GHOSSST
Treść opublikowana przez GHOSSST
  1. Witam! Chciałbym żebyście mi pomogli ocenić ogłoszenie. Planuję kupić BMW e90, po lifcie. Mam jedno ogłoszenie które mnie zaciekawiło http://otomoto.pl/bmw-320-m-pakiet-xenon-prefessional-f-vat-23-C35089943.html Mieszkam w Mińsku Mazowieckim a autko z Krakowa ;) nie chcę jechać na darmo
  2. Witam!! Bardzo proszę o pomoc. Nie wiem co robię źle. Załączam screeny oraz plik edibas.ini http://img829.imageshack.us/gal.php?g=ustawieniasieci.png ;============================================================================= ;EDIABAS 6.4.7 Configuration [Configuration] ;============================================================================= ;----------------------------------------------------------------------------- ; EcuPath ; Description : ECU file path ; Default = . EcuPath =C:\EDIABAS\ECU ;----------------------------------------------------------------------------- ; SimulationPath ; Description : Simulation file path ; Default = . SimulationPath =C:\EDIABAS\SIMULATION ;----------------------------------------------------------------------------- ; TracePath ; Description : Trace file path ; Default = . TracePath =C:\EDIABAS\TRACE ;----------------------------------------------------------------------------- ; CodeMapping ; Description : Character mapping file path ; Default = . ;CodeMapping = C:\EDIABAS\BIN\ansi2oem.tab ;----------------------------------------------------------------------------- ; TraceSize ; Description : Maximum size of each trace file [KB] ; Value : 0..32767 ; Default = 1024 TraceSize = 32767 ;----------------------------------------------------------------------------- ; ApiTrace ; Description : Enable/Disable API/User trace ; Value : 0 = Trace disabled ; 1 = User trace ; 2 = User trace + time stamp ; 3 = User trace + time stamp + process id (Win32) ; 4 = Function trace ; 5 = Function trace + time stamp ; 6 = Function trace + time stamp + timing ; 7 = Function trace + time stamp + timing + process id (Win32) ; Default = 0 ApiTrace =0 ;----------------------------------------------------------------------------- ; IfhTrace ; Description : Enable/Disable IFH trace ; Value : 0 = Trace disabled ; 1 = User trace ; 2 = User trace + interface ; 3 = User trace + interface + time stamp ; Default = 0 IfhTrace =0 ;----------------------------------------------------------------------------- ; IfhnTrace ; Description : Enable/Disable IFH network trace (with XREMOTE) ; Value : 0 = Trace disabled ; 1 = User trace ; 2 = User trace + interface ; 3 = User trace + interface + time stamp ; Default = 0 ;IfhnTrace = 0 ;----------------------------------------------------------------------------- ; SystemTraceSys ; Description : Enable/Disable system trace (runtime system) ; Value : 0 = Trace disabled ; Trace levels 1..7 ; Default = 0 SystemTraceSys = 0 ;----------------------------------------------------------------------------- ; SystemTraceBip ; Description : Enable/Disable BIP trace (runtime system) ; Value : 0 = Trace disabled ; Trace levels 1..7 ; Default = 0 SystemTraceBip = 0 ;----------------------------------------------------------------------------- ; SystemTraceIfh ; Description : Enable/Disable IFH system trace ; Value : 0 = Trace disabled ; Trace levels 1..7 ; Default = 0 SystemTraceIfh = 0 ;----------------------------------------------------------------------------- ; SystemTraceNet ; Description : Enable/Disable network trace ; Value : 0 = Trace disabled ; Trace levels 1..7 ; Default = 0 SystemTraceNet = 0 ;----------------------------------------------------------------------------- ; BipDebugLevel ; Description : BIP debug level of ECU files ; Value : 0..32767 ; Default = 0 BipDebugLevel = 0 ;----------------------------------------------------------------------------- ; UbattHandling ; Description : Ubatt ON/OFF handling ; Value : 0 = Ubatt ON/OFF: No EDIABAS error ; 1 = Ubatt ON/OFF: EDIABAS error ; Default = 1 UbattHandling = 0 ;----------------------------------------------------------------------------- ; IgnitionHandling ; Description : Ignition ON/OFF handling ; Value : 0 = Ignition ON/OFF: No EDIABAS error ; 1 = Ignition ON/OFF: EDIABAS error ; Default = 1 IgnitionHandling = 0 ;----------------------------------------------------------------------------- ; ClampHandling ; Description : automatic check of clamps for Ubatt and Ignition ; Value : 0 = no automatic clamp check with send_and_receive ; 1 = automatic clamp check with send_and_receive ; Default = 1 ;ClampHandling = 1 ;----------------------------------------------------------------------------- ; TaskPriority ; Description : EDIABAS process/thread priority (only Win32/16) ; Value : 0 = Optimal EDIABAS performance = 8 ; 1 = Minimal EDIABAS performance ; .. ; 10 = Maximal EDIABAS performance ; Default = 0 TaskPriority = 0 ;----------------------------------------------------------------------------- ; LoadWin32 ; Description : Map EDIABAS Win16 calls to EDIABAS Win32 ; Value : 0 = Win16/32 Mapping disabled (Win16-->Win16) ; 1 = Win16/32 Mapping enabled (Win16-->Win32) ; Default = 0 for Windows 9x/Me ; Default = 1 for Windows NT4/2000/XP ;LoadWin32 = 0 ;----------------------------------------------------------------------------- ; SystemResults ; Description : Enable/Disable system results (ubatt/ignition/jobstatus) ; Value : 0 = Disable system results ; 1 = Enable system results ; Default = 1 SystemResults = 1 ;----------------------------------------------------------------------------- ; RetryComm ; Description : Repeat failed communication automatically (1x) ; Value : 0 = Retry disabled ; 1 = Retry enabled (1x) ; Default = 1 RetryComm = 1 ;----------------------------------------------------------------------------- ; Simulation ; Description : Enable/Disable ECU simulation ; Value : 0 = Simulation disabled ; 1 = Simulation enabled ; Default = 0 Simulation = 0 ;----------------------------------------------------------------------------- ; Interface ; Description : Connected diagnosis interface ; Default = STD:OBD Interface =STD:OBD ; Additional information (in German) : ; Bitte beachten: Der HW-Treiber fuer das Interface muss installiert sein! ; Interface = STD:OBD ; Beschreibung : Serieller Pegelwandler (Nachfolger von ADS / Anschluss an OBD-Dose) ; Installation : \EDIABAS\HARDWARE\OBD\ODBSETUP (nur noetig fuer WIN NT4, WIN 2000, WIN XP) ; INI-Datei : Suchreihenfolge analog zu EDIABAS.ini ; Unterstuetzung : WIN3.xx : Nein ; WIN95,98 16-Bit : Ja ; WIN95,98 32-Bit : Ja ; WIN NT 4.0 : Ja ; WIN XP : Ja ; Interface = STD:FUNK ; Beschreibung : Funk-Diagnose Interface MDA von Fa. Siemens ; Installation : keine ; INI-Datei : FUNK.INI ; Unterstuetzung : WIN95,98 16-Bit : Ja ; WIN95,98 32-Bit : Ja ; WIN NT 4.0 : Ja ; WIN XP : Ja ; Interface = ADS ; Beschreibung : Serieller Pegelwandler (Anschluss an Diagnose-Dose) ; Installation : \EDIABAS\HARDWARE\ADS\ADS32\ADSSETUP (nur fuer WinNT4 noetig) ; INI-Datei : keine ; Unterstuetzung : WIN95,98 16-Bit : Ja ; WIN95,98 32-Bit : Nein ; WIN NT 4.0 : Ja ; WIN XP : Ja ; Interface = KBUS ; Beschreibung : Serieller Pegelwandler (Anschluss direkt an K-Bus oder I-Bus) ; Installation : \EDIABAS\HARDWARE\ADS\ADS32\ADSSETUP (nur fuer WinNT4 noetig) ; INI-Datei : keine ; Unterstuetzung : WIN95,98 16-Bit : Ja ; WIN95,98 32-Bit : Nein ; WIN NT 4.0 : Ja ; WIN XP : Ja ; Interface = EDIC ; Beschreibung : Serielles , PCMCIA , PC-Card Interface von Fa. Softing ; Installation : \EDIABAS\HARDWARE\EDIC\SETUP.EXE ; INI-Datei : EDICFW.INI, EDICHW.INI ; Unterstuetzung : WIN95,98 16-Bit : Ja ; WIN95,98 32-Bit : Ja ; WIN NT 4.0 : Ja ; WIN XP : Ja ; Interface = EDICC ; Beschreibung : EDIC-Card C oder EDIC-Card 2 CAN-Interface von Fa. Softing ; Installation : \EDIABAS\HARDWARE\EDIC\SETUP.EXE ; INI-Datei : XEDICC.INI ; Unterstuetzung : WIN95,98 16-Bit : Ja ; WIN95,98 32-Bit : Ja ; WIN NT 4.0 : Ja ; WIN XP : Ja ; Interface = STD:CAN ; Beschreibung : PCMCIA CAN-Interface CanCardX/XL von Fa. Vector ; Installation : keine (ausser Installation der CAN-Karte) ; INI-Datei : CAN32.INI ; Unterstuetzung : WIN95,98 16-Bit : Nein ; WIN95,98 32-Bit : Nein ; WIN NT 4.0 : Ja ; WIN XP : Ja ; Ansprechpartner: Hr. Jusko ; Telefon : +49-(0)89/382-35891 (Hotline) ; email : [email protected] (Hotline) ; Interface = STD:ADS4MOST ; Beschreibung : Most-Interfaces von Fa. Oasis ; Installation : keine (ausser Installation der Oasis-Karte) ; INI-Datei : ADS4MOST.INI ; Unterstuetzung : WIN95,98 16-Bit : ? ; WIN95,98 32-Bit : ? ; WIN NT 4.0 : Ja ; WIN XP : Ja ; Ansprechpart.: Hr. Rowedder ; Telefon : 089 / 382-29159 ; email : [email protected] ; Interface = REMOTE ; Beschreibung : Anbindung eines EDIABAS-Interfaces über TCP/IP ; Installation : Anpassung der Einträge in [TCP] auf beiden Seiten (ins.: RemoteHost, Port) ; INI-Datei : keine ; Unterstuetzung : WIN95,98 16-Bit : Nein ; WIN95,98 32-Bit : Ja ; WIN NT 4.0, XP : Ja ; WIN XP : Ja ; Sonderfall : Interface OPPS ; Ansprechpart.: Hr. Rowedder ; Telefon : 089 / 382-29159 ; email : [email protected] ; Interface = REMOTE:name ; Beschreibung : Anbindung eines EDIABAS-Interfaces über TCP/IP ; Installation : Anpassung der Einträge in [TCP] auf beiden Seiten (ins.: RemoteHost, Port) ; INI-Datei : REMOTE.INI (insbesondere für Parallelbetrieb notwendig) ; In REMOTE.INI stehen unter [name] spezif. Einstellungen(z.B.: RemoteHost, Port) ; Unterstuetzung : WIN95,98 16-Bit : Nein ; WIN95,98 32-Bit : Ja ; WIN NT 4.0, XP : Ja ; WIN XP : Ja ; Sonderfall : Interface OPPS ; Ansprechpart.: Hr. Rowedder ; Telefon : 089 / 382-29159 ; email : [email protected] ;----------------------------------------------------------------------------- ; NetworkProtocol ; Description : Network protocol ; Default = NetworkProtocol = TCP ;============================================================================= ;TCP/IP Configuration [TCP] ;============================================================================= ;----------------------------------------------------------------------------- ; RemoteHost ; Description : server address/name ; Default = RemoteHost =192.168.68.30 ;----------------------------------------------------------------------------- ; Port ; Description : IP communication port ; Value : 1000 < port < 30000 ; Default = Port = 6801 ;----------------------------------------------------------------------------- ;TimeoutConnect ; Description : Timeout for establishing the connection ; Default = 5000 TimeoutConnect = 2000 ;----------------------------------------------------------------------------- ;TimeoutReceive ; Description : Timeout for receiving a message ; Default = 5000 TimeoutReceive = 2000 ;----------------------------------------------------------------------------- ;TimeoutFunction ; Description : Timeout for a long function ; Default = 59000 TimeoutFunction = 10000 ;----------------------------------------------------------------------------- ;DisconnectOnApiEnd ; Description : Enable/Disable Disconnection with function call ApiEnd ; Value : 0 = Disconnection disabled ; 1 = Disconnection enabled ; Default = 0 ;DisconnectOnApiEnd = 1 ;----------------------------------------------------------------------------- ;InitCmd ; Description : Initialization command (normally for OPPS) ; Default = ;InitCmd0 = FE,04,00,03,01 ;InitCmd1 = FD,05,00,03,01 ;============================================================================= ; End Of File EDIABAS.ini ;============================================================================= [XEDIC] EdicApiPath= C:\EDIABAS\EDIC\EIDBSS EdicInterfaceNo= 2
