E-46 320d błędy z INPA - prosze o pomoc
Witam wszystkich. Poniższe błędy wyrzuciło mi w sterowniku silnika (INPA). Proszę o pomoc w interpretacji. Po skasowaniu błędy wyskakują ponownie.
E R R O R M E M O R Y
Date: 26.01.2010 19:31:21
ECU: D50M47A
JobStatus: OKAY
Variant: D50M47A
RESULT: 3 error in error memory !
4B10 4B10 (1278) rough controller
Error counter: 19
Logistic counter: 30
1. Umweltsatz
Mileage 122850 km
average engine rotational speed 827.47 rpm
coolant temperature 23.02 deg C
maximum common-rail-pressure of last 10ms 315.08 bar
injection volume setpoint without volume offset 13.00 mg/cyc
intaken air mass per cylinder 409.60 mg/Hub
charge pressure value 984.61 hPa
linearised APP1 0.00 %
Battery Voltage 13848.74 mV
Vehicle speed 0.00 km/h
idle running regulator torque 58.51 Nm
2. Umweltsatz
Mileage 131080 km
average engine rotational speed 799.89 rpm
coolant temperature 34.06 deg C
maximum common-rail-pressure of last 10ms 322.96 bar
injection volume setpoint without volume offset 15.36 mg/cyc
intaken air mass per cylinder 390.70 mg/Hub
idle running regulator torque 87.77 Nm
Signal or value above threshold
Test conditions fulfilled
Error not occurred yet
Error would not cause a warning lamp to light up
Fehler in Entprellphase
Error code: 4B 10 01 06 00 00 13 1E 2F FD 1E 49 28 21 41 64
00 55 00 57 33 34 1D 54 29 27 3E 64 00 55 00 58
4B11 4B11 (1279) rough controller
Error counter: 19
Mileage 655350 km
average engine rotational speed 0.00 rpm
coolant temperature -50.27 deg C
maximum common-rail-pressure of last 10ms 0.00 bar
injection volume setpoint without volume offset 0.00 mg/cyc
intaken air mass per cylinder 0.00 mg/Hub
charge pressure value 0.00 hPa
Battery Voltage 0.00 mV
idle running regulator torque -2486.83 Nm
Signal or value below threshold
Fehler in EntprellphaseError code: 4B 11 02 00 00 00 13 1E FF FF 00 00 00 00 00 00
00 00 00 00
4501 4501 (0401) control of exhaust re-circulation
Error counter: 7
Logistic counter: 18
1. Umweltsatz
Mileage 123230 km
average engine rotational speed 1572.20 rpm
coolant temperature 63.17 deg C
maximum common-rail-pressure of last 10ms 606.54 bar
intaken air mass per cylinder 567.14 mg/Hub
charge pressure value 1122.46 hPa
linearised APP1 21.26 %
Tastverhältnis zür Endstufenansteuerung 99.25 %
Tastverhältnis zür Endstufenansteuerung 68.53 %
Atmospheric-pressure 994.46 hPa
2. Umweltsatz
Mileage 130840 km
average engine rotational speed 2096.26 rpm
coolant temperature 68.19 deg C
maximum common-rail-pressure of last 10ms 708.94 bar
injection volume setpoint without volume offset 21.66 mg/cyc
intaken air mass per cylinder 730.98 mg/Hub
charge pressure value 1358.76 hPa
linearised APP1 31.50 %
Tastverhältnis zür Endstufenansteuerung 45.69 %
Atmospheric-pressure 974.76 hPa
Error would cause a warning lamp to light up
Error code: 45 01 82 06 00 00 07 12 30 23 39 71 4D 27 5A 72
1B 7E 57 65 33 1C 4C 76 5A 37 74 8A
pierwszy to błąd o którym już była mowa na forum 4B10 4B10 (1278) rough controller, 4B11 4B11 (1279) rough controller mówi przekroczeniu wartości korekcyjnych potrzebnych do utrzymania gładkiej pracy silnika
4B10 Smooth run regulation : correction quantity to high
4B11 Smooth run regulation : correction quantity to low
tu kolega
atebe
profesjonalnie opisał co i jak pozwolę sobie zacytować
po raz pierwszy biorę udział w dyskusji na forum i chętnie przyłaczę się do tematu korekty wtrysków ...
systemy Coman Rail wymagają tzw. przedwtrysku zapłonowego a następnie dawki paliwa która nadaje właściwą moc zapłonu , korekta która pojawia się na poszczególnych wtryskiwaczach uzależniona jest od czynników
1 stan kompresji na danym cylindrze
2 stanu wtryskiwacza
jeżeli ciśnienie na cylindrze jest niższe od pozostałych , jednostka DDE wydłuża czas wtrysku co objawia się na przykład wartością +2 , a ponieważ silniki są 4 i 6 cylindrowe , pozostałe cylindry i kolejność zapłonu ma tu olbrzymi wpływ na pracę silnika na "wolnych obrotach" , jedynym sposobem na uniknięcie falowania jest "sparowanie wtryskiwaczy z słabszymi cylindrami , przy czy należy sprawdzić czy dany wtryskiwacz nie "leje " tzn, jaka jest dawka w 1 cm3 na 1 min przenoszona do przelewów dla poszczególnych zadanych ciśnień roboczych , z całym szacunkiem zawór ciśnieniowy na magaistrali kumulacyjnej ma całkowicie inne zadanie
Trudno jest to ustawić bez stołu pomiarowego i pomiaru ciśnienia sprężania
drugim błędem jest 4501 4501 (0401) control of exhaust re-circulation chodzi tu o egr i sterownie nim (elektrozawór,filterek, zacinanie samego egr)
wszystkie te błędy są sporadyczne (zerknij min na przebieg przy jakim występowały i ilość pojawienia się)
jak też błąd nr 2 może wpływać na błąd nr 1 i na odwrót
tu kilka przyczyn kiedy błędy mogą występować:
Recyrkulacji spalin zostanie wyłączona gdy:
Temperatura płynu chłodzącego ≤ 15 ° C lub ≥ 105 ° C
Prędkość obrotowa 750 obr. / min i ≤ ≥ 2800 obr / min
Objętość wstrzyknięcia zbyt wysoka (w zależności od prędkości obrotowej silnika)
Ciśnienie atmosferyczne ≤ 880 mbar
Napięcie na baterii ≤ 9 V
Temperatura powietrza wlotowego-≤ -25 ° C lub ≥ 105 ° C
Podczas uruchamiania silnika
podczas pracy na biegu jałowym silnika zbyt długo
i jeśli występują następujące błędy:
Kody błędów 4500, 4506: układu recyrkulacji gazów spalinowych, odchylenie kontroli
Kody błędów 41B0, 41D0, 41E0: Układ recyrkulacji spalin
Kody błędów 3FB0, 3FC0, 3FD0: Air-mass flow sensor
Kod błędu 4060: czujnik ciśnienia atmosferycznego
Kody błędów 4180, 4190, 41A0: regulator ciśnienia turbosprężarki
Kod błędu 4680: Napięcie zasilania 2
Kod błędu 4140: Air-mass flow sensor
Kod błędu 3F00: czujnik ciśnienia Turbo
Kody błędów 4520, 4530: kontrola ciśnienia, odchylenie kontroli
  • 7 miesięcy temu...
Jak rozwiązałeś powyższy problem? Ja właśnie jestem po czyszczeniu kolektora w e45 330xd M57N i wywala mi taki błąd... EGR podłączony jak trzeba, do tej cienkiej rurki wsikałem trochę wd40. Czy to może być przyczyna? Po skasowaniu błędu w INPIe wyskakuje na nowo...
Hej,
to nie mój samochód, a kolegi i szczerze on po prostu jeździ dalej i chyba nic nie robił. Ja nie do końca znam się na dieslach :(
