320d/2005r. Prośba o zinterpretowanie błędów
Mam własny interface do Inpy. Ostatnio dwukrotnie zapaliła mi się kontrolka silnika i sama po jakimś czasie zgasła. Obecnie się nie świeci. Odczyt błędów przedstawiam poniżej. Nie wiem czy mam do wymiany przepływomierz, czujnik wałka rozrządu a może jeszcze coś innego. Proszę o pomoc.
E R R O R M E M O R Y
Date: 20.08.2010 23:30:33
ECU: D50M47B1
JobStatus: OKAY
Variant: D50M47B1
RESULT: 2 error in error memory !
3EC0 3EC0 Camshaft sensor, Signal
Error counter: 255
Logistic counter: 22
1. Umweltsatz
Mileage 190380 km
average engine rotational speed 855.05 rpm
coolant temperature 69.20 deg C
maximum common-rail-pressure of last 10ms 385.98 bar
injection mass index value without mass balance control 6.70 mg/cyc
intaken air mass per cylinder 245.76 mg/Hub
charge pressure value 1004.30 hPa
Linearised APP1 0.00 %
Battery Voltage 14011.66 mV
Vehicle speed 3.95 km/h
meta-status of KW- and NW-event managment 48.00 -
2. Umweltsatz
Mileage 200650 km
average engine rotational speed 1820.44 rpm
coolant temperature 88.27 deg C
maximum common-rail-pressure of last 10ms 764.08 bar
injection mass index value without mass balance control 22.45 mg/cyc
intaken air mass per cylinder 472.62 mg/Hub
charge pressure value 1043.69 hPa
Linearised APP1 33.86 %
Vehicle speed 45.40 km/h
kein Signal
Test conditions fulfilled
Error not occurred yet
Error would not cause a warning lamp to light up
Fehler in Entprellphase
Error code: 3E C0 01 06 00 00 FF 16 4A 5E 1F 77 31 11 27 66
00 56 04 30 4E 61 42 8A 61 39 4B 6A 2B 56 2E 30
3FF0 3FF0 (3263) air flow meter
P3263 Mass or Volume Air Flow Too High due to Sensor Drift
Error counter: 52
Logistic counter: 36
1. Umweltsatz
Mileage 197770 km
average engine rotational speed 2372.09 rpm
coolant temperature 76.23 deg C
maximum common-rail-pressure of last 10ms 685.31 bar
injection mass index value without mass balance control 10.24 mg/cyc
intaken air mass per cylinder 636.46 mg/Hub
charge pressure value 1240.61 hPa
Linearised APP1 18.11 %
Battery Voltage 14174.59 mV
Vehicle speed 59.22 km/h
Atmospheric-pressure 974.76 hPa
2. Umweltsatz
Mileage 203600 km
average engine rotational speed 2399.67 rpm
coolant temperature 71.21 deg C
maximum common-rail-pressure of last 10ms 834.97 bar
injection mass index value without mass balance control 20.48 mg/cyc
intaken air mass per cylinder 743.59 mg/Hub
charge pressure value 1447.38 hPa
Linearised APP1 32.28 %
Vehicle speed 84.88 km/h
Atmospheric-pressure 984.61 hPa
Verhaeltnis berechnete zu gemessener Luftmasse zu groß
Test conditions not yet fulfilled
Error not present now, but already stored
Error would cause a warning lamp to light up
Error code: 3F F0 B1 06 32 63 34 24 4D 41 56 7E 57 1A 65 7E
17 57 3C 63 4F 88 57 79 6A 34 76 93 29 56 56 64
Powiedz może coś co się dzieje??
Właśnie, że poza tym, iż się ta kontrolka 2 razy zapalała i gasła po kilku dniach, to nic się nie dzieje. Żadnego szarpania ani większego spalania, gorszego zapalania, mniejszej mocy... nic. Zero objawów poza kontrolką.
Ale w dłuższą trasę za granicę strach jechać. To co robić? Co naprawiać?
