Kukles
  1. Kukles odpowiedział(a) na Kukles temat w E36
    Na stacji diagnostycznej mi tak powiedzieli ze na wykonczeniu bo strasznie gwizda. To jak wstawie zwykla rure albo np. tlumik srodkowy to sondy nie musze wymieniac?
  2. Kukles opublikował(a) temat w E36
    Witam Ostatnio strasznie duzo mi pali samochod 12 benzyny 18 gazu. Czy moze to byc wina katalizatora ktory jest na wykonczeniu?
  3. Kukles odpowiedział(a) na Kukles temat w E36
    Znalazlem takie schematy: 1.8L, Engine Performance Circuits (1 of 2) , 40462 byte 1.8L, Engine Performance Circuits (2 of 2) , 48727 byte Air Conditioning Circuits (1 of 2) , 47597 byte Air Conditioning Circuits (2 of 2) , 54113 byte Anti-lock Brake Circuits, W/O Traction Control , 41080 byte Anti-theft Circuit , 31590 byte Body Computer Circuits , 25466 byte Charging Circuit , 19924 byte Computer Data Lines , 34734 byte Cooling Fan Circuit , 31677 byte Cruise Control Circuit , 28977 byte Defogger Circuit , 24017 byte Driver Power Seat Circuit , 32275 byte Exterior Light Circuit, Canada (1 of 3) , 33944 byte Exterior Light Circuit, Canada (2 of 3) , 35795 byte Exterior Light Circuit, Canada (3 of 3) , 29194 byte Exterior Light Circuit, USA (1 of 3) , 33814 byte Exterior Light Circuit, USA (2 of 3) , 32141 byte Exterior Light Circuit, USA (3 of 3) , 29216 byte Ground Distribution Circuit (1 of 5) , 37816 byte Ground Distribution Circuit (2 of 5) , 37760 byte Ground Distribution Circuit (3 of 5) , 36450 byte Ground Distribution Circuit (4 of 5) , 34708 byte Ground Distribution Circuit (5 of 5) , 30179 byte Headlamp/Foglamp Washer Circuit, USA , 16886 byte Headlight Circuit, W/ DRL (1 of 2) , Headlight Circuit, W/ DRL (2 of 2) , Headlight Circuit, W/O DRL Heated Seats Circuit , Horn Circuit Instrument Cluster Circuit (1 of 2) Instrument Cluster Circuit (2 of 2) Interior Light Circuit (1 of 2) Interior Light Circuit (2 of 2) Jet Heater Circuit Passenger Power Seat Circuit Power Distribution Circuit (1 of 5) Power Distribution Circuit (2 of 5) Power Distribution Circuit (3 of 5) Power Distribution Circuit (4 of 5) Power Distribution Circuit (5 of 5) Power Door Lock Circuit Power Mirror Circuit Power Window Circuit (1 of 2) Power Window Circuit (2 of 2) Radio Circuits, 10 Speaker System Radio Circuits, 6 Speaker System Shift Interlock Circuit Starting Circuit Sunroof Circuit Supplemental Restraint Circuit Transmission Circuit Warning System Circuits Wiper/Washer Circuit, USA Wiper/Washer/Headlamp Washer Circuit To sa z modelu samochodu z ktorego wzialem silnik czyli M42 ktory mi bedzie potrzebny do przerobienia zebym dal elektrykowi? I ktory z modelu M44 Pomozcie
  4. Kukles opublikował(a) temat w E36
    Potrzebny mi schemat elektroniki do silnika M42 i M44. Zmienilem silnik z nowszego na starszy i PINy niepasuja do elektroniki samochodu Ma ktos moze? HELP
  5. Niech ktos cos napisze zaproponuje rozwiazanie
  6. Dowiedzialem sie ze musze zmieniac cala instalacje z wnetrza z imobilajzerem z kluczykami stacyjka i cala reszta:/ Nie da sie tego inaczej zrobic?
  7. Zmienilem ten silnik i pojawily sie problemy. W zakladzie powiedzieli ze instalacja wew auta ma inna wtyczke inaczej PINy sa niz w tej z silnika M42 i potrzebny schemat do przerobienia:/ Gdzie cos takiego moga zrobic bo oni mowia ze nie maja schematu:( Jestem ze slaska No i musze jeszcze zdjasc imobilajzer bo wymienilem caly silnik z wiazkom i komputerem.
  8. Ja chce zmieniac w swoim compakcie 97r silnik z M44 na M42 tamten padł jakie beda przerobki? Kupuje cały silnik z osprzetem.
  9. Kukles odpowiedział(a) na Kukles temat w E36
    Az tak dobrze angielskiego nie znam :(
  10. Kukles opublikował(a) temat w E36
    Moj samochodzik 318Ti 97r stal poltora roku i nie byl uzywany po wypadku. Niedawno zostal zrobiony i wszystko jest spoko tylko nie padal deszcz i nie wiedzialem. Jak troche popada i zaczne skrecac kierownica to strasznie trzeszczy i skrzypi najbardziej to w lewo nie da sie wytrzymac w prawo tylko troche. Co zrobic i co moze byc powodem?
  11. odlacz akumulator na jakis czas potem przejedz sie spokojnie troche, uwazaj zeby nie zgasl kontrolujac go gazem, potem zgas silnik na moment i powinno byc lepiej wczesniej wymien swiece, sprawdz gume przeplywomierza czy czasem nie przetarla sie gdzies np od smigla, i czy dobrze jest zalozona, sprawdz obejmy, to najtansze co mozesz zrobic Sprawdzilem to wczesniej samochod nie chodzil 1.5roku wiec wiedzialem ze cos bedzie wychodzic pochodzil kilka minut na gazie i byl wielki chuk przy odpalaniu. Zajrzalem teraz glebiej i guma sie lekko zeslizgnela miedzy silnikiem a przeplywomierzem juz jest ok zamocowalem juz dobrze niema prawa nic spasc. Dziwi mnie tylko jedna rzecz jutro wymieniam olej i wszystkie filtry a w tym tygodniu swiece. Na gazie chodzi lepiej niz na benzynie wogole nie szarpie nie traci obrotow ani tym bardziej nie pierdzi wiem ze samochod dlugo stal i sie musi ulozyc wszystko ale na gazie chodzi pieknie.
  12. Teraz to sie zrobilo. Samochod spada z obrotow do zera i gasnie. Obojetne na jakim biegu. Na gazie i na benzynie. Pomozcie nie wiem co zrobic :(
  13. Mam taki sam problem w moim E36 318Ti gdzie jest jakis normalny mechanik na slasku co moglby to zobaczyc bo ja lewy jestem i nie wiem co zrobic
  14. Kukles odpowiedział(a) na Yan00sh temat w E36
    Shell Helix Ultra 5W40 na allegro od 110-135 a w sklepie 180zl:/ Boje sie tylko czy jakas podrobka by nie byla
  15. Kukles odpowiedział(a) na Yan00sh temat w E36
    Olej na allegro jest srednio o 60zl tanszy niz w sklepie czy w sklepie tyle zarabiaja? Czemu jest az taka roznica?
