po dzisiejszej diagnostyce wyskoczyły mi następujące kody błędów:
ECU: ZUHEIZ JobStatus: OKAY Variant: ZUHEIZ
RESULT: 1 errors in error memory !
0 Glow plug Flame detector
Error frequency : 255
Glowing 10 70.00 0-n
Cooling temperature 12.00 degrees Celsius
Short circuit to ground
ECU: IHKA39_4 JobStatus: OKAY Variant: IHKA39_4
RESULT: 2 errors in error memory !
16 Relay Washer jet heating
Error frequency : 16
Short circuit to batt+ Error present
Errorcode: 10 41 10 84 84 00 93 00 11 03 7A
41 Additional heater
Error frequency : 14
Open circuit
Error present
Errorcode: 29 44 0E 84 84 00 93 00 11 03 7F
ECU: MRS3 JobStatus: OKAY Variant: MRS3
26 seat occupied recognition 1 (SBE1)
Error frequency : 1
error not active at the moment
(wiring) break seat mat
error is not sporadic
ECU: ASC57 JobStatus: OKAY Variant: ASC57
4 wheel sensor rear left
Error frequency : 249
Vehicle speed 116.13 km/h
ASC passive
ABS-control passive
stop light switch off
ASC-control passive
ECU: DDE40KW0 JobStatus: OKAY Variant: DDE40KW0
13573 glow device
Error frequency : 1
Logistic counter: 40
Engine speed 724.28 1/min
Coolant temperature 36.12 Grad C
Einspritzmenge 9.73 mm^3
RPC rail pressure 337.35 bar
Fehler aufgetreten bei 312140.00 km
Error present
Glow system - Glow-plug or Glow-plug relay
Errorcode: 35 05 28 01 74 80 1D 71 13 38 79 EE 00 00 00 00
00 00 00 00 00 00 00 00 00
ECU: LWR2A JobStatus: OKAY Variant: LWR2A
2 error front sensor
Error frequency : 31
Outside temperature 4.00 degrees C
Error present
ECU: LCM_III JobStatus: OKAY Variant: LCM_III
40 thermal sensor for oillevel defect
Error frequency : 1
Error not present
http://archway.w.interii.pl/oil%20sensor.jpg
Proszę o interpretacje i co należało by sprawdzić lub wymienić..
