Moduł Airbag (MRS4) E83 2.0d 2005
Czy ktoś się orientuje gdzie znajduje się moduł (ECU) i sensory poduszek? Czy jeśli mam takie błędy:
S 0017 - No communication possible with: Multifunctional steering wheel
000001 - MRS: Airbag, driver stage 1
000006 - MRS: Side Airbag front right
00000D - MRS: Airbag, driver stage 2
Mogę założyć, że sensory są ok?
Pełna lista błędów modułu MRS4:
1 Airbag driver stage 1
2 Belt tensioner driver
3 Belt tensioner front passenger
4 Airbag passenger stage 1
5 Side airbag front left
6 Side airbag front right
7 Side airbag rear left
8 Side airbag rear right
9 Head airbag (ITS) left
A Head airbag (ITS) right
B Battery positive terminal isolation 1
C Airbag front passenger stage 2
D Airbag driver stage 2
E Rear left head airbag
F Rear right head airbag
10 Safety battery terminal 2
11 Belt tensioner rear left
12 Belt tensioner rear right
13 Belt tensioner rear middle
14 Firing circuit ZK19
15 Airbag driver stage 2
16 Firing circuit ZK7
30 Coupling in firing circuit airbag driver stage 1
31 Coupling in firing circuit belt tensioner driver
32 Coupling in firing circuit belt tensioner passenger
33 Coupling in firing circuit airbag passenger stage 1
34 Coupling in firing circuit side airbag front left
35 Coupling in firing circuit side airbag front right
36 Side airbag rear left
37 Side airbag rear right
38 Coupling in firing circuit head airbag (ITS) left
39 Coupling in firing circuit head airbag (ITS) right
3A Coupling in firing circuit pos.-term. Disconnection 1
3B Coupling in firing circuit airbag passenger stage 2
3C Coupling in firing circuit airbag driver stage 2
3D Rear left head airbag
3E Rear right head airbag
3F Safety battery terminal 2
40 Coupling in firing circuit belt tensioner rear left
41 Coupling in firing circuit belt tensioner rear right
42 Coupling in firing circuit belt tensioner rear middle
43 Coupling in firing circuit ZK19
44 Coupling in firing circuit airbag driver stage 2
45 Coupling in firing circuit ZK7
40 Rear left seatbelt tensioner
50 Power supply
51 Fault lamp
52 Information lamp
60 Seat belt lock driver
61 Seat belt lock passenger
62 Seat belt lock rear left
63 Seat belt lock rear right
64 Seat belt lock rear middle
70 Seat occupancy recognition
71 Seat occupancy detector 2
72 Seat armrests locking without K-Bus
73 Driver seat module seat armrests locking
74 Passenger seat module seat armrests locking
75 External rollover sensor
80 Sensors for side airbag front
81 Sensor for side airbag left
82 Sensor for side airbag left
83 Sensor for side airbag left
84 Sensor for side airbag right
85 Sensor for side airbag right
86 Sensor for side airbag right
87 Coupling fault sensor side airbag left
88 Coupling fault sensor side airbag right
90 Coding incorrect
91 Crash-telegram memory
FO Internal Control Unit Fault
Po wymianie poduszek i programowaniu pamiętaj włączyć im licznik od nowa.
Moduł zazwyczaj jest gdzieś w podłokietniku.
Xdrive
Koder
Co masz na myśli mówiąc włączyć licznik od nowa? Chodzi o usunięcie crash data?
Nie wiem czy poduszki były wymieniane, wszystkie są.
Takie dane mam jeszcze z INPA:
- driver stage 1 - resistance too high
- driver stage 2 - resistance too high
- side front right - resistance too low (drzwi kierowcy - anglik)
Poza tym dis sugeruje diagnoze napinacza kierowcy, której nie może przeprowadzić.
http://s15.postimg.org/pzm1aa7sr/dis.jpg
Czy ktoś miał podobny problem? Albo może pomóc mi zdiagnozować?
Poduszki nie są zdolne do pracy, bez wykasowania im licznika - znajdziesz to w skrypcie do inpy.
Co do napinaczy, to może być to wynik złego kodowania
Xdrive
Koder
