Zafi
Zasłużeni forumowicze-
1 494 -
Wygrane w rankingu
2
Treść opublikowana przez Zafi
witam .... tak trzeba zaczac :D Production Date 2005-01-09 609 Navigation System Professional / Navigationssystem Professional 676 Hifi Loudspeaker System / Hifi Lautsprechersystem 672 Cd Changer Bmw For 6 Cds / Cd Wechsler 6-fach jak wyzej pisalem , BMW X3 E83 ma dwie wersje wzmacniacza ...... .... prawdopodobnie masz - HiFi wersje ( wersja Top HiFi z DSP odpada )
witam 2004 BMW X3 Car Audio Wiring Diagram Car Radio Battery Constant 12v+ Wire: Red/Green Car Radio Accessory Switched 12v+ Wire: Violet/White Car Radio Ground Wire: Brown Car Radio Illumination Wire: Gray/Red Car Stereo Dimmer Wire: White Car Stereo Antenna Trigger Wire: White Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Yellow/Red Left Front Speaker Negative Wire (-): Yellow/Brown Right Front Speaker Positive Wire (+): Blue/Red Right Front Speaker Negative Wire (-): Blue/Brown Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Yellow/Black Left Rear Speaker Negative Wire (-): Yellow/Brown Right Rear Speaker Positive Wire (+): Yellow/Violet Right Rear Speaker Negative Wire (-): Yellow/Gray 2005 BMW X3 Car Radio Wiring Diagram Car Radio Battery Constant 12v+ Wire: Red/Green Car Radio Accessory Switched 12v+ Wire: Violet/White Car Radio Ground Wire: Brown Car Radio Illumination Wire: Gray/Red Car Stereo Dimmer Wire: White Car Stereo Antenna Trigger Wire: White Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Yellow/Red Left Front Speaker Negative Wire (-): Yellow/Brown Right Front Speaker Positive Wire (+): Blue/Red Right Front Speaker Negative Wire (-): Blue/Brown Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Yellow/Black Left Rear Speaker Negative Wire (-): Yellow/Brown Right Rear Speaker Positive Wire (+): Yellow/Violet Right Rear Speaker Negative Wire (-): Yellow/Gray 2006 BMW X3 Car Stereo Wiring Diagram Car Radio Battery Constant 12v+ Wire: Red/Green Car Radio Accessory Switched 12v+ Wire: Violet/White Car Radio Ground Wire: Brown Car Radio Illumination Wire: Gray/Red Car Stereo Dimmer Wire: White Car Stereo Antenna Trigger Wire: White Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Yellow/Red Left Front Speaker Negative Wire (-): Yellow/Brown Right Front Speaker Positive Wire (+): Blue/Red Right Front Speaker Negative Wire (-): Blue/Brown Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Yellow/Black Left Rear Speaker Negative Wire (-): Yellow/Brown Right Rear Speaker Positive Wire (+): Yellow/Violet Right Rear Speaker Negative Wire (-): Yellow/Gray
witam tutaj masz filmik - to jest instukcja BMW - Pdf / 3D .... jak rozebrac dach panoramiczny - BMW E53 E61 E70 E83 E91 Panoramadach Mechanism Disassembly .... jak zlozyc dach panoramiczny - BMW E53 E61 E70 E83 E91 Panoramadach Mechanism Assembly .... czym smarowac elementy mechaniczne dachu - zalecenia BMW : Cassette Lubricant Würth Glide Grease Part No. 0893898 P.S. .... posiadam ta instrukcje BMW - ( Pdf-a ) - podaj adres internetowy na PW :D
witam .... albo dyferencjał : BMW X5 E70 4.8i rear differential in pieces after catastrophic failure X5 E70 Rear Differential Failure .... albo poloska tylna :cry2: , a jak sie zmienia tutaj : BMW CV Shaft X5 E70 Removal & Replacement How to DIY: BMTroubleU
witam ... gratuluje :cool2: .... a teraz polecam spokojnie ogladnoc jeszcze raz filmik :D Bmw water leak fix https://www.youtube.com/watch?v=7TS0oIfH8sc na zdjeciu ponizej 2:24 minuta : jest " tajemniczy " odplyw wody http://fs5.directupload.net/images/160315/7gnhrl3n.jpg
tutaj jest filmik jak to zrobic samemu : BMW X5 E70 Fix Water Inside Inner Tail light How to DIY: BMTtroubleU P.S. przepraszam ze w j.angielskim .... ale wszystko widac co i jak :cool2:
witam .... wiesz ja tez nie znam angielskiego .... ale jest w dzisiejszych czasach np. internet :D tutaj : "wklejasz" tekst i mozesz tlumaczyc np z j.angielskiego na j. polski => http://www.babelfish.de/ http://fs5.directupload.net/images/160312/dz4pjxe7.jpg gotowe ! :cool2:
witam to sa zalecenia BMW :D .... zalecenia producenta skrzyn to zupelnie inna bajka :cry2: http://fs5.directupload.net/images/160312/mn7uwusl.jpg => " Zaleznie od stylu jazdy Firma ZF zaleca wymiane oleju co 80.00 do 120.000 km lub najpozniej po uplywie 8 lat " https://www.google.de/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0ahUKEwij2PiUhLvLAhVM5xoKHYd8D-cQFggqMAI&url=https%3A%2F%2Fwww.bimmerfest.com%2Fforums%2Fattachment.php%3Fattachmentid%3D472571%26d%3D1414451942&usg=AFQjCNFzg_eHRTlV8piqKfL2Pq59yfb6ag
witam GA6HP19ZTU E70 3.0i from start production to present The transmission fluid has a Condition Based Service interval of approximately 100,000 miles; please refer to S.I. B00 07 02 for further information. Never mix any other oil with this transmission fluid when doing repairs or topping up. Shell M-1375.4, BMW Part No. 83 22 0 142 516. GA6HP26ZTU E70 X5 4.8i from start production to present The transmission fluid has a Condition Based Service interval of approximately 100,000 miles; please refer to S.I. Bulletin B 00 07 02 for further information. Never mix any other oil with this transmission fluid when doing repairs or topping up. Shell M-1375.4, BMW Part No. 83 22 0 142 516. 1.0 Transfer Case Operating Fluids Model: .. Fluid: .. BMW Part Number: E70 All models .. TF0870 .. 83 22 0 397 244 (1 Liter) Note: Before opening the container, shake the container to evenly mix the additives with the oil.
witam .... podaj linka :D
witam .... dlaczego piszesz "BODAJZE" ? :duh: - masz linka i pisze wyraznie co i jak ! Wymiana lampy , wymiana uszczelki itd np. Nr. 63217288973 - http://pl.bmwfans.info/parts-catalog/E70/Europe/X5_4.8i-N62N/L-A/browse/lighting/rear_light#7288973_--
witam ... tez moze byc winna , ale ja tutaj opisalem inny przypadek :D Przyczyn moze byc kilka np. zatkany odplyw kondensatora klimy , nieszczelne podszybie, nieszczelne drzwi, uszczelki szyb w drzwiach itd. Bmw 5 series water leak fix, water problem , bmw w https://www.youtube.com/watch?v=9SPvdqaQuU0 Bmw water leak fix https://www.youtube.com/watch?v=7TS0oIfH8sc
witam Audio Systems The various audio systems of the E83 are described in this technical documentation. Systemy audio Poszczególne systemy audio z E83 są opisane w niniejszej dokumentacji technicznej. The radio systems originate from the E85. Systemy radiowe pochodzą z E85. The loudspeaker systems are new developments and are adapted to the acoustic and technical dimension requirements of the E83. Systemy głośnikowe to nowe rozwiązania i są dostosowane do wymagań akustycznych i technicznych E83. The following audio systems are available for the E83: Z następującymi systemami audio są dostępne dla E83: • HiFi audio system (Standard) • System audio HiFi (Standard) System audio • Top HiFi audio system The BMW audio standards which have been applied since the E85 are also being applied to the E83. • Top HiFi Standardy audio BMW, które zostały zastosowane wE85 są również stosowane do E83. They apply to the HiFi and Top HiFi systems with regard to symmetry of the sound field, sound pressure and linearity of the frequency response. Mają one zastosowanie do systemów HiFi i Top HiFi w odniesieniu do symetrii Pole akustyczne, ciśnienia akustycznego i liniowość odpowiedzi częstotliwościowej. • HiFi audio system (Standard) http://fs5.directupload.net/images/160311/3t9e82ya.jpg http://fs5.directupload.net/images/160311/x8besdux.jpg http://fs5.directupload.net/images/160311/kn6bja98.jpg Wzmacniacz HiFi Wzmacniacz HiFi 6 kanałów komory bagażnika E83 to zmodyfikowana wersja 10 -cio kanałowego wzmacniacza HiFi od E85 / E46. Cztery kanały są dla głośników drzwiowych (Głośnik szerokopasmowy lub szerokopasmowego Głośnik z dodatkowym głośnikiem wysokotonowym) i 2 kanały są w centralnych głośników niskotonowych. Obudowa jest wykonana w taki sam sposób, jak wzmacniacz HiFi 10 kanałów w E85 / E46. Wzmacniacz HiFi posiada na wyjściu 4 x 25 watów dla średniej wielkości i dużych zakresów i 2 x 40 W dla niskich częstotliwości. • Top HiFi audio system http://fs5.directupload.net/images/160311/z79efzg3.jpg http://fs5.directupload.net/images/160311/4jc7qqoo.jpg http://fs5.directupload.net/images/160311/hqe9qzjk.jpg Top HiFi Wzmacniacz Bezpiecznik jest dodawany do znanego Carver Top HiFi Wzmacniacz z E85, ale jest inaczej zainstalowany w E83 bez dalszych modyfikacji. Jednak specjalne niskotonowe Carver ze zwiększoną wychylenia membrany są stosowane w E83, które są wykorzystywane w tym E85. Dostępna przestrzeń w E83 oraz wielkość rezonansu w parapet bocznej umożliwia korzystanie z centralnej zasadzie basowej. Centralne głośników w systemie dźwięku Top HiFi prosto dostosować do zwiększonego poziomu napięcia poziomów końcowych bas (8. impedancja). Wzmacniacz dostarcza 6 x 20 watów, 2 x 40 W i 2 x 100 watów.
witam ... dokladnie taki sam przypadek jak tutaj, znalazlem w forum zagranicznym : tutaj zdjecia : http://fs5.directupload.net/images/160311/6hfzgwxg.jpg http://fs5.directupload.net/images/160311/crin3dg4.jpg .... zatkany odplyw wody - skrzynka mikrofiltra ...... albo zle dokrecona pokrywa mikrofiltra - uszczelka pokrywy nie byla wystarczajaco docisnieta :mad2:
witam SI B63 11 10 SUBJECT Tailgate Lamp Leaking MODEL E70 (X5) produced from November 30, 2007 to March 21, 2010 04/2011 .... https://drive.google.com/file/d/0B1epIteFE7i-Z3hoZ2VoVVA3Q28/view?pref=2&pli=1
Brak regulacji kierownicy i pamięci ustawień foteli
Zafi odpowiedział(a) na kaczmarczyktomek1 temat w X5 (E53)
witam ... jezeli ktosz chce naprawiac to tutaj kilka informacji na temat - panel : http://fs5.directupload.net/images/160308/iqfkzoo7.jpg http://fs5.directupload.net/images/160308/ym73qegs.jpg http://fs5.directupload.net/images/160308/ixf8p8by.jpg PCB Relays Twin Relays / Double Mini Relay DMR http://www.aphelektra.com/photo/_pdf/ENG_DS_V23084X0000A001_C.pdf?sess_id=7fd0d38cd5cb48e3ef7e77900ccc5c6c .... a tutaj jak to dziala : https://www.bmwgm5.com/E53_MemorySeatModule.htm X1465 - 15 pin connector X1465 Function 1 Motor - Seat Inclination - Upward 2 Motor - Seat Inclination - Downward 3 Motor - Seat Slide - Back 4 Motor - Seat Slide - Forward 5 Motor - Seat Height - Raise 6 Ground 7 Motor - Seat Backrest - Forward 8 Power - Fuse 26 9 K-Bus 10 Motor - Seat Height - Lower 11 12 Motor - Seat Headrest - Raise 13 14 Motor - Seat Backrest - Back 15 Motor - Seat Headrest - Lower X650 - 12 pin Connector (black) X650 Function 1 Switch - Steering column 2 Motor - Seat Backrest Adjust 3 Motor - Seat Height Adjust 4 Motor+ Seat Cushion Tilt 5 Motor+Seat Movement 6 Motor+ Back-Rest Actuator 7 Switch - Steering column inclinaton motor 8 Motor- Seat Backrest Recliner 9 Motor- Seat Height adjust 10 Motor- Seat Cushion Tilt 11 Motor- Seat Movement 12 Motor- Seat Headrest X653 - 4-pin Connector (natural) X653 Function 1 Switch - Steering column longit. adj., backward 2 Switch - Steering column col. adj., forwards 3 Switch - Steering column inclination, higher 4 Switch - Steering column inclination, lower X18840 - 3-pin (black) X18840 Function 1 Ground 2 Not used 3 Power In -
hak holowniczy do f10 mpakiet i bezdotykowy bagażnik
Zafi odpowiedział(a) na michals600 temat w F10, F11
witam .... tu jest instrukcja : Firma AL-KO : http://kupplungs-profi.de/out/media/BMW_F10_F11_AHK__abnehmbar.pdf Firma JAEGER : http://www.atu.de/extern/files/artikel/ES0131_21020520_5erF10.pdf -
witam ponownie .... kolego , chyba zle mnie zrozumiales :nienie: jeszcze raz od poczatku .... potrzebujesz ponad 40 roznych czesci ! .... oczywiscie kupiles " dwa kanały powietrza na hamulce, lewy 51117896587 prawy 51117896588".... ale to jeszcze nie wszystko ! ! ! Potrzebne sa jeszcze np. "AV" i "AU" http://fs5.directupload.net/images/160305/jwzrmdq9.jpg Verkleidungen vorn unten durch Teile AU und AV ersetzen
witam .... czytales powyzej co napisalem ? w.g. instrukcji montazu potrzeba ponad 40 roznych czesci :duh:
witam cos znalazlem na ten temat .... Umbauanleitung CIC-NBT http://www.typo3-templates-kostenlos.de/Umbauanleitung-CIC-NBT.pdf P.S. ... jak trzeba to cos przetlumacze :D NBT Retrofit for BMW 5 series F10 https://www.youtube.com/watch?v=JnjSh8hkNks
witam ... mozesz dokladniej napisac ? Jakie objawy ? co jest nie tak ? np. przy otwieraniu zacina sie .... zostaje czesciowo otwarty .... nie domyka sie .... nie dziala funkcja uchylenia ... itp
witam http://fs5.directupload.net/images/160303/ej6kpwml.jpg BMW X5 [ E70 ] - silnik 3.0 Si - N52 ! ! - data produkcji 01.04.2009 :D :D
witam w BMW X5 E70 byly montowane silniki N52 => 11/2006 – 06/2010 https://de.wikipedia.org/wiki/BMW_E70 https://de.wikipedia.org/wiki/BMW_N52 Silnik N53 nie wystepuje w E70 . https://de.wikipedia.org/wiki/BMW_N53 ... prosze podaj 7-dem ostatnich liter/ cyfr VIN na PW - to sprawdze :D
witam .... masz moze dach panoramiczny ? Pierwszy problem to mechanizm dachu : - lubi sie zacinac , wylamuja sie male elementy przy prowadnicach , nie dziala mechanizm .... itd ( ale to inna bajka ) Drugi problem to uszczelki dachu : - jest glosno w samochodzie , nie zamyka sie jak trzeba .... , wibracje itp. Trzeci problem odplywy wody - rurki - przewody sa zapchane lub zabrudzone i woda dostaje sie do autka w rozne miejsca .... - ten problem wystepuje prawie we wszystkich modelach BMW np. BMW X3 E83 :2004-10 BMW X3 Sunroof Drain Location(E83) [/b] BMW X3 Still leaking water after last repair Water leak on BMW X3 Sunroof
witam tu masz instrukcje montazu BMW : USB Interface Retrofit for ACM These installation instructions only apply to cars with ACM. https://www.google.de/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwjknZK4lPHYAhXPLFAKHVmlDtIQFgg1MAE&url=http%3A%2F%2Fwww.m5board.com%2Fvbulletin%2Fattachments%2Fe60-m5-e61-m5-touring-discussion%2F80973d1239044627-got-my-acm-usb-interface-installed-acm_usb_install.pdf&usg=AOvVaw2mVzVzWijUzvcSQ_3SCGFH
