opis punktów rozrządu 318ti
witam.tak jak w temacie pilnie poszukuję opisów punktów rozrządu do bmki 318 ti 97r. wiadomo 2 wałki rozrządu 1.9 pojemności.potrzebuję tych wartości do ustawienia tego autka.proszę o pomoc.pozdrawiam
%5B576%3A480%5Dhttp%3A//yoshi.tarchomin.pl/bmw4fun/upload/noker_318ti_camshaft.jpg
Special tools
  • Flywheel timing pin - BMW No.11 2 300.
    Camshaft alignment tool - BMW No.11 3 240.
    Crankshaft/damper holding tool - BMW No.11 2 150/11 2 410
General precautions
  • Disconnect battery earth lead.
    Remove spark plugs to ease turning engine.
    Turn engine in normal direction of rotation (unless otherwise stated).
    Observe tightening torques.
    If fitted: Mark position of crankshaft position (CKP) sensor before removal.
    Do NOT turn crankshaft via camshaft or other sprockets.
    Do NOT turn crankshaft or camshaft with timing chain removed.
Valve timing procedures
  • Engine at TDC on No.1 cylinder.
    Ensure camshaft lobes are facing [1]11803and arrows face upwards [2]11803.
    Ensure camshaft alignment bores face upwards [3]11803.
    Insert flywheel timing pin [4]11803.
    Install camshaft alignment tool [5]11803.
    Ensure crankshaft sprocket keyway at 12 o'clock position [6]11803.
    Install hydraulic chain tensioner, prior to tightening bolts of camshaft sprockets.
    Drain chain tensioner [7]11803before installation:
    Push tensioner into housing as far as lock washer [8]11803.
    Repeat this procedure twice.
    Tighten crankshaft pulley bolt. Tightening torque: 330 Nm.
