Instalacja DIS na Vmware
;EDIABAS 6.4.7 Configuration
[Configuration]
; EcuPath
;       Description :   ECU file path
;       Default     =   .
EcuPath          =C:\EDIABAS\ECU
; SimulationPath
;       Description :   Simulation file path
;       Default     =   .
SimulationPath   =C:\EDIABAS\SIMULATION
; TracePath
;       Description :   Trace file path
;       Default     =   .
TracePath        =C:\EDIABAS\TRACE
; CodeMapping
;       Description :   Character mapping file path
;       Default     =   .
;CodeMapping      = C:\EDIABAS\BIN\ansi2oem.tab
; TraceSize
;       Description :   Maximum size of each trace file [KB]
;       Value       :   0..32767
;       Default     =   1024
TraceSize        = 32767
; ApiTrace
;       Description :   Enable/Disable API/User trace
;       Value       :   0  = Trace disabled
;                       1  = User trace
;                       2  = User trace + time stamp
;                       3  = User trace + time stamp + process id (Win32)
;                       4  = Function trace
;                       5  = Function trace + time stamp
;                       6  = Function trace + time stamp + timing
;                       7  = Function trace + time stamp + timing + process id (Win32)
;       Default     =   0
ApiTrace         =0
; IfhTrace
;       Description :   Enable/Disable IFH trace
;                       1  = User trace
;                       2  = User trace + interface
;                       3  = User trace + interface + time stamp
;       Default     =   0
IfhTrace         =0
; IfhnTrace
;       Description :   Enable/Disable IFH network trace (with XREMOTE)
;                       1  = User trace
;       Default     =   0
;IfhnTrace        = 0
; SystemTraceSys
;       Description :   Enable/Disable system trace (runtime system)
;                       Trace levels 1..7
;       Default     =   0
SystemTraceSys   = 0
; SystemTraceBip
;       Description :   Enable/Disable BIP trace (runtime system)
;                       Trace levels 1..7
;       Default     =   0
SystemTraceBip   = 0
; SystemTraceIfh
;       Description :   Enable/Disable IFH system trace
;                       Trace levels 1..7
;       Default     =   0
SystemTraceIfh   = 0
; SystemTraceNet
;       Description :   Enable/Disable network trace
;                       Trace levels 1..7
;       Default     =   0
SystemTraceNet   = 0
; BipDebugLevel
;       Description :   BIP debug level of ECU files
;       Value       :   0..32767
;       Default     =   0
BipDebugLevel    = 0
; UbattHandling
;       Description :   Ubatt ON/OFF handling
;       Value       :   0  = Ubatt ON/OFF: No EDIABAS error
;                       1  = Ubatt ON/OFF: EDIABAS error
;       Default     =   1
UbattHandling    = 0
; IgnitionHandling
;       Description :   Ignition ON/OFF handling
;       Value       :   0  = Ignition ON/OFF: No EDIABAS error
;                       1  = Ignition ON/OFF: EDIABAS error
;       Default     =   1
IgnitionHandling = 0
; ClampHandling
;       Description :   automatic check of clamps for Ubatt and Ignition
;       Value       :   0  = no automatic clamp check with send_and_receive
;                       1  = automatic clamp check with send_and_receive
;       Default     =   1
;ClampHandling    = 1
; TaskPriority
;       Description :   EDIABAS process/thread priority (only Win32/16)
;       Value       :   0  = Optimal EDIABAS performance = 8
;                       1  = Minimal EDIABAS performance
;                       10 = Maximal EDIABAS performance
;       Default     =   0
TaskPriority     = 0
; LoadWin32
;       Description :   Map EDIABAS Win16 calls to EDIABAS Win32
;       Value       :   0  = Win16/32 Mapping disabled (Win16-->Win16)
;                       1  = Win16/32 Mapping enabled (Win16-->Win32)
;       Default     =   0 for Windows 9x/Me
;       Default     =   1 for Windows NT4/2000/XP
;LoadWin32        = 0
; SystemResults
;       Description :   Enable/Disable system results (ubatt/ignition/jobstatus)
;       Value       :   0  = Disable system results
;                       1  = Enable system results
;       Default     =   1
SystemResults    = 1
; RetryComm
;       Description :   Repeat failed communication automatically (1x)
;       Value       :   0  = Retry disabled
;                       1  = Retry enabled (1x)
;       Default     =   1
RetryComm        = 1
; Simulation
;       Description :   Enable/Disable ECU simulation
;       Value       :   0  = Simulation disabled
;                       1  = Simulation enabled
;       Default     =   0
Simulation       = 0
; Interface
;       Description :   Connected diagnosis interface
;       Default     =   STD:OBD
Interface        =ADS
; Additional information (in German) :
; Bitte beachten: Der HW-Treiber fuer das Interface muss installiert sein!
; Interface      = STD:OBD
; Beschreibung   : Serieller Pegelwandler (Nachfolger von ADS / Anschluss an OBD-Dose)
; Installation   : \EDIABAS\HARDWARE\OBD\ODBSETUP (nur noetig fuer WIN NT4, WIN 2000, WIN XP)
; INI-Datei      : Suchreihenfolge analog zu EDIABAS.ini
; Unterstuetzung : WIN3.xx          : Nein
;                  WIN95,98  16-Bit : Ja
;                  WIN95,98  32-Bit : Ja
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Interface      = STD:FUNK
; Beschreibung   : Funk-Diagnose Interface MDA von Fa. Siemens
; Installation   : keine
; INI-Datei      : FUNK.INI
; Unterstuetzung : WIN95,98  16-Bit : Ja
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Interface      = ADS
; Beschreibung   : Serieller Pegelwandler (Anschluss an Diagnose-Dose)
; Installation   : \EDIABAS\HARDWARE\ADS\ADS32\ADSSETUP (nur fuer WinNT4 noetig)
; INI-Datei      : keine
;                  WIN95,98  32-Bit : Nein
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Interface      = KBUS
; Beschreibung   : Serieller Pegelwandler (Anschluss direkt an K-Bus oder I-Bus)
; INI-Datei      : keine
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Interface      = EDIC
; Beschreibung   : Serielles , PCMCIA , PC-Card Interface von Fa. Softing
; Installation   : \EDIABAS\HARDWARE\EDIC\SETUP.EXE
; INI-Datei      : EDICFW.INI, EDICHW.INI
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Interface      = EDICC
; Beschreibung   : EDIC-Card C oder EDIC-Card 2 CAN-Interface von Fa. Softing
; INI-Datei      : XEDICC.INI
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Interface      = STD:CAN
; Beschreibung   : PCMCIA CAN-Interface CanCardX/XL von Fa. Vector
; Installation   : keine (ausser Installation der CAN-Karte)
; INI-Datei      : CAN32.INI
; Unterstuetzung : WIN95,98  16-Bit : Nein
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Ansprechpartner: Hr. Jusko
;   Telefon      : +49-(0)89/382-35891  (Hotline)
;   email        : [email protected] (Hotline)
; Interface      = STD:ADS4MOST
; Beschreibung   : Most-Interfaces von Fa. Oasis
; Installation   : keine (ausser Installation der Oasis-Karte)
; INI-Datei      : ADS4MOST.INI
; Unterstuetzung : WIN95,98  16-Bit : ?
;                  WIN95,98  32-Bit : ?
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
;   Ansprechpart.: Hr. Rowedder
;   Telefon      : 089 / 382-29159
; Interface      = REMOTE
; Beschreibung   : Anbindung eines EDIABAS-Interfaces über TCP/IP
; Installation   : Anpassung der Einträge in [TCP] auf beiden Seiten (ins.: RemoteHost, Port)
; INI-Datei      : keine
;                  WIN NT 4.0, XP   : Ja
;                  WIN XP           : Ja
; Sonderfall     : Interface OPPS
; Interface      = REMOTE:name
; INI-Datei      : REMOTE.INI (insbesondere für Parallelbetrieb notwendig)
;                  In REMOTE.INI stehen unter [name] spezif. Einstellungen(z.B.: RemoteHost, Port)
;                  WIN XP           : Ja
; NetworkProtocol
;       Description :   Network protocol
;       Default     =
NetworkProtocol  = TCP
;TCP/IP Configuration
[TCP]
; RemoteHost
;       Description :   server address/name
;       Default     =
RemoteHost           = 192.168.68.1
; Port
;       Description :   IP communication port
;       Value       :   1000 < port < 30000
;       Default     =
Port                 = 6801
;TimeoutConnect
;       Description :   Timeout for establishing the connection
;       Default     =   5000
TimeoutConnect       = 2000
;TimeoutReceive
;       Description :   Timeout for receiving a message
;       Default     =   5000
TimeoutReceive       = 2000
;TimeoutFunction
;       Description :   Timeout for a long function
;       Default     =   59000
TimeoutFunction      = 10000
;DisconnectOnApiEnd
;       Description :   Enable/Disable Disconnection with function call ApiEnd
;       Value       :   0  = Disconnection disabled
;                       1  = Disconnection enabled
;       Default     =   0
;DisconnectOnApiEnd   = 1
;InitCmd<n>
;       Description :   Initialization command <n> (normally for OPPS)
;       Default     =
;InitCmd0             = FE,04,00,03,01
;InitCmd1             = FD,05,00,03,01
; End Of File EDIABAS.ini
Zaznaczę że w Disie nie widzi modułu silnika resztę widzi.W Carsofcie 6.1.4 nic nie widzi.Na drugim kompie to samo
  • Odpowiedzi 1 tys.
  • Wyświetleń 327,8 tys.
zmień LoadWin32 = 0 na =1 i tylko tyle.
Raczej nic nie wydłubiesz więcej z autem na tym co masz.
W jaki sposób zmienic długość nazwy komputera wyświetlanej w DIS? Moja jest dłuższa niz 8 znaków i chyba dlatego mam problem z disem. Nie przechodze takze api testu.
Api test przeprowadza sie przy podłączym aucie czy mozna sprawdzic "na sucho"?
Inpa i ncs działają wyśmienicie.
DIS wykrywa głowice, na pierwszy rzut oka wszystko jest dobrze ale po wielu probach nie połączylem sie z autem i wyskakuje błąd 200.159 albo 200.166.
Klikasz prawym na ikonie mój komputer, wybierasz właściwości. Zakładka nazwa komputera, klawisz zmień.
Api test idzie na sucho, musisz mieć ifhserv32 odpalony jedynie.
Nic nie pomogło.Dziwi mnie fakt że z innymi modułami mnie łączy.
Pomoże ktoś bo walczę już drugi dzień i nie mogę pojąć, :mad2: może sprawdzić mój EDIABAS.ini, bo wydaje się, że jest wszystko ok, ale nie mogę się połączyć z DISem v44. Inpa i ecs działa w prawdzie nie wszystkie funkcje ale się łączy. Kabel mam OBD-usb od nerwuasa, ustawienia zgodnie z filmikami. BMW jak w podpisie. Jak wchodzę w kodowanie najpierw komunikat "Connect diagnosis connector to vehicle! Switch on ignition! Start automatic vehicle identification!" później "Error in program run! Communication between DISplus/GT1 and diagnostic head is disturbed." i "Fault nr 200.166". Cały czas świecą się 2paski od połączenia na zielono, ale w conections na liście polewej nie widzi mojego laptopa i jest nie aktywny przycisk connect po środku. Przed chwilą pojawił się wpis żeby zmienić w Winload32 0 na 1 już myślałem, że sukces bo dolny pasek zielony drugi nie świeci, wchodzę w połączenia jest na liście nazwa mojego lapka i IP-> łącze... i jest połączył wszystko niby super zamykam okno wchodzę do programowania albo diagnostyki ... k*pa ten sam błąd, ale dwa paski na zielono, że niby połączenie jest. Z powrotem wchodz w Admi. Connection i niestety znowu nie widzi.
Emulacja głowicy chodzi. Ktoś pisał, żeby usunąć karty w DISie i z powrotem dodać, ale u mnie w SCOADMIN NETWORK mam dwie karty i boje się je usuwać bo w hardware -> add new adapter takich nie ma, a innej chyba nie można? czy jak usunę aktywne to pojawią się na liście?
http://img233.imageshack.us/img233/62/kartys.jpgwłaściwości sieci windows i virtual http://img510.imageshack.us/img510/4412/ustawieniasieci.jpg
ediabas
;EDIABAS 6.4.3 Configuration
[Configuration]
; EcuPath
;       Default     =   .
; SimulationPath
;       Default     =   .
; TracePath
;       Default     =   .
; CodeMapping
;       Default     =   .
; TraceSize
;       Value       :   0..32767
;       Default     =   1024
TraceSize        = 32767
; ApiTrace
;                       1  = User trace
;       Default     =   0
ApiTrace         =0
; IfhTrace
;                       1  = User trace
;       Default     =   0
IfhTrace         =0
; IfhnTrace
;                       1  = User trace
;       Default     =   0
;IfhnTrace        = 0
; SystemTraceSys
;                       Trace levels 1..7
;       Default     =   0
SystemTraceSys   = 0
; SystemTraceBip
;                       Trace levels 1..7
;       Default     =   0
SystemTraceBip   = 0
; SystemTraceIfh
;                       Trace levels 1..7
;       Default     =   0
SystemTraceIfh   = 0
; SystemTraceNet
;                       Trace levels 1..7
;       Default     =   0
SystemTraceNet   = 0
; BipDebugLevel
;       Value       :   0..32767
;       Default     =   0
BipDebugLevel    = 0
; UbattHandling
;       Default     =   1
UbattHandling    = 0
; IgnitionHandling
;       Default     =   1
; ClampHandling
;       Default     =   1
;ClampHandling    = 1
; TaskPriority
;       Default     =   0
TaskPriority     = 0
; LoadWin32
;LoadWin32        = 0
; SystemResults
;       Default     =   1
SystemResults    = 1
; RetryComm
;       Default     =   1
RetryComm        = 1
; Simulation
;       Default     =   0
Simulation       = 0
; Interface
;       Default     =   STD:OBD
Interface        = STD:OBD
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Interface      = ADS
; INI-Datei      : keine
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Interface      = KBUS
; INI-Datei      : keine
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Interface      = EDIC
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Interface      = EDICC
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; INI-Datei      : keine
;                  WIN XP           : Ja
;                  WIN XP           : Ja
; NetworkProtocol
;       Default     =
[TCP]
; RemoteHost
;       Default     =
; Port
;       Default     =
Port                 = 6801
;TimeoutConnect
;       Default     =   5000
;TimeoutReceive
;       Default     =   5000
;TimeoutFunction
;       Default     =   59000
;DisconnectOnApiEnd
;       Default     =   0
;InitCmd<n>
;       Default     =
Nie jestem pewien, bo prawie rok temu ostatnio bawiłem się DISem i chyba się łączył. A od tego czasu na kompie prawie nic się zmieniło praktycznie nie był używany.
Aha system to WIN XP
zmień RemoteHost = 192.168.68.1 na RemoteHost = 192.168.68.30
kart nie ruszaj to najszybszy sposób by "zatłuc" DIS'a.
Niestety to samo
http://img821.imageshack.us/img821/7268/polac.jpg
Panowie może ktoś ponownie wrzucić DIS v57 USA, bo linki wygasły.
Deusexe zrób sobie kopie tego dis-a co zainstalowałeś (skopiuj cały folder w inne miejsce).
Wczytaj tą kopie do vmware i na niej rób wszystkie modyfikacje (nawet jak uwalisz czymś dis-a to masz pierwotną wersje przed zmianami)
Przeczytaj sobie ten temat jest tu co nieco o 200.166
viewtopic.php?f=97&t=124062&hilit=200.166
Kopie folderu, tylko (domyślne nazwy) C:\GT1_vmware i C:\EDIABAS czy jeszcze któryś?
A co do tego tematu to on jest o wersji z Widowsem 7 ja mam XP
Kopie tego gdzie masz ścieżkę z vmware, zapewne c:\gt1_vmware
Przeczytaj temat mimo iż jest o win7 bo zawiera się tam też xp (zresztą czy xp czy win7 32bit to i tak ta sam instalacja )
poprawione
api test idzie?
api test idzie?
Nie wiem gdzie jak go uruchomić :oops:
Masz na filmikach instalacyjnych
api test idzie?
Na sucho wywala (bez podpiecia do auta) błąd:
http://img689.imageshack.us/img689/9297/apitest.jpg
Sprawdzę jeszcze jak podłącze się.
Poprawka ApiTest przeszedł zapomniałem wyłączyć zaporę ;)
http://img521.imageshack.us/img521/8388/apio.jpg
jak api test idzie to głowice tez musi znaleźć.
poprawione
Nadal nie działają.
Jakiś postęp jest, jak zrobiłem api test i wyłączyłem i włączyłem vm, nsw i dsm, ale nadal nie do końca, łączy niby z samochodem, laptopa widzi, ale wchodzę w kodowanie car memory, wywala:
http://img9.imageshack.us/img9/8580/postep.jpg
Diagnoza idzie? jaki masz protokol ustawiony i jak vm jest ?
Diagnoza też nie idzie. Protokół i vm nie wiem czy dobrze rozumiem protokół to ip w ediabas? to 192.168.68.30 a vm wersja VMware? 5.5.1 build - 19175 ten Twój i ustawienia kart zgodnie z filmami. Dodam jeszcze może to pomoże, że nie mogę zczytać niektórych modułów w NCSexpert (niektórych bo najważniejsze dla mnie GM5 i ALSZ bezbłędnie udało się) w prawdzie plik wynikowy pojawia się ale wyskakuje błąd (może tak ma być - nie wiem) w innym temacie o tym pisałem: http://www.bmw-klub.pl/forum/viewtopic.php?f=97&t=120966
Protokół masz w ostatnim filmiku od instalacji DIS.
Panowie, tez od pewnego czasu mam problem z disem którego nie mogę rozwiązać. Kiedyś działa poprawnie wiedz zrobiłem sobie kopie zapasowa c:\gt1_vmware, gdy lapek mi się wysypał to razem z disem. Teraz mam sytuacje taką że działa mi tylko przy pierwszym uruchomieniu (po skopiowaniu kopi zapasowej)działa wszystko połączenie z autem itp., a później już nie czy to po wyłączeniu przez , czy płazie jest brak wykrywania głowicy. czyżby było coś nie tak z win XP?
Aha, no to jest Fister i wszystko zrobiłem po kolei jak na filmiku.
Witam mam takie pytanie czy tym softem można usuwać błędy z licznika? Świeci mi sie abs/asc i ręczny instalnąłem dis'a robię diagnozę i mi mówi, że nie ma żadnych błędów w ASC, ale nie mam zielonego pojęcia gdzie wejść żeby usunąć ten błąd
