320i, OBC 18 przyciskow ,, PROG 1 ,, na wyswietlaczu
WItam. Niedawno zmienilem obc z 7 przyciskow na 18 podlaczylem wg instrukcji z forum, lecz wyskakuje mi ,,prog1,, i nic nie mozna wcisnac. prosze o rade
Display: Prog 1:
If any required function key is now depressed, the corresponding function is stored in the "scroll". For instance, if the function keys outside temperature, limit and range are pressed after the display "Prog 1" has appeared followed by the SET/RES key, the selected functions are stored in this order in the scroll and can be called up one after the other by pressing the steering column switch (LSS).
Note that on completion of such a programming procedure, the function first stored is displayed immediately.
