e30+m50 a ABS
po swapie nie dziala abs, raczej jest problem z kabelkiem nr14 w e30
wedlug tabelki z e30.de wynika ze laczymy z
16\17, lecz 16 i 17 kable na wiazce silnika m50 sa po prostu dla diagnostyki.
Allocation 318i Touring 1989:
Pin Cable color Strength Function
1 bl 0,75 Generator
4 brvi 0,75 Coolant temperature gauge
5 swge 0,75 Oil pressure
6 gnge 1,5 Ignition plus
7 gn 1,5 Ignition plus unsecured
8 gnws 0,75
9 sw 0,75 Number of revolutions
11 wsbl 0,75 SI
13 virt 2,5 Gasoline pump
14 blge 0,75 ABS
15 swgn 0,75 Load shedder relay (starter)
16 wssw 0,75 Consumption signal
18 swge 1,5 Starter
20 gert 0,75
Allocation 325i M50 1994:
4 swbl 0,75
5 swws 0,75 Geschwindigkeitssignal?
6 viws 0,75
7 swvi 0,75 OBC?
10 blge 1,5 Back-up light contact
11 brge 0,75 Coolant temperature (not used with E30 coolant temperature gauge giver)
12 brvi 0,75 Kuehlmitteltemparatur
13 grvi 1,5 Gasoline pump
14 swws 0,75
16 wsge 0,75 ABS diagnosis
17 wsli 0,75 ABS diagnosis
18 swge 1,5 Starter
19 gnws 0,75 SI
20 sw 0,75 Number of revolutions exit
21 gn 1,5 Ignition plus
22 grws 1,5 Back-up light contact
23 brgr 0,75 Oil pressure
24 swws 0,75 Consumption
25 bl 0,75 Generator
wtedy gdzie podlanczamy kabelek 14?
