ludiagsm
Treść opublikowana przez ludiagsm
  1. ludiagsm
    hi there
    Myślę, że mocy dostaniesz ile będziesz chciaŁ, popatrz na filmy z linków i zobaczysz doŁadowania od 1,4 - 2,3 bara. Jeśli to jest silnik bez modyfikacji, a patrząc na zaolejoną pokrywę zaworów myślę , że tak, to nie dojedzie do ZŁotych Piasków. :) Bacouse I am Bulgarian and i dont uderstand good your language but links from my signature is for my favorite project E36 318is turbo the project is here : http://www.m42club.com/forums/showthread.php?t=2404 pp: sorry for my bad einglish
  2. ludiagsm
    hi there
    Hi i did not make dino yet ,but i have another E 36 325 coupe with 3,45 diff, and E 316 m40 turbo is fastest. The CR is stock 9:1 and i did't make any serios modifications on engine. Before I start turbochargering he was in good condition (you know that problem with camshaft for now it is good) I change original termostate from the same type but with lower temperature from original 88C to 80C. The gears and diff are stock .I replace original clutch and flywheel with that kit : http://cgi.ebay.com/ebaymotors/SACHS-CLUTCH-FIDANZA-FLYWHEEL-BMW-318-325-328-M3-Z3_W0QQitemZ150198344372QQihZ005QQcategoryZ33730QQssPageNameZWDVWQQrdZ1QQcmdZViewItem turbocharger is IHI VF 34 ballbearing . I use SMT6 pigiback system with 3 bar(absolute pressure) mapsensor and four extra injectors for tune correct afr and adwance in boost. This days i must change the place for extrainjectors they will be mounted after the throttle direct on ports 150-200 milimeters behind original injectors. For now boost level is 0,7 bar and i did't have any problems with engine i have 750kilometers with 316i turbo fun :)
  3. ludiagsm
    hi there
    i so another m40 turbo projekt in your forum and i will be glad if we can discuss and help for our turbo beemers here is my last project E36 sedan 316_m40-turbo http://img101.imageshack.us/img101/3940/12122007565eu1.th.jpg http://img101.imageshack.us/img101/4306/12122007558vs3.th.jpg http://img184.imageshack.us/img184/2656/17122007572qz9.th.jpg http://img101.imageshack.us/img101/5541/10122007555na3.th.jpg http://img184.imageshack.us/img184/3430/15122007567oj7.th.jpg http://img524.imageshack.us/img524/1561/12122007562ic7.th.jpg http://img524.imageshack.us/img524/4845/12122007563bk9.th.jpg http://img175.imageshack.us/img175/8576/24122007vl1.th.jpg http://img301.imageshack.us/img301/1023/24122007002yn9.th.jpg http://img167.imageshack.us/img167/2016/24122007001jp5.th.jpg
