jak sie robi test licznika???????
mam bmw 320d touring mam pytanko jak sie robi test licznika :modlitwa:
bylo do e36 i do e34 wpisz "test zegarow " w szukaj
pozdrafiam
dodam: Zeby budzik zablysnal jak choinka musisz trzymac prawy przycisk i wlaczyc zaplon. Pozniej klikasz dwa razy az na wyswietlaczu pojawi sie numer 2. Czekasz chwilke az pojawi sie numer 2.0 i wciskasz jeszcze raz przycisk. Zegarki powinni poleciec do konca skali, a kontrolki zapalic. Pozdro
po1. CCCP- cep cepowi cupnął poduszkę :mrgreen:
po2. Respekt dla Swiezakow :twisted2:
i jeszcze cos
BMW E46 On-Board Computer (OBC) Hidden Codes
nr example description
1 Car Engine and cluster data
1.0 46nnn Chassis nr/VIN serial number (last 5 digits)
1.1 4nnn K-number
1.2 690236 Cluster Part #
1.3 045210 Coding (04)/diagnosis (52)/bus index (10)
1.4 1200 Week (12)/year of manufacture (2000)
1.5 09_160 Hardware (09) and software # (16.0) of cluster
1.6 Not used
1.7 04__44 CAN-version (04) KI-revision index (44)
2 (test) Cluster System Test - Activates the gauge drivers,
indicators and LEDs to confirm function
3 SI Data
3.0 1098 Used fuel in liters since last SI (Service Inspection)
3.1 0231 Periodic inspection days; elapsed days (since last SI)
4 Momentary Consumption
4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km
4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour
5 Distance Gone Consumption
5.0 082 Average mileage; 082=8.2 liters/100km
5.1 0536 Calc. km to refuel (momentary distance to go)
6 Fuel Level sensor inputs in liters
6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters
6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters
6.2 0442+ Indicated value (44.2) and tank phase
7 Temperature and Speed
7.0 021+ Coolant/Engine temperature (2.1C)
7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135
7.2 + Engine speed / Current RPMs 1/min
7.3 + Vehicle speed / Current Speed in km/hour
8 Input value in HEX form
8.0 1d0+ System voltage ADC-Value Hex code
8.1 26C33C+ ADC Values HG left/HG right
8.2 0000 ADC Value brake degradation sensor (000=o.k.)
8.3 18C ADC Value outside temperature
9 Battery
9.0 140 Battery Voltage - 140 = UB 14.0v
9.1 242013+?
9.2 074_78+?
9.3 0011+?
10 Not used
11 Not used
12 Not used
13 GonG Gong Test
14 Not used
15 Status cluster I/O-ports (bit codes) 0=low; 1=high
1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0
Status Digital Outputs (bits) 0=inactive, 1=active
1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot
16 Not used
17 Not used
18 Not used
19 Lock Status; unlocks functions in range 3-18
19.0 L-On/L-Off Unlock: press button when "L-Off"
20 Not used
21 Software Reset; reset OBC settings
00 End of test
:dance: :dance:
oki spoko ale dlaczego dochodzi do 1.7 i nie pokazuje faktyczny stan licznika :jawdrop: aha i dziala pod lewym przyciskiem od zerowania km a nie od zegarow czy mogl kto manipulowac w liczniku????
Edytowane przez lawer
tego nie wiem ja mam e36 :mrgreen:
Faktyczny przebieg.... czyta z modułu lamp jak ktoś dobrze skręcił to możesz sobie szukać. Jedynie VIN i serwis.
Krzysztof
Bo to jest WIELKA BZDURA :!:
W teście zegarów nie ma żadnego faktycznego stanu licznika :!:
Tak naprawdę to nawet w module świateł może być stan licznika cofnięty ;)
http://images.spritmonitor.de/575756.png
Wie ktos moze jak właczyc taka funkcje w E46 zeby cyfrowy wyswietlacz (chyba tam gdzie jest przebieg) pokazywał predkosc??
dj ...a czytałes lub robiłes kiedys testy???
masz w/w przez plalnete... test 7.3 pojawia się km/h a poprzedni masz obroty silnika...
Czytałes, robiołes.... tylko jak to właczyc
wiem ze 7.3 ale jakos nie moge tego właczyc :duh:
Gdy juz wyskoczy mi 7 to zaraz przełacza sie na stan licznika
1.1
1.2
1.3 itd normalnie sie włacza
2.0 robia sie testy...
1.1
1.2
Och |Cie kArol.. :evil:
nie masz właczonych ..wszystkie testy do 2.0 chodza...
trzeba wejsc w 19 ... tam włączyć...
i potem klikasz na tes 7 ... czekasz pojawia ci sie 7. 0
i przelaczsz dalej i masz 7.1
7.2
7.3
i tak kazdy...
jak przytryzmasz to wróci na 7
i lecisz do nastepnych testów...
Dzieki :cool2:
Tylko kicha że za kazdym razem trzeba właczac w 19 i dopiero wtedy powyzej 2 testy działaja
tak ale ja powtorze moj [roblem jak chce zrobic ten test to licznik staje na 1.7 i od nowa1.1 czemu nie chce nawet isc do 2 czy czegos nie mam wlaczonego ???????/
bo jestes w trybie 1.0 ...i bedziesz skakal po 1.0 musisz przytrzymac na długo lewy guzik aby przeszlo w 1 i potem wchodzisz w jakie chcesz.... np. 5 a gdy zaczekasz chwile samo przeskoczy w 5.0
