kusztek
  1. Moja jest w manualu...... może dlatego różnica w spalaniu (ogólnie dziennie robię 80 km z czego tylko 20% w mieście)
  2. TABELA: Sterownik - Dana Funkcja - Wykonanie - Wyjaśnienie BLOK I - BLOK II - BLOK III - BLOK IV CAPPL - ACOUSTIK - aktiv - Alarm sound when unlocking/locking the vehicle (Off by default on UK model, also off on almost all models in EU) CAPPL - AMBANDS - nicht_aktiv - Skip AM band on entertainment source selection. Must also set "NEXT_SOURCE" to aktiv CAPPL - HUD_M - aktiv - M5 HUD - shows RPM bar and current gear (all three needs to be enabled for Mview to work in HUD settings) CAPPL - MDrive - aktiv - M5 HUD - shows RPM bar and current gear (all three needs to be enabled for Mview to work in HUD settings) CAPPL - VA_SEATCLIMA_SHORTCUT - aktiv - Seat heater display comes up in iDrive when heat button pushed CAPPL - VA_SEATHEAT_SLIDER - aktiv - Seat heat hi-med-low slider in iDrive CAPPL - VA_WELCOMELIGHT - aktiv - Welcome lights in lights menu (needs LMA2), linked with WELCOME_LIGHT in LMA CAPPL - VIDEO_DENY_COB - deny_never - Enable TV/video functions while driving CAPPL/MASK - LEGAL_DISCL - nicht_aktiv - No legal notice on iDrive startup (US models) CAS - ER_KEYOUT_AUTOVR - aktiv - Unlock door(s) after pressing Stop Button CAS - KOMFORTSCHLIESSUNG_FB - aktiv - Close windows via key FOB CAS - KOMFORT_EJECT - aktiv - Eject key fob after holding Stop Button, and unlock door(s) when linked w/ ER_KEYOUT_AUTOVR CAS - KOMFORTOEFFNEN_FB_O_SHD - nicht_aktiv - Windows open with key fob but sunroof remains closed HUD - BLINKER_AUSSTATTUNG - aktiv - Turn signals in HUD HUD - M_SPORT_HUD - aktiv - M5 HUD - shows RPM bar and current gear (all three needs to be enabled for Mview to work in HUD settings) IHKA - ABWAHL_AC - nicht_aktiv - Pressing "AUTO" on the climate control does not turn on the AC IHKA - GEBL_ANZEIGE_AUTO - aktiv - Climate fan speed display via orange light around manual speed knob even in automatic climate mode KBM - SCHEINW_REINIGUNGS_AUTOM - nicht_aktiv - Automatic headlamp cleaning KGM - ASP_BORDSTEIN - aktiv - Passenger mirror kerb function (needs SA430) - Sept. '05 onwards KGM - ASP_BEIKLAPPEN - aktiv - Must be turn on for US model (provided the mirror has folding motor) KGM - BEIKLAPPEN_B_KOMFORTSCHL - aktiv - Comfort folding mirrors (Needs SA430) - 09/'05 onwards (hold close button on key FOB to fold mirrors) KOMBI - BC_DIGITAL_V - aktiv - Digital speedometer in cluster KOMBI - BC_DIGITAL_V_KORREKTUR - nicht_aktiv - nicht_aktiv=True car speed in digital speedometer (removes the standard circa +5mph safety feature for radars) KOMBI - BC_V_KORREKTUR - nicht_aktiv - nicht_aktiv=True car speed on analogue meter and HUD (removes the standard circa +5mph safety feature for radars) LMA - FL_UND_NSW_NICHT_GLEICHZ - nicht_aktiv - Allow high beam and fog lamps on at same time LMA - HEIMLEUCHTEN_FUNKSCHL - aktiv - Enable Pathway Lighting function on key fob (quick press on trunk release button) LMA [LM2] - WELCOME_LIGHT_ACTIVE - aktiv - Welcome lights function (needs LMA2), linked with VA_WELCOMELIGHT in CAPPL (WELCOMELIGHT in MASK) LMA [LM2] - TAGFAHRLICHT_ECE - aktiv - Enable DRL (the same as on/off menu if available from iDrive) LMA [LM2] - VERHALTEN_DRL_TFL_33 - drl_s - Select the AE as the DRL (default to drl_h for US model), linked with DRL_TFL_SML_33 LMA [LM2] - DRL_TFL_SML_33 - aktiv - Enable the AE as the DRL after switching VERHALTEN_DRL_TFL_33 -> drl_s - (LM2) LMA [LM2] - BI_XENON_BEI_LH - aktiv - Flash to pass with bi-xenons instead of halogens LMA [LM2] - PWM_AN_SL_V_AL_1_34 - wert_01 - Make LCI AE brightness to stick to high all the time. MASK - WEATHERBAND - nicht_aktiv - Removes Weatherband from entertainment source selection MASK - WELCOMELIGHT - aktiv - Welcome lights in lights menu (needs LMA2), linked with WELCOME_LIGHT in LMA PDC - MELDUNG_TASTER - aktiv - Creates a tone when PDC button pressed PDC - PDC_AKTIV/DEAKTIV - rueckwaertsgang - PDC comes on in reverse and turns off when leaving reverse TCUM - RINGTONE - 3 settings - Changes incoming call ringtone. TCUM - E-CALL_HARDKEY_FITTED - nicht_aktiv - Eliminates the SOS malfunction error in iDrive. Note: The SOS functionality is no longer operable from the hardkey.
  3. ......Czy w serwisie jak podam nr vin to od tak podadzą mi historię serwisową ?? ( do tej pory przy sprawdzaniu aut kolega mi pomagał - ale to nie bylo bmw :) ) CZego się obawiać w tym modelu, czy warto iść w model z przed liftu ??? ( skolej tych po lifcie ciężko znaleźć ) ( już przerobiłem temat o plastikowej zębatce tylnego dyfru ) jakie jeszcze przypadłości mogą spotkać ten model ???..... Witaj, jeżeli masz ochotę to mogę Ci trochę opisać E90 330 xd jeżdżę takim dość długo..... Co do tego co opisałeś to muszę Cię zmartwić tam już nie ma plastikowej zębatki (ślimacznicy) - tylko stalowa (wytrzymuję) ale za to ślimak już nie (pomimo tego też jest ze stali), ciężko go zdobyć, serwis (1800,- w komplecie z silniczkiem) udało mi się zdobyć kilka sztuk (samego ślimaka). Jak będzie trzeba to pomogę. - Autko super, jak w MP to jeszcze lepiej, aczkolwiek trochę twarde i na naszych drogach komfort jest słaby. - Spalanie to 10 l jak byś nie jeździł. - Uważaj na opony to największa przyczyna problemów xdrive... - W zimę rewelacja, aż chce się w góry jeździć i nie trzeba łańcuchów itp. - W twoim regionie może zawitać rdza w tylnej części podwozia (nawet gdy auto nie było nigdy naprawiane), lepie się trochę na to przygotować i zabezpieczyć przed, a nie po fakcie bo będzie za późno... Czytam te forum już od kilku miesięcy, można znaleźć dużo ciekawych rzeczy aczkolwiek o xdrive za wiele konkretnego nie znajdziesz i nie wiem czym to jest spowodowane (może się nie psuje :) ) Pozdro...
