ArEkO
Treść opublikowana przez ArEkO
  1. jak dla mnie BECKER trafic pro super dzwiek i do tego navi ..............
  2. 2000 DSP Premium Sound connector information The pinouts for the 15 pin connector are: PIN - CONNECTION 1- Sub 1 + 2- Sub 2 + 3- LH Rear loudspeaker + (Touring LH rear speaker ground) 4- Radio on/antenna signal 5- RH rear loudspeaker + (Touring RH rear +) 6- Sub 4 - 7- Sub 3 - 8- Terminal 30 connects to Fuse 56 9- Sub 1 - 10- Sub 2 - 11- Touring LH rear + 12- Touring RH rear - 13- Sub 4 + 14- Sub 3 + 15- Terminal 31 connects to Ground Point The pinouts for the 18 pin connector are: PIN - CONNECTION 1- Not used 2- Low freq. negative (-) signal - Transceiver/charging electronics 3- Not used 4- Not used 5- I-bus Signal Line - Splice X18344 6- Not used 7- Not used 8- RH front speaker - Connects to Radio 9- LH front speaker - Connects to Radio 10-Not used 11 Low freq. voltage (+) signal - Transceiver/charging electronics 12-Not used 13-Telephone mute signal - Transceiver/charging electronics 14-Not used 15-Telephone ON signal - Transceiver/charging electronics 16-Not used 17-RH front speaker + - Connects to Radio 18-LH front speaker + - Connects to Radio The pinouts for the 26 pin connector are: PIN - CONNECTION 1- LH front woofer + 2- LH front woofer - 3- Not used 4- RH front mid-range - 5- LH front mid-range + 6- Not used 7- Not used 8- Not used 9- RH front mid-range + 10-LH front mid-range - 11-Right rear mid-range speaker/tweeter + 12-RH front tweeter + 13-RH front woofer + 14-LH front tweeter + 15 LH front tweeter - 16-Left rear mid-range speaker/tweeter - 17-Not used 18-Not used 19-Left rear mid-range speaker/tweeter + 20-Not used 21-Not used 22-Not used 23-Not used 24-Right rear mid-range speaker/tweeter - 25-RH front tweeter - 26 RH front woofer - znalazlem moze sie komus sprzyda
  3. Moze ktos z kolegow ma opis DSP z E39 dokladnie chodzi mi o te 3 wtyki szukam sygnalu audio i kabelka Remonte zeby podpiac sie (subwofer) :arrow: wielkie dzieki za kazde info .
  4. Tez zalozylem sobie takie podswietlenie :arrow: ale podlaczylem je tak ze zapalaja sie tylko jak sa wlaczone swiatla :!: mam juz to 6 tygodni i jakos mi akmulator nie siadl.Musiales to zle podpiac widocznie.....
  5. mozna zakupic cos takiego :arrow: http://cgi.ebay.de/TV-Frei-TV-Free-BMW-E38-E39-E46-Z3-Z4-X5-und-X3_W0QQitemZ4637907566QQcategoryZ76083QQssPageNameZWDVWQQrdZ1QQcmdZViewItem albo takie nowsze :arrow: http://cgi.ebay.de/TV-free-Freischaltung-direkt-fuer-BMW-e46-e38-e39-X3-X5_W0QQitemZ4649701403QQcategoryZ76083QQrdZ1QQcmdZViewItem
  6. Najprosciej zajechac do salonu BMW ,ale impreza ta do tanich niebedzie nalezec :!: proponuje Emule lub cos w tym stylu :cool2:
  7. :arrow: no i opanowalem :D jak by ktos mial nastepny raz z tym problem chetnie pomoge.........pozdrowionka
  8. No i dalej kwie z problemem po zrobionym przejsciu niema glosu wszystko chodzi tylko bez dzwieku :!: dziwne jest to ze zmieniarka gra :jawdrop: moze ktos wie co zrobic z tym problemem :?: z wtyczki samochodowej wychodzi tylko 10 kabli piny 4,7,5,10,16,13,15,9,2,1,
  9. Pisalem na PW i na GG ale niemoge cie zastac :cry: jestem zainteresowany tym przejsciem jak co :!:
  10. Witam , szukalem ale nieznalazlem na forum :( wiec moze ktos bedzie wiedzial :arrow: kupilem radio minidisc do E39 i niemoge podlaczyc to w moim modelu jest jeszcze stara wytczka okragle bolce a w radiu mam plaskie piny :!: szukam opisu lub gotowego przejscia, dzieki za kazda pomoc :!:
  11. Wielkie dzieki :cool2: nieliczylem na taka szybka odpowiedz :!: o to mi chodzilo wlasnie :shock: eXtra forum.Pozdrowionka
  12. Witam mysle ze moge sie dolaczyc do tematu aby nieotwierac nowego a wiec pytanie jest takie :arrow: gdzie podlaczyc w E39 wzmacniacz z subweferem wiadomo kable pradowe do akmulatora ale chodzi mi o impuls zalaczania wzmachola i podlaczenie dzwieku audio ,wiem ze to wszystko bedzie po lewej stronie w schowku w bagarzniku :!: moze to ktos dokladnie opisac albo ma jakiegos linka lub opis kabli z tylu :?: dzieki za kazde info
