e91 320d
pod koniec stycznia udało mi się kupić taki oto samochód:
VIN: WBAUY11020F042078
Type code: UY11
Model: 320D (EUR)
E-F-R series: E91 LCI (LifeCycleImpulse)
Series: 3
Type: TOUR
Steering: LL
Doors: 5
Engine: N47T
Displacement: 2.00
Power: 135 (183 hp)
Drive: HECK
Transmission: AUT
Paint code: 475 - BLACK SAPPHIRE METALLI
Upholstery code: FMAT - POLSTER IMPULS M
Prod.date: 2011-09-08
S1CA SELECTION COP RELEVANT VEHICLES
S1CB ACEA / CO2 scope
S1CD Brake Energy Regeneration
S2K9 LM RAEDER V-SPEICHE 360
S4AE Armrest front, retractable
S4CG Interior trim strips "satin-silber" matt
S6AA BMW TeleServices
S6AB Control, Teleservices
S6FL USB/audio interface
S6VC STEUERUNG COMBOX
P7KA NAVIGATIONPAKET BUSINESS
P7RS Package Comfort
S8SC Telematics access request,country-spec.
S8SP Control unit COP
S8TL TAGFAHRLICHT FRONT UND HECK AKTIV
S8TN TAGFAHRLICHT UEBER LICHTMENUE EINST
S205 Automatic transmission
S216 HYDRO STEERING-SERVOTRONIC
S230 Extra package, EU-speciifc
S240 Steering wheel, leather
S249 Multifunction f steering wheel
S313 Fold-in outside mirror
S320 Deleted, model lettering
S321 Exterior parts in vehicle colour
S423 Floor mats, velours
S428 Warning triangle and first aid kit
S431 Interior rear-view mirror with auto dip
S488 Lumbar support, driver and passenger
S493 Storage compartment package
S494 Seat heating driver/passenger
S508 Park Distance Control (PDC)
S520 Fog lights
S521 Rain sensor
S534 Automatic air conditioning
S540 Cruise control
S548 Kilometre speedo
S606 Navigation system Business
S612 BMW Assist
S615 Extended BMW Online Information
S616 BMW Online
S620 Voice control
S633 Preparation, mobile phone, Business
S698 Area-Code 2 for DVD
L801 NATIONAL VERSION GERMANY
S851 Language version German
S879 Operating instructions German
Od chwili zakupu, samochód przeszedł kilka zmian. W przyszłości zamierzam robić fotorelacje z ewentualnych napraw.
Zazdroszczę servotronicu i automatu :) Ale mógłbyś opisać co pozmieniałeś i dać więcej zdjęć... :P
Zmiany od momentu zakupu:
- dołożone relingi niskie, czarny mat
- przyciemnione tylne szyby
- założone felgi aluminiowe 16'
- polerka lakieru tak na szybko, czyli tylko pastami
Z mechanicznych rzeczy:
- wymiana oleju i filtra
- wymiana filtra kabinowego
Korzystając z Waszego doświadczenia podpowiedzcie na co zwrócić uwagę.
Co do servotronica to jak możesz to napisz czym się różni od zwykłego wspomagania elektrycznego? Dotychczas jeździłem tylko oplem corsą ze wspomaganiem elektrycznym i powiem szczerze, że tam to jakoś dziwnie samochód się prowadzi, nie czuć za bardzo tego co się dzieje z kołami. Bałem się tego wspomagania w BMW, ale jak się przejechałem to za bardzo nie czułem różnicy pomiędzy wspomaganiem hydraulicznym.
Automat przyjemnie zmienia biegi. Dlatego nie wiem, czy wymieniać w ogóle olej. Jakie są wasze doświadczenia?
Na chwilę obecną samochód wygląda tak:
Jeszcze jedna wątpliwość, mierzyłem szyby z przodu, wyszło 80% przepuszczalności światła. Wychodzi zatem, że żeby jeździć zgodnie z prawem to można użyć foli przyciemniającej w 10%. Ktoś przyciemniał może u siebie, jeżeli tak to jaką folią i czy nie miał problemów z widocznością?
gratulacje auta! pięknie się prezentuje :cool2:
ja u siebie mam lekko przyciemniony przód i powiem, że jest super! nie przeszkadza w ogóle, zaś miśki jeszcze się również nie ustosunkowały do nich, choć kilka razy stali na pasie obok i przyglądali się
(jak chcesz zobaczyć jak to u mnie wyszło to w zasadzie wszystkie fotki w galerii mam z takimi szybami, zaś parametry z certyfikatu są na końcu 1 postu - 50/20/05a - nie wiem do końca co oznaczają te parametry, ale są ;)
Galeria: E91 320D LCI M-Pakiet 2009r.
2010-2016 E46 Touring 320D 136km 2000r.
2016-2017 E91 318i LCI 143km 2008r.
2017 E91 320d LCI 206km|393Nm 2009r.
kod zniżkowyna 5€ do Carly: XAZHF8
http://yanosik24.pl/widget/64583.png
Relingi niesamowicie dodają uroku E91 :cool2: Szyby też na +, ale przód jak sam zauważyłeś za bardzo się odcina. Autko ma potencjał ;)
Moje galerie:
Jest ?BMW F36 440I // TOYOTA GR SUPRA
Była ? BMW F30 335XI
https://www.bmw-klub.pl/forum/viewtopic.php?f=167&t=397494
Była ? BMW E90 330D
https://www.bmw-klub.pl/forum/viewtopic.php?f=158&t=339724
Te niskie bardziej mi się podobają, a w sumie były w tych samych pieniądzach co te wysokie.
Jakiś czas temu pojawił mi się komunikat o zużytych klockach z tyłu. Rzuciłem na nie okiem i okazało się, że są tak na 90%. Skasowałem inspekcje i na desce wyświetliły się takie oto rzeczy:
Okazało się, że przerwał się przewód od czujnika zużycia klocków. Zakupiłem zatem:
I zabrałem się za wymianę. Sprawa prosta, trzeba tylko odkręcić kilka śrub trzymających osłonę nadkola, wyjąć stary czujnik i zastąpić nowym. Sam czujnik najprawdopodobniej można przymocować do wewnętrznego klocka bez zdejmowania zacisku. Ja demontowałem ponieważ przy okazji chciałem przeczyścić zaciski z rdzy. Całość 40 min roboty.
Białe łączenie - czujnik zużycia klocków
Szare łączenie - czujnik ABS
Po podłączeniu nowego czujnika i skasowaniu inspekcji wszystkie ostrzeżenia zniknęły.
Edytowane przez Marcin1987
Tylko eibach prokit + koła minimum 17" uratują wygląd tego auta.... o bixenonach i sport kierownicy nie wspomnę...
Jeśli się okaże, że auto zostaje na dłużej:
eibach prokit (masz na myśli zawieszenie?) - myślę że nie, chyba że da się obniżyć, przy jednoczesnym zachowaniu obecnej "miękkości"
koła minimum 17" - chciałbym
bixenony - raczej nie
sport kierownica - chciałbym
Fizyka nie pozwala. Przy każdym obniżeniu jest uszczerbek na komforcie.
Eibach prokit jest genialne (same sprężynki) - zachowujesz komfort w 90% i obniżasz auto o ok. 2cm... Komfort to opony NIE runflat...
Bixenony: dość droga i upierdliwa impreza ale za 3k powinieneś się wyrobić z montazem oraz zaslepkami sprysków... WARTO
Kiera sport: wystarczy zakup, montaż to 20 min... WARTO
Generalnie lepiej kupić auto wyposażone w te rzeczy fabrycznie, tu moja e91 na prokicie i 18":
http://static.pokazywarka.pl/g/b/0/a0bfb46fc6a1f3ec9ca0028e174febb5_big.jpg?1525086522
http://static.pokazywarka.pl/s/v/u/d0f7f6616b622de1fa908942b199cb08_big.jpg?1525086670
Gratuluje autka.
Generalnie uważam, że lepiej jak już wszystko jest w fabryce ogarnięte, ale niestety kupując samochód miałem ograniczony budżet. Bardziej zależało mi na stanie technicznym oraz na tym żeby auto było bezwypadkowe. Poruszają się w jakichś widełkach cenowych trzeba było iść na kompromis kosztem np. wyposażenia.
A jak stan techniczny? Rozrząd miałeś wymieniony? jezeli od handlarza to pewnie nawet nie wiesz czy ruszany... uroki brania aut od handlarzy... :(
Tak, samochod był kupiony od handlarza. Rozrząd nie był ruszany. A przez stan techniczny rozumiem to czy ktos samochód serwisował i gdzie. W tym przypadku sprzedający pozwolił samochodem przejechać się na tablicach serwisowych z podłączonym komputerem. To dało mi podstawy stwierdzić czy samochód jest warty uwagi.
Czyli na rozrząd szykuj kase. Druga sprawa sprawdziłeś wartości ciśnien dpf na wolnych i wysokich obrotach?
Czemu mam szykować? Na chwilę obecną nie widzę (słyszę) żadnych niepokojących oznak. Jeśli takie się pojawią to będę myślał, chociaż dla mnie to nie jest jakiś problem, ponieważ takie już są dzisiejsze samochody i trzeba się z tym pogodzić. Kupując ten samochód byłem świadom jego wad, ale nie zamierzam (jak niektórzy piszą na forum) wymieniać czegoś prewencyjnie. Co do DPF wszystkie parametry w normie.
Obyś nie usłyszał raz, a porządnie :nienie: Poczytaj o rozrządzie w N47 i przemyśl :P
Moje galerie:
Była ? BMW E90 330D
Z rozrządem w N47 jest tak, że nie musi być go słychać przed zerwaniem :D Kupując auto z tym silnikiem trzeba wliczyć w koszty wymianę rozrządu :/
---------------------------------Moja galeria------------------------------------
https://www.bmw-klub.pl/forum/viewtopic.php?f=158&t=339720&p=2477504#p2477504 jest
http://www.bmw-klub.pl/forum/viewtopic.php?f=158&t=306494 [*] była
Jestem przeciwnikiem brania aut od handlarzy bo nigdy ci taki nie powie czy byl rozrząd wymieniany miesiąc temu czy może nigdy. Biorąc od handlarza pakujesz sie w pakiet startowy wynoszący od 3 do 13 tysiaczków... ewentualnie nie robisz nic i czekasz aż coś łupnie :(
Inna sprawa, że to co "ktoś" powie, że rozrząd był zmieniany, nie zawsze musi oznaczać prawdę :twisted: :mad2:
Moje galerie:
Była ? BMW E90 330D
Te relingi robią robotę! Eibacha bym się nie bał,ale musiałbyś zrezygnować z run flatów, nie doczytałem czy już to zrobiłeś :) Jak nie chcesz iść w m-pakiet, to poluj na sportowa kierownicę z podgrzewaniem, super sprawa :D
Dzięki za rady, ale na pewno nie będę niczego wymieniał jeżeli nie ma żadnych objawów.
Opony mam zwykłe, na takich kupiłem i pewnie przy takich zostanę. Nie prowadziłem nigdy samochodu na ROF więc nie mam porównania, ale tak jak teraz jest mnie satysfakcjonuje. Z niższym zawieszeniem bardziej mi się podoba. Jeżeli moje zawieszenie się posypie to na pewno przemyślę poważnie sprawę.
W sumie nie masz co i po co wymieniać, skoro auto już wisi od jakiegoś czasu na allegro...
jak wygląda zainteresowanie ?
