buhaiul
Treść opublikowana przez buhaiul
  1. try using "Progman" for this! It;s very simple with graphic interface for key memory options you can recode ..
  2. thanks again for the info! Do you know, an ordinary battery charger will do the job ? and how it will be connected: to the battery contacts into the boot or under the hood on "+" socket with red cable and "-" to the chassis ?
  3. thanks everyone ! now everything it's clear ! I changed my old 314 BOSCH MAF with the new one (in fact a Pierburg 09 which everybody says is better the bosch 527) and the garage-guy remapped dde with new software, but I realized after the thing that the version number is the old-one still, he remapped only dde maps I think, he don't know nothing about the software version numbers according to bmw TIS Bulletin, so I want to do it my self ... I have power loss in warm weather or when engine gets very hot and I hope that's the cause !
  4. hmm.. 20 minutes.. my battery is 6 years old already; I'm a bit scared.. thanks @K3m0T1989 You mean : it takes 20 minutes after select in DIS the new software number to the end of programming , yes ? not all the the procedure (opening DIS, go to coding, enter the new number software.. and all the stuff) ?
  5. hello how long it takes to do adaptation on 320d M47 I changed the MAF (with the new model) I have DIS but I don't have a voltage charger Can I try without it? how many minutes it take to reencode DDE with the new number of software (operation is described very well in the beginning of the thread) Thanks!
  6. WBAAL71000KG46579 - prosze o rozkodowanie. Dziekuje i pozdrawiam.
  7. Please, decoding: WBAAL71000KG46579 Thanks in advance !
