E83 interpretacja dolegliwości
Palą się kontrolki 4x4, recznego, oraz abs. Domyślam sie że xdrive padł ale zanim zlece wymianę skrzyni rozdzielczej chciałbym upewnić się czy czasami wina nie lezy po stronie elektroniki sterującej. Inpa wskazała takie o to błedy :
E R R O R M E M O R Y
Date: 16.10.2011 13:59:11
ECU: DXC8
JobStatus: OKAY
Variant: DXC8
RESULT: 3 error in error memory !
5F39 5f39 - clutch gearbox-ECU: VG-clutch defekt - clutch position unknown.
Error counter: 255
Logistic counter: 39
Mileage 178460 km
Fahrzeuggeschwindigkeit 0.00 km/h
ACB 0.00 0/1
HBA 0.00 0/1
ECD 0.00 0/1
HDC 0.00 0/1
DSC 0.00 0/1
ABS 0.00 0/1
BLS 0.00 0/1
ASC 0.00 0/1
No matching error symptom
Test conditions fulfilled
Error not present now, but already stored
Error would cause a warning lamp to light up
Error code: 5F 39 A0 FF 27 45 B6 00 00 00
5F1E 5f1e - variant code: Info : Trailer_Oscillation_Logic on EEPROM deactivated.
Error counter: 255
Logistic counter: 40
Mileage 178460 km
ACB 0.00 0/1
HBA 0.00 0/1
ECD 0.00 0/1
HDC 0.00 0/1
DSC 0.00 0/1
ABS 0.00 0/1
BLS 0.00 0/1
ASC 0.00 0/1
Error present now and already stored
Error code: 5F 1E E0 FF 28 45 B6 00 00 00
5EB1 5eb1 - steering angle sensor: LWS - Signal relativ. steering wheel central position unidentified. learning quadrant.
Error counter: 26
Logistic counter: 28
Mileage 190860 km
ACB 0.00 0/1
HBA 0.00 0/1
ECD 0.00 0/1
HDC 0.00 0/1
DSC 0.00 0/1
ABS 0.00 0/1
BLS 0.00 0/1
ASC 0.00 0/1
Error code: 5E B1 A0 1A 1C 4A 8E 00 00 00
Date: 16.10.2011 14:11:42
ECU: VGSG83
JobStatus: OKAY
Variant: VGSG83
RESULT: 2 error in error memory !
539E 539E Function error VTG hole system
Error counter: 255
1. Umweltsatz
Mileage 178456 km
Input voltage KL30 14.00 Volt
KL15 State CAN CAN Signal OK -- KL15 on 0-n
KL15 internal KL15 on 0-n
Engine speed CAN Signal OK -- VKM on 0-n
Reset-Source NO RESET 0-n
iSM 0.00 Ampere
BarrierActPosLim 0.00 Nm
error counter calibration try 0.00 1
BarrierError 3.00 1
BarrierMainState 255.00 1
error counter timeout 0.00 1
2. Umweltsatz
Mileage 199064 km
Input voltage KL30 11.75 Volt
Engine speed CAN Signal OK -- VKM off 0-n
iSM 0.00 Ampere
BarrierError 3.00 1
Implausible signal or value
Test conditions not yet fulfilled
Error would not cause a warning lamp to light up
Error code: 53 9E 38 FF 28 57 23 70 ED 00 00 00 03 FF 00 61
33 5E E5 00 00 00 03 FF 00
55C4 55C4 CAN_MESSAGE_DSC1
Error counter: 1
Logistic counter: 30
Mileage 199024 km
Input voltage KL30 13.88 Volt
MKINDEX 0.00 Nm
deltaPhiBarrierCal 0.00 degrees
BarrierError 0.00 1
BarrierMainState 80.00 1
DSC1_error_signals DSC1_MK_SOLL 0-n
Error code: 55 C4 28 01 1E 61 2E 6F ED 00 00 00 00 50 01 00
00 00 00 00 00 00 00 00 00
wykazuj wszystkie błędy, zrób parę kilometrów i sprawdź co pokaże się znowu.
steering angle sensor: LWS - wydaje mi się że gdzieś w inpie albo carsofcie widziałem możliwość adaptacji tego...
reszty nie kojarzę :)
