[E61] 530dA 2005r błędy elektryki 4660, 4547 i 44E2
Witam Forum,
Czego mogą być objawem poniższe błędy wyciągnięte z INPA (5.0.2)? Czy to oznaka starości akumulatora czy może walniętego regulatora napięcia bądź/i klemy IBS? Nie do końca jestem biegły w ocenianiu, które pomiary są za niskie/wysokie, więc docenię wszelkie wskazówki! :)
4660 4660 Supply voltage
Error counter: 1
Logistic counter: 40
Mileage 192680 km
Engine speed 1572.20 1/min
coolant temperature 24.02 °C
Rail pressure Actual 307.21 bar
Injection quantity 1.97 mg/Hub
Air mass per cylinder 592.35 mg/Hub
Charge pressure Actualwert 1486.76 mbar
Linearised APP1 0.00 %
Battery Voltage 17433.11 mV
Vehicle speed 36.52 km/h
Environment pressure 984.61 mbar
Versorgungsspannung DDE ueberschritten
Test conditions fulfilled
Error not occurred yet
Error would not cause a warning lamp to light up
Fehler in Entprellphase
Error code: 46 60 01 02 00 00 01 28 5E 15 39 4A 27 05 5E 97 00 6B 25 64
4547 4547 Powermanagement Bordnet
Error counter: 1
Mileage 192680 km
Engine speed 1434.28 1/min
Battery charge state 38.25 %
Battery Voltage im IBSCD 16.50 V
aktueller Batterystrom -156.83 A
Batterytemperatur 8.67 Grad C
Battery Voltage 7820.46 mV
Faktor für Battery aging 14.70 %
Batterieloser Betrieb
Error not present now, but already stored
Error code: 45 47 24 02 00 00 01 28 5E 15 34 4A 87 05 A4 0B 47 30 25 70
44E2 44E2 Generator
Error counter: 2
1. Umweltsatz Mileage 193256 km
Engine speed 744.72 1/min
coolant temperature 18.00 °C
Rail pressure Actual 362.35 bar
Injection quantity 14.97 mg/Hub
Air mass per cylinder 535.64 mg/Hub
Charge pressure Actualwert 1014.15 mbar
Battery Voltage 11730.69 mV
Vehicle speed 0.00 km/h
Environment pressure 1004.30 mbar
2. Umweltsatz Mileage 193256 km
Engine speed 661.98 1/min
coolant temperature 71.21 °C
Injection quantity 7.48 mg/Hub
Air mass per cylinder 485.22 mg/Hub
Battery Voltage 11567.77 mV
keine Kommunikation ueber BSD-Schnittstelle
Test conditions not yet fulfilled
Error code: 44 E2 14 06 00 00 02 28 5E 5D 1B 44 2E 26 55 67 00 48 00 66 5E 5D 18 79 27 13 4D 67 00 47 0
Pierwszy błąd został zarejestrowany przy napięciu 17,43V - wygląda to na zepsuty regulator napięcia. Poobserwuj sobie INPĄ napięcie przy włączonym silniku, jeśli zdarza się mu przekroczyć ~14,5 V to regulator do wymiany.
Rozumiem, że mowa jest o regulatorze napięcia przy alternatorze, tak?
Czy da się to wymienić samemu? :) Co z resztą tych błędów? Może też zostały spowodowane przez skoki napięcia?
Wielka filozofia to to nie jest. Jak masz kanał/podnośnik to powinieneś dać sobie radę. Trzeba zdemontować alternator. Te błędy mogą być spowodowane skokami napięcia. Jeśli rzeczywiście regulator wariuje to go wymień, skasuj błędy i obserwuj czy coś nowego się pojawiło.
  • 3 lata później...
szkoda że nie napisał czy uporał się z tym błędem :mad2:
