MkI : Watch TV / Videotext during driving This works on all 5/7 Series with the Mark I Navigation System (the one with the male voice). On Mark II (the newer version with the female voice) you have to use "brightness" instead of contrast for TV and "color" instead of brightness for videotext to get the trick to work. This works on the latest 99 7-series models as well. This does not appear to work for the latest BMWs sold in Europe (2000 onward, 3/5/7 series). The software updates for latest navigation CD-ROM's do not appear to affect or disable this trick. 1. set ignition to pos. II (przekręć kluczyk na pozycję II) 2. enter TV mode (włącz TV) 3. enter "settings" (przyciśnij przycisk ustawienia) 4. enter "contrast" (włącz kontrast) 5. when the green contrast bar is visible, push the knob and keep it pressed (kiedy widoczny jest zielony pasek kontrastu , wcisnij guzik (pokretlo) i trzymaj wcisniete) 6. turn ignition off (keep button pressed!) (przekrec zaplon aby go wyłączyć (dalej trzymajac wciniety przycisk)) 7. wait 8-10 seconds (timing must be accurate!) (czekaj 8-10 sekund (musisz dokladnie przypilnowac tego czasu)) 8. release the knob (pusc galke (przycisk) 9. turn on ignition again (teraz wszstko będzie już gotowe) Now the TV will operate while the car is in motion, though you certainly should leave that to your passengers only while driving. To watch videotext use the same procedure as above, but choose "brightness" instead of "contrast" Jeżeli to Ci nie działa to spróbuj dla mkII http://www.tv-free.de/anleit/tv_free.pdf Zamiast contrast dajemy britness... skopiowano z www.bmw7.pl
