320 Bezpiczniki
Mam takie pytanko. Ktory bepiecznik odpowiada za podswietlanie deski i lewe swiatlo tylne.dzisjaj jadac zgaslo to i to a bylo za ciemno zeby szukac
http://yoshi.tarchomin.pl/bmw4fun/upload/noker_fusebox_e36.jpg
BEZPIECZNIKI:
  • F1 Sunroof
    F2 Trailer socket
    F3 Headlamp washers
    F4 Seat heater
    F5 Seat adjustment
    F6 Heated rear window
    F7 Door lock heater, central locking, alarm system, convertible roof
    F8 Horn
    F9 Audio system
    F10 ABS/traction control, suspension adjustment
    F11 Headlamp - left
    F12 Headlamp - right
    F13 Electric windows - rear (2 door)
    F14 Electric windows
    F15 Fog lamps-front, instrument panel
    F16 Air conditioning
    F17 Rear fog lamps
    F18 Fuel pump
    F19 Electric windows - rear (4 door/cabrio)
    F20 Heater/air conditioning
    F21 ABS/traction control, suspension adjustment
    F22 Fog lamps
    F23 Seat heaters, instrument panel, clock, trip computer, indicators, ABS, bonnet lamp, heater, heated rear window, fog lamps, headlamp relay
    F24 Windscreen washer jet heaters, door mirror adjustment, parking aid control
    F25 Light switch (headlamps/fog lamps)
    F26 Reversing lamps, transmission selector, oxygen sensor, diagnostic link, fuel heater
    F27 ABS/traction control, instrument panel, trip computer
    F28 Engine control module, transmission control module, cruise control module
    F29 Headlamp high beam - left
    F30 Headlamp high beam - right
    F31 Instrument panel, clock, trip computer, alarm system, central locking signal control module, air conditioning
    F32 Cigarette lighter
    F33 Side/tail lamps - left, bonnet lamp, interior lamps, charging socket, alarm system, telephone, door lock heater
    F34 Indicators/hazard lamps, crash alarm sensor, alarm system
    F35 Central locking, convertible roof
    F36 Windscreen wash/wipe control module
    F37 Side/tail lamps - right
    F38 ABS
    F39 Air conditioning compressor relay
    F40 Seat adjustment
    F41 Air conditioning condenser blower motor
    F42 Airbag, roll over protection (convertible)
    F43 Interior lamps, alarm system, central locking, telephone, convertible roof
    F44 Windscreen wash/wipe control module, glove box lamp, audio unit, alarm system
    F45 Trip computer, auxiliary warning module
    F46 Instrument panel, stop lamps, cruise control
PRZEKAŹNIKI:
  • 1 Fuel pump relay
    1 Oxygen sensor system relay
    1 Alternator warning lamp relay (318 tds)
    2 Engine control module relay
    3 Oxygen sensor system relay
    3 Fuel pump relay (/diesel)
    4 Horn relay
    5 Fog lamps relay
    6 Headlamp relay
    7 Headlamp high beam relay
    8 Hazard lamps relay
    9 Heater blower relay
    10 Heated rear window relay
    11 ABS protection relay
    12 ABS pump relay
    13 Engine coolant blower motor relay II
    14 Air conditioning compressor clutch relay
    15 Engine coolant blower motor relay I
  • 5 tygodni później...
Po dwóch dniach bezowocnej walki wkońcu oświeciło mnie zaraz po obejrzeniu odpowiedzi od Nokermana że przyczyną niedziałania lusterek i PDC u mnie może być spalony bezpiecznik F24, wczesniej ogladałem bezpieczniki ale jakoś nie rzuciło mi się w oczy że jest przepalony.
Nokerman dzieki za tą rozpiske bo niemiecki opis w skrzynce bezpieczników jest do bani :) :) :)
Marqu
