zbieżność kół
Witam czy mógłby mi ktoś podać parametry ustawień kół tj zbieżności dla F30 320D 135kW
Dziękuję i pozdrawiam
Front axle:
Total toe-in   0° 14' ± 12’
Total toe-in adjustment*   0° 14' ± 4'
Toe difference** single wheel between left/ right   max. 12'
Camber
(difference between left/right max. 30')
  - 0° 20' ±  30’
Camber adjustment*   - 0° 20' ±  25’
Toe difference angle (difference between left/right max. 30')   -1° 26'
Castor angle   (difference between left/right max. 30')
Front wheel offset   0° ± 15'
Maximum steering angle
‐ Inner cornering wheel Ca. ° 40° 30'
‐ Outer cornering wheel Ca. ° 33° 48'
Rear axle:
Total toe-in   0° 18' ± 12'
Total toe-in adjustment*       0° 18' ± 4'
Camber (difference between left/right max. 30')   -1° 30' ± 25'
Camber adjustment*   -1° 30' ± 5'
Geometrical driving axis   0° ± 12'
*Note: To minimise adjusting errors (measuring inaccuracies), use a narrower tolerance for adjusting toe/camber.
**Note: Toe difference front axle = criterion for steering wheel inclination
