se93
  1. here are a few snapshots of my setup I have run INPA successfully, have deleted and reinstalled the ethernet adapter from scoadmin, restarted the kernel and as i indicated, all necessary procedures have been done to get this working. http://s958.photobucket.com/albums/ae66/se93/ Regards, Mark
  2. Check ip address in ediabas.ini. Double check network settings in VMware. Enable VMware 5.xx emulation. Switch off antivrus, firewall, etc. In DIS go to administrator, touch pad calibration. Chose configure process. Make all of them not running and apply configuration. Make all of them running and apply configuration. Removing cards can kill DIS. Thankyou for your reply. Antivirus/Firewall are always disabled when i work with DIS. In DIS as you say, do you mean that i change all the processes to not running and run an API Test and if it does not pass then go back and set them all to run and redo the API test? Is this what you mean? In my ediabas.ini file, IP is: 192.168.68.1 Hmm, i have never used the emulation option in Vmware. I am running Vmware 6.0 and have not seen the emulation you mention. I am going to have to check and see as the instructions i used to install did not specify this and my first installation was completely successful using these same instructions. Everything turned downhill after i had to reformat my hard drive because of a worm virus. Regards, Mark
  3. Hi and thankyou for the reply. I have tried removing the network device a number of times and still cannot pass the API Test. I ran a ping 192.168.68.30 and the results were 4 packets received and 4 sent 0% lost. I figured that with this result i would pass the API, but have not been able to do so. Everything has been properly configured and installed. I do not know what else to check and what else to do to make this work. Regards, Mark
  4. Hello to all: I was hoping someone on the board Could help me figure out why and get a NET 0016 Host error When running the API test in DIS. All Has Been Properly installed and configured. INPA works flawlessly with absolutely no problems at all. I am running Windows XP Professional with SP3 on a Sony Vaio Laptop Dual Core 1.6. I had to reformate the computer due to a computer virus and Since this and have been unable to pass the API Test. My previous installation Worked flawlessly until the machine got a worm virus and i had to reformate the hard drive. Since this, and have not been able to indictment the API Test. I would be grateful That is anyone can help me out and figure this out. I have snapshots of my VMware machine with all-IP addrsses if anyone would like to see them. I am running Vmware 6.0 Regards, Mark
