[E46] 330d - prośba o interpretację błędów, livedata
E46 330d, rok produkcji 2000, 276k km, problemy z odpalaniem na mrozie, gigantyczne spalanie 10l<, falujące obroty (podgrzewacz)
E R R O R   M E M O R Y   R E P O R T           -------------------------------------
Date:      12/14/12 14:19:56 ECU:       DDE40KW0 JobStatus: OKAY Variant:   DDE40KW0-------------------------------------------------------------
RESULT:    7 errors in error memory !-------------------------------------------------------------
7680  CAN - bus
Error frequency : 26 Logistic counter: 40
  Error occured 1. times at:
  Engine speed                                 0.00  1/min   Supply voltage                              11.69  V   Einspritzmenge                              25.09  mm^3   driving speed                                0.00  km/h   Fehler aufgetreten bei                   267810.00  km
  Error occured 2. times at:
  Engine speed                                 0.00  1/min   Supply voltage                              11.11  V   Einspritzmenge                              56.32  mm^3   driving speed                                0.00  km/h   Fehler aufgetreten bei                   276430.00  km
  Error occured 3. times at:
  Error present   Sporadic error   Receive fault transmission control (EGS)
Errorcode: 1E 00 28 1A FC 01 00 65 31 00 68 9D 01 00 60 6E           00 6B FB 01 00 60 6E 00 6B-------------------------------------------------------------
6690  flap
Error frequency : 76 Logistic counter: 40
  Engine speed                                 0.00  1/min   Coolant temperature                         68.20  Grad C   Einspritzmenge                              25.09  mm^3   RPC rail pressure                            0.00  bar   Fehler aufgetreten bei                   267810.00  km
  Engine speed                                 0.00  1/min   Coolant temperature                         -8.94  Grad C   Einspritzmenge                              55.30  mm^3   RPC rail pressure                          102.41  bar
  Engine speed                                 0.00  1/min   Coolant temperature                         -8.94  Grad C   Einspritzmenge                              55.30  mm^3   RPC rail pressure                          102.41  bar   Fehler aufgetreten bei                   276430.00  km
  Error present   Sporadic error   Open circuit or short circuit to B-
Errorcode: 1A 22 28 4C FC 08 00 A0 31 00 68 9D 08 00 2F 6C           11 6B FB 08 00 2F 6C 11 6B-------------------------------------------------------------
1028  EGR control
Error frequency : 255 Logistic counter: 32
  Engine speed                              1448.55  1/min   Coolant temperature                         83.91  Grad C   Einspritzmenge                              15.36  mm^3   RPC rail pressure                          542.17  bar   Fehler aufgetreten bei                   267830.00  km
  Engine speed                              1498.50  1/min   Coolant temperature                         53.18  Grad C   Einspritzmenge                              15.87  mm^3   RPC rail pressure                          536.14  bar   Fehler aufgetreten bei                   276290.00  km
  Engine speed                              1898.10  1/min   Coolant temperature                         70.25  Grad C   Einspritzmenge                               9.22  mm^3   RPC rail pressure                          536.14  bar   Fehler aufgetreten bei                   276440.00  km
  Error not present   Sporadic error   neg. deviation / Air mass to big
Errorcode: 04 04 20 FF F8 20 3A B7 1E 5A 68 9F 20 3C 8A 1F           59 6B ED 20 4C A3 12 59 6B-------------------------------------------------------------
256   air mass meter
Error frequency : 7 Logistic counter: 40
  Engine speed                                 0.00  1/min   Coolant temperature                         77.08  Grad C   Einspritzmenge                              24.58  mm^3   RPC rail pressure                          536.14  bar   Fehler aufgetreten bei                   269120.00  km
  Engine speed                                 0.00  1/min   Coolant temperature                         37.48  Grad C   Einspritzmenge                              25.60  mm^3   RPC rail pressure                            0.00  bar   Fehler aufgetreten bei                   274750.00  km
  Error present   Sporadic error   Signal open circuit or short circuit to B-
Errorcode: 01 00 28 07 FC 10 00 AD 30 59 69 20 10 00 73 32           00 6B 53 10 00 73 32 00 6B-------------------------------------------------------------
400   Rail-pressure sensor
Error frequency : 21 Logistic counter: 30
  Engine speed                               624.38  1/min   fuel pre-supply pressure                     3.81  bar   Einspritzmenge                              16.39  mm^3   RPC rail pressure                          397.59  bar   Fehler aufgetreten bei                   269120.00  km
  Engine speed                               124.88  1/min   fuel pre-supply pressure                     4.00  bar   Einspritzmenge                              55.81  mm^3   RPC rail pressure                          493.98  bar   Fehler aufgetreten bei                   276430.00  km
  Error not present   Sporadic error   Open circuit or short circuit to B+
Errorcode: 01 90 1E 15 D8 02 19 EE 20 42 69 20 02 05 FA 6D           52 6B FB 02 05 FA 6D 52 6B-------------------------------------------------------------
6660  Coolant temperature heater
Error frequency : 255 Logistic counter: 39
  Engine speed                              1298.70  1/min   Coolant temperature                         52.50  Grad C   Einspritzmenge                              25.09  mm^3   Supply voltage                              11.92  V   Fehler aufgetreten bei                   271240.00  km
  Engine speed                              1423.58  1/min   Coolant temperature                         53.18  Grad C   Einspritzmenge                              17.41  mm^3   Supply voltage                              13.08  V   Fehler aufgetreten bei                   271240.00  km
  Engine speed                               749.25  1/min   Coolant temperature                         72.98  Grad C   Einspritzmenge                               7.17  mm^3   Supply voltage                              12.96  V   Fehler aufgetreten bei                   276460.00  km
  Error present   Sporadic error   Over temperature detection   Open circuit or short circuit to B-
Errorcode: 1A 04 27 FF 7C 80 34 89 31 67 69 F4 01 39 8A 22           71 69 F4 01 1E A7 0E 70 6B-------------------------------------------------------------
13573 glow device
Error frequency : 106 Logistic counter: 40
  Engine speed                               849.15  1/min   Coolant temperature                         14.95  Grad C   Einspritzmenge                              14.34  mm^3   RPC rail pressure                          373.49  bar   Fehler aufgetreten bei                   271500.00  km
  Engine speed                                 0.00  1/min   Coolant temperature                        -10.31  Grad C   Einspritzmenge                              56.32  mm^3   RPC rail pressure                           12.05  bar   Fehler aufgetreten bei                   276430.00  km
  Error present   Sporadic error   Glow system - Glow-plug or Glow-plug relay
Errorcode: 35 05 28 6A FC 80 22 52 1C 3E 6A 0E 80 00 2D 6E           02 6B FB 80 00 2D 6E 02 6B =============================================================
Po wymiane 6-go wtrysku korekcja spadła z cylindrów #1 z 2.5 i #6 z -2.5 na odpowiednio ~1.3 i ~-1.3
I analog values:
http://img6.imageshack.us/img6/8384/analogvalues2.jpg
http://img715.imageshack.us/img715/1939/korekcje.jpg
Wtryski masz ok, stawiałbym na problem z zasilaniem, akumulator masz dobry? Albo może coś z alternatorem, zobacz jaki masz Voltage, jest za niski.
Druga sprawa to niskie ciśnienie na listwie i problem może być z pompą progową lub wtryskową. Obadaj pompę wtryskową czy nie jest obluzgana ON.
Czy auto jest słabsze, kręci się tylko do 3-3,5k obrotów?
_____________________
do sprawdzenia akumulator i alternator. Ładowanie za niskie. Błąd podgrzewacza, świec żarowych, przepływomierza, egr (albo sterowanie ale węzyki) do sprawdzenia i czyszczenia, czujnik w listwi wtryskowej (niskie ciśnienie paliwa. albo pompka podprogowa albo filtr paliwa albo sam czujnik). Na poczatek zrób ładowanie. Pozniej zobaczysz co sie dalej dzieje
Auto ma moc, silnik się kręci powyżej 3.5k obr/min
Akumulator z datą produkcji 2010
To w takim razie sprawdź alternator, bo ewidentnie masz za niskie napięcie.
Ładowanie akumulatora po odpaleniu silnika - mierzone miernikiem - 14.6V - wyłączone odbiorniki prądu, 14V dla włączonego radia, ogrzewania i swiateł
