Potrzebny schemat rozrządu E36 318 TDS 95r
witam
Jak w temacie.Potrzebuje dla znajomego schemat rozrządu i info co i jak ,żeby działało:)
Dzięki za pomoc.
Pozdr
E36 318is -> E46 323i -> E46 325Ci -> E92 335i -> E60 520d LCI M Sport -> E46 330ci M Sport Auto -> E81 120d M Sport -> E91 330d M Sport Tourer -> F30 330d M Sport Plus Tourer -> E91 335d M Sport Tourer -> E92 335i Coupe M Sport -> E70 Lci X5 40d M Sport ->???
http://img86.imageshack.us/img86/3521/e36318tdsvalvetrim6ri.th.jpg
Special tools
  • Flywheel timing pin - BMW No.11 2 300.
  • Timing chain tensioner locking pins - BMW No.11 3 340.
  • Camshaft alignment tool - BMW No.11 3 320.
  • Timing chain compressor tool - BMW No.11 3 360.
  • Injection pump sprocket puller - BMW No.13 5 120.
General precautions
  • Disconnect battery earth lead.
  • Remove glow plugs to ease turning engine.
  • Turn engine in normal direction of rotation (unless otherwise stated).
  • Observe tightening torques.
  • If fitted: Mark position of crankshaft position (CKP) sensor before removal.
  • Do NOT turn crankshaft via camshaft or other sprockets.
  • Do NOT turn crankshaft or camshaft with timing chain removed.
  • Check diesel injection pump timing after resetting valve timing.
Valve timing procedures
  • Engine at TDC on No.1 cylinder [1]11666.
  • Insert flywheel timing pin [1]11666. Tool No.11 2 300.
  • 4 cylinders: Align injection pump sprocket timing mark 4 with timing chain bright link [2]11666.
  • 6 cylinders: Align injection pump sprocket timing mark 6 with timing chain bright link [2]11666.
  • Align crankshaft sprocket timing mark with bright link [3]11666.
  • Install camshaft alignment tool [4]11666. Tool No.11 3 320.
  • Compress timing chain [5]11666. Use tool No.11 3 360.
  • Insert locking pins in tensioner [6]11666. Tool No.11 3 340.
  • Remove injection pump sprocket [7]11666. Use tool No.13 5 120.
  • Tighten injection pump sprocket nut to 50 Nm [8]11666.
  • Tighten crankshaft damper bolts to 22 Nm [9]11666.
  • [A]11666: 80 links. 11666: 74 links.
PZDR
