Inpa błąd requested control unit:'MS430D0' not found
witam
auto e39 525i 2002r.
inpa 10004 ediabas 647
kabel viaken usb
obd.ini oraz kabel ustawione na com2
podczas próby połączenia z silnikiem i innymi modulami wyskakuje błąd
IFH-0009: no response from control unit
ogolnie wszystkie foldery typu ecu czy cfgdat mam zapelnione
pomoże ktoś
;EDIABAS 6.4.7 Configuration
[Configuration]
; EcuPath
;       Description :   ECU file path
;       Default     =   .
EcuPath          =C:\EDIABAS\ECU
; SimulationPath
;       Description :   Simulation file path
;       Default     =   .
SimulationPath   =C:\EDIABAS\SIMULATION
; TracePath
;       Description :   Trace file path
;       Default     =   .
TracePath        =C:\EDIABAS\TRACE
; CodeMapping
;       Description :   Character mapping file path
;       Default     =   .
;CodeMapping      = C:\EDIABAS\BIN\ansi2oem.tab
; TraceSize
;       Description :   Maximum size of each trace file [KB]
;       Value       :   0..32767
;       Default     =   1024
TraceSize        = 32767
; ApiTrace
;       Description :   Enable/Disable API/User trace
;       Value       :   0  = Trace disabled
;                       1  = User trace
;                       2  = User trace + time stamp
;                       3  = User trace + time stamp + process id (Win32)
;                       4  = Function trace
;                       5  = Function trace + time stamp
;                       6  = Function trace + time stamp + timing
;                       7  = Function trace + time stamp + timing + process id (Win32)
;       Default     =   0
ApiTrace         =0
; IfhTrace
;       Description :   Enable/Disable IFH trace
;                       1  = User trace
;                       2  = User trace + interface
;                       3  = User trace + interface + time stamp
;       Default     =   0
IfhTrace         =0
; IfhnTrace
;       Description :   Enable/Disable IFH network trace (with XREMOTE)
;                       1  = User trace
;       Default     =   0
;IfhnTrace        = 0
; SystemTraceSys
;       Description :   Enable/Disable system trace (runtime system)
;                       Trace levels 1..7
;       Default     =   0
SystemTraceSys   = 0
; SystemTraceBip
;       Description :   Enable/Disable BIP trace (runtime system)
;                       Trace levels 1..7
;       Default     =   0
SystemTraceBip   = 0
; SystemTraceIfh
;       Description :   Enable/Disable IFH system trace
;                       Trace levels 1..7
;       Default     =   0
SystemTraceIfh   = 0
; SystemTraceNet
;       Description :   Enable/Disable network trace
;                       Trace levels 1..7
;       Default     =   0
SystemTraceNet   = 0
; BipDebugLevel
;       Description :   BIP debug level of ECU files
;       Value       :   0..32767
;       Default     =   0
BipDebugLevel    = 0
; UbattHandling
;       Description :   Ubatt ON/OFF handling
;       Value       :   0  = Ubatt ON/OFF: No EDIABAS error
;                       1  = Ubatt ON/OFF: EDIABAS error
;       Default     =   1
UbattHandling    = 0
; IgnitionHandling
;       Description :   Ignition ON/OFF handling
;       Value       :   0  = Ignition ON/OFF: No EDIABAS error
;                       1  = Ignition ON/OFF: EDIABAS error
;       Default     =   1
IgnitionHandling = 0
; ClampHandling
;       Description :   automatic check of clamps for Ubatt and Ignition
;       Value       :   0  = no automatic clamp check with send_and_receive
;                       1  = automatic clamp check with send_and_receive
;       Default     =   1
;ClampHandling    = 1
; TaskPriority
;       Description :   EDIABAS process/thread priority (only Win32/16)
;       Value       :   0  = Optimal EDIABAS performance = 8
;                       1  = Minimal EDIABAS performance
;                       10 = Maximal EDIABAS performance
;       Default     =   0
TaskPriority     = 0
; LoadWin32
;       Description :   Map EDIABAS Win16 calls to EDIABAS Win32
;       Value       :   0  = Win16/32 Mapping disabled (Win16-->Win16)
;                       1  = Win16/32 Mapping enabled (Win16-->Win32)
;       Default     =   0 for Windows 9x/Me
;       Default     =   1 for Windows NT4/2000/XP
;LoadWin32        = 0
; SystemResults
;       Description :   Enable/Disable system results (ubatt/ignition/jobstatus)
;       Value       :   0  = Disable system results
;                       1  = Enable system results
;       Default     =   1
SystemResults    = 1
; RetryComm
;       Description :   Repeat failed communication automatically (1x)
;       Value       :   0  = Retry disabled
;                       1  = Retry enabled (1x)
;       Default     =   1
RetryComm        = 1
; Simulation
;       Description :   Enable/Disable ECU simulation
;       Value       :   0  = Simulation disabled
;                       1  = Simulation enabled
;       Default     =   0
Simulation       = 0
; Interface
;       Description :   Connected diagnosis interface
;       Default     =   STD:OBD
Interface        =STD:OBD
; Additional information (in German) :
; Bitte beachten: Der HW-Treiber fuer das Interface muss installiert sein!
; Interface      = STD:OBD
; Beschreibung   : Serieller Pegelwandler (Nachfolger von ADS / Anschluss an OBD-Dose)
; Installation   : \EDIABAS\HARDWARE\OBD\ODBSETUP (nur noetig fuer WIN NT4, WIN 2000, WIN XP)
; INI-Datei      : Suchreihenfolge analog zu EDIABAS.ini
; Unterstuetzung : WIN3.xx          : Nein
;                  WIN95,98  16-Bit : Ja
;                  WIN95,98  32-Bit : Ja
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Interface      = STD:FUNK
; Beschreibung   : Funk-Diagnose Interface MDA von Fa. Siemens
; Installation   : keine
; INI-Datei      : FUNK.INI
; Unterstuetzung : WIN95,98  16-Bit : Ja
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Interface      = ADS
; Beschreibung   : Serieller Pegelwandler (Anschluss an Diagnose-Dose)
; Installation   : \EDIABAS\HARDWARE\ADS\ADS32\ADSSETUP (nur fuer WinNT4 noetig)
; INI-Datei      : keine
;                  WIN95,98  32-Bit : Nein
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Interface      = KBUS
; Beschreibung   : Serieller Pegelwandler (Anschluss direkt an K-Bus oder I-Bus)
; INI-Datei      : keine
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Interface      = EDIC
; Beschreibung   : Serielles , PCMCIA , PC-Card Interface von Fa. Softing
; Installation   : \EDIABAS\HARDWARE\EDIC\SETUP.EXE
; INI-Datei      : EDICFW.INI, EDICHW.INI
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Interface      = EDICC
; Beschreibung   : EDIC-Card C oder EDIC-Card 2 CAN-Interface von Fa. Softing
; INI-Datei      : XEDICC.INI
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Interface      = STD:CAN
; Beschreibung   : PCMCIA CAN-Interface CanCardX/XL von Fa. Vector
; Installation   : keine (ausser Installation der CAN-Karte)
; INI-Datei      : CAN32.INI
; Unterstuetzung : WIN95,98  16-Bit : Nein
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Ansprechpartner: Hr. Jusko
;   Telefon      : +49-(0)89/382-35891  (Hotline)
;   email        : [email protected] (Hotline)
; Interface      = STD:ADS4MOST
; Beschreibung   : Most-Interfaces von Fa. Oasis
; Installation   : keine (ausser Installation der Oasis-Karte)
; INI-Datei      : ADS4MOST.INI
; Unterstuetzung : WIN95,98  16-Bit : ?
;                  WIN95,98  32-Bit : ?
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
;   Ansprechpart.: Hr. Rowedder
;   Telefon      : 089 / 382-29159
; Interface      = REMOTE
; Beschreibung   : Anbindung eines EDIABAS-Interfaces über TCP/IP
; Installation   : Anpassung der Einträge in [TCP] auf beiden Seiten (ins.: RemoteHost, Port)
; INI-Datei      : keine
;                  WIN NT 4.0, XP   : Ja
;                  WIN XP           : Ja
; Sonderfall     : Interface OPPS
; Interface      = REMOTE:name
; INI-Datei      : REMOTE.INI (insbesondere für Parallelbetrieb notwendig)
;                  In REMOTE.INI stehen unter [name] spezif. Einstellungen(z.B.: RemoteHost, Port)
;                  WIN XP           : Ja
; NetworkProtocol
;       Description :   Network protocol
;       Default     =
NetworkProtocol  = TCP
;TCP/IP Configuration
[TCP]
; RemoteHost
;       Description :   server address/name
;       Default     =
RemoteHost           = 192.168.68.30
; Port
;       Description :   IP communication port
;       Value       :   1000 < port < 30000
;       Default     =
Port                 = 6801
;TimeoutConnect
;       Description :   Timeout for establishing the connection
;       Default     =   5000
TimeoutConnect       = 2000
;TimeoutReceive
;       Description :   Timeout for receiving a message
;       Default     =   5000
TimeoutReceive       = 2000
;TimeoutFunction
;       Description :   Timeout for a long function
;       Default     =   59000
TimeoutFunction      = 10000
;DisconnectOnApiEnd
;       Description :   Enable/Disable Disconnection with function call ApiEnd
;       Value       :   0  = Disconnection disabled
;                       1  = Disconnection enabled
;       Default     =   0
;DisconnectOnApiEnd   = 1
;InitCmd<n>
;       Description :   Initialization command <n> (normally for OPPS)
;       Default     =
;InitCmd0             = FE,04,00,03,01
;InitCmd1             = FD,05,00,03,01
; End Of File EDIABAS.ini
[OBD]
Port=Com2
Hardware=USB
RETRY=ON
UBATT=OFF
;Tracelevel=0xFFFFFFFF
;Tracelevel=0xF0000000
;Tracelevel=0x0000FFFF
; Bit 0    = Funktionsaufruf
; Bit 1    = io Ergebnis
; Bit 2    = nio Ergebnis
; Bit 3    = Detailinfos
; Nibble 0 = readchar_wait
; Nibble 1 = main
; Nibble 2 = cmd
; Nibble 3 = obd
; Nibble 4 = send_and_receive_...
; Nibble 5 = read_telegram_...
; Nibble 6 = send_telegram
; Nibble 7 = SendData
[UNIT_A]
Port=Com2
Hardware=OBD
[UNIT_B]
Port=Com3
Hardware=OBD
[UNIT_C]
Port=Com4
Hardware=OBD
[UNIT_D]
Port=Com5
Hardware=OBD
[UNIT_E]
Port=Com6
Hardware=OBD
[UNIT_F]
Port=Com7
Hardware=OBD
[UNIT_G]
Port=Com8
Hardware=OBD
[UNIT_H]
Port=Com9
Hardware=OBD
[UNIT_I]
Port=Com10
Hardware=OBD
[UNIT_J]
Port=Com11
Hardware=OBD
[UNIT_K]
Port=Com12
Hardware=OBD
[UNIT_L]
Port=Com13
Hardware=OBD
[UNIT_M]
Port=Com14
Hardware=OBD
[UNIT_N]
Port=Com15
Hardware=OBD
[UNIT_O]
Port=Com16
Hardware=OBD
aktualnie obd.ini i ediabas.ini mam tak
da sie coś z tym zrobić, czy instalować inną inpe ?
Ma ktoś może jakąś sprawdzoną inpe, która będzie działać z kabelkiem viakena pod e39, e46 ?
czy to możne być przez kabel, na tych ustawieniach obd.ini bateria jest cały czas, a zapłon jest po przekręceniu kluczyka ?
próbuje się połączyć z silnikiem i taki błąd:
ifh-0009 no response from control unit. program will be stopped
kabel mam taki: http://allegro.pl/interfejs-bmw-e39-e46-e60-e90-usb-1996-06-inpa-pl-i4963380542.html
ustawiony zgodnie z instrukcją viakena, miedzy innymi na com 2
Połączyłam sie z e46 2000r ale tylko z silnikiem przez gniazdo pod kierownicą, ale tutaj zapłonu nie pokazało
Edytowane przez Haron1101
z e39 525i
palą się kontrolki abs asc i hamulca, chciałem się połączyć inpą w celu sprawdzenia błędów i za nic nie mogłem się połączyć nawet z silnikiem (ifh-0009 no response from control unit. program will be stopped). Po odłączeniu wtyczki od sterownika abs (końcówka sterwonika 002) inpa normalnie się połączyła z silnikiem i innymi modułami, czy to oznacza, że sterownik jest uszkodzony ?
błędy silnika:
130 CAN sygnał ASC -opóźnienie
214 Sygnał prędkości pojazdu (VSS)
8 Przepływomierz powietrza (HFM)
240 przerwy w zapłonie Cyl 3
228 Odchylenie mieszanki Bank 2
203 Lambda regulacja Bank 2 za kat
227 Odchylenie mieszanki Bank 1
auto z lpg
Poleci ktoś sprawdzoną inpe na win 10 ?
sprawdź obdsetup (C:\Ediabas\Hardware\OBD\ )
uruchom i jak będzie dużo błędów to dodaj rejestr do serial
http://chomikuj.pl/M-car/Dokumenty/serial+port,5326921881.reg
po dodaniu rejestru uruchom od nowa obdsetup i sprawdz czy wszystko ok na vin10 to główna przyczyna braku komunikacji interfejsu
jak pozostanie jakiś błąd to uruchom regedit.exe i popraw jak na filmie moim
oczywiście ustawienia interfejsu musza być poprawne opóźnienie 1s com dla viakena to com2 tak samo w EDIABAS/BIN/obd.ini
