masu93
Treść opublikowana przez masu93
  1. Witam, BMW E90 318i 129KM świeci mi się check, przy ruszaniu dziwny grzechot z silnika oraz słabe wkręcanie się od dołu obrotów, minimalne falowanie obrotów. Po sprawdzenia INPĄ wyskoczyły następujące błędy: Control Unit : 12 DME/DDE - MEV9N46L - Motorelektronik ME9.2 4 Zylinder N46 Job Status : OKAY Failure Place : 10883 0x2A83 - CDKENWS - camshaft control- Input Failure Symptom : 113 Control stop too long too large Readyness Flag : 16 Test conditions fulfilled Error present : 33 Error not present now, but already stored Warning Flag : 49 Error would cause a warning lamp to light up P-Code : 18 P0012 P0012 Nockenwellensteuerung Einlass (Bank 1) - Regelfehler, unplausible Position P-Code7 : 0 -- Occurence Counter : 78 Logistic Counter : 40 Failure Kinds : 6 Failure K. 1 : 11 Diagnostic active Failure K. 2 : 20 -- Failure K. 3 : 31 Cycle flag set Failure K. 4 : 40 -- Failure K. 5 : 51 MIL on Failure K. 6 : 60 -- 1. Data Set Environment Amount : 4 Environment KM : 123456 Environment Set 1 : 10 Engine speed (nmot) 1880.0000 /min Environment Set 2 : 18 Engine temperature (tmot) 94.5000 degrees C Environment Set 3 : 26 Relative air filling (rl) 56.2500 % Environment Set 4 : 108 actual angle for camshaft 1(wnwi1_u) 1.0000 Degree KW 2. Data Set Environment Amount : 4 Environment KM : 123472 Environment Set 1 : 10 Engine speed (nmot) 720.0000 /min Environment Set 2 : 18 Engine temperature (tmot) 103.5000 degrees C Environment Set 3 : 26 Relative air filling (rl) 12.0000 % Environment Set 4 : 108 actual angle for camshaft 1(wnwi1_u) 1.0000 Degree KW 3. Data Set Environment Amount : 4 Environment KM : 124104 Environment Set 1 : 10 Engine speed (nmot) 1800.0000 /min Environment Set 2 : 18 Engine temperature (tmot) 88.5000 degrees C Environment Set 3 : 26 Relative air filling (rl) 30.0000 % Environment Set 4 : 108 actual angle for camshaft 1(wnwi1_u) 2.0000 Degree KW ---------------------------------------------------------------------------------------------- Control Unit : 12 DME/DDE - MEV9N46L - Motorelektronik ME9.2 4 Zylinder N46 Job Status : OKAY Failure Place : 11426 0x2CA2 - CDKHSVSA - heating lambda sensor of front cat (shearing stress) Failure Symptom : 124 Too low thrust signal voltage Readyness Flag : 16 Test conditions fulfilled Error present : 32 Error not occurred yet Warning Flag : 49 Error would cause a warning lamp to light up P-Code : 0 -- P-Code7 : 0 -- Occurence Counter : 1 Logistic Counter : 2 Failure Kinds : 6 Failure K. 1 : 10 -- Failure K. 2 : 20 -- Failure K. 3 : 30 -- Failure K. 4 : 40 -- Failure K. 5 : 50 -- Failure K. 6 : 60 -- 1. Data Set Environment Amount : 4 Environment KM : 123504 Environment Set 1 : 45 Voltage LS heating front cat (uhsv) 0.0000 V Environment Set 2 : 168 LSU voltage front cat (ADC) (uulsuv_u) 2.5389 V Environment Set 3 : 41 Exhaust temp. front cat from model (tabgm) 615.0000 Degrees C Environment Set 4 : 11 Vehicle speed (vfzg_u) 70.0000 km/h ---------------------------------------------------------------------------------------------- Control Unit : 12 DME/DDE - MEV9N46L - Motorelektronik ME9.2 4 Zylinder N46 Job Status : OKAY Failure Place : 11427 0x2CA3 - CDKHSVSA2 - heating lambda sensor of front cat (shearing stress) Bank2 Failure Symptom : 124 Too low thrust signal voltage Readyness Flag : 16 Test conditions fulfilled Error present : 32 Error not occurred yet Warning Flag : 49 Error would cause a warning lamp to light up P-Code : 0 -- P-Code7 : 0 -- Occurence Counter : 1 Logistic Counter : 2 Failure Kinds : 6 Failure K. 1 : 11 Diagnostic active Failure K. 2 : 20 -- Failure K. 3 : 30 -- Failure K. 4 : 40 -- Failure K. 5 : 50 -- Failure K. 6 : 60 -- 1. Data Set Environment Amount : 4 Environment KM : 123504 Environment Set 1 : 46 Voltage LS heating front cat bank2 (uhsv2) 4.9725 V Environment Set 2 : 169 LSU voltage front cat bank2 (ADC)(uulsuv2_u) 4.9802 V Environment Set 3 : 42 Exhaust temp. front cat from model bank2(tabgm2) 1225.0000 Degrees C Environment Set 4 : 11 Vehicle speed (vfzg_u) 70.0000 km/h Od czego byście proponowali zacząć? Wymiana czujnika wałka? Mam jeszcze jeden problem, ostatnio jadąc jakieś 20km z prędkością 130-140 mrugała kontrolka DTC i auto zaczynało przyhamowywać, dopiero po wyłączeniu DTC jechało normalnie, prawe koło było strasznie gorące. Po sprawdzeniu w INPIE brak jakichkolwiek błędów w tym kierunku. Jakieś sugestie?
  2. Ok, raczej dam sobie spokój. Dzięki za wsparcie. :D
  3. Rozumiem, ale po takich przekładkach co się z autem może dziać poważnego?
  4. To oznacza, że od razu jest skreślona? Czy da się z tym żyć? :)
  5. Sprzedawca twierdzi, że w 2009 roku zostało sprowadzone, natomiast on jeździ nim od roku i zrobił jakieś 15tys, jest 3 właścicielem, a sprzedaję bo kupił e60. ps. może to być przekładka? na realoem pokazuję kierownice z prawej.
  6. Witam, Auto oglądałem wczoraj i dzisiaj z mechanikiem. Technicznie ok. Gdzie nie gdzie było malowane. Trochę dziwnie poskładana konsola środkowa, takjakby co było robione. Generalnie zadbane w środku. [url http://otomoto.pl/oferta/bmw-seria-3-zadbany-automatyczna-skrzynia-ID6yfV9R.html /url] Warto? VIn: Vehicle Identification Number WBAVC32010VA30574 Type VC32 Model 320d Ol - EUR Development Code E90 Chassis LIM Steering RL Doors 4 Engine M47/T2 Displacement 2.00 Power 120 Drivetrain HECK Transmission AUT Color Monacoblau Metallic - A35 Upholstery Stoff Fluid/anthrazit - ALAT Production Plant LEIPZIG Production Date 2005-08-17 1CA Selection Cop Relevant Vehicles Selektion Cop Relevanter Fahrzeuge 2BH Lt/aly Wheels Double Spoke 156 Lm Raeder Doppelspeiche 156 200 Diesel Particle Filter Dieselpartikelfilter 205 Automatic Transmission Automatic Getriebe 240 Leather Steering Wheel Lederlenkrad 249 Multi-function For Steering Wheel Multifunktion Fuer Lenkrad 302 Alarm System Alarmanlage 321 Exterior Parts In Body Color Exterieurumfaenge In Wagenfarbe 428 Warning Triangle Warndreieck 431 Interior Rr Vw Mirror W Aut Anti-d Innenspiegel,automatisch Abblendend 441 Smokers Package Raucherpaket 507 Park Distance Control (pdc) Park Distance Control (pdc) 520 Foglights Nebelscheinwerfer 534 Automatic Air Conditioning Klimaautomatik 540 Cruise Control Geschwindigkeitsregelung 563 Lights Package Lichtpaket 663 Radio Bmw Professional Radio Bmw Professional 694 Preparation For Cd Changer Cd-wechsler Vorbereitung 8SB Country Spec. Release Of Telematic Laenderspez. Telematikfreisch. 8SC Country Spec. Release Of Teleservice Laenderspez. Teleservicefreisch. 8SM Vin, Visible From Outside Fahrgestellnummer,v.aussen Sichtbar 8SP Cop Control Cop Steuerung 812 England Version England/irland Ausfuehrung 850 Add Fuel Tank Filling For Export Zusaetzl. Tankfuellung Export 863 Europe/dealer Directory Service Kontakt-flyer Europa 877 Deletion Cross-over Operation Ueberkreuzbedienung Entfall 880 English / On-board Documentation Englisch / Bordliteratur 9AA External Skin Protection Aussenhautschutz
