Co się psuło w 850ce w USA
Znalazłem coś takiego. Widac, że np. kłopoty z chłodzeniem to nic nowego.
1991-1997 BMW 8-Series Reliability
Trouble Spots
Consumer Guide's® Auto Editors have scoured repair bulletins and questioned mechanics to search for commonly occurring problems for a particular vehicle. In some cases we also give possible manufacturer-suggested solutions. In many instances these trouble spots are Technical Service Bulletins posted by the manufacturer, however, we have our own expert looking at additional vehicle problems.
Air conditioner: The air conditioner compressor will shut down if the belt slips, which can occur after driving through a puddle and can be fixed by bypassing the A/C lock sensor control module. (1990-92)
Dashboard lights: Several problems with the hazard warning lights and turn signals activating by themselves, not blinking, etc. have been traced to problems with the flasher relay or the crash-sensor control module. (1992-95)
Poor transmission shift: The synchronizers in six-speed manual transmission get damaged if anything other than Dexron II automatic transmission fluid is used, causing notchy shifting. (1990-97)
Rough idle: Engine idles rough due to knock sensor picking up noise from water pump chatter when transmission is in drive and the air conditioning is on. (1997)
Rough idle: Engine may idle too high or run poorly (accompanied by a check engine light) due to vacuum leaks in the manifold gasket and/or leaking vacuum plugs on the fuel pressure regulator. (1997)
NHTSA Recall History
1991-92 850i: Airbag contact-ring locking tab in steering wheel assembly can break without warning, possibly causing wiring to break and preventing airbag from deploying in a collision.
1991-95: Malfunction or failure of cooling system component can result in significantly increased coolant temperature and system pressure. 1994: Remote activation device can close windows and sunroof from a distance greater than the maximum (6 meters) permitted by Federal standard.
1994-97 840Ci: Plastic housing on cruise-control or throttle cable could break due to environmental influences, coupled with vibration, leading to separation; could result in throttle valve remaining partially open.
Pozdrowienia
Paweł
www.automobile-catalog.com
To takie ogólne i ,,polityczne,, gadanie jednak potwierdzałoby np awarie, którą złapałeś w Giżycku czyli zacięty bimetal termostatu na skutek przegrzania go parą pod ciśnieniem układu. Pamiętam, że mówiłeś, iż testowałeś inne termostaty w tym oryginalne. U mnie wskaźnik temperatury wskazuje zawsze idealny środek. Nie ważne jak i w jakich warunkach pracuje silnik. Ciężko celnąć w jednoznaczne określenie i odnalezienie tego szwankującego komponentu układu chłodzenia ale możemy tego poszukać, choć teoretycznie.
Właśnie, gdyby chociaż wskazali na jakiś konkretny element... W każdym razie coś jest na rzeczy i się zdarzało...
Pozdrowienia
Paweł
Intuicyjnie myślę o chłodnicy silnika i tym co ma w środku po latach działania. Druga sprawa to zagęszczenie chłodnic z przodu układu wlotowego:AC,wspomaganie,chłodzenie,olej silnikowy,skrzynia...wiele tego....Po trzecie plastik kierujący wlot powietrza na chłodnice czyli pierwszą od wspomagania i za nią na tę od AC ich brak i obecność. Czwarta to sprawność wentylatora AC. Hmm wiele tego ale i tak nic to nie wyjaśnia.
