dzieki Bicker te lampki tylne sa naprawde wypasione ale z tego co widzialem w salonie bmw jezeli sie nie myle to swiecily same te paski...
a co do przodu to u mnie tez na zolto ale dzieki temy przy zenonie moze tak to wszytsko sie nie zlewa w jedna calosc a tu jest zestaw jezeli ktos che zmienic kolor ringow:
http://cgi.ebay.com/ebaymotors/PIAA-6500K-Super-LED-White-E87-E39-E60-X5-Angel-Eye-473_W0QQcmdZViewItemQQcategoryZ33713QQihZ018QQitemZ280112958732QQrdZ1QQsspagenameZWD2V
troszke przydrogawy ten zestaw na ebay widziałem za 90$ jakoś tylko zamawiać ze stanów troche mi się nie uśmiecha.
prosba o przetłumaczenie(nie musi być szczegółowe). Wydaje mi się to dość istotne. Z góry dzięki
nick, from looking at your pins diagram. it is the correct and prefer way to hook up. the only drawback is the 3 back lightbulbs will wash out the lightrods. but there is an easy solution to it by hooking up some diodes.
if i remember correctly from taking the voltage reading...the taillight pin gives ~9 volts to the 3 backlight bulbs. each bulbs will be ~3V and appears on but not too bright. by installing a few diodes in series to the pin we can drastically reduce the voltage to those light bulb to a low value. this will make the light bulbs very dim and at the same time the LCM will still detect the lightbulbs and cause NO error message . diodes will allow electricity(current) to flow in one direction and cause a voltage drop called the foward voltage in data sheet. the voltage regulator zener diodes are used for voltage regulation. there are different values 3V-9V etc. by reversing a zener diode, we can use the value of the voltage regulation as a voltage drop too!
in electronic hardware store, there are many kind of diodes....but all diodes exhibit the forward voltage drop. silicone diodes will drop the voltage by ~.7v while other ones might drop ~1v. we can hook up a few of these diodes in series to get a desire voltage drop. about the power rating of the diode, the light bulbs at 21 watts with 12 voltage source, will draw about ~2 A of current. i recommend getting a diode with a minimum of 3 amperes. i hooked up one of the diode to the pin and was successful in getting a reduce voltage of 1V and this was expected since the particular 6 amp rectifier diode were designed to have a ~1v drop. i'm certain this solution will easily fix the aesthetic problem. i hope nick or someone else can give it a try very soon.
i do NOT recommend my pin setup. in the further i'll have to rehook it again. as a few here have speculated i did use only the european fog or the big bottom center circle light bulb as my brake light. the brake light pin will always give a light when the parkinglight/headlight is switched to on. that is why i did not connect the tailight pin. however to trick the computer from not giving me the error msg, i connected the grey/green and black/red (pin 2 ,4, 7) all together i know this is a bad idea--i have 2 wires with different voltages, one is 9V, other one is 3V. what happens in this circuit, the output voltage will be 6V. however the current from the 9V wire will flow to the lower 3V wire too! assuming the battery has build in resistance, this will slowly drain the battery when car is not running and parkinglight is turned on. in addition, when brake is applied...voltage output goes to around 12.5V-13V. this will burn out the bulb prematurely if it didn't burn out right away. the next day i finally had a chance to correct the voltage problem by putting a diode to get it back safely under 12V. Again, i don't recommend this solution. i have some time, i'll need to rehook the wires back according to nick's diagram.
Tylnia lampa pobiera ~9 v na 3 żarówki. Na każdą żarówkę przypada ~3 v, więc okazuje się, że nie jest zbyt jasna. Instalując kilka diod szeregowo możemy drastycznie zredukować (zmniejszyć) napięcie do żarówek. Spowodować może to przygasanie(ściemnianie) żarówek, w tym samym czasie LCM będzie wykrywać żarówki i nie będzie wyświetlać błędu. Regulator napięcia zener jest używany do regulacji napięcia. Są różne wartości 3V-9V itd. ??????Instalując "zener" do diod możemy użyć go do zmian napięcia, tak aby było odpowiednie (po zainstalowaniu diod)????????????
W sklepach z częściami elektronicznymi jest dużo typ diód, ale każda spowoduje spadek napięcia. Diody silikonowe spowodują spadek o 7 V , natomiast inne mogą o np. 1 V. Możemy sprawdzić kilka typów, aby uzyskać odpowiedni spadek napięcia. Żarówki o mocy 21 watt z z 12 v. napięciem pobierają 2 A . Polecam zakup diod z minimum 3 A . Podłączając diodę uzyskałem odpowiednie zredukowanie napięcia o 1 V.
pod kreskami metoda której nie poleca
dzięki tora. Twoa pomoc jest dla mnie nieoceniona. W poniedziałek lub wtorek przystąpuje do działania. Dam znać co i jak z tymi światełkami
Cześć,
bicker, z innych postów widzę, że śledzisz postępy gości na e60.net. Jak na razie nie mają gotowego i pewnego rozwiązania. Kable, o ktorych wcześniej mowa wykonał jeden z forumowiczów (chyba z Brazylii) ale mają problem z mocnym nagrzewaniem się rezystora. Na razie nie udało im się powtórzyć pełnej funkcjonalności z modelu LCI. Najmądrzejsze (z technicznego punktu widzenia posty mają nicke60gre, rudy, bruce_miranda, Rootkit i alex.br.
Powodzenia z Twoimi lampami, daj znać, jak udało Ci się finalnie je zainstalować.
Pozdrawaim,
Witek
witam wczoraj zamontowalem tylnie lapy diodowe w warsztacie wszytsko dziala super zero mrugania i bledow czas motazu ok 4 godzin :D :cool2:
pozdrawiam bazyl00
pozdrawiam bazyl00
i jak zamontowal , dokladali jakies oporniki ? czy kupiles gotowe przejscia ? jak mozesz to pokaz jakies fotki jak to wyglada
Raz BMW / / / Zawsze BMW http://img528.imageshack.us/img528/4160/motorsporticon0ms.gif
bazyl a powiedz mi czy świecą Ci się zarówki od świateł czy tylko podczas hamowania?
SWIECI TYLKO JEDNA ZAROWKA TA OKRAGLA RESZTA SWIECI TYLKO PRZY HAMOWANIU NEONKI SWIECA CALY CZAS FOTKI WIECZOREM
pozdrawiam bazyl00
w warszatacie zamontowali jakies przejscia nestety jest to ukryte nie bede otwieral tapicerki puszki wielkosci 8cmna 5 cm czarne podlaczone do nowych lamp
gdzie ci to zakladali. mozesz podac nazwe serwisu miejscowosc tel adres ::) i jaki koszt podlaczenia ?
Gliwice facet ma super sprzet zmienia soft itd. bez problemu. montaz swiatelek 500 zl
no to autostrada z wroclawia jakas godzinke . mozesz podac do niego jakies namiary ?
Też monitorowałem to co wypisują na tamtym forum. Na przełomie lipca i sierpnia miał się pojawić kompletny kit do montażu diodowych lamp z wersji od 2006 do wersji 2003 - 2006. To sa zdjęcia tego kitu-kabla. Ciekawi mnie czy jest już u nas i ile to kosztuje?
Czytałem tam ciekawy artykuł o podłączaniu ipoda poprzez specjalny kit pod navi i oglądaniu video. Widziałem tam film na całej szerokości ekranu.LOL
