BMW NBT Evo - Problem z kodowaniem! NO SIGNAL
Witam, mam problem z BMW M4 2016', nawigacja NBT Evo, po kodowaniu przez EsysPlus na ekranie pojawiło się "No Signal', w esysie nbt nie ma pozycji CAFD, próbowałem "Detect CAFD for SWE", - znalazłem poprawy ale nie przyjmuje, konćzy z błędem:
Caf's suchen
Tal wird generiert
Abarbeitung wird gestartet
TAL execution started.
VCM Update: VCM-Update is deactivated. VCM will not be updated. [C197]
ExecutionID=2016/12/09-16:25:19.158
[] prepareTALExecution started
[] prepareTALExecution finished
[] prepareVehicleForCoding started
[] prepareVehicleForCoding finished
[HU_NBT2 - 63] prepareECUforCoding started
[HU_NBT2 - 63] prepareECUforCoding finished
[HU_NBT2 - 63] authenticateECUforCoding started
[HU_NBT2 - 63] authenticateECUforCoding finished
[HU_NBT2 - 63 - cafd_00001ef6-006_018_016] Transaction type: cdDeploy; Message: TA started
MCDDiagService
[HU_NBT2 - 63 - cafd_00001ef6-006_018_016] Transaction type: cdDeploy; Message: TA finished
[HU_NBT2 - 63] There was an error during TAL execution, please check the log files.
[HU_NBT2 - 63] - [Exception - HU_NBT2 - 63] job failed with negative response error:
code: service returned global negative response
description: Service WDBI_PLAIN returned a negative response with response code requestOutOfRange; ECU: HU_NBT2_63_ETHERNET
severity: ERROR
[HU_NBT2 - 63] finalizeECUCoding started
[HU_NBT2 - 63] finalizeECUCoding finished
[] There was an error, please check the log files.
[] - [Exception - HU_NBT2 - 63] job failed with negative response error:
severity: ERROR
[] finalizeVehicleCoding started
[] finalizeVehicleCoding finished
[] finalizeTALExecution started
[] finalizeTALExecution finished
TAL execution finished
TAL-Execution finished with status: "FinishedWithError". [C207]
TAL execution finished. Duration: "24s". [C206]
Abarbeitung beendet
Później puściłem ISTAP- także kończy kodowanie NBT komunikatem "FinishedWithError"
W Rheingoldzie mam takie błędy:
026308 - HU-H No current coding data stored
02630A - HU-H Coding data not enabled
B7F87F - HU-H encoding fault
B7F880 - HU-H encoding fault
B7F8C3 - Conection, headunit to CID
E14600 - TCB: Ethernet: Unexpected communication termination.
Jakieś pomysły jak to postawić? Z góry wielkie dzięki :)
Zostawic samochod w spokoju i nie dotykać. Ty już swoją misję wypełnił ))) . Nic nie szkodzi, zdarza się . U mnie też niedawno było, najważniejsze, zrozumieć swój błąd i wyciągnąć wnioski.
Twój błąd - to EsysPlus
Jak wersja PSDZDATA w ESYS ?? może masz za starą wersje i nie ma takiego cafd (uzupełnienie jest dla starych modeli nie nowych )
tak samo jak ISTA P do kodowania modelu z 2016 wybierz v59 lub v60 aby była pewność że pliki CAFD są dostępne.
kodowanie do serii powinno przywrócić funkcje (CODE) jak oczywiście nie namieszałeś w FA
Próbuj 3.60
16.11.501
