E87 - schemat pinów komputera
Czy ma ktoś może schemat pinów komputera do BMW E87, E90. Za co odpowiada jaki PIN ?
Tyle szczegółów napisałeś, że nie da się pomóc. Jaki silnik , rok. Tu musisz podać szczegóły skoro oczekujesz pomocy.
BMW 1 E87 118d 2.0 D 2007r 143km
BMW 3 E90 E91 2.0 D 2007r
oznaczenia komputera:
N47 BMW E87 118d SHA /
A2249 Digital diesel electronics control unit
Plug connector overview
X2411 96-pin, black Component connector Digital diesel electronics control unit
X2412 58-pin, black Component connector Digital diesel electronics control unit
Pin assignments at plug connector X2411
Pin Type Description /Signal type Connection /Measuring notes
1 -- Not used
2 -- Not used
3 A Voltage supply, fuel injector Injector 1
4 -- Not used
5 A Signal, swirl flap actuator Swirl flap actuator
6 M Ground, charge air temperature sensor Charge air temperature sensor
7 M Ground Coolant temperature sensor Coolant temperature sensor
8 E Signal Exhaust temperature sensor before particle filter Exhaust temperature sensor before particle filter
9 M Ground Exhaust temperature sensor before particle filter Exhaust temperature sensor before particle filter
10 E Signal, oil pressure switch Oil pressure switch
11 M Ground Fuel pressure/temperature sensor Fuel pressure/temperature sensor
12 M Ground Oxygen sensor before catalytic converter Oxygen sensor before catalytic converter
13 E Signal Position sensor, EGR valve Position sensor, EGR valve
14 M Ground Camshaft sensor Camshaft sensor
15 M Ground Crankshaft sensor Crankshaft sensor
16 E/A Signal, LIN bus Preheating control unit Preheating control unit
17 E Signal, intake air temperature Hot-film air mass meter
18 A Negative activation, oxygen sensor heating Oxygen sensor before catalytic converter
19 E Fuel pressure signal Fuel pressure/temperature sensor
20 E Activation, boost pressure actuator Boost pressure adjuster 1
21 -- Not used
22 A Negative activation Compressor bypass valve Compressor bypass valve Only on variant TOP
23 -- Not used
24 M Ground Hot-film air mass meter Hot-film air mass meter
25 -- Not used
26 -- Not used
27 A Voltage supply, fuel injector Injector 2
28 -- Not used
29 A Signal, swirl flap actuator Swirl flap actuator
30 A Voltage supply, rail pressure sensor Rail pressure sensor
31 A Voltage supply Position sensor, EGR valve Position sensor, EGR valve
32 A Voltage supply Boost pressure sensor Boost pressure sensor
33 A Supply Exhaust backpressure sensor Exhaust backpressure sensor
34 E Signal Exhaust temperature sensor before particle filter Exhaust temperature sensor before particle filter
35 M Ground Position sensor, EGR valve Position sensor, EGR valve
36 E Signal Oxygen sensor before catalytic converter Oxygen sensor before catalytic converter
37 -- Not used
38 E Signal, oil level sensor Oil level sensor
39 A Supply Crankshaft sensor Crankshaft sensor
40 -- Not used
41 -- Not used
42 -- Not used
43 E/A Signal Oil condition sensor Oil condition sensor with EU3 exhaust emission standard
44 A Activation, DDE relay DDE main relay
45 E Signal, hot film air mass meter Hot-film air mass meter
46 E Negative activation Wastegate valve Wastegate valve Only on variant TOP
47 A Negative activation Exhaust gas recirculation actuator 1 Exhaust gas recirculation actuator 1
48 A Activation, boost pressure actuator Boost pressure adjuster 1
48 A Activation Turbine control valve Turbine control valve Only on variant TOP
49 M Ground, fuel injector Injector 2
50 M Ground, fuel injector Injector 4
51 A Voltage supply, fuel injector Injector 3
52 -- Not used
53 -- Not used
54 M Ground Exhaust backpressure sensor Exhaust backpressure sensor
55 E/A Signal, LIN bus Oil level sensor with exhaust emission standard EU5/EU6
56 E Signal, rail pressure sensor Rail pressure sensor
57 E Signal, fuel temperature Fuel pressure/temperature sensor
58 A Voltage supply Exhaust temperature sensor before particle filter Exhaust temperature sensor before particle filter
59 E Signal Exhaust backpressure sensor Exhaust backpressure sensor
60 E Signal Oxygen sensor before catalytic converter Oxygen sensor before catalytic converter
61 -- Not used
62 E Signal Camshaft sensor Camshaft sensor
63 -- Not used
64 -- Not used
65 -- Not used
66 -- Not used
67 -- Not used
68 E/A Bi-directional data interface Preheating control unit
69 E/A Bi-directional data interface Alternator
70 M Ground, preheating control unit Preheating control unit
71 A Signal, volume control valve Volume control valve
72 M Ground Volume control valve Volume control valve
73 M Ground, fuel injector Injector 1
74 M Ground, fuel injector Injector 3
75 A Voltage supply, fuel injector Injector 4
76 -- Not used
77 -- Not used
78 M Ground, rail pressure sensor Rail pressure sensor
79 -- Not used
80 M Ground Boost pressure sensor Boost pressure sensor
81 E Signal Boost pressure sensor Boost pressure sensor
82 E Signal, coolant temperature Coolant temperature sensor
83 E Signal, charge air temperature Charge air temperature sensor
84 E Signal Oxygen sensor before catalytic converter Oxygen sensor before catalytic converter
85 -- Not used
86 M Ground Oil condition sensor Oil condition sensor with EU3 exhaust emission standard
86 M Ground Oil level sensor Oil level sensor with exhaust emission standard EU5/EU6
87 E Signal Crankshaft sensor Crankshaft sensor
88 A Voltage supply Fuel pressure/temperature sensor Fuel pressure/temperature sensor
89 M Ground Swirl flap actuator Swirl flap actuator
90 E/A Signal, swirl flap actuator Swirl flap actuator
91 -- Not used
92 A Voltage supply Swirl flap actuator Swirl flap actuator
93 A Signal Turbine control valve Boost pressure adjuster 1
94 A Signal Throttle valve Throttle valve
95 A Negative activation Solenoid valve, exhaust recirculation cooler bypass Solenoid valve, exhaust recirculation cooler bypass Only on variant upper power stage
96 M Ground Rail pressure control valve Rail pressure control valve
Pin assignments at plug connector X2412
1 E Supply, DDE control unit Fuse F03
2 M Earth for DDE control unit Ground point
3 E Supply, DDE control unit Fuse F03
4 M Earth for DDE control unit Ground point
5 E Supply, DDE control unit Fuse F03
6 M Earth for DDE control unit Ground point
7 E Wake-up signal, terminal 15 Connector , terminal 15 wake-up signal
8 -- Not used
9 -- Not used
10 E/A Bus signal Car access system
11 -- Not used
12 -- Not used
13 E Ground Brake vacuum sensor Brake vacuum sensor Only on variant MSA
14 E/A Bi-directional data interface Battery sensor
15 -- Not used
16 A Signal, fuel temperature Fuel heater
17 A Supply Neutral sensor Neutral sensor Only on variant MSA
18 -- Ground Neutral sensor Neutral sensor Only on variant MSA
19 A Negative activation Heating, crankcase breather Heating, crankcase breather
20 -- Not used
21 -- Not used
22 E Signal Neutral sensor Neutral sensor Only on variant MSA
23 E Brake light test signal Brake light switch
24 -- Not used
25 -- Not used
26 -- Not used
27 -- Not used
28 -- Not used
29 M Ground Accelerator pedal module Accelerator pedal module
30 M Ground Accelerator pedal module Accelerator pedal module
31 -- Not used
32 E Signal, electronic vehicle immobilizer Car access system
33 E/A Signal PT-CAN low CAN-bus connector
34 E Start signal Car access system
35 -- Not used
36 E Brake light signal Brake light switch
37 -- Not used
38 -- Not used
39 E Signal Accelerator pedal module Accelerator pedal module
40 A Signal, electric fan Electric fan
41 A Supply Brake vacuum sensor Brake vacuum sensor Only on variant MSA
42 -- Not used
43 A Supply Accelerator pedal module Accelerator pedal module
44 A Signal Electric auxiliary heater Junction box, electronics
45 -- Not used
46 E/A Signal PT-CAN high CAN-bus connector
47 E Signal Brake vacuum sensor Brake vacuum sensor Only on variant MSA
48 -- Not used
49 -- Not used
50 E Signal, clutch switch Clutch switch module
51 -- Not used
52 E Signal Accelerator pedal module Accelerator pedal module
53 A Speed signal OBDII socket
54 -- Not used
55 -- Not used
56 A Supply Accelerator pedal module Accelerator pedal module
57 -- Not used
58 -- Not used
Dziękuję dobry człowieku !
Miej dzisiaj wspaniały dzień
