Panowie mam problem - jade w tym tygodniu do serwisu na przegląd gwarancyjny a mam pare zmian zakodowanych ( start&stop i inne duperele ) mam też oryginalne pliki CAFD zapisne a dysku.
Ale problem jest taki ze z rozpędu kliknałem w esys - CODE DEFAULT VALUES na module ACSM i wywaliło mi na desce komunikat awarii poduszek i pasów :/
Doradzcie jak to szybko ogarnąć :mad2: :|
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
Spróbuj tego.
znalazłem tez cos takiego :
1. Open E-Sys and connect to your car chassis
2. Under Comfort Mode -> TAL-Calculating
Vehicle Order
Read the VO and Save
- Right Click on the FA folder and select Activate FA
- Read the SVT Actual and Save
SVT Actual
Read the SVT and Save
Select Edit
- Under StandardSVT Version->"Your Module you want to modify (mine was CID)-> StandardSVK->
SWFL_######..., CAFD_... and BTLD_... - Change the following:
Subversion - to 000 <- these are zeros
Pathversion - to 000
Select the save icon on the top menu
3. Hit the back button
You will be asked to save the file and use it, Select YES.
4. Under KIS/SVT
Select Complete Flash under Calculating Strategy
Change the I-Step (Shipment to the version that is in the lower right corner of the E-Sys window (mine was f25_12-03-2012)
Leave the I-Step (Target as is.
5. Select Calculate and Save the file
6. Under TAL Select Calculate and Save the file.
7. Select Execute. This will take you to TAL-Processing
TAL-Processing
8. Under TAL -> Click on ... Select the TAL file you created
9. Under SVT -> Click on ... Select the SVT file that you calculated and Saved
10. Under FA-> Select Read SA
11. Under the ECU Tab in the bottom window, click on the ALL box to UNHIGHLIGHT all of the boxes
12. In the ALL column, select the box that corresponds to you Module (mine was CID). This will highlight all of the boxes in that row.
13 Select the START button.
Spróbuj tego.
Moge tym cos bardziej jeszcze spieprzyć ?
Kolega Gk tds dobrze ci napisał instrukcje
jeszcze sprawdź FA czy nie ma braków lub dodatków jakiś innch kodów FA
(najszybszy podgląd w INPA /TD-530) lub w esys
oczywiście Psdzdata czy nie jest za stara dla twojego poziomu integracji (nie produkcji auta)
korzystam z e-sys 3.27.1 ,, Psdzdata_v3.60_lite
po wcisnieciu detect ..... wyskakuje mi okienko "CAS auswahl " i lista a obk drugie z zielonym paskiem który leci aż do non stopu ...
Nie powinno tak długo szukać, masz jakiś brak w CAS
może dla ACSM jest wszystko ok z CAFD ja nie ufam psdzdata lite nie wiadomo co usunięte z psdzdaty
zrób prosto ,
odznacz ACSM > i kliknij CODE powinno przywrócić dane z FA
jak coś to szukaj innej psdzdaty
Modul ACSM posiada parę plików CAFD,nie jeden jak inne moduły.
Vehicle Order
SVT Actual
Select Edit
4. Under KIS/SVT
TAL-Processing
Jak nie nasz pełnej psdzdata to tego nie rób.To jest update softu w module,bo namieszasz sobie jeszcze bardziej.
Oficjalnie chcę podziękować koledze @temsky740 - wczoraj o północy na teamviewerze starał sie mi pomóc :cool2: - niestety był problem z komunikacją z ZGM ale rano połączenie odpaliło i przywróciłem wszystko ,natomiast błędy wywalało dalej. Zgodnie z sugestią (nie miałem zainstalowanej inpy ) obleciałem do kumpla wykasować błędy i jest ok - po wyczyszczeniu błędów nie wróciły.
Pewnie zapłon wyłączyło podczas kodowania,
ciekawi mnie w takim przypadku (nie jest to pojedynczy już przypadek) czy jest komunikacja przez DCAN w przypadku odcięcia portu ethernet,
kodowaliście cały samochód czy tylko sam moduł ACSM,
On zakodowal tylko ACSM 1-j CAFD i ruszylo.
Można było jeszcze zrobić wczoraj wieczorem, on po prostu nie chciał zrzucić zacisk "-" z akumulatora . No i JAVA z ESYS instalowali ponownie dla profilaktyky )))
Rano przekodowałem jeszcze KOMBI, FEM i chyba jeszcze 2 moduły w których coś zmieniałem -jutro serwis to chciałem doprowadzić do stanu fabrycznego żeby sie nie przypieprzyli ;)
FRM. FEM w innych modeljach
Nie ma co się bać moduły tak nie padają , to osprzęt który obsługują ulega awarii nie sam moduł ,
a dodatkowo prawie każdy dopiszesz używany, rynek wtórny w BMW jest duży wiec prawie wszystko dostaniesz :D
tylko CAS , DDE/DME i najgorszy moduł to skrzyni automatycznej zintegrowany z mechatroniką , tego można się obawiać
CAS dużo nie kosztuje nowy , pozostaje DDE/DME i sterownik skrzyni to trochę kosztuje , :cry:
i może NBT ale to naprawiają (dorzucę jeszcze EPS) :mrgreen:
Nie pamiętam jak w F10 ale od 2014 roku modele z serii F020 z FEM są już pozbawione CAS
zintegrowane są trzy sterowniki MES(ZGM) , FRM, CAS, co będzie w przyszłości bardzo utrudniać modyfikacje i zastępowanie używką .
