
Pedal Position 1 High Input
P1132
O2 Sensor Heater Control Circuit (Bank 1 Sensor 1)
P1133
O2 Sensor Heater Control Circuit (Bank 2 Sensor 1)
P1134
O2 Sensor Heater Circuit Signal Intermittent (Bank 1 Sensor 2)
P1135
O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 1)
P1136
O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 1)
P1137
O2 Sensor Heater Circuit Signal Intermittant (Bank 1 Sensor 2)
P1138
O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 2)
P1139
O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 2)
P1140
Mass or Volume Air Flow Circuit Range/Performance Problem
P1145
Solenoid Valve Running Losses Control Circuit Electrical
P1151
O2 Sensor Heater Circuit Signal Intermittant (Bank 2 Sensor 1)
P1152
O2 Sensor Heater Circuit Low Voltage (Bank 2 Sensor 1)
P1153
O2 Sensor Heater Circuit High Voltage (Bank 2 Sensor 1)
P1155
O2 Sensor Heater Circuit Intermittant (Bank 2 Sensor 2)
P1156
O2 Sensor Heater Circuit Low Voltage (Bank 2 Sensor 2)
P1157
O2 Sensor Heater Circuit High Voltage (Bank 2 Sensor 2)
P1158
Fuel Trim Additve Bank 1 Low
P1159
Fuel Trim Additve Bank 1 High
P1160
Fuel Trim Additve Bank 2 Low
P1161
Fuel Trim Additve Bank 2 High
P1162
Fuel Trim Additve Per Ignition Bank 1 Low
P1163
Fuel Trim Additve Per Ignition Bank 1 High
P1164
Fuel Trim Additve Per Ignition Bank 2 Low
P1165
Fuel Trim Additve Per Ignition Bank 2 High
P1174
Fuel Trim Adaptation Additve Bank 1 Malfunction
P1175
Fuel Trim Adaptation Additve Bank 2 Malfunction
P1176
O2 Sensor Slow Response Bank 1
P1177
O2 Sensor Slow Response Bank 2
P1178
O2 Sensor Signal Circuit Slow Switching From Rich to Lean (Bank 1 Sensor 1)
P1179
O2 Sensor Signal Circuit Slow Switching From Rich to Lean (Bank 2 Sensor 1)
P1180
O2 Sensor Signal Circuit Slow Switching From Rich to Lean (Bank 1 Sensor 2)
P1181
O2 Sensor Signal Circuit Slow Switching From Rich to Lean (Bank 2 Sensor 2)
P1182
O2 Sensor (Bank 1 Sensor 2) Open Circuit During Coast Down Fuel Cut-off
P1183
O2 Sensor (Bank 2 Sensor 2) Open Circuit During Coast Down Fuel Cut-off
P1186
O2 Sensor Heater Control Circuit (Bank 1 Sensor 2)
P1187
O2 Sensor Heater Control Circuit (Bank 2 Sensor 2)
P1188
Fuel Control (Bank 1 Sensor 1)
P1189
Fuel Control (Bank 2 Sensor 1)
P1190
Pre-catalyst Fuel Trim System Bank 1
P1191
Pre-catalyst Fuel Trim System Bank 2
P1192
Post-catalyst Fuel Trim System Bank 1
P1193
Post-catalyst Fuel Trim System Bank 2
P1221
Pedal Position Sensor 2 Range/Performance Problem
P1222
Pedal Position Sensor 2 Low Input
P1223
Pedal Position Sensor 2 High Input
P1270
Control Module Self-Test, Torque Monitoring
P1271
Ambient Air Pressure Sensor
Electrical
P1283
Switching Solenoid for Air Assisted Injection Valves Bank 1 Control Circuit Electrical
P1284
Switching Solenoid for Air Assisted Injection Valves Bank 1 Control Circuit Signal Low
P1285
Switching Solenoid for Air Assisted Injection Valves Bank 1 Control Circuit Signal High
P1287
Switching Solenoid for Air Assisted Injection Valves Bank 2 Control Circuit Electrical
P1288
Switching Solenoid for Air Assisted Injection Valves Bank 2 Control Circuit Signal Low
P1289
Switching Solenoid for Air Assisted Injection Valves Bank 2 Control Circuit Signal High
P1313
"A" Camshaft Position Plausibility
P1317
"B" Camshaft Position Plausibility
P1327
Knock Sensor 2 (Bank 1) Low Input
P1328
Knock Sensor 2 (Bank 1) High Input
P1332
Knock Sensor 4 Low Input
P1333
Knock Sensor 4 High Input
P1340
Multiple Cylinder Misfire During Start
P1341
Multiple Cylinder Misfire With Fuel Cut-off
P1342
Misfire During Start Cylinder 1
P1343
Misfire Cylinder 1 With Fuel Cut-off
P1344
Misfire During Start Cylinder 2
P1345
Misfire Cylinder 2 With Fuel Cut-off
P1346
Misfire During Start Cylinder 3
P1347
Misfire Cylinder 3 With Fuel Cut-off
P1348
Misfire During Start Cylinder 4
P1349
Misfire Cylinder 4 With Fuel Cut-off
P1350
Misfire During Start Cylinder 5
P1351
Misfire Cylinder 5 With Fuel Cut-off
P1352
Misfire During Start Cylinder 6
P1353
Misfire Cylinder 6 With Fuel Cut-off
P1354
Misfire During Start Cylinder 7
P1355
Misfire Cylinder 7 With Fuel Cut-off
P1356
Misfire During Start Cylinder 8
P1357
Misfire Cylinder 8 With Fuel Cut-off
P1358
Misfire During Start Cylinder 9
P1359
Misfire Cylinder 9 With Fuel Cut-off
P1360
Misfire During Start Cylinder 10
P1361
Misfire Cylinder 10 With Fuel Cut-off
P1362
Misfire During Start Cylinder 11
P1363
Misfire Cylinder 11 With Fuel Cut-off
P1364
Misfire During Start Cylinder 12
P1365
Misfire Cylinder 12 With Fuel Cut-off
P1384
Knock Sensor 3 Circuit
P1385
Knock Sensor 4 Circuit
P1386
Control Module Self-test, Knock Control Baseline Test Bank 1
P1396
Crankshaft Position Sensor Segment Timing Plausibility
P1397
Camshaft Position Sensor "B" Circuit (Bank 1)
P1400
Heated Catalyst Battery Voltage or Current too Low During Heating (Bank 1)
P1401
Heated Catalyst Current too High During Heating (Bank 1)
P1402
Heated Catalyst Power Switch Overtemperature Condition (Bank 1)
P1403
Carbon Canister Shut Off valve Control Circuit Electrical
P1404
Heated Catalyst Current too High During Heating (Bank 2)
P1405
Heated Catalyst Power Switch Overtemperature Condition (Bank 2)
P1406
Heated Catalyst Internal Control Module Checksum/ROM Error
P1413
Secondary Air Injection Pump
Relay Control Circuit Signal Low
P1414
Secondary Air Injection System Monitor Circuit High
P1420
Secondary Air Valve Control Circuit Electrical
P1421
Secondary Air System Bank 1
P1422
Secondary Air System Bank 2
P1432
Secondary Air Injection System Incorrect Flow Detected
P1438
Purge Control Valve Control Open Circuit
P1439
Purge Control Valve Control Circuit Signal Low
P1440
Purge Control Valve Control Circuit Signal High
P1441
Leakage Diagnostic Pump Control Open Circuit
P1442
Leakage Diagnostic Pump Control Circuit Signal Low
P1443
Leakage Diagnostic Pump Control Circuit Signal High
P1444
Diagnostic Module Tank Leakage (DM-TL) Pump Control Open Circuit
P1445
Diagnostic Module Tank Leakage (DM-TL) Pump Control Circuit Signal Low
P1446
Diagnostic Module Tank Leakage (DM-TL) Pump Control Circuit Signal High
P1447
Diagnostic Module Tank Leakage (DM-TL) Pump Too High During Switching
P1448
Diagnostic Module Tank Leakage (DM-TL) Pump Too Low During Switching
P1449
P1450
Diagnostic Module Tank Leakage (DM-TL) Switching Solenoid Open Circuit
P1451
Diagnostic Module Tank Leakage (DM-TL) Switching Solenoid Control Circuit Signal Low
P1452
Diagnostic Module Tank Leakage (DM-TL) Switching Solenoid Control Circuit Signal High
P1453
Secondary Air Injection Pump Relay Control Circuit Electrical
P1454
Secondary Air Injection Pump With Series Resistor Control Circuit Electrical
P1456
Heated Catalyst Heater Power Supply Open Circuit (Bank 1)
P1457
Heated Catalyst Heater Power Switch Temperature Sensor Electrical (Bank 1)
P1459
Heated Catalyst Heater Power Supply Open Circuit (Bank 2)
P1460
Heated Catalyst Heater Power Switch Temperature Sensor Electrical (Bank 2)
P1461
Heated Catalyst Gate Voltage Signal Low
P1462
P1463
Heated Catalyst Battery Temperature Sensor 1 Electrical
P1464
Heated Catalyst Battery Temperature Sensor 2 Electrical
P1465
Heated Catalyst Battery Temperature Sensor 1 or 2 Plausibility
P1466
Heated Catalyst Power Switch Temperature Sensor Plausibility
P1467
Heated Catalyst Comparison Battery Voltages of Power Switches Plausibility
P1468
Heated Catalyst Battery Disconnecting Switch Plausibility
P1470
Leakage Diagnostic Pump Control Circuit Electrical
P1472
Diagnostic Module Tank leakage (DM-TL) Switching Solenoid Control Circuit Electrical
P1473
Diagnostic Module Tank leakage (DM-TL) Pump Current Plausibility
P1475
Leakage Diagnostic Pump Reed Switch Did Not Close
P1476
Leakage Diagnostic Pump Clamped Tube
P1477
Leakage Diagnostic Pump Reed Switch Did Not Open
P1500
Idle Speed Control Valve Stuck Open
P1501
Idle Speed Control Valve Stuck Closed
P1502
Idle Speed Control Valve Closing Solenoid Control Circuit Signal High or Low
P1503
Idle Speed Control Valve Closing Solenoid Control Circuit Signal Low
P1504
Idle Speed Control Valve Closing Solenoid Control Open Circuit
P1505
Idle Speed Control Valve Closing Solenoid Control Circuit Electrial
P1506
Idle Speed Control Valve Open Solenoid Control Circuit Signal High
P1507
Idle Speed Control Valve Open Solenoid Control Circuit Signal Low
P1508
Idle Speed Control Valve Opening Solenoid Control Open Circuit
P1509
Idle Speed Control Valve Opening Solenoid Control Circuit Electrial
P1510
P1511
DISA Control Circuit Electrical
P1512
DISA Control Circuit Signal Low
P1513
DISA Control Circuit Signal High
P1519
"A" Camshaft Position Actuator Bank 1
P1520
"B" Camshaft Position Actuator Bank 1
P1522
"A" Camshaft Position Actuator Bank 2
P1523
"A" Camshaft Position Actuator Signal Low Bank 1
P1524
"A" Camshaft Position Actuator Signal High Bank 1
P1525
"A" Camshaft Position Actuator Control Open Circuit Bank 1
P1526
"A" Camshaft Position Actuator Control Open Circuit Bank 2
P1527
"A" Camshaft Position Actuator Control Circuit Signal Low Bank 1
P1528
"A" Camshaft Position Actuator Control Circuit Signal High Bank 1
P1529
"B" Camshaft Position Actuator Control Circuit Signal Low Bank 1
P1530
"B" Camshaft Position Actuator Control Circuit Signal High Bank 1
P1531
"B" Camshaft Position Actuator Control Open Circuit Bank 1
P1532
"B" Camshaft Position Actuator Control Open Circuit Bank 2
P1533
"B" Camshaft Position Actuator Control Circuit Signal Low Bank 2
P1534
"B" Camshaft Position Actuator Control Circuit Signal High Bank 2
P1540
P1541
Pedal Position Sensor Double Error
P1542
Pedal Position Sensor Electrical
P1543
P1544
P1545
P1546
P1550
Idle Speed Control valve Closing Solenoid Control Circuit Electrical
P1551
P1552
P1556
P1560
P1564
Control Module Selection
P1565
P1569
P1580
Throttle Valve Mechanically Stuck
P1581
P1589
Control Module Self Test, Knock Control Test Pulse Bank 1
P1593
P1594
P1602
Control Module Self Test, Control Module Defective
P1603
Control Module Self Test, Torque Monitoring
P1604
Control Module Self Test, Speed Monitoring
P1607
CAN Version
P1608
Serial Communicating Link Control Module
P1609
Serial Communicating Link EML
P1611
Serial Communicating Link Transmission Control Module
P1619
MAP Cooling Control Circuit Signal Low
P1620
MAP Cooling Control Circuit Signal High
P1622
MAP Cooling Control Circuit Electrical
P1623
Pedal Position Sensor Potentiometer Supply
P1624
Pedal Position Sensor Potentiometer Supply Channel 1 Electrical
P1625
Pedal Position Sensor Potentiometer Supply Channel 2 Electrical
P1632
Throttle Valve Adaptation; Adaptation Condition Not Met
P1633
Throttle Valve Adaptation; Limp Home Position
P1634
Throttle Valve Adaptation; Spring Test Failed
P1635
Throttle Valve Adaptation; Lower Mechanical Stop Not Adapted
P1636
Throttle Valve Control Circuit
P1637
Throttle Valve Position Control; Control Deviation
P1638
Throttle Valve Position Control; Throttle Stuck Temporarily
P1639
Throttle Valve Position Control; Throttle Stuck Permanently
P1640
Internal Control Module (ROM/RAM) Error
P1690
Malfunction Indicator Lamp (MIL) Electrical
P1734
Pressure Control Solenoid "B" Electrical
P1738
Pressure Control Solenoid "C" Electrical
P1743
Pressure Control Solenoid "E" Electrical
P1744
Pressure Control Solenoid "A" Electrical
P1746
Transmission Control Module Output Stage
P1747
CAN Bus Monitoring
P1748
Transmission Control Module Self Test
P1749
Secondary Pressure Solenoid Communication Error
P1750
Secondary Pressure Solenoid Circuit Range/Performance
P1751
Secondary Pressure Solenoid Open Circuit
P1761
Shift Solenoid Malfunction
P1765
CAN Throttle Valve
P1770
CAN Torque Interface
P1780
CAN Torque Reduction
Audi B2 4.2 V8 yeahh
BMW e91 2.0d
Dzieki wielkie koledzy :) tylko ze bardziej chodzilo mi o kody no. takiego typu CID 88 wyskakuje mi taki blad jak dluzej przytrzymam przycisk BC na "czerwonym podnosniku" Dzieki i pozdrawiam!
Hej,
Czy Tobie tez od czasu do czasu pokazuje sie czerwony podnosnik zaraz po uruchomieniu samochodu??
Ja mam ten problem i aso rozklada rece, nie wiedza co jest przyczyna, komputer niby nie pokazuje im zadnych bledow.
Nie wiem co z tym zrobic i strasznie mnie to denerwuje.
Pozdrawiam.
To auto na podnosniku jest to informacja o terminie lub ilości kilometrów po których należy dokonać jakiejś operacji serwisowej zgodnie z tym co wyswietla komputer.. jesli jest jeszcze dość odległy czas do tej wymiany to przy odpaleniu to auto na podnośniku ma kolor żółty, jesli czerwony to znaczy że przekroczono juz termin i trzeba sie zgłosić do serwisu i zrobić to co trzeba..
pzdr
Jeśli Bmw to religia, to M5 jest Mesjaszem.
