Stivo92
Treść opublikowana przez Stivo92
  1. Stivo92
    INPA Bledy prosze o pomoc
    Takie wyświetlono błędy E R R O R M E M O R Y --------------------------------------- Date: 14.12.2013 15:24:45 ECU: D50M47B1 JobStatus: OKAY Variant: D50M47B1 ------------------------------------------------------------- RESULT: 9 error in error memory ! ------------------------------------------------------------- 4212 4212 Glow plug zylinder 1, Ansteuerung Error counter: 94 Logistic counter: 40 1. Umweltsatz Mileage 218750 km average engine rotational speed 827.47 rpm coolant temperature 51.13 deg C maximum common-rail-pressure of last 10ms 385.98 bar injection mass index value without mass balance control 9.45 mg/cyc intaken air mass per cylinder 504.13 mg/Hub charge pressure value 984.61 hPa Linearised APP1 0.00 % Battery Voltage 11730.69 mV Vehicle speed 0.00 km/h status glow scale 0.00 - 2. Umweltsatz Mileage 219050 km average engine rotational speed 827.47 rpm coolant temperature 36.07 deg C maximum common-rail-pressure of last 10ms 401.73 bar injection mass index value without mass balance control 13.00 mg/cyc intaken air mass per cylinder 516.73 mg/Hub charge pressure value 1004.30 hPa Linearised APP1 0.00 % Battery Voltage 11893.62 mV Vehicle speed 0.00 km/h status glow scale 0.00 - Unterbrechung Test conditions fulfilled Error not present now, but already stored Error would not cause a warning lamp to light up Fehler in Entprellphase Fehler in Entprellphase Fehler in Entprellphase Error code: 42 12 24 06 00 00 5E 28 55 73 1E 65 31 18 50 64 00 48 00 00 55 91 1E 56 33 21 52 66 00 49 00 00 ------------------------------------------------------------- 4222 4222 Glow plug zylinder 2, Ansteuerung Error counter: 94 Logistic counter: 40 1. Umweltsatz Mileage 218750 km average engine rotational speed 827.47 rpm coolant temperature 51.13 deg C maximum common-rail-pressure of last 10ms 385.98 bar injection mass index value without mass balance control 9.45 mg/cyc intaken air mass per cylinder 504.13 mg/Hub charge pressure value 984.61 hPa Linearised APP1 0.00 % Battery Voltage 11730.69 mV Vehicle speed 0.00 km/h status glow scale 0.00 - 2. Umweltsatz Mileage 219050 km average engine rotational speed 827.47 rpm coolant temperature 36.07 deg C maximum common-rail-pressure of last 10ms 401.73 bar injection mass index value without mass balance control 13.00 mg/cyc intaken air mass per cylinder 516.73 mg/Hub charge pressure value 1004.30 hPa Linearised APP1 0.00 % Battery Voltage 11893.62 mV Vehicle speed 0.00 km/h status glow scale 0.00 - Unterbrechung Test conditions fulfilled Error not present now, but already stored Error would not cause a warning lamp to light up Fehler in Entprellphase Fehler in Entprellphase Fehler in Entprellphase Error code: 42 22 24 06 00 00 5E 28 55 73 1E 65 31 18 50 64 00 48 00 00 55 91 1E 56 33 21 52 66 00 49 00 00 ------------------------------------------------------------- 4232 4232 Glow plug zylinder 3, Ansteuerung Error counter: 94 Logistic counter: 40 1. Umweltsatz Mileage 218750 km average engine rotational speed 827.47 rpm coolant temperature 51.13 deg C maximum common-rail-pressure of last 10ms 385.98 bar injection mass index value without mass balance control 9.45 mg/cyc intaken air mass per cylinder 504.13 mg/Hub charge pressure value 984.61 hPa Linearised APP1 0.00 % Battery Voltage 11730.69 mV Vehicle speed 0.00 km/h status glow scale 0.00 - 2. Umweltsatz Mileage 219050 km average engine rotational speed 827.47 rpm coolant temperature 36.07 deg C maximum common-rail-pressure of last 10ms 401.73 bar injection mass index value without mass balance control 13.00 mg/cyc intaken air mass per cylinder 516.73 mg/Hub charge pressure value 1004.30 hPa Linearised APP1 0.00 % Battery Voltage 11893.62 mV Vehicle speed 0.00 km/h status glow scale 0.00 - Unterbrechung Test conditions fulfilled Error not present now, but already stored Error would not cause a warning lamp to light up Fehler in Entprellphase Fehler in Entprellphase Fehler in Entprellphase Error code: 42 32 24 06 00 00 5E 28 55 73 1E 65 31 18 50 64 00 48 00 00 55 91 1E 56 33 21 52 66 00 49 00 00 ------------------------------------------------------------- 4242 4242 Glow plug zylinder 4, Ansteuerung Error counter: 94 Logistic counter: 40 1. Umweltsatz Mileage 218750 km average engine rotational speed 827.47 rpm coolant temperature 51.13 deg C maximum common-rail-pressure of last 10ms 385.98 bar injection mass index value without mass balance control 9.45 mg/cyc intaken air mass per cylinder 504.13 mg/Hub charge pressure value 984.61 hPa Linearised APP1 0.00 % Battery Voltage 11730.69 mV Vehicle speed 0.00 km/h status glow scale 0.00 - 2. Umweltsatz Mileage 219050 km average engine rotational speed 827.47 rpm coolant temperature 36.07 deg C maximum common-rail-pressure of last 10ms 401.73 bar injection mass index value without mass balance control 13.00 mg/cyc intaken air mass per cylinder 516.73 mg/Hub charge pressure value 1004.30 hPa Linearised APP1 0.00 % Battery Voltage 11893.62 mV Vehicle speed 0.00 km/h status glow scale 0.00 - Unterbrechung Test conditions fulfilled Error not present now, but already stored Error would not cause a warning lamp to light up Fehler in Entprellphase Fehler in Entprellphase Fehler in Entprellphase Error code: 42 42 24 06 00 00 5E 28 55 73 1E 65 31 18 50 64 00 48 00 00 55 91 1E 56 33 21 52 66 00 49 00 00 ------------------------------------------------------------- 3F35 3F35 boost air hose monitoring im Leerlauf Error counter: 23 Logistic counter: 40 1. Umweltsatz Mileage 219000 km average engine rotational speed 1517.03 rpm coolant temperature 47.11 deg C maximum common-rail-pressure of last 10ms 512.01 bar injection mass index value without mass balance control 8.66 mg/cyc intaken air mass per cylinder 882.22 mg/Hub charge pressure value 994.46 hPa Linearised APP1 12.60 % duty cycle - exhaust refeeding actuator 0.00 % duty cycle - air charge pressure controller 85.07 % Atmospheric-pressure 984.61 hPa 2. Umweltsatz Mileage 219050 km average engine rotational speed 827.47 rpm coolant temperature 62.17 deg C maximum common-rail-pressure of last 10ms 385.98 bar injection mass index value without mass balance control 7.88 mg/cyc intaken air mass per cylinder 743.59 mg/Hub charge pressure value 1004.30 hPa Linearised APP1 0.00 % duty cycle - exhaust refeeding actuator 94.53 % duty cycle - air charge pressure controller 89.01 % Atmospheric-pressure 1004.30 hPa Ladeluftschlauch abgefallen Test conditions fulfilled Error not present now, but already stored Error would not cause a warning lamp to light up Fehler in Entprellphase Fehler in Entprellphase Fehler in Entprellphase Error code: 3F 35 21 06 00 00 17 28 55 8C 37 61 41 16 8C 65 10 00 6C 64 55 91 1E 70 31 14 76 66 00 78 71 66 ------------------------------------------------------------- 3FF1 3FF1 (3264) air flow meter P3264 Mass or Volume Air Flow Too Low due to Sensor Drift Error counter: 2 Logistic counter: 40 1. Umweltsatz Mileage 219010 km average engine rotational speed 827.47 rpm coolant temperature 78.23 deg C maximum common-rail-pressure of last 10ms 385.98 bar injection mass index value without mass balance control 6.30 mg/cyc intaken air mass per cylinder 472.62 mg/Hub charge pressure value 994.46 hPa Linearised APP1 0.00 % Battery Voltage 14174.59 mV Vehicle speed 0.00 km/h Atmospheric-pressure 984.61 hPa 2. Umweltsatz Mileage 219050 km average engine rotational speed 827.47 rpm coolant temperature 85.26 deg C maximum common-rail-pressure of last 10ms 378.10 bar injection mass index value without mass balance control 6.30 mg/cyc intaken air mass per cylinder 478.92 mg/Hub charge pressure value 1014.15 hPa Linearised APP1 0.00 % Battery Voltage 14174.59 mV Vehicle speed 0.00 km/h Atmospheric-pressure 1004.30 hPa Verhaeltnis berechnete zu gemessener Luftmasse zu klein Test conditions not yet fulfilled Error not present now, but already stored Error would cause a warning lamp to light up Fehler in Entprellphase Fehler in Entprellphase Fehler in Entprellphase Error code: 3F F1 B2 06 32 64 02 28 55 8D 1E 80 31 10 4B 65 00 57 00 64 55 91 1E 87 30 10 4C 67 00 57 00 66 ------------------------------------------------------------- 4501 4501 (0401) regulation of exhaust re-circulation, Regelabweichung P0401 Exhaust Gas Recirculation Flow Insufficient Detected Error counter: 9 Logistic counter: 40 1. Umweltsatz Mileage 219010 km average engine rotational speed 799.89 rpm coolant temperature 61.17 deg C maximum common-rail-pressure of last 10ms 385.98 bar injection mass index value without mass balance control 7.88 mg/cyc intaken air mass per cylinder 504.13 mg/Hub charge pressure value 1023.99 hPa Linearised APP1 0.00 % duty cycle - exhaust refeeding actuator 94.53 % duty cycle - air charge pressure controller 89.80 % Atmospheric-pressure 994.46 hPa 2. Umweltsatz Mileage 219050 km average engine rotational speed 827.47 rpm coolant temperature 24.02 deg C maximum common-rail-pressure of last 10ms 385.98 bar injection mass index value without mass balance control 11.42 mg/cyc intaken air mass per cylinder 529.33 mg/Hub charge pressure value 994.46 hPa Linearised APP1 0.00 % duty cycle - exhaust refeeding actuator 94.53 % duty cycle - air charge pressure controller 90.59 % Atmospheric-pressure 1004.30 hPa Luftmasse zu hoch/negative Regelabweichung Test conditions not yet fulfilled Error not present now, but already stored Error would cause a warning lamp to light up Fehler in Entprellphase Fehler in Entprellphase Fehler in Entprellphase Error code: 45 01 B2 06 04 01 09 28 55 8D 1D 6F 31 14 50 68 00 78 72 65 55 91 1E 4A 31 1D 54 65 00 78 73 66 ------------------------------------------------------------- 4841 4841 (1491) regulation of exhaust re-circulation 2, Regelabweichung Error counter: 13 Logistic counter: 40 1. Umweltsatz Mileage 219010 km average engine rotational speed 827.47 rpm coolant temperature 61.17 deg C maximum common-rail-pressure of last 10ms 385.98 bar injection mass index value without mass balance control 7.88 mg/cyc intaken air mass per cylinder 504.13 mg/Hub charge pressure value 1023.99 hPa Linearised APP1 0.00 % duty cycle - exhaust refeeding actuator 0.00 % duty cycle - air charge pressure controller 89.80 % Atmospheric-pressure 994.46 hPa 2. Umweltsatz Mileage 219050 km average engine rotational speed 799.89 rpm coolant temperature 28.04 deg C maximum common-rail-pressure of last 10ms 385.98 bar injection mass index value without mass balance control 10.63 mg/cyc intaken air mass per cylinder 523.03 mg/Hub charge pressure value 1004.30 hPa Linearised APP1 0.00 % duty cycle - exhaust refeeding actuator 0.00 % duty cycle - air charge pressure controller 89.80 % Atmospheric-pressure 1004.30 hPa Luftmasse zu hoch/negative Regelabweichung Test conditions not yet fulfilled Error not present now, but already stored Error would not cause a warning lamp to light up Fehler in Entprellphase Fehler in Entprellphase Fehler in Entprellphase Error code: 48 41 32 06 00 00 0D 28 55 8D 1E 6F 31 14 50 68 00 00 72 65 55 91 1D 4E 31 1B 53 66 00 00 72 66 ------------------------------------------------------------- 4302 4302 (0001) amount control valve, Ansteuerung P0001 Fuel Volume Regulator Control Circuit/Open Error counter: 1 Logistic counter: 39 Mileage 0 km average engine rotational speed 0.00 rpm coolant temperature 40.08 deg C maximum common-rail-pressure of last 10ms 0.00 bar injection mass index value without mass balance control 0.00 mg/cyc intaken air mass per cylinder 0.00 mg/Hub charge pressure value 994.46 hPa Linearised APP1 0.00 % Battery Voltage 12219.47 mV Vehicle speed 0.00 km/h output duty cycle - amount control valve 60.65 % Unterbrechung Test conditions fulfilled Error not present now, but already stored Error would not cause a warning lamp to light up Fehler in Entprellphase Fehler in Entprellphase Fehler in Entprellphase Error code: 43 02 24 02 00 01 01 27 00 00 00 5A 00 00 00 65 00 4B 00 4D ============================
  2. a co by się mogło stać jak by były założone przewody sylikonowe tam gdzie Paliwowe?
  3. dla tego kupiłem 3.0mm aha a dla czego mówisz by wymienić przewody paliwowe?
  4. no ja kupiłem 4 metry kabla sylikonowego SAMCO(taki niebieski) o średnicy 3mm i tu pytanie czy taka średnica jest ok chodzi o,to czy jak by była np 3.5mm to byłby lepszy przepływ powietrza?
  5. Czy przewody podciśniena mają znaczenie jeśli chodzi o ich szerokość bo mam zakupione o szerokośći 3mm i czy to nie za mało? w sensie jak bedzie powietrze przepływało?
  6. Panownie mam pod podwoziem w 3 miejsach rdzę,chciałbym to zakonserwować.. Zakupilem środek BOLL do konserwacji podwozia w Spreyu ''Baranek'' lecz mechanik mówi pierw pasowało by dać jakiś podkład,co się wżera w blachę i dopiero ten baranek i tu pytanie jaki pokład? jaka ta farba?
  7. no właśnie dla tego mam mechanika która pracuje w zawodzie mechanik a po robocie albo jak ma wolne robi w domu i zawsze z dużymi rabatami mi robi dla tego wolę spytać.Pójdę do pobliskich sklepów u mnie albo też nie daleko mnie chce wymienić olej to to co na półce będzie np castrol itp a tak,żeby sami zaproponowali np motul itp ee gdzie tam.Filtry tak samo jak samemu nie kupi się i zawiezie do mechanika to na słowo Knetch :shock: takie oczy,ale po chwili szperania w necie dostaje się wiadomość no byłby na zamówienie i weż tu co rób.Dla tego tak pytam,żeby wiedzieć kupić to i to jadę do mechanika zakłada i gra gitara.A nie w warsztacie.Już wcześniej tak serwisowałem Hondę,robili stacyjkę to w koło plastiki porysowane,siedzenie smarem ubabrane..
  8. tak tak oddał bym auto do warsztatu to by od razu zalalil borygo
  9. bo nie wiem ile kupić czy 5,6,7
  10. dobra poszukam prestone w takim razie trza kupić aż 7l prestone...
  11. Stivo92
    e46 320d olej
    heh najlepsze to,ze idę i mówię olej Motul jakii :mrgreen: mówią na zamówienie tylko dla czego na alledrogo są po 130zł za 5l
  12. no tak tylko ile l wchodzi i jest problem bo przeważnie borygo wszędzie jest... eh
  13. Stivo92
    e46 320d olej
    zamawiając w sklepie motoryzacyjnym krzykneli 178zł za 5l Motula 8100 C3 5w30 dobra to cena? aha i czy 5l wystarczy? czy trzeba dokupywać jeszcze 1l?
  14. Stivo92
    e46 320d olej
    koledzy chce zamówic w sklepie Motul 8100 tylko dylemat bo nie wiem jaki mam olej teraz w silniku czy 5w30 czy 5w40 brać? chodzi o Motul
  15. Formułowicze ile l płynu chłodniczego wchodzi do układu? jeżeli bym chcial wymienić termostat główny?? i czy płyn borygo się nada? jeśli tak to zielony czy te różowy co jest?
  16. Stivo92
    Tuleja e46 320d
    no nic zamówilem febi... 119zł+25wysyłka nie chciałem meyle bo jak bym dwie kupywał to okej a na dodatek,ze to twarde i do tego jedna to nie ciekawie by było
  17. Stivo92
    Tuleja e46 320d
    Rozumiem,ale póki co chce wstawic coś z tego febi meyle hd ruville bardzo prosiłbym o odpowiedz które będą chociaż w miarę sensowne
  18. Stivo92
    Tuleja e46 320d
    boże jedyny nie chce lem bo jak bym nie miał wydatków typu sterownik świec żarowych itp to bym kupił dla tego coś z tych 3
  19. Stivo92
    Tuleja e46 320d
    Panownie tuleja febi meyle hd ruville która najlepsza?
  20. Stivo92
    Tuleja e46 320d
    to tak raczej zdecyduję się na wymiane jednej tylko tu pytanie febi czy meyle hd? tylko z tych dwóch coś
  21. Stivo92
    Tuleja e46 320d
    hmm prasy to on na pewno nie ma... pracuje w okręgowej stacji pojazdów jako mechanik tam to może tam mają prase... sam nie wiem... ale wymieniająć jedną tuleje nic sie nie stanie? w sensie nie będzie dziwnych zachowań auta itp?... a jeżeli tak to czytam i dużo osób odraza FEBI,że padają błyskawicznie a dużo osób poleca Meyle HD 1szt 120zł na czescidobmw to co polecasz kolego? chodzi o to,że jak wymiana jednej tulei nie,bedzie miała wpływu na komfort itp to nie ma sensu dwuch bo dodam,że mam teraz trochę wydatków 2 termostaty,sterownik świec żarowych itp ps; czy jak tuleja lata/skrzypiała to możliwe jest ściąganie auto w lewo jak poszła lewa tuleja?
  22. Stivo92
    Tuleja e46 320d
    heh zadzwoniłem do mechanika i mówi bym z uchem kupil :mrgreen: ale mówię coś tam o wkładach czy by wprasował itp mówi a to już kup ale pytanie ile on za to powie,żeby mi na to samo co z uchami nie wyszło... a co się stanie jak by kupił jedną tulejkę tylko?
  23. Stivo92
    Tuleja e46 320d
    a to jest ciężkie wyprasowac i wprasowac trzeba mieć jakieś narzędzie?
  24. Stivo92
    Tuleja e46 320d
    no właśnie widzę,ze tylko 60 pare złotych ale to bez uchywtu jest...
  25. Stivo92
    Tuleja e46 320d
    ale nie o to chodzi... chodzi o tuleje przedniego zawieszenia... wyszła,ze lewa tuleja jest rozyspana czy ma luzy jakoś tak dla tego pytanie czy można wymienić samą lewą tuleje przedniego zawieszenia? o to chodzi
