[E39] 528i wysokie spalanie
.xKamiLx.
Witam wszystkich forumowiczów.
Mam problem z moim autem otóż od zeszłego tygodnia zaczęło palić drakońskie ilości paliwa(rzędu 20l/100km)
Inpa pokazuje takie błędy
E R R O R M E M O R Y R E P O R T -------------------------------------
Date: 05/02/16 13:19:58 ECU: MS420DS0 JobStatus: OKAY Variant: MS420DS0-------------------------------------------------------------
RESULT: 4 errors in error memory !-------------------------------------------------------------
153 Signal Lambda probe before-Kat Bank 2 max value over limit
Error frequency : 1 Logistic counter: 40
Engine speed 736.00 1/min load 103.49 mg/Hub temperature cooling water 70.50 Grad C lambda probe voltage control probe Bank 1.28 V appear before (rel.) 2.50 h
Kurzschluss gegen U-Batt. CARB-Fehler Fehler nach Entprellung gespeichert Fehler momentan nicht vorhanden sporadischer Fehler
Errorcode: 99 B1 01 28 17 13 9E FF B4 5B-------------------------------------------------------------
55 avtivate Lambda probe heating before KAT Bank 2
Engine speed 736.00 1/min load 103.49 mg/Hub lambda probe voltage control probe Bank 1.28 V temperature cooling water 70.50 Grad C appear before (rel.) 2.50 h
Leitungsunterbrechung CARB-Fehler Fehler nach Entprellung gespeichert Fehler momentan vorhanden statischer Fehler
Errorcode: 37 74 01 28 17 13 FF 9E B4 5B-------------------------------------------------------------
140 Signal tank-leck-diagnostic-pump reed-switch not clossed
load 103.49 mg/Hub Engine speed 736.00 1/min temperature cooling water at the start 66.00 Grad C temperature intake air 30.00 Grad C appear before (rel.) 2.50 h
Reed-Switch nicht geschlossen CARB-Fehler Fehler nach Entprellung gespeichert Fehler momentan vorhanden statischer Fehler
Errorcode: 8C 72 01 28 13 17 98 68 B4 5B-------------------------------------------------------------
18 Signal Camshaft sensor outlet
Error frequency : 4 Logistic counter: 40
Engine speed 832.00 1/min engine condition = idle 4.00 -- oel temperature 84.15 Grad C Battery Voltage 13.87 V appear before (rel.) 2.30 h
Signal nicht plausibel CARB-Fehler Fehler nach Entprellung gespeichert Fehler momentan nicht vorhanden sporadischer Fehler
Errorcode: 12 B8 04 28 1A 04 A6 88 B4 5D =============================================
Za pomoc z góry dziękuje
Weź pod uwagę fakt, że sondy mogły wcześniej nie działać prawidłowo, a dopiero teraz paść zupełnie. Poczytaj sobie czym są i za co odpowiadają.
Zrób odczyt life data i się przekonasz czy tak jak twierdzisz, nie one są winne.
Błąd 140 to uszkodzony zawór magnetyczny odpowietrzenia zbiornika, nr części 1748875.
pzdr
yaz
Auto właśnie miało jechać na większy przegląd i wymiane tej sondy.
Nowe sondy tylko orginał czy zamienniki też dadzą rade?(różnie ludzie piszą)
Dzisiaj po podłączeniu kompa błędy 18 i 140 już nie wyskakiwały. Czy mimo to i tak wymienić czujnik wałka?? Bo teraz nie wiem czy jest w końcu sprawny czy nie.
Możesz spróbować na początek zakupić sondę używkę,tylko aby była dedykowana do Twojego auta(kolory przewodów) jak u mnie padła sonda wzrost spalania był zauważalny od razu. Kupiłem używkę na "gwarancji rozruchowej" i śmiga już półtora roku. Skoro nie masz problemów z mocą w aucie to odpuść na chwilę obecną wymianę czujnika wałka, wymienić go możesz w każdej chwili jak zajdzie potrzeba.
