scooby90
Treść opublikowana przez scooby90
  1. scooby90 opublikował(a) temat w E39
    Witam mam pytanko w mojej buni nie dziala licznik sa tam 3 kostki czy jak kupie nowy licznik musi byc on rowniez od 2.5? czy to bez rozniczy wazne zeby byl z automata bo ja taki posiadam czy jednak musi byc konkretnie od tego danego modelu ?
  2. wersja inpa 9.0.7 usunelem ten srednik i nic :/nawet formata zrobilem
  3. Prosze zawartosc pliku EDIBAS ;============================================================================= ;EDIABAS 6.4.3 Configuration [Configuration] ;============================================================================= ;----------------------------------------------------------------------------- ; EcuPath ; Description : ECU file path ; Default = . EcuPath = C:\EDIABAS\ECU ;----------------------------------------------------------------------------- ; SimulationPath ; Description : Simulation file path ; Default = . SimulationPath = C:\EDIABAS\SIM ;----------------------------------------------------------------------------- ; TracePath ; Description : Trace file path ; Default = . TracePath = C:\EDIABAS\TRACE ;----------------------------------------------------------------------------- ; CodeMapping ; Description : Character mapping file path ; Default = . ;CodeMapping = C:\EDIABAS\BIN\ansi2oem.tab ;----------------------------------------------------------------------------- ; TraceSize ; Description : Maximum size of each trace file [KB] ; Value : 0..32767 ; Default = 1024 ;TraceSize = 1024 ;----------------------------------------------------------------------------- ; ApiTrace ; Description : Enable/Disable API/User trace ; Value : 0 = Trace disabled ; 1 = User trace ; 2 = User trace + time stamp ; 3 = User trace + time stamp + process id (Win32) ; 4 = Function trace ; 5 = Function trace + time stamp ; 6 = Function trace + time stamp + timing ; 7 = Function trace + time stamp + timing + process id (Win32) ; Default = 0 ApiTrace = 0 ;----------------------------------------------------------------------------- ; IfhTrace ; Description : Enable/Disable IFH trace ; Value : 0 = Trace disabled ; 1 = Trace enabled ; 2 = Trace enabled ; 3 = Trace enabled ; Default = 0 IfhTrace = 0 ;----------------------------------------------------------------------------- ; SystemTraceSys ; Description : Enable/Disable system trace (runtime system) ; Value : 0 = Trace disabled ; Trace levels 1..7 ; Default = 0 SystemTraceSys = 0 ;----------------------------------------------------------------------------- ; SystemTraceBip ; Description : Enable/Disable BIP trace (runtime system) ; Value : 0 = Trace disabled ; Trace levels 1..7 ; Default = 0 SystemTraceBip = 0 ;----------------------------------------------------------------------------- ; SystemTraceIfh ; Description : Enable/Disable IFH system trace ; Value : 0 = Trace disabled ; Trace levels 1..7 ; Default = 0 SystemTraceIfh = 0 ;----------------------------------------------------------------------------- ; SystemTraceNet ; Description : Enable/Disable network trace ; Value : 0 = Trace disabled ; Trace levels 1..7 ; Default = 0 SystemTraceNet = 0 ;----------------------------------------------------------------------------- ; BipDebugLevel ; Description : BIP debug level of ECU files ; Value : 0..32767 ; Default = 0 BipDebugLevel = 0 ;----------------------------------------------------------------------------- ; UbattHandling ; Description : Ubatt ON/OFF handling ; Value : 0 = Ubatt ON/OFF: No EDIABAS error ; 1 = Ubatt ON/OFF: EDIABAS error ; Default = 1 UbattHandling = 1 ;----------------------------------------------------------------------------- ; IgnitionHandling ; Description : Ignition ON/OFF handling ; Value : 0 = Ignition ON/OFF: No EDIABAS error ; 1 = Ignition ON/OFF: EDIABAS error ; Default = 1 IgnitionHandling = 1 ;----------------------------------------------------------------------------- ; TaskPriority ; Description : EDIABAS process/thread priority (only Win32/16) ; Value : 0 = Optimal EDIABAS performance = 8 ; 1 = Minimal EDIABAS performance ; .. ; 10 = Maximal EDIABAS performance ; Default = 0 TaskPriority = 0 ;----------------------------------------------------------------------------- ; LoadWin32 ; Description : Map EDIABAS Win16 calls to EDIABAS Win32 ; Value : 0 = Win16/32 Mapping disabled (Win16-->Win16) ; 1 = Win16/32 Mapping enabled (Win16-->Win32) ; Default = 0 for Windows 9x/Me ; Default = 1 for Windows NT4/2000/XP ;LoadWin32 = 1 ;----------------------------------------------------------------------------- ; SystemResults ; Description : Enable/Disable system results (ubatt/ignition/jobstatus) ; Value : 0 = Disable system results ; 1 = Enable system results ; Default = 1 SystemResults = 1 ;----------------------------------------------------------------------------- ; RetryComm ; Description : Repeat failed communication automatically (1x) ; Value : 0 = Retry disabled ; 1 = Retry enabled (1x) ; Default = 1 RetryComm = 1 ;----------------------------------------------------------------------------- ; Simulation ; Description : Enable/Disable ECU simulation ; Value : 0 = Simulation disabled ; 1 = Simulation enabled ; Default = 0 Simulation = 0 ;----------------------------------------------------------------------------- ; Interface ; Description : Connected diagnosis interface ; Default = EDIC Interface =STD:OBD ; Additional information (in German) : ; Bitte beachten: Der HW-Treiber fuer das Interface muss installiert sein! ; Interface = STD:OBD ; Beschreibung : Serieller Pegelwandler (Nachfolger von ADS / Anschluss an OBD-Dose) ; Installation : \EDIABAS\HARDWARE\OBD\ODBSETUP (nur noetig fuer WIN NT4, WIN 2000, WIN XP) ; INI-Datei : OBD.ini nur benutzt wenn im Windows-Verzeichnis ; Unterstuetzung : WIN3.xx : Nein ; WIN95,98 16-Bit : Ja ; WIN95,98 32-Bit : Ja ; WIN NT 4.0 : Ja ; WIN XP : Ja ; Interface = STD:FUNK ; Beschreibung : Funk-Diagnose Interface MDA von Fa. Siemens ; Installation : keine ; INI-Datei : FUNK.INI ; Unterstuetzung : WIN95,98 16-Bit : Ja ; WIN95,98 32-Bit : Ja ; WIN NT 4.0 : Ja ; WIN XP : Ja ; Interface = ADS ; Beschreibung : Serieller Pegelwandler (Anschluss an Diagnose-Dose) ; Installation : \EDIABAS\HARDWARE\ADS\ADS32\ADSSETUP (nur fuer WinNT4 noetig) ; INI-Datei : keine ; Unterstuetzung : WIN95,98 16-Bit : Ja ; WIN95,98 32-Bit : Nein ; WIN NT 4.0 : Ja ; WIN XP : Ja ; Interface = KBUS ; Beschreibung : Serieller Pegelwandler (Anschluss direkt an K-Bus oder I-Bus) ; Installation : \EDIABAS\HARDWARE\ADS\ADS32\ADSSETUP (nur fuer WinNT4 noetig) ; INI-Datei : keine ; Unterstuetzung : WIN95,98 16-Bit : Ja ; WIN95,98 32-Bit : Nein ; WIN NT 4.0 : Ja ; WIN XP : Ja ; Interface = EDIC ; Beschreibung : Serielles , PCMCIA , PC-Card Interface von Fa. Softing ; Installation : \EDIABAS\HARDWARE\EDIC\SETUP.EXE ; INI-Datei : EDICFW.INI, EDICHW.INI ; Unterstuetzung : WIN95,98 16-Bit : Ja ; WIN95,98 32-Bit : Ja ; WIN NT 4.0 : Ja ; WIN XP : Ja ; Interface = EDICC ; Beschreibung : EDIC-Card C oder EDIC-Card 2 CAN-Interface von Fa. Softing ; Installation : \EDIABAS\HARDWARE\EDIC\SETUP.EXE ; INI-Datei : XEDICC.INI ; Unterstuetzung : WIN95,98 16-Bit : Ja ; WIN95,98 32-Bit : Ja ; WIN NT 4.0 : Ja ; WIN XP : Ja ; Interface = STD:CAN ; Beschreibung : PCMCIA CAN-Interface CanCardX von Fa. Vector ; Installation : keine (ausser Installation der CAN-Karte) ; INI-Datei : CANRTTP.INI ; Unterstuetzung : WIN95,98 16-Bit : ? ; WIN95,98 32-Bit : ? ; WIN NT 4.0 : Ja ; WIN XP : ? ; Ansprechpartner: Hr. Jusko ; Telefon : +49-(0)89/382-35891 (Hotline) ; email : [email protected] (Hotline) ; Interface = STD:ADS4MOST ; Beschreibung : Most-Interfaces von Fa. Oasis ; Installation : keine (ausser Installation der Oasis-Karte) ; INI-Datei : ADS4MOST.INI ; Unterstuetzung : WIN95,98 16-Bit : ? ; WIN95,98 32-Bit : ? ; WIN NT 4.0 : Ja ; WIN XP : Ja ; Ansprechpart.: Hr. Rowedder ; Telefon : 089 / 382-29159 ; email : [email protected] ; Interface = REMOTE ; Beschreibung : Anbindung eines EDIABAS-Interfaces über TCP/IP ; Installation : Anpassung der Einträge in [TCP] auf beiden Seiten (ins.: RemoteHost, Port) ; INI-Datei : keine ; Unterstuetzung : WIN95,98 16-Bit : Nein ; WIN95,98 32-Bit : Ja ; WIN NT 4.0, XP : Ja ; WIN XP : Ja ; Sonderfall : Interface OPPS ; Ansprechpart.: Hr. Rowedder ; Telefon : 089 / 382-29159 ; email : [email protected] ; Interface = REMOTE:name ; Beschreibung : Anbindung eines EDIABAS-Interfaces über TCP/IP ; Installation : Anpassung der Einträge in [TCP] auf beiden Seiten (ins.: RemoteHost, Port) ; INI-Datei : REMOTE.INI (insbesondere für Parallelbetrieb notwendig) ; In REMOTE.INI stehen unter [name] spezif. Einstellungen(z.B.: RemoteHost, Port) ; Unterstuetzung : WIN95,98 16-Bit : Nein ; WIN95,98 32-Bit : Ja ; WIN NT 4.0, XP : Ja ; WIN XP : Ja ; Sonderfall : Interface OPPS ; Ansprechpart.: Hr. Rowedder ; Telefon : 089 / 382-29159 ; email : [email protected] ;----------------------------------------------------------------------------- ; NetworkProtocol ; Description : Network protocol ; Default = NetworkProtocol = TCP ;============================================================================= ;TCP/IP Configuration [TCP] ;============================================================================= ;----------------------------------------------------------------------------- ; RemoteHost ; Description : server address/name ; Default = RemoteHost = WMUC102911 ;----------------------------------------------------------------------------- ; Port ; Description : IP communication port ; Value : 1000 < port < 30000 ; Default = Port = 3000 ;----------------------------------------------------------------------------- ;TimeoutConnect ; Description : Timeout for establishing the connection ; Default = 5000 TimeoutConnect = 2000 ;----------------------------------------------------------------------------- ;TimeoutReceive ; Description : Timeout for receiving a message ; Default = 5000 TimeoutReceive = 2000 ;----------------------------------------------------------------------------- ;TimeoutFunction ; Description : Timeout for a long function ; Default = 59000 TimeoutFunction = 10000 ;----------------------------------------------------------------------------- ;DisconnectOnApiEnd ; Description : Enable/Disable Disconnection with function call ApiEnd ; Value : 0 = Disconnection disabled ; 1 = Disconnection enabled ; Default = 0 ;DisconnectOnApiEnd = 1 ;----------------------------------------------------------------------------- ;InitCmd<n> ; Description : Initialization command <n> (normally for OPPS) ; Default = ;InitCmd0 = FE,04,00,03,01 ;InitCmd1 = FD,05,00,03,01 ;============================================================================= ; End Of File EDIABAS.ini ;============================================================================= http://img24.imageshack.us/img24/4074/inpac.jpg Uploaded with ImageShack.us
  4. Witam zainstalowalem INPA i przy wlaczaniu mam taki komunikat "Error opening error log file---->abort" moze ktos wie o chodzi bo ja juz nie mam pomyslu
  5. Witam mam takie pytanko jestem posiadaczem bmw e39 525i gasnie mi przy ruszaniu i chce przez komputer wykasowac wszystkie adaptacje tzn vanos przeplywki przepustnicy itp zeby samochod sie uczyl na nowo dodam jeszcze ze samochod jest po swapie i nie wiem czy poprzedni wlasciciel robil cos takiego i tu moje pytanie po wykasowaniu wszystkich adaptacji czego mam sie spodziewac jak samochod bedzie chodzic? moze gasnac pyrchac itp? czy on sobie sam wszystko ustawi ze mozliwe ze bedzie poprawa Z gory dziekuje za odpowiedz :) Pozdrawiam
  6. dzieki wielkie
  7. Witam tak jak w temacie chce zakupić kabel do komputera w moim bmw e39 czy ten kabel będzie się do tego nadawać? http://allegro.pl/show_item.php?item=2988690985 będę mógł przez niego skasować adaptacje itp?
  8. scooby90 odpowiedział(a) na scooby90 temat w E39
    http://img580.imageshack.us/img580/4175/dsc0019jq.jpg Uploaded with ImageShack.us] wedlug tego to samochod posiada silnik 2.5 L jak mozna sprawdzic po silniku jaka ma pojemnosc?
  9. scooby90 odpowiedział(a) na scooby90 temat w E39
    no wlascie i tu mnie ciekawi czy ten byly wlasciciel zmienil ta mape w ogole czy tylko po przekladal po podlaczal i tyle u mnie byl silnik 2.5 wczesniej teraz niby jest 3.0 ale pewnosci to ja juz nie mam z tego co zauwazylem to przeplywomierz jest inny niz w silnikach 3.0 po podlaczeniu pod komputer bede widzial jaki jest silnik?
  10. scooby90 odpowiedział(a) na scooby90 temat w E39
    aa oki dzieki wielkie jutro tam zagladne i zobacze co wyjdzie ale adaptacje wszystkiego musze zrobic mimo wszystko?
  11. scooby90 odpowiedział(a) na scooby90 temat w E39
    Moze glupie pytanie ale gdzie sie znajduje ten sterownik ? i na nim bedzie ten numer vin i po vin bede mogl sprawdzic czy on jest od tego silnika? czy moze jakis numer seryjny bedzie zamiast vin?
  12. scooby90 odpowiedział(a) na scooby90 temat w E39
    a w jaki sposob moge uzyskac ten vin? wystarczy jak podepne sie pod komputer?
  13. scooby90 odpowiedział(a) na scooby90 temat w E39
    no tak u mnie silnik jest z anglika i tu pytanie czy licznik tez musi byc angielski czy moze byc europejski bo wolal bym europejski mowiac szczeze
  14. scooby90 odpowiedział(a) na scooby90 temat w E39
    no fakt jest ale od miesiaca nie moge znalesc licznika do niej :D
  15. scooby90 odpowiedział(a) na scooby90 temat w E39
    no oby tak bylo przeciez ludzie przekladaja silniki i jakos jezdza A mam jeszcze pytanko bo od jakiegos czasu szukam licznik z tym duzym wyswietlaczem do mojej buni ale nie moge znalesc i czasem sie zastanawiam czy w ogole byl e39 530i automat bo z tego co czytam na aukcjach to sa 2.8 3.5 4.0
  16. scooby90 odpowiedział(a) na scooby90 temat w E39
    czyli zawsze będą dwa? ale taka adaptacja wszystkiego na nowo pomoze?
  17. scooby90 odpowiedział(a) na scooby90 temat w E39
    no tylko nie wiadomo czy nie trzeba wszystkiego zgrac na nowo zeby byl jeden vin Jak by ktos kogos znal co zna sie na tym to prosze o info na priv
  18. scooby90 odpowiedział(a) na scooby90 temat w E39
    A możliwe jest ze przez to ze są dwa vin samochód Gorzej chodzi?
  19. scooby90 opublikował(a) temat w E39
    Witam (jak bym pisal w zlym dziale prosze o przeniesienie) moze ktos zna jakas firme albo osobe co zajmuje sie swapem do bmw jestem wlascicielem bmw e39 530i od wlasciciela ktorego kupilem ten samochod robil swap wczesniej byl tam silnik 2.5 teraz jest 3.0 i chcial bym zeby osoba ktora na tym sie zna zaglodnela do tego bo mam wrazenie ze swap zostal wykonany zle nawet bardzo zle jak sprawdzalismy z szymonem samochod wydaje sie jak by byly dwa viny i parametry na biegu jalowym jak stwierdzil szymon sa o ok 80% wieksze niz powinny i teraz sie boje nim jezdzic zeby nie uszkodzic silnika prosze o info jesli znacie kogos dobrego w swapach bmw :) Ja jestem z Żar kolo Zielonej Góry Pozdrawiam
  20. scooby90 odpowiedział(a) na scooby90 temat w E39
    silnik chodzi rowno wlasnie choc mam wrazenie ze jak by troszke za wolno na gaz ragowal ale ciezko mi to stwierdzic bo mam samochod od niedawna
  21. scooby90 opublikował(a) temat w E39
    Witam jestem posiadaczem bmw E39 530i automat od niedawna i mam taki problem ze czasem przy ruszaniu jak samochód już się powoli toczy i wcisnę delikatnie gaz to gaśnie może ktoś miał podobny problem i wie dlaczego tak jest?
  22. Napisałem do wlasciciela i czekam na odpowiedz
  23. tez to zauwazylem wlasciciel mowi ze wrzucil tak z rozpedu niby w sobote sie okaze co to za auto
  24. znasz ten samochód ze tak go komentujesz?
  25. posiadam zdjecia i w dzien napisalem do niego o VIN wiec czekam na info wnetrze nie jest zbyt zadbane listwy sa w zlym stanie prawe nadkole wgniecione i do poprawek lakierniczych nie wiem co mial na mysli mowiac ze w 90% sprawne ale z tego co z nim rozmawialem to wychodzi na to ze gosc ma sporo kasy a chce sie pozbyc szybko samochodow :P
