zoom
  1. Hello, a little late with an answer, but nevertheless I was able to get the SSS to work with the help of tomaszf. Everything is working correctly and I was able to code my car to automatically close the door after drive out (which is a pretty annoying feature btw :)). Some pictures from the SSS session are here: http://www.abload.de/thumb/sss_01fm93.png http://www.abload.de/thumb/sss_02w7s5.png http://www.abload.de/thumb/sss_05ww7z.png Now I am off to learn to work with NCS Expert. Thanks so far.
  2. Hello, I am sorry to write in English, but I don't know Polish language. Should you answer this post and not delete it, you can reply in Polish language - I can comprehend it a little bit and translate the rest via Google. My problem is to get the SSS working in VMware. I will try to describe everything in detail. First a little background: I bought a used notebook with native COM port just for diagnostics purposes. I also bought an ADS interface from nerwus in this topic, which is operating fine. First I used the software from that topic and those great video tutorials to get myself familiarized with the whole DIS thing. At that time I had a working DIS in VMware 5.5 based on EasyDIS v44 and DiagHeadEmulator. Current situation: I wanted to try newer DIS. I was aware, that new DIS can't code the car and I will need an SSS station. I loaded up VMware 6.5 and installed DIS base v52 together with v55 UK update. This part seems to be operating fine. I haven't tried it yet on my car, but the DIS v55 system can find the diagnostic head and both graph bars ale fully lit as seen in next screenshot: http://www.abload.de/thumb/dis_170y4.png So far so good. Then I needed to install SSS (Progman) to be able to code the car. The problem: I used this extensive guide to install SSS/Progman. I used a modified base system v3.1 (with modified HWVER.DLL) and then installed Progman v28 and v32 (I tried both version on two different installs, of course). Everything went well, but I can't see the diagnostic head in settings (the DiagHeadEmulator and IFHServ are running). Here are couple of screenshots from my Progman install: http://www.abload.de/thumb/sss_1v4s5.png http://www.abload.de/thumb/sss_2y1g1.png http://www.abload.de/thumb/sss_3z5p3.png The second picture is the one where you are supposed to select interface. It's empty as you can see. I've been playing with this for the past two weeks, but I am unable to find a solution. Could anybody help me with this? Should you need more information about my setup or anything else, just ask. I really want to solve this, or else I will have to go back to VMware 5.5 and DIS v44 that is able to code a vehicle as well.
